[U-Boot] [PATCH] arm64: ls1043ardb: Add distro secure boot support
Enable validation of boot.scr script prior to its execution dependent on "secureboot" flag in environment. Disable fall back option to nor/qspi boot in case of secure boot. Also enable "secureboot=y" flag in environment for ARM based platforms instead of bootcmd.
Signed-off-by: Sumit Garg sumit.garg@nxp.com Tested-by: Vinitha Pillai vinitha.pillai@nxp.com --- board/freescale/common/fsl_chain_of_trust.c | 6 ++++++ configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + include/configs/ls1043a_common.h | 23 +++++++++++++++++++++-- 4 files changed, 29 insertions(+), 2 deletions(-)
diff --git a/board/freescale/common/fsl_chain_of_trust.c b/board/freescale/common/fsl_chain_of_trust.c index 438e781..609e2b2 100644 --- a/board/freescale/common/fsl_chain_of_trust.c +++ b/board/freescale/common/fsl_chain_of_trust.c @@ -80,7 +80,13 @@ int fsl_setenv_chain_of_trust(void) * bootcmd = CONFIG_CHAIN_BOOT_CMD (Validate and execute Boot script) */ setenv("bootdelay", "0"); + +#ifdef CONFIG_ARM + setenv("secureboot", "y"); +#else setenv("bootcmd", CONFIG_CHAIN_BOOT_CMD); +#endif + return 0; } #endif diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 861d49b..3f535cc 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -40,3 +40,4 @@ CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 5f9b21d..2d57e79 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -56,3 +56,4 @@ CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y +CONFIG_DISTRO_DEFAULTS=y diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index e8a756f..6e30427 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -282,6 +282,7 @@ "fdt_addr=0x64f00000\0" \ "kernel_addr=0x65000000\0" \ "scriptaddr=0x80000000\0" \ + "scripthdraddr=0x80080000\0" \ "fdtheader_addr_r=0x80100000\0" \ "kernelheader_addr_r=0x80200000\0" \ "kernel_addr_r=0x81000000\0" \ @@ -292,6 +293,7 @@ "mtdparts=" MTDPARTS_DEFAULT "\0" \ BOOTENV \ "boot_scripts=ls1043ardb_boot.scr\0" \ + "boot_script_hdr=hdr_ls1043ardb_bs.out\0" \ "scan_dev_for_boot_part=" \ "part list ${devtype} ${devnum} devplist; " \ "env exists devplist || setenv devplist 1; " \ @@ -302,6 +304,21 @@ "run scan_dev_for_boot; " \ "fi; " \ "done\0" \ + "scan_dev_for_boot=" \ + "echo Scanning ${devtype} " \ + "${devnum}:${distro_bootpart}...; " \ + "for prefix in ${boot_prefixes}; do " \ + "run scan_dev_for_scripts; " \ + "done;" \ + "\0" \ + "boot_a_script=" \ + "load ${devtype} ${devnum}:${distro_bootpart} " \ + "${scriptaddr} ${prefix}${script}; " \ + "env exists secureboot && load ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "${scripthdraddr} ${prefix}${boot_script_hdr} " \ + "&& esbc_validate ${scripthdraddr};" \ + "source ${scriptaddr}\0" \ "installer=load mmc 0:2 $load_addr " \ "/flex_installer_arm64.itb; " \ "bootm $load_addr#ls1043ardb\0" \ @@ -315,9 +332,11 @@
#undef CONFIG_BOOTCOMMAND #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) -#define CONFIG_BOOTCOMMAND "run distro_bootcmd;run qspi_bootcmd" +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; env exists secureboot" \ + "&& esbc_halt; run qspi_bootcmd;" #else -#define CONFIG_BOOTCOMMAND "run distro_bootcmd;run nor_bootcmd" +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; env exists secureboot" \ + "&& esbc_halt; run nor_bootcmd;" #endif
#define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \
-----Original Message----- From: Sumit Garg [mailto:sumit.garg@nxp.com] Sent: Monday, June 05, 2017 11:52 PM To: u-boot@lists.denx.de Cc: york sun york.sun@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Sumit Garg sumit.garg@nxp.com Subject: [PATCH] arm64: ls1043ardb: Add distro secure boot support
Forgot to add dependency on https://patchwork.ozlabs.org/patch/767352/ patch.
-Sumit
+#ifdef CONFIG_ARM
- setenv("secureboot", "y");
- "scripthdraddr=0x80080000\0" \ "fdtheader_addr_r=0x80100000\0" \ "kernelheader_addr_r=0x80200000\0" \ "kernel_addr_r=0x81000000\0" \
- "boot_script_hdr=hdr_ls1043ardb_bs.out\0" \ "scan_dev_for_boot_part=" \ "part list ${devtype} ${devnum} devplist; " \ "env exists devplist || setenv devplist 1; " \ @@ -302,6 +304,21 @@ "run scan_dev_for_boot; " \ "fi; " \ "done\0" \
- "scan_dev_for_boot=" \
"done;" \
"\0" \
- "boot_a_script=" \
"installer=load mmc 0:2 $load_addr " \ "/flex_installer_arm64.itb; " \ "bootm $load_addr#ls1043ardb\0" \"source ${scriptaddr}\0" \
#undef CONFIG_BOOTCOMMAND #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) - #define CONFIG_BOOTCOMMAND "run distro_bootcmd;run qspi_bootcmd" +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; env exists secureboot" \
#endif
#define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ -- 1.9.1
Can you add the steps to board README or a general README file to describe the steps to make distro boot on these boards? I don't think it is common knowledge yet. Last time when I tried on LS2080ARDB, it took me quite some effort to sort it out.
York
-----Original Message----- From: York Sun Sent: Wednesday, June 14, 2017 2:13 AM To: Sumit Garg sumit.garg@nxp.com; u-boot@lists.denx.de Cc: Ruchika Gupta ruchika.gupta@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Subject: Re: [PATCH] arm64: ls1043ardb: Add distro secure boot support
York
As per my understanding DISTRO boot is common feature in u-boot and we have enabled it on our boards. Please refer to "doc/README.distro".
Sumit
Applied to fsl-qoriq master. Thanks.
York
+#ifdef CONFIG_ARM
- return 0; } #endif
"done;" \
"\0" \
#else"&& esbc_halt; run qspi_bootcmd;"
#endif
Sumit,
I found an issue in a recent test. If distro boot is not setup, do you expect it to fail? Don't you want it to fall back to CONFIG_CHAIN_BOOT_CMD?
York
-----Original Message----- From: York Sun Sent: Friday, September 01, 2017 4:38 AM To: Sumit Garg sumit.garg@nxp.com; u-boot@lists.denx.de Cc: Ruchika Gupta ruchika.gupta@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Subject: Re: [PATCH] arm64: ls1043ardb: Add distro secure boot support
script)
+#ifdef CONFIG_ARM
"done;" \
"\0" \
qspi_bootcmd"
secureboot" \
secureboot" \
#endif
root=/dev/ram0 " \
Sumit,
York
You are correct about the issue. Actually I have to send a patch upstream to enable fallback option in case of LS1043, LS1046 and LS1021. But if you see on LS2088 and LS1088, fallback option is already there in upstream.
Sumit
Sumit Garg
York Sun
