[U-Boot] [PATCH 1/6] powerpc: p2041: dts: Added Sata DT nodes
This patch is to add sata node for P2041 platform
Signed-off-by: Peng Ma peng.ma@nxp.com --- arch/powerpc/dts/p2041.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/powerpc/dts/p2041.dtsi b/arch/powerpc/dts/p2041.dtsi index 55f7adc..239439d 100644 --- a/arch/powerpc/dts/p2041.dtsi +++ b/arch/powerpc/dts/p2041.dtsi @@ -59,6 +59,15 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + sata: sata@220000 { + compatible = "fsl,pq-sata-v2"; + reg = <0x220000 0x1000>; + interrupts = <68 0x2 0 0>; + sata-offset = <0x1000>; + sata-number = <2>; + sata-fpdma = <0>; + }; };
pcie@ffe200000 {
This patch is to add sata node for P3041 platform
Signed-off-by: Peng Ma peng.ma@nxp.com --- arch/powerpc/dts/p3041.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/powerpc/dts/p3041.dtsi b/arch/powerpc/dts/p3041.dtsi index 197896d..23bde81 100644 --- a/arch/powerpc/dts/p3041.dtsi +++ b/arch/powerpc/dts/p3041.dtsi @@ -59,6 +59,15 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + sata: sata@220000 { + compatible = "fsl,pq-sata-v2"; + reg = <0x220000 0x1000>; + interrupts = <68 0x2 0 0>; + sata-offset = <0x1000>; + sata-number = <2>; + sata-fpdma = <0>; + }; };
pcie@ffe200000 {
This patch is to add sata node for P5040 platform
Signed-off-by: Peng Ma peng.ma@nxp.com --- arch/powerpc/dts/p5040.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/powerpc/dts/p5040.dtsi b/arch/powerpc/dts/p5040.dtsi index 8ab123d..7b8218a 100644 --- a/arch/powerpc/dts/p5040.dtsi +++ b/arch/powerpc/dts/p5040.dtsi @@ -58,6 +58,15 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + sata: sata@220000 { + compatible = "fsl,pq-sata-v2"; + reg = <0x220000 0x1000>; + interrupts = <68 0x2 0 0>; + sata-offset = <0x1000>; + sata-number = <2>; + sata-fpdma = <0>; + }; };
pcie@ffe200000 {
This patch is to add sata node for T102x platform
Signed-off-by: Peng Ma peng.ma@nxp.com --- arch/powerpc/dts/t102x.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/powerpc/dts/t102x.dtsi b/arch/powerpc/dts/t102x.dtsi index c49fd21..7d3f7c5 100644 --- a/arch/powerpc/dts/t102x.dtsi +++ b/arch/powerpc/dts/t102x.dtsi @@ -48,6 +48,15 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + sata: sata@220000 { + compatible = "fsl,pq-sata-v2"; + reg = <0x220000 0x1000>; + interrupts = <68 0x2 0 0>; + sata-offset = <0x1000>; + sata-number = <2>; + sata-fpdma = <0>; + }; };
pcie@ffe240000 {
This patch is to add sata node for T104x platform
Signed-off-by: Peng Ma peng.ma@nxp.com --- arch/powerpc/dts/t104x.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/powerpc/dts/t104x.dtsi b/arch/powerpc/dts/t104x.dtsi index 5998967..fe6cc3c 100644 --- a/arch/powerpc/dts/t104x.dtsi +++ b/arch/powerpc/dts/t104x.dtsi @@ -58,6 +58,15 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + sata: sata@220000 { + compatible = "fsl,pq-sata-v2"; + reg = <0x220000 0x1000>; + interrupts = <68 0x2 0 0>; + sata-offset = <0x1000>; + sata-number = <2>; + sata-fpdma = <0>; + }; };
pcie@ffe240000 {
This patch is to add sata node for T4240 platform
Signed-off-by: Peng Ma peng.ma@nxp.com --- arch/powerpc/dts/t4240.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/powerpc/dts/t4240.dtsi b/arch/powerpc/dts/t4240.dtsi index fc34974..3bda2fa 100644 --- a/arch/powerpc/dts/t4240.dtsi +++ b/arch/powerpc/dts/t4240.dtsi @@ -98,6 +98,15 @@ device_type = "open-pic"; clock-frequency = <0x0>; }; + + sata: sata@220000 { + compatible = "fsl,pq-sata-v2"; + reg = <0x220000 0x1000>; + interrupts = <68 0x2 0 0>; + sata-offset = <0x1000>; + sata-number = <2>; + sata-fpdma = <0>; + }; };
pcie@ffe240000 {
Peng Ma
