[PATCH v2] imx8mn-venice-u-boot: Fix broken boot
When the imx8mn.dtsi file was pulled in from Linux, the UARTs were moved into an spba sub-node which wasn't being included in the SPL device tree. This meant the references to the UART weren't being handled properly and when booting the system would constantly reboot. Fix this by adding the spba node to the spl device tree to restore normal booting.
Based on the patch from Adam Ford for the imx8mn-beacon-kit-u-boot board.
Fixes: 4e5114daf9eb ("imx8mn: synchronise device tree with linux") Signed-off-by: Fabio Estevam festevam@denx.de --- Changes since v1:
- Fix typo in commit log: imx8mm.dtsi--> imx8mn.dtsi
Hi Tim,
Could you please test this patch?
It fixes boot regression on imx8mn-evk and imx8mn-beacon.
arch/arm/dts/imx8mn-venice-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi index 9fb3871452..9debf9675d 100644 --- a/arch/arm/dts/imx8mn-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -20,6 +20,10 @@ u-boot,dm-spl; };
+&spba1 { + u-boot,dm-spl; +}; + &clk { u-boot,dm-spl; u-boot,dm-pre-reloc;
Fabio Estevam
