[PATCH 0/2] Reduce the complexity of add_map() and count_required_pts()
Reduce the complexity of add_map() and count_required_pts() to gain better performance.
Marc Zyngier (2): arm64: Reduce add_map() complexity arm64: Reduce PT size estimation complexity
arch/arm/cpu/armv8/cache_v8.c | 201 +++++++++++++--------------------- 1 file changed, 79 insertions(+), 122 deletions(-)
In the add_map() function, for each level it populates, it iterates from the root of the PT tree, making it ineficient if a mapping needs to occur past level 1.
Instead, replace it with a recursive (and much simpler) algorithm that keeps the complexity as low as possible. With this, mapping 512GB at level 2 goes from several seconds down to not measurable on an A55 machine.
We keep the block mappings at level 1 for now though.
Signed-off-by: Marc Zyngier maz@kernel.org Signed-off-by: Pierre-Clément Tosi ptosi@google.com [ Paul: pick from the Android tree. Fixup Pierre's commit. Rebase to the upstream ] Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: Tom Rini trini@konsulko.com Link: https://android.googlesource.com/platform/external/u-boot/+/96ad729cf4cab53b... Link: https://android.googlesource.com/platform/external/u-boot/+/6be9330601d81545... --- arch/arm/cpu/armv8/cache_v8.c | 94 +++++++++++++++++------------------ 1 file changed, 46 insertions(+), 48 deletions(-)
diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index f333ad8889..876344e1b4 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -299,61 +299,59 @@ static void split_block(u64 *pte, int level) set_pte_table(pte, new_table); }
-/* Add one mm_region map entry to the page tables */ -static void add_map(struct mm_region *map) +static void map_range(u64 virt, u64 phys, u64 size, int level, + u64 *table, u64 attrs) { - u64 *pte; - u64 virt = map->virt; - u64 phys = map->phys; - u64 size = map->size; - u64 attrs = map->attrs | PTE_TYPE_BLOCK | PTE_BLOCK_AF; - u64 blocksize; - int level; - u64 *new_table; + u64 map_size = BIT_ULL(level2shift(level)); + int i, idx;
- while (size) { - pte = find_pte(virt, 0); - if (pte && (pte_type(pte) == PTE_TYPE_FAULT)) { - debug("Creating table for virt 0x%llx\n", virt); - new_table = create_table(); - set_pte_table(pte, new_table); - } + idx = (virt >> level2shift(level)) & (MAX_PTE_ENTRIES - 1); + for (i = idx; size; i++) { + u64 next_size, *next_table;
- for (level = 1; level < 4; level++) { - pte = find_pte(virt, level); - if (!pte) - panic("pte not found\n"); - - blocksize = 1ULL << level2shift(level); - debug("Checking if pte fits for virt=%llx size=%llx blocksize=%llx\n", - virt, size, blocksize); - if (size >= blocksize && !(virt & (blocksize - 1))) { - /* Page fits, create block PTE */ - debug("Setting PTE %p to block virt=%llx\n", - pte, virt); - if (level == 3) - *pte = phys | attrs | PTE_TYPE_PAGE; - else - *pte = phys | attrs; - virt += blocksize; - phys += blocksize; - size -= blocksize; - break; - } else if (pte_type(pte) == PTE_TYPE_FAULT) { - /* Page doesn't fit, create subpages */ - debug("Creating subtable for virt 0x%llx blksize=%llx\n", - virt, blocksize); - new_table = create_table(); - set_pte_table(pte, new_table); - } else if (pte_type(pte) == PTE_TYPE_BLOCK) { - debug("Split block into subtable for virt 0x%llx blksize=0x%llx\n", - virt, blocksize); - split_block(pte, level); - } + if (level >= 1 && + size >= map_size && !(virt & (map_size - 1))) { + if (level == 3) + table[i] = phys | attrs | PTE_TYPE_PAGE; + else + table[i] = phys | attrs; + + virt += map_size; + phys += map_size; + size -= map_size; + + continue; } + + /* Going one level down */ + if (pte_type(&table[i]) == PTE_TYPE_FAULT) + set_pte_table(&table[i], create_table()); + + next_table = (u64 *)(table[i] & GENMASK_ULL(47, PAGE_SHIFT)); + next_size = min(map_size - (virt & (map_size - 1)), size); + + map_range(virt, phys, next_size, level + 1, next_table, attrs); + + virt += next_size; + phys += next_size; + size -= next_size; } }
+static void add_map(struct mm_region *map) +{ + u64 attrs = map->attrs | PTE_TYPE_BLOCK | PTE_BLOCK_AF; + u64 va_bits; + int level = 0; + + get_tcr(NULL, &va_bits); + if (va_bits < 39) + level = 1; + + map_range(map->virt, map->phys, map->size, level, + (u64 *)gd->arch.tlb_addr, attrs); +} + enum pte_type { PTE_INVAL, PTE_BLOCK,
Hello Marc,
this patch somehow broke the boot of my imx8qm board. I run into this issue:
U-Boot 2023.07-rc6-00004-g5527698481 (Aug 01 2023 - 10:10:52 +0200)
Model: Advantech iMX8QM DMSSE20 Board: DMS-SE20A1 8GB Build: SCFW 549b1e18, SECO-FW c9de51c0, ATF 5782363 Boot: USB DRAM: 8 GiB "Error" handler, esr 0xbf000000 elr: 0000000080020938 lr : 00000000800209c8 (reloc) elr: 00000000ffecf938 lr : 00000000ffecf9c8 x0 : 0000000000000001 x1 : 0000000060000000 x2 : 0000000010000000 x3 : 0000000000000002 x4 : 0000000040000000 x5 : 0060000000000401 x6 : 0000000000000800 x7 : 00000000fff44a60 x8 : 0068000000000481 x9 : 0000000000000008 x10: 000000000a200023 x11: 0000000000000002 x12: 0000000000000002 x13: 0000000080095a00 x14: 00000000ffffffff x15: 00000000ffecfd2c x16: 000000008005454c x17: 0000000000000000 x18: 00000000fd6afd50 x19: 000000000fe00000 x20: 0000000000000000 x21: 0060000000000401 x22: 0000000060200000 x23: 0000000000200000 x24: 0000000040000808 x25: 00000000001fffff x26: 0000000000000003 x27: 0000000060200000 x28: 0000000000000002 x29: 00000000fd6ab110
Code: a94573fb a8c67bfd d65f03c0 b9418a40 (8a160334) Resetting CPU ...
resetting ... SCI reboot request............................................................................................................................................................................................................................
After some bisecting this patch poped up:
41e2787f5ec4249cb2e77a3ebd3c49035e3c6535 is the first bad commit arm64: Reduce add_map() complexity
After I reverted everything on top of this patch its booting again with v2023.07
commit c1da6fdb5c239b432440721772d993e63cfdeb20 armv8: enable HAFDBS for other ELx when FEAT_HAFDBS is present
commit 836b8d4b205d2175b57cb9ef271e638b0c116e89 arm64: Use level-2 for largest block mappings when FEAT_HAFDBS is present
commit 6cdf6b7a340db4ddd008516181de7e08e3f8c213 arm64: Use FEAT_HAFDBS to track dirty pages when available
Do you have any idea whats going on here?
Best Regards,
Oliver
Hello Marc,
Is this behavior somehow releated to the known Cache coherency issue on A53 Core on NXP imx8qm?
https://lore.kernel.org/linux-arm-kernel/ZDflS%2FCnEx8iCspk@FVFF77S0Q05N/T/#...
+Jason Liu +Peng Fan
Best Regards,
Oliver
On Tue, 01 Aug 2023 09:53:52 +0100, Oliver Graute oliver.graute@gmail.com wrote:
Hello Marc,
SError.
Not really. I can only tell you that your HW has generated a SError, which is usually pretty fatal. There could be all sort of reasons why this happen, such as mapping a piece of address space that you are not supposed to access.
If the previous incarnation of the PT code was behaving in a better way, the way to debug this is to dump both sets of page tables and compare what they actually map, figuring out where things go wrong.
M.
Hi Paul and Tom,
On Tue, Feb 14, 2023 at 10:38 AM Ying-Chun Liu (PaulLiu) paul.liu@linaro.org wrote:
I know this is an old thread, but this commit causes the following boot regression on a colibri-imx8qxp board:
U-Boot 2024.04-rc3-00070-gecc9298a893b (Mar 08 2024 - 17:15:31 -0300)
CPU: NXP i.MX8QXP RevC A35 at 1200 MHz at 51C
DRAM: 2 GiB "Error" handler, esr 0xbf000000 elr: 0000000080020914 lr : 00000000800209c0 (reloc) elr: 00000000ffec4914 lr : 00000000ffec49c0 x0 : 0060000070800401 x1 : 0000000070000000 x2 : 0000000010000000 x3 : 0000000000000002 x4 : 0000000040000000 x5 : 0060000000000401 x6 : 0000000000000c00 x7 : 00000000fff45140 x8 : 0060000000000000 x9 : 00000000fff45100 x10: 000000000a200023 x11: 0000000000000002 x12: 0000000000000002 x13: 00000000800a10e8 x14: 00000000ffffffff x15: 00000000ffec4cb8 x16: 0000000080056a88 x17: 0000000000000000 x18: 00000000fd6c1d70 x19: 000000000f600000 x20: 0000000000000000 x21: 0060000000000401 x22: 0000000070a00000 x23: 0000000000200000 x24: 0000000040000c28 x25: 00000000001fffff x26: 0000000000000003 x27: 0000000070a00000 x28: 0000000000000002 x29: 00000000fd6bbfd0
Code: 1100047a a90573fb aa0103fb 2a0303fc (b5000113) Resetting CPU ...
resetting ...
Reverting this commit on top of master fixes the boot regression.
Any ideas?
Thanks
On Fri, 08 Mar 2024 20:22:53 +0000, Fabio Estevam festevam@gmail.com wrote:
Hi Paul and Tom,
SError. Not good.
resetting ...
Any ideas?
It would be good to narrow down which access is generating this. It is an asynchronous error, so the code above won't help.
Alternatively, and if you are sure that this is due to this change, dumping the page tables and comparing them before and after would help.
Thanks,
M.
Hi Marc,
Yes, I am sure the error is due to this change. It is 100% reproducible.
I am not familiar with this part of the code, so I would appreciate it if you could tell me how to dump the page tables so I can compare them before and after.
Thanks,
Fabio Estevam
On Sat, 09 Mar 2024 12:29:10 +0000, Fabio Estevam festevam@gmail.com wrote:
Hi Marc,
Can you figure out what memory access is triggering it? Even at narrowing it to the subsystem level would be a good indication.
You could just dump the entries as they are written. The order may not be the same, but for a given VA you should observe the same entries being written.
My hunch is that the new code is a lot more picky about the alignment of things, and that could result in something being similarly unaligned. But without access to the platform nor an idea of what gets mapped, it's a bit hard to have a clue.
Thanks,
M.
The problem happens so early that I am not able to narrow it down at subsystem level.
Does the log below help?
https://pastebin.com/raw/1i1VBA0a
If not, please send me a debug patch and I will be glad to run it here.
Thanks
Hi Marc,
I'm sorry to bother you, but have you had a chance to look at the log I shared with you?
That's the only issue preventing colibri-imx8x from booting mainline U-Boot.
We would like to get this fixed for U-Boot 2024.04.
Thanks for your help
Hi Fabio,
On Fri, Mar 15, 2024 at 08:56:17AM -0300, Fabio Estevam wrote:
Hi Marc,
I had a quick look through your logs and notice that U-Boot master attempts to map addresses in the high VA range e.g.
Checking if pte fits for virt=ffffffffe4000000 [...]
while the logs that boot successfully only use the low VA range e.g.
Checking if pte fits for virt=80193000 [...]
Unless that has recently changed (since I last worked with U-Boot), U-Boot on AArch64 only supports identity mappings and therefore was only taught how to program TTBR0_ELx (i.e. is only able to map low virtual addresses). This means that the code - with or without 41e2787f5ec4 - would be unable to map addresses such as 0xffffffffe4000000.
Now, given that 41e2787f5ec4 only affects implementation details of add_map(), I am surprised that reverting that commit changes the arguments received by the function such as virt. As a reminder, add_map() is exclusively used on mem_map:
for (i = 0; mem_map[i].size || mem_map[i].attrs; i++) add_map(&mem_map[i]);
If I read the U-Boot configs right i.e.
- configs/colibri-imx8x_defconfig: CONFIG_ARCH_IMX8=y - arch/arm/mach-imx/imx8/Makefile: obj-y += cpu.o - arch/arm/mach-imx/imx8/cpu.c: struct mm_region *mem_map = imx8_mem_map;
There is a possibility that your mem_map is getting modified by MACH-specific code. In particular, enable_caches() seems to dynamically get the MMU mappings from some RPC mechanism (see get_owned_memreg() and sc_rm_get_memreg_info()).
Could it be that whatever services those requests might be returning unexpected values? Instrumenting arch/arm/mach-imx/imx8/cpu.c and dumping mem_map (and the RPC messages) with/without the patch would help clear this up.
HTH,
Hi Pierre,
Yes, I found it strange too. I may have done something wrong the last time I instrumented the code.
I tried it again and no longer see these unexpected high virtual addresses.
Please find the new logs here:
https://pastebin.com/raw/qF3GbJry
Correct, these are the relevant files for the i.MXQ8XP.
I tried dumping the page table entries, but could not notice anything that looked suspicious.
Please let me know if you have any suggestions.
Thanks
This looks suspicious:
With 41e2787f5ec4 reverted:
Checking if pte fits for virt=1c000000 size=64000000 blocksize=40000000 Checking if pte fits for virt=1c000000 size=64000000 blocksize=200000 Checking if pte fits for virt=1c200000 size=63e00000 blocksize=40000000 Checking if pte fits for virt=1c200000 size=63e00000 blocksize=200000 Checking if pte fits for virt=1c400000 size=63c00000 blocksize=40000000 ....
In U-Boot master:
Checking if pte fits for virt=1c000000 size=64000000 blocksize=40000000 Checking if pte fits for virt=1c000000 size=24000000 blocksize=200000 Checking if pte fits for virt=1c200000 size=23e00000 blocksize=200000 Checking if pte fits for virt=1c400000 size=23c00000 blocksize=200000
The second entry has size=24000000 instead of size=64000000.
Hi Fabio,
I notice that the mem_map in these logs have overlapping ranges, which results in unnecessary work when creating the PTs. For this reason, it would make sense to prune it in arch/arm/mach-imx/imx8/cpu.c before calling dcache_enable(), IMO. On this point, you also have contiguous ranges with identical attributes (mem_map[0] and mem_map[6]), which could be merged into a single entry. This could result in more efficient MMU mappings if the mem_map entries can share a block mapping. Also note that mem_map[4].size=0 so could be dropped.
In any case, if we assume that overlapping mem_map entries are a valid input to the arch code (maybe not as it leads to potentially ambiguous behavior?), then 41e2787f5ec4 had removed support for splitting existing block mappings.
In your case, my assumption is that the function was then treating block mappings in the range 0x1c000000-0x80000000 (which get mapped, at least partially, by mem_map[0], mem_map[1], then mem_map[2]) as table mappings and was issuing read/write instructions in that range (accessing them as PTEs). As those seem to be device memory (I see they get mapped as MT_DEVICE_NGNRNE), these accesses might explain the SError you were experiencing.
Would you mind testing [1] and giving it "Tested-by:" if it addresses the issue?
Thanks,
[1]: https://lore.kernel.org/u-boot/43haokus4jdxguk4arig5tsqcgq2wbezwpbj7oti6pdkv...
Hi Pierre,
Your patch fixed the boot regression. Thanks for your fix, appreciated it!
I have replied with my Tested-by tag.
Cheers,
Fabio Estevam
count_required_pts()'s complexity is high if mappings are not using the largest possible block size (due to some other requirement such as tracking dirty pages, for example).
Let's switch to a method that follows the pattern established with the add_map() helper, and make it almost instantaneous instead of taking a large amount of time if 2MB mappings are in use instead of 1GB.
Signed-off-by: Marc Zyngier maz@kernel.org Signed-off-by: Pierre-Clément Tosi ptosi@google.com [ Paul: pick from the Android tree. Fixup Pierre's commit. Rebase to the upstream ] Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: Tom Rini trini@konsulko.com Link: https://android.googlesource.com/platform/external/u-boot/+/5d756d147e31a1cd... Link: https://android.googlesource.com/platform/external/u-boot/+/6be9330601d81545... --- arch/arm/cpu/armv8/cache_v8.c | 109 +++++++++++----------------------- 1 file changed, 34 insertions(+), 75 deletions(-)
diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index 876344e1b4..697334086f 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -352,98 +352,57 @@ static void add_map(struct mm_region *map) (u64 *)gd->arch.tlb_addr, attrs); }
-enum pte_type { - PTE_INVAL, - PTE_BLOCK, - PTE_LEVEL, -}; - -/* - * This is a recursively called function to count the number of - * page tables we need to cover a particular PTE range. If you - * call this with level = -1 you basically get the full 48 bit - * coverage. - */ -static int count_required_pts(u64 addr, int level, u64 maxaddr) +static void count_range(u64 virt, u64 size, int level, int *cntp) { - int levelshift = level2shift(level); - u64 levelsize = 1ULL << levelshift; - u64 levelmask = levelsize - 1; - u64 levelend = addr + levelsize; - int r = 0; - int i; - enum pte_type pte_type = PTE_INVAL; + u64 map_size = BIT_ULL(level2shift(level)); + int i, idx;
- for (i = 0; mem_map[i].size || mem_map[i].attrs; i++) { - struct mm_region *map = &mem_map[i]; - u64 start = map->virt; - u64 end = start + map->size; + idx = (virt >> level2shift(level)) & (MAX_PTE_ENTRIES - 1); + for (i = idx; size; i++) { + u64 next_size;
- /* Check if the PTE would overlap with the map */ - if (max(addr, start) <= min(levelend, end)) { - start = max(addr, start); - end = min(levelend, end); + if (level >= 1 && + size >= map_size && !(virt & (map_size - 1))) { + virt += map_size; + size -= map_size;
- /* We need a sub-pt for this level */ - if ((start & levelmask) || (end & levelmask)) { - pte_type = PTE_LEVEL; - break; - } + continue; + }
- /* Lv0 can not do block PTEs, so do levels here too */ - if (level <= 0) { - pte_type = PTE_LEVEL; - break; - } + /* Going one level down */ + (*cntp)++; + next_size = min(map_size - (virt & (map_size - 1)), size);
- /* PTE is active, but fits into a block */ - pte_type = PTE_BLOCK; - } - } + count_range(virt, next_size, level + 1, cntp);
- /* - * Block PTEs at this level are already covered by the parent page - * table, so we only need to count sub page tables. - */ - if (pte_type == PTE_LEVEL) { - int sublevel = level + 1; - u64 sublevelsize = 1ULL << level2shift(sublevel); - - /* Account for the new sub page table ... */ - r = 1; - - /* ... and for all child page tables that one might have */ - for (i = 0; i < MAX_PTE_ENTRIES; i++) { - r += count_required_pts(addr, sublevel, maxaddr); - addr += sublevelsize; - - if (addr >= maxaddr) { - /* - * We reached the end of address space, no need - * to look any further. - */ - break; - } - } + virt += next_size; + size -= next_size; } - - return r; }
-/* Returns the estimated required size of all page tables */ -__weak u64 get_page_table_size(void) +static int count_ranges(void) { - u64 one_pt = MAX_PTE_ENTRIES * sizeof(u64); - u64 size = 0; + int i, count = 0, level = 0; u64 va_bits; - int start_level = 0;
get_tcr(NULL, &va_bits); if (va_bits < 39) - start_level = 1; + level = 1; + + for (i = 0; mem_map[i].size || mem_map[i].attrs; i++) + count_range(mem_map[i].virt, mem_map[i].size, level, &count); + + return count; +} + +/* Returns the estimated required size of all page tables */ +__weak u64 get_page_table_size(void) +{ + u64 one_pt = MAX_PTE_ENTRIES * sizeof(u64); + u64 size;
/* Account for all page tables we would need to cover our memory map */ - size = one_pt * count_required_pts(0, start_level - 1, 1ULL << va_bits); + size = one_pt * count_ranges();
/* * We need to duplicate our page table once to have an emergency pt to
participants (6)
Fabio Estevam
Marc Zyngier
Oliver Graute
Pierre-Clément Tosi
