[PATCH] stm32mp: Fix board_get_usable_ram_top()
When booting in EFI, lib/efi_loader/efi_memory.c calls board_get_usable_ram_top(0) which returns by default gd->ram_base + gd->ram_size which is the top of DDR.
In case of OPTEE boot, the top of DDR is currently reserved by OPTEE, board_get_usable_ram_top(0) must return an address outside OPTEE reserved memory.
gd->ram_top matches this constraint as it has already been initialized by substracting all DT reserved-memory (included OPTEE memory area).
Fixes: 92b611e8b003 ("stm32mp: correctly handle board_get_usable_ram_top(0)")
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com ---
arch/arm/mach-stm32mp/dram_init.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/dram_init.c b/arch/arm/mach-stm32mp/dram_init.c index 94f25f34e0..920b99bb68 100644 --- a/arch/arm/mach-stm32mp/dram_init.c +++ b/arch/arm/mach-stm32mp/dram_init.c @@ -47,7 +47,7 @@ ulong board_get_usable_ram_top(ulong total_size) struct lmb lmb;
if (!total_size) - return gd->ram_base + gd->ram_size; + return gd->ram_top;
/* found enough not-reserved memory to relocated U-Boot */ lmb_init(&lmb);
Hi Patrice,
if (!total_size)
return gd->ram_top;
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
Hi Patrice,
Applied to u-boot-stm/master, thanks!
Regards Patrick
Patrice Chotard
Patrick DELAUNAY
