[U-Boot] [PATCH] board: ti: am43xx: remove net platform code
The TI AM43xx platform has DM_ETH and OF_CONTROL enabled, so remove networking platform code.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- board/ti/am43xx/board.c | 106 +--------------------------------------- 1 file changed, 1 insertion(+), 105 deletions(-)
diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index f5ecf871bc..7ec9c38e6a 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -8,6 +8,7 @@ */
#include <common.h> +#include <dm/uclass.h> #include <env.h> #include <i2c.h> #include <linux/errno.h> @@ -26,8 +27,6 @@ #include <power/pmic.h> #include <power/tps65218.h> #include <power/tps62362.h> -#include <miiphy.h> -#include <cpsw.h> #include <linux/usb/gadget.h> #include <dwc3-uboot.h> #include <dwc3-omap-uboot.h> @@ -851,109 +850,6 @@ int board_usb_cleanup(int index, enum usb_init_type init) #endif /* defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_OMAP) */ #endif /* !CONFIG_IS_ENABLED(DM_USB_GADGET) */
-#ifdef CONFIG_DRIVER_TI_CPSW - -static void cpsw_control(int enabled) -{ - /* Additional controls can be added here */ - return; -} - -static struct cpsw_slave_data cpsw_slaves[] = { - { - .slave_reg_ofs = 0x208, - .sliver_reg_ofs = 0xd80, - .phy_addr = 16, - }, - { - .slave_reg_ofs = 0x308, - .sliver_reg_ofs = 0xdc0, - .phy_addr = 1, - }, -}; - -static struct cpsw_platform_data cpsw_data = { - .mdio_base = CPSW_MDIO_BASE, - .cpsw_base = CPSW_BASE, - .mdio_div = 0xff, - .channels = 8, - .cpdma_reg_ofs = 0x800, - .slaves = 1, - .slave_data = cpsw_slaves, - .ale_reg_ofs = 0xd00, - .ale_entries = 1024, - .host_port_reg_ofs = 0x108, - .hw_stats_reg_ofs = 0x900, - .bd_ram_ofs = 0x2000, - .mac_control = (1 << 5), - .control = cpsw_control, - .host_port_num = 0, - .version = CPSW_CTRL_VERSION_2, -}; - -int board_eth_init(bd_t *bis) -{ - int rv; - uint8_t mac_addr[6]; - uint32_t mac_hi, mac_lo; - - /* try reading mac address from efuse */ - mac_lo = readl(&cdev->macid0l); - mac_hi = readl(&cdev->macid0h); - mac_addr[0] = mac_hi & 0xFF; - mac_addr[1] = (mac_hi & 0xFF00) >> 8; - mac_addr[2] = (mac_hi & 0xFF0000) >> 16; - mac_addr[3] = (mac_hi & 0xFF000000) >> 24; - mac_addr[4] = mac_lo & 0xFF; - mac_addr[5] = (mac_lo & 0xFF00) >> 8; - - if (!env_get("ethaddr")) { - puts("<ethaddr> not set. Validating first E-fuse MAC\n"); - if (is_valid_ethaddr(mac_addr)) - eth_env_set_enetaddr("ethaddr", mac_addr); - } - - mac_lo = readl(&cdev->macid1l); - mac_hi = readl(&cdev->macid1h); - mac_addr[0] = mac_hi & 0xFF; - mac_addr[1] = (mac_hi & 0xFF00) >> 8; - mac_addr[2] = (mac_hi & 0xFF0000) >> 16; - mac_addr[3] = (mac_hi & 0xFF000000) >> 24; - mac_addr[4] = mac_lo & 0xFF; - mac_addr[5] = (mac_lo & 0xFF00) >> 8; - - if (!env_get("eth1addr")) { - if (is_valid_ethaddr(mac_addr)) - eth_env_set_enetaddr("eth1addr", mac_addr); - } - - if (board_is_eposevm()) { - writel(RMII_MODE_ENABLE | RMII_CHIPCKL_ENABLE, &cdev->miisel); - cpsw_slaves[0].phy_if = PHY_INTERFACE_MODE_RMII; - cpsw_slaves[0].phy_addr = 16; - } else if (board_is_sk()) { - writel(RGMII_MODE_ENABLE, &cdev->miisel); - cpsw_slaves[0].phy_if = PHY_INTERFACE_MODE_RGMII; - cpsw_slaves[0].phy_addr = 4; - cpsw_slaves[1].phy_addr = 5; - } else if (board_is_idk()) { - writel(RGMII_MODE_ENABLE, &cdev->miisel); - cpsw_slaves[0].phy_if = PHY_INTERFACE_MODE_RGMII; - cpsw_slaves[0].phy_addr = 0; - } else { - writel(RGMII_MODE_ENABLE, &cdev->miisel); - cpsw_slaves[0].phy_if = PHY_INTERFACE_MODE_RGMII; - cpsw_slaves[0].phy_addr = 0; - } - - rv = cpsw_register(&cpsw_data); - if (rv < 0) - printf("Error %d registering CPSW switch\n", rv); - - return rv; -} -#endif - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, bd_t *bd) {
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
Grygorii Strashko
Lokesh Vutla
