[PATCH 0/4] dm: Print device name in dev_xxx() like Linux
This series adds some additional information to dev_dbg. With this series, and the following options applied in addition to sandbox_defconfig
CONFIG_LOGLEVEL=8 CONFIG_LOG=n CONFIG_CMD_LOG=n CONFIG_CMD_TPM=n
the output of U-Boot is
U-Boot 2020.10-rc4-00006-g19b641dddd-dirty (Sep 12 2020 - 18:15:00 -0400)
Model: sandbox DRAM: 128 MiB pinctrl-gpio sandbox_pinctrl_gpio: set_state_simple op missing leds gpio_led: set_state_simple op missing default_on gpio_led: set_state_simple op missing base-gpios sandbox_gpio: set_state_simple op missing default_off gpio_led: set_state_simple op missing wdt@0 wdt_sandbox: set_state_simple op missing WDT: Started with servicing (60s timeout) MMC: mmc0 mmc_sandbox: set_state_simple op missing mmc1 mmc_sandbox: set_state_simple op missing mmc2 mmc_sandbox: set_state_simple op missing mmc2: 2 (SD), mmc1: 1 (SD), mmc0: 0 (SD) lcd sandbox_lcd_sdl: set_state_simple op missing In: serial Out: vidconsole Err: vidconsole Model: sandbox hog_input_active_low gpio_hog: set_state_simple op missing hog_input_active_high gpio_hog: set_state_simple op missing hog_output_low gpio_hog: set_state_simple op missing hog_output_high gpio_hog: set_state_simple op missing cros-ec google_cros_ec_sandbox: set_state_simple op missing SCSI: pci_ep pci_ep_sandbox: set_state_simple op missing Net: eth@10002000 eth_sandbox: set_state_simple op missing eth0: eth@10002000eth@10003000 eth_sandbox: set_state_simple op missing , eth5: eth@10003000sbe5 eth_sandbox: set_state_simple op missing , eth3: sbe5eth@10004000 eth_sandbox: set_state_simple op missing , eth6: eth@10004000 bootcount@0 bootcount-rtc: set_state_simple op missing i2c@0 i2c_sandbox: set_state_simple op missing rtc@61 rtc-sandbox: set_state_simple op missing emul i2c_emul_parent_drv: set_state_simple op missing emull sandbox_i2c_rtc_emul: set_state_simple op missing Hit any key to stop autoboot:
When using CONFIG_LOG the output of U-Boot is too verbose to fit in this email. Note that there is a soft dependency on [1] if you would like to test this patch with CONFIG_LOG and a higher LOG_LEVEL than LOGL_INFO.
[1] https://patchwork.ozlabs.org/project/uboot/list/?series=201343
Sean Anderson (4): remoteproc: Remove unused function rproc_elf_sanity_check net: mdio: Supply appropriate devices for dev_dgb calls dm: Use symbolic constants for log levels in dev_xxx() dm: Print device name in dev_xxx() like Linux
drivers/remoteproc/rproc-elf-loader.c | 16 ------ include/dm/device_compat.h | 75 +++++++++++++-------------- include/remoteproc.h | 13 ----- net/mdio-uclass.c | 4 +- 4 files changed, 39 insertions(+), 69 deletions(-)
This function is never used anywhere, and it also tries to log with a nonexistant device.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
drivers/remoteproc/rproc-elf-loader.c | 16 ---------------- include/remoteproc.h | 13 ------------- 2 files changed, 29 deletions(-)
diff --git a/drivers/remoteproc/rproc-elf-loader.c b/drivers/remoteproc/rproc-elf-loader.c index c464ecebb7..b185a6cafb 100644 --- a/drivers/remoteproc/rproc-elf-loader.c +++ b/drivers/remoteproc/rproc-elf-loader.c @@ -158,22 +158,6 @@ int rproc_elf64_sanity_check(ulong addr, ulong size) return 0; }
-/* Basic function to verify ELF image format */ -int rproc_elf_sanity_check(ulong addr, ulong size) -{ - Elf32_Ehdr *ehdr = (Elf32_Ehdr *)addr; - - if (!addr) { - dev_err(dev, "Invalid firmware address\n"); - return -EFAULT; - } - - if (ehdr->e_ident[EI_CLASS] == ELFCLASS64) - return rproc_elf64_sanity_check(addr, size); - else - return rproc_elf32_sanity_check(addr, size); -} - int rproc_elf32_load_image(struct udevice *dev, unsigned long addr, ulong size) { Elf32_Ehdr *ehdr; /* Elf header structure pointer */ diff --git a/include/remoteproc.h b/include/remoteproc.h index a903acb9b2..74d01723f6 100644 --- a/include/remoteproc.h +++ b/include/remoteproc.h @@ -226,19 +226,6 @@ int rproc_elf32_sanity_check(ulong addr, ulong size); */ int rproc_elf64_sanity_check(ulong addr, ulong size);
-/** - * rproc_elf_sanity_check() - Verify if an image is a valid ELF one - * - * Check if a valid ELF image exists at the given memory location. Auto - * detects ELF32/ELF64 and verifies basic ELF64/ELF32 format requirements - * like magic number and sections size. - * - * @addr: address of the image to verify - * @size: size of the image - * @return 0 if the image looks good, else appropriate error value. - */ -int rproc_elf_sanity_check(ulong addr, ulong size); - /** * rproc_elf32_load_image() - load an ELF32 image * @dev: device loading the ELF32 image
The name of the device we are working on is `ethdev` and not just `dev`.
net/mdio-uclass.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/net/mdio-uclass.c b/net/mdio-uclass.c index 66ee2e1976..b5e8e46512 100644 --- a/net/mdio-uclass.c +++ b/net/mdio-uclass.c @@ -145,7 +145,7 @@ static struct phy_device *dm_eth_connect_phy_handle(struct udevice *ethdev, break;
if (!ofnode_valid(phandle.node)) { - dev_dbg(dev, "can't find PHY node\n"); + dev_dbg(ethdev, "can't find PHY node\n"); return NULL; }
@@ -161,7 +161,7 @@ static struct phy_device *dm_eth_connect_phy_handle(struct udevice *ethdev, if (uclass_get_device_by_ofnode(UCLASS_MDIO, ofnode_get_parent(phandle.node), &mdiodev)) { - dev_dbg(dev, "can't find MDIO bus for node %s\n", + dev_dbg(ethdev, "can't find MDIO bus for node %s\n", ofnode_get_name(ofnode_get_parent(phandle.node))); return NULL; }
BTW I really like using 'dev' for the struct udevice if there is only one, and other names for other things (e.g. edev for Ethernet, udev for USB).
Yeah, I think it is only really necessary when disambiguating between several different devices. However, I am trying to make these patches as minimal as possible, so I would like to keep the variable names the same where possible.
--Sean
Hi Sean,
Yes definitely better the way you have the patches now.
This substitutes literal log levels with their symbolic constants.
include/dm/device_compat.h | 21 +++++++++++---------- 1 file changed, 11 insertions(+), 10 deletions(-)
diff --git a/include/dm/device_compat.h b/include/dm/device_compat.h index 3d8cd09f4c..7c14aa464d 100644 --- a/include/dm/device_compat.h +++ b/include/dm/device_compat.h @@ -10,6 +10,7 @@ #ifndef _DM_DEVICE_COMPAT_H #define _DM_DEVICE_COMPAT_H
+#include <log.h> #include <linux/compat.h>
/* @@ -48,28 +49,28 @@ })
#define dev_emerg(dev, fmt, ...) \ - __dev_printk(0, dev, fmt, ##__VA_ARGS__) + __dev_printk(LOGL_EMERG, dev, fmt, ##__VA_ARGS__) #define dev_alert(dev, fmt, ...) \ - __dev_printk(1, dev, fmt, ##__VA_ARGS__) + __dev_printk(LOGL_ALERT, dev, fmt, ##__VA_ARGS__) #define dev_crit(dev, fmt, ...) \ - __dev_printk(2, dev, fmt, ##__VA_ARGS__) + __dev_printk(LOGL_CRIT, dev, fmt, ##__VA_ARGS__) #define dev_err(dev, fmt, ...) \ - __dev_printk(3, dev, fmt, ##__VA_ARGS__) + __dev_printk(LOGL_ERR, dev, fmt, ##__VA_ARGS__) #define dev_warn(dev, fmt, ...) \ - __dev_printk(4, dev, fmt, ##__VA_ARGS__) + __dev_printk(LOGL_WARNING, dev, fmt, ##__VA_ARGS__) #define dev_notice(dev, fmt, ...) \ - __dev_printk(5, dev, fmt, ##__VA_ARGS__) + __dev_printk(LOGL_NOTICE, dev, fmt, ##__VA_ARGS__) #define dev_info(dev, fmt, ...) \ - __dev_printk(6, dev, fmt, ##__VA_ARGS__) + __dev_printk(LOGL_INFO, dev, fmt, ##__VA_ARGS__)
#ifdef DEBUG #define dev_dbg(dev, fmt, ...) \ - __dev_printk(7, dev, fmt, ##__VA_ARGS__) + __dev_printk(LOGL_DEBUG, dev, fmt, ##__VA_ARGS__) #else #define dev_dbg(dev, fmt, ...) \ ({ \ if (0) \ - __dev_printk(7, dev, fmt, ##__VA_ARGS__); \ + __dev_printk(LOGL_DEBUG, dev, fmt, ##__VA_ARGS__); \ }) #endif
@@ -79,7 +80,7 @@ #define dev_vdbg(dev, fmt, ...) \ ({ \ if (0) \ - __dev_printk(7, dev, fmt, ##__VA_ARGS__); \ + __dev_printk(LOGL_DEBUG, dev, fmt, ##__VA_ARGS__); \ }) #endif
This adorns messages generated by dev_xxx() with the device and driver names. It also redirects dev_xxx() to log() when it is available. The names of these functions very roughly take inspiration from Linux, but there is no deeper correlation.
include/dm/device_compat.h | 58 ++++++++++++++++++-------------------- 1 file changed, 28 insertions(+), 30 deletions(-)
diff --git a/include/dm/device_compat.h b/include/dm/device_compat.h index 7c14aa464d..5d18eb68fa 100644 --- a/include/dm/device_compat.h +++ b/include/dm/device_compat.h @@ -1,5 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com * Copyright (c) 2013 Google, Inc * * (C) Copyright 2012 @@ -33,19 +34,33 @@ #undef dev_warn #endif
-/* - * REVISIT: - * print device name like Linux - */ -#define dev_printk(dev, fmt, ...) \ -({ \ - printk(fmt, ##__VA_ARGS__); \ +#ifdef VERBOSE_DEBUG +#define _VERBOSE_DEBUG 1 +#else +#define _VERBOSE_DEBUG 0 +#endif + +#define dev_printk_emit(cat, level, fmt, ...) \ +({ \ + if ((_DEBUG && level == LOGL_DEBUG) || \ + (_VERBOSE_DEBUG && level == LOGL_DEBUG_CONTENT)) \ + printf(fmt, ##__VA_ARGS__); \ + else if (CONFIG_IS_ENABLED(LOG)) \ + log(cat, level, fmt, ##__VA_ARGS__); \ + else if (level < CONFIG_VAL(LOGLEVEL)) \ + printf(fmt, ##__VA_ARGS__); \ })
-#define __dev_printk(level, dev, fmt, ...) \ -({ \ - if (level < CONFIG_VAL(LOGLEVEL)) \ - dev_printk(dev, fmt, ##__VA_ARGS__); \ +#define __dev_printk(level, dev, fmt, ...) \ +({ \ + struct udevice *__dev = dev; \ + if (__dev) \ + dev_printk_emit(__dev->driver->id, level, "%s %s: " fmt, \ + __dev->name, __dev->driver->name, \ + ##__VA_ARGS__); \ + else \ + dev_printk_emit(LOG_CATEGORY, level, \ + "(NULL udevice *): " fmt, ##__VA_ARGS__); \ })
#define dev_emerg(dev, fmt, ...) \ @@ -62,26 +77,9 @@ __dev_printk(LOGL_NOTICE, dev, fmt, ##__VA_ARGS__) #define dev_info(dev, fmt, ...) \ __dev_printk(LOGL_INFO, dev, fmt, ##__VA_ARGS__) - -#ifdef DEBUG #define dev_dbg(dev, fmt, ...) \ __dev_printk(LOGL_DEBUG, dev, fmt, ##__VA_ARGS__) -#else -#define dev_dbg(dev, fmt, ...) \ -({ \ - if (0) \ - __dev_printk(LOGL_DEBUG, dev, fmt, ##__VA_ARGS__); \ -}) -#endif - -#ifdef VERBOSE_DEBUG -#define dev_vdbg dev_dbg -#else -#define dev_vdbg(dev, fmt, ...) \ -({ \ - if (0) \ - __dev_printk(LOGL_DEBUG, dev, fmt, ##__VA_ARGS__); \ -}) -#endif +#define dev_vdbg(dev, fmt, ...) \ + __dev_printk(LOGL_DEBUG_CONTENT, dev, fmt, ##__VA_ARGS__)
#endif
In my haste I may have forgotten to run CI and make many more patches like the first two to fix drivers calling a dev_ log function without an actual device. So this series breaks a lot of things at the moment [1]. Consider it an RFC I guess for after I fix all those build failures.
--Sean
[1] https://dev.azure.com/seanga2/u-boot/_build/results?buildId=30&view=logs...
Sean Anderson
