[PATCH] reloc_bootstage: Fix out-of-bounds read
bootstage_get_size() returns the total size of the data structure including associated records. When copying from gd->bootstage, only the allocation size of gd->bootstage must be used. Otherwise too much memory is copied.
This bug caused no harm so far because gd->new_bootstage is always large enough and reading beyond the allocation length of gd->bootstage caused no problem due to the U-Boot memory layout.
Fix by using the correct size and perform the initial copy directly in bootstage_relocate() to have the whole relocation process in the same function.
Signed-off-by: Richard Weinberger richard@nod.at --- common/board_f.c | 6 ------ common/bootstage.c | 7 ++++++- 2 files changed, 6 insertions(+), 7 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 039d6d712d..f4d87692b9 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -683,12 +683,6 @@ static int reloc_bootstage(void) if (gd->flags & GD_FLG_SKIP_RELOC) return 0; if (gd->new_bootstage) { - int size = bootstage_get_size(); - - debug("Copying bootstage from %p to %p, size %x\n", - gd->bootstage, gd->new_bootstage, size); - memcpy(gd->new_bootstage, gd->bootstage, size); - gd->bootstage = gd->new_bootstage; bootstage_relocate(); } #endif diff --git a/common/bootstage.c b/common/bootstage.c index 0e6d80718f..aea5a318df 100644 --- a/common/bootstage.c +++ b/common/bootstage.c @@ -58,10 +58,15 @@ struct bootstage_hdr {
int bootstage_relocate(void) { - struct bootstage_data *data = gd->bootstage; + struct bootstage_data *data; int i; char *ptr;
+ debug("Copying bootstage from %p to %p\n", gd->bootstage, + gd->new_bootstage); + memcpy(gd->new_bootstage, gd->bootstage, sizeof(struct bootstage_data)); + data = gd->bootstage = gd->new_bootstage; + /* Figure out where to relocate the strings to */ ptr = (char *)(data + 1);
Hi Richard,
Nice commit message.
Can you use 'bootstage' as the commit tag?
gd->new_bootstage);
I would like to have the relocation addresses in board_f like with other relocations, so it is easy to see what is happening, in one file. So how about passing the old address to bootstage_relocate() so it doesn't need to access gd->new_bootstage ?
-- 2.35.3
Simon,
Am Samstag, 13. Juli 2024, 17:13:50 CEST schrieb Simon Glass:
Sure.
gd->new_bootstage);
You mean passing the *new* address?
Thanks, //richard
Hi Richard,
On Mon, 29 Jul 2024 at 15:57, Richard Weinberger richard@sigma-star.at wrote:
Simon,
Sure.
gd->new_bootstage);
Yes, sorry.
REgards, Simon
Richard Weinberger
Richard Weinberger
