[U-Boot] [PATCH] Add new Elpida memory configuration for ads5121
Rev 3 and earlier stay with Micron memory settings. Rev 4 and later will default to Elpida settings. CONFIG_ELPIDA forces these setting and will run slightly more slowly. CONFIG_MICRON will force Micron settings. If Micron settings are used, if a memory test fails, it will revert to the slower Elpida settings
Signed-off-by: Martha Marx mmarx@silicontkx.com --- board/ads5121/ads5121.c | 154 ++++++++++++++++++++++++++++++++++++--------- include/configs/ads5121.h | 41 +++++++----- 2 files changed, 150 insertions(+), 45 deletions(-)
diff --git a/board/ads5121/ads5121.c b/board/ads5121/ads5121.c index 6c40e94..deb4a74 100644 --- a/board/ads5121/ads5121.c +++ b/board/ads5121/ads5121.c @@ -120,13 +120,53 @@ phys_size_t initdram (int board_type) return msize; }
+int simple_mem_check() +{ + volatile u32 val; + volatile u32 *addr; + int i, j; + u32 save[32]; + + /* + * Very very simple non-destructive check for operational RAM. + */ + j = 0; + for (i = CONFIG_SYS_DDR_SIZE / sizeof (long); i > 0; i >>= 1) { + addr = (volatile u32 *) CONFIG_SYS_DDR_BASE + i; + save[j++] = *addr; + *addr = ~i; + } + + addr = (volatile u32 *) CONFIG_SYS_DDR_BASE; + save[j] = *addr; + *addr = 0xdeadbeef; + val = *addr; + *addr = save[j]; + + if (val != 0xdeadbeef) + return (0); + + for (i = 1; i <= CONFIG_SYS_DDR_SIZE / sizeof (long); i <<= 1) { + addr = (volatile u32 *) CONFIG_SYS_DDR_BASE + i; + val = *addr; + *addr = save[--j]; + if (val != ~i) + return (0); + } + return(1); +} + /* * fixed sdram init -- the board doesn't use memory modules that have serial presence * detect or similar mechanism for discovery of the DRAM settings */ + long int fixed_sdram (void) { + u32 try_elpida; volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; + ushort brd_rev = *(vu_short *) (CONFIG_SYS_CPLD_BASE + 0x00); + u32 msize = CONFIG_SYS_DDR_SIZE * 1024 * 1024; u32 msize_log2 = __ilog2 (msize); u32 i; @@ -174,41 +214,97 @@ long int fixed_sdram (void) im->mddrc.lut_table4_alternate_upper = CONFIG_SYS_MDDRCGRP_LUT4_AU; im->mddrc.lut_table4_alternate_lower = CONFIG_SYS_MDDRCGRP_LUT4_AL;
+#ifdef CONFIG_MICRON +/* forces Micron settings - on rev 4 boards will retry w/Elpida if necessary */ + try_elpida = 0; +#elif defined(CONFIG_ELPIDA) +/* forces Elpida settings w/slower CAS - works w/ both Micron and Elpida rev4 */ + try_elpida = 1; +#else + if (brd_rev >= 0x0400) + try_elpida = 1; + else + try_elpida = 0; +#endif +retry: + debug("Use %s Memory settings\n\t", try_elpida ? "Elpida" : "Micron"); + /* Initialize MDDRC */ - im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG; - im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0; - im->mddrc.ddr_time_config1 = CONFIG_SYS_MDDRC_TIME_CFG1; - im->mddrc.ddr_time_config2 = CONFIG_SYS_MDDRC_TIME_CFG2; + if (try_elpida) { + im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA; + im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0; + im->mddrc.ddr_time_config1 = CONFIG_SYS_MDDRC_TIME_CFG1_ELPIDA; + im->mddrc.ddr_time_config2 = CONFIG_SYS_MDDRC_TIME_CFG2_ELPIDA; + } else { + im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_MICRON; + im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0; + im->mddrc.ddr_time_config1 = CONFIG_SYS_MDDRC_TIME_CFG1_MICRON; + im->mddrc.ddr_time_config2 = CONFIG_SYS_MDDRC_TIME_CFG2_MICRON; + }
/* Initialize DDR */ for (i = 0; i < 10; i++) - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EM2; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EM2; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EM3; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EN_DLL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_OCD_DEFAULT; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + + if (try_elpida) { + /* Elpida init sequence - works for Micron too but runs slower */ + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM3; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EN_DLL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RES_DLL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_ELPIDA_INIT_DEV_OP; + udelay(200); + } else { + /* Micron init sequence */ + im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM3; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EN_DLL; + im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; + udelay(200); + } + im->mddrc.ddr_command = CONFIG_SYS_DDR_OCD_DEFAULT; + im->mddrc.ddr_command = CONFIG_SYS_DDR_OCD_EXIT; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + for (i = 0; i < 10; i++) + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; /* Start MDDRC */ im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0_RUN; - im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_RUN; + + if (try_elpida) + im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA_RUN; + else + im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_MICRON_RUN; + + if (try_elpida == 0) { + if (!simple_mem_check()) { + debug("Mem check failed\n\t"); + try_elpida += 1; + im->mddrc.ddr_sys_config = CONFIG_SYS_MDDRC_SYS_CFG_EN; + goto retry; + } + } + debug("Mem check %s\n\t", simple_mem_check()? "Passes":"Fails");
return msize; } diff --git a/include/configs/ads5121.h b/include/configs/ads5121.h index 8fda3f2..ab06276 100644 --- a/include/configs/ads5121.h +++ b/include/configs/ads5121.h @@ -130,29 +130,38 @@ * [09:05] DRAM tRP: * [04:00] DRAM tRPA */ +#define CONFIG_SYS_MDDRC_SYS_CFG_RUN ~(0x10000000) #ifdef CONFIG_ADS5121_REV2 -#define CONFIG_SYS_MDDRC_SYS_CFG 0xF8604A00 -#define CONFIG_SYS_MDDRC_SYS_CFG_RUN 0xE8604A00 -#define CONFIG_SYS_MDDRC_TIME_CFG1 0x54EC1168 -#define CONFIG_SYS_MDDRC_TIME_CFG2 0x35210864 +#define CONFIG_SYS_MDDRC_SYS_CFG_MICRON 0xF8604A00 +#define CONFIG_SYS_MDDRC_TIME_CFG1_MICRON 0x54EC1168 +#define CONFIG_SYS_MDDRC_TIME_CFG2_MICRON 0x35210864 #else -#define CONFIG_SYS_MDDRC_SYS_CFG 0xFA804A00 -#define CONFIG_SYS_MDDRC_SYS_CFG_RUN 0xEA804A00 -#define CONFIG_SYS_MDDRC_TIME_CFG1 0x68EC1168 -#define CONFIG_SYS_MDDRC_TIME_CFG2 0x34310864 +#define CONFIG_SYS_MDDRC_SYS_CFG_MICRON 0xFA804A00 +#define CONFIG_SYS_MDDRC_SYS_CFG_MICRON_RUN 0xEA804A00 +#define CONFIG_SYS_MDDRC_TIME_CFG1_MICRON 0x68EC1168 +#define CONFIG_SYS_MDDRC_TIME_CFG2_MICRON 0x34310864 #endif +#define CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA 0xFA802b40 +#define CONFIG_SYS_MDDRC_SYS_CFG_ELPIDA_RUN 0xEA802b40 +#define CONFIG_SYS_MDDRC_TIME_CFG1_ELPIDA 0x690e1189 +#define CONFIG_SYS_MDDRC_TIME_CFG2_ELPIDA 0x35410864 + #define CONFIG_SYS_MDDRC_SYS_CFG_EN 0xF0000000 +#define CONFIG_SYS_MDDRC_SYS_CFG_CLK_BIT (1 << 29) +#define CONFIG_SYS_MDDRC_SYS_CFG_CKE_BIT (1 << 30) #define CONFIG_SYS_MDDRC_TIME_CFG0 0x00003D2E #define CONFIG_SYS_MDDRC_TIME_CFG0_RUN 0x06183D2E - -#define CONFIG_SYS_MICRON_NOP 0x01380000 -#define CONFIG_SYS_MICRON_PCHG_ALL 0x01100400 -#define CONFIG_SYS_MICRON_EM2 0x01020000 -#define CONFIG_SYS_MICRON_EM3 0x01030000 -#define CONFIG_SYS_MICRON_EN_DLL 0x01010000 -#define CONFIG_SYS_MICRON_RFSH 0x01080000 #define CONFIG_SYS_MICRON_INIT_DEV_OP 0x01000432 -#define CONFIG_SYS_MICRON_OCD_DEFAULT 0x01010780 +#define CONFIG_SYS_ELPIDA_INIT_DEV_OP 0x01000842 +#define CONFIG_SYS_DDR_NOP 0x01380000 +#define CONFIG_SYS_DDR_PCHG_ALL 0x01100400 +#define CONFIG_SYS_DDR_EM2 0x01020000 +#define CONFIG_SYS_DDR_EM3 0x01030000 +#define CONFIG_SYS_DDR_EN_DLL 0x01010000 +#define CONFIG_SYS_DDR_RES_DLL 0x01000932 +#define CONFIG_SYS_DDR_RFSH 0x01080000 +#define CONFIG_SYS_DDR_OCD_DEFAULT 0x01010780 +#define CONFIG_SYS_DDR_OCD_EXIT 0x01010400
/* DDR Priority Manager Configuration */ #define CONFIG_SYS_MDDRCGRP_PM_CFG1 0x00077777
Dear Martha,
- volatile u32 val;
- volatile u32 *addr;
- int i, j;
- u32 save[32];
- j = 0;
- for (i = CONFIG_SYS_DDR_SIZE / sizeof (long); i > 0; i >>= 1) {
save[j++] = *addr;
*addr = ~i;
- addr = (volatile u32 *) CONFIG_SYS_DDR_BASE;
- save[j] = *addr;
- *addr = 0xdeadbeef;
- val = *addr;
- *addr = save[j];
- if (val != 0xdeadbeef)
return (0);
- for (i = 1; i <= CONFIG_SYS_DDR_SIZE / sizeof (long); i <<= 1) {
val = *addr;
*addr = save[--j];
if (val != ~i)
return (0);
- return(1);
We already have that code, just a bit more general and non-destructive, as function get_ram_size() in "common/memsize.c".
Please do not reinvent the wheel - use the existing code instead (ideally this should also be used to auto-adjust the RAM size on the boards).
- fixed sdram init -- the board doesn't use memory modules that have serial presence
- detect or similar mechanism for discovery of the DRAM settings
Please do not add random white space changes.
- u32 try_elpida; volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR;
- ushort brd_rev = *(vu_short *) (CONFIG_SYS_CPLD_BASE + 0x00);
- u32 msize = CONFIG_SYS_DDR_SIZE * 1024 * 1024; u32 msize_log2 = __ilog2 (msize); u32 i;
- try_elpida = 0;
- try_elpida = 1;
+#else
- if (brd_rev >= 0x0400)
try_elpida = 1;
- else
try_elpida = 0;
+#endif +retry:
Please keep the code simple. As discussed by PM before, please drop the config stuff and support for old boards that long have reached EOL.
Old boards can be used with the existing U-Boot; here in mainline we should support board rev. 4.x and higher only.
- debug("Use %s Memory settings\n\t", try_elpida ? "Elpida" : "Micron");
- /* Initialize MDDRC */
- if (try_elpida) {
- } else {
Drop this. ALways use the (more relaxed?) Elpida settings.
- im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL;
- im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP;
- im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH;
As mentioned a couple times before, we should start with an initial patch that performas a global rename to get rid of the (inappropiate) CONFIG_SYS_ names here.
Thanks.
Martha Marx
