[U-Boot] [PATCH] cmd, fdt: add subcommand "get" to fdt header
store fdt header member with name <member> in U-Boot Environment variable with name <var>.
for example to get the total length of the fdt and store it in filesize, call:
fdt header get filesize totalsize
For membernames look into fdt header definition at scripts/dtc/libfdt/libfdt.h
Signed-off-by: Heiko Schocher hs@denx.de ---
cmd/fdt.c | 40 +++++++++++++++++++++++++++++++++++++++- 1 file changed, 39 insertions(+), 1 deletion(-)
diff --git a/cmd/fdt.c b/cmd/fdt.c index 8a19a3fdbf..cc50f7914d 100644 --- a/cmd/fdt.c +++ b/cmd/fdt.c @@ -73,6 +73,40 @@ static int fdt_value_env_set(const void *nodep, int len, const char *var) return 0; }
+fdt_member_table[] = { + {"magic"}, + {"totalsize"}, + {"off_dt_struct"}, + {"off_dt_strings"}, + {"off_mem_rsvmap"}, + {"version"}, + {"last_comp_version"}, + {"boot_cpuid_phys"}, + {"size_dt_strings"}, + {"size_dt_struct"}, +}; + +static int fdt_get_header_value(int argc, char * const argv[]) +{ + fdt32_t *fdtp = (fdt32_t *)working_fdt; + ulong val; + int i; + + if (argv[2][0] != 'g') + return CMD_RET_FAILURE; + + for (i = 0; i < ARRAY_SIZE(fdt_member_table); i++) { + if (strcmp(fdt_member_table[i], argv[4]) == 0) { + val = fdt32_to_cpu(*fdtp); + env_set_hex(argv[3], val); + return CMD_RET_SUCCESS; + } + fdtp++; + } + + return CMD_RET_FAILURE; +} + /* * Flattened Device Tree command, see the help for parameter definitions. */ @@ -491,6 +525,9 @@ static int do_fdt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) * Display header info */ } else if (argv[1][0] == 'h') { + if (argc == 5) + return fdt_get_header_value(argc, argv); + u32 version = fdt_version(working_fdt); printf("magic:\t\t\t0x%x\n", fdt_magic(working_fdt)); printf("totalsize:\t\t0x%x (%d)\n", fdt_totalsize(working_fdt), @@ -1090,7 +1127,8 @@ static char fdt_help_text[] = "fdt set <path> <prop> [<val>] - Set <property> [to <val>]\n" "fdt mknode <path> <node> - Create a new node after <path>\n" "fdt rm <path> [<prop>] - Delete the node or <property>\n" - "fdt header - Display header info\n" + "fdt header [get <var> <member>] - Display header info\n" + " get - get header member <member> and store it in <var>\n" "fdt bootcpu <id> - Set boot cpuid\n" "fdt memory <addr> <size> - Add/Update memory node\n" "fdt rsvmem print - Show current mem reserves\n"
Heiko Schocher
