[PATCH v2 0/3] libfdt: make lib/libfdt/ contain only wrappers
Linux DT community follows the strict rule that they never locally modify libfdt. In Linux, lib/fdt_*.c are wrapper files to scripts/dtc/libfdt/fdt_*.c and scripts/dtc/ is synced with upstream DTC by running scripts/dtc/update-dtc-source.sh The local code in Linux is separated in drivers/of/.
On the other hand, U-Boot originally had own copies in lib/libfdt/, and people locally modified them. The code diverged, and made it difficult to re-sync with upstream.
In 2018, I worked on migrating them to wrapper files, just like Linux does. 50a327ded68b7e675389ad284ea3f8c62e683bda 87be1e9fb4dcc130e90d497cc5ce49c715efc6c2 26e961c8cfdff00c5c9389d301d9a2eb10eb844c
This series completes this work.
1/3 migrates fdt_ro.c to a wrapper. Two years ago, it diverged from the upstream, and gave up resync. Now, I do not see essential diff.
2/3 and 3/3 separate fdt_region out of the upstream code. I am resending them after two years since the previous rejection. It was unfortuate that they were rejected based on the assumption that is unlikely to happen. They should be re-evaluated.
Masahiro Yamada (3): libfdt: migrate fdt_ro.c to a wrapper of scripts/dtc/libfdt/fdt_ro.c fdt_region: move fdt_region.c to common/ from lib/libfdt/ libfdt: split fdt_region declarations out to <fdt_region.h>
common/Makefile | 1 + {lib/libfdt => common}/fdt_region.c | 1 + common/image-fit-sig.c | 1 + include/fdt_region.h | 304 +++++++++ include/linux/libfdt.h | 299 --------- lib/libfdt/Makefile | 9 +- lib/libfdt/fdt_ro.c | 925 +--------------------------- tools/Makefile | 13 +- tools/fdtgrep.c | 1 + tools/image-host.c | 1 + tools/libfdt/fdt_ro.c | 2 + 11 files changed, 317 insertions(+), 1240 deletions(-) rename {lib/libfdt => common}/fdt_region.c (99%) create mode 100644 include/fdt_region.h create mode 100644 tools/libfdt/fdt_ro.c
There is no essential difference between scripts/dtc/libfdt/fdt_ro.c and lib/libfdt/fdt_ro.c
Migrate to a simple wrapper like the other files.
Signed-off-by: Masahiro Yamada masahiroy@kernel.org ---
Changes in v2: - refactor tools/Makefile
lib/libfdt/Makefile | 6 +- lib/libfdt/fdt_ro.c | 925 +----------------------------------------- tools/Makefile | 5 +- tools/libfdt/fdt_ro.c | 2 + 4 files changed, 6 insertions(+), 932 deletions(-) create mode 100644 tools/libfdt/fdt_ro.c
diff --git a/lib/libfdt/Makefile b/lib/libfdt/Makefile index 5d3ae4e2f1..878659f99e 100644 --- a/lib/libfdt/Makefile +++ b/lib/libfdt/Makefile @@ -3,9 +3,9 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-# Use upstream code. obj-y += \ fdt.o \ + fdt_ro.o \ fdt_wip.o \ fdt_strerror.o \ fdt_sw.o \ @@ -15,10 +15,6 @@ obj-y += \
obj-$(CONFIG_OF_LIBFDT_OVERLAY) += fdt_overlay.o
-# Locally modified for U-Boot. -# TODO: split out the local modifiction. -obj-y += fdt_ro.o - # U-Boot own file obj-y += fdt_region.o
diff --git a/lib/libfdt/fdt_ro.c b/lib/libfdt/fdt_ro.c index be03aea9eb..7ede074537 100644 --- a/lib/libfdt/fdt_ro.c +++ b/lib/libfdt/fdt_ro.c @@ -1,925 +1,2 @@ -// SPDX-License-Identifier: GPL-2.0+ OR BSD-2-Clause -/* - * libfdt - Flat Device Tree manipulation - * Copyright (C) 2006 David Gibson, IBM Corporation. - */ #include <linux/libfdt_env.h> - -#ifndef USE_HOSTCC -#include <fdt.h> -#include <linux/libfdt.h> -#else -#include "fdt_host.h" -#endif - -#include "libfdt_internal.h" - -static int fdt_nodename_eq_(const void *fdt, int offset, - const char *s, int len) -{ - int olen; - const char *p = fdt_get_name(fdt, offset, &olen); - - if (!p || (fdt_chk_extra() && olen < len)) - /* short match */ - return 0; - - if (memcmp(p, s, len) != 0) - return 0; - - if (p[len] == '\0') - return 1; - else if (!memchr(s, '@', len) && (p[len] == '@')) - return 1; - else - return 0; -} - -const char *fdt_get_string(const void *fdt, int stroffset, int *lenp) -{ - int32_t totalsize; - uint32_t absoffset; - size_t len; - int err; - const char *s, *n; - - if (!fdt_chk_extra()) { - s = (const char *)fdt + fdt_off_dt_strings(fdt) + stroffset; - - if (lenp) - *lenp = strlen(s); - return s; - } - totalsize = fdt_ro_probe_(fdt); - err = totalsize; - if (totalsize < 0) - goto fail; - - err = -FDT_ERR_BADOFFSET; - absoffset = stroffset + fdt_off_dt_strings(fdt); - if (absoffset >= totalsize) - goto fail; - len = totalsize - absoffset; - - if (fdt_magic(fdt) == FDT_MAGIC) { - if (stroffset < 0) - goto fail; - if (!fdt_chk_version() || fdt_version(fdt) >= 17) { - if (stroffset >= fdt_size_dt_strings(fdt)) - goto fail; - if ((fdt_size_dt_strings(fdt) - stroffset) < len) - len = fdt_size_dt_strings(fdt) - stroffset; - } - } else if (fdt_magic(fdt) == FDT_SW_MAGIC) { - if ((stroffset >= 0) - || (stroffset < -fdt_size_dt_strings(fdt))) - goto fail; - if ((-stroffset) < len) - len = -stroffset; - } else { - err = -FDT_ERR_INTERNAL; - goto fail; - } - - s = (const char *)fdt + absoffset; - n = memchr(s, '\0', len); - if (!n) { - /* missing terminating NULL */ - err = -FDT_ERR_TRUNCATED; - goto fail; - } - - if (lenp) - *lenp = n - s; - return s; - -fail: - if (lenp) - *lenp = err; - return NULL; -} - -const char *fdt_string(const void *fdt, int stroffset) -{ - return fdt_get_string(fdt, stroffset, NULL); -} - -static int fdt_string_eq_(const void *fdt, int stroffset, - const char *s, int len) -{ - int slen; - const char *p = fdt_get_string(fdt, stroffset, &slen); - - return p && (slen == len) && (memcmp(p, s, len) == 0); -} - -int fdt_find_max_phandle(const void *fdt, uint32_t *phandle) -{ - uint32_t max = 0; - int offset = -1; - - while (true) { - uint32_t value; - - offset = fdt_next_node(fdt, offset, NULL); - if (offset < 0) { - if (offset == -FDT_ERR_NOTFOUND) - break; - - return offset; - } - - value = fdt_get_phandle(fdt, offset); - - if (value > max) - max = value; - } - - if (phandle) - *phandle = max; - - return 0; -} - -int fdt_generate_phandle(const void *fdt, uint32_t *phandle) -{ - uint32_t max; - int err; - - err = fdt_find_max_phandle(fdt, &max); - if (err < 0) - return err; - - if (max == FDT_MAX_PHANDLE) - return -FDT_ERR_NOPHANDLES; - - if (phandle) - *phandle = max + 1; - - return 0; -} - -static const struct fdt_reserve_entry *fdt_mem_rsv(const void *fdt, int n) -{ - int offset = n * sizeof(struct fdt_reserve_entry); - int absoffset = fdt_off_mem_rsvmap(fdt) + offset; - - if (fdt_chk_extra()) { - if (absoffset < fdt_off_mem_rsvmap(fdt)) - return NULL; - if (absoffset > fdt_totalsize(fdt) - - sizeof(struct fdt_reserve_entry)) - return NULL; - } - return fdt_mem_rsv_(fdt, n); -} - -int fdt_get_mem_rsv(const void *fdt, int n, uint64_t *address, uint64_t *size) -{ - const struct fdt_reserve_entry *re; - - FDT_RO_PROBE(fdt); - re = fdt_mem_rsv(fdt, n); - if (fdt_chk_extra() && !re) - return -FDT_ERR_BADOFFSET; - - *address = fdt64_to_cpu(re->address); - *size = fdt64_to_cpu(re->size); - return 0; -} - -int fdt_num_mem_rsv(const void *fdt) -{ - int i; - const struct fdt_reserve_entry *re; - - for (i = 0; (re = fdt_mem_rsv(fdt, i)) != NULL; i++) { - if (fdt64_to_cpu(re->size) == 0) - return i; - } - return -FDT_ERR_TRUNCATED; -} - -static int nextprop_(const void *fdt, int offset) -{ - uint32_t tag; - int nextoffset; - - do { - tag = fdt_next_tag(fdt, offset, &nextoffset); - - switch (tag) { - case FDT_END: - if (nextoffset >= 0) - return -FDT_ERR_BADSTRUCTURE; - else - return nextoffset; - - case FDT_PROP: - return offset; - } - offset = nextoffset; - } while (tag == FDT_NOP); - - return -FDT_ERR_NOTFOUND; -} - -int fdt_subnode_offset_namelen(const void *fdt, int offset, - const char *name, int namelen) -{ - int depth; - - FDT_RO_PROBE(fdt); - - for (depth = 0; - (offset >= 0) && (depth >= 0); - offset = fdt_next_node(fdt, offset, &depth)) - if ((depth == 1) - && fdt_nodename_eq_(fdt, offset, name, namelen)) - return offset; - - if (depth < 0) - return -FDT_ERR_NOTFOUND; - return offset; /* error */ -} - -int fdt_subnode_offset(const void *fdt, int parentoffset, - const char *name) -{ - return fdt_subnode_offset_namelen(fdt, parentoffset, name, strlen(name)); -} - -int fdt_path_offset_namelen(const void *fdt, const char *path, int namelen) -{ - const char *end = path + namelen; - const char *p = path; - int offset = 0; - - FDT_RO_PROBE(fdt); - - /* see if we have an alias */ - if (*path != '/') { - const char *q = memchr(path, '/', end - p); - - if (!q) - q = end; - - p = fdt_get_alias_namelen(fdt, p, q - p); - if (!p) - return -FDT_ERR_BADPATH; - offset = fdt_path_offset(fdt, p); - - p = q; - } - - while (p < end) { - const char *q; - - while (*p == '/') { - p++; - if (p == end) - return offset; - } - q = memchr(p, '/', end - p); - if (! q) - q = end; - - offset = fdt_subnode_offset_namelen(fdt, offset, p, q-p); - if (offset < 0) - return offset; - - p = q; - } - - return offset; -} - -int fdt_path_offset(const void *fdt, const char *path) -{ - return fdt_path_offset_namelen(fdt, path, strlen(path)); -} - -const char *fdt_get_name(const void *fdt, int nodeoffset, int *len) -{ - const struct fdt_node_header *nh = fdt_offset_ptr_(fdt, nodeoffset); - const char *nameptr; - int err; - - if (fdt_chk_extra() && - (((err = fdt_ro_probe_(fdt)) < 0) - || ((err = fdt_check_node_offset_(fdt, nodeoffset)) < 0))) - goto fail; - - nameptr = nh->name; - - if (fdt_chk_version() && fdt_version(fdt) < 0x10) { - /* - * For old FDT versions, match the naming conventions of V16: - * give only the leaf name (after all /). The actual tree - * contents are loosely checked. - */ - const char *leaf; - leaf = strrchr(nameptr, '/'); - if (leaf == NULL) { - err = -FDT_ERR_BADSTRUCTURE; - goto fail; - } - nameptr = leaf+1; - } - - if (len) - *len = strlen(nameptr); - - return nameptr; - - fail: - if (len) - *len = err; - return NULL; -} - -int fdt_first_property_offset(const void *fdt, int nodeoffset) -{ - int offset; - - if ((offset = fdt_check_node_offset_(fdt, nodeoffset)) < 0) - return offset; - - return nextprop_(fdt, offset); -} - -int fdt_next_property_offset(const void *fdt, int offset) -{ - if ((offset = fdt_check_prop_offset_(fdt, offset)) < 0) - return offset; - - return nextprop_(fdt, offset); -} - -static const struct fdt_property *fdt_get_property_by_offset_(const void *fdt, - int offset, - int *lenp) -{ - int err; - const struct fdt_property *prop; - - if (fdt_chk_basic() && (err = fdt_check_prop_offset_(fdt, offset)) < 0) { - if (lenp) - *lenp = err; - return NULL; - } - - prop = fdt_offset_ptr_(fdt, offset); - - if (lenp) - *lenp = fdt32_to_cpu(prop->len); - - return prop; -} - -const struct fdt_property *fdt_get_property_by_offset(const void *fdt, - int offset, - int *lenp) -{ - /* Prior to version 16, properties may need realignment - * and this API does not work. fdt_getprop_*() will, however. */ - - if (fdt_chk_version() && fdt_version(fdt) < 0x10) { - if (lenp) - *lenp = -FDT_ERR_BADVERSION; - return NULL; - } - - return fdt_get_property_by_offset_(fdt, offset, lenp); -} - -static const struct fdt_property *fdt_get_property_namelen_(const void *fdt, - int offset, - const char *name, - int namelen, - int *lenp, - int *poffset) -{ - for (offset = fdt_first_property_offset(fdt, offset); - (offset >= 0); - (offset = fdt_next_property_offset(fdt, offset))) { - const struct fdt_property *prop; - - prop = fdt_get_property_by_offset_(fdt, offset, lenp); - if (fdt_chk_extra() && !prop) { - offset = -FDT_ERR_INTERNAL; - break; - } - if (fdt_string_eq_(fdt, fdt32_to_cpu(prop->nameoff), - name, namelen)) { - if (poffset) - *poffset = offset; - return prop; - } - } - - if (lenp) - *lenp = offset; - return NULL; -} - - -const struct fdt_property *fdt_get_property_namelen(const void *fdt, - int offset, - const char *name, - int namelen, int *lenp) -{ - /* Prior to version 16, properties may need realignment - * and this API does not work. fdt_getprop_*() will, however. */ - if (fdt_chk_version() && fdt_version(fdt) < 0x10) { - if (lenp) - *lenp = -FDT_ERR_BADVERSION; - return NULL; - } - - return fdt_get_property_namelen_(fdt, offset, name, namelen, lenp, - NULL); -} - - -const struct fdt_property *fdt_get_property(const void *fdt, - int nodeoffset, - const char *name, int *lenp) -{ - return fdt_get_property_namelen(fdt, nodeoffset, name, - strlen(name), lenp); -} - -const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, - const char *name, int namelen, int *lenp) -{ - int poffset; - const struct fdt_property *prop; - - prop = fdt_get_property_namelen_(fdt, nodeoffset, name, namelen, lenp, - &poffset); - if (!prop) - return NULL; - - /* Handle realignment */ - if (fdt_chk_version() && fdt_version(fdt) < 0x10 && - (poffset + sizeof(*prop)) % 8 && fdt32_to_cpu(prop->len) >= 8) - return prop->data + 4; - return prop->data; -} - -const void *fdt_getprop_by_offset(const void *fdt, int offset, - const char **namep, int *lenp) -{ - const struct fdt_property *prop; - - prop = fdt_get_property_by_offset_(fdt, offset, lenp); - if (!prop) - return NULL; - if (namep) { - const char *name; - int namelen; - - if (fdt_chk_extra()) { - name = fdt_get_string(fdt, fdt32_to_cpu(prop->nameoff), - &namelen); - if (!name) { - if (lenp) - *lenp = namelen; - return NULL; - } - *namep = name; - } else { - *namep = fdt_string(fdt, fdt32_to_cpu(prop->nameoff)); - } - } - - /* Handle realignment */ - if (fdt_chk_version() && fdt_version(fdt) < 0x10 && - (offset + sizeof(*prop)) % 8 && fdt32_to_cpu(prop->len) >= 8) - return prop->data + 4; - return prop->data; -} - -const void *fdt_getprop(const void *fdt, int nodeoffset, - const char *name, int *lenp) -{ - return fdt_getprop_namelen(fdt, nodeoffset, name, strlen(name), lenp); -} - -uint32_t fdt_get_phandle(const void *fdt, int nodeoffset) -{ - const fdt32_t *php; - int len; - - /* FIXME: This is a bit sub-optimal, since we potentially scan - * over all the properties twice. */ - php = fdt_getprop(fdt, nodeoffset, "phandle", &len); - if (!php || (len != sizeof(*php))) { - php = fdt_getprop(fdt, nodeoffset, "linux,phandle", &len); - if (!php || (len != sizeof(*php))) - return 0; - } - - return fdt32_to_cpu(*php); -} - -const char *fdt_get_alias_namelen(const void *fdt, - const char *name, int namelen) -{ - int aliasoffset; - - aliasoffset = fdt_path_offset(fdt, "/aliases"); - if (aliasoffset < 0) - return NULL; - - return fdt_getprop_namelen(fdt, aliasoffset, name, namelen, NULL); -} - -const char *fdt_get_alias(const void *fdt, const char *name) -{ - return fdt_get_alias_namelen(fdt, name, strlen(name)); -} - -int fdt_get_path(const void *fdt, int nodeoffset, char *buf, int buflen) -{ - int pdepth = 0, p = 0; - int offset, depth, namelen; - const char *name; - - FDT_RO_PROBE(fdt); - - if (buflen < 2) - return -FDT_ERR_NOSPACE; - - for (offset = 0, depth = 0; - (offset >= 0) && (offset <= nodeoffset); - offset = fdt_next_node(fdt, offset, &depth)) { - while (pdepth > depth) { - do { - p--; - } while (buf[p-1] != '/'); - pdepth--; - } - - if (pdepth >= depth) { - name = fdt_get_name(fdt, offset, &namelen); - if (!name) - return namelen; - if ((p + namelen + 1) <= buflen) { - memcpy(buf + p, name, namelen); - p += namelen; - buf[p++] = '/'; - pdepth++; - } - } - - if (offset == nodeoffset) { - if (pdepth < (depth + 1)) - return -FDT_ERR_NOSPACE; - - if (p > 1) /* special case so that root path is "/", not "" */ - p--; - buf[p] = '\0'; - return 0; - } - } - - if ((offset == -FDT_ERR_NOTFOUND) || (offset >= 0)) - return -FDT_ERR_BADOFFSET; - else if (offset == -FDT_ERR_BADOFFSET) - return -FDT_ERR_BADSTRUCTURE; - - return offset; /* error from fdt_next_node() */ -} - -int fdt_supernode_atdepth_offset(const void *fdt, int nodeoffset, - int supernodedepth, int *nodedepth) -{ - int offset, depth; - int supernodeoffset = -FDT_ERR_INTERNAL; - - FDT_RO_PROBE(fdt); - - if (supernodedepth < 0) - return -FDT_ERR_NOTFOUND; - - for (offset = 0, depth = 0; - (offset >= 0) && (offset <= nodeoffset); - offset = fdt_next_node(fdt, offset, &depth)) { - if (depth == supernodedepth) - supernodeoffset = offset; - - if (offset == nodeoffset) { - if (nodedepth) - *nodedepth = depth; - - if (supernodedepth > depth) - return -FDT_ERR_NOTFOUND; - else - return supernodeoffset; - } - } - - if (fdt_chk_extra()) { - if ((offset == -FDT_ERR_NOTFOUND) || (offset >= 0)) - return -FDT_ERR_BADOFFSET; - else if (offset == -FDT_ERR_BADOFFSET) - return -FDT_ERR_BADSTRUCTURE; - } - - return offset; /* error from fdt_next_node() */ -} - -int fdt_node_depth(const void *fdt, int nodeoffset) -{ - int nodedepth; - int err; - - err = fdt_supernode_atdepth_offset(fdt, nodeoffset, 0, &nodedepth); - if (err) - return (!fdt_chk_extra() || err < 0) ? err : -FDT_ERR_INTERNAL; - return nodedepth; -} - -int fdt_parent_offset(const void *fdt, int nodeoffset) -{ - int nodedepth = fdt_node_depth(fdt, nodeoffset); - - if (nodedepth < 0) - return nodedepth; - return fdt_supernode_atdepth_offset(fdt, nodeoffset, - nodedepth - 1, NULL); -} - -int fdt_node_offset_by_prop_value(const void *fdt, int startoffset, - const char *propname, - const void *propval, int proplen) -{ - int offset; - const void *val; - int len; - - FDT_RO_PROBE(fdt); - - /* FIXME: The algorithm here is pretty horrible: we scan each - * property of a node in fdt_getprop(), then if that didn't - * find what we want, we scan over them again making our way - * to the next node. Still it's the easiest to implement - * approach; performance can come later. */ - for (offset = fdt_next_node(fdt, startoffset, NULL); - offset >= 0; - offset = fdt_next_node(fdt, offset, NULL)) { - val = fdt_getprop(fdt, offset, propname, &len); - if (val && (len == proplen) - && (memcmp(val, propval, len) == 0)) - return offset; - } - - return offset; /* error from fdt_next_node() */ -} - -int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle) -{ - int offset; - - if ((phandle == 0) || (phandle == -1)) - return -FDT_ERR_BADPHANDLE; - - FDT_RO_PROBE(fdt); - - /* FIXME: The algorithm here is pretty horrible: we - * potentially scan each property of a node in - * fdt_get_phandle(), then if that didn't find what - * we want, we scan over them again making our way to the next - * node. Still it's the easiest to implement approach; - * performance can come later. */ - for (offset = fdt_next_node(fdt, -1, NULL); - offset >= 0; - offset = fdt_next_node(fdt, offset, NULL)) { - if (fdt_get_phandle(fdt, offset) == phandle) - return offset; - } - - return offset; /* error from fdt_next_node() */ -} - -int fdt_stringlist_contains(const char *strlist, int listlen, const char *str) -{ - int len = strlen(str); - const char *p; - - while (listlen >= len) { - if (memcmp(str, strlist, len+1) == 0) - return 1; - p = memchr(strlist, '\0', listlen); - if (!p) - return 0; /* malformed strlist.. */ - listlen -= (p-strlist) + 1; - strlist = p + 1; - } - return 0; -} - -int fdt_stringlist_count(const void *fdt, int nodeoffset, const char *property) -{ - const char *list, *end; - int length, count = 0; - - list = fdt_getprop(fdt, nodeoffset, property, &length); - if (!list) - return length; - - end = list + length; - - while (list < end) { - length = strnlen(list, end - list) + 1; - - /* Abort if the last string isn't properly NUL-terminated. */ - if (list + length > end) - return -FDT_ERR_BADVALUE; - - list += length; - count++; - } - - return count; -} - -int fdt_stringlist_search(const void *fdt, int nodeoffset, const char *property, - const char *string) -{ - int length, len, idx = 0; - const char *list, *end; - - list = fdt_getprop(fdt, nodeoffset, property, &length); - if (!list) - return length; - - len = strlen(string) + 1; - end = list + length; - - while (list < end) { - length = strnlen(list, end - list) + 1; - - /* Abort if the last string isn't properly NUL-terminated. */ - if (list + length > end) - return -FDT_ERR_BADVALUE; - - if (length == len && memcmp(list, string, length) == 0) - return idx; - - list += length; - idx++; - } - - return -FDT_ERR_NOTFOUND; -} - -const char *fdt_stringlist_get(const void *fdt, int nodeoffset, - const char *property, int idx, - int *lenp) -{ - const char *list, *end; - int length; - - list = fdt_getprop(fdt, nodeoffset, property, &length); - if (!list) { - if (lenp) - *lenp = length; - - return NULL; - } - - end = list + length; - - while (list < end) { - length = strnlen(list, end - list) + 1; - - /* Abort if the last string isn't properly NUL-terminated. */ - if (list + length > end) { - if (lenp) - *lenp = -FDT_ERR_BADVALUE; - - return NULL; - } - - if (idx == 0) { - if (lenp) - *lenp = length - 1; - - return list; - } - - list += length; - idx--; - } - - if (lenp) - *lenp = -FDT_ERR_NOTFOUND; - - return NULL; -} - -int fdt_node_check_compatible(const void *fdt, int nodeoffset, - const char *compatible) -{ - const void *prop; - int len; - - prop = fdt_getprop(fdt, nodeoffset, "compatible", &len); - if (!prop) - return len; - - return !fdt_stringlist_contains(prop, len, compatible); -} - -int fdt_node_offset_by_compatible(const void *fdt, int startoffset, - const char *compatible) -{ - int offset, err; - - FDT_RO_PROBE(fdt); - - /* FIXME: The algorithm here is pretty horrible: we scan each - * property of a node in fdt_node_check_compatible(), then if - * that didn't find what we want, we scan over them again - * making our way to the next node. Still it's the easiest to - * implement approach; performance can come later. */ - for (offset = fdt_next_node(fdt, startoffset, NULL); - offset >= 0; - offset = fdt_next_node(fdt, offset, NULL)) { - err = fdt_node_check_compatible(fdt, offset, compatible); - if ((err < 0) && (err != -FDT_ERR_NOTFOUND)) - return err; - else if (err == 0) - return offset; - } - - return offset; /* error from fdt_next_node() */ -} - -#if !defined(CHECK_LEVEL) || CHECK_LEVEL > 0 -int fdt_check_full(const void *fdt, size_t bufsize) -{ - int err; - int num_memrsv; - int offset, nextoffset = 0; - uint32_t tag; - unsigned depth = 0; - const void *prop; - const char *propname; - - if (bufsize < FDT_V1_SIZE) - return -FDT_ERR_TRUNCATED; - err = fdt_check_header(fdt); - if (err != 0) - return err; - if (bufsize < fdt_totalsize(fdt)) - return -FDT_ERR_TRUNCATED; - - num_memrsv = fdt_num_mem_rsv(fdt); - if (num_memrsv < 0) - return num_memrsv; - - while (1) { - offset = nextoffset; - tag = fdt_next_tag(fdt, offset, &nextoffset); - - if (nextoffset < 0) - return nextoffset; - - switch (tag) { - case FDT_NOP: - break; - - case FDT_END: - if (depth != 0) - return -FDT_ERR_BADSTRUCTURE; - return 0; - - case FDT_BEGIN_NODE: - depth++; - if (depth > INT_MAX) - return -FDT_ERR_BADSTRUCTURE; - break; - - case FDT_END_NODE: - if (depth == 0) - return -FDT_ERR_BADSTRUCTURE; - depth--; - break; - - case FDT_PROP: - prop = fdt_getprop_by_offset(fdt, offset, &propname, - &err); - if (!prop) - return err; - break; - - default: - return -FDT_ERR_INTERNAL; - } - } -} -#endif +#include "../../scripts/dtc/libfdt/fdt_ro.c" diff --git a/tools/Makefile b/tools/Makefile index 3b9ae90369..bfdbb1339c 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -63,11 +63,10 @@ FIT_CIPHER_OBJS-$(CONFIG_FIT_CIPHER) := common/image-cipher.o
# The following files are synced with upstream DTC. # Use synced versions from scripts/dtc/libfdt/. -LIBFDT_SRCS_SYNCED := fdt.c fdt_wip.c fdt_sw.c fdt_rw.c \ +LIBFDT_SRCS_SYNCED := fdt.c fdt_ro.c fdt_wip.c fdt_sw.c fdt_rw.c \ fdt_strerror.c fdt_empty_tree.c fdt_addresses.c fdt_overlay.c -# The following files are locally modified for U-Boot (unfotunately). # Use U-Boot own versions from lib/libfdt/. -LIBFDT_SRCS_UNSYNCED := fdt_ro.c fdt_region.c +LIBFDT_SRCS_UNSYNCED := fdt_region.c
LIBFDT_OBJS := $(addprefix libfdt/, $(patsubst %.c, %.o, $(LIBFDT_SRCS_SYNCED))) \ $(addprefix lib/libfdt/, $(patsubst %.c, %.o, $(LIBFDT_SRCS_UNSYNCED))) diff --git a/tools/libfdt/fdt_ro.c b/tools/libfdt/fdt_ro.c new file mode 100644 index 0000000000..8a9735a48c --- /dev/null +++ b/tools/libfdt/fdt_ro.c @@ -0,0 +1,2 @@ +#include "fdt_host.h" +#include "../scripts/dtc/libfdt/fdt_ro.c"
Applied to u-boot-dm, thanks!
My goal is to sync lib/libfdt/ with scripts/dtc/libfdt/, that is, make lib/libfdt/ contain only wrapper files.
fdt_region.c was written only for U-Boot to implement the verified boot. So, this belongs to the same group as common/fdt_support.c, which is a collection of U-Boot own fdt helpers.
Move lib/libfdt/fdt_region.c to common/fdt_region.c . This is necessary only when CONFIG_(SPL_TPL_)_FIT_SIGNATURE is enabled.
I am resending this after two years since v1.
My previous attempt sank by this comment: http://patchwork.ozlabs.org/project/uboot/patch/1521623017-29312-5-git-send-...
Two years have passed, but I still do not see this file in upstream DTC.
Changes in v2: - rebase
common/Makefile | 1 + {lib/libfdt => common}/fdt_region.c | 0 lib/libfdt/Makefile | 3 --- tools/Makefile | 12 ++++-------- 4 files changed, 5 insertions(+), 11 deletions(-) rename {lib/libfdt => common}/fdt_region.c (100%)
diff --git a/common/Makefile b/common/Makefile index 702f2396cf..a3f3faf479 100644 --- a/common/Makefile +++ b/common/Makefile @@ -110,6 +110,7 @@ obj-y += image.o obj-$(CONFIG_ANDROID_AB) += android_ab.o obj-$(CONFIG_ANDROID_BOOT_IMAGE) += image-android.o image-android-dt.o obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += image-fdt.o +obj-$(CONFIG_$(SPL_TPL_)FIT_SIGNATURE) += fdt_region.o obj-$(CONFIG_$(SPL_TPL_)FIT) += image-fit.o obj-$(CONFIG_$(SPL_)MULTI_DTB_FIT) += boot_fit.o common_fit.o obj-$(CONFIG_IMAGE_SIGN_INFO) += image-sig.o diff --git a/lib/libfdt/fdt_region.c b/common/fdt_region.c similarity index 100% rename from lib/libfdt/fdt_region.c rename to common/fdt_region.c diff --git a/lib/libfdt/Makefile b/lib/libfdt/Makefile index 878659f99e..1fe50ecbe5 100644 --- a/lib/libfdt/Makefile +++ b/lib/libfdt/Makefile @@ -15,8 +15,5 @@ obj-y += \
-# U-Boot own file -obj-y += fdt_region.o - ccflags-y := -I$(srctree)/scripts/dtc/libfdt \ -DFDT_ASSUME_MASK=$(CONFIG_$(SPL_TPL_)OF_LIBFDT_ASSUME_MASK) diff --git a/tools/Makefile b/tools/Makefile index bfdbb1339c..ee9077ca82 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -63,13 +63,8 @@ FIT_CIPHER_OBJS-$(CONFIG_FIT_CIPHER) := common/image-cipher.o
# The following files are synced with upstream DTC. # Use synced versions from scripts/dtc/libfdt/. -LIBFDT_SRCS_SYNCED := fdt.c fdt_ro.c fdt_wip.c fdt_sw.c fdt_rw.c \ - fdt_strerror.c fdt_empty_tree.c fdt_addresses.c fdt_overlay.c -# Use U-Boot own versions from lib/libfdt/. -LIBFDT_SRCS_UNSYNCED := fdt_region.c - -LIBFDT_OBJS := $(addprefix libfdt/, $(patsubst %.c, %.o, $(LIBFDT_SRCS_SYNCED))) \ - $(addprefix lib/libfdt/, $(patsubst %.c, %.o, $(LIBFDT_SRCS_UNSYNCED))) +LIBFDT_OBJS := $(addprefix libfdt/, fdt.o fdt_ro.o fdt_wip.o fdt_sw.o fdt_rw.o \ + fdt_strerror.o fdt_empty_tree.o fdt_addresses.o fdt_overlay.o)
RSA_OBJS-$(CONFIG_FIT_SIGNATURE) := $(addprefix lib/rsa/, \ rsa-sign.o rsa-verify.o rsa-checksum.o \ @@ -86,6 +81,7 @@ dumpimage-mkimage-objs := aisimage.o \ $(FIT_OBJS-y) \ $(FIT_SIG_OBJS-y) \ $(FIT_CIPHER_OBJS-y) \ + common/fdt_region.o \ common/bootm.o \ lib/crc32.o \ default_image.o \ @@ -210,7 +206,7 @@ hostprogs-$(CONFIG_STATIC_RELA) += relocate-rela hostprogs-$(CONFIG_RISCV) += prelink-riscv
hostprogs-y += fdtgrep -fdtgrep-objs += $(LIBFDT_OBJS) fdtgrep.o +fdtgrep-objs += $(LIBFDT_OBJS) common/fdt_region.o fdtgrep.o
ifneq ($(TOOLS_ONLY),y) hostprogs-y += spl_size_limit
fdt_region APIs are not part of libfdt. They are U-Boot extension for the verified boot. Split the declarations related to fdt_region out of <fdt_region.h>. This allows <linux/libfdt.h> to become a simple wrapper file, like Linux does.
My previous attempt sank by this comment: http://patchwork.ozlabs.org/project/uboot/patch/1521623017-29312-6-git-send-...
Two years have passed, but I still do not see such code in upstream DTC.
Changes in v2: - Rebase
common/fdt_region.c | 1 + common/image-fit-sig.c | 1 + include/fdt_region.h | 304 +++++++++++++++++++++++++++++++++++++++++ include/linux/libfdt.h | 299 ---------------------------------------- tools/fdtgrep.c | 1 + tools/image-host.c | 1 + 6 files changed, 308 insertions(+), 299 deletions(-) create mode 100644 include/fdt_region.h
diff --git a/common/fdt_region.c b/common/fdt_region.c index 7e9fa9272e..bf0a9be730 100644 --- a/common/fdt_region.c +++ b/common/fdt_region.c @@ -6,6 +6,7 @@ */
#include <linux/libfdt_env.h> +#include <fdt_region.h>
#ifndef USE_HOSTCC #include <fdt.h> diff --git a/common/image-fit-sig.c b/common/image-fit-sig.c index f6caeb0c59..64a181266e 100644 --- a/common/image-fit-sig.c +++ b/common/image-fit-sig.c @@ -11,6 +11,7 @@ #include <malloc.h> DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/ +#include <fdt_region.h> #include <image.h> #include <u-boot/rsa.h> #include <u-boot/rsa-checksum.h> diff --git a/include/fdt_region.h b/include/fdt_region.h new file mode 100644 index 0000000000..ff7a1ccb9a --- /dev/null +++ b/include/fdt_region.h @@ -0,0 +1,304 @@ +/* SPDX-License-Identifier: GPL-2.0 */ + +#ifndef _FDT_REGION_H +#define _FDT_REGION_H + +#ifndef SWIG /* Not available in Python */ +struct fdt_region { + int offset; + int size; +}; + +/* + * Flags for fdt_find_regions() + * + * Add a region for the string table (always the last region) + */ +#define FDT_REG_ADD_STRING_TAB (1 << 0) + +/* + * Add all supernodes of a matching node/property, useful for creating a + * valid subset tree + */ +#define FDT_REG_SUPERNODES (1 << 1) + +/* Add the FDT_BEGIN_NODE tags of subnodes, including their names */ +#define FDT_REG_DIRECT_SUBNODES (1 << 2) + +/* Add all subnodes of a matching node */ +#define FDT_REG_ALL_SUBNODES (1 << 3) + +/* Add a region for the mem_rsvmap table (always the first region) */ +#define FDT_REG_ADD_MEM_RSVMAP (1 << 4) + +/* Indicates what an fdt part is (node, property, value) */ +#define FDT_IS_NODE (1 << 0) +#define FDT_IS_PROP (1 << 1) +#define FDT_IS_VALUE (1 << 2) /* not supported */ +#define FDT_IS_COMPAT (1 << 3) /* used internally */ +#define FDT_NODE_HAS_PROP (1 << 4) /* node contains prop */ + +#define FDT_ANY_GLOBAL (FDT_IS_NODE | FDT_IS_PROP | FDT_IS_VALUE | \ + FDT_IS_COMPAT) +#define FDT_IS_ANY 0x1f /* all the above */ + +/* We set a reasonable limit on the number of nested nodes */ +#define FDT_MAX_DEPTH 32 + +/* Decribes what we want to include from the current tag */ +enum want_t { + WANT_NOTHING, + WANT_NODES_ONLY, /* No properties */ + WANT_NODES_AND_PROPS, /* Everything for one level */ + WANT_ALL_NODES_AND_PROPS /* Everything for all levels */ +}; + +/* Keeps track of the state at parent nodes */ +struct fdt_subnode_stack { + int offset; /* Offset of node */ + enum want_t want; /* The 'want' value here */ + int included; /* 1 if we included this node, 0 if not */ +}; + +struct fdt_region_ptrs { + int depth; /* Current tree depth */ + int done; /* What we have completed scanning */ + enum want_t want; /* What we are currently including */ + char *end; /* Pointer to end of full node path */ + int nextoffset; /* Next node offset to check */ +}; + +/* The state of our finding algortihm */ +struct fdt_region_state { + struct fdt_subnode_stack stack[FDT_MAX_DEPTH]; /* node stack */ + struct fdt_region *region; /* Contains list of regions found */ + int count; /* Numnber of regions found */ + const void *fdt; /* FDT blob */ + int max_regions; /* Maximum regions to find */ + int can_merge; /* 1 if we can merge with previous region */ + int start; /* Start position of current region */ + struct fdt_region_ptrs ptrs; /* Pointers for what we are up to */ +}; + +/** + * fdt_find_regions() - find regions in device tree + * + * Given a list of nodes to include and properties to exclude, find + * the regions of the device tree which describe those included parts. + * + * The intent is to get a list of regions which will be invariant provided + * those parts are invariant. For example, if you request a list of regions + * for all nodes but exclude the property "data", then you will get the + * same region contents regardless of any change to "data" properties. + * + * This function can be used to produce a byte-stream to send to a hashing + * function to verify that critical parts of the FDT have not changed. + * + * Nodes which are given in 'inc' are included in the region list, as + * are the names of the immediate subnodes nodes (but not the properties + * or subnodes of those subnodes). + * + * For eaxample "/" means to include the root node, all root properties + * and the FDT_BEGIN_NODE and FDT_END_NODE of all subnodes of /. The latter + * ensures that we capture the names of the subnodes. In a hashing situation + * it prevents the root node from changing at all Any change to non-excluded + * properties, names of subnodes or number of subnodes would be detected. + * + * When used with FITs this provides the ability to hash and sign parts of + * the FIT based on different configurations in the FIT. Then it is + * impossible to change anything about that configuration (include images + * attached to the configuration), but it may be possible to add new + * configurations, new images or new signatures within the existing + * framework. + * + * Adding new properties to a device tree may result in the string table + * being extended (if the new property names are different from those + * already added). This function can optionally include a region for + * the string table so that this can be part of the hash too. + * + * The device tree header is not included in the list. + * + * @fdt: Device tree to check + * @inc: List of node paths to included + * @inc_count: Number of node paths in list + * @exc_prop: List of properties names to exclude + * @exc_prop_count: Number of properties in exclude list + * @region: Returns list of regions + * @max_region: Maximum length of region list + * @path: Pointer to a temporary string for the function to use for + * building path names + * @path_len: Length of path, must be large enough to hold the longest + * path in the tree + * @add_string_tab: 1 to add a region for the string table + * @return number of regions in list. If this is >max_regions then the + * region array was exhausted. You should increase max_regions and try + * the call again. + */ +int fdt_find_regions(const void *fdt, char * const inc[], int inc_count, + char * const exc_prop[], int exc_prop_count, + struct fdt_region region[], int max_regions, + char *path, int path_len, int add_string_tab); + +/** + * fdt_first_region() - find regions in device tree + * + * Given a nodes and properties to include and properties to exclude, find + * the regions of the device tree which describe those included parts. + * + * The use for this function is twofold. Firstly it provides a convenient + * way of performing a structure-aware grep of the tree. For example it is + * possible to grep for a node and get all the properties associated with + * that node. Trees can be subsetted easily, by specifying the nodes that + * are required, and then writing out the regions returned by this function. + * This is useful for small resource-constrained systems, such as boot + * loaders, which want to use an FDT but do not need to know about all of + * it. + * + * Secondly it makes it easy to hash parts of the tree and detect changes. + * The intent is to get a list of regions which will be invariant provided + * those parts are invariant. For example, if you request a list of regions + * for all nodes but exclude the property "data", then you will get the + * same region contents regardless of any change to "data" properties. + * + * This function can be used to produce a byte-stream to send to a hashing + * function to verify that critical parts of the FDT have not changed. + * Note that semantically null changes in order could still cause false + * hash misses. Such reordering might happen if the tree is regenerated + * from source, and nodes are reordered (the bytes-stream will be emitted + * in a different order and many hash functions will detect this). However + * if an existing tree is modified using libfdt functions, such as + * fdt_add_subnode() and fdt_setprop(), then this problem is avoided. + * + * The nodes/properties to include/exclude are defined by a function + * provided by the caller. This function is called for each node and + * property, and must return: + * + * 0 - to exclude this part + * 1 - to include this part + * -1 - for FDT_IS_PROP only: no information is available, so include + * if its containing node is included + * + * The last case is only used to deal with properties. Often a property is + * included if its containing node is included - this is the case where + * -1 is returned.. However if the property is specifically required to be + * included/excluded, then 0 or 1 can be returned. Note that including a + * property when the FDT_REG_SUPERNODES flag is given will force its + * containing node to be included since it is not valid to have a property + * that is not in a node. + * + * Using the information provided, the inclusion of a node can be controlled + * either by a node name or its compatible string, or any other property + * that the function can determine. + * + * As an example, including node "/" means to include the root node and all + * root properties. A flag provides a way of also including supernodes (of + * which there is none for the root node), and another flag includes + * immediate subnodes, so in this case we would get the FDT_BEGIN_NODE and + * FDT_END_NODE of all subnodes of /. + * + * The subnode feature helps in a hashing situation since it prevents the + * root node from changing at all. Any change to non-excluded properties, + * names of subnodes or number of subnodes would be detected. + * + * When used with FITs this provides the ability to hash and sign parts of + * the FIT based on different configurations in the FIT. Then it is + * impossible to change anything about that configuration (include images + * attached to the configuration), but it may be possible to add new + * configurations, new images or new signatures within the existing + * framework. + * + * Adding new properties to a device tree may result in the string table + * being extended (if the new property names are different from those + * already added). This function can optionally include a region for + * the string table so that this can be part of the hash too. This is always + * the last region. + * + * The FDT also has a mem_rsvmap table which can also be included, and is + * always the first region if so. + * + * The device tree header is not included in the region list. Since the + * contents of the FDT are changing (shrinking, often), the caller will need + * to regenerate the header anyway. + * + * @fdt: Device tree to check + * @h_include: Function to call to determine whether to include a part or + * not: + * + * @priv: Private pointer as passed to fdt_find_regions() + * @fdt: Pointer to FDT blob + * @offset: Offset of this node / property + * @type: Type of this part, FDT_IS_... + * @data: Pointer to data (node name, property name, compatible + * string, value (not yet supported) + * @size: Size of data, or 0 if none + * @return 0 to exclude, 1 to include, -1 if no information is + * available + * @priv: Private pointer passed to h_include + * @region: Returns list of regions, sorted by offset + * @max_regions: Maximum length of region list + * @path: Pointer to a temporary string for the function to use for + * building path names + * @path_len: Length of path, must be large enough to hold the longest + * path in the tree + * @flags: Various flags that control the region algortihm, see + * FDT_REG_... + * @return number of regions in list. If this is >max_regions then the + * region array was exhausted. You should increase max_regions and try + * the call again. Only the first max_regions elements are available in the + * array. + * + * On error a -ve value is return, which can be: + * + * -FDT_ERR_BADSTRUCTURE (too deep or more END tags than BEGIN tags + * -FDT_ERR_BADLAYOUT + * -FDT_ERR_NOSPACE (path area is too small) + */ +int fdt_first_region(const void *fdt, + int (*h_include)(void *priv, const void *fdt, int offset, + int type, const char *data, int size), + void *priv, struct fdt_region *region, + char *path, int path_len, int flags, + struct fdt_region_state *info); + +/** fdt_next_region() - find next region + * + * See fdt_first_region() for full description. This function finds the + * next region according to the provided parameters, which must be the same + * as passed to fdt_first_region(). + * + * This function can additionally return -FDT_ERR_NOTFOUND when there are no + * more regions + */ +int fdt_next_region(const void *fdt, + int (*h_include)(void *priv, const void *fdt, int offset, + int type, const char *data, int size), + void *priv, struct fdt_region *region, + char *path, int path_len, int flags, + struct fdt_region_state *info); + +/** + * fdt_add_alias_regions() - find aliases that point to existing regions + * + * Once a device tree grep is complete some of the nodes will be present + * and some will have been dropped. This function checks all the alias nodes + * to figure out which points point to nodes which are still present. These + * aliases need to be kept, along with the nodes they reference. + * + * Given a list of regions function finds the aliases that still apply and + * adds more regions to the list for these. This function is called after + * fdt_next_region() has finished returning regions and requires the same + * state. + * + * @fdt: Device tree file to reference + * @region: List of regions that will be kept + * @count: Number of regions + * @max_regions: Number of entries that can fit in @region + * @info: Region state as returned from fdt_next_region() + * @return new number of regions in @region (i.e. count + the number added) + * or -FDT_ERR_NOSPACE if there was not enough space. + */ +int fdt_add_alias_regions(const void *fdt, struct fdt_region *region, int count, + int max_regions, struct fdt_region_state *info); +#endif /* SWIG */ + +#endif /* _FDT_REGION_H */ diff --git a/include/linux/libfdt.h b/include/linux/libfdt.h index eeb2344971..39dbc88aa5 100644 --- a/include/linux/libfdt.h +++ b/include/linux/libfdt.h @@ -8,305 +8,6 @@ #include "../../scripts/dtc/libfdt/libfdt.h"
/* U-Boot local hacks */ - -#ifndef SWIG /* Not available in Python */ -struct fdt_region { - int offset; - int size; -}; - -/* - * Flags for fdt_find_regions() - * - * Add a region for the string table (always the last region) - */ -#define FDT_REG_ADD_STRING_TAB (1 << 0) - -/* - * Add all supernodes of a matching node/property, useful for creating a - * valid subset tree - */ -#define FDT_REG_SUPERNODES (1 << 1) - -/* Add the FDT_BEGIN_NODE tags of subnodes, including their names */ -#define FDT_REG_DIRECT_SUBNODES (1 << 2) - -/* Add all subnodes of a matching node */ -#define FDT_REG_ALL_SUBNODES (1 << 3) - -/* Add a region for the mem_rsvmap table (always the first region) */ -#define FDT_REG_ADD_MEM_RSVMAP (1 << 4) - -/* Indicates what an fdt part is (node, property, value) */ -#define FDT_IS_NODE (1 << 0) -#define FDT_IS_PROP (1 << 1) -#define FDT_IS_VALUE (1 << 2) /* not supported */ -#define FDT_IS_COMPAT (1 << 3) /* used internally */ -#define FDT_NODE_HAS_PROP (1 << 4) /* node contains prop */ - -#define FDT_ANY_GLOBAL (FDT_IS_NODE | FDT_IS_PROP | FDT_IS_VALUE | \ - FDT_IS_COMPAT) -#define FDT_IS_ANY 0x1f /* all the above */ - -/* We set a reasonable limit on the number of nested nodes */ -#define FDT_MAX_DEPTH 32 - -/* Decribes what we want to include from the current tag */ -enum want_t { - WANT_NOTHING, - WANT_NODES_ONLY, /* No properties */ - WANT_NODES_AND_PROPS, /* Everything for one level */ - WANT_ALL_NODES_AND_PROPS /* Everything for all levels */ -}; - -/* Keeps track of the state at parent nodes */ -struct fdt_subnode_stack { - int offset; /* Offset of node */ - enum want_t want; /* The 'want' value here */ - int included; /* 1 if we included this node, 0 if not */ -}; - -struct fdt_region_ptrs { - int depth; /* Current tree depth */ - int done; /* What we have completed scanning */ - enum want_t want; /* What we are currently including */ - char *end; /* Pointer to end of full node path */ - int nextoffset; /* Next node offset to check */ -}; - -/* The state of our finding algortihm */ -struct fdt_region_state { - struct fdt_subnode_stack stack[FDT_MAX_DEPTH]; /* node stack */ - struct fdt_region *region; /* Contains list of regions found */ - int count; /* Numnber of regions found */ - const void *fdt; /* FDT blob */ - int max_regions; /* Maximum regions to find */ - int can_merge; /* 1 if we can merge with previous region */ - int start; /* Start position of current region */ - struct fdt_region_ptrs ptrs; /* Pointers for what we are up to */ -}; - -/** - * fdt_find_regions() - find regions in device tree - * - * Given a list of nodes to include and properties to exclude, find - * the regions of the device tree which describe those included parts. - * - * The intent is to get a list of regions which will be invariant provided - * those parts are invariant. For example, if you request a list of regions - * for all nodes but exclude the property "data", then you will get the - * same region contents regardless of any change to "data" properties. - * - * This function can be used to produce a byte-stream to send to a hashing - * function to verify that critical parts of the FDT have not changed. - * - * Nodes which are given in 'inc' are included in the region list, as - * are the names of the immediate subnodes nodes (but not the properties - * or subnodes of those subnodes). - * - * For eaxample "/" means to include the root node, all root properties - * and the FDT_BEGIN_NODE and FDT_END_NODE of all subnodes of /. The latter - * ensures that we capture the names of the subnodes. In a hashing situation - * it prevents the root node from changing at all Any change to non-excluded - * properties, names of subnodes or number of subnodes would be detected. - * - * When used with FITs this provides the ability to hash and sign parts of - * the FIT based on different configurations in the FIT. Then it is - * impossible to change anything about that configuration (include images - * attached to the configuration), but it may be possible to add new - * configurations, new images or new signatures within the existing - * framework. - * - * Adding new properties to a device tree may result in the string table - * being extended (if the new property names are different from those - * already added). This function can optionally include a region for - * the string table so that this can be part of the hash too. - * - * The device tree header is not included in the list. - * - * @fdt: Device tree to check - * @inc: List of node paths to included - * @inc_count: Number of node paths in list - * @exc_prop: List of properties names to exclude - * @exc_prop_count: Number of properties in exclude list - * @region: Returns list of regions - * @max_region: Maximum length of region list - * @path: Pointer to a temporary string for the function to use for - * building path names - * @path_len: Length of path, must be large enough to hold the longest - * path in the tree - * @add_string_tab: 1 to add a region for the string table - * @return number of regions in list. If this is >max_regions then the - * region array was exhausted. You should increase max_regions and try - * the call again. - */ -int fdt_find_regions(const void *fdt, char * const inc[], int inc_count, - char * const exc_prop[], int exc_prop_count, - struct fdt_region region[], int max_regions, - char *path, int path_len, int add_string_tab); - -/** - * fdt_first_region() - find regions in device tree - * - * Given a nodes and properties to include and properties to exclude, find - * the regions of the device tree which describe those included parts. - * - * The use for this function is twofold. Firstly it provides a convenient - * way of performing a structure-aware grep of the tree. For example it is - * possible to grep for a node and get all the properties associated with - * that node. Trees can be subsetted easily, by specifying the nodes that - * are required, and then writing out the regions returned by this function. - * This is useful for small resource-constrained systems, such as boot - * loaders, which want to use an FDT but do not need to know about all of - * it. - * - * Secondly it makes it easy to hash parts of the tree and detect changes. - * The intent is to get a list of regions which will be invariant provided - * those parts are invariant. For example, if you request a list of regions - * for all nodes but exclude the property "data", then you will get the - * same region contents regardless of any change to "data" properties. - * - * This function can be used to produce a byte-stream to send to a hashing - * function to verify that critical parts of the FDT have not changed. - * Note that semantically null changes in order could still cause false - * hash misses. Such reordering might happen if the tree is regenerated - * from source, and nodes are reordered (the bytes-stream will be emitted - * in a different order and many hash functions will detect this). However - * if an existing tree is modified using libfdt functions, such as - * fdt_add_subnode() and fdt_setprop(), then this problem is avoided. - * - * The nodes/properties to include/exclude are defined by a function - * provided by the caller. This function is called for each node and - * property, and must return: - * - * 0 - to exclude this part - * 1 - to include this part - * -1 - for FDT_IS_PROP only: no information is available, so include - * if its containing node is included - * - * The last case is only used to deal with properties. Often a property is - * included if its containing node is included - this is the case where - * -1 is returned.. However if the property is specifically required to be - * included/excluded, then 0 or 1 can be returned. Note that including a - * property when the FDT_REG_SUPERNODES flag is given will force its - * containing node to be included since it is not valid to have a property - * that is not in a node. - * - * Using the information provided, the inclusion of a node can be controlled - * either by a node name or its compatible string, or any other property - * that the function can determine. - * - * As an example, including node "/" means to include the root node and all - * root properties. A flag provides a way of also including supernodes (of - * which there is none for the root node), and another flag includes - * immediate subnodes, so in this case we would get the FDT_BEGIN_NODE and - * FDT_END_NODE of all subnodes of /. - * - * The subnode feature helps in a hashing situation since it prevents the - * root node from changing at all. Any change to non-excluded properties, - * names of subnodes or number of subnodes would be detected. - * - * When used with FITs this provides the ability to hash and sign parts of - * the FIT based on different configurations in the FIT. Then it is - * impossible to change anything about that configuration (include images - * attached to the configuration), but it may be possible to add new - * configurations, new images or new signatures within the existing - * framework. - * - * Adding new properties to a device tree may result in the string table - * being extended (if the new property names are different from those - * already added). This function can optionally include a region for - * the string table so that this can be part of the hash too. This is always - * the last region. - * - * The FDT also has a mem_rsvmap table which can also be included, and is - * always the first region if so. - * - * The device tree header is not included in the region list. Since the - * contents of the FDT are changing (shrinking, often), the caller will need - * to regenerate the header anyway. - * - * @fdt: Device tree to check - * @h_include: Function to call to determine whether to include a part or - * not: - * - * @priv: Private pointer as passed to fdt_find_regions() - * @fdt: Pointer to FDT blob - * @offset: Offset of this node / property - * @type: Type of this part, FDT_IS_... - * @data: Pointer to data (node name, property name, compatible - * string, value (not yet supported) - * @size: Size of data, or 0 if none - * @return 0 to exclude, 1 to include, -1 if no information is - * available - * @priv: Private pointer passed to h_include - * @region: Returns list of regions, sorted by offset - * @max_regions: Maximum length of region list - * @path: Pointer to a temporary string for the function to use for - * building path names - * @path_len: Length of path, must be large enough to hold the longest - * path in the tree - * @flags: Various flags that control the region algortihm, see - * FDT_REG_... - * @return number of regions in list. If this is >max_regions then the - * region array was exhausted. You should increase max_regions and try - * the call again. Only the first max_regions elements are available in the - * array. - * - * On error a -ve value is return, which can be: - * - * -FDT_ERR_BADSTRUCTURE (too deep or more END tags than BEGIN tags - * -FDT_ERR_BADLAYOUT - * -FDT_ERR_NOSPACE (path area is too small) - */ -int fdt_first_region(const void *fdt, - int (*h_include)(void *priv, const void *fdt, int offset, - int type, const char *data, int size), - void *priv, struct fdt_region *region, - char *path, int path_len, int flags, - struct fdt_region_state *info); - -/** fdt_next_region() - find next region - * - * See fdt_first_region() for full description. This function finds the - * next region according to the provided parameters, which must be the same - * as passed to fdt_first_region(). - * - * This function can additionally return -FDT_ERR_NOTFOUND when there are no - * more regions - */ -int fdt_next_region(const void *fdt, - int (*h_include)(void *priv, const void *fdt, int offset, - int type, const char *data, int size), - void *priv, struct fdt_region *region, - char *path, int path_len, int flags, - struct fdt_region_state *info); - -/** - * fdt_add_alias_regions() - find aliases that point to existing regions - * - * Once a device tree grep is complete some of the nodes will be present - * and some will have been dropped. This function checks all the alias nodes - * to figure out which points point to nodes which are still present. These - * aliases need to be kept, along with the nodes they reference. - * - * Given a list of regions function finds the aliases that still apply and - * adds more regions to the list for these. This function is called after - * fdt_next_region() has finished returning regions and requires the same - * state. - * - * @fdt: Device tree file to reference - * @region: List of regions that will be kept - * @count: Number of regions - * @max_regions: Number of entries that can fit in @region - * @info: Region state as returned from fdt_next_region() - * @return new number of regions in @region (i.e. count + the number added) - * or -FDT_ERR_NOSPACE if there was not enough space. - */ -int fdt_add_alias_regions(const void *fdt, struct fdt_region *region, int count, - int max_regions, struct fdt_region_state *info); -#endif /* SWIG */ - extern struct fdt_header *working_fdt; /* Pointer to the working fdt */
#endif /* _INCLUDE_LIBFDT_H_ */ diff --git a/tools/fdtgrep.c b/tools/fdtgrep.c index 2a8058f57f..7e168a1e6b 100644 --- a/tools/fdtgrep.c +++ b/tools/fdtgrep.c @@ -17,6 +17,7 @@ #include <stdlib.h> #include <string.h> #include <unistd.h> +#include <fdt_region.h>
#include "fdt_host.h" #include "libfdt_internal.h" diff --git a/tools/image-host.c b/tools/image-host.c index 76a361b9d6..1b4bc0eb58 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -10,6 +10,7 @@
#include "mkimage.h" #include <bootm.h> +#include <fdt_region.h> #include <image.h> #include <version.h>
Masahiro Yamada
sjg@google.com
