[U-Boot-Users] Support for ALTERA FPGAs
Hi there,
the patch attached adds support for ALTERA FPGAs. For now only the ACEX1K using the so called "passive serial" Interface.
The code and idea is heavily stolen from the xilinx stuff. And just like there the board specific code has to provide some functions for handling the FPGA signals CONF_DONE, DATA, DCLK, nCONFIG, nSTATUS.
I thought I release it quite early to avoid redundant work done by others and hope this could be a usefull starting point for people using Altera FPGAs.
* Patch by Steven Scholz, 10 Oct 2003 - Add support for Altera FPGA ACEX1K
Cheers,
Dear Steven,
- Patch by Steven Scholz, 10 Oct 2003
Mostly added. There is a small bug in the patch, which I tried to fix:
Index: common/Makefile =================================================================== RCS file: /cvsroot/u-boot/u-boot/common/Makefile,v retrieving revision 1.10 diff -p -u -r1.10 Makefile --- common/Makefile 27 Jul 2003 00:21:15 -0000 1.10 +++ common/Makefile 9 Oct 2003 16:50:34 -0000 @@ -47,7 +47,8 @@ COBJS = main.o altera.o bedbug.o \ hush.o kgdb.o lists.o lynxkdi.o miiphybb.o miiphyutil.o \ s_record.o soft_i2c.o soft_spi.o spartan2.o \ usb.o usb_kbd.o usb_storage.o \ - virtex2.o xilinx.o + virtex2.o xilinx.o \ + altera.o ACEX1K.o
You add "altera.o" which is already present in the list of objects ? [Also you ignore ordering :-( ]
Added, thanks. Will show up on CVS soon.
Dear Wolfgang,
the patch attached adds support for ALTERA FPGAs. For now only the ACEX1K using the so called "passive serial" Interface. ...
Oops.
I've overseen the altera.o. And I did not know that order here is important! Why is it? Why was altera at.o the beginning of the list? Is it in alphabetical order?
Dear Steven,
Oops.
For esthetical reasons, and and easo of work, and reliability. Searching an item or verifying if it already exists is much easier if such lists are kept sorted.
Indeed.
Dear Wolfgang,
how long does it usually take for your changes to appear on sourceforge?
Because there still not there? :-(
Dear Steven,
I'm sorry, ther eis little I can do but hope the situation will improve soon as SF has been promising for some time. Please feel free to check the CVS status page at SF at http://sourceforge.net/docman/display_doc.php?docid=2352&group_id=1#cvs
Steven Scholz
