[U-Boot] Secure update of uboot devices?
With the new threats like Stuxnet and Duqu one need to improve on how new updates to software is distrubuted to devcies so one can be sure that it's not a hacked or modified software that runs in the device. We use uboot + usb stick to update the software in our devices. Have anyone been trying out to add e.g cryptated,certificates or rsa keys to uboot?
sha1sum of the file isn't enough?
sha1sum sum is yes enough to verify that no files have been modified on the file system on the already installed Linux device.
But my case here is if one need to update the software on the device out somewhere in the world we have now made a usb stick and uboot looks for special files first on the usb stick before it continues normal boot. How can one ensure that the software on the usb stick is not altered on the way to include some additional unwanted features?
I mean a sha1sum on the usb stick one would ofcource also modify at same time as one add some files to the sub stick. I have been thinking of public/private keys but then you have the problem that these expires
Dear Andreas,
In message CAB+EkH4j-UoUyHb=XgDbGRncX=Oq6+3+MNjWStiuojoOYUcMPw@mail.gmail.com you wrote:
It is also good enough to ensure that the files on any distribution media have not been corrupted or modified in some way. Of course it dies not protect against intentional modifications.
You cannot. Actually you would have to insure first that the U-Boot running on that system has not been tampered with. If I were to attack such a system, I'd probably first install (or otherwise run) a version of U-boot that has any such security checks disabled or removed.
On Fri, 30 Dec 2011 13:37:47 +0100 Wolfgang Denk wd@denx.de wrote:
Dear Andreas,
That depends on your hardware. SoCs with Freescale SEC v4+ h/w can enable a trusted boot mode after writing a private key to special-purpose on-chip key memory and subsequently blowing a fuse. The trusted boot mode ensures a continuous root of trust by booting an initial (u-)bootloader from on-chip firmware that verifies the authenticity of the u-boot image it loads before executing it. The initial bootloader is written in a similar fashion to the private key of the chip, and similarly can never be overwritten. Subsequent loads, e.g., u-boot->kernel, kernel->app, are free to inherit that same root of trust.
The Freescale BSP version of u-boot includes some of Freescale's secure boot work [1], but since then it's been modified to use the dedicated crypto unit to do the crypto and therefore boot much faster. Ideally u-boot would be modified to use either s/w or h/w crypto, but unfortunately I haven't had the time to look into it.
Kim
[1] I don't know where to find the latest that uses the h/w to do the crypto right now, but there's some s/w crypto based code available here:
http://git.freescale.com/git/cgit.cgi/ppc/sdk/u-boot.git/log/
Hello
Our linux boxes with Uboot and frescale mpc5200B are set at production with software and that is no problem. But then when the need to update software afterwards in the field is today only so simple that if uboot finds a usb stick with a file uImage then it will start that and do all the updates. What I am after a litle more tamperproff way of knowing that the software that is updated to these hardware software are not totally modified / hacked.
If one could have e.g uboot to verify uImage that it signed with right private key (The software in production would have compiled in the public part), I relize it can be hard to prevent all things with our current hardware but if one could at last rise the level so that at least some jtag debugger is need to modify the content and not only a only basic tools found in any windows/linux computer. We are also starting to design next generation of hardware and here more can be done in the hardware to rise the bar even more.
Or have you any other suggestion on how this could be improved?
Thanks in advance
Hi Andreas,
On Sat, Mar 17, 2012 at 2:25 AM, Andreas Bäck andreas.back778@gmail.com wrote:
Hello
I copied you on a series I sent a few days ago which implements verified boot using RSA, using FIT as suggested by Wolfgang. That might be closer to what you want.
Thanks in advance
participants (5)
Andreas Bäck
Kim Phillips
