[U-Boot-Users] [PATCH] Add Vitesse 8601 support to TSEC driver
Add phy_info for Vitesse VSC8601. Add config option, CFG_VSC8601_SKEWFIX, to enable RGMII skew timing compensation.
Signed-off-by: Tor Krill tor@excito.com --- drivers/net/tsec.c | 30 ++++++++++++++++++++++++++++++ drivers/net/tsec.h | 5 +++++ 2 files changed, 35 insertions(+), 0 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 431a8d2..9d22aa3 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -1267,6 +1267,35 @@ struct phy_info phy_info_VSC8244 = { }, };
+struct phy_info phy_info_VSC8601 = { + 0x00007042, + "Vitesse VSC8601", + 4, + (struct phy_cmd[]){ /* config */ + /* Override PHY config settings */ + /* Configure some basic stuff */ + {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, +#ifdef CFG_VSC8601_SKEWFIX + {MIIM_VSC8601_EPHY_CON,MIIM_VSC8601_EPHY_CON_INIT_SKEW,NULL}, +#endif + {miim_end,} + }, + (struct phy_cmd[]){ /* startup */ + /* Read the Status (2x to make sure link is right) */ + {MIIM_STATUS, miim_read, NULL}, + /* Auto-negotiate */ + {MIIM_STATUS, miim_read, &mii_parse_sr}, + /* Read the status */ + {MIIM_VSC8244_AUX_CONSTAT, miim_read, + &mii_parse_vsc8244}, + {miim_end,} + }, + (struct phy_cmd[]){ /* shutdown */ + {miim_end,} + }, +}; + + struct phy_info phy_info_dm9161 = { 0x0181b88, "Davicom DM9161E", @@ -1462,6 +1491,7 @@ struct phy_info *phy_info[] = { &phy_info_dm9161, &phy_info_lxt971, &phy_info_VSC8244, + &phy_info_VSC8601, &phy_info_dp83865, &phy_info_rtl8211b, &phy_info_generic, diff --git a/drivers/net/tsec.h b/drivers/net/tsec.h index d4dc15a..cfa7d1a 100644 --- a/drivers/net/tsec.h +++ b/drivers/net/tsec.h @@ -159,6 +159,11 @@ #define MIIM_VSC8244_LED_CON 0x1b #define MIIM_VSC8244_LEDCON_INIT 0xF011
+/* Entry for Vitesse VSC8601 regs starts here (Not complete) */ +/* Vitesse VSC8601 Extended PHY Control Register 1 */ +#define MIIM_VSC8601_EPHY_CON 0x17 +#define MIIM_VSC8601_EPHY_CON_INIT_SKEW 0x1120 + /* 88E1011 PHY Status Register */ #define MIIM_88E1011_PHY_STATUS 0x11 #define MIIM_88E1011_PHYSTAT_SPEED 0xc000
Tor,
what a pitty - I've been working on this for 2 days now. I did not implement the skew since I configured it by hardware strapping.
Very interesting PHY : low power, self calibrating ...... and cheap :-)
Is yor PHY already up and running including data ?
regards, André Schwarz Matrix Vision
0x00007042,
"Vitesse VSC8601",
4,
{miim_end,}
{miim_end,}
{miim_end,}
- &phy_info_VSC8601, &phy_info_dp83865, &phy_info_rtl8211b, &phy_info_generic,
MATRIX VISION GmbH, Talstraße 16, DE-71570 Oppenweiler - Registergericht: Amtsgericht Stuttgart, HRB 271090 Geschäftsführer: Gerhard Thullner, Werner Armingeon, Uwe Furtner
Ben regarding your call for network related patches. Im not sure if i should have sent this one to you? Got no reactions on it.
/Tor
0x00007042,
"Vitesse VSC8601",
4,
{miim_end,}
{miim_end,}
{miim_end,}
1.5.4.4
Acked-by: Ben Warren biggerbadderben@gmail.com
0x00007042,
"Vitesse VSC8601",
4,
{miim_end,}
{miim_end,}
{miim_end,}
On Mon, 31 Mar 2008 10:01:34 -0400 Ben Warren biggerbadderben@gmail.com wrote:
I don't have a Vitesse 8601, so technically I can't ack it, but I can:
Reviewed-by: Kim Phillips kim.phillips@freescale.com
minor nit: it would be nice if the following:
were made to have spaces after commas, and flow onto a separate line so as to not be a 96 char line..
Kim
Kim,
would it help if we donate one or two boards to the custodians ? Or do you have no time at all for specific testing ?
After bring-up + validation I could offer 1-2 MPC8343B based boards with 2x VSC8601. The system also has a miniPCI Slot, USB-A and 512MB DDR-II Micron memory.
Please let me know if you're interested.
regards, Andre Schwarz Matrix Vision
Kim
Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Tor,
after all my VSC8601 is up and running on MPC8343 :-)
I'm sorry to say that I don't find this patch ok after going through the manuals :
Register 0x17 is a very coarse setting. If the capabilities of the PHY should be taken into account and be configurable we should use the skew control in extended register 0x1c. This should be definable - CFG_VSC8601_SKEWFIX simply applies maximum skew ...
After all changing the bits in register 0x17 _require_ a soft reset by asserting bit 15 in register 0 before they are going to work.
Obviously this patch has no effect at all. Do you reset the PHY manually after this configuration ?
This PHY definitely needs a proper setup function since there are quite interesting registers which need read-modify-write.
What do you think ?
regards, Andre
Kim
On 4/17/2008, "Andre Schwarz" andre.schwarz@matrix-vision.de wrote:
Tor,
Sure it certainly could have been done in a more configurable way. But you have to decide what you need. For us this was an apropriate level atm that scratched our itch. If we where to expose every setting from the start we still would not have been done ;)
According to our datasheet (dated july 2006) only changes of bit 12 in this register needs a software reset to take. We don't reset the phy after changing this and the change obviously work (we have tested and verified that it won't work without the change).
What do you think ?
Perhaps a patch to improve what you find missing?
/Tor
Kim
Tor,
at last I could solve my "strange" behaviour.
Actually the PHY definitely uses both 2 bit definitions of Rx and Tx Skew at "RGMII Skew Control Reg" 0x1c - which are set up by eeprom or strapping.
Due to noise or strapping resistor mismatch these setting are not always like I want them to be.
Setting bit 8 in "Extended PHY Control 1" @ 0x17 activates the delay lines. Obviously your Skew values did match.
I'll send a patch to configure the delay.
Cheers, Andre
Tor,
What do you think ?
/Tor
Kim
MATRIX VISION GmbH, Talstra�e 16, DE-71570 Oppenweiler - Registergericht: Amtsgericht Stuttgart, HRB 271090 Gesch�ftsf�hrer: Gerhard Thullner, Werner Armingeon, Uwe Furtner
Tor,
after investigating the tsec code I'm wondering how your PHY works in RGMII mode ...
I think that there are some things missing, e.g. taking RGMII into account during tsec_init.
/* Init ECNTRL */ regs->ecntrl = ECNTRL_INIT_SETTINGS;
This will clear bit 27 which indicates RGMII as set up by the HRCW.
I would expect something like
if ( priv->flags & TSEC_REDUCED ) regs->ecntrl |= ECNTRL_RPM;
afterwards.
Before I'll start doing double work again : Have you some unposted patches regarding RGMII on TSEC ?
Am I missing something ?
@Kim : Did you ever run a MPC834x with a RGMII PHY ? Is it known to work ?
regards, Andre
0x00007042,
"Vitesse VSC8601",
4,
{miim_end,}
{miim_end,}
{miim_end,}
On Tue, Apr 1, 2008 at 8:33 AM, Andre Schwarz andre.schwarz@matrix-vision.de wrote:
Tor,
If you look carefully, you'll notice that ecntrl's RPM bit is read-only. Those bits are configured by POR pin strappings.
You may be more familiar with the UEC, which doesn't automatically detect the link type, but is otherwise fairly similar to the tsec.
Andy
Tor,
sorry, my documentation (MPC8349EARM rev.1) declares this register read-write. Of course it will be configured by the HRCW but can be overwritten afterwards.
If this is not true it's a documentation bug.
What do you mean ? I'm trying to get two VSC8601 RGMII PHYs running on a MPC8343B ...
Andy
regards, Andre
On Tue, Apr 1, 2008 at 9:08 AM, Andre Schwarz andre.schwarz@matrix-vision.de wrote:
Tor,
Thank you for bringing this to my attention. It is almost certainly a bug. If you look at the 8349ERM (rather than the 8349EARM), you'll see that the bits are read-only (except for R100, which tsec.c does modify based on the link type). I will file a bug with the docs people.
sorry, I forgot which ethernet controller you were using, and I'm not as familiar with the 83xx family as the 85xx family. Some of our parts have the QUICC Engine, which has an ethernet controller with some similar registers to the TSEC's. I was guessing that was why you thought those bits were writable, rather than a documentation bug, but clearly I was wrong. :)
Andy
Andy
Tor,
I've x-checked and printed the register after init. You're right - it's read only and the RPM bit is set. But the ECNTL register description @ 15.5.3.1.4 says "read/write" to all bits ...
no problem.
Andre
Andy
Andy
On Tue, 01 Apr 2008 15:33:10 +0200 Andre Schwarz andre.schwarz@matrix-vision.de wrote:
yeah, that register should be r/o..
834x? I haven't, but I also haven't a reason why it would not work :)
Kim
you're right. The register actually _is_ r/o. But datasheet says "r/w" ...
ok - I'll have a closer look into the hardware.
Kim
thanks, André
participants (7)
Andre Schwarz
André Schwarz
André Schwarz
Andy Fleming
Ben Warren
Kim Phillips
Tor Krill
