[U-Boot] [PATCH] doc: fix file extension for flattened image tree blob
Different sections in the document suggest flattened image tree blob files have a file name extension of .itb. Fix the list of file extensions to reflect that.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- doc/uImage.FIT/source_file_format.txt | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/doc/uImage.FIT/source_file_format.txt b/doc/uImage.FIT/source_file_format.txt index 029f481..5d8cda4 100644 --- a/doc/uImage.FIT/source_file_format.txt +++ b/doc/uImage.FIT/source_file_format.txt @@ -55,7 +55,7 @@ FIT is formally a flattened device tree (in the libfdt meaning), which conforms to bindings defined in this document.
.its - image tree source -.fit - flattened image tree blob +.itb - flattened image tree blob
c) Image building procedure
Andreas Dannenberg
