[U-Boot] [PATCH 00/18] Initial support of driver brcmnand (from kernel 4.18)
This serie is a port the support of driver brcmnand from kernel 4.18 to u-boot. I've tried to stay as close as possible to the kernel. In this first port, I haven't ported the support of DMA, it's not mandatory in the first step and it could be added later.
This code has been tested on bcm6838 (mips), bcm63158 (arm) and bcm6858 (arm64).
In the code, I've used "#ifndef __UBOOT__" to show the difference between the kernel code.
I've also added a file brcmnand_compat.[hc] to compat function with the kernel (for example devm_clk_get).
Changes in v1: - define less function in brcmnand_compat.c/h and add more #ifndef __UBOOT__ - port completion.h (function stubbed) from kernel 4.18 - define devm_ioremap for everybody - remove duplicate SoB - update text commit - add support of bcm63158
Boris Brezillon (1): mtd: nand: provide several helpers to do common NAND operations
Brian Norris (1): mtd: add get/set of_node/flash_node helpers
Marc Gonzalez (1): mtd: nand: import nand_hw_control_init()
Philippe Reynes (15): arm: asm: io.h: define readX_relaxed and writeX_relaxed include: linux: io: define devm_ioremap on board with ioremap compat linux: import completion from linux 4.18 drivers: nand: brcmnand: add initial support drivers: nand: brcmnand: add parameter parameter-page-big-endian drivers: nand: brcmnand: add an option to read the write-protect from device tree dt: bcm6838: add nand controller dt: bcm968380gerg: enable nand controller bcm968380gerg: add nand support dt: bcm6858: add nand controller dt: bcm968580xref: enable nand controller bcm968580xref: add nand support dt: bcm63158: add nand controller dt: bcm963158: enable nand controller bcm963158: add nand support
arch/arm/dts/bcm63158.dtsi | 13 + arch/arm/dts/bcm6858.dtsi | 13 + arch/arm/dts/bcm963158.dts | 15 + arch/arm/dts/bcm968580xref.dts | 15 + arch/arm/include/asm/io.h | 21 + arch/mips/dts/brcm,bcm6838.dtsi | 13 + arch/mips/dts/brcm,bcm968380gerg.dts | 12 + configs/bcm963158_ram_defconfig | 6 + configs/bcm968380gerg_ram_defconfig | 7 + configs/bcm968580xref_ram_defconfig | 7 + drivers/mtd/nand/raw/Kconfig | 25 + drivers/mtd/nand/raw/Makefile | 1 + drivers/mtd/nand/raw/brcmnand/Makefile | 7 + drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c | 123 + drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c | 122 + drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c | 123 + drivers/mtd/nand/raw/brcmnand/brcmnand.c | 2805 +++++++++++++++++++++++ drivers/mtd/nand/raw/brcmnand/brcmnand.h | 63 + drivers/mtd/nand/raw/brcmnand/brcmnand_compat.c | 66 + drivers/mtd/nand/raw/brcmnand/brcmnand_compat.h | 15 + drivers/mtd/nand/raw/nand_base.c | 1013 ++++++-- include/configs/broadcom_bcm963158.h | 7 + include/configs/broadcom_bcm968380gerg.h | 7 + include/configs/broadcom_bcm968580xref.h | 7 + include/linux/completion.h | 173 ++ include/linux/io.h | 2 +- include/linux/mtd/rawnand.h | 49 + 27 files changed, 4569 insertions(+), 161 deletions(-) create mode 100644 drivers/mtd/nand/raw/brcmnand/Makefile create mode 100644 drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c create mode 100644 drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c create mode 100644 drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c create mode 100644 drivers/mtd/nand/raw/brcmnand/brcmnand.c create mode 100644 drivers/mtd/nand/raw/brcmnand/brcmnand.h create mode 100644 drivers/mtd/nand/raw/brcmnand/brcmnand_compat.c create mode 100644 drivers/mtd/nand/raw/brcmnand/brcmnand_compat.h create mode 100644 include/linux/completion.h
Linux commit 28b8b26b308 ("mtd: add get/set of_node/flash_node helpers")
We are going to begin using the mtd->dev.of_node field for MTD device nodes, so let's add helpers for it. Also, we'll be making some conversions on spi_nor (and nand_chip eventually) too, so get that ready with their own helpers.
Signed-off-by: Brian Norris computersforpeace@gmail.com Reviewed-by: Boris Brezillon boris.brezillon@free-electrons.com [Philippe Reynes: only add function nand_set_flash_node and nand_get_flash_node because others were already backported]
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- include/linux/mtd/rawnand.h | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/include/linux/mtd/rawnand.h b/include/linux/mtd/rawnand.h index 9f5dc81..e2bd598 100644 --- a/include/linux/mtd/rawnand.h +++ b/include/linux/mtd/rawnand.h @@ -15,6 +15,7 @@
#include <config.h>
+#include <dm/device.h> #include <linux/compat.h> #include <linux/mtd/mtd.h> #include <linux/mtd/flashchip.h> @@ -961,6 +962,17 @@ struct nand_chip { void *priv; };
+static inline void nand_set_flash_node(struct nand_chip *chip, + ofnode node) +{ + chip->flash_node = ofnode_to_offset(node); +} + +static inline ofnode nand_get_flash_node(struct nand_chip *chip) +{ + return offset_to_ofnode(chip->flash_node); +} + static inline struct nand_chip *mtd_to_nand(struct mtd_info *mtd) { return container_of(mtd, struct nand_chip, mtd);
Linux commit d45bc58dd3b ("mtd: nand: import nand_hw_control_init()")
The code to initialize a struct nand_hw_control is duplicated across several drivers. Factorize it using an inline function.
Signed-off-by: Marc Gonzalez marc_gonzalez@sigmadesigns.com Signed-off-by: Boris Brezillon boris.brezillon@free-electrons.com [Philippe Reynes: adapt code to u-boot and only keep new function]
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- include/linux/mtd/rawnand.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/linux/mtd/rawnand.h b/include/linux/mtd/rawnand.h index e2bd598..96b5847 100644 --- a/include/linux/mtd/rawnand.h +++ b/include/linux/mtd/rawnand.h @@ -499,6 +499,13 @@ struct nand_hw_control { struct nand_chip *active; };
+static inline void nand_hw_control_init(struct nand_hw_control *nfc) +{ + nfc->active = NULL; + spin_lock_init(&nfc->lock); + init_waitqueue_head(&nfc->wq); +} + /** * struct nand_ecc_step_info - ECC step information of ECC engine * @stepsize: data bytes per ECC step
From: Boris Brezillon boris.brezillon@free-electrons.com
Linux commit 97d90da8a88 ("mtd: nand: provide several helpers to do common NAND operations")
This is part of the process of removing direct calls to ->cmdfunc() outside of the core in order to introduce a better interface to execute NAND operations.
Here we provide several helpers and make use of them to remove all direct calls to ->cmdfunc(). This way, we can easily modify those helpers to make use of the new ->exec_op() interface when available.
Signed-off-by: Boris Brezillon boris.brezillon@free-electrons.com [miquel.raynal@free-electrons.com: rebased and fixed some conflicts] Signed-off-by: Miquel Raynal miquel.raynal@free-electrons.com Acked-by: Masahiro Yamada yamada.masahiro@socionext.com [Philippe Reynes: adapt code to u-boot and only keep new function]
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- drivers/mtd/nand/raw/nand_base.c | 1013 ++++++++++++++++++++++++++++++++------ include/linux/mtd/rawnand.h | 30 ++ 2 files changed, 883 insertions(+), 160 deletions(-)
diff --git a/drivers/mtd/nand/raw/nand_base.c b/drivers/mtd/nand/raw/nand_base.c index 6d2ff58..e07bd6b 100644 --- a/drivers/mtd/nand/raw/nand_base.c +++ b/drivers/mtd/nand/raw/nand_base.c @@ -486,14 +486,19 @@ static int nand_block_markbad_lowlevel(struct mtd_info *mtd, loff_t ofs) static int nand_check_wp(struct mtd_info *mtd) { struct nand_chip *chip = mtd_to_nand(mtd); + u8 status; + int ret;
/* Broken xD cards report WP despite being writable */ if (chip->options & NAND_BROKEN_XD) return 0;
/* Check the WP bit */ - chip->cmdfunc(mtd, NAND_CMD_STATUS, -1, -1); - return (chip->read_byte(mtd) & NAND_STATUS_WP) ? 0 : 1; + ret = nand_status_op(chip, &status); + if (ret) + return ret; + + return status & NAND_STATUS_WP ? 0 : 1; }
/** @@ -575,11 +580,18 @@ static void nand_wait_status_ready(struct mtd_info *mtd, unsigned long timeo) { register struct nand_chip *chip = mtd_to_nand(mtd); u32 time_start; + int ret;
timeo = (CONFIG_SYS_HZ * timeo) / 1000; time_start = get_timer(0); while (get_timer(time_start) < timeo) { - if ((chip->read_byte(mtd) & NAND_STATUS_READY)) + u8 status; + + ret = nand_read_data_op(chip, &status, sizeof(status), true); + if (ret) + return; + + if (status & NAND_STATUS_READY) break; WATCHDOG_RESET(); } @@ -851,7 +863,15 @@ static void panic_nand_wait(struct mtd_info *mtd, struct nand_chip *chip, if (chip->dev_ready(mtd)) break; } else { - if (chip->read_byte(mtd) & NAND_STATUS_READY) + int ret; + u8 status; + + ret = nand_read_data_op(chip, &status, sizeof(status), + true); + if (ret) + return; + + if (status & NAND_STATUS_READY) break; } mdelay(1); @@ -867,8 +887,9 @@ static void panic_nand_wait(struct mtd_info *mtd, struct nand_chip *chip, */ static int nand_wait(struct mtd_info *mtd, struct nand_chip *chip) { - int status; unsigned long timeo = 400; + u8 status; + int ret;
led_trigger_event(nand_led_trigger, LED_FULL);
@@ -878,7 +899,9 @@ static int nand_wait(struct mtd_info *mtd, struct nand_chip *chip) */ ndelay(100);
- chip->cmdfunc(mtd, NAND_CMD_STATUS, -1, -1); + ret = nand_status_op(chip, NULL); + if (ret) + return ret;
u32 timer = (CONFIG_SYS_HZ * timeo) / 1000; u32 time_start; @@ -889,13 +912,21 @@ static int nand_wait(struct mtd_info *mtd, struct nand_chip *chip) if (chip->dev_ready(mtd)) break; } else { - if (chip->read_byte(mtd) & NAND_STATUS_READY) + ret = nand_read_data_op(chip, &status, + sizeof(status), true); + if (ret) + return ret; + + if (status & NAND_STATUS_READY) break; } } led_trigger_event(nand_led_trigger, LED_OFF);
- status = (int)chip->read_byte(mtd); + ret = nand_read_data_op(chip, &status, sizeof(status), true); + if (ret) + return ret; + /* This can happen if in case of timeout or buggy dev_ready */ WARN_ON(!(status & NAND_STATUS_READY)); return status; @@ -1048,6 +1079,516 @@ static void __maybe_unused nand_release_data_interface(struct nand_chip *chip) }
/** + * nand_read_page_op - Do a READ PAGE operation + * @chip: The NAND chip + * @page: page to read + * @offset_in_page: offset within the page + * @buf: buffer used to store the data + * @len: length of the buffer + * + * This function issues a READ PAGE operation. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_read_page_op(struct nand_chip *chip, unsigned int page, + unsigned int offset_in_page, void *buf, unsigned int len) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + if (len && !buf) + return -EINVAL; + + if (offset_in_page + len > mtd->writesize + mtd->oobsize) + return -EINVAL; + + chip->cmdfunc(mtd, NAND_CMD_READ0, offset_in_page, page); + if (len) + chip->read_buf(mtd, buf, len); + + return 0; +} +EXPORT_SYMBOL_GPL(nand_read_page_op); + +/** + * nand_read_param_page_op - Do a READ PARAMETER PAGE operation + * @chip: The NAND chip + * @page: parameter page to read + * @buf: buffer used to store the data + * @len: length of the buffer + * + * This function issues a READ PARAMETER PAGE operation. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +static int nand_read_param_page_op(struct nand_chip *chip, u8 page, void *buf, + unsigned int len) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + unsigned int i; + u8 *p = buf; + + if (len && !buf) + return -EINVAL; + + chip->cmdfunc(mtd, NAND_CMD_PARAM, page, -1); + for (i = 0; i < len; i++) + p[i] = chip->read_byte(mtd); + + return 0; +} + +/** + * nand_change_read_column_op - Do a CHANGE READ COLUMN operation + * @chip: The NAND chip + * @offset_in_page: offset within the page + * @buf: buffer used to store the data + * @len: length of the buffer + * @force_8bit: force 8-bit bus access + * + * This function issues a CHANGE READ COLUMN operation. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_change_read_column_op(struct nand_chip *chip, + unsigned int offset_in_page, void *buf, + unsigned int len, bool force_8bit) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + if (len && !buf) + return -EINVAL; + + if (offset_in_page + len > mtd->writesize + mtd->oobsize) + return -EINVAL; + + chip->cmdfunc(mtd, NAND_CMD_RNDOUT, offset_in_page, -1); + if (len) + chip->read_buf(mtd, buf, len); + + return 0; +} +EXPORT_SYMBOL_GPL(nand_change_read_column_op); + +/** + * nand_read_oob_op - Do a READ OOB operation + * @chip: The NAND chip + * @page: page to read + * @offset_in_oob: offset within the OOB area + * @buf: buffer used to store the data + * @len: length of the buffer + * + * This function issues a READ OOB operation. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_read_oob_op(struct nand_chip *chip, unsigned int page, + unsigned int offset_in_oob, void *buf, unsigned int len) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + if (len && !buf) + return -EINVAL; + + if (offset_in_oob + len > mtd->oobsize) + return -EINVAL; + + chip->cmdfunc(mtd, NAND_CMD_READOOB, offset_in_oob, page); + if (len) + chip->read_buf(mtd, buf, len); + + return 0; +} +EXPORT_SYMBOL_GPL(nand_read_oob_op); + +/** + * nand_prog_page_begin_op - starts a PROG PAGE operation + * @chip: The NAND chip + * @page: page to write + * @offset_in_page: offset within the page + * @buf: buffer containing the data to write to the page + * @len: length of the buffer + * + * This function issues the first half of a PROG PAGE operation. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_prog_page_begin_op(struct nand_chip *chip, unsigned int page, + unsigned int offset_in_page, const void *buf, + unsigned int len) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + if (len && !buf) + return -EINVAL; + + if (offset_in_page + len > mtd->writesize + mtd->oobsize) + return -EINVAL; + + chip->cmdfunc(mtd, NAND_CMD_SEQIN, offset_in_page, page); + + if (buf) + chip->write_buf(mtd, buf, len); + + return 0; +} +EXPORT_SYMBOL_GPL(nand_prog_page_begin_op); + +/** + * nand_prog_page_end_op - ends a PROG PAGE operation + * @chip: The NAND chip + * + * This function issues the second half of a PROG PAGE operation. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_prog_page_end_op(struct nand_chip *chip) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + int status; + + chip->cmdfunc(mtd, NAND_CMD_PAGEPROG, -1, -1); + + status = chip->waitfunc(mtd, chip); + if (status & NAND_STATUS_FAIL) + return -EIO; + + return 0; +} +EXPORT_SYMBOL_GPL(nand_prog_page_end_op); + +/** + * nand_prog_page_op - Do a full PROG PAGE operation + * @chip: The NAND chip + * @page: page to write + * @offset_in_page: offset within the page + * @buf: buffer containing the data to write to the page + * @len: length of the buffer + * + * This function issues a full PROG PAGE operation. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_prog_page_op(struct nand_chip *chip, unsigned int page, + unsigned int offset_in_page, const void *buf, + unsigned int len) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + int status; + + if (!len || !buf) + return -EINVAL; + + if (offset_in_page + len > mtd->writesize + mtd->oobsize) + return -EINVAL; + + chip->cmdfunc(mtd, NAND_CMD_SEQIN, offset_in_page, page); + chip->write_buf(mtd, buf, len); + chip->cmdfunc(mtd, NAND_CMD_PAGEPROG, -1, -1); + + status = chip->waitfunc(mtd, chip); + if (status & NAND_STATUS_FAIL) + return -EIO; + + return 0; +} +EXPORT_SYMBOL_GPL(nand_prog_page_op); + +/** + * nand_change_write_column_op - Do a CHANGE WRITE COLUMN operation + * @chip: The NAND chip + * @offset_in_page: offset within the page + * @buf: buffer containing the data to send to the NAND + * @len: length of the buffer + * @force_8bit: force 8-bit bus access + * + * This function issues a CHANGE WRITE COLUMN operation. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_change_write_column_op(struct nand_chip *chip, + unsigned int offset_in_page, + const void *buf, unsigned int len, + bool force_8bit) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + if (len && !buf) + return -EINVAL; + + if (offset_in_page + len > mtd->writesize + mtd->oobsize) + return -EINVAL; + + chip->cmdfunc(mtd, NAND_CMD_RNDIN, offset_in_page, -1); + if (len) + chip->write_buf(mtd, buf, len); + + return 0; +} +EXPORT_SYMBOL_GPL(nand_change_write_column_op); + +/** + * nand_readid_op - Do a READID operation + * @chip: The NAND chip + * @addr: address cycle to pass after the READID command + * @buf: buffer used to store the ID + * @len: length of the buffer + * + * This function sends a READID command and reads back the ID returned by the + * NAND. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_readid_op(struct nand_chip *chip, u8 addr, void *buf, + unsigned int len) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + unsigned int i; + u8 *id = buf; + + if (len && !buf) + return -EINVAL; + + chip->cmdfunc(mtd, NAND_CMD_READID, addr, -1); + + for (i = 0; i < len; i++) + id[i] = chip->read_byte(mtd); + + return 0; +} +EXPORT_SYMBOL_GPL(nand_readid_op); + +/** + * nand_status_op - Do a STATUS operation + * @chip: The NAND chip + * @status: out variable to store the NAND status + * + * This function sends a STATUS command and reads back the status returned by + * the NAND. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_status_op(struct nand_chip *chip, u8 *status) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + chip->cmdfunc(mtd, NAND_CMD_STATUS, -1, -1); + if (status) + *status = chip->read_byte(mtd); + + return 0; +} +EXPORT_SYMBOL_GPL(nand_status_op); + +/** + * nand_exit_status_op - Exit a STATUS operation + * @chip: The NAND chip + * + * This function sends a READ0 command to cancel the effect of the STATUS + * command to avoid reading only the status until a new read command is sent. + * + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_exit_status_op(struct nand_chip *chip) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + chip->cmdfunc(mtd, NAND_CMD_READ0, -1, -1); + + return 0; +} +EXPORT_SYMBOL_GPL(nand_exit_status_op); + +/** + * nand_erase_op - Do an erase operation + * @chip: The NAND chip + * @eraseblock: block to erase + * + * This function sends an ERASE command and waits for the NAND to be ready + * before returning. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_erase_op(struct nand_chip *chip, unsigned int eraseblock) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + unsigned int page = eraseblock << + (chip->phys_erase_shift - chip->page_shift); + int status; + + chip->cmdfunc(mtd, NAND_CMD_ERASE1, -1, page); + chip->cmdfunc(mtd, NAND_CMD_ERASE2, -1, -1); + + status = chip->waitfunc(mtd, chip); + if (status < 0) + return status; + + if (status & NAND_STATUS_FAIL) + return -EIO; + + return 0; +} +EXPORT_SYMBOL_GPL(nand_erase_op); + +/** + * nand_set_features_op - Do a SET FEATURES operation + * @chip: The NAND chip + * @feature: feature id + * @data: 4 bytes of data + * + * This function sends a SET FEATURES command and waits for the NAND to be + * ready before returning. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +static int nand_set_features_op(struct nand_chip *chip, u8 feature, + const void *data) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + const u8 *params = data; + int i, status; + + chip->cmdfunc(mtd, NAND_CMD_SET_FEATURES, feature, -1); + for (i = 0; i < ONFI_SUBFEATURE_PARAM_LEN; ++i) + chip->write_byte(mtd, params[i]); + + status = chip->waitfunc(mtd, chip); + if (status & NAND_STATUS_FAIL) + return -EIO; + + return 0; +} + +/** + * nand_get_features_op - Do a GET FEATURES operation + * @chip: The NAND chip + * @feature: feature id + * @data: 4 bytes of data + * + * This function sends a GET FEATURES command and waits for the NAND to be + * ready before returning. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +static int nand_get_features_op(struct nand_chip *chip, u8 feature, + void *data) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + u8 *params = data; + int i; + + chip->cmdfunc(mtd, NAND_CMD_GET_FEATURES, feature, -1); + for (i = 0; i < ONFI_SUBFEATURE_PARAM_LEN; ++i) + params[i] = chip->read_byte(mtd); + + return 0; +} + +/** + * nand_reset_op - Do a reset operation + * @chip: The NAND chip + * + * This function sends a RESET command and waits for the NAND to be ready + * before returning. + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_reset_op(struct nand_chip *chip) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + chip->cmdfunc(mtd, NAND_CMD_RESET, -1, -1); + + return 0; +} +EXPORT_SYMBOL_GPL(nand_reset_op); + +/** + * nand_read_data_op - Read data from the NAND + * @chip: The NAND chip + * @buf: buffer used to store the data + * @len: length of the buffer + * @force_8bit: force 8-bit bus access + * + * This function does a raw data read on the bus. Usually used after launching + * another NAND operation like nand_read_page_op(). + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_read_data_op(struct nand_chip *chip, void *buf, unsigned int len, + bool force_8bit) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + if (!len || !buf) + return -EINVAL; + + if (force_8bit) { + u8 *p = buf; + unsigned int i; + + for (i = 0; i < len; i++) + p[i] = chip->read_byte(mtd); + } else { + chip->read_buf(mtd, buf, len); + } + + return 0; +} +EXPORT_SYMBOL_GPL(nand_read_data_op); + +/** + * nand_write_data_op - Write data from the NAND + * @chip: The NAND chip + * @buf: buffer containing the data to send on the bus + * @len: length of the buffer + * @force_8bit: force 8-bit bus access + * + * This function does a raw data write on the bus. Usually used after launching + * another NAND operation like nand_write_page_begin_op(). + * This function does not select/unselect the CS line. + * + * Returns 0 on success, a negative error code otherwise. + */ +int nand_write_data_op(struct nand_chip *chip, const void *buf, + unsigned int len, bool force_8bit) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + + if (!len || !buf) + return -EINVAL; + + if (force_8bit) { + const u8 *p = buf; + unsigned int i; + + for (i = 0; i < len; i++) + chip->write_byte(mtd, p[i]); + } else { + chip->write_buf(mtd, buf, len); + } + + return 0; +} +EXPORT_SYMBOL_GPL(nand_write_data_op); + +/** * nand_reset - Reset and initialize a NAND device * @chip: The NAND chip * @chipnr: Internal die id @@ -1068,8 +1609,10 @@ int nand_reset(struct nand_chip *chip, int chipnr) * interface settings, hence this weird ->select_chip() dance. */ chip->select_chip(mtd, chipnr); - chip->cmdfunc(mtd, NAND_CMD_RESET, -1, -1); + ret = nand_reset_op(chip); chip->select_chip(mtd, -1); + if (ret) + return ret;
chip->select_chip(mtd, chipnr); ret = nand_setup_data_interface(chip, chipnr); @@ -1220,9 +1763,19 @@ EXPORT_SYMBOL(nand_check_erased_ecc_chunk); static int nand_read_page_raw(struct mtd_info *mtd, struct nand_chip *chip, uint8_t *buf, int oob_required, int page) { - chip->read_buf(mtd, buf, mtd->writesize); - if (oob_required) - chip->read_buf(mtd, chip->oob_poi, mtd->oobsize); + int ret; + + ret = nand_read_data_op(chip, buf, mtd->writesize, false); + if (ret) + return ret; + + if (oob_required) { + ret = nand_read_data_op(chip, chip->oob_poi, mtd->oobsize, + false); + if (ret) + return ret; + } + return 0; }
@@ -1243,29 +1796,46 @@ static int nand_read_page_raw_syndrome(struct mtd_info *mtd, int eccsize = chip->ecc.size; int eccbytes = chip->ecc.bytes; uint8_t *oob = chip->oob_poi; - int steps, size; + int steps, size, ret;
for (steps = chip->ecc.steps; steps > 0; steps--) { - chip->read_buf(mtd, buf, eccsize); + ret = nand_read_data_op(chip, buf, eccsize, false); + if (ret) + return ret; + buf += eccsize;
if (chip->ecc.prepad) { - chip->read_buf(mtd, oob, chip->ecc.prepad); + ret = nand_read_data_op(chip, oob, chip->ecc.prepad, + false); + if (ret) + return ret; + oob += chip->ecc.prepad; }
- chip->read_buf(mtd, oob, eccbytes); + ret = nand_read_data_op(chip, oob, eccbytes, false); + if (ret) + return ret; + oob += eccbytes;
if (chip->ecc.postpad) { - chip->read_buf(mtd, oob, chip->ecc.postpad); + ret = nand_read_data_op(chip, oob, chip->ecc.postpad, + false); + if (ret) + return ret; + oob += chip->ecc.postpad; } }
size = mtd->oobsize - (oob - chip->oob_poi); - if (size) - chip->read_buf(mtd, oob, size); + if (size) { + ret = nand_read_data_op(chip, oob, size, false); + if (ret) + return ret; + }
return 0; } @@ -1336,6 +1906,7 @@ static int nand_read_subpage(struct mtd_info *mtd, struct nand_chip *chip, int busw = (chip->options & NAND_BUSWIDTH_16) ? 2 : 1; int index; unsigned int max_bitflips = 0; + int ret;
/* Column address within the page aligned to ECC size (256bytes) */ start_step = data_offs / chip->ecc.size; @@ -1353,7 +1924,9 @@ static int nand_read_subpage(struct mtd_info *mtd, struct nand_chip *chip, chip->cmdfunc(mtd, NAND_CMD_RNDOUT, data_col_addr, -1);
p = bufpoi + data_col_addr; - chip->read_buf(mtd, p, datafrag_len); + ret = nand_read_data_op(chip, p, datafrag_len, false); + if (ret) + return ret;
/* Calculate ECC */ for (i = 0; i < eccfrag_len ; i += chip->ecc.bytes, p += chip->ecc.size) @@ -1370,8 +1943,11 @@ static int nand_read_subpage(struct mtd_info *mtd, struct nand_chip *chip, } } if (gaps) { - chip->cmdfunc(mtd, NAND_CMD_RNDOUT, mtd->writesize, -1); - chip->read_buf(mtd, chip->oob_poi, mtd->oobsize); + ret = nand_change_read_column_op(chip, mtd->writesize, + chip->oob_poi, mtd->oobsize, + false); + if (ret) + return ret; } else { /* * Send the command to read the particular ECC bytes take care @@ -1384,9 +1960,12 @@ static int nand_read_subpage(struct mtd_info *mtd, struct nand_chip *chip, if (eccpos[index + (num_steps * chip->ecc.bytes)] & (busw - 1)) aligned_len++;
- chip->cmdfunc(mtd, NAND_CMD_RNDOUT, - mtd->writesize + aligned_pos, -1); - chip->read_buf(mtd, &chip->oob_poi[aligned_pos], aligned_len); + ret = nand_change_read_column_op(chip, + mtd->writesize + aligned_pos, + &chip->oob_poi[aligned_pos], + aligned_len, false); + if (ret) + return ret; }
for (i = 0; i < eccfrag_len; i++) @@ -1439,13 +2018,21 @@ static int nand_read_page_hwecc(struct mtd_info *mtd, struct nand_chip *chip, uint8_t *ecc_code = chip->buffers->ecccode; uint32_t *eccpos = chip->ecc.layout->eccpos; unsigned int max_bitflips = 0; + int ret;
for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize) { chip->ecc.hwctl(mtd, NAND_ECC_READ); - chip->read_buf(mtd, p, eccsize); + + ret = nand_read_data_op(chip, p, eccsize, false); + if (ret) + return ret; + chip->ecc.calculate(mtd, p, &ecc_calc[i]); } - chip->read_buf(mtd, chip->oob_poi, mtd->oobsize); + + ret = nand_read_data_op(chip, chip->oob_poi, mtd->oobsize, false); + if (ret) + return ret;
for (i = 0; i < chip->ecc.total; i++) ecc_code[i] = chip->oob_poi[eccpos[i]]; @@ -1501,11 +2088,16 @@ static int nand_read_page_hwecc_oob_first(struct mtd_info *mtd, uint32_t *eccpos = chip->ecc.layout->eccpos; uint8_t *ecc_calc = chip->buffers->ecccalc; unsigned int max_bitflips = 0; + int ret;
/* Read the OOB area first */ - chip->cmdfunc(mtd, NAND_CMD_READOOB, 0, page); - chip->read_buf(mtd, chip->oob_poi, mtd->oobsize); - chip->cmdfunc(mtd, NAND_CMD_READ0, 0, page); + ret = nand_read_oob_op(chip, page, 0, chip->oob_poi, mtd->oobsize); + if (ret) + return ret; + + ret = nand_read_page_op(chip, page, 0, NULL, 0); + if (ret) + return ret;
for (i = 0; i < chip->ecc.total; i++) ecc_code[i] = chip->oob_poi[eccpos[i]]; @@ -1514,7 +2106,11 @@ static int nand_read_page_hwecc_oob_first(struct mtd_info *mtd, int stat;
stat = chip->ecc.correct(mtd, p, &ecc_code[i], NULL); @@ -1551,7 +2147,7 @@ static int nand_read_page_hwecc_oob_first(struct mtd_info *mtd, static int nand_read_page_syndrome(struct mtd_info *mtd, struct nand_chip *chip, uint8_t *buf, int oob_required, int page) { - int i, eccsize = chip->ecc.size; + int ret, i, eccsize = chip->ecc.size; int eccbytes = chip->ecc.bytes; int eccsteps = chip->ecc.steps; int eccpadbytes = eccbytes + chip->ecc.prepad + chip->ecc.postpad; @@ -1563,21 +2159,36 @@ static int nand_read_page_syndrome(struct mtd_info *mtd, struct nand_chip *chip, int stat;
chip->ecc.hwctl(mtd, NAND_ECC_READSYN); - chip->read_buf(mtd, oob, eccbytes); + + ret = nand_read_data_op(chip, oob, eccbytes, false); + if (ret) + return ret; + stat = chip->ecc.correct(mtd, p, oob, NULL);
oob += eccbytes;
@@ -1601,8 +2212,11 @@ static int nand_read_page_syndrome(struct mtd_info *mtd, struct nand_chip *chip,
/* Calculate remaining oob bytes */ i = mtd->oobsize - (oob - chip->oob_poi); - if (i) - chip->read_buf(mtd, oob, i); + if (i) { + ret = nand_read_data_op(chip, oob, i, false); + if (ret) + return ret; + }
return max_bitflips; } @@ -1739,8 +2353,11 @@ static int nand_do_read_ops(struct mtd_info *mtd, loff_t from, __func__, buf);
read_retry: - if (nand_standard_page_accessors(&chip->ecc)) - chip->cmdfunc(mtd, NAND_CMD_READ0, 0x00, page); + if (nand_standard_page_accessors(&chip->ecc)) { + ret = nand_read_page_op(chip, page, 0, NULL, 0); + if (ret) + break; + }
/* * Now read the page into the buffer. Absent an error, @@ -1874,9 +2491,7 @@ read_retry: static int nand_read_oob_std(struct mtd_info *mtd, struct nand_chip *chip, int page) { - chip->cmdfunc(mtd, NAND_CMD_READOOB, 0, page); - chip->read_buf(mtd, chip->oob_poi, mtd->oobsize); - return 0; + return nand_read_oob_op(chip, page, 0, chip->oob_poi, mtd->oobsize); }
/** @@ -1893,25 +2508,43 @@ static int nand_read_oob_syndrome(struct mtd_info *mtd, struct nand_chip *chip, int chunk = chip->ecc.bytes + chip->ecc.prepad + chip->ecc.postpad; int eccsize = chip->ecc.size; uint8_t *bufpoi = chip->oob_poi; - int i, toread, sndrnd = 0, pos; + int i, toread, sndrnd = 0, pos, ret; + + ret = nand_read_page_op(chip, page, chip->ecc.size, NULL, 0); + if (ret) + return ret;
- chip->cmdfunc(mtd, NAND_CMD_READ0, chip->ecc.size, page); for (i = 0; i < chip->ecc.steps; i++) { if (sndrnd) { + int ret; + pos = eccsize + i * (eccsize + chunk); if (mtd->writesize > 512) - chip->cmdfunc(mtd, NAND_CMD_RNDOUT, pos, -1); + ret = nand_change_read_column_op(chip, pos, + NULL, 0, + false); else - chip->cmdfunc(mtd, NAND_CMD_READ0, pos, page); + ret = nand_read_page_op(chip, page, pos, NULL, + 0); + + if (ret) + return ret; } else sndrnd = 1; toread = min_t(int, length, chunk); - chip->read_buf(mtd, bufpoi, toread); + + ret = nand_read_data_op(chip, bufpoi, toread, false); + if (ret) + return ret; + bufpoi += toread; length -= toread; } - if (length > 0) - chip->read_buf(mtd, bufpoi, length); + if (length > 0) { + ret = nand_read_data_op(chip, bufpoi, length, false); + if (ret) + return ret; + }
return 0; } @@ -1925,18 +2558,8 @@ static int nand_read_oob_syndrome(struct mtd_info *mtd, struct nand_chip *chip, static int nand_write_oob_std(struct mtd_info *mtd, struct nand_chip *chip, int page) { - int status = 0; - const uint8_t *buf = chip->oob_poi; - int length = mtd->oobsize; - - chip->cmdfunc(mtd, NAND_CMD_SEQIN, mtd->writesize, page); - chip->write_buf(mtd, buf, length); - /* Send command to program the OOB data */ - chip->cmdfunc(mtd, NAND_CMD_PAGEPROG, -1, -1); - - status = chip->waitfunc(mtd, chip); - - return status & NAND_STATUS_FAIL ? -EIO : 0; + return nand_prog_page_op(chip, page, mtd->writesize, chip->oob_poi, + mtd->oobsize); }
/** @@ -1951,7 +2574,7 @@ static int nand_write_oob_syndrome(struct mtd_info *mtd, { int chunk = chip->ecc.bytes + chip->ecc.prepad + chip->ecc.postpad; int eccsize = chip->ecc.size, length = mtd->oobsize; - int i, len, pos, status = 0, sndcmd = 0, steps = chip->ecc.steps; + int ret, i, len, pos, sndcmd = 0, steps = chip->ecc.steps; const uint8_t *bufpoi = chip->oob_poi;
/* @@ -1965,7 +2588,10 @@ static int nand_write_oob_syndrome(struct mtd_info *mtd, } else pos = eccsize;
- chip->cmdfunc(mtd, NAND_CMD_SEQIN, pos, page); + ret = nand_prog_page_begin_op(chip, page, pos, NULL, 0); + if (ret) + return ret; + for (i = 0; i < steps; i++) { if (sndcmd) { if (mtd->writesize <= 512) { @@ -1974,28 +2600,40 @@ static int nand_write_oob_syndrome(struct mtd_info *mtd, len = eccsize; while (len > 0) { int num = min_t(int, len, 4); - chip->write_buf(mtd, (uint8_t *)&fill, - num); + + ret = nand_write_data_op(chip, &fill, + num, false); + if (ret) + return ret; + len -= num; } } else { pos = eccsize + i * (eccsize + chunk); - chip->cmdfunc(mtd, NAND_CMD_RNDIN, pos, -1); + ret = nand_change_write_column_op(chip, pos, + NULL, 0, + false); + if (ret) + return ret; } } else sndcmd = 1; len = min_t(int, length, chunk); - chip->write_buf(mtd, bufpoi, len); + + ret = nand_write_data_op(chip, bufpoi, len, false); + if (ret) + return ret; + bufpoi += len; length -= len; } - if (length > 0) - chip->write_buf(mtd, bufpoi, length); - - chip->cmdfunc(mtd, NAND_CMD_PAGEPROG, -1, -1); - status = chip->waitfunc(mtd, chip); + if (length > 0) { + ret = nand_write_data_op(chip, bufpoi, length, false); + if (ret) + return ret; + }
- return status & NAND_STATUS_FAIL ? -EIO : 0; + return nand_prog_page_end_op(chip); }
/** @@ -2154,9 +2792,18 @@ out: static int nand_write_page_raw(struct mtd_info *mtd, struct nand_chip *chip, const uint8_t *buf, int oob_required, int page) { - chip->write_buf(mtd, buf, mtd->writesize); - if (oob_required) - chip->write_buf(mtd, chip->oob_poi, mtd->oobsize); + int ret; + + ret = nand_write_data_op(chip, buf, mtd->writesize, false); + if (ret) + return ret; + + if (oob_required) { + ret = nand_write_data_op(chip, chip->oob_poi, mtd->oobsize, + false); + if (ret) + return ret; + }
return 0; } @@ -2179,29 +2826,46 @@ static int nand_write_page_raw_syndrome(struct mtd_info *mtd, int eccsize = chip->ecc.size; int eccbytes = chip->ecc.bytes; uint8_t *oob = chip->oob_poi; - int steps, size; + int steps, size, ret;
for (steps = chip->ecc.steps; steps > 0; steps--) { - chip->write_buf(mtd, buf, eccsize); + ret = nand_write_data_op(chip, buf, eccsize, false); + if (ret) + return ret; + buf += eccsize;
if (chip->ecc.prepad) { - chip->write_buf(mtd, oob, chip->ecc.prepad); + ret = nand_write_data_op(chip, oob, chip->ecc.prepad, + false); + if (ret) + return ret; + oob += chip->ecc.prepad; }
- chip->write_buf(mtd, oob, eccbytes); + ret = nand_write_data_op(chip, oob, eccbytes, false); + if (ret) + return ret; + oob += eccbytes;
if (chip->ecc.postpad) { - chip->write_buf(mtd, oob, chip->ecc.postpad); + ret = nand_write_data_op(chip, oob, chip->ecc.postpad, + false); + if (ret) + return ret; + oob += chip->ecc.postpad; } }
size = mtd->oobsize - (oob - chip->oob_poi); - if (size) - chip->write_buf(mtd, oob, size); + if (size) { + ret = nand_write_data_op(chip, oob, size, false); + if (ret) + return ret; + }
return 0; } @@ -2252,17 +2916,24 @@ static int nand_write_page_hwecc(struct mtd_info *mtd, struct nand_chip *chip, uint8_t *ecc_calc = chip->buffers->ecccalc; const uint8_t *p = buf; uint32_t *eccpos = chip->ecc.layout->eccpos; + int ret;
for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize) { chip->ecc.hwctl(mtd, NAND_ECC_WRITE); - chip->write_buf(mtd, p, eccsize); + + ret = nand_write_data_op(chip, p, eccsize, false); + if (ret) + return ret; + chip->ecc.calculate(mtd, p, &ecc_calc[i]); }
for (i = 0; i < chip->ecc.total; i++) chip->oob_poi[eccpos[i]] = ecc_calc[i];
- chip->write_buf(mtd, chip->oob_poi, mtd->oobsize); + ret = nand_write_data_op(chip, chip->oob_poi, mtd->oobsize, false); + if (ret) + return ret;
return 0; } @@ -2293,13 +2964,16 @@ static int nand_write_subpage_hwecc(struct mtd_info *mtd, uint32_t end_step = (offset + data_len - 1) / ecc_size; int oob_bytes = mtd->oobsize / ecc_steps; int step, i; + int ret;
for (step = 0; step < ecc_steps; step++) { /* configure controller for WRITE access */ chip->ecc.hwctl(mtd, NAND_ECC_WRITE);
/* write data (untouched subpages already masked by 0xFF) */ - chip->write_buf(mtd, buf, ecc_size); + ret = nand_write_data_op(chip, buf, ecc_size, false); + if (ret) + return ret;
/* mask ECC of un-touched subpages by padding 0xFF */ if ((step < start_step) || (step > end_step)) @@ -2324,7 +2998,9 @@ static int nand_write_subpage_hwecc(struct mtd_info *mtd, chip->oob_poi[eccpos[i]] = ecc_calc[i];
/* write OOB buffer to NAND device */ - chip->write_buf(mtd, chip->oob_poi, mtd->oobsize); + ret = nand_write_data_op(chip, chip->oob_poi, mtd->oobsize, false); + if (ret) + return ret;
return 0; } @@ -2351,31 +3027,49 @@ static int nand_write_page_syndrome(struct mtd_info *mtd, int eccsteps = chip->ecc.steps; const uint8_t *p = buf; uint8_t *oob = chip->oob_poi; + int ret;
for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize) { - chip->ecc.hwctl(mtd, NAND_ECC_WRITE); - chip->write_buf(mtd, p, eccsize); + + ret = nand_write_data_op(chip, p, eccsize, false); + if (ret) + return ret;
chip->ecc.calculate(mtd, p, oob); - chip->write_buf(mtd, oob, eccbytes); + + ret = nand_write_data_op(chip, oob, eccbytes, false); + if (ret) + return ret; + oob += eccbytes;
/* Calculate remaining oob bytes */ i = mtd->oobsize - (oob - chip->oob_poi); - if (i) - chip->write_buf(mtd, oob, i); + if (i) { + ret = nand_write_data_op(chip, oob, i, false); + if (ret) + return ret; + }
return 0; } @@ -2403,8 +3097,11 @@ static int nand_write_page(struct mtd_info *mtd, struct nand_chip *chip, else subpage = 0;
- if (nand_standard_page_accessors(&chip->ecc)) - chip->cmdfunc(mtd, NAND_CMD_SEQIN, 0x00, page); + if (nand_standard_page_accessors(&chip->ecc)) { + status = nand_prog_page_begin_op(chip, page, 0, NULL, 0); + if (status) + return status; + }
if (unlikely(raw)) status = chip->ecc.write_page_raw(mtd, chip, buf, @@ -2419,13 +3116,8 @@ static int nand_write_page(struct mtd_info *mtd, struct nand_chip *chip, if (status < 0) return status;
- if (nand_standard_page_accessors(&chip->ecc)) { - chip->cmdfunc(mtd, NAND_CMD_PAGEPROG, -1, -1); - - status = chip->waitfunc(mtd, chip); - if (status & NAND_STATUS_FAIL) - return -EIO; - } + if (nand_standard_page_accessors(&chip->ecc)) + return nand_prog_page_end_op(chip);
return 0; } @@ -2785,11 +3477,12 @@ out: static int single_erase(struct mtd_info *mtd, int page) { struct nand_chip *chip = mtd_to_nand(mtd); + unsigned int eraseblock; + /* Send commands to erase a block */ - chip->cmdfunc(mtd, NAND_CMD_ERASE1, -1, page); - chip->cmdfunc(mtd, NAND_CMD_ERASE2, -1, -1); + eraseblock = page >> (chip->phys_erase_shift - chip->page_shift);
- return chip->waitfunc(mtd, chip); + return nand_erase_op(chip, eraseblock); }
/** @@ -2982,9 +3675,6 @@ static int nand_block_markbad(struct mtd_info *mtd, loff_t ofs) static int nand_onfi_set_features(struct mtd_info *mtd, struct nand_chip *chip, int addr, uint8_t *subfeature_param) { - int status; - int i; - #ifdef CONFIG_SYS_NAND_ONFI_DETECTION if (!chip->onfi_version || !(le16_to_cpu(chip->onfi_params.opt_cmd) @@ -2992,14 +3682,7 @@ static int nand_onfi_set_features(struct mtd_info *mtd, struct nand_chip *chip, return -ENOTSUPP; #endif
- chip->cmdfunc(mtd, NAND_CMD_SET_FEATURES, addr, -1); - for (i = 0; i < ONFI_SUBFEATURE_PARAM_LEN; ++i) - chip->write_byte(mtd, subfeature_param[i]); - - status = chip->waitfunc(mtd, chip); - if (status & NAND_STATUS_FAIL) - return -EIO; - return 0; + return nand_set_features_op(chip, addr, subfeature_param); }
/** @@ -3012,8 +3695,6 @@ static int nand_onfi_set_features(struct mtd_info *mtd, struct nand_chip *chip, static int nand_onfi_get_features(struct mtd_info *mtd, struct nand_chip *chip, int addr, uint8_t *subfeature_param) { - int i; - #ifdef CONFIG_SYS_NAND_ONFI_DETECTION if (!chip->onfi_version || !(le16_to_cpu(chip->onfi_params.opt_cmd) @@ -3021,10 +3702,7 @@ static int nand_onfi_get_features(struct mtd_info *mtd, struct nand_chip *chip, return -ENOTSUPP; #endif
- chip->cmdfunc(mtd, NAND_CMD_GET_FEATURES, addr, -1); - for (i = 0; i < ONFI_SUBFEATURE_PARAM_LEN; ++i) - *subfeature_param++ = chip->read_byte(mtd); - return 0; + return nand_get_features_op(chip, addr, subfeature_param); }
/* Set default functions */ @@ -3118,7 +3796,7 @@ static int nand_flash_detect_ext_param_page(struct mtd_info *mtd, struct onfi_ext_section *s; struct onfi_ext_ecc_info *ecc; uint8_t *cursor; - int ret = -EINVAL; + int ret; int len; int i;
@@ -3128,14 +3806,18 @@ static int nand_flash_detect_ext_param_page(struct mtd_info *mtd, return -ENOMEM;
/* Send our own NAND_CMD_PARAM. */ - chip->cmdfunc(mtd, NAND_CMD_PARAM, 0, -1); + ret = nand_read_param_page_op(chip, 0, NULL, 0); + if (ret) + goto ext_out;
/* Use the Change Read Column command to skip the ONFI param pages. */ - chip->cmdfunc(mtd, NAND_CMD_RNDOUT, - sizeof(*p) * p->num_of_param_pages , -1); + ret = nand_change_read_column_op(chip, + sizeof(*p) * p->num_of_param_pages, + ep, len, true); + if (ret) + goto ext_out;
- /* Read out the Extended Parameter Page. */ - chip->read_buf(mtd, (uint8_t *)ep, len); + ret = -EINVAL; if ((onfi_crc16(ONFI_CRC_BASE, ((uint8_t *)ep) + 2, len - 2) != le16_to_cpu(ep->crc))) { pr_debug("fail in the CRC.\n"); @@ -3212,19 +3894,23 @@ static int nand_flash_detect_onfi(struct mtd_info *mtd, struct nand_chip *chip, int *busw) { struct nand_onfi_params *p = &chip->onfi_params; - int i, j; - int val; + char id[4]; + int i, ret, val;
/* Try ONFI for unknown chip or LP */ - chip->cmdfunc(mtd, NAND_CMD_READID, 0x20, -1); - if (chip->read_byte(mtd) != 'O' || chip->read_byte(mtd) != 'N' || - chip->read_byte(mtd) != 'F' || chip->read_byte(mtd) != 'I') + ret = nand_readid_op(chip, 0x20, id, sizeof(id)); + if (ret || strncmp(id, "ONFI", 4)) + return 0; + + ret = nand_read_param_page_op(chip, 0, NULL, 0); + if (ret) return 0;
- chip->cmdfunc(mtd, NAND_CMD_PARAM, 0, -1); for (i = 0; i < 3; i++) { - for (j = 0; j < sizeof(*p); j++) - ((uint8_t *)p)[j] = chip->read_byte(mtd); + ret = nand_read_data_op(chip, p, sizeof(*p), true); + if (ret) + return 0; + if (onfi_crc16(ONFI_CRC_BASE, (uint8_t *)p, 254) == le16_to_cpu(p->crc)) { break; @@ -3324,20 +4010,22 @@ static int nand_flash_detect_jedec(struct mtd_info *mtd, struct nand_chip *chip, { struct nand_jedec_params *p = &chip->jedec_params; struct jedec_ecc_info *ecc; - int val; - int i, j; + char id[5]; + int i, val, ret;
/* Try JEDEC for unknown chip or LP */ - chip->cmdfunc(mtd, NAND_CMD_READID, 0x40, -1); - if (chip->read_byte(mtd) != 'J' || chip->read_byte(mtd) != 'E' || - chip->read_byte(mtd) != 'D' || chip->read_byte(mtd) != 'E' || - chip->read_byte(mtd) != 'C') + ret = nand_readid_op(chip, 0x40, id, sizeof(id)); + if (ret || strncmp(id, "JEDEC", sizeof(id))) + return 0; + + ret = nand_read_param_page_op(chip, 0x40, NULL, 0); + if (ret) return 0;
- chip->cmdfunc(mtd, NAND_CMD_PARAM, 0x40, -1); for (i = 0; i < 3; i++) { - for (j = 0; j < sizeof(*p); j++) - ((uint8_t *)p)[j] = chip->read_byte(mtd); + ret = nand_read_data_op(chip, p, sizeof(*p), true); + if (ret) + return 0;
if (onfi_crc16(ONFI_CRC_BASE, (uint8_t *)p, 510) == le16_to_cpu(p->crc)) @@ -3708,25 +4396,29 @@ struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, int *maf_id, int *dev_id, struct nand_flash_dev *type) { - int busw; - int i, maf_idx; + int busw, ret; + int maf_idx; u8 id_data[8];
/* * Reset the chip, required by some chips (e.g. Micron MT29FxGxxxxx) * after power-up. */ - nand_reset(chip, 0); + ret = nand_reset(chip, 0); + if (ret) + return ERR_PTR(ret);
/* Select the device */ chip->select_chip(mtd, 0);
/* Send the command for reading device ID */ - chip->cmdfunc(mtd, NAND_CMD_READID, 0x00, -1); + ret = nand_readid_op(chip, 0, id_data, 2); + if (ret) + return ERR_PTR(ret);
/* Read manufacturer and device IDs */ - *maf_id = chip->read_byte(mtd); - *dev_id = chip->read_byte(mtd); + *maf_id = id_data[0]; + *dev_id = id_data[1];
/* * Try again to make sure, as some systems the bus-hold or other @@ -3735,11 +4427,10 @@ struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, * not match, ignore the device completely. */
- chip->cmdfunc(mtd, NAND_CMD_READID, 0x00, -1); - /* Read entire ID string */ - for (i = 0; i < 8; i++) - id_data[i] = chip->read_byte(mtd); + ret = nand_readid_op(chip, 0, id_data, 8); + if (ret) + return ERR_PTR(ret);
if (id_data[0] != *maf_id || id_data[1] != *dev_id) { pr_info("second ID read did not match %02x,%02x against %02x,%02x\n", @@ -3999,15 +4690,17 @@ int nand_scan_ident(struct mtd_info *mtd, int maxchips,
/* Check for a chip array */ for (i = 1; i < maxchips; i++) { + u8 id[2]; + /* See comment in nand_get_flash_type for reset */ nand_reset(chip, i);
chip->select_chip(mtd, i); /* Send the command for reading device ID */ - chip->cmdfunc(mtd, NAND_CMD_READID, 0x00, -1); + nand_readid_op(chip, 0, id, sizeof(id)); + /* Read manufacturer and device IDs */ - if (nand_maf_id != chip->read_byte(mtd) || - nand_dev_id != chip->read_byte(mtd)) { + if (nand_maf_id != id[0] || nand_dev_id != id[1]) { chip->select_chip(mtd, -1); break; } diff --git a/include/linux/mtd/rawnand.h b/include/linux/mtd/rawnand.h index 96b5847..bd373b9 100644 --- a/include/linux/mtd/rawnand.h +++ b/include/linux/mtd/rawnand.h @@ -1299,4 +1299,34 @@ int nand_maximize_ecc(struct nand_chip *chip,
/* Reset and initialize a NAND device */ int nand_reset(struct nand_chip *chip, int chipnr); + +/* NAND operation helpers */ +int nand_reset_op(struct nand_chip *chip); +int nand_readid_op(struct nand_chip *chip, u8 addr, void *buf, + unsigned int len); +int nand_status_op(struct nand_chip *chip, u8 *status); +int nand_exit_status_op(struct nand_chip *chip); +int nand_erase_op(struct nand_chip *chip, unsigned int eraseblock); +int nand_read_page_op(struct nand_chip *chip, unsigned int page, + unsigned int offset_in_page, void *buf, unsigned int len); +int nand_change_read_column_op(struct nand_chip *chip, + unsigned int offset_in_page, void *buf, + unsigned int len, bool force_8bit); +int nand_read_oob_op(struct nand_chip *chip, unsigned int page, + unsigned int offset_in_page, void *buf, unsigned int len); +int nand_prog_page_begin_op(struct nand_chip *chip, unsigned int page, + unsigned int offset_in_page, const void *buf, + unsigned int len); +int nand_prog_page_end_op(struct nand_chip *chip); +int nand_prog_page_op(struct nand_chip *chip, unsigned int page, + unsigned int offset_in_page, const void *buf, + unsigned int len); +int nand_change_write_column_op(struct nand_chip *chip, + unsigned int offset_in_page, const void *buf, + unsigned int len, bool force_8bit); +int nand_read_data_op(struct nand_chip *chip, void *buf, unsigned int len, + bool force_8bit); +int nand_write_data_op(struct nand_chip *chip, const void *buf, + unsigned int len, bool force_8bit); + #endif /* __LINUX_MTD_RAWNAND_H */
This patch port the function readX_relaxed and writeX_relaxed from kernel 4.18.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- arch/arm/include/asm/io.h | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/arch/arm/include/asm/io.h b/arch/arm/include/asm/io.h index 12bc7fb..e6d27b6 100644 --- a/arch/arm/include/asm/io.h +++ b/arch/arm/include/asm/io.h @@ -123,6 +123,27 @@ static inline void __raw_readsl(unsigned long addr, void *data, int longlen) #define readq(c) ({ u64 __v = __arch_getq(c); __iormb(); __v; })
/* + * Relaxed I/O memory access primitives. These follow the Device memory + * ordering rules but do not guarantee any ordering relative to Normal memory + * accesses. + */ +#define readb_relaxed(c) ({ u8 __r = __raw_readb(c); __r; }) +#define readw_relaxed(c) ({ u16 __r = le16_to_cpu((__force __le16) \ + __raw_readw(c)); __r; }) +#define readl_relaxed(c) ({ u32 __r = le32_to_cpu((__force __le32) \ + __raw_readl(c)); __r; }) +#define readq_relaxed(c) ({ u64 __r = le64_to_cpu((__force __le64) \ + __raw_readq(c)); __r; }) + +#define writeb_relaxed(v, c) ((void)__raw_writeb((v), (c))) +#define writew_relaxed(v, c) ((void)__raw_writew((__force u16) \ + cpu_to_le16(v), (c))) +#define writel_relaxed(v, c) ((void)__raw_writel((__force u32) \ + cpu_to_le32(v), (c))) +#define writeq_relaxed(v, c) ((void)__raw_writeq((__force u64) \ + cpu_to_le64(v), (c))) + +/* * The compiler seems to be incapable of optimising constants * properly. Spell it out to the compiler in some cases. * These are only valid for small values of "off" (< 1<<12)
The macro devm_ioremap is only defined for configuration that doesn't have ioremap. But this macro may also be defined on configuration with ioremap. This patch remove the condition for the macro devm_ioremap, so it's always defined.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- include/linux/io.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/linux/io.h b/include/linux/io.h index 9badab4..7984788 100644 --- a/include/linux/io.h +++ b/include/linux/io.h @@ -65,8 +65,8 @@ static inline void __iomem *ioremap(resource_size_t offset, static inline void iounmap(void __iomem *addr) { } +#endif
#define devm_ioremap(dev, offset, size) ioremap(offset, size) -#endif
#endif /* _LINUX_IO_H */
This patch port the file include/linux/completion.h from linux 4.18 to u-boot. It define the structure but all the function are stubbed.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- include/linux/completion.h | 173 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 173 insertions(+) create mode 100644 include/linux/completion.h
diff --git a/include/linux/completion.h b/include/linux/completion.h new file mode 100644 index 0000000..9835826 --- /dev/null +++ b/include/linux/completion.h @@ -0,0 +1,173 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __LINUX_COMPLETION_H +#define __LINUX_COMPLETION_H + +/* + * (C) Copyright 2001 Linus Torvalds + * + * Atomic wait-for-completion handler data structures. + * See kernel/sched/completion.c for details. + */ +#ifndef __UBOOT__ +#include <linux/wait.h> +#endif /* __UBOOT__ */ + +/* + * struct completion - structure used to maintain state for a "completion" + * + * This is the opaque structure used to maintain the state for a "completion". + * Completions currently use a FIFO to queue threads that have to wait for + * the "completion" event. + * + * See also: complete(), wait_for_completion() (and friends _timeout, + * _interruptible, _interruptible_timeout, and _killable), init_completion(), + * reinit_completion(), and macros DECLARE_COMPLETION(), + * DECLARE_COMPLETION_ONSTACK(). + */ +struct completion { + unsigned int done; +#ifndef __UBOOT__ + wait_queue_head_t wait; +#endif /* __UBOOT__ */ +}; + +#define init_completion_map(x, m) __init_completion(x) +#define init_completion(x) __init_completion(x) +static inline void complete_acquire(struct completion *x) {} +static inline void complete_release(struct completion *x) {} + +#define COMPLETION_INITIALIZER(work) \ + { 0, __WAIT_QUEUE_HEAD_INITIALIZER((work).wait) } + +#define COMPLETION_INITIALIZER_ONSTACK_MAP(work, map) \ + (*({ init_completion_map(&(work), &(map)); &(work); })) + +#define COMPLETION_INITIALIZER_ONSTACK(work) \ + (*({ init_completion(&work); &work; })) + +/** + * DECLARE_COMPLETION - declare and initialize a completion structure + * @work: identifier for the completion structure + * + * This macro declares and initializes a completion structure. Generally used + * for static declarations. You should use the _ONSTACK variant for automatic + * variables. + */ +#define DECLARE_COMPLETION(work) \ + struct completion work = COMPLETION_INITIALIZER(work) + +/* + * Lockdep needs to run a non-constant initializer for on-stack + * completions - so we use the _ONSTACK() variant for those that + * are on the kernel stack: + */ +/** + * DECLARE_COMPLETION_ONSTACK - declare and initialize a completion structure + * @work: identifier for the completion structure + * + * This macro declares and initializes a completion structure on the kernel + * stack. + */ +#ifdef CONFIG_LOCKDEP +# define DECLARE_COMPLETION_ONSTACK(work) \ + struct completion work = COMPLETION_INITIALIZER_ONSTACK(work) +# define DECLARE_COMPLETION_ONSTACK_MAP(work, map) \ + struct completion work = COMPLETION_INITIALIZER_ONSTACK_MAP(work, map) +#else +# define DECLARE_COMPLETION_ONSTACK(work) DECLARE_COMPLETION(work) +# define DECLARE_COMPLETION_ONSTACK_MAP(work, map) DECLARE_COMPLETION(work) +#endif + +/** + * init_completion - Initialize a dynamically allocated completion + * @x: pointer to completion structure that is to be initialized + * + * This inline function will initialize a dynamically created completion + * structure. + */ +static inline void __init_completion(struct completion *x) +{ + x->done = 0; +#ifndef __UBOOT__ + init_waitqueue_head(&x->wait); +#endif /* __UBOOT__ */ +} + +/** + * reinit_completion - reinitialize a completion structure + * @x: pointer to completion structure that is to be reinitialized + * + * This inline function should be used to reinitialize a completion structure so it can + * be reused. This is especially important after complete_all() is used. + */ +static inline void reinit_completion(struct completion *x) +{ + x->done = 0; +} + +#ifndef __UBOOT__ +extern void wait_for_completion(struct completion *); +extern void wait_for_completion_io(struct completion *); +extern int wait_for_completion_interruptible(struct completion *x); +extern int wait_for_completion_killable(struct completion *x); +extern unsigned long wait_for_completion_timeout(struct completion *x, + unsigned long timeout); +extern unsigned long wait_for_completion_io_timeout(struct completion *x, + unsigned long timeout); +extern long wait_for_completion_interruptible_timeout( + struct completion *x, unsigned long timeout); +extern long wait_for_completion_killable_timeout( + struct completion *x, unsigned long timeout); +extern bool try_wait_for_completion(struct completion *x); +extern bool completion_done(struct completion *x); + +extern void complete(struct completion *); +extern void complete_all(struct completion *); + +#else /* __UBOOT __ */ + +#define wait_for_completion(x) do {} while (0) +#define wait_for_completion_io(x) do {} while (0) + +inline int wait_for_completion_interruptible(struct completion *x) +{ + return 1; +} +inline int wait_for_completion_killable(struct completion *x) +{ + return 1; +} +inline unsigned long wait_for_completion_timeout(struct completion *x, + unsigned long timeout) +{ + return 1; +} +inline unsigned long wait_for_completion_io_timeout(struct completion *x, + unsigned long timeout) +{ + return 1; +} +inline long wait_for_completion_interruptible_timeout(struct completion *x, + unsigned long timeout) +{ + return 1; +} +inline long wait_for_completion_killable_timeout(struct completion *x, + unsigned long timeout) +{ + return 1; +} +inline bool try_wait_for_completion(struct completion *x) +{ + return 1; +} +inline bool completion_done(struct completion *x) +{ + return 1; +} + +#define complete(x) do {} while (0) +#define complete_all(x) do {} while (0) +#endif /* __UBOOT__ */ + +#endif
The driver brcmnand come from linux kernel 4.18. Only SoC bcm6838 and bcm6858 are supported.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- drivers/mtd/nand/raw/Kconfig | 25 + drivers/mtd/nand/raw/Makefile | 1 + drivers/mtd/nand/raw/brcmnand/Makefile | 7 + drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c | 123 + drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c | 122 + drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c | 123 + drivers/mtd/nand/raw/brcmnand/brcmnand.c | 2789 +++++++++++++++++++++++ drivers/mtd/nand/raw/brcmnand/brcmnand.h | 63 + drivers/mtd/nand/raw/brcmnand/brcmnand_compat.c | 66 + drivers/mtd/nand/raw/brcmnand/brcmnand_compat.h | 15 + 10 files changed, 3334 insertions(+) create mode 100644 drivers/mtd/nand/raw/brcmnand/Makefile create mode 100644 drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c create mode 100644 drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c create mode 100644 drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c create mode 100644 drivers/mtd/nand/raw/brcmnand/brcmnand.c create mode 100644 drivers/mtd/nand/raw/brcmnand/brcmnand.h create mode 100644 drivers/mtd/nand/raw/brcmnand/brcmnand_compat.c create mode 100644 drivers/mtd/nand/raw/brcmnand/brcmnand_compat.h
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 7f76e5e..92fadeb 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -60,6 +60,31 @@ config SPL_GENERATE_ATMEL_PMECC_HEADER
endif
+config NAND_BRCMNAND + bool "Support Broadcom NAND controller" + depends on OF_CONTROL && DM && MTD + help + Enable the driver for NAND flash on platforms using a Broadcom NAND + controller. + +config NAND_BRCMNAND_6838 + bool "Support Broadcom NAND controller on bcm6838" + depends on NAND_BRCMNAND && ARCH_BMIPS && SOC_BMIPS_BCM6838 + help + Enable support for broadcom nand driver on bcm6838. + +config NAND_BRCMNAND_6858 + bool "Support Broadcom NAND controller on bcm6858" + depends on NAND_BRCMNAND && ARCH_BCM6858 + help + Enable support for broadcom nand driver on bcm6858. + +config NAND_BRCMNAND_63158 + bool "Support Broadcom NAND controller on bcm63158" + depends on NAND_BRCMNAND && ARCH_BCM63158 + help + Enable support for broadcom nand driver on bcm63158. + config NAND_DAVINCI bool "Support TI Davinci NAND controller" help diff --git a/drivers/mtd/nand/raw/Makefile b/drivers/mtd/nand/raw/Makefile index c61e3f3..7e50206 100644 --- a/drivers/mtd/nand/raw/Makefile +++ b/drivers/mtd/nand/raw/Makefile @@ -41,6 +41,7 @@ obj-$(CONFIG_NAND_ECC_BCH) += nand_bch.o
obj-$(CONFIG_NAND_ATMEL) += atmel_nand.o obj-$(CONFIG_NAND_ARASAN) += arasan_nfc.o +obj-$(CONFIG_NAND_BRCMNAND) += brcmnand/ obj-$(CONFIG_NAND_DAVINCI) += davinci_nand.o obj-$(CONFIG_NAND_DENALI) += denali.o obj-$(CONFIG_NAND_DENALI_DT) += denali_dt.o diff --git a/drivers/mtd/nand/raw/brcmnand/Makefile b/drivers/mtd/nand/raw/brcmnand/Makefile new file mode 100644 index 0000000..a2363cc --- /dev/null +++ b/drivers/mtd/nand/raw/brcmnand/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-$(CONFIG_NAND_BRCMNAND_63158) += bcm63158_nand.o +obj-$(CONFIG_NAND_BRCMNAND_6838) += bcm6838_nand.o +obj-$(CONFIG_NAND_BRCMNAND_6858) += bcm6858_nand.o +obj-$(CONFIG_NAND_BRCMNAND) += brcmnand.o +obj-$(CONFIG_NAND_BRCMNAND) += brcmnand_compat.o diff --git a/drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c new file mode 100644 index 0000000..16b0d44 --- /dev/null +++ b/drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c @@ -0,0 +1,123 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <asm/io.h> +#include <memalign.h> +#include <nand.h> +#include <linux/errno.h> +#include <linux/io.h> +#include <linux/ioport.h> +#include <dm.h> + +#include "brcmnand.h" + +struct bcm63158_nand_soc { + struct brcmnand_soc soc; + void __iomem *base; +}; + +#define BCM63158_NAND_INT 0x00 +#define BCM63158_NAND_STATUS_SHIFT 0 +#define BCM63158_NAND_STATUS_MASK (0xfff << BCM63158_NAND_STATUS_SHIFT) + +#define BCM63158_NAND_INT_EN 0x04 +#define BCM63158_NAND_ENABLE_SHIFT 0 +#define BCM63158_NAND_ENABLE_MASK (0xffff << BCM63158_NAND_ENABLE_SHIFT) + +enum { + BCM63158_NP_READ = BIT(0), + BCM63158_BLOCK_ERASE = BIT(1), + BCM63158_COPY_BACK = BIT(2), + BCM63158_PAGE_PGM = BIT(3), + BCM63158_CTRL_READY = BIT(4), + BCM63158_DEV_RBPIN = BIT(5), + BCM63158_ECC_ERR_UNC = BIT(6), + BCM63158_ECC_ERR_CORR = BIT(7), +}; + +static bool bcm63158_nand_intc_ack(struct brcmnand_soc *soc) +{ + struct bcm63158_nand_soc *priv = + container_of(soc, struct bcm63158_nand_soc, soc); + void __iomem *mmio = priv->base + BCM63158_NAND_INT; + u32 val = brcmnand_readl(mmio); + + if (val & (BCM63158_CTRL_READY << BCM63158_NAND_STATUS_SHIFT)) { + /* Ack interrupt */ + val &= ~BCM63158_NAND_STATUS_MASK; + val |= BCM63158_CTRL_READY << BCM63158_NAND_STATUS_SHIFT; + brcmnand_writel(val, mmio); + return true; + } + + return false; +} + +static void bcm63158_nand_intc_set(struct brcmnand_soc *soc, bool en) +{ + struct bcm63158_nand_soc *priv = + container_of(soc, struct bcm63158_nand_soc, soc); + void __iomem *mmio = priv->base + BCM63158_NAND_INT_EN; + u32 val = brcmnand_readl(mmio); + + /* Don't ack any interrupts */ + val &= ~BCM63158_NAND_STATUS_MASK; + + if (en) + val |= BCM63158_CTRL_READY << BCM63158_NAND_ENABLE_SHIFT; + else + val &= ~(BCM63158_CTRL_READY << BCM63158_NAND_ENABLE_SHIFT); + + brcmnand_writel(val, mmio); +} + +static int bcm63158_nand_probe(struct udevice *dev) +{ + struct udevice *pdev = dev; + struct bcm63158_nand_soc *priv = dev_get_priv(dev); + struct brcmnand_soc *soc; + struct resource res; + + soc = &priv->soc; + + dev_read_resource_byname(pdev, "nand-int-base", &res); + priv->base = devm_ioremap(dev, res.start, resource_size(&res)); + if (IS_ERR(priv->base)) + return PTR_ERR(priv->base); + + soc->ctlrdy_ack = bcm63158_nand_intc_ack; + soc->ctlrdy_set_enabled = bcm63158_nand_intc_set; + + /* Disable and ack all interrupts */ + brcmnand_writel(0, priv->base + BCM63158_NAND_INT_EN); + brcmnand_writel(0, priv->base + BCM63158_NAND_INT); + + return brcmnand_probe(pdev, soc); +} + +static const struct udevice_id bcm63158_nand_dt_ids[] = { + { + .compatible = "brcm,nand-bcm63158", + }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(bcm63158_nand) = { + .name = "bcm63158-nand", + .id = UCLASS_MTD, + .of_match = bcm63158_nand_dt_ids, + .probe = bcm63158_nand_probe, + .priv_auto_alloc_size = sizeof(struct bcm63158_nand_soc), +}; + +void board_nand_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MTD, + DM_GET_DRIVER(bcm63158_nand), &dev); + if (ret && ret != -ENODEV) + pr_err("Failed to initialize %s. (error %d)\n", dev->name, + ret); +} diff --git a/drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c new file mode 100644 index 0000000..ece9444 --- /dev/null +++ b/drivers/mtd/nand/raw/brcmnand/bcm6838_nand.c @@ -0,0 +1,122 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <asm/io.h> +#include <memalign.h> +#include <nand.h> +#include <linux/errno.h> +#include <linux/io.h> +#include <linux/ioport.h> +#include <dm.h> + +#include "brcmnand.h" + +struct bcm6838_nand_soc { + struct brcmnand_soc soc; + void __iomem *base; +}; + +#define BCM6838_NAND_INT 0x00 +#define BCM6838_NAND_STATUS_SHIFT 0 +#define BCM6838_NAND_STATUS_MASK (0xfff << BCM6838_NAND_STATUS_SHIFT) +#define BCM6838_NAND_ENABLE_SHIFT 16 +#define BCM6838_NAND_ENABLE_MASK (0xffff << BCM6838_NAND_ENABLE_SHIFT) + +enum { + BCM6838_NP_READ = BIT(0), + BCM6838_BLOCK_ERASE = BIT(1), + BCM6838_COPY_BACK = BIT(2), + BCM6838_PAGE_PGM = BIT(3), + BCM6838_CTRL_READY = BIT(4), + BCM6838_DEV_RBPIN = BIT(5), + BCM6838_ECC_ERR_UNC = BIT(6), + BCM6838_ECC_ERR_CORR = BIT(7), +}; + +static bool bcm6838_nand_intc_ack(struct brcmnand_soc *soc) +{ + struct bcm6838_nand_soc *priv = + container_of(soc, struct bcm6838_nand_soc, soc); + void __iomem *mmio = priv->base + BCM6838_NAND_INT; + u32 val = brcmnand_readl(mmio); + + if (val & (BCM6838_CTRL_READY << BCM6838_NAND_STATUS_SHIFT)) { + /* Ack interrupt */ + val &= ~BCM6838_NAND_STATUS_MASK; + val |= BCM6838_CTRL_READY << BCM6838_NAND_STATUS_SHIFT; + brcmnand_writel(val, mmio); + return true; + } + + return false; +} + +static void bcm6838_nand_intc_set(struct brcmnand_soc *soc, bool en) +{ + struct bcm6838_nand_soc *priv = + container_of(soc, struct bcm6838_nand_soc, soc); + void __iomem *mmio = priv->base + BCM6838_NAND_INT; + u32 val = brcmnand_readl(mmio); + + /* Don't ack any interrupts */ + val &= ~BCM6838_NAND_STATUS_MASK; + + if (en) + val |= BCM6838_CTRL_READY << BCM6838_NAND_ENABLE_SHIFT; + else + val &= ~(BCM6838_CTRL_READY << BCM6838_NAND_ENABLE_SHIFT); + + brcmnand_writel(val, mmio); +} + +static int bcm6838_nand_probe(struct udevice *dev) +{ + struct udevice *pdev = dev; + struct bcm6838_nand_soc *priv = dev_get_priv(dev); + struct brcmnand_soc *soc; + struct resource res; + + soc = &priv->soc; + + dev_read_resource_byname(pdev, "nand-int-base", &res); + priv->base = ioremap(res.start, resource_size(&res)); + if (IS_ERR(priv->base)) + return PTR_ERR(priv->base); + + soc->ctlrdy_ack = bcm6838_nand_intc_ack; + soc->ctlrdy_set_enabled = bcm6838_nand_intc_set; + + /* Disable and ack all interrupts */ + brcmnand_writel(0, priv->base + BCM6838_NAND_INT); + brcmnand_writel(BCM6838_NAND_STATUS_MASK, + priv->base + BCM6838_NAND_INT); + + return brcmnand_probe(pdev, soc); +} + +static const struct udevice_id bcm6838_nand_dt_ids[] = { + { + .compatible = "brcm,nand-bcm6838", + }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(bcm6838_nand) = { + .name = "bcm6838-nand", + .id = UCLASS_MTD, + .of_match = bcm6838_nand_dt_ids, + .probe = bcm6838_nand_probe, + .priv_auto_alloc_size = sizeof(struct bcm6838_nand_soc), +}; + +void board_nand_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MTD, + DM_GET_DRIVER(bcm6838_nand), &dev); + if (ret && ret != -ENODEV) + pr_err("Failed to initialize %s. (error %d)\n", dev->name, + ret); +} diff --git a/drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c new file mode 100644 index 0000000..3586baa --- /dev/null +++ b/drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c @@ -0,0 +1,123 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <asm/io.h> +#include <memalign.h> +#include <nand.h> +#include <linux/errno.h> +#include <linux/io.h> +#include <linux/ioport.h> +#include <dm.h> + +#include "brcmnand.h" + +struct bcm6858_nand_soc { + struct brcmnand_soc soc; + void __iomem *base; +}; + +#define BCM6858_NAND_INT 0x00 +#define BCM6858_NAND_STATUS_SHIFT 0 +#define BCM6858_NAND_STATUS_MASK (0xfff << BCM6858_NAND_STATUS_SHIFT) + +#define BCM6858_NAND_INT_EN 0x04 +#define BCM6858_NAND_ENABLE_SHIFT 0 +#define BCM6858_NAND_ENABLE_MASK (0xffff << BCM6858_NAND_ENABLE_SHIFT) + +enum { + BCM6858_NP_READ = BIT(0), + BCM6858_BLOCK_ERASE = BIT(1), + BCM6858_COPY_BACK = BIT(2), + BCM6858_PAGE_PGM = BIT(3), + BCM6858_CTRL_READY = BIT(4), + BCM6858_DEV_RBPIN = BIT(5), + BCM6858_ECC_ERR_UNC = BIT(6), + BCM6858_ECC_ERR_CORR = BIT(7), +}; + +static bool bcm6858_nand_intc_ack(struct brcmnand_soc *soc) +{ + struct bcm6858_nand_soc *priv = + container_of(soc, struct bcm6858_nand_soc, soc); + void __iomem *mmio = priv->base + BCM6858_NAND_INT; + u32 val = brcmnand_readl(mmio); + + if (val & (BCM6858_CTRL_READY << BCM6858_NAND_STATUS_SHIFT)) { + /* Ack interrupt */ + val &= ~BCM6858_NAND_STATUS_MASK; + val |= BCM6858_CTRL_READY << BCM6858_NAND_STATUS_SHIFT; + brcmnand_writel(val, mmio); + return true; + } + + return false; +} + +static void bcm6858_nand_intc_set(struct brcmnand_soc *soc, bool en) +{ + struct bcm6858_nand_soc *priv = + container_of(soc, struct bcm6858_nand_soc, soc); + void __iomem *mmio = priv->base + BCM6858_NAND_INT_EN; + u32 val = brcmnand_readl(mmio); + + /* Don't ack any interrupts */ + val &= ~BCM6858_NAND_STATUS_MASK; + + if (en) + val |= BCM6858_CTRL_READY << BCM6858_NAND_ENABLE_SHIFT; + else + val &= ~(BCM6858_CTRL_READY << BCM6858_NAND_ENABLE_SHIFT); + + brcmnand_writel(val, mmio); +} + +static int bcm6858_nand_probe(struct udevice *dev) +{ + struct udevice *pdev = dev; + struct bcm6858_nand_soc *priv = dev_get_priv(dev); + struct brcmnand_soc *soc; + struct resource res; + + soc = &priv->soc; + + dev_read_resource_byname(pdev, "nand-int-base", &res); + priv->base = devm_ioremap(dev, res.start, resource_size(&res)); + if (IS_ERR(priv->base)) + return PTR_ERR(priv->base); + + soc->ctlrdy_ack = bcm6858_nand_intc_ack; + soc->ctlrdy_set_enabled = bcm6858_nand_intc_set; + + /* Disable and ack all interrupts */ + brcmnand_writel(0, priv->base + BCM6858_NAND_INT_EN); + brcmnand_writel(0, priv->base + BCM6858_NAND_INT); + + return brcmnand_probe(pdev, soc); +} + +static const struct udevice_id bcm6858_nand_dt_ids[] = { + { + .compatible = "brcm,nand-bcm6858", + }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(bcm6858_nand) = { + .name = "bcm6858-nand", + .id = UCLASS_MTD, + .of_match = bcm6858_nand_dt_ids, + .probe = bcm6858_nand_probe, + .priv_auto_alloc_size = sizeof(struct bcm6858_nand_soc), +}; + +void board_nand_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MTD, + DM_GET_DRIVER(bcm6858_nand), &dev); + if (ret && ret != -ENODEV) + pr_err("Failed to initialize %s. (error %d)\n", dev->name, + ret); +} diff --git a/drivers/mtd/nand/raw/brcmnand/brcmnand.c b/drivers/mtd/nand/raw/brcmnand/brcmnand.c new file mode 100644 index 0000000..7791077 --- /dev/null +++ b/drivers/mtd/nand/raw/brcmnand/brcmnand.c @@ -0,0 +1,2789 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright © 2010-2015 Broadcom Corporation + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/io.h> +#include <memalign.h> +#include <nand.h> +#include <clk.h> +#include <linux/ioport.h> +#include <linux/completion.h> +#include <linux/errno.h> +#include <linux/log2.h> +#include <asm/processor.h> +#include <dm.h> + +#include "brcmnand.h" +#include "brcmnand_compat.h" + +/* + * This flag controls if WP stays on between erase/write commands to mitigate + * flash corruption due to power glitches. Values: + * 0: NAND_WP is not used or not available + * 1: NAND_WP is set by default, cleared for erase/write operations + * 2: NAND_WP is always cleared + */ +static int wp_on = 1; +module_param(wp_on, int, 0444); + +/*********************************************************************** + * Definitions + ***********************************************************************/ + +#define DRV_NAME "brcmnand" + +#define CMD_NULL 0x00 +#define CMD_PAGE_READ 0x01 +#define CMD_SPARE_AREA_READ 0x02 +#define CMD_STATUS_READ 0x03 +#define CMD_PROGRAM_PAGE 0x04 +#define CMD_PROGRAM_SPARE_AREA 0x05 +#define CMD_COPY_BACK 0x06 +#define CMD_DEVICE_ID_READ 0x07 +#define CMD_BLOCK_ERASE 0x08 +#define CMD_FLASH_RESET 0x09 +#define CMD_BLOCKS_LOCK 0x0a +#define CMD_BLOCKS_LOCK_DOWN 0x0b +#define CMD_BLOCKS_UNLOCK 0x0c +#define CMD_READ_BLOCKS_LOCK_STATUS 0x0d +#define CMD_PARAMETER_READ 0x0e +#define CMD_PARAMETER_CHANGE_COL 0x0f +#define CMD_LOW_LEVEL_OP 0x10 + +struct brcm_nand_dma_desc { + u32 next_desc; + u32 next_desc_ext; + u32 cmd_irq; + u32 dram_addr; + u32 dram_addr_ext; + u32 tfr_len; + u32 total_len; + u32 flash_addr; + u32 flash_addr_ext; + u32 cs; + u32 pad2[5]; + u32 status_valid; +} __packed; + +/* Bitfields for brcm_nand_dma_desc::status_valid */ +#define FLASH_DMA_ECC_ERROR (1 << 8) +#define FLASH_DMA_CORR_ERROR (1 << 9) + +/* 512B flash cache in the NAND controller HW */ +#define FC_SHIFT 9U +#define FC_BYTES 512U +#define FC_WORDS (FC_BYTES >> 2) + +#define BRCMNAND_MIN_PAGESIZE 512 +#define BRCMNAND_MIN_BLOCKSIZE (8 * 1024) +#define BRCMNAND_MIN_DEVSIZE (4ULL * 1024 * 1024) + +#define NAND_CTRL_RDY (INTFC_CTLR_READY | INTFC_FLASH_READY) +#define NAND_POLL_STATUS_TIMEOUT_MS 100 + +/* Controller feature flags */ +enum { + BRCMNAND_HAS_1K_SECTORS = BIT(0), + BRCMNAND_HAS_PREFETCH = BIT(1), + BRCMNAND_HAS_CACHE_MODE = BIT(2), + BRCMNAND_HAS_WP = BIT(3), +}; + +struct brcmnand_controller { +#ifndef __UBOOT__ + struct device *dev; +#else + struct udevice *dev; +#endif /* __UBOOT__ */ + struct nand_hw_control controller; + void __iomem *nand_base; + void __iomem *nand_fc; /* flash cache */ + void __iomem *flash_dma_base; + unsigned int irq; + unsigned int dma_irq; + int nand_version; + + /* Some SoCs provide custom interrupt status register(s) */ + struct brcmnand_soc *soc; + + /* Some SoCs have a gateable clock for the controller */ + struct clk *clk; + + int cmd_pending; + bool dma_pending; + struct completion done; + struct completion dma_done; + + /* List of NAND hosts (one for each chip-select) */ + struct list_head host_list; + + struct brcm_nand_dma_desc *dma_desc; + dma_addr_t dma_pa; + + /* in-memory cache of the FLASH_CACHE, used only for some commands */ + u8 flash_cache[FC_BYTES]; + + /* Controller revision details */ + const u16 *reg_offsets; + unsigned int reg_spacing; /* between CS1, CS2, ... regs */ + const u8 *cs_offsets; /* within each chip-select */ + const u8 *cs0_offsets; /* within CS0, if different */ + unsigned int max_block_size; + const unsigned int *block_sizes; + unsigned int max_page_size; + const unsigned int *page_sizes; + unsigned int max_oob; + u32 features; + + /* for low-power standby/resume only */ + u32 nand_cs_nand_select; + u32 nand_cs_nand_xor; + u32 corr_stat_threshold; + u32 flash_dma_mode; +}; + +struct brcmnand_cfg { + u64 device_size; + unsigned int block_size; + unsigned int page_size; + unsigned int spare_area_size; + unsigned int device_width; + unsigned int col_adr_bytes; + unsigned int blk_adr_bytes; + unsigned int ful_adr_bytes; + unsigned int sector_size_1k; + unsigned int ecc_level; + /* use for low-power standby/resume only */ + u32 acc_control; + u32 config; + u32 config_ext; + u32 timing_1; + u32 timing_2; +}; + +struct brcmnand_host { + struct list_head node; + + struct nand_chip chip; +#ifndef __UBOOT__ + struct platform_device *pdev; +#else + struct udevice *pdev; +#endif /* __UBOOT__ */ + int cs; + + unsigned int last_cmd; + unsigned int last_byte; + u64 last_addr; + struct brcmnand_cfg hwcfg; + struct brcmnand_controller *ctrl; +}; + +enum brcmnand_reg { + BRCMNAND_CMD_START = 0, + BRCMNAND_CMD_EXT_ADDRESS, + BRCMNAND_CMD_ADDRESS, + BRCMNAND_INTFC_STATUS, + BRCMNAND_CS_SELECT, + BRCMNAND_CS_XOR, + BRCMNAND_LL_OP, + BRCMNAND_CS0_BASE, + BRCMNAND_CS1_BASE, /* CS1 regs, if non-contiguous */ + BRCMNAND_CORR_THRESHOLD, + BRCMNAND_CORR_THRESHOLD_EXT, + BRCMNAND_UNCORR_COUNT, + BRCMNAND_CORR_COUNT, + BRCMNAND_CORR_EXT_ADDR, + BRCMNAND_CORR_ADDR, + BRCMNAND_UNCORR_EXT_ADDR, + BRCMNAND_UNCORR_ADDR, + BRCMNAND_SEMAPHORE, + BRCMNAND_ID, + BRCMNAND_ID_EXT, + BRCMNAND_LL_RDATA, + BRCMNAND_OOB_READ_BASE, + BRCMNAND_OOB_READ_10_BASE, /* offset 0x10, if non-contiguous */ + BRCMNAND_OOB_WRITE_BASE, + BRCMNAND_OOB_WRITE_10_BASE, /* offset 0x10, if non-contiguous */ + BRCMNAND_FC_BASE, +}; + +/* BRCMNAND v4.0 */ +static const u16 brcmnand_regs_v40[] = { + [BRCMNAND_CMD_START] = 0x04, + [BRCMNAND_CMD_EXT_ADDRESS] = 0x08, + [BRCMNAND_CMD_ADDRESS] = 0x0c, + [BRCMNAND_INTFC_STATUS] = 0x6c, + [BRCMNAND_CS_SELECT] = 0x14, + [BRCMNAND_CS_XOR] = 0x18, + [BRCMNAND_LL_OP] = 0x178, + [BRCMNAND_CS0_BASE] = 0x40, + [BRCMNAND_CS1_BASE] = 0xd0, + [BRCMNAND_CORR_THRESHOLD] = 0x84, + [BRCMNAND_CORR_THRESHOLD_EXT] = 0, + [BRCMNAND_UNCORR_COUNT] = 0, + [BRCMNAND_CORR_COUNT] = 0, + [BRCMNAND_CORR_EXT_ADDR] = 0x70, + [BRCMNAND_CORR_ADDR] = 0x74, + [BRCMNAND_UNCORR_EXT_ADDR] = 0x78, + [BRCMNAND_UNCORR_ADDR] = 0x7c, + [BRCMNAND_SEMAPHORE] = 0x58, + [BRCMNAND_ID] = 0x60, + [BRCMNAND_ID_EXT] = 0x64, + [BRCMNAND_LL_RDATA] = 0x17c, + [BRCMNAND_OOB_READ_BASE] = 0x20, + [BRCMNAND_OOB_READ_10_BASE] = 0x130, + [BRCMNAND_OOB_WRITE_BASE] = 0x30, + [BRCMNAND_OOB_WRITE_10_BASE] = 0, + [BRCMNAND_FC_BASE] = 0x200, +}; + +/* BRCMNAND v5.0 */ +static const u16 brcmnand_regs_v50[] = { + [BRCMNAND_CMD_START] = 0x04, + [BRCMNAND_CMD_EXT_ADDRESS] = 0x08, + [BRCMNAND_CMD_ADDRESS] = 0x0c, + [BRCMNAND_INTFC_STATUS] = 0x6c, + [BRCMNAND_CS_SELECT] = 0x14, + [BRCMNAND_CS_XOR] = 0x18, + [BRCMNAND_LL_OP] = 0x178, + [BRCMNAND_CS0_BASE] = 0x40, + [BRCMNAND_CS1_BASE] = 0xd0, + [BRCMNAND_CORR_THRESHOLD] = 0x84, + [BRCMNAND_CORR_THRESHOLD_EXT] = 0, + [BRCMNAND_UNCORR_COUNT] = 0, + [BRCMNAND_CORR_COUNT] = 0, + [BRCMNAND_CORR_EXT_ADDR] = 0x70, + [BRCMNAND_CORR_ADDR] = 0x74, + [BRCMNAND_UNCORR_EXT_ADDR] = 0x78, + [BRCMNAND_UNCORR_ADDR] = 0x7c, + [BRCMNAND_SEMAPHORE] = 0x58, + [BRCMNAND_ID] = 0x60, + [BRCMNAND_ID_EXT] = 0x64, + [BRCMNAND_LL_RDATA] = 0x17c, + [BRCMNAND_OOB_READ_BASE] = 0x20, + [BRCMNAND_OOB_READ_10_BASE] = 0x130, + [BRCMNAND_OOB_WRITE_BASE] = 0x30, + [BRCMNAND_OOB_WRITE_10_BASE] = 0x140, + [BRCMNAND_FC_BASE] = 0x200, +}; + +/* BRCMNAND v6.0 - v7.1 */ +static const u16 brcmnand_regs_v60[] = { + [BRCMNAND_CMD_START] = 0x04, + [BRCMNAND_CMD_EXT_ADDRESS] = 0x08, + [BRCMNAND_CMD_ADDRESS] = 0x0c, + [BRCMNAND_INTFC_STATUS] = 0x14, + [BRCMNAND_CS_SELECT] = 0x18, + [BRCMNAND_CS_XOR] = 0x1c, + [BRCMNAND_LL_OP] = 0x20, + [BRCMNAND_CS0_BASE] = 0x50, + [BRCMNAND_CS1_BASE] = 0, + [BRCMNAND_CORR_THRESHOLD] = 0xc0, + [BRCMNAND_CORR_THRESHOLD_EXT] = 0xc4, + [BRCMNAND_UNCORR_COUNT] = 0xfc, + [BRCMNAND_CORR_COUNT] = 0x100, + [BRCMNAND_CORR_EXT_ADDR] = 0x10c, + [BRCMNAND_CORR_ADDR] = 0x110, + [BRCMNAND_UNCORR_EXT_ADDR] = 0x114, + [BRCMNAND_UNCORR_ADDR] = 0x118, + [BRCMNAND_SEMAPHORE] = 0x150, + [BRCMNAND_ID] = 0x194, + [BRCMNAND_ID_EXT] = 0x198, + [BRCMNAND_LL_RDATA] = 0x19c, + [BRCMNAND_OOB_READ_BASE] = 0x200, + [BRCMNAND_OOB_READ_10_BASE] = 0, + [BRCMNAND_OOB_WRITE_BASE] = 0x280, + [BRCMNAND_OOB_WRITE_10_BASE] = 0, + [BRCMNAND_FC_BASE] = 0x400, +}; + +/* BRCMNAND v7.1 */ +static const u16 brcmnand_regs_v71[] = { + [BRCMNAND_CMD_START] = 0x04, + [BRCMNAND_CMD_EXT_ADDRESS] = 0x08, + [BRCMNAND_CMD_ADDRESS] = 0x0c, + [BRCMNAND_INTFC_STATUS] = 0x14, + [BRCMNAND_CS_SELECT] = 0x18, + [BRCMNAND_CS_XOR] = 0x1c, + [BRCMNAND_LL_OP] = 0x20, + [BRCMNAND_CS0_BASE] = 0x50, + [BRCMNAND_CS1_BASE] = 0, + [BRCMNAND_CORR_THRESHOLD] = 0xdc, + [BRCMNAND_CORR_THRESHOLD_EXT] = 0xe0, + [BRCMNAND_UNCORR_COUNT] = 0xfc, + [BRCMNAND_CORR_COUNT] = 0x100, + [BRCMNAND_CORR_EXT_ADDR] = 0x10c, + [BRCMNAND_CORR_ADDR] = 0x110, + [BRCMNAND_UNCORR_EXT_ADDR] = 0x114, + [BRCMNAND_UNCORR_ADDR] = 0x118, + [BRCMNAND_SEMAPHORE] = 0x150, + [BRCMNAND_ID] = 0x194, + [BRCMNAND_ID_EXT] = 0x198, + [BRCMNAND_LL_RDATA] = 0x19c, + [BRCMNAND_OOB_READ_BASE] = 0x200, + [BRCMNAND_OOB_READ_10_BASE] = 0, + [BRCMNAND_OOB_WRITE_BASE] = 0x280, + [BRCMNAND_OOB_WRITE_10_BASE] = 0, + [BRCMNAND_FC_BASE] = 0x400, +}; + +/* BRCMNAND v7.2 */ +static const u16 brcmnand_regs_v72[] = { + [BRCMNAND_CMD_START] = 0x04, + [BRCMNAND_CMD_EXT_ADDRESS] = 0x08, + [BRCMNAND_CMD_ADDRESS] = 0x0c, + [BRCMNAND_INTFC_STATUS] = 0x14, + [BRCMNAND_CS_SELECT] = 0x18, + [BRCMNAND_CS_XOR] = 0x1c, + [BRCMNAND_LL_OP] = 0x20, + [BRCMNAND_CS0_BASE] = 0x50, + [BRCMNAND_CS1_BASE] = 0, + [BRCMNAND_CORR_THRESHOLD] = 0xdc, + [BRCMNAND_CORR_THRESHOLD_EXT] = 0xe0, + [BRCMNAND_UNCORR_COUNT] = 0xfc, + [BRCMNAND_CORR_COUNT] = 0x100, + [BRCMNAND_CORR_EXT_ADDR] = 0x10c, + [BRCMNAND_CORR_ADDR] = 0x110, + [BRCMNAND_UNCORR_EXT_ADDR] = 0x114, + [BRCMNAND_UNCORR_ADDR] = 0x118, + [BRCMNAND_SEMAPHORE] = 0x150, + [BRCMNAND_ID] = 0x194, + [BRCMNAND_ID_EXT] = 0x198, + [BRCMNAND_LL_RDATA] = 0x19c, + [BRCMNAND_OOB_READ_BASE] = 0x200, + [BRCMNAND_OOB_READ_10_BASE] = 0, + [BRCMNAND_OOB_WRITE_BASE] = 0x400, + [BRCMNAND_OOB_WRITE_10_BASE] = 0, + [BRCMNAND_FC_BASE] = 0x600, +}; + +enum brcmnand_cs_reg { + BRCMNAND_CS_CFG_EXT = 0, + BRCMNAND_CS_CFG, + BRCMNAND_CS_ACC_CONTROL, + BRCMNAND_CS_TIMING1, + BRCMNAND_CS_TIMING2, +}; + +/* Per chip-select offsets for v7.1 */ +static const u8 brcmnand_cs_offsets_v71[] = { + [BRCMNAND_CS_ACC_CONTROL] = 0x00, + [BRCMNAND_CS_CFG_EXT] = 0x04, + [BRCMNAND_CS_CFG] = 0x08, + [BRCMNAND_CS_TIMING1] = 0x0c, + [BRCMNAND_CS_TIMING2] = 0x10, +}; + +/* Per chip-select offsets for pre v7.1, except CS0 on <= v5.0 */ +static const u8 brcmnand_cs_offsets[] = { + [BRCMNAND_CS_ACC_CONTROL] = 0x00, + [BRCMNAND_CS_CFG_EXT] = 0x04, + [BRCMNAND_CS_CFG] = 0x04, + [BRCMNAND_CS_TIMING1] = 0x08, + [BRCMNAND_CS_TIMING2] = 0x0c, +}; + +/* Per chip-select offset for <= v5.0 on CS0 only */ +static const u8 brcmnand_cs_offsets_cs0[] = { + [BRCMNAND_CS_ACC_CONTROL] = 0x00, + [BRCMNAND_CS_CFG_EXT] = 0x08, + [BRCMNAND_CS_CFG] = 0x08, + [BRCMNAND_CS_TIMING1] = 0x10, + [BRCMNAND_CS_TIMING2] = 0x14, +}; + +/* + * Bitfields for the CFG and CFG_EXT registers. Pre-v7.1 controllers only had + * one config register, but once the bitfields overflowed, newer controllers + * (v7.1 and newer) added a CFG_EXT register and shuffled a few fields around. + */ +enum { + CFG_BLK_ADR_BYTES_SHIFT = 8, + CFG_COL_ADR_BYTES_SHIFT = 12, + CFG_FUL_ADR_BYTES_SHIFT = 16, + CFG_BUS_WIDTH_SHIFT = 23, + CFG_BUS_WIDTH = BIT(CFG_BUS_WIDTH_SHIFT), + CFG_DEVICE_SIZE_SHIFT = 24, + + /* Only for pre-v7.1 (with no CFG_EXT register) */ + CFG_PAGE_SIZE_SHIFT = 20, + CFG_BLK_SIZE_SHIFT = 28, + + /* Only for v7.1+ (with CFG_EXT register) */ + CFG_EXT_PAGE_SIZE_SHIFT = 0, + CFG_EXT_BLK_SIZE_SHIFT = 4, +}; + +/* BRCMNAND_INTFC_STATUS */ +enum { + INTFC_FLASH_STATUS = GENMASK(7, 0), + + INTFC_ERASED = BIT(27), + INTFC_OOB_VALID = BIT(28), + INTFC_CACHE_VALID = BIT(29), + INTFC_FLASH_READY = BIT(30), + INTFC_CTLR_READY = BIT(31), +}; + +static inline u32 nand_readreg(struct brcmnand_controller *ctrl, u32 offs) +{ + return brcmnand_readl(ctrl->nand_base + offs); +} + +static inline void nand_writereg(struct brcmnand_controller *ctrl, u32 offs, + u32 val) +{ + brcmnand_writel(val, ctrl->nand_base + offs); +} + +static int brcmnand_revision_init(struct brcmnand_controller *ctrl) +{ + static const unsigned int block_sizes_v6[] = { 8, 16, 128, 256, 512, 1024, 2048, 0 }; + static const unsigned int block_sizes_v4[] = { 16, 128, 8, 512, 256, 1024, 2048, 0 }; + static const unsigned int page_sizes[] = { 512, 2048, 4096, 8192, 0 }; + + ctrl->nand_version = nand_readreg(ctrl, 0) & 0xffff; + + /* Only support v4.0+? */ + if (ctrl->nand_version < 0x0400) { + dev_err(ctrl->dev, "version %#x not supported\n", + ctrl->nand_version); + return -ENODEV; + } + + /* Register offsets */ + if (ctrl->nand_version >= 0x0702) + ctrl->reg_offsets = brcmnand_regs_v72; + else if (ctrl->nand_version >= 0x0701) + ctrl->reg_offsets = brcmnand_regs_v71; + else if (ctrl->nand_version >= 0x0600) + ctrl->reg_offsets = brcmnand_regs_v60; + else if (ctrl->nand_version >= 0x0500) + ctrl->reg_offsets = brcmnand_regs_v50; + else if (ctrl->nand_version >= 0x0400) + ctrl->reg_offsets = brcmnand_regs_v40; + + /* Chip-select stride */ + if (ctrl->nand_version >= 0x0701) + ctrl->reg_spacing = 0x14; + else + ctrl->reg_spacing = 0x10; + + /* Per chip-select registers */ + if (ctrl->nand_version >= 0x0701) { + ctrl->cs_offsets = brcmnand_cs_offsets_v71; + } else { + ctrl->cs_offsets = brcmnand_cs_offsets; + + /* v5.0 and earlier has a different CS0 offset layout */ + if (ctrl->nand_version <= 0x0500) + ctrl->cs0_offsets = brcmnand_cs_offsets_cs0; + } + + /* Page / block sizes */ + if (ctrl->nand_version >= 0x0701) { + /* >= v7.1 use nice power-of-2 values! */ + ctrl->max_page_size = 16 * 1024; + ctrl->max_block_size = 2 * 1024 * 1024; + } else { + ctrl->page_sizes = page_sizes; + if (ctrl->nand_version >= 0x0600) + ctrl->block_sizes = block_sizes_v6; + else + ctrl->block_sizes = block_sizes_v4; + + if (ctrl->nand_version < 0x0400) { + ctrl->max_page_size = 4096; + ctrl->max_block_size = 512 * 1024; + } + } + + /* Maximum spare area sector size (per 512B) */ + if (ctrl->nand_version >= 0x0702) + ctrl->max_oob = 128; + else if (ctrl->nand_version >= 0x0600) + ctrl->max_oob = 64; + else if (ctrl->nand_version >= 0x0500) + ctrl->max_oob = 32; + else + ctrl->max_oob = 16; + + /* v6.0 and newer (except v6.1) have prefetch support */ + if (ctrl->nand_version >= 0x0600 && ctrl->nand_version != 0x0601) + ctrl->features |= BRCMNAND_HAS_PREFETCH; + + /* + * v6.x has cache mode, but it's implemented differently. Ignore it for + * now. + */ + if (ctrl->nand_version >= 0x0700) + ctrl->features |= BRCMNAND_HAS_CACHE_MODE; + + if (ctrl->nand_version >= 0x0500) + ctrl->features |= BRCMNAND_HAS_1K_SECTORS; + + if (ctrl->nand_version >= 0x0700) + ctrl->features |= BRCMNAND_HAS_WP; +#ifndef __UBOOT__ + else if (of_property_read_bool(ctrl->dev->of_node, "brcm,nand-has-wp")) +#else + else if (dev_read_bool(ctrl->dev, "brcm,nand-has-wp")) +#endif /* __UBOOT__ */ + ctrl->features |= BRCMNAND_HAS_WP; + + return 0; +} + +static inline u32 brcmnand_read_reg(struct brcmnand_controller *ctrl, + enum brcmnand_reg reg) +{ + u16 offs = ctrl->reg_offsets[reg]; + + if (offs) + return nand_readreg(ctrl, offs); + else + return 0; +} + +static inline void brcmnand_write_reg(struct brcmnand_controller *ctrl, + enum brcmnand_reg reg, u32 val) +{ + u16 offs = ctrl->reg_offsets[reg]; + + if (offs) + nand_writereg(ctrl, offs, val); +} + +static inline void brcmnand_rmw_reg(struct brcmnand_controller *ctrl, + enum brcmnand_reg reg, u32 mask, unsigned + int shift, u32 val) +{ + u32 tmp = brcmnand_read_reg(ctrl, reg); + + tmp &= ~mask; + tmp |= val << shift; + brcmnand_write_reg(ctrl, reg, tmp); +} + +static inline u32 brcmnand_read_fc(struct brcmnand_controller *ctrl, int word) +{ + return __raw_readl(ctrl->nand_fc + word * 4); +} + +static inline void brcmnand_write_fc(struct brcmnand_controller *ctrl, + int word, u32 val) +{ + __raw_writel(val, ctrl->nand_fc + word * 4); +} + +static inline u16 brcmnand_cs_offset(struct brcmnand_controller *ctrl, int cs, + enum brcmnand_cs_reg reg) +{ + u16 offs_cs0 = ctrl->reg_offsets[BRCMNAND_CS0_BASE]; + u16 offs_cs1 = ctrl->reg_offsets[BRCMNAND_CS1_BASE]; + u8 cs_offs; + + if (cs == 0 && ctrl->cs0_offsets) + cs_offs = ctrl->cs0_offsets[reg]; + else + cs_offs = ctrl->cs_offsets[reg]; + + if (cs && offs_cs1) + return offs_cs1 + (cs - 1) * ctrl->reg_spacing + cs_offs; + + return offs_cs0 + cs * ctrl->reg_spacing + cs_offs; +} + +static inline u32 brcmnand_count_corrected(struct brcmnand_controller *ctrl) +{ + if (ctrl->nand_version < 0x0600) + return 1; + return brcmnand_read_reg(ctrl, BRCMNAND_CORR_COUNT); +} + +static void brcmnand_wr_corr_thresh(struct brcmnand_host *host, u8 val) +{ + struct brcmnand_controller *ctrl = host->ctrl; + unsigned int shift = 0, bits; + enum brcmnand_reg reg = BRCMNAND_CORR_THRESHOLD; + int cs = host->cs; + + if (ctrl->nand_version >= 0x0702) + bits = 7; + else if (ctrl->nand_version >= 0x0600) + bits = 6; + else if (ctrl->nand_version >= 0x0500) + bits = 5; + else + bits = 4; + + if (ctrl->nand_version >= 0x0702) { + if (cs >= 4) + reg = BRCMNAND_CORR_THRESHOLD_EXT; + shift = (cs % 4) * bits; + } else if (ctrl->nand_version >= 0x0600) { + if (cs >= 5) + reg = BRCMNAND_CORR_THRESHOLD_EXT; + shift = (cs % 5) * bits; + } + brcmnand_rmw_reg(ctrl, reg, (bits - 1) << shift, shift, val); +} + +static inline int brcmnand_cmd_shift(struct brcmnand_controller *ctrl) +{ + if (ctrl->nand_version < 0x0602) + return 24; + return 0; +} + +/*********************************************************************** + * NAND ACC CONTROL bitfield + * + * Some bits have remained constant throughout hardware revision, while + * others have shifted around. + ***********************************************************************/ + +/* Constant for all versions (where supported) */ +enum { + /* See BRCMNAND_HAS_CACHE_MODE */ + ACC_CONTROL_CACHE_MODE = BIT(22), + + /* See BRCMNAND_HAS_PREFETCH */ + ACC_CONTROL_PREFETCH = BIT(23), + + ACC_CONTROL_PAGE_HIT = BIT(24), + ACC_CONTROL_WR_PREEMPT = BIT(25), + ACC_CONTROL_PARTIAL_PAGE = BIT(26), + ACC_CONTROL_RD_ERASED = BIT(27), + ACC_CONTROL_FAST_PGM_RDIN = BIT(28), + ACC_CONTROL_WR_ECC = BIT(30), + ACC_CONTROL_RD_ECC = BIT(31), +}; + +static inline u32 brcmnand_spare_area_mask(struct brcmnand_controller *ctrl) +{ + if (ctrl->nand_version >= 0x0702) + return GENMASK(7, 0); + else if (ctrl->nand_version >= 0x0600) + return GENMASK(6, 0); + else + return GENMASK(5, 0); +} + +#define NAND_ACC_CONTROL_ECC_SHIFT 16 +#define NAND_ACC_CONTROL_ECC_EXT_SHIFT 13 + +static inline u32 brcmnand_ecc_level_mask(struct brcmnand_controller *ctrl) +{ + u32 mask = (ctrl->nand_version >= 0x0600) ? 0x1f : 0x0f; + + mask <<= NAND_ACC_CONTROL_ECC_SHIFT; + + /* v7.2 includes additional ECC levels */ + if (ctrl->nand_version >= 0x0702) + mask |= 0x7 << NAND_ACC_CONTROL_ECC_EXT_SHIFT; + + return mask; +} + +static void brcmnand_set_ecc_enabled(struct brcmnand_host *host, int en) +{ + struct brcmnand_controller *ctrl = host->ctrl; + u16 offs = brcmnand_cs_offset(ctrl, host->cs, BRCMNAND_CS_ACC_CONTROL); + u32 acc_control = nand_readreg(ctrl, offs); + u32 ecc_flags = ACC_CONTROL_WR_ECC | ACC_CONTROL_RD_ECC; + + if (en) { + acc_control |= ecc_flags; /* enable RD/WR ECC */ + acc_control |= host->hwcfg.ecc_level + << NAND_ACC_CONTROL_ECC_SHIFT; + } else { + acc_control &= ~ecc_flags; /* disable RD/WR ECC */ + acc_control &= ~brcmnand_ecc_level_mask(ctrl); + } + + nand_writereg(ctrl, offs, acc_control); +} + +static inline int brcmnand_sector_1k_shift(struct brcmnand_controller *ctrl) +{ + if (ctrl->nand_version >= 0x0702) + return 9; + else if (ctrl->nand_version >= 0x0600) + return 7; + else if (ctrl->nand_version >= 0x0500) + return 6; + else + return -1; +} + +static int brcmnand_get_sector_size_1k(struct brcmnand_host *host) +{ + struct brcmnand_controller *ctrl = host->ctrl; + int shift = brcmnand_sector_1k_shift(ctrl); + u16 acc_control_offs = brcmnand_cs_offset(ctrl, host->cs, + BRCMNAND_CS_ACC_CONTROL); + + if (shift < 0) + return 0; + + return (nand_readreg(ctrl, acc_control_offs) >> shift) & 0x1; +} + +static void brcmnand_set_sector_size_1k(struct brcmnand_host *host, int val) +{ + struct brcmnand_controller *ctrl = host->ctrl; + int shift = brcmnand_sector_1k_shift(ctrl); + u16 acc_control_offs = brcmnand_cs_offset(ctrl, host->cs, + BRCMNAND_CS_ACC_CONTROL); + u32 tmp; + + if (shift < 0) + return; + + tmp = nand_readreg(ctrl, acc_control_offs); + tmp &= ~(1 << shift); + tmp |= (!!val) << shift; + nand_writereg(ctrl, acc_control_offs, tmp); +} + +/*********************************************************************** + * CS_NAND_SELECT + ***********************************************************************/ + +enum { + CS_SELECT_NAND_WP = BIT(29), + CS_SELECT_AUTO_DEVICE_ID_CFG = BIT(30), +}; + +static int bcmnand_ctrl_poll_status(struct brcmnand_controller *ctrl, + u32 mask, u32 expected_val, + unsigned long timeout_ms) +{ +#ifndef __UBOOT__ + unsigned long limit; + u32 val; + + if (!timeout_ms) + timeout_ms = NAND_POLL_STATUS_TIMEOUT_MS; + + limit = jiffies + msecs_to_jiffies(timeout_ms); + do { + val = brcmnand_read_reg(ctrl, BRCMNAND_INTFC_STATUS); + if ((val & mask) == expected_val) + return 0; + + cpu_relax(); + } while (time_after(limit, jiffies)); +#else + unsigned long base, limit; + u32 val; + + if (!timeout_ms) + timeout_ms = NAND_POLL_STATUS_TIMEOUT_MS; + + base = get_timer(0); + limit = CONFIG_SYS_HZ * timeout_ms / 1000; + do { + val = brcmnand_read_reg(ctrl, BRCMNAND_INTFC_STATUS); + if ((val & mask) == expected_val) + return 0; + + cpu_relax(); + } while (get_timer(base) < limit); +#endif /* __UBOOT__ */ + + dev_warn(ctrl->dev, "timeout on status poll (expected %x got %x)\n", + expected_val, val & mask); + + return -ETIMEDOUT; +} + +static inline void brcmnand_set_wp(struct brcmnand_controller *ctrl, bool en) +{ + u32 val = en ? CS_SELECT_NAND_WP : 0; + + brcmnand_rmw_reg(ctrl, BRCMNAND_CS_SELECT, CS_SELECT_NAND_WP, 0, val); +} + +/*********************************************************************** + * Flash DMA + ***********************************************************************/ + +enum flash_dma_reg { + FLASH_DMA_REVISION = 0x00, + FLASH_DMA_FIRST_DESC = 0x04, + FLASH_DMA_FIRST_DESC_EXT = 0x08, + FLASH_DMA_CTRL = 0x0c, + FLASH_DMA_MODE = 0x10, + FLASH_DMA_STATUS = 0x14, + FLASH_DMA_INTERRUPT_DESC = 0x18, + FLASH_DMA_INTERRUPT_DESC_EXT = 0x1c, + FLASH_DMA_ERROR_STATUS = 0x20, + FLASH_DMA_CURRENT_DESC = 0x24, + FLASH_DMA_CURRENT_DESC_EXT = 0x28, +}; + +static inline bool has_flash_dma(struct brcmnand_controller *ctrl) +{ + return ctrl->flash_dma_base; +} + +static inline bool flash_dma_buf_ok(const void *buf) +{ +#ifndef __UBOOT__ + return buf && !is_vmalloc_addr(buf) && + likely(IS_ALIGNED((uintptr_t)buf, 4)); +#else + return buf && likely(IS_ALIGNED((uintptr_t)buf, 4)); +#endif /* __UBOOT__ */ +} + +static inline void flash_dma_writel(struct brcmnand_controller *ctrl, u8 offs, + u32 val) +{ + brcmnand_writel(val, ctrl->flash_dma_base + offs); +} + +static inline u32 flash_dma_readl(struct brcmnand_controller *ctrl, u8 offs) +{ + return brcmnand_readl(ctrl->flash_dma_base + offs); +} + +/* Low-level operation types: command, address, write, or read */ +enum brcmnand_llop_type { + LL_OP_CMD, + LL_OP_ADDR, + LL_OP_WR, + LL_OP_RD, +}; + +/*********************************************************************** + * Internal support functions + ***********************************************************************/ + +static inline bool is_hamming_ecc(struct brcmnand_controller *ctrl, + struct brcmnand_cfg *cfg) +{ + if (ctrl->nand_version <= 0x0701) + return cfg->sector_size_1k == 0 && cfg->spare_area_size == 16 && + cfg->ecc_level == 15; + else + return cfg->sector_size_1k == 0 && ((cfg->spare_area_size == 16 && + cfg->ecc_level == 15) || + (cfg->spare_area_size == 28 && cfg->ecc_level == 16)); +} + +/* + * Set mtd->ooblayout to the appropriate mtd_ooblayout_ops given + * the layout/configuration. + * Returns -ERRCODE on failure. + */ +static int brcmnand_hamming_ooblayout_ecc(struct mtd_info *mtd, int section, + struct mtd_oob_region *oobregion) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_cfg *cfg = &host->hwcfg; + int sas = cfg->spare_area_size << cfg->sector_size_1k; + int sectors = cfg->page_size / (512 << cfg->sector_size_1k); + + if (section >= sectors) + return -ERANGE; + + oobregion->offset = (section * sas) + 6; + oobregion->length = 3; + + return 0; +} + +static int brcmnand_hamming_ooblayout_free(struct mtd_info *mtd, int section, + struct mtd_oob_region *oobregion) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_cfg *cfg = &host->hwcfg; + int sas = cfg->spare_area_size << cfg->sector_size_1k; + int sectors = cfg->page_size / (512 << cfg->sector_size_1k); + + if (section >= sectors * 2) + return -ERANGE; + + oobregion->offset = (section / 2) * sas; + + if (section & 1) { + oobregion->offset += 9; + oobregion->length = 7; + } else { + oobregion->length = 6; + + /* First sector of each page may have BBI */ + if (!section) { + /* + * Small-page NAND use byte 6 for BBI while large-page + * NAND use byte 0. + */ + if (cfg->page_size > 512) + oobregion->offset++; + oobregion->length--; + } + } + + return 0; +} + +static const struct mtd_ooblayout_ops brcmnand_hamming_ooblayout_ops = { + .ecc = brcmnand_hamming_ooblayout_ecc, + .free = brcmnand_hamming_ooblayout_free, +}; + +static int brcmnand_bch_ooblayout_ecc(struct mtd_info *mtd, int section, + struct mtd_oob_region *oobregion) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_cfg *cfg = &host->hwcfg; + int sas = cfg->spare_area_size << cfg->sector_size_1k; + int sectors = cfg->page_size / (512 << cfg->sector_size_1k); + + if (section >= sectors) + return -ERANGE; + + oobregion->offset = (section * (sas + 1)) - chip->ecc.bytes; + oobregion->length = chip->ecc.bytes; + + return 0; +} + +static int brcmnand_bch_ooblayout_free_lp(struct mtd_info *mtd, int section, + struct mtd_oob_region *oobregion) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_cfg *cfg = &host->hwcfg; + int sas = cfg->spare_area_size << cfg->sector_size_1k; + int sectors = cfg->page_size / (512 << cfg->sector_size_1k); + + if (section >= sectors) + return -ERANGE; + + if (sas <= chip->ecc.bytes) + return 0; + + oobregion->offset = section * sas; + oobregion->length = sas - chip->ecc.bytes; + + if (!section) { + oobregion->offset++; + oobregion->length--; + } + + return 0; +} + +static int brcmnand_bch_ooblayout_free_sp(struct mtd_info *mtd, int section, + struct mtd_oob_region *oobregion) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_cfg *cfg = &host->hwcfg; + int sas = cfg->spare_area_size << cfg->sector_size_1k; + + if (section > 1 || sas - chip->ecc.bytes < 6 || + (section && sas - chip->ecc.bytes == 6)) + return -ERANGE; + + if (!section) { + oobregion->offset = 0; + oobregion->length = 5; + } else { + oobregion->offset = 6; + oobregion->length = sas - chip->ecc.bytes - 6; + } + + return 0; +} + +static const struct mtd_ooblayout_ops brcmnand_bch_lp_ooblayout_ops = { + .ecc = brcmnand_bch_ooblayout_ecc, + .free = brcmnand_bch_ooblayout_free_lp, +}; + +static const struct mtd_ooblayout_ops brcmnand_bch_sp_ooblayout_ops = { + .ecc = brcmnand_bch_ooblayout_ecc, + .free = brcmnand_bch_ooblayout_free_sp, +}; + +static int brcmstb_choose_ecc_layout(struct brcmnand_host *host) +{ + struct brcmnand_cfg *p = &host->hwcfg; + struct mtd_info *mtd = nand_to_mtd(&host->chip); + struct nand_ecc_ctrl *ecc = &host->chip.ecc; + unsigned int ecc_level = p->ecc_level; + int sas = p->spare_area_size << p->sector_size_1k; + int sectors = p->page_size / (512 << p->sector_size_1k); + + if (p->sector_size_1k) + ecc_level <<= 1; + + if (is_hamming_ecc(host->ctrl, p)) { + ecc->bytes = 3 * sectors; + mtd_set_ooblayout(mtd, &brcmnand_hamming_ooblayout_ops); + return 0; + } + + /* + * CONTROLLER_VERSION: + * < v5.0: ECC_REQ = ceil(BCH_T * 13/8) + * >= v5.0: ECC_REQ = ceil(BCH_T * 14/8) + * But we will just be conservative. + */ + ecc->bytes = DIV_ROUND_UP(ecc_level * 14, 8); + if (p->page_size == 512) + mtd_set_ooblayout(mtd, &brcmnand_bch_sp_ooblayout_ops); + else + mtd_set_ooblayout(mtd, &brcmnand_bch_lp_ooblayout_ops); + + if (ecc->bytes >= sas) { + dev_err(&host->pdev->dev, + "error: ECC too large for OOB (ECC bytes %d, spare sector %d)\n", + ecc->bytes, sas); + return -EINVAL; + } + + return 0; +} + +static void brcmnand_wp(struct mtd_info *mtd, int wp) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_controller *ctrl = host->ctrl; + + if ((ctrl->features & BRCMNAND_HAS_WP) && wp_on == 1) { + static int old_wp = -1; + int ret; + + if (old_wp != wp) { + dev_dbg(ctrl->dev, "WP %s\n", wp ? "on" : "off"); + old_wp = wp; + } + + /* + * make sure ctrl/flash ready before and after + * changing state of #WP pin + */ + ret = bcmnand_ctrl_poll_status(ctrl, NAND_CTRL_RDY | + NAND_STATUS_READY, + NAND_CTRL_RDY | + NAND_STATUS_READY, 0); + if (ret) + return; + + brcmnand_set_wp(ctrl, wp); + nand_status_op(chip, NULL); + /* NAND_STATUS_WP 0x00 = protected, 0x80 = not protected */ + ret = bcmnand_ctrl_poll_status(ctrl, + NAND_CTRL_RDY | + NAND_STATUS_READY | + NAND_STATUS_WP, + NAND_CTRL_RDY | + NAND_STATUS_READY | + (wp ? 0 : NAND_STATUS_WP), 0); +#ifndef __UBOOT__ + if (ret) + dev_err_ratelimited(&host->pdev->dev, + "nand #WP expected %s\n", + wp ? "on" : "off"); +#else + if (ret) + dev_err(&host->pdev->dev, + "nand #WP expected %s\n", + wp ? "on" : "off"); +#endif /* __UBOOT__ */ + } +} + +/* Helper functions for reading and writing OOB registers */ +static inline u8 oob_reg_read(struct brcmnand_controller *ctrl, u32 offs) +{ + u16 offset0, offset10, reg_offs; + + offset0 = ctrl->reg_offsets[BRCMNAND_OOB_READ_BASE]; + offset10 = ctrl->reg_offsets[BRCMNAND_OOB_READ_10_BASE]; + + if (offs >= ctrl->max_oob) + return 0x77; + + if (offs >= 16 && offset10) + reg_offs = offset10 + ((offs - 0x10) & ~0x03); + else + reg_offs = offset0 + (offs & ~0x03); + + return nand_readreg(ctrl, reg_offs) >> (24 - ((offs & 0x03) << 3)); +} + +static inline void oob_reg_write(struct brcmnand_controller *ctrl, u32 offs, + u32 data) +{ + u16 offset0, offset10, reg_offs; + + offset0 = ctrl->reg_offsets[BRCMNAND_OOB_WRITE_BASE]; + offset10 = ctrl->reg_offsets[BRCMNAND_OOB_WRITE_10_BASE]; + + if (offs >= ctrl->max_oob) + return; + + if (offs >= 16 && offset10) + reg_offs = offset10 + ((offs - 0x10) & ~0x03); + else + reg_offs = offset0 + (offs & ~0x03); + + nand_writereg(ctrl, reg_offs, data); +} + +/* + * read_oob_from_regs - read data from OOB registers + * @ctrl: NAND controller + * @i: sub-page sector index + * @oob: buffer to read to + * @sas: spare area sector size (i.e., OOB size per FLASH_CACHE) + * @sector_1k: 1 for 1KiB sectors, 0 for 512B, other values are illegal + */ +static int read_oob_from_regs(struct brcmnand_controller *ctrl, int i, u8 *oob, + int sas, int sector_1k) +{ + int tbytes = sas << sector_1k; + int j; + + /* Adjust OOB values for 1K sector size */ + if (sector_1k && (i & 0x01)) + tbytes = max(0, tbytes - (int)ctrl->max_oob); + tbytes = min_t(int, tbytes, ctrl->max_oob); + + for (j = 0; j < tbytes; j++) + oob[j] = oob_reg_read(ctrl, j); + return tbytes; +} + +/* + * write_oob_to_regs - write data to OOB registers + * @i: sub-page sector index + * @oob: buffer to write from + * @sas: spare area sector size (i.e., OOB size per FLASH_CACHE) + * @sector_1k: 1 for 1KiB sectors, 0 for 512B, other values are illegal + */ +static int write_oob_to_regs(struct brcmnand_controller *ctrl, int i, + const u8 *oob, int sas, int sector_1k) +{ + int tbytes = sas << sector_1k; + int j; + + /* Adjust OOB values for 1K sector size */ + if (sector_1k && (i & 0x01)) + tbytes = max(0, tbytes - (int)ctrl->max_oob); + tbytes = min_t(int, tbytes, ctrl->max_oob); + + for (j = 0; j < tbytes; j += 4) + oob_reg_write(ctrl, j, + (oob[j + 0] << 24) | + (oob[j + 1] << 16) | + (oob[j + 2] << 8) | + (oob[j + 3] << 0)); + return tbytes; +} + +#ifndef __UBOOT__ +static irqreturn_t brcmnand_ctlrdy_irq(int irq, void *data) +{ + struct brcmnand_controller *ctrl = data; + + /* Discard all NAND_CTLRDY interrupts during DMA */ + if (ctrl->dma_pending) + return IRQ_HANDLED; + + complete(&ctrl->done); + return IRQ_HANDLED; +} + +/* Handle SoC-specific interrupt hardware */ +static irqreturn_t brcmnand_irq(int irq, void *data) +{ + struct brcmnand_controller *ctrl = data; + + if (ctrl->soc->ctlrdy_ack(ctrl->soc)) + return brcmnand_ctlrdy_irq(irq, data); + + return IRQ_NONE; +} + +static irqreturn_t brcmnand_dma_irq(int irq, void *data) +{ + struct brcmnand_controller *ctrl = data; + + complete(&ctrl->dma_done); + + return IRQ_HANDLED; +} +#endif /* __UBOOT__ */ + +static void brcmnand_send_cmd(struct brcmnand_host *host, int cmd) +{ + struct brcmnand_controller *ctrl = host->ctrl; + int ret; + + dev_dbg(ctrl->dev, "send native cmd %d addr_lo 0x%x\n", cmd, + brcmnand_read_reg(ctrl, BRCMNAND_CMD_ADDRESS)); + BUG_ON(ctrl->cmd_pending != 0); + ctrl->cmd_pending = cmd; + + ret = bcmnand_ctrl_poll_status(ctrl, NAND_CTRL_RDY, NAND_CTRL_RDY, 0); + WARN_ON(ret); + + mb(); /* flush previous writes */ + brcmnand_write_reg(ctrl, BRCMNAND_CMD_START, + cmd << brcmnand_cmd_shift(ctrl)); +} + +/*********************************************************************** + * NAND MTD API: read/program/erase + ***********************************************************************/ + +static void brcmnand_cmd_ctrl(struct mtd_info *mtd, int dat, + unsigned int ctrl) +{ + /* intentionally left blank */ +} + +static int brcmnand_waitfunc(struct mtd_info *mtd, struct nand_chip *this) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_controller *ctrl = host->ctrl; + +#ifndef __UBOOT__ + unsigned long timeo = msecs_to_jiffies(100); + + dev_dbg(ctrl->dev, "wait on native cmd %d\n", ctrl->cmd_pending); + if (ctrl->cmd_pending && + wait_for_completion_timeout(&ctrl->done, timeo) <= 0) { + u32 cmd = brcmnand_read_reg(ctrl, BRCMNAND_CMD_START) + >> brcmnand_cmd_shift(ctrl); + + dev_err_ratelimited(ctrl->dev, + "timeout waiting for command %#02x\n", cmd); + dev_err_ratelimited(ctrl->dev, "intfc status %08x\n", + brcmnand_read_reg(ctrl, BRCMNAND_INTFC_STATUS)); + } +#else + unsigned long timeo = 100; /* 100 msec */ + int ret; + + dev_dbg(ctrl->dev, "wait on native cmd %d\n", ctrl->cmd_pending); + + ret = bcmnand_ctrl_poll_status(ctrl, NAND_CTRL_RDY, NAND_CTRL_RDY, timeo); + WARN_ON(ret); +#endif /* __UBOOT__ */ + + ctrl->cmd_pending = 0; + return brcmnand_read_reg(ctrl, BRCMNAND_INTFC_STATUS) & + INTFC_FLASH_STATUS; +} + +enum { + LLOP_RE = BIT(16), + LLOP_WE = BIT(17), + LLOP_ALE = BIT(18), + LLOP_CLE = BIT(19), + LLOP_RETURN_IDLE = BIT(31), + + LLOP_DATA_MASK = GENMASK(15, 0), +}; + +static int brcmnand_low_level_op(struct brcmnand_host *host, + enum brcmnand_llop_type type, u32 data, + bool last_op) +{ + struct mtd_info *mtd = nand_to_mtd(&host->chip); + struct nand_chip *chip = &host->chip; + struct brcmnand_controller *ctrl = host->ctrl; + u32 tmp; + + tmp = data & LLOP_DATA_MASK; + switch (type) { + case LL_OP_CMD: + tmp |= LLOP_WE | LLOP_CLE; + break; + case LL_OP_ADDR: + /* WE | ALE */ + tmp |= LLOP_WE | LLOP_ALE; + break; + case LL_OP_WR: + /* WE */ + tmp |= LLOP_WE; + break; + case LL_OP_RD: + /* RE */ + tmp |= LLOP_RE; + break; + } + if (last_op) + /* RETURN_IDLE */ + tmp |= LLOP_RETURN_IDLE; + + dev_dbg(ctrl->dev, "ll_op cmd %#x\n", tmp); + + brcmnand_write_reg(ctrl, BRCMNAND_LL_OP, tmp); + (void)brcmnand_read_reg(ctrl, BRCMNAND_LL_OP); + + brcmnand_send_cmd(host, CMD_LOW_LEVEL_OP); + return brcmnand_waitfunc(mtd, chip); +} + +static void brcmnand_cmdfunc(struct mtd_info *mtd, unsigned command, + int column, int page_addr) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_controller *ctrl = host->ctrl; + u64 addr = (u64)page_addr << chip->page_shift; + int native_cmd = 0; + + if (command == NAND_CMD_READID || command == NAND_CMD_PARAM || + command == NAND_CMD_RNDOUT) + addr = (u64)column; + /* Avoid propagating a negative, don't-care address */ + else if (page_addr < 0) + addr = 0; + + dev_dbg(ctrl->dev, "cmd 0x%x addr 0x%llx\n", command, + (unsigned long long)addr); + + host->last_cmd = command; + host->last_byte = 0; + host->last_addr = addr; + + switch (command) { + case NAND_CMD_RESET: + native_cmd = CMD_FLASH_RESET; + break; + case NAND_CMD_STATUS: + native_cmd = CMD_STATUS_READ; + break; + case NAND_CMD_READID: + native_cmd = CMD_DEVICE_ID_READ; + break; + case NAND_CMD_READOOB: + native_cmd = CMD_SPARE_AREA_READ; + break; + case NAND_CMD_ERASE1: + native_cmd = CMD_BLOCK_ERASE; + brcmnand_wp(mtd, 0); + break; + case NAND_CMD_PARAM: + native_cmd = CMD_PARAMETER_READ; + break; + case NAND_CMD_SET_FEATURES: + case NAND_CMD_GET_FEATURES: + brcmnand_low_level_op(host, LL_OP_CMD, command, false); + brcmnand_low_level_op(host, LL_OP_ADDR, column, false); + break; + case NAND_CMD_RNDOUT: + native_cmd = CMD_PARAMETER_CHANGE_COL; + addr &= ~((u64)(FC_BYTES - 1)); + /* + * HW quirk: PARAMETER_CHANGE_COL requires SECTOR_SIZE_1K=0 + * NB: hwcfg.sector_size_1k may not be initialized yet + */ + if (brcmnand_get_sector_size_1k(host)) { + host->hwcfg.sector_size_1k = + brcmnand_get_sector_size_1k(host); + brcmnand_set_sector_size_1k(host, 0); + } + break; + } + + if (!native_cmd) + return; + + brcmnand_write_reg(ctrl, BRCMNAND_CMD_EXT_ADDRESS, + (host->cs << 16) | ((addr >> 32) & 0xffff)); + (void)brcmnand_read_reg(ctrl, BRCMNAND_CMD_EXT_ADDRESS); + brcmnand_write_reg(ctrl, BRCMNAND_CMD_ADDRESS, lower_32_bits(addr)); + (void)brcmnand_read_reg(ctrl, BRCMNAND_CMD_ADDRESS); + + brcmnand_send_cmd(host, native_cmd); + brcmnand_waitfunc(mtd, chip); + + if (native_cmd == CMD_PARAMETER_READ || + native_cmd == CMD_PARAMETER_CHANGE_COL) { + /* Copy flash cache word-wise */ + u32 *flash_cache = (u32 *)ctrl->flash_cache; + int i; + + brcmnand_soc_data_bus_prepare(ctrl->soc, true); + + /* + * Must cache the FLASH_CACHE now, since changes in + * SECTOR_SIZE_1K may invalidate it + */ + for (i = 0; i < FC_WORDS; i++) + /* + * Flash cache is big endian for parameter pages, at + * least on STB SoCs + */ + flash_cache[i] = be32_to_cpu(brcmnand_read_fc(ctrl, i)); + + brcmnand_soc_data_bus_unprepare(ctrl->soc, true); + + /* Cleanup from HW quirk: restore SECTOR_SIZE_1K */ + if (host->hwcfg.sector_size_1k) + brcmnand_set_sector_size_1k(host, + host->hwcfg.sector_size_1k); + } + + /* Re-enable protection is necessary only after erase */ + if (command == NAND_CMD_ERASE1) + brcmnand_wp(mtd, 1); +} + +static uint8_t brcmnand_read_byte(struct mtd_info *mtd) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_controller *ctrl = host->ctrl; + uint8_t ret = 0; + int addr, offs; + + switch (host->last_cmd) { + case NAND_CMD_READID: + if (host->last_byte < 4) + ret = brcmnand_read_reg(ctrl, BRCMNAND_ID) >> + (24 - (host->last_byte << 3)); + else if (host->last_byte < 8) + ret = brcmnand_read_reg(ctrl, BRCMNAND_ID_EXT) >> + (56 - (host->last_byte << 3)); + break; + + case NAND_CMD_READOOB: + ret = oob_reg_read(ctrl, host->last_byte); + break; + + case NAND_CMD_STATUS: + ret = brcmnand_read_reg(ctrl, BRCMNAND_INTFC_STATUS) & + INTFC_FLASH_STATUS; + if (wp_on) /* hide WP status */ + ret |= NAND_STATUS_WP; + break; + + case NAND_CMD_PARAM: + case NAND_CMD_RNDOUT: + addr = host->last_addr + host->last_byte; + offs = addr & (FC_BYTES - 1); + + /* At FC_BYTES boundary, switch to next column */ + if (host->last_byte > 0 && offs == 0) + nand_change_read_column_op(chip, addr, NULL, 0, false); + + ret = ctrl->flash_cache[offs]; + break; + case NAND_CMD_GET_FEATURES: + if (host->last_byte >= ONFI_SUBFEATURE_PARAM_LEN) { + ret = 0; + } else { + bool last = host->last_byte == + ONFI_SUBFEATURE_PARAM_LEN - 1; + brcmnand_low_level_op(host, LL_OP_RD, 0, last); + ret = brcmnand_read_reg(ctrl, BRCMNAND_LL_RDATA) & 0xff; + } + } + + dev_dbg(ctrl->dev, "read byte = 0x%02x\n", ret); + host->last_byte++; + + return ret; +} + +static void brcmnand_read_buf(struct mtd_info *mtd, uint8_t *buf, int len) +{ + int i; + + for (i = 0; i < len; i++, buf++) + *buf = brcmnand_read_byte(mtd); +} + +static void brcmnand_write_buf(struct mtd_info *mtd, const uint8_t *buf, + int len) +{ + int i; + struct nand_chip *chip = mtd_to_nand(mtd); + struct brcmnand_host *host = nand_get_controller_data(chip); + + switch (host->last_cmd) { + case NAND_CMD_SET_FEATURES: + for (i = 0; i < len; i++) + brcmnand_low_level_op(host, LL_OP_WR, buf[i], + (i + 1) == len); + break; + default: + BUG(); + break; + } +} + +/** + * Construct a FLASH_DMA descriptor as part of a linked list. You must know the + * following ahead of time: + * - Is this descriptor the beginning or end of a linked list? + * - What is the (DMA) address of the next descriptor in the linked list? + */ +#ifndef __UBOOT__ +static int brcmnand_fill_dma_desc(struct brcmnand_host *host, + struct brcm_nand_dma_desc *desc, u64 addr, + dma_addr_t buf, u32 len, u8 dma_cmd, + bool begin, bool end, + dma_addr_t next_desc) +{ + memset(desc, 0, sizeof(*desc)); + /* Descriptors are written in native byte order (wordwise) */ + desc->next_desc = lower_32_bits(next_desc); + desc->next_desc_ext = upper_32_bits(next_desc); + desc->cmd_irq = (dma_cmd << 24) | + (end ? (0x03 << 8) : 0) | /* IRQ | STOP */ + (!!begin) | ((!!end) << 1); /* head, tail */ +#ifdef CONFIG_CPU_BIG_ENDIAN + desc->cmd_irq |= 0x01 << 12; +#endif + desc->dram_addr = lower_32_bits(buf); + desc->dram_addr_ext = upper_32_bits(buf); + desc->tfr_len = len; + desc->total_len = len; + desc->flash_addr = lower_32_bits(addr); + desc->flash_addr_ext = upper_32_bits(addr); + desc->cs = host->cs; + desc->status_valid = 0x01; + return 0; +} + +/** + * Kick the FLASH_DMA engine, with a given DMA descriptor + */ +static void brcmnand_dma_run(struct brcmnand_host *host, dma_addr_t desc) +{ + struct brcmnand_controller *ctrl = host->ctrl; + unsigned long timeo = msecs_to_jiffies(100); + + flash_dma_writel(ctrl, FLASH_DMA_FIRST_DESC, lower_32_bits(desc)); + (void)flash_dma_readl(ctrl, FLASH_DMA_FIRST_DESC); + flash_dma_writel(ctrl, FLASH_DMA_FIRST_DESC_EXT, upper_32_bits(desc)); + (void)flash_dma_readl(ctrl, FLASH_DMA_FIRST_DESC_EXT); + + /* Start FLASH_DMA engine */ + ctrl->dma_pending = true; + mb(); /* flush previous writes */ + flash_dma_writel(ctrl, FLASH_DMA_CTRL, 0x03); /* wake | run */ + + if (wait_for_completion_timeout(&ctrl->dma_done, timeo) <= 0) { + dev_err(ctrl->dev, + "timeout waiting for DMA; status %#x, error status %#x\n", + flash_dma_readl(ctrl, FLASH_DMA_STATUS), + flash_dma_readl(ctrl, FLASH_DMA_ERROR_STATUS)); + } + ctrl->dma_pending = false; + flash_dma_writel(ctrl, FLASH_DMA_CTRL, 0); /* force stop */ +} + +static int brcmnand_dma_trans(struct brcmnand_host *host, u64 addr, u32 *buf, + u32 len, u8 dma_cmd) +{ + struct brcmnand_controller *ctrl = host->ctrl; + dma_addr_t buf_pa; + int dir = dma_cmd == CMD_PAGE_READ ? DMA_FROM_DEVICE : DMA_TO_DEVICE; + + buf_pa = dma_map_single(ctrl->dev, buf, len, dir); + if (dma_mapping_error(ctrl->dev, buf_pa)) { + dev_err(ctrl->dev, "unable to map buffer for DMA\n"); + return -ENOMEM; + } + + brcmnand_fill_dma_desc(host, ctrl->dma_desc, addr, buf_pa, len, + dma_cmd, true, true, 0); + + brcmnand_dma_run(host, ctrl->dma_pa); + + dma_unmap_single(ctrl->dev, buf_pa, len, dir); + + if (ctrl->dma_desc->status_valid & FLASH_DMA_ECC_ERROR) + return -EBADMSG; + else if (ctrl->dma_desc->status_valid & FLASH_DMA_CORR_ERROR) + return -EUCLEAN; + + return 0; +} +#endif /* __UBOOT__ */ + +/* + * Assumes proper CS is already set + */ +static int brcmnand_read_by_pio(struct mtd_info *mtd, struct nand_chip *chip, + u64 addr, unsigned int trans, u32 *buf, + u8 *oob, u64 *err_addr) +{ + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_controller *ctrl = host->ctrl; + int i, j, ret = 0; + + /* Clear error addresses */ + brcmnand_write_reg(ctrl, BRCMNAND_UNCORR_ADDR, 0); + brcmnand_write_reg(ctrl, BRCMNAND_CORR_ADDR, 0); + brcmnand_write_reg(ctrl, BRCMNAND_UNCORR_EXT_ADDR, 0); + brcmnand_write_reg(ctrl, BRCMNAND_CORR_EXT_ADDR, 0); + + brcmnand_write_reg(ctrl, BRCMNAND_CMD_EXT_ADDRESS, + (host->cs << 16) | ((addr >> 32) & 0xffff)); + (void)brcmnand_read_reg(ctrl, BRCMNAND_CMD_EXT_ADDRESS); + + for (i = 0; i < trans; i++, addr += FC_BYTES) { + brcmnand_write_reg(ctrl, BRCMNAND_CMD_ADDRESS, + lower_32_bits(addr)); + (void)brcmnand_read_reg(ctrl, BRCMNAND_CMD_ADDRESS); + /* SPARE_AREA_READ does not use ECC, so just use PAGE_READ */ + brcmnand_send_cmd(host, CMD_PAGE_READ); + brcmnand_waitfunc(mtd, chip); + + if (likely(buf)) { + brcmnand_soc_data_bus_prepare(ctrl->soc, false); + + for (j = 0; j < FC_WORDS; j++, buf++) + *buf = brcmnand_read_fc(ctrl, j); + + brcmnand_soc_data_bus_unprepare(ctrl->soc, false); + } + + if (oob) + oob += read_oob_from_regs(ctrl, i, oob, + mtd->oobsize / trans, + host->hwcfg.sector_size_1k); + + if (!ret) { + *err_addr = brcmnand_read_reg(ctrl, + BRCMNAND_UNCORR_ADDR) | + ((u64)(brcmnand_read_reg(ctrl, + BRCMNAND_UNCORR_EXT_ADDR) + & 0xffff) << 32); + if (*err_addr) + ret = -EBADMSG; + } + + if (!ret) { + *err_addr = brcmnand_read_reg(ctrl, + BRCMNAND_CORR_ADDR) | + ((u64)(brcmnand_read_reg(ctrl, + BRCMNAND_CORR_EXT_ADDR) + & 0xffff) << 32); + if (*err_addr) + ret = -EUCLEAN; + } + } + + return ret; +} + +/* + * Check a page to see if it is erased (w/ bitflips) after an uncorrectable ECC + * error + * + * Because the HW ECC signals an ECC error if an erase paged has even a single + * bitflip, we must check each ECC error to see if it is actually an erased + * page with bitflips, not a truly corrupted page. + * + * On a real error, return a negative error code (-EBADMSG for ECC error), and + * buf will contain raw data. + * Otherwise, buf gets filled with 0xffs and return the maximum number of + * bitflips-per-ECC-sector to the caller. + * + */ +static int brcmstb_nand_verify_erased_page(struct mtd_info *mtd, + struct nand_chip *chip, void *buf, u64 addr) +{ + int i, sas; + void *oob = chip->oob_poi; + int bitflips = 0; + int page = addr >> chip->page_shift; + int ret; + + if (!buf) { +#ifndef __UBOOT__ + buf = chip->data_buf; +#else + buf = chip->buffers->databuf; +#endif + /* Invalidate page cache */ + chip->pagebuf = -1; + } + + sas = mtd->oobsize / chip->ecc.steps; + + /* read without ecc for verification */ + ret = chip->ecc.read_page_raw(mtd, chip, buf, true, page); + if (ret) + return ret; + + for (i = 0; i < chip->ecc.steps; i++, oob += sas) { + ret = nand_check_erased_ecc_chunk(buf, chip->ecc.size, + oob, sas, NULL, 0, + chip->ecc.strength); + if (ret < 0) + return ret; + + bitflips = max(bitflips, ret); + } + + return bitflips; +} + +static int brcmnand_read(struct mtd_info *mtd, struct nand_chip *chip, + u64 addr, unsigned int trans, u32 *buf, u8 *oob) +{ + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_controller *ctrl = host->ctrl; + u64 err_addr = 0; + int err; + bool retry = true; + + dev_dbg(ctrl->dev, "read %llx -> %p\n", (unsigned long long)addr, buf); + +try_dmaread: + brcmnand_write_reg(ctrl, BRCMNAND_UNCORR_COUNT, 0); + +#ifndef __UBOOT__ + if (has_flash_dma(ctrl) && !oob && flash_dma_buf_ok(buf)) { + err = brcmnand_dma_trans(host, addr, buf, trans * FC_BYTES, + CMD_PAGE_READ); + if (err) { + if (mtd_is_bitflip_or_eccerr(err)) + err_addr = addr; + else + return -EIO; + } + } else { + if (oob) + memset(oob, 0x99, mtd->oobsize); + + err = brcmnand_read_by_pio(mtd, chip, addr, trans, buf, + oob, &err_addr); + } +#else + if (oob) + memset(oob, 0x99, mtd->oobsize); + + err = brcmnand_read_by_pio(mtd, chip, addr, trans, buf, + oob, &err_addr); +#endif /* __UBOOT__ */ + + if (mtd_is_eccerr(err)) { + /* + * On controller version and 7.0, 7.1 , DMA read after a + * prior PIO read that reported uncorrectable error, + * the DMA engine captures this error following DMA read + * cleared only on subsequent DMA read, so just retry once + * to clear a possible false error reported for current DMA + * read + */ + if ((ctrl->nand_version == 0x0700) || + (ctrl->nand_version == 0x0701)) { + if (retry) { + retry = false; + goto try_dmaread; + } + } + + /* + * Controller version 7.2 has hw encoder to detect erased page + * bitflips, apply sw verification for older controllers only + */ + if (ctrl->nand_version < 0x0702) { + err = brcmstb_nand_verify_erased_page(mtd, chip, buf, + addr); + /* erased page bitflips corrected */ + if (err >= 0) + return err; + } + + dev_dbg(ctrl->dev, "uncorrectable error at 0x%llx\n", + (unsigned long long)err_addr); + mtd->ecc_stats.failed++; + /* NAND layer expects zero on ECC errors */ + return 0; + } + + if (mtd_is_bitflip(err)) { + unsigned int corrected = brcmnand_count_corrected(ctrl); + + dev_dbg(ctrl->dev, "corrected error at 0x%llx\n", + (unsigned long long)err_addr); + mtd->ecc_stats.corrected += corrected; + /* Always exceed the software-imposed threshold */ + return max(mtd->bitflip_threshold, corrected); + } + + return 0; +} + +static int brcmnand_read_page(struct mtd_info *mtd, struct nand_chip *chip, + uint8_t *buf, int oob_required, int page) +{ + struct brcmnand_host *host = nand_get_controller_data(chip); + u8 *oob = oob_required ? (u8 *)chip->oob_poi : NULL; + + nand_read_page_op(chip, page, 0, NULL, 0); + + return brcmnand_read(mtd, chip, host->last_addr, + mtd->writesize >> FC_SHIFT, (u32 *)buf, oob); +} + +static int brcmnand_read_page_raw(struct mtd_info *mtd, struct nand_chip *chip, + uint8_t *buf, int oob_required, int page) +{ + struct brcmnand_host *host = nand_get_controller_data(chip); + u8 *oob = oob_required ? (u8 *)chip->oob_poi : NULL; + int ret; + + nand_read_page_op(chip, page, 0, NULL, 0); + + brcmnand_set_ecc_enabled(host, 0); + ret = brcmnand_read(mtd, chip, host->last_addr, + mtd->writesize >> FC_SHIFT, (u32 *)buf, oob); + brcmnand_set_ecc_enabled(host, 1); + return ret; +} + +static int brcmnand_read_oob(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + return brcmnand_read(mtd, chip, (u64)page << chip->page_shift, + mtd->writesize >> FC_SHIFT, + NULL, (u8 *)chip->oob_poi); +} + +static int brcmnand_read_oob_raw(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + struct brcmnand_host *host = nand_get_controller_data(chip); + + brcmnand_set_ecc_enabled(host, 0); + brcmnand_read(mtd, chip, (u64)page << chip->page_shift, + mtd->writesize >> FC_SHIFT, + NULL, (u8 *)chip->oob_poi); + brcmnand_set_ecc_enabled(host, 1); + return 0; +} + +static int brcmnand_write(struct mtd_info *mtd, struct nand_chip *chip, + u64 addr, const u32 *buf, u8 *oob) +{ + struct brcmnand_host *host = nand_get_controller_data(chip); + struct brcmnand_controller *ctrl = host->ctrl; + unsigned int i, j, trans = mtd->writesize >> FC_SHIFT; + int status, ret = 0; + + dev_dbg(ctrl->dev, "write %llx <- %p\n", (unsigned long long)addr, buf); + + if (unlikely((unsigned long)buf & 0x03)) { + dev_warn(ctrl->dev, "unaligned buffer: %p\n", buf); + buf = (u32 *)((unsigned long)buf & ~0x03); + } + + brcmnand_wp(mtd, 0); + + for (i = 0; i < ctrl->max_oob; i += 4) + oob_reg_write(ctrl, i, 0xffffffff); + +#ifndef __UBOOT__ + if (has_flash_dma(ctrl) && !oob && flash_dma_buf_ok(buf)) { + if (brcmnand_dma_trans(host, addr, (u32 *)buf, + mtd->writesize, CMD_PROGRAM_PAGE)) + ret = -EIO; + goto out; + } +#endif /* __UBOOT__ */ + + brcmnand_write_reg(ctrl, BRCMNAND_CMD_EXT_ADDRESS, + (host->cs << 16) | ((addr >> 32) & 0xffff)); + (void)brcmnand_read_reg(ctrl, BRCMNAND_CMD_EXT_ADDRESS); + + for (i = 0; i < trans; i++, addr += FC_BYTES) { + /* full address MUST be set before populating FC */ + brcmnand_write_reg(ctrl, BRCMNAND_CMD_ADDRESS, + lower_32_bits(addr)); + (void)brcmnand_read_reg(ctrl, BRCMNAND_CMD_ADDRESS); + + if (buf) { + brcmnand_soc_data_bus_prepare(ctrl->soc, false); + + for (j = 0; j < FC_WORDS; j++, buf++) + brcmnand_write_fc(ctrl, j, *buf); + + brcmnand_soc_data_bus_unprepare(ctrl->soc, false); + } else if (oob) { + for (j = 0; j < FC_WORDS; j++) + brcmnand_write_fc(ctrl, j, 0xffffffff); + } + + if (oob) { + oob += write_oob_to_regs(ctrl, i, oob, + mtd->oobsize / trans, + host->hwcfg.sector_size_1k); + } + + /* we cannot use SPARE_AREA_PROGRAM when PARTIAL_PAGE_EN=0 */ + brcmnand_send_cmd(host, CMD_PROGRAM_PAGE); + status = brcmnand_waitfunc(mtd, chip); + + if (status & NAND_STATUS_FAIL) { + dev_info(ctrl->dev, "program failed at %llx\n", + (unsigned long long)addr); + ret = -EIO; + goto out; + } + } +out: + brcmnand_wp(mtd, 1); + return ret; +} + +static int brcmnand_write_page(struct mtd_info *mtd, struct nand_chip *chip, + const uint8_t *buf, int oob_required, int page) +{ + struct brcmnand_host *host = nand_get_controller_data(chip); + void *oob = oob_required ? chip->oob_poi : NULL; + + nand_prog_page_begin_op(chip, page, 0, NULL, 0); + brcmnand_write(mtd, chip, host->last_addr, (const u32 *)buf, oob); + + return nand_prog_page_end_op(chip); +} + +static int brcmnand_write_page_raw(struct mtd_info *mtd, + struct nand_chip *chip, const uint8_t *buf, + int oob_required, int page) +{ + struct brcmnand_host *host = nand_get_controller_data(chip); + void *oob = oob_required ? chip->oob_poi : NULL; + + nand_prog_page_begin_op(chip, page, 0, NULL, 0); + brcmnand_set_ecc_enabled(host, 0); + brcmnand_write(mtd, chip, host->last_addr, (const u32 *)buf, oob); + brcmnand_set_ecc_enabled(host, 1); + + return nand_prog_page_end_op(chip); +} + +static int brcmnand_write_oob(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + return brcmnand_write(mtd, chip, (u64)page << chip->page_shift, + NULL, chip->oob_poi); +} + +static int brcmnand_write_oob_raw(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + struct brcmnand_host *host = nand_get_controller_data(chip); + int ret; + + brcmnand_set_ecc_enabled(host, 0); + ret = brcmnand_write(mtd, chip, (u64)page << chip->page_shift, NULL, + (u8 *)chip->oob_poi); + brcmnand_set_ecc_enabled(host, 1); + + return ret; +} + +/*********************************************************************** + * Per-CS setup (1 NAND device) + ***********************************************************************/ + +static int brcmnand_set_cfg(struct brcmnand_host *host, + struct brcmnand_cfg *cfg) +{ + struct brcmnand_controller *ctrl = host->ctrl; + struct nand_chip *chip = &host->chip; + u16 cfg_offs = brcmnand_cs_offset(ctrl, host->cs, BRCMNAND_CS_CFG); + u16 cfg_ext_offs = brcmnand_cs_offset(ctrl, host->cs, + BRCMNAND_CS_CFG_EXT); + u16 acc_control_offs = brcmnand_cs_offset(ctrl, host->cs, + BRCMNAND_CS_ACC_CONTROL); + u8 block_size = 0, page_size = 0, device_size = 0; + u32 tmp; + + if (ctrl->block_sizes) { + int i, found; + + for (i = 0, found = 0; ctrl->block_sizes[i]; i++) + if (ctrl->block_sizes[i] * 1024 == cfg->block_size) { + block_size = i; + found = 1; + } + if (!found) { + dev_warn(ctrl->dev, "invalid block size %u\n", + cfg->block_size); + return -EINVAL; + } + } else { + block_size = ffs(cfg->block_size) - ffs(BRCMNAND_MIN_BLOCKSIZE); + } + + if (cfg->block_size < BRCMNAND_MIN_BLOCKSIZE || (ctrl->max_block_size && + cfg->block_size > ctrl->max_block_size)) { + dev_warn(ctrl->dev, "invalid block size %u\n", + cfg->block_size); + block_size = 0; + } + + if (ctrl->page_sizes) { + int i, found; + + for (i = 0, found = 0; ctrl->page_sizes[i]; i++) + if (ctrl->page_sizes[i] == cfg->page_size) { + page_size = i; + found = 1; + } + if (!found) { + dev_warn(ctrl->dev, "invalid page size %u\n", + cfg->page_size); + return -EINVAL; + } + } else { + page_size = ffs(cfg->page_size) - ffs(BRCMNAND_MIN_PAGESIZE); + } + + if (cfg->page_size < BRCMNAND_MIN_PAGESIZE || (ctrl->max_page_size && + cfg->page_size > ctrl->max_page_size)) { + dev_warn(ctrl->dev, "invalid page size %u\n", cfg->page_size); + return -EINVAL; + } + + if (fls64(cfg->device_size) < fls64(BRCMNAND_MIN_DEVSIZE)) { + dev_warn(ctrl->dev, "invalid device size 0x%llx\n", + (unsigned long long)cfg->device_size); + return -EINVAL; + } + device_size = fls64(cfg->device_size) - fls64(BRCMNAND_MIN_DEVSIZE); + + tmp = (cfg->blk_adr_bytes << CFG_BLK_ADR_BYTES_SHIFT) | + (cfg->col_adr_bytes << CFG_COL_ADR_BYTES_SHIFT) | + (cfg->ful_adr_bytes << CFG_FUL_ADR_BYTES_SHIFT) | + (!!(cfg->device_width == 16) << CFG_BUS_WIDTH_SHIFT) | + (device_size << CFG_DEVICE_SIZE_SHIFT); + if (cfg_offs == cfg_ext_offs) { + tmp |= (page_size << CFG_PAGE_SIZE_SHIFT) | + (block_size << CFG_BLK_SIZE_SHIFT); + nand_writereg(ctrl, cfg_offs, tmp); + } else { + nand_writereg(ctrl, cfg_offs, tmp); + tmp = (page_size << CFG_EXT_PAGE_SIZE_SHIFT) | + (block_size << CFG_EXT_BLK_SIZE_SHIFT); + nand_writereg(ctrl, cfg_ext_offs, tmp); + } + + tmp = nand_readreg(ctrl, acc_control_offs); + tmp &= ~brcmnand_ecc_level_mask(ctrl); + tmp |= cfg->ecc_level << NAND_ACC_CONTROL_ECC_SHIFT; + tmp &= ~brcmnand_spare_area_mask(ctrl); + tmp |= cfg->spare_area_size; + nand_writereg(ctrl, acc_control_offs, tmp); + + brcmnand_set_sector_size_1k(host, cfg->sector_size_1k); + + /* threshold = ceil(BCH-level * 0.75) */ + brcmnand_wr_corr_thresh(host, DIV_ROUND_UP(chip->ecc.strength * 3, 4)); + + return 0; +} + +static void brcmnand_print_cfg(struct brcmnand_host *host, + char *buf, struct brcmnand_cfg *cfg) +{ + buf += sprintf(buf, + "%lluMiB total, %uKiB blocks, %u%s pages, %uB OOB, %u-bit", + (unsigned long long)cfg->device_size >> 20, + cfg->block_size >> 10, + cfg->page_size >= 1024 ? cfg->page_size >> 10 : cfg->page_size, + cfg->page_size >= 1024 ? "KiB" : "B", + cfg->spare_area_size, cfg->device_width); + + /* Account for Hamming ECC and for BCH 512B vs 1KiB sectors */ + if (is_hamming_ecc(host->ctrl, cfg)) + sprintf(buf, ", Hamming ECC"); + else if (cfg->sector_size_1k) + sprintf(buf, ", BCH-%u (1KiB sector)", cfg->ecc_level << 1); + else + sprintf(buf, ", BCH-%u", cfg->ecc_level); +} + +/* + * Minimum number of bytes to address a page. Calculated as: + * roundup(log2(size / page-size) / 8) + * + * NB: the following does not "round up" for non-power-of-2 'size'; but this is + * OK because many other things will break if 'size' is irregular... + */ +static inline int get_blk_adr_bytes(u64 size, u32 writesize) +{ + return ALIGN(ilog2(size) - ilog2(writesize), 8) >> 3; +} + +static int brcmnand_setup_dev(struct brcmnand_host *host) +{ + struct mtd_info *mtd = nand_to_mtd(&host->chip); + struct nand_chip *chip = &host->chip; + struct brcmnand_controller *ctrl = host->ctrl; + struct brcmnand_cfg *cfg = &host->hwcfg; + char msg[128]; + u32 offs, tmp, oob_sector; + int ret; + + memset(cfg, 0, sizeof(*cfg)); + +#ifndef __UBOOT__ + ret = of_property_read_u32(nand_get_flash_node(chip), + "brcm,nand-oob-sector-size", + &oob_sector); +#else + ret = ofnode_read_u32(nand_get_flash_node(chip), + "brcm,nand-oob-sector-size", + &oob_sector); +#endif /* __UBOOT__ */ + if (ret) { + /* Use detected size */ + cfg->spare_area_size = mtd->oobsize / + (mtd->writesize >> FC_SHIFT); + } else { + cfg->spare_area_size = oob_sector; + } + if (cfg->spare_area_size > ctrl->max_oob) + cfg->spare_area_size = ctrl->max_oob; + /* + * Set oobsize to be consistent with controller's spare_area_size, as + * the rest is inaccessible. + */ + mtd->oobsize = cfg->spare_area_size * (mtd->writesize >> FC_SHIFT); + + cfg->device_size = mtd->size; + cfg->block_size = mtd->erasesize; + cfg->page_size = mtd->writesize; + cfg->device_width = (chip->options & NAND_BUSWIDTH_16) ? 16 : 8; + cfg->col_adr_bytes = 2; + cfg->blk_adr_bytes = get_blk_adr_bytes(mtd->size, mtd->writesize); + + if (chip->ecc.mode != NAND_ECC_HW) { + dev_err(ctrl->dev, "only HW ECC supported; selected: %d\n", + chip->ecc.mode); + return -EINVAL; + } + + if (chip->ecc.algo == NAND_ECC_UNKNOWN) { + if (chip->ecc.strength == 1 && chip->ecc.size == 512) + /* Default to Hamming for 1-bit ECC, if unspecified */ + chip->ecc.algo = NAND_ECC_HAMMING; + else + /* Otherwise, BCH */ + chip->ecc.algo = NAND_ECC_BCH; + } + + if (chip->ecc.algo == NAND_ECC_HAMMING && (chip->ecc.strength != 1 || + chip->ecc.size != 512)) { + dev_err(ctrl->dev, "invalid Hamming params: %d bits per %d bytes\n", + chip->ecc.strength, chip->ecc.size); + return -EINVAL; + } + + switch (chip->ecc.size) { + case 512: + if (chip->ecc.algo == NAND_ECC_HAMMING) + cfg->ecc_level = 15; + else + cfg->ecc_level = chip->ecc.strength; + cfg->sector_size_1k = 0; + break; + case 1024: + if (!(ctrl->features & BRCMNAND_HAS_1K_SECTORS)) { + dev_err(ctrl->dev, "1KB sectors not supported\n"); + return -EINVAL; + } + if (chip->ecc.strength & 0x1) { + dev_err(ctrl->dev, + "odd ECC not supported with 1KB sectors\n"); + return -EINVAL; + } + + cfg->ecc_level = chip->ecc.strength >> 1; + cfg->sector_size_1k = 1; + break; + default: + dev_err(ctrl->dev, "unsupported ECC size: %d\n", + chip->ecc.size); + return -EINVAL; + } + + cfg->ful_adr_bytes = cfg->blk_adr_bytes; + if (mtd->writesize > 512) + cfg->ful_adr_bytes += cfg->col_adr_bytes; + else + cfg->ful_adr_bytes += 1; + + ret = brcmnand_set_cfg(host, cfg); + if (ret) + return ret; + + brcmnand_set_ecc_enabled(host, 1); + + brcmnand_print_cfg(host, msg, cfg); + dev_info(ctrl->dev, "detected %s\n", msg); + + /* Configure ACC_CONTROL */ + offs = brcmnand_cs_offset(ctrl, host->cs, BRCMNAND_CS_ACC_CONTROL); + tmp = nand_readreg(ctrl, offs); + tmp &= ~ACC_CONTROL_PARTIAL_PAGE; + tmp &= ~ACC_CONTROL_RD_ERASED; + + /* We need to turn on Read from erased paged protected by ECC */ + if (ctrl->nand_version >= 0x0702) + tmp |= ACC_CONTROL_RD_ERASED; + tmp &= ~ACC_CONTROL_FAST_PGM_RDIN; + if (ctrl->features & BRCMNAND_HAS_PREFETCH) + tmp &= ~ACC_CONTROL_PREFETCH; + + nand_writereg(ctrl, offs, tmp); + + return 0; +} + +#ifndef __UBOOT__ +static int brcmnand_init_cs(struct brcmnand_host *host, struct device_node *dn) +#else +static int brcmnand_init_cs(struct brcmnand_host *host, ofnode dn) +#endif +{ + struct brcmnand_controller *ctrl = host->ctrl; +#ifndef __UBOOT__ + struct platform_device *pdev = host->pdev; +#else + struct udevice *pdev = host->pdev; +#endif /* __UBOOT__ */ + struct mtd_info *mtd; + struct nand_chip *chip; + int ret; + u16 cfg_offs; + +#ifndef __UBOOT__ + ret = of_property_read_u32(dn, "reg", &host->cs); +#else + ret = ofnode_read_s32(dn, "reg", &host->cs); +#endif + if (ret) { + dev_err(&pdev->dev, "can't get chip-select\n"); + return -ENXIO; + } + + mtd = nand_to_mtd(&host->chip); + chip = &host->chip; + + nand_set_flash_node(chip, dn); + nand_set_controller_data(chip, host); +#ifndef __UBOOT__ + mtd->name = devm_kasprintf(&pdev->dev, GFP_KERNEL, "brcmnand.%d", + host->cs); +#else + mtd->name = devm_kasprintf(pdev, GFP_KERNEL, "brcmnand.%d", + host->cs); +#endif /* __UBOOT__ */ + if (!mtd->name) + return -ENOMEM; + + mtd->owner = THIS_MODULE; +#ifndef __UBOOT__ + mtd->dev.parent = &pdev->dev; +#else + mtd->dev->parent = pdev; +#endif /* __UBOOT__ */ + + chip->IO_ADDR_R = (void __iomem *)0xdeadbeef; + chip->IO_ADDR_W = (void __iomem *)0xdeadbeef; + + chip->cmd_ctrl = brcmnand_cmd_ctrl; + chip->cmdfunc = brcmnand_cmdfunc; + chip->waitfunc = brcmnand_waitfunc; + chip->read_byte = brcmnand_read_byte; + chip->read_buf = brcmnand_read_buf; + chip->write_buf = brcmnand_write_buf; + + chip->ecc.mode = NAND_ECC_HW; + chip->ecc.read_page = brcmnand_read_page; + chip->ecc.write_page = brcmnand_write_page; + chip->ecc.read_page_raw = brcmnand_read_page_raw; + chip->ecc.write_page_raw = brcmnand_write_page_raw; + chip->ecc.write_oob_raw = brcmnand_write_oob_raw; + chip->ecc.read_oob_raw = brcmnand_read_oob_raw; + chip->ecc.read_oob = brcmnand_read_oob; + chip->ecc.write_oob = brcmnand_write_oob; + + chip->controller = &ctrl->controller; + + /* + * The bootloader might have configured 16bit mode but + * NAND READID command only works in 8bit mode. We force + * 8bit mode here to ensure that NAND READID commands works. + */ + cfg_offs = brcmnand_cs_offset(ctrl, host->cs, BRCMNAND_CS_CFG); + nand_writereg(ctrl, cfg_offs, + nand_readreg(ctrl, cfg_offs) & ~CFG_BUS_WIDTH); + + ret = nand_scan_ident(mtd, 1, NULL); + if (ret) + return ret; + + chip->options |= NAND_NO_SUBPAGE_WRITE; + /* + * Avoid (for instance) kmap()'d buffers from JFFS2, which we can't DMA + * to/from, and have nand_base pass us a bounce buffer instead, as + * needed. + */ + chip->options |= NAND_USE_BOUNCE_BUFFER; + + if (chip->bbt_options & NAND_BBT_USE_FLASH) + chip->bbt_options |= NAND_BBT_NO_OOB; + + if (brcmnand_setup_dev(host)) + return -ENXIO; + + chip->ecc.size = host->hwcfg.sector_size_1k ? 1024 : 512; + /* only use our internal HW threshold */ + mtd->bitflip_threshold = 1; + + ret = brcmstb_choose_ecc_layout(host); + if (ret) + return ret; + + ret = nand_scan_tail(mtd); + if (ret) + return ret; + +#ifndef __UBOOT__ + ret = mtd_device_register(mtd, NULL, 0); + if (ret) + nand_cleanup(chip); +#else + ret = nand_register(0, mtd); +#endif /* __UBOOT__ */ + + return ret; +} + +#ifndef __UBOOT__ +static void brcmnand_save_restore_cs_config(struct brcmnand_host *host, + int restore) +{ + struct brcmnand_controller *ctrl = host->ctrl; + u16 cfg_offs = brcmnand_cs_offset(ctrl, host->cs, BRCMNAND_CS_CFG); + u16 cfg_ext_offs = brcmnand_cs_offset(ctrl, host->cs, + BRCMNAND_CS_CFG_EXT); + u16 acc_control_offs = brcmnand_cs_offset(ctrl, host->cs, + BRCMNAND_CS_ACC_CONTROL); + u16 t1_offs = brcmnand_cs_offset(ctrl, host->cs, BRCMNAND_CS_TIMING1); + u16 t2_offs = brcmnand_cs_offset(ctrl, host->cs, BRCMNAND_CS_TIMING2); + + if (restore) { + nand_writereg(ctrl, cfg_offs, host->hwcfg.config); + if (cfg_offs != cfg_ext_offs) + nand_writereg(ctrl, cfg_ext_offs, + host->hwcfg.config_ext); + nand_writereg(ctrl, acc_control_offs, host->hwcfg.acc_control); + nand_writereg(ctrl, t1_offs, host->hwcfg.timing_1); + nand_writereg(ctrl, t2_offs, host->hwcfg.timing_2); + } else { + host->hwcfg.config = nand_readreg(ctrl, cfg_offs); + if (cfg_offs != cfg_ext_offs) + host->hwcfg.config_ext = + nand_readreg(ctrl, cfg_ext_offs); + host->hwcfg.acc_control = nand_readreg(ctrl, acc_control_offs); + host->hwcfg.timing_1 = nand_readreg(ctrl, t1_offs); + host->hwcfg.timing_2 = nand_readreg(ctrl, t2_offs); + } +} + +static int brcmnand_suspend(struct device *dev) +{ + struct brcmnand_controller *ctrl = dev_get_drvdata(dev); + struct brcmnand_host *host; + + list_for_each_entry(host, &ctrl->host_list, node) + brcmnand_save_restore_cs_config(host, 0); + + ctrl->nand_cs_nand_select = brcmnand_read_reg(ctrl, BRCMNAND_CS_SELECT); + ctrl->nand_cs_nand_xor = brcmnand_read_reg(ctrl, BRCMNAND_CS_XOR); + ctrl->corr_stat_threshold = + brcmnand_read_reg(ctrl, BRCMNAND_CORR_THRESHOLD); + + if (has_flash_dma(ctrl)) + ctrl->flash_dma_mode = flash_dma_readl(ctrl, FLASH_DMA_MODE); + + return 0; +} + +static int brcmnand_resume(struct device *dev) +{ + struct brcmnand_controller *ctrl = dev_get_drvdata(dev); + struct brcmnand_host *host; + + if (has_flash_dma(ctrl)) { + flash_dma_writel(ctrl, FLASH_DMA_MODE, ctrl->flash_dma_mode); + flash_dma_writel(ctrl, FLASH_DMA_ERROR_STATUS, 0); + } + + brcmnand_write_reg(ctrl, BRCMNAND_CS_SELECT, ctrl->nand_cs_nand_select); + brcmnand_write_reg(ctrl, BRCMNAND_CS_XOR, ctrl->nand_cs_nand_xor); + brcmnand_write_reg(ctrl, BRCMNAND_CORR_THRESHOLD, + ctrl->corr_stat_threshold); + if (ctrl->soc) { + /* Clear/re-enable interrupt */ + ctrl->soc->ctlrdy_ack(ctrl->soc); + ctrl->soc->ctlrdy_set_enabled(ctrl->soc, true); + } + + list_for_each_entry(host, &ctrl->host_list, node) { + struct nand_chip *chip = &host->chip; + + brcmnand_save_restore_cs_config(host, 1); + + /* Reset the chip, required by some chips after power-up */ + nand_reset_op(chip); + } + + return 0; +} + +const struct dev_pm_ops brcmnand_pm_ops = { + .suspend = brcmnand_suspend, + .resume = brcmnand_resume, +}; +EXPORT_SYMBOL_GPL(brcmnand_pm_ops); + +static const struct of_device_id brcmnand_of_match[] = { + { .compatible = "brcm,brcmnand-v4.0" }, + { .compatible = "brcm,brcmnand-v5.0" }, + { .compatible = "brcm,brcmnand-v6.0" }, + { .compatible = "brcm,brcmnand-v6.1" }, + { .compatible = "brcm,brcmnand-v6.2" }, + { .compatible = "brcm,brcmnand-v7.0" }, + { .compatible = "brcm,brcmnand-v7.1" }, + { .compatible = "brcm,brcmnand-v7.2" }, + {}, +}; +MODULE_DEVICE_TABLE(of, brcmnand_of_match); +#endif /* __UBOOT__ */ + +/*********************************************************************** + * Platform driver setup (per controller) + ***********************************************************************/ + +#ifndef __UBOOT__ +int brcmnand_probe(struct platform_device *pdev, struct brcmnand_soc *soc) +#else +int brcmnand_probe(struct udevice *dev, struct brcmnand_soc *soc) +#endif /* __UBOOT__ */ +{ +#ifndef __UBOOT__ + struct device *dev = &pdev->dev; + struct device_node *dn = dev->of_node, *child; +#else + ofnode child; + struct udevice *pdev = dev; +#endif /* __UBOOT__ */ + struct brcmnand_controller *ctrl; +#ifndef __UBOOT__ + struct resource *res; +#else + struct resource res; +#endif /* __UBOOT__ */ + int ret; + +#ifndef __UBOOT__ + /* We only support device-tree instantiation */ + if (!dn) + return -ENODEV; + + if (!of_match_node(brcmnand_of_match, dn)) + return -ENODEV; +#endif /* __UBOOT__ */ + + ctrl = devm_kzalloc(dev, sizeof(*ctrl), GFP_KERNEL); + if (!ctrl) + return -ENOMEM; + +#ifndef __UBOOT__ + dev_set_drvdata(dev, ctrl); +#else + /* + * in u-boot, the data for the driver is allocated before probing + * so to keep the reference to ctrl, we store it in the variable soc + */ + soc->ctrl = ctrl; +#endif /* __UBOOT__ */ + ctrl->dev = dev; + + init_completion(&ctrl->done); + init_completion(&ctrl->dma_done); + nand_hw_control_init(&ctrl->controller); + INIT_LIST_HEAD(&ctrl->host_list); + + /* NAND register range */ +#ifndef __UBOOT__ + res = platform_get_resource(pdev, IORESOURCE_MEM, 0); + ctrl->nand_base = devm_ioremap_resource(dev, res); +#else + dev_read_resource(pdev, 0, &res); + ctrl->nand_base = devm_ioremap(pdev, res.start, resource_size(&res)); +#endif + if (IS_ERR(ctrl->nand_base)) + return PTR_ERR(ctrl->nand_base); + + /* Enable clock before using NAND registers */ + ctrl->clk = devm_clk_get(dev, "nand"); + if (!IS_ERR(ctrl->clk)) { + ret = clk_prepare_enable(ctrl->clk); + if (ret) + return ret; + } else { + ret = PTR_ERR(ctrl->clk); + if (ret == -EPROBE_DEFER) + return ret; + + ctrl->clk = NULL; + } + + /* Initialize NAND revision */ + ret = brcmnand_revision_init(ctrl); + if (ret) + goto err; + + /* + * Most chips have this cache at a fixed offset within 'nand' block. + * Some must specify this region separately. + */ +#ifndef __UBOOT__ + res = platform_get_resource_byname(pdev, IORESOURCE_MEM, "nand-cache"); + if (res) { + ctrl->nand_fc = devm_ioremap_resource(dev, res); + if (IS_ERR(ctrl->nand_fc)) { + ret = PTR_ERR(ctrl->nand_fc); + goto err; + } + } else { + ctrl->nand_fc = ctrl->nand_base + + ctrl->reg_offsets[BRCMNAND_FC_BASE]; + } +#else + if (!dev_read_resource_byname(pdev, "nand-cache", &res)) { + ctrl->nand_fc = devm_ioremap(dev, res.start, + resource_size(&res)); + if (IS_ERR(ctrl->nand_fc)) { + ret = PTR_ERR(ctrl->nand_fc); + goto err; + } + } else { + ctrl->nand_fc = ctrl->nand_base + + ctrl->reg_offsets[BRCMNAND_FC_BASE]; + } +#endif + +#ifndef __UBOOT__ + /* FLASH_DMA */ + res = platform_get_resource_byname(pdev, IORESOURCE_MEM, "flash-dma"); + if (res) { + ctrl->flash_dma_base = devm_ioremap_resource(dev, res); + if (IS_ERR(ctrl->flash_dma_base)) { + ret = PTR_ERR(ctrl->flash_dma_base); + goto err; + } + + flash_dma_writel(ctrl, FLASH_DMA_MODE, 1); /* linked-list */ + flash_dma_writel(ctrl, FLASH_DMA_ERROR_STATUS, 0); + + /* Allocate descriptor(s) */ + ctrl->dma_desc = dmam_alloc_coherent(dev, + sizeof(*ctrl->dma_desc), + &ctrl->dma_pa, GFP_KERNEL); + if (!ctrl->dma_desc) { + ret = -ENOMEM; + goto err; + } + + ctrl->dma_irq = platform_get_irq(pdev, 1); + if ((int)ctrl->dma_irq < 0) { + dev_err(dev, "missing FLASH_DMA IRQ\n"); + ret = -ENODEV; + goto err; + } + + ret = devm_request_irq(dev, ctrl->dma_irq, + brcmnand_dma_irq, 0, DRV_NAME, + ctrl); + if (ret < 0) { + dev_err(dev, "can't allocate IRQ %d: error %d\n", + ctrl->dma_irq, ret); + goto err; + } + + dev_info(dev, "enabling FLASH_DMA\n"); + } +#endif /* __UBOOT__ */ + + /* Disable automatic device ID config, direct addressing */ + brcmnand_rmw_reg(ctrl, BRCMNAND_CS_SELECT, + CS_SELECT_AUTO_DEVICE_ID_CFG | 0xff, 0, 0); + /* Disable XOR addressing */ + brcmnand_rmw_reg(ctrl, BRCMNAND_CS_XOR, 0xff, 0, 0); + + if (ctrl->features & BRCMNAND_HAS_WP) { + /* Permanently disable write protection */ + if (wp_on == 2) + brcmnand_set_wp(ctrl, false); + } else { + wp_on = 0; + } + +#ifndef __UBOOT__ + /* IRQ */ + ctrl->irq = platform_get_irq(pdev, 0); + if ((int)ctrl->irq < 0) { + dev_err(dev, "no IRQ defined\n"); + ret = -ENODEV; + goto err; + } + + /* + * Some SoCs integrate this controller (e.g., its interrupt bits) in + * interesting ways + */ + if (soc) { + ctrl->soc = soc; + + ret = devm_request_irq(dev, ctrl->irq, brcmnand_irq, 0, + DRV_NAME, ctrl); + + /* Enable interrupt */ + ctrl->soc->ctlrdy_ack(ctrl->soc); + ctrl->soc->ctlrdy_set_enabled(ctrl->soc, true); + } else { + /* Use standard interrupt infrastructure */ + ret = devm_request_irq(dev, ctrl->irq, brcmnand_ctlrdy_irq, 0, + DRV_NAME, ctrl); + } + if (ret < 0) { + dev_err(dev, "can't allocate IRQ %d: error %d\n", + ctrl->irq, ret); + goto err; + } +#endif /* __UBOOT__ */ + +#ifndef __UBOOT__ + for_each_available_child_of_node(dn, child) { + if (of_device_is_compatible(child, "brcm,nandcs")) { + struct brcmnand_host *host; + + host = devm_kzalloc(dev, sizeof(*host), GFP_KERNEL); + if (!host) { + of_node_put(child); + ret = -ENOMEM; + goto err; + } + host->pdev = pdev; + host->ctrl = ctrl; + + ret = brcmnand_init_cs(host, child); + if (ret) { + devm_kfree(dev, host); + continue; /* Try all chip-selects */ + } + + list_add_tail(&host->node, &ctrl->host_list); + } + } +#else + ofnode_for_each_subnode(child, dev_ofnode(dev)) { + if (ofnode_device_is_compatible(child, "brcm,nandcs")) { + struct brcmnand_host *host; + + host = devm_kzalloc(dev, sizeof(*host), GFP_KERNEL); + if (!host) { + ret = -ENOMEM; + goto err; + } + host->pdev = pdev; + host->ctrl = ctrl; + + ret = brcmnand_init_cs(host, child); + if (ret) { + devm_kfree(dev, host); + continue; /* Try all chip-selects */ + } + + list_add_tail(&host->node, &ctrl->host_list); + } + } +#endif /* __UBOOT__ */ + +err: +#ifndef __UBOOT__ + clk_disable_unprepare(ctrl->clk); +#else + if (ctrl->clk) + clk_disable(ctrl->clk); +#endif /* __UBOOT__ */ + return ret; + +} +EXPORT_SYMBOL_GPL(brcmnand_probe); + +#ifndef __UBOOT__ +int brcmnand_remove(struct platform_device *pdev) +{ + struct brcmnand_controller *ctrl = dev_get_drvdata(&pdev->dev); + struct brcmnand_host *host; + + list_for_each_entry(host, &ctrl->host_list, node) + nand_release(nand_to_mtd(&host->chip)); + + clk_disable_unprepare(ctrl->clk); + + dev_set_drvdata(&pdev->dev, NULL); + + return 0; +} +#else +int brcmnand_remove(struct udevice *pdev) +{ + return 0; +} +#endif /* __UBOOT__ */ +EXPORT_SYMBOL_GPL(brcmnand_remove); + +MODULE_LICENSE("GPL v2"); +MODULE_AUTHOR("Kevin Cernekee"); +MODULE_AUTHOR("Brian Norris"); +MODULE_DESCRIPTION("NAND driver for Broadcom chips"); +MODULE_ALIAS("platform:brcmnand"); diff --git a/drivers/mtd/nand/raw/brcmnand/brcmnand.h b/drivers/mtd/nand/raw/brcmnand/brcmnand.h new file mode 100644 index 0000000..6946a62 --- /dev/null +++ b/drivers/mtd/nand/raw/brcmnand/brcmnand.h @@ -0,0 +1,63 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __BRCMNAND_H__ +#define __BRCMNAND_H__ + +#include <linux/types.h> +#include <linux/io.h> + +struct brcmnand_soc { + bool (*ctlrdy_ack)(struct brcmnand_soc *soc); + void (*ctlrdy_set_enabled)(struct brcmnand_soc *soc, bool en); + void (*prepare_data_bus)(struct brcmnand_soc *soc, bool prepare, + bool is_param); + void *ctrl; +}; + +static inline void brcmnand_soc_data_bus_prepare(struct brcmnand_soc *soc, + bool is_param) +{ + if (soc && soc->prepare_data_bus) + soc->prepare_data_bus(soc, true, is_param); +} + +static inline void brcmnand_soc_data_bus_unprepare(struct brcmnand_soc *soc, + bool is_param) +{ + if (soc && soc->prepare_data_bus) + soc->prepare_data_bus(soc, false, is_param); +} + +static inline u32 brcmnand_readl(void __iomem *addr) +{ + /* + * MIPS endianness is configured by boot strap, which also reverses all + * bus endianness (i.e., big-endian CPU + big endian bus ==> native + * endian I/O). + * + * Other architectures (e.g., ARM) either do not support big endian, or + * else leave I/O in little endian mode. + */ + if (IS_ENABLED(CONFIG_MIPS) && IS_ENABLED(CONFIG_SYS_BIG_ENDIAN)) + return __raw_readl(addr); + else + return readl_relaxed(addr); +} + +static inline void brcmnand_writel(u32 val, void __iomem *addr) +{ + /* See brcmnand_readl() comments */ + if (IS_ENABLED(CONFIG_MIPS) && IS_ENABLED(CONFIG_SYS_BIG_ENDIAN)) + __raw_writel(val, addr); + else + writel_relaxed(val, addr); +} + +int brcmnand_probe(struct udevice *dev, struct brcmnand_soc *soc); +int brcmnand_remove(struct udevice *dev); + +#ifndef __UBOOT__ +extern const struct dev_pm_ops brcmnand_pm_ops; +#endif /* __UBOOT__ */ + +#endif /* __BRCMNAND_H__ */ diff --git a/drivers/mtd/nand/raw/brcmnand/brcmnand_compat.c b/drivers/mtd/nand/raw/brcmnand/brcmnand_compat.c new file mode 100644 index 0000000..96b27e6 --- /dev/null +++ b/drivers/mtd/nand/raw/brcmnand/brcmnand_compat.c @@ -0,0 +1,66 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include "brcmnand_compat.h" + +struct clk *devm_clk_get(struct udevice *dev, const char *id) +{ + struct clk *clk; + int ret; + + clk = devm_kzalloc(dev, sizeof(*clk), GFP_KERNEL); + if (!clk) { + debug("%s: can't allocate clock\n", __func__); + return ERR_PTR(-ENOMEM); + } + + ret = clk_get_by_name(dev, id, clk); + if (ret < 0) { + debug("%s: can't get clock (ret = %d)!\n", __func__, ret); + return ERR_PTR(ret); + } + + return clk; +} + +int clk_prepare_enable(struct clk *clk) +{ + return clk_enable(clk); +} + +void clk_disable_unprepare(struct clk *clk) +{ + clk_disable(clk); +} + +static char *devm_kvasprintf(struct udevice *dev, gfp_t gfp, const char *fmt, + va_list ap) +{ + unsigned int len; + char *p; + va_list aq; + + va_copy(aq, ap); + len = vsnprintf(NULL, 0, fmt, aq); + va_end(aq); + + p = devm_kmalloc(dev, len + 1, gfp); + if (!p) + return NULL; + + vsnprintf(p, len + 1, fmt, ap); + + return p; +} + +char *devm_kasprintf(struct udevice *dev, gfp_t gfp, const char *fmt, ...) +{ + va_list ap; + char *p; + + va_start(ap, fmt); + p = devm_kvasprintf(dev, gfp, fmt, ap); + va_end(ap); + + return p; +} diff --git a/drivers/mtd/nand/raw/brcmnand/brcmnand_compat.h b/drivers/mtd/nand/raw/brcmnand/brcmnand_compat.h new file mode 100644 index 0000000..02cab0f --- /dev/null +++ b/drivers/mtd/nand/raw/brcmnand/brcmnand_compat.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __BRCMNAND_COMPAT_H +#define __BRCMNAND_COMPAT_H + +#include <clk.h> +#include <dm.h> + +struct clk *devm_clk_get(struct udevice *dev, const char *id); +int clk_prepare_enable(struct clk *clk); +void clk_disable_unprepare(struct clk *clk); + +char *devm_kasprintf(struct udevice *dev, gfp_t gfp, const char *fmt, ...); + +#endif /* __BRCMNAND_COMPAT_H */
On Fri, Mar 15, 2019 at 03:14:36PM +0100, Philippe Reynes wrote:
The driver brcmnand come from linux kernel 4.18. Only SoC bcm6838 and bcm6858 are supported.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com
The parameter page isn't always in big endian, so we add an option to choose the endiannes of the parameter page.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- drivers/mtd/nand/raw/brcmnand/brcmnand.c | 17 +++++++++++++++-- 1 file changed, 15 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/raw/brcmnand/brcmnand.c b/drivers/mtd/nand/raw/brcmnand/brcmnand.c index 7791077..e333320 100644 --- a/drivers/mtd/nand/raw/brcmnand/brcmnand.c +++ b/drivers/mtd/nand/raw/brcmnand/brcmnand.c @@ -113,6 +113,7 @@ struct brcmnand_controller { unsigned int irq; unsigned int dma_irq; int nand_version; + int parameter_page_big_endian;
/* Some SoCs provide custom interrupt status register(s) */ struct brcmnand_soc *soc; @@ -1439,12 +1440,20 @@ static void brcmnand_cmdfunc(struct mtd_info *mtd, unsigned command, * Must cache the FLASH_CACHE now, since changes in * SECTOR_SIZE_1K may invalidate it */ - for (i = 0; i < FC_WORDS; i++) + for (i = 0; i < FC_WORDS; i++) { + u32 fc; + + fc = brcmnand_read_fc(ctrl, i); + /* * Flash cache is big endian for parameter pages, at * least on STB SoCs */ - flash_cache[i] = be32_to_cpu(brcmnand_read_fc(ctrl, i)); + if (ctrl->parameter_page_big_endian) + flash_cache[i] = be32_to_cpu(fc); + else + flash_cache[i] = le32_to_cpu(fc); + }
@@ -2550,6 +2559,10 @@ int brcmnand_probe(struct udevice *dev, struct brcmnand_soc *soc) nand_hw_control_init(&ctrl->controller); INIT_LIST_HEAD(&ctrl->host_list);
+ /* Is parameter page in big endian ? */ + ctrl->parameter_page_big_endian = + dev_read_u32_default(dev, "parameter-page-big-endian", 1); + /* NAND register range */ #ifndef __UBOOT__ res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
The option write-protect may only change on the kernel command line, we add a property in the device tree to be more flexible.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- drivers/mtd/nand/raw/brcmnand/brcmnand.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mtd/nand/raw/brcmnand/brcmnand.c b/drivers/mtd/nand/raw/brcmnand/brcmnand.c index e333320..faa6da4 100644 --- a/drivers/mtd/nand/raw/brcmnand/brcmnand.c +++ b/drivers/mtd/nand/raw/brcmnand/brcmnand.c @@ -2671,6 +2671,9 @@ int brcmnand_probe(struct udevice *dev, struct brcmnand_soc *soc) /* Disable XOR addressing */ brcmnand_rmw_reg(ctrl, BRCMNAND_CS_XOR, 0xff, 0, 0);
+ /* Read the write-protect configuration in the device tree */ + wp_on = dev_read_u32_default(dev, "write-protect", wp_on); + if (ctrl->features & BRCMNAND_HAS_WP) { /* Permanently disable write protection */ if (wp_on == 2)
Add the nand controller in the bcm6838 device tree.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- arch/mips/dts/brcm,bcm6838.dtsi | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/mips/dts/brcm,bcm6838.dtsi b/arch/mips/dts/brcm,bcm6838.dtsi index b6f9559..2b7baf9 100644 --- a/arch/mips/dts/brcm,bcm6838.dtsi +++ b/arch/mips/dts/brcm,bcm6838.dtsi @@ -98,5 +98,18 @@
status = "disabled"; }; + + nand: nand-controller@14e02200 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "brcm,nand-bcm6838", + "brcm,brcmnand-v5.0", + "brcm,brcmnand"; + reg-names = "nand", "nand-int-base", "nand-cache"; + reg = <0x14e02200 0x180>, + <0x14e000f0 0x10>, + <0x14e02600 0x180>; + status = "disabled"; + }; }; };
Enable the nand controller in the device tree of the board bcm96838gerg.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- arch/mips/dts/brcm,bcm968380gerg.dts | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/mips/dts/brcm,bcm968380gerg.dts b/arch/mips/dts/brcm,bcm968380gerg.dts index 513045e..a070adf 100644 --- a/arch/mips/dts/brcm,bcm968380gerg.dts +++ b/arch/mips/dts/brcm,bcm968380gerg.dts @@ -38,3 +38,15 @@ label = "bcm968380gerg:green:usb"; }; }; + +&nand { + status = "okay"; + + nandcs@0 { + compatible = "brcm,nandcs"; + reg = <0>; + nand-ecc-strength = <4>; + nand-ecc-step-size = <512>; + brcm,nand-oob-sector-size = <16>; + }; +};
Enable the nand support (driver and command) in the configuration of the board bcm96838gerg.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- configs/bcm968380gerg_ram_defconfig | 7 +++++++ include/configs/broadcom_bcm968380gerg.h | 7 +++++++ 2 files changed, 14 insertions(+)
diff --git a/configs/bcm968380gerg_ram_defconfig b/configs/bcm968380gerg_ram_defconfig index 61661bd..9d42d59 100644 --- a/configs/bcm968380gerg_ram_defconfig +++ b/configs/bcm968380gerg_ram_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_LICENSE=y CONFIG_CMD_MEMINFO=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_NAND=y # CONFIG_CMD_MISC is not set CONFIG_DEFAULT_DEVICE_TREE="brcm,bcm968380gerg" # CONFIG_NET is not set @@ -34,6 +35,12 @@ CONFIG_DM_GPIO=y CONFIG_LED=y CONFIG_LED_BCM6328=y CONFIG_LED_BLINK=y +CONFIG_MTD=y +CONFIG_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_6838=y +CONFIG_SPI_FLASH=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHY=y CONFIG_BCM6368_USBH_PHY=y CONFIG_PINCTRL=y diff --git a/include/configs/broadcom_bcm968380gerg.h b/include/configs/broadcom_bcm968380gerg.h index 6126a88..355f3ef 100644 --- a/include/configs/broadcom_bcm968380gerg.h +++ b/include/configs/broadcom_bcm968380gerg.h @@ -7,3 +7,10 @@ #include <configs/bmips_bcm6838.h>
#define CONFIG_ENV_SIZE (8 * 1024) + +#ifdef CONFIG_NAND +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_SELF_INIT +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_NAND_DRIVER_ECC_LAYOUT +#endif /* CONFIG_NAND */
Add the nand controller in the bcm6858 device tree.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- arch/arm/dts/bcm6858.dtsi | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/dts/bcm6858.dtsi b/arch/arm/dts/bcm6858.dtsi index 23b80c6..f48f93b 100644 --- a/arch/arm/dts/bcm6858.dtsi +++ b/arch/arm/dts/bcm6858.dtsi @@ -98,5 +98,18 @@ compatible = "wdt-reboot"; wdt = <&wdt1>; }; + + nand: nand-controller@ff801800 { + compatible = "brcm,nand-bcm6858", + "brcm,brcmnand-v5.0", + "brcm,brcmnand"; + reg-names = "nand", "nand-int-base", "nand-cache"; + reg = <0x0 0xff801800 0x0 0x180>, + <0x0 0xff802000 0x0 0x10>, + <0x0 0xff801c00 0x0 0x200>; + parameter-page-big-endian = <0>; + + status = "disabled"; + }; }; };
Enable the nand controller in the device tree of the board bcm968580xref.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- arch/arm/dts/bcm968580xref.dts | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/arm/dts/bcm968580xref.dts b/arch/arm/dts/bcm968580xref.dts index 0c59f94..2085c18 100644 --- a/arch/arm/dts/bcm968580xref.dts +++ b/arch/arm/dts/bcm968580xref.dts @@ -29,3 +29,18 @@ u-boot,dm-pre-reloc; status = "okay"; }; + +&nand { + status = "okay"; + write-protect = <0>; + #address-cells = <1>; + #size-cells = <0>; + + nandcs@0 { + compatible = "brcm,nandcs"; + reg = <0>; + nand-ecc-strength = <4>; + nand-ecc-step-size = <512>; + brcm,nand-oob-sector-size = <16>; + }; +};
Enable the nand support (driver and command) in the configuration of the board bcm968580xref.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- configs/bcm968580xref_ram_defconfig | 7 +++++++ include/configs/broadcom_bcm968580xref.h | 7 +++++++ 2 files changed, 14 insertions(+)
diff --git a/configs/bcm968580xref_ram_defconfig b/configs/bcm968580xref_ram_defconfig index e8cb3a0..737d726 100644 --- a/configs/bcm968580xref_ram_defconfig +++ b/configs/bcm968580xref_ram_defconfig @@ -15,6 +15,9 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTEFI_SELFTEST=y +CONFIG_CMD_MTD=y +CONFIG_CMD_NAND=y +CONFIG_CMD_PART=y CONFIG_DOS_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y @@ -23,6 +26,10 @@ CONFIG_DEFAULT_DEVICE_TREE="bcm968580xref" CONFIG_BLK=y CONFIG_CLK=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_6858=y CONFIG_SPECIFY_CONSOLE_INDEX=y # CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_CONS_INDEX=0 diff --git a/include/configs/broadcom_bcm968580xref.h b/include/configs/broadcom_bcm968580xref.h index 1c0945e..52b4f55 100644 --- a/include/configs/broadcom_bcm968580xref.h +++ b/include/configs/broadcom_bcm968580xref.h @@ -29,6 +29,13 @@
#define CONFIG_SKIP_LOWLEVEL_INIT
+#ifdef CONFIG_NAND +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_SELF_INIT +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_NAND_DRIVER_ECC_LAYOUT +#endif /* CONFIG_NAND */ + /* * 968580xref */
Add the nand controller in the bcm63158 device tree.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- arch/arm/dts/bcm63158.dtsi | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/dts/bcm63158.dtsi b/arch/arm/dts/bcm63158.dtsi index 6a3fbc9..12ade2a 100644 --- a/arch/arm/dts/bcm63158.dtsi +++ b/arch/arm/dts/bcm63158.dtsi @@ -98,5 +98,18 @@ compatible = "wdt-reboot"; wdt = <&wdt1>; }; + + nand: nand-controller@ff801800 { + compatible = "brcm,nand-bcm63158", + "brcm,brcmnand-v5.0", + "brcm,brcmnand"; + reg-names = "nand", "nand-int-base", "nand-cache"; + reg = <0x0 0xff801800 0x0 0x180>, + <0x0 0xff802000 0x0 0x10>, + <0x0 0xff801c00 0x0 0x200>; + parameter-page-big-endian = <0>; + + status = "disabled"; + }; }; };
Enable the nand controller in the device tree of the board bcm963158.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- arch/arm/dts/bcm963158.dts | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/arm/dts/bcm963158.dts b/arch/arm/dts/bcm963158.dts index dc5afb5..abb44a6 100644 --- a/arch/arm/dts/bcm963158.dts +++ b/arch/arm/dts/bcm963158.dts @@ -29,3 +29,18 @@ u-boot,dm-pre-reloc; status = "okay"; }; + +&nand { + status = "okay"; + write-protect = <0>; + #address-cells = <1>; + #size-cells = <0>; + + nandcs@0 { + compatible = "brcm,nandcs"; + reg = <0>; + nand-ecc-strength = <4>; + nand-ecc-step-size = <512>; + brcm,nand-oob-sector-size = <16>; + }; +};
Enable the nand support (driver and command) in the configuration of the board bcm963158.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- configs/bcm963158_ram_defconfig | 6 ++++++ include/configs/broadcom_bcm963158.h | 7 +++++++ 2 files changed, 13 insertions(+)
diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index fc55e98..248044a 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_BOOTEFI_SELFTEST=y # CONFIG_CMD_LZMADEC is not set # CONFIG_CMD_UNZIP is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MTD=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y CONFIG_DOS_PARTITION=y CONFIG_ISO_PARTITION=y @@ -29,6 +31,10 @@ CONFIG_DEFAULT_DEVICE_TREE="bcm963158" CONFIG_BLK=y CONFIG_CLK=y # CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_63158=y CONFIG_SPECIFY_CONSOLE_INDEX=y # CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_CONS_INDEX=0 diff --git a/include/configs/broadcom_bcm963158.h b/include/configs/broadcom_bcm963158.h index 5834e1e..2de6f21 100644 --- a/include/configs/broadcom_bcm963158.h +++ b/include/configs/broadcom_bcm963158.h @@ -30,6 +30,13 @@
+#ifdef CONFIG_NAND +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_SELF_INIT +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_NAND_DRIVER_ECC_LAYOUT +#endif /* CONFIG_NAND */ + /* * bcm963158 */
Philippe Reynes
