[U-Boot] [PATCH/next] 74xx_7xx/mpc86xx/ppmc7xx: Fix do_reset() declaration
The following commit:
commit 882b7d726febe65579d6502c271412ecb05821d7 Author: Mike Frysinger vapier@gentoo.org Date: Wed Oct 20 03:41:17 2010 -0400
do_reset: unify duplicate prototypes
missed the 74xx_7xx and mpc86xx arches and the ppmc7xx board do_reset() functions which resulted in build errors such as: cpu.c:128: error: conflicting types for 'do_reset' include/command.h:102: error: previous declaration of 'do_reset' was here
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- arch/powerpc/cpu/74xx_7xx/cpu.c | 10 +++++++--- arch/powerpc/cpu/mpc86xx/cpu.c | 5 +++-- board/ppmc7xx/ppmc7xx.c | 7 +++++-- 3 files changed, 15 insertions(+), 7 deletions(-)
diff --git a/arch/powerpc/cpu/74xx_7xx/cpu.c b/arch/powerpc/cpu/74xx_7xx/cpu.c index ab6f11d..b6a31b4 100644 --- a/arch/powerpc/cpu/74xx_7xx/cpu.c +++ b/arch/powerpc/cpu/74xx_7xx/cpu.c @@ -234,8 +234,7 @@ soft_restart(unsigned long addr) !defined(CONFIG_ELPPC) && \ !defined(CONFIG_PPMC7XX) /* no generic way to do board reset. simply call soft_reset. */ -void -do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { ulong addr; /* flush and disable I/D cache */ @@ -263,7 +262,12 @@ do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) addr = CONFIG_SYS_MONITOR_BASE - sizeof (ulong); #endif soft_restart(addr); - while(1); /* not reached */ + + /* not reached */ + while(1) + ; + + return 1; } #endif
diff --git a/arch/powerpc/cpu/mpc86xx/cpu.c b/arch/powerpc/cpu/mpc86xx/cpu.c index 4e90fd2..ffcc8e6 100644 --- a/arch/powerpc/cpu/mpc86xx/cpu.c +++ b/arch/powerpc/cpu/mpc86xx/cpu.c @@ -123,8 +123,7 @@ checkcpu(void) }
-void -do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; volatile ccsr_gur_t *gur = &immap->im_gur; @@ -137,6 +136,8 @@ do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
while (1) ; + + return 1; }
diff --git a/board/ppmc7xx/ppmc7xx.c b/board/ppmc7xx/ppmc7xx.c index 5e7427f..432d366 100644 --- a/board/ppmc7xx/ppmc7xx.c +++ b/board/ppmc7xx/ppmc7xx.c @@ -88,7 +88,7 @@ int misc_init_r( void ) * * Shell command to reset the board. */ -void do_reset( cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[] ) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { printf( "Resetting...\n" );
@@ -100,7 +100,10 @@ void do_reset( cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[] ) _start();
/* Should never get here */ - while(1); + while(1) + ; + + return 1; }
int board_eth_init(bd_t *bis)
yeah, i just noticed this last nite too. when the patch was written, most boards were broken due to other common changes, so i had a hard time finding all the locations. examples/api/libgenwrap.c needs updating too, but we can post that in a diff chageset.
Signed-off-by: Mike Frysinger vapier@gentoo.org -mike
also, because this is [next], i'm not sure if wolfgang will want to squash these fixes into the existing change -mike
Dear Mike Frysinger,
git doesn't want to do that. Too many merges inbetween already.
np. if you want to pick up Peter's patch, i'll send another one for the api examples file. -mike
Please do. TIA.
Dear Peter Tyser,
Applied to "next", thanks.
Mike Frysinger
Peter Tyser
