[U-Boot] Please pull u-boot-ti/master
Hey,
The following changes since commit 8ee950dd273aef6a074d41bf2ee4ef11d6f848fb:
Prepare v2014.04-rc2 (2014-03-10 17:21:06 -0400)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to d157776388b2b6cb819e76a56d3c63e604d8b291:
arm: am335x: DXR2: Move unconditional LAN9303 reset into command (2014-03-12 14:51:45 -0400)
---------------------------------------------------------------- Hannes Petermaier (1): board/BuR/kwb: fix usage of 'i2c_set_bus_speed'
Ilya Ledvich (1): drivers: net: cpsw: init phy with gigabit features
Stefan Roese (2): arm: omap: cm_t35: Fix: Re-add GPMC_NAND_ECC_LP_x8_LAYOUT arm: am335x: DXR2: Move unconditional LAN9303 reset into command
Tom Rini (2): am33xx: Rework #ifdef's around s_init for clarity am335x_evm: Remove SPI SPL from NOR support target
Vasili Galka (1): drivers/spi/omap3: Bug fix of premature write transfer completion
arch/arm/cpu/armv7/am33xx/board.c | 8 +++----- board/BuR/kwb/board.c | 4 ++-- board/siemens/dxr2/board.c | 26 +++++++++++++++++++------- drivers/net/cpsw.c | 6 +----- drivers/spi/omap3_spi.c | 5 +++-- include/configs/am335x_evm.h | 2 ++ include/configs/cm_t35.h | 2 ++ 7 files changed, 32 insertions(+), 21 deletions(-)
On Wed, Mar 12, 2014 at 04:05:05PM -0400, Tom Rini wrote:
Hey,
Ooops, updated as..
for you to fetch changes up to aadf3192f83a55dbbdb0d395ee5af88b6560edcb:
board/BuR/kwb: fix usage of 'i2c_set_bus_speed' (2014-03-12 16:22:16 -0400)
Hi Tom,
Hey,
Ooops, updated as..
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
