[U-Boot] [PATCH] dm: usb: fix USB Ethernet without CONFIG_DM_ETH regression
The following commit enforces CONFIG_DM_ETH for USB Ethernet which breaks any board using CONFIG_USB_HOST_ETHER without CONFIG_DM which this patch fixes.
commit 69559093f6173dcfcb041df0995063bdbd07d49b dm: usb: Avoid using USB ethernet with CONFIG_DM_USB and no DM_ETH
Tested on Colibri T20/T30 as well as Apalis T30 with CONFIG_USB_HOST_ETHER and CONFIG_USB_ETHER_ASIX enabled and a LevelOne USB-0301 ASIX AX88772 dongle.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com --- Note: Enabling CONFIG_DM_ETH (which BTW does not even compile without adding some more errno.h includes to asix.c and usb_ether.c) doesn't quite work neither due to reception issues which I will report in separate emails/patches.
common/cmd_usb.c | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/common/cmd_usb.c b/common/cmd_usb.c index 0ade775..6874af7 100644 --- a/common/cmd_usb.c +++ b/common/cmd_usb.c @@ -530,13 +530,16 @@ static void do_usb_start(void) /* try to recognize storage devices immediately */ usb_stor_curr_dev = usb_stor_scan(1); #endif +#endif #ifdef CONFIG_USB_HOST_ETHER # ifdef CONFIG_DM_ETH -# error "You must use CONFIG_DM_USB if you want to use CONFIG_USB_HOST_ETHER with CONFIG_DM_ETH" -# endif +# ifndef CONFIG_DM_USB +# error "You must use CONFIG_DM_USB if you want to use CONFIG_USB_HOST_ETHER with CONFIG_DM_ETH" +# endif +# else /* try to recognize ethernet devices immediately */ usb_ether_curr_dev = usb_host_eth_scan(1); -#endif +# endif #endif #ifdef CONFIG_USB_KEYBOARD drv_usb_kbd_init();
Simon, do you have any comment on this particular patch please ?
Best regards, Marek Vasut
I think this commit message might need a few tweaks. This is not a regression as mentioned elsewhere. Also I don't thing it means CONFIG_DM here. Maybe CONFIG_DM_USB?
There was a report that this does in fact not work ("CONFIG_DM_ETH USB_ETHER_ASIX Reception Issue on Tegra"). does this patch fix that problem? I'm not sure how but the above suggests that it does.
diff --git a/common/cmd_usb.c b/common/cmd_usb.c index 0ade775..6874af7 100644 --- a/common/cmd_usb.c +++ b/common/cmd_usb.c @@ -530,13 +530,16 @@ static void do_usb_start(void) /* try to recognize storage devices immediately */ usb_stor_curr_dev = usb_stor_scan(1); #endif +#endif #ifdef CONFIG_USB_HOST_ETHER # ifdef CONFIG_DM_ETH -# error "You must use CONFIG_DM_USB if you want to use CONFIG_USB_HOST_ETHER with CONFIG_DM_ETH" -# endif +# ifndef CONFIG_DM_USB +# error "You must use CONFIG_DM_USB if you want to use CONFIG_USB_HOST_ETHER with CONFIG_DM_ETH" +# endif +# else /* try to recognize ethernet devices immediately */ usb_ether_curr_dev = usb_host_eth_scan(1); -#endif +# endif #endif #ifdef CONFIG_USB_KEYBOARD drv_usb_kbd_init(); -- 2.4.3
The logic here was really ugly (sorry!). However even so I'm struggling to understand what this patch actually changes. It seems that the #error is activated:
#if !CONFIG_DM_USB && CONFIG_USB_HOST_ETHER && CONFIG_DM_ETH
which looks the same as before.
So overall I'm a bit confused. Hoping we can figure this out soon. The patches to enable driver model USB Ethernet and Asix were applied a few weeks ago and there may well still be problems. As I mentioned I did not test this on Tegra hardware unfortuantely.
Yes you are right. It's about DM_USB of course, sorry.
No, those are two entirely different issues. Fact is right now almost nobody defines DM_ETH but e.g. on Tegra DM_USB is set which currently renders on-module Ethernet defunct on both Colibri T20 as well as Colibri T30. This patch fixes just that and Ethernet will work again.
No, it's not only about the error message. You missed the usb_host_eth_scan() call! Without that being called in the old non-DM_ETH case it simply won't work! Which is the case in current mainline U-Boot on Colibri T20/T30.
As mentioned before. That's a different story but as DM_ETH is not currently enabled on any Tegras I consider this a secondary issue
Marcel Ziswiler
