[U-Boot] [PATCH V2]omap3: Add RAM configuration independent of x-loader or CH
V2: Some settings in mem.h were wrong - correct now.
OMAP3 relied on the memory config done by X-loader or Configuration Header. This has to be reworked for the implementation of a SPL. This patch configures RAM bank 0 if CONFIG_PRELOADER is set. Settings for Micron-RAM used by devkit8000 are added to mem.h
Signed-off-by: Simon Schwarz simonschwarzcor@gmail.com Cc: Sandeep Paulraj s-paulraj@ti.com -- diff --git a/arch/arm/cpu/armv7/omap3/sdrc.c b/arch/arm/cpu/armv7/omap3/sdrc.c index 2a7970b..3ea0842 100644 --- a/arch/arm/cpu/armv7/omap3/sdrc.c +++ b/arch/arm/cpu/armv7/omap3/sdrc.c @@ -8,6 +8,8 @@ * Copyright (C) 2004-2010 * Texas Instruments Incorporated - http://www.ti.com/ * + * Copyright (C) 2011 Simon Schwarz simonschwarzcor@gmail.com + * * Author : * Vaibhav Hiremath hvaibhav@ti.com * @@ -133,13 +135,38 @@ void do_sdrc_init(u32 cs, u32 early) sdelay(0x20000); }
+#ifdef CONFIG_PRELOADER + /* If we use a SPL there is no x-loader nor config header so we have + * to do the job ourselfs + */ + if (cs == CS0) { + sdrc_actim_base0 = (struct sdrc_actim *)SDRC_ACTIM_CTRL0_BASE; + + /* General SDRC config */ + writel(V_MCFG, &sdrc_base->cs[cs].mcfg); + writel(V_RFR_CTRL, &sdrc_base->cs[cs].rfr_ctrl); + + /* AC timings */ + writel(V_ACTIMA_165, &sdrc_actim_base0->ctrla); + writel(V_ACTIMB_165, &sdrc_actim_base0->ctrlb); + + /* Initialize */ + writel(CMD_NOP, &sdrc_base->cs[cs].manual); + writel(CMD_PRECHARGE, &sdrc_base->cs[cs].manual); + writel(CMD_AUTOREFRESH, &sdrc_base->cs[cs].manual); + writel(CMD_AUTOREFRESH, &sdrc_base->cs[cs].manual); + + writel(V_MR, &sdrc_base->cs[cs].mr); + } +#endif + /* * SDRC timings are set up by x-load or config header * We don't need to redo them here. * Older x-loads configure only CS0 * configure CS1 to handle this ommission */ - if (cs) { + if (cs == CS1) { sdrc_actim_base0 = (struct sdrc_actim *)SDRC_ACTIM_CTRL0_BASE; sdrc_actim_base1 = (struct sdrc_actim *)SDRC_ACTIM_CTRL1_BASE; writel(readl(&sdrc_base->cs[CS0].mcfg), diff --git a/arch/arm/include/asm/arch-omap3/mem.h b/arch/arm/include/asm/arch-omap3/mem.h index f165949..8b39745 100644 --- a/arch/arm/include/asm/arch-omap3/mem.h +++ b/arch/arm/include/asm/arch-omap3/mem.h @@ -128,6 +128,33 @@ enum { (MICRON_XSR_165 << 0) | (MICRON_TXP_165 << 8) | \ (MICRON_TWTR_165 << 16))
+#define MICRON_RAMTYPE 0x1 +#define MICRON_DDRTYPE 0x0 +#define MICRON_DEEPPD 0x1 +#define MICRON_B32NOT16 0x1 +#define MICRON_BANKALLOCATION 0x2 +#define MICRON_RAMSIZE ((PHYS_SDRAM_1_SIZE/(1024*1024))/2) +#define MICRON_ADDRMUXLEGACY 0x1 +#define MICRON_CASWIDTH 0x5 +#define MICRON_RASWIDTH 0x2 +#define MICRON_LOCKSTATUS 0x0 +#define MICRON_V_MCFG ((MICRON_LOCKSTATUS << 30) | (MICRON_RASWIDTH << 24) | \ + (MICRON_CASWIDTH << 20) | (MICRON_ADDRMUXLEGACY << 19) | \ + (MICRON_RAMSIZE << 8) | (MICRON_BANKALLOCATION << 6) | \ + (MICRON_B32NOT16 << 4) | (MICRON_DEEPPD << 3) | \ + (MICRON_DDRTYPE << 2) | (MICRON_RAMTYPE)) + +#define MICRON_ARCV 2030 +#define MICRON_ARE 0x1 +#define MICRON_V_RFR_CTRL ((MICRON_ARCV << 8) | (MICRON_ARE)) + +#define MICRON_BL 0x2 +#define MICRON_SIL 0x0 +#define MICRON_CASL 0x3 +#define MICRON_WBST 0x0 +#define MICRON_V_MR ((MICRON_WBST << 9) | (MICRON_CASL << 4) | \ + (MICRON_SIL << 3) | (MICRON_BL)) + /* * NUMONYX part of IGEP v2 (165MHz optimized) 6.06ns * ACTIMA @@ -171,10 +198,15 @@ enum { #define V_ACTIMA_165 INFINEON_V_ACTIMA_165 #define V_ACTIMB_165 INFINEON_V_ACTIMB_165 #endif + #ifdef CONFIG_OMAP3_MICRON_DDR -#define V_ACTIMA_165 MICRON_V_ACTIMA_165 -#define V_ACTIMB_165 MICRON_V_ACTIMB_165 +#define V_ACTIMA_165 MICRON_V_ACTIMA_165 +#define V_ACTIMB_165 MICRON_V_ACTIMB_165 +#define V_MCFG MICRON_V_MCFG +#define V_RFR_CTRL MICRON_V_RFR_CTRL +#define V_MR MICRON_V_MR #endif + #ifdef CONFIG_OMAP3_NUMONYX_DDR #define V_ACTIMA_165 NUMONYX_V_ACTIMA_165 #define V_ACTIMB_165 NUMONYX_V_ACTIMB_165 @@ -184,6 +216,10 @@ enum { #error "Please choose the right DDR type in config header" #endif
+#if defined(CONFIG_PRELOADER) && (!defined(V_MCFG) || !defined(V_RFR_CTRL)) +#error "Please choose the right DDR type in config header" +#endif + /* * GPMC settings - * Definitions is as per the following format
simonschwarzcorļ¼ googlemail.com
