[PATCH] rtc: pcf2127: fix uninitialized variable msg
Fix uninitialized variable msg
Signed-off-by: Biwen Li biwen.li@nxp.com --- drivers/rtc/pcf2127.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/rtc/pcf2127.c b/drivers/rtc/pcf2127.c index f695350..58c4ee9 100644 --- a/drivers/rtc/pcf2127.c +++ b/drivers/rtc/pcf2127.c @@ -1,6 +1,7 @@ /* * Copyright (C) 2016 by NXP Semiconductors Inc. * Date & Time support for PCF2127 RTC + * Copyright 2020 NXP */
/* #define DEBUG */ @@ -26,7 +27,7 @@ static int pcf2127_read_reg(struct udevice *dev, uint offset, u8 *buffer, int len) { struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); - struct i2c_msg msg; + struct i2c_msg msg = {0}; int ret;
/* Set the address of the start register to be read */
I assume it's the
msg.flags |= I2C_M_RD;
line that is warned about (please include such info)? Isn't the right fix to replace that by
msg.flags = I2C_M_RD;
Rasmus
struct i2c_msg msg;
struct i2c_msg msg = {0}; int ret; /* Set the address of the start register to be read */
I assume it's the
Two lines("struct i2c msg;" and "msg.flags |= I2C_M_RD") are warned by build system. Initializing msg variable will be better.
Rasmus
struct i2c_msg msg;
I assume it's the
What? That doesn't make sense. Perhaps your compiler is just friendly enough to show you the declaration of the struct i2c_msg, but clearly declaring an automatic variable without initializing it is not, by itself, wrong. Otherwise "int ret;" in that very same function should be warned about, and 100000 other instances in any code base written in C.
Please show the exact output from the compiler and the compiler version.
No, understanding the cause of the warning and fixing that is clearly better.
Rasmus
struct i2c_msg msg;
I assume it's the
build system.
Sorry, acctually not build system. It's code analysis tool. Such as: Declaring variable msg without initializer. (struce i2c_msg msg;) Uninitialized scalar variable (UNINIT), uninit_use: Using uninitialized value msg.flags.(msg.flags |= I2C_M_RD)
Rasmus
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Biwen Li (OSS) Sent: Friday, July 10, 2020 7:24 AM To: Rasmus Villemoes rasmus.villemoes@prevas.dk; Biwen Li (OSS) biwen.li@oss.nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Priyanka Jain priyanka.jain@nxp.com Cc: Jiafei Pan jiafei.pan@nxp.com; u-boot@lists.denx.de Subject: RE: [EXT] Re: [PATCH] rtc: pcf2127: fix uninitialized variable msg
struct i2c_msg msg;
I assume it's the
build system.
Can you please update subject or description stating that you are fixing issue reported by static analysis tool coverity
Thanks Priyanka
Rasmus
participants (5)
Biwen Li
Biwen Li
Biwen Li (OSS)
Priyanka Jain (OSS)
Rasmus Villemoes
