[U-Boot-Users] [PATCH] (MIPS) Support for all dbau1x00 boards
Use different configurations for the boards from AMD ( dbau1000, dbau1100 and dbau1500 ).
Only tested for dbau1000, but compiles for all three.
Users with dbau1100 and dbau1500 should check that the cpu is compatible with au1000.
* Patch by Thomas Lange 14 Oct 2003 Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs
/Thomas
According to the Au1500 manual, differences between Au1500 and Au1000 are:
<quote>
The Au1500 processor does not have the following peripherals that are present on the Au1000 processor:
IrDA UART1 UART2 SSI I2S
The Au1500 processor has added these functions not present on the Au1000 processor:
PCI 2.2 compliant interface Genereal-purpose I/O (GPIO): 32 total, 22 dedicated. (Au1000 has 32 total, 5 dedicated)
The NIC base address has changed from 0x010500000 to 0x11500000.
Some inputs to the interrupt controller have changed due to the addion/removal of blocks. Refer to the interrupt controller section for the Au1500 processor interrupt map.
A new CCA encoding has been added to the Au1500 processor. If CCA==4, all system bus accesses will be cacheline aligned, i.e. no cacheline wrapping is supported. When the PCI Cacheable Memory space is used, it must be mapped to CCA==4.
JTAG memory overlay of the PCI boot memory is not supported.
</quote>
As soon as my BDI2000 arrives I will begin more thorough testing on the Au1500.
Ed Okerson
- Patch by Thomas Lange 14 Oct 2003 Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs
Added, thanks. Sorry this took so long.
Ed Okerson
Thomas Lange
