[U-Boot] Odroid U3 - Upgrade to latest u-boot kernel load fails.
Hi Krzysztof / Marek,
After I update the latest u-boot on my Odroud U3+ it fails to load the kernel it hangs. I am using Archlinux on Odroid U3.
U-Boot 2019.04-rc3-00131-g8303467e80d-dirty (Mar 18 2019 - 12:12:23 +0000)
CPU: Exynos4412 @ 1 GHz Model: Odroid based on Exynos4412 Type: u3 DRAM: 2 GiB LDO20@VDDQ_EMMC_1.8V: set 1800000 uV; enabling LDO22@VDDQ_EMMC_2.8V: set 2800000 uV; enabling LDO21@TFLASH_2.8V: set 2800000 uV; enabling MMC: SAMSUNG SDHCI: 1, EXYNOS DWMMC: 0 Loading Environment from MMC... Card did not respond to voltage select! *** Warning - No block device, using default environment
Net: No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 769 bytes read in 6 ms (125 KiB/s) ## Executing script at 42000000 6901856 bytes read in 253 ms (26 MiB/s) 53078 bytes read in 19 ms (2.7 MiB/s) 6590950 bytes read in 240 ms (26.2 MiB/s) Kernel image @ 0x41000000 [ 0x000000 - 0x695060 ] ## Flattened Device Tree blob at 40800000 Booting using the fdt blob at 0x40800000 Loading Ramdisk to 4f9b6000, end 4ffff1e6 ... OK Loading Device Tree to 4f9a6000, end 4f9b5f55 ... OK
Starting kernel ...
Old u-boot boots fine see the logs below. -------------------------------------------------------------------------------------------------- U-Boot 2018.01-1 (Feb 13 2018 - 02:19:55 +0000) Arch Linux ARM
CPU: Exynos4412 @ 1 GHz Model: Odroid based on Exynos4412 Board: Odroid based on Exynos4412 Type: u3 DRAM: 2 GiB LDO20@VDDQ_EMMC_1.8V: set 1800000 uV; enabling LDO22@VDDQ_EMMC_2.8V: set 2800000 uV; enabling LDO21@TFLASH_2.8V: set 2800000 uV; enabling MMC: sdhci@12530000 - probe failed: -19
*** Warning - bad CRC, using default environment
Net: No ethernet found. Hit any key to stop autoboot: 0 no mmc device at slot 1 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 770 bytes read in 31 ms (23.4 KiB/s) ## Executing script at 50000000 6625416 bytes read in 267 ms (23.7 MiB/s) 72531 bytes read in 483 ms (146.5 KiB/s) 6590888 bytes read in 256 ms (24.6 MiB/s) Kernel image @ 0x42000000 [ 0x000000 - 0x651888 ] ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Ramdisk to 4f9b6000, end 4ffff1a8 ... OK Loading Device Tree to 4f9a1000, end 4f9b5b52 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0xa00 [ 0.000000] Linux version 5.0.1-1-ARCH (builduser@leming) (gcc version 8.2.1 20181127 (GCC)) #1 SMP PREEMPT Tue Mar 12 04:09:35 UTC 2019 [ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Hardkernel ODROID-U3 board based on Exynos4412 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Reserved memory: created DMA memory pool at 0xbf700000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node region_mfc_right, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0xbd300000, size 36 MiB
Please could you share the details on how to debug this issue or how to resolve.
Best Regards -Anand
Starting kernel ...
Can you attach your boot.init file (the source of boot.scr)?
By the size of DTB you can see that different DTB is loaded. I assume you tried to boot the same kernel, then it could mean that boardname was used instead of board_name to choose DTB. Suspicious is that kernel size also differs... so maybe you booted something else? As usual debugging practice, reduce number of unknown factors. Do not change kernel and U-Boot at the same time.
Also, you can try reverting commit e6b1467081d3 ("arm: exynos: Remove duplicated "boardname" env setting") and see if it helps. Or just try to bisect around changes coming from u-boot samsung tree. Try booting v2019.01 and paste the results as well.
Best regards, Krzysztof
Starting kernel ...
Best Regards -Anand
Hi Krzysztof,
Starting kernel ...
I have tested with pre-compiled image and the cross compiled kernel image both failed to load the kernel.
No revert of the commit e6b1467081d3 did not help.
Yes it seem strange that that load address is changes some how in the u-boot env
printenv setting of the latest u-boot U-Boot 2019.04-rc3-00131-g8303467e80d-dirty [0] https://pastebin.com/1Hgc5xxC (newu-boot.txt)
printenv setting for the old u-boot. U-Boot 2018.01-1 [1] https://pastebin.com/wD6zK6eG (oldu-boot.txt)
Attach is the boot.txt (boot.scr), also the u-boot env old and u-boot-env new
Best Regards -Anand
On Mon, 18 Mar 2019 at 18:49, Anand Moon linux.amoon@gmail.com wrote:
Hi Krzysztof,
Starting kernel ...
And does 2019.01 work?
Krzysztof
Hi Krzysztof,
Hi Krzysztof,
Starting kernel ...
I have not tied this version.
Krzysztof
I have flashed the latest Archlinux Image for Odroid U3 on the sdcard. did full update on the kernel image and then tried to update the latest u-boot it failed to boot. It looks like the some u-boot environment settings are incorrect.
Best Regards -Anand
Hi Krzysztof,
Hi Krzysztof,
the
+0000)
select!
Starting kernel ...
u-boot env
u-boot-env new
Krzysztof
It looks like Archlinux uboot for Odroid U3 set some extra environment variable to make this work.
[0] https://github.com/archlinuxarm/PKGBUILDs/blob/master/alarm/uboot-odroid/000... [1] https://github.com/archlinuxarm/PKGBUILDs/blob/master/alarm/uboot-odroid/000...
I gave these patches a try but no success 🤔
Best Regards -Anand
Hi Krzysztof,
On Tue, 19 Mar 2019 at 01:54, Anand Moon linux.amoon@gmail.com wrote:
Hi Krzysztof,
Hi Krzysztof,
Starting kernel ...
Krzysztof
Best Regards -Anand
If found out the commit that break the boot on Odroid U3 Revert of below commit breaks the booting of the kernel.
From: Seung-Woo Kim sw0312.kim@samsung.com Date: Tue, 20 Nov 2018 14:54:39 +0900 Subject: [PATCH] Revert "arm: config: fix default console only to specify the device"
This reverts commit 232ed3ca534708527a9515c7c41bc3542949525c.
In exynos boards, ${console} is used to set bootargs but it sets without "console=", so CONFIG_DEFAULT_CONSOLE for these boards is designated with "console=" but it is removed. So revert the commit.
References for using ${console} in board/samsung/common/bootscripts/autoboot.cmd board/samsung/common/bootscripts/bootzimg.cmd
Please let me know it how to resolve this issue.
Best Regards -Anand
Anand Moon
Krzysztof Kozlowski
