[PATCH 1/1] Add mmc_set_env_dev to TI AM33xx, using the scratch reg of UART port
Signed-off-by: Dashi Cao dscao999@gmail.com --- board/ti/am335x/board.c | 40 ++++++++++++++++++++++++++++++++++++++++ common/spl/spl.c | 6 ++++++ drivers/mmc/mmc.c | 4 ++++ include/mmc.h | 1 + 4 files changed, 51 insertions(+)
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 7c0545892c..577e4f2b1f 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -1010,3 +1010,43 @@ U_BOOT_DRVINFO(am335x_mmc1) = { .plat = &am335x_mmc1_plat, }; #endif + +#if defined(CONFIG_SPL_MMC) && defined(CONFIG_AM33XX) +struct uart_reg { + u16 resv0[4]; + u16 uart_efr; + u16 resv1[3]; + u16 uart_mcr; + u16 resv2[5]; + u16 uart_spr; +}; + +int mmc_get_env_dev(void) +{ + u16 bdev = 0; + u16 efr, mcr; + volatile struct uart_reg *uart = (void *)UART0_BASE; + + efr = uart->uart_efr; + mcr = uart->uart_mcr; + if ((efr & 0x10) == 0 || (mcr & 0x40) == 0) + bdev = uart->uart_spr; + else + printf("Cannot get mmc dev number from uart0 scratch reg\n"); + + return (bdev & 0x0ff); +} + +void mmc_set_env_dev(u16 bdev) +{ + u16 efr, mcr; + volatile struct uart_reg *uart = (void *)UART0_BASE; + + efr = uart->uart_efr; + mcr = uart->uart_mcr; + if ((efr & 0x10) == 0 || (mcr & 0x40) == 0) + uart->uart_spr = (bdev & 0x0ff); + else + printf("Cannot set mmc dev number to uart0 scratch reg\n"); +} +#endif diff --git a/common/spl/spl.c b/common/spl/spl.c index c8c463f80b..a14ae76698 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -37,6 +37,7 @@ #include <fdt_support.h> #include <bootcount.h> #include <wdt.h> +#include <mmc.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -723,6 +724,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) }; struct spl_image_info spl_image; int ret; + short bootdev;
debug(">>" SPL_TPL_PROMPT "board_init_r()\n");
@@ -798,6 +800,10 @@ void board_init_r(gd_t *dummy1, ulong dummy2) puts(SPL_TPL_PROMPT "failed to boot from all boot devices\n"); hang(); } + bootdev = spl_image.boot_device - BOOT_DEVICE_MMC1; + if (bootdev < 0) + bootdev = -bootdev; + mmc_set_env_dev(bootdev);
spl_perform_fixups(&spl_image); if (CONFIG_IS_ENABLED(HANDOFF)) { diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 8a7d073900..8c941b575a 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -3133,3 +3133,7 @@ __weak int mmc_get_env_dev(void) return 0; #endif } + +__weak void mmc_set_env_dev(u16 bootdev) +{ +} diff --git a/include/mmc.h b/include/mmc.h index 9b4dc68311..3c09652382 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -943,6 +943,7 @@ int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr); extern uint mmc_get_env_part(struct mmc *mmc); # endif int mmc_get_env_dev(void); +void mmc_set_env_dev(u16 bootdev);
/* Minimum partition switch timeout in units of 10-milliseconds */ #define MMC_MIN_PART_SWITCH_TIME 30 /* 300 ms */
So, this should be done more generically. And it's hard to say how exactly without seeing how you've done mmc_get_env_dev() for your platform.
Da Shi Cao
