[U-Boot-Users] [PATCH 4/6] mpc83xx: move common /memory node update mechanism to cpu.c
also adds common prototypes to include/common.h.
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- board/freescale/mpc8323erdb/mpc8323erdb.c | 22 -------------------- board/mpc8360emds/mpc8360emds.c | 31 +---------------------------- cpu/mpc83xx/cpu.c | 31 +++++++++++++++++++++------- include/common.h | 7 ++++++ 4 files changed, 31 insertions(+), 60 deletions(-)
diff --git a/board/freescale/mpc8323erdb/mpc8323erdb.c b/board/freescale/mpc8323erdb/mpc8323erdb.c index 1886f19..81b82b7 100644 --- a/board/freescale/mpc8323erdb/mpc8323erdb.c +++ b/board/freescale/mpc8323erdb/mpc8323erdb.c @@ -17,7 +17,6 @@ #include <miiphy.h> #include <command.h> #include <libfdt.h> -#include <libfdt_env.h> #if defined(CONFIG_PCI) #include <pci.h> #endif @@ -185,31 +184,10 @@ void pci_init_board(void) }
#if defined(CONFIG_OF_BOARD_SETUP) - -/* - * Prototypes of functions that we use. - */ -void ft_cpu_setup(void *blob, bd_t *bd); - -#ifdef CONFIG_PCI -void ft_pci_setup(void *blob, bd_t *bd); -#endif - void ft_board_setup(void *blob, bd_t *bd) { - int nodeoffset; - int tmp[2]; - - nodeoffset = fdt_find_node_by_path(blob, "/memory"); - if (nodeoffset >= 0) { - tmp[0] = cpu_to_be32(bd->bi_memstart); - tmp[1] = cpu_to_be32(bd->bi_memsize); - fdt_setprop(blob, nodeoffset, "reg", tmp, sizeof(tmp)); - } - ft_cpu_setup(blob, bd); - #ifdef CONFIG_PCI ft_pci_setup(blob, bd); #endif diff --git a/board/mpc8360emds/mpc8360emds.c b/board/mpc8360emds/mpc8360emds.c index e37d2dc..eec46fb 100644 --- a/board/mpc8360emds/mpc8360emds.c +++ b/board/mpc8360emds/mpc8360emds.c @@ -29,7 +29,6 @@ #include <ft_build.h> #elif defined(CONFIG_OF_LIBFDT) #include <libfdt.h> -#include <libfdt_env.h> #endif
const qe_iop_conf_t qe_iop_conf_tab[] = { @@ -287,38 +286,10 @@ void sdram_init(void)
#if (defined(CONFIG_OF_FLAT_TREE) || defined(CONFIG_OF_LIBFDT)) \ && defined(CONFIG_OF_BOARD_SETUP) - -/* - * Prototypes of functions that we use. - */ -void ft_cpu_setup(void *blob, bd_t *bd); - -#ifdef CONFIG_PCI -void ft_pci_setup(void *blob, bd_t *bd); -#endif - void ft_board_setup(void *blob, bd_t *bd) { -#if defined(CONFIG_OF_LIBFDT) - int nodeoffset; - int tmp[2]; - - nodeoffset = fdt_find_node_by_path(blob, "/memory"); - if (nodeoffset < 0) { - nodeoffset = fdt_add_subnode(blob, 0, "memory"); - if (nodeoffset < 0) - printf("WARNING: failed to add /memory node: %s\n", - fdt_strerror(nodeoffset)); - } - if (nodeoffset >= 0) { - fdt_setprop(blob, nodeoffset, "device_type", - "memory", sizeof("memory")); - tmp[0] = cpu_to_be32(bd->bi_memstart); - tmp[1] = cpu_to_be32(bd->bi_memsize); - fdt_setprop(blob, nodeoffset, "reg", tmp, sizeof(tmp)); - } -#else +#if defined(CONFIG_OF_FLAT_TREE) u32 *p; int len;
diff --git a/cpu/mpc83xx/cpu.c b/cpu/mpc83xx/cpu.c index 4deb5e5..e634f0a 100644 --- a/cpu/mpc83xx/cpu.c +++ b/cpu/mpc83xx/cpu.c @@ -523,9 +523,10 @@ static const struct { void ft_cpu_setup(void *blob, bd_t *bd) { - int nodeoffset; - int err; - int j; + int nodeoffset; + int err; + int j; + int tmp[2];
for (j = 0; j < (sizeof(fixup_props) / sizeof(fixup_props[0])); j++) { nodeoffset = fdt_find_node_by_path(blob, fixup_props[j].node); @@ -534,15 +535,29 @@ ft_cpu_setup(void *blob, bd_t *bd) fixup_props[j].prop, bd); if (err < 0) debug("Problem setting %s = %s: %s\n", - fixup_props[j].node, - fixup_props[j].prop, - fdt_strerror(err)); + fixup_props[j].node, fixup_props[j].prop, + fdt_strerror(err)); } else { debug("Couldn't find %s: %s\n", - fixup_props[j].node, - fdt_strerror(nodeoffset)); + fixup_props[j].node, fdt_strerror(nodeoffset)); } } + + /* update, or add and update /memory node */ + nodeoffset = fdt_find_node_by_path(blob, "/memory"); + if (nodeoffset < 0) { + nodeoffset = fdt_add_subnode(blob, 0, "memory"); + if (nodeoffset < 0) + debug("failed to add /memory node: %s\n", + fdt_strerror(nodeoffset)); + } + if (nodeoffset >= 0) { + fdt_setprop(blob, nodeoffset, "device_type", + "memory", sizeof("memory")); + tmp[0] = cpu_to_be32(bd->bi_memstart); + tmp[1] = cpu_to_be32(bd->bi_memsize); + fdt_setprop(blob, nodeoffset, "reg", tmp, sizeof(tmp)); + } } #elif defined(CONFIG_OF_FLAT_TREE) void diff --git a/include/common.h b/include/common.h index 27a660a..9a5a0ab 100644 --- a/include/common.h +++ b/include/common.h @@ -434,6 +434,13 @@ int checkdcache (void); void upmconfig (unsigned int, unsigned int *, unsigned int); ulong get_tbclk (void); void reset_cpu (ulong addr); +#if defined (CONFIG_OF_LIBFDT) && defined (CONFIG_OF_BOARD_SETUP) +void ft_cpu_setup(void *blob, bd_t *bd); +#ifdef CONFIG_PCI +void ft_pci_setup(void *blob, bd_t *bd); +#endif +#endif +
/* $(CPU)/serial.c */ int serial_init (void);
Kim Phillips
