[U-Boot] Question about CONFIG_ENV_IS_IN_FAT
Hello Submarine Friends!
My goal is to keep env at fat partition on mmc. I added these definitions to am335x_evm.h config.
#define CONFIG_ENV_IS_IN_FAT #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE 0 #define FAT_ENV_PART 1 #define FAT_ENV_FILE "uEnv.txt"
This enables to store the content on MMC, but I am concerned about two things: 1)I got this warning message every booting: reading uEnv.txt FAT: Misaligned buffer address (8fa16f10) 2) There is a problem with opening the file in text editors, because it have non ascii bytes at head. But seems data is not corrupt.
Is it ok? Help me shedding some light on these issues. Thank You.
Best Regards, Dima.
Note that the uEnv.txt file is used for something similar but different, so please use a different name here.
Depending on where in the boot process that is, it could be that.
- There is a problem with opening the file in text editors, because it have non ascii bytes at head.
Correct. With the environment stored as a file in FAT it is NOT also stored in plain text. You would need to use fw_printenv/setenv to modify it.
Dear Dmitriy,
In message 1382090916.95783.YahooMailNeo@web160602.mail.bf1.yahoo.com you wrote:
This is bad.
No matter what file name you are using, this is NOT a text file. It is a binary data structure.
Dmitriy Alekseev
