[U-Boot-Users] [PATCH 1/1] Added preliminary support for the AT91SAM9263-EK. The following has been tested:
diff --git a/Makefile b/Makefile index 4688a26..36feb00 100644 --- a/Makefile +++ b/Makefile @@ -2347,6 +2347,9 @@ at91cap9adk_config : unconfig at91sam9260ek_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs at91sam9260ek atmel at91sam9
+at91sam9263ek_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs at91sam9263ek atmel at91sam9 + ######################################################################## ## ARM Integrator boards - see doc/README-integrator for more info. integratorap_config \ diff --git a/board/atmel/at91sam9263ek/Makefile b/board/atmel/at91sam9263ek/Makefile new file mode 100644 index 0000000..ca87a4c --- /dev/null +++ b/board/atmel/at91sam9263ek/Makefile @@ -0,0 +1,53 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd <at> denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += at91sam9263ek.o +COBJS-y += led.o +COBJS-y += partition.o +COBJS-$(CONFIG_CMD_NAND) += nand.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c new file mode 100644 index 0000000..b047209 --- /dev/null +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -0,0 +1,230 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91sam9263_matrix.h> +#include <asm/arch/at91sam926x_mc.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +static void at91sam9263ek_serial_hw_init(void) +{ +#ifdef CONFIG_USART0 + at91_set_A_periph(AT91_PIN_PA26, 1); /* TXD0 */ + at91_set_A_periph(AT91_PIN_PA27, 0); /* RXD0 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US0); +#endif + +#ifdef CONFIG_USART1 + at91_set_A_periph(AT91_PIN_PD0, 1); /* TXD1 */ + at91_set_A_periph(AT91_PIN_PD1, 0); /* RXD1 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US1); +#endif + +#ifdef CONFIG_USART2 + at91_set_A_periph(AT91_PIN_PD2, 1); /* TXD2 */ + at91_set_A_periph(AT91_PIN_PD3, 0); /* RXD2 */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_US2); +#endif + +#ifdef CONFIG_USART3 /* DBGU */ + at91_set_A_periph(AT91_PIN_PC30, 0); /* DRXD */ + at91_set_A_periph(AT91_PIN_PC31, 1); /* DTXD */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91_ID_SYS); +#endif +} + +#ifdef CONFIG_CMD_NAND +static void at91sam9263ek_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_CSA); + at91_sys_write(AT91_MATRIX_CSA, + csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | + AT91_SMC_DBW_8 | AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOA); + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOCDE); + + /* Configure RDY/BSY */ + at91_set_gpio_input(AT91_PIN_PA22, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(AT91_PIN_PD15, 1); +} +#endif + +#ifdef CONFIG_HAS_DATAFLASH +static void at91sam9263ek_spi_hw_init(void) +{ + at91_set_B_periph(AT91_PIN_PA5, 0); /* SPI0_NPCS0 */ + at91_set_B_periph(AT91_PIN_PA3, 0); /* SPI0_NPCS1 */ + + at91_set_B_periph(AT91_PIN_PA0, 0); /* SPI0_MISO */ + at91_set_B_periph(AT91_PIN_PA1, 0); /* SPI0_MOSI */ + at91_set_B_periph(AT91_PIN_PA2, 0); /* SPI0_SPCK */ + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_SPI0); +} +#endif + +#ifdef CONFIG_MACB +static void at91sam9263ek_macb_hw_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PC25) => PHY normal mode (not Test mode) + * RX0 (PE25) => PHY ADDR0 + * RX1 (PE26) => PHY ADDR1 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUDR); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUDR); + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + AT91_RSTC_ERSTL | (0x0D << 8) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Restore NRST value */ + /*at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + AT91_RSTC_ERSTL | (0x0 << 8) | + AT91_RSTC_URSTEN);*/ + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PC25), + pin_to_controller(AT91_PIN_PC0) + PIO_PUER); + writel(pin_to_mask(AT91_PIN_PE25) | + pin_to_mask(AT91_PIN_PE26), + pin_to_controller(AT91_PIN_PE0) + PIO_PUER); + + at91_set_A_periph(AT91_PIN_PE21, 0); /* ETXCK_EREFCK */ + at91_set_B_periph(AT91_PIN_PC25, 0); /* ERXDV */ + at91_set_A_periph(AT91_PIN_PE25, 0); /* ERX0 */ + at91_set_A_periph(AT91_PIN_PE26, 0); /* ERX1 */ + at91_set_A_periph(AT91_PIN_PE27, 0); /* ERXER */ + at91_set_A_periph(AT91_PIN_PE28, 0); /* ETXEN */ + at91_set_A_periph(AT91_PIN_PE23, 0); /* ETX0 */ + at91_set_A_periph(AT91_PIN_PE24, 0); /* ETX1 */ + at91_set_A_periph(AT91_PIN_PE30, 0); /* EMDIO */ + at91_set_A_periph(AT91_PIN_PE29, 0); /* EMDC */ + +#ifndef CONFIG_RMII + at91_set_A_periph(AT91_PIN_PE22, 0); /* ECRS */ + at91_set_B_periph(AT91_PIN_PC26, 0); /* ECOL */ + at91_set_B_periph(AT91_PIN_PC22, 0); /* ERX2 */ + at91_set_B_periph(AT91_PIN_PC23, 0); /* ERX3 */ + at91_set_B_periph(AT91_PIN_PC27, 0); /* ERXCK */ + at91_set_B_periph(AT91_PIN_PC20, 0); /* ETX2 */ + at91_set_B_periph(AT91_PIN_PC21, 0); /* ETX3 */ + at91_set_B_periph(AT91_PIN_PC24, 0); /* ETXER */ +#endif + +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of at91sam9263EK-Board */ + gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9263EK; + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91sam9263ek_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + at91sam9263ek_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91sam9263ek_spi_hw_init(); +#endif +#ifdef CONFIG_MACB + at91sam9263ek_macb_hw_init(); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif diff --git a/board/atmel/at91sam9263ek/config.mk b/board/atmel/at91sam9263ek/config.mk new file mode 100644 index 0000000..ff2cfd1 --- /dev/null +++ b/board/atmel/at91sam9263ek/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x23f00000 diff --git a/board/atmel/at91sam9263ek/led.c b/board/atmel/at91sam9263ek/led.c new file mode 100644 index 0000000..2a71d61 --- /dev/null +++ b/board/atmel/at91sam9263ek/led.c @@ -0,0 +1,78 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +#define POWER_LED AT91_PIN_PB7 /* this is the power led */ +#define USER1_LED AT91_PIN_PB8 /* this is the user led 1 */ +#define USER2_LED AT91_PIN_PC29 /* this is the user led 2 */ + +void power_LED_on(void) +{ + at91_set_gpio_value(POWER_LED, 1); +} + +void power_LED_off(void) +{ + at91_set_gpio_value(POWER_LED, 0); +} + +void user1_LED_on(void) +{ + at91_set_gpio_value(USER1_LED, 0); +} + +void user1_LED_off(void) +{ + at91_set_gpio_value(USER1_LED, 1); +} + +void user2_LED_on(void) +{ + at91_set_gpio_value(USER2_LED, 0); +} + +void user2_LED_off(void) +{ + at91_set_gpio_value(USER2_LED, 1); +} + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOB); + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOCDE); + + at91_set_gpio_output(POWER_LED, 1); + at91_set_gpio_output(USER1_LED, 1); + at91_set_gpio_output(USER2_LED, 1); + + at91_set_gpio_value(POWER_LED, 0); + at91_set_gpio_value(USER1_LED, 1); + at91_set_gpio_value(USER2_LED, 1); +} diff --git a/board/atmel/at91sam9263ek/nand.c b/board/atmel/at91sam9263ek/nand.c new file mode 100644 index 0000000..8c5b4b1 --- /dev/null +++ b/board/atmel/at91sam9263ek/nand.c @@ -0,0 +1,76 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2006 ATMEL Rousset, Lacressonniere Nicolas + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/gpio.h> +#include <asm/arch/at91_pio.h> + +#include <nand.h> + +/* + * hardware specific access to control-lines + */ +#define MASK_ALE (1 << 21) /* our ALE is AD21 */ +#define MASK_CLE (1 << 22) /* our CLE is AD22 */ + +static void at91sam9263ek_nand_hwcontrol(struct mtd_info *mtd, int cmd) +{ + struct nand_chip *this = mtd->priv; + ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; + + IO_ADDR_W &= ~(MASK_ALE|MASK_CLE); + switch (cmd) { + case NAND_CTL_SETCLE: + IO_ADDR_W |= MASK_CLE; + break; + case NAND_CTL_SETALE: + IO_ADDR_W |= MASK_ALE; + break; + case NAND_CTL_CLRNCE: + at91_set_gpio_value(AT91_PIN_PD15, 1); + break; + case NAND_CTL_SETNCE: + at91_set_gpio_value(AT91_PIN_PD15, 0); + break; + } + this->IO_ADDR_W = (void *) IO_ADDR_W; +} + +static int at91sam9263ek_nand_ready(struct mtd_info *mtd) +{ + return at91_get_gpio_value(AT91_PIN_PA22); +} + +int board_nand_init(struct nand_chip *nand) +{ + nand->eccmode = NAND_ECC_SOFT; + nand->hwcontrol = at91sam9263ek_nand_hwcontrol; + nand->dev_ready = at91sam9263ek_nand_ready; + nand->chip_delay = 20; + + return 0; +} diff --git a/board/atmel/at91sam9263ek/partition.c b/board/atmel/at91sam9263ek/partition.c new file mode 100644 index 0000000..389fb2c --- /dev/null +++ b/board/atmel/at91sam9263ek/partition.c @@ -0,0 +1,38 @@ +/* + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CFG_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CFG_MAX_DATAFLASH_BANKS] = { + {CFG_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ + {CFG_DATAFLASH_LOGIC_ADDR_CS1, 1} +}; + +/*define the area offsets*/ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x000041FF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00004200, 0x000083FF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00008400, 0x00041FFF, FLAG_PROTECT_SET, 0, "U-Boot"}, + {0x00042000, 0x00251FFF, FLAG_PROTECT_CLEAR, 0, "Kernel"}, + {0x00252000, 0xFFFFFFFF, FLAG_PROTECT_CLEAR, 0, "FS"}, +}; diff --git a/board/atmel/at91sam9263ek/u-boot.lds b/board/atmel/at91sam9263ek/u-boot.lds new file mode 100644 index 0000000..05a6d83 --- /dev/null +++ b/board/atmel/at91sam9263ek/u-boot.lds @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, <gj <at> denx.de> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +/*OUTPUT_FORMAT("elf32-arm", "elf32-arm", "elf32-arm")*/ +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm926ejs/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 703784e..499c7da 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -417,13 +417,13 @@ static int macb_init(struct eth_device *netdev, bd_t *bd)
/* choose RMII or MII mode. This depends on the board */ #ifdef CONFIG_RMII -#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) +#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || defined (CONFIG_AT91SAM9263) macb_writel(macb, USRIO, MACB_BIT(RMII) | MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, 0); #endif #else -#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) +#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || defined (CONFIG_AT91SAM9263) macb_writel(macb, USRIO, MACB_BIT(CLKEN)); #else macb_writel(macb, USRIO, MACB_BIT(MII)); diff --git a/include/asm-arm/arch-at91sam9/at91sam9263.h b/include/asm-arm/arch-at91sam9/at91sam9263.h new file mode 100644 index 0000000..f91a357 --- /dev/null +++ b/include/asm-arm/arch-at91sam9/at91sam9263.h @@ -0,0 +1,120 @@ +/* + * include/asm-arm/arch-at91/at91sam9263.h + * + * (C) 2006 Andrew Victor + * + * Common definitions. + * Based on AT91SAM9263 datasheet revision A (Preliminary). + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91SAM9263_H +#define AT91SAM9263_H + +/* + * Peripheral identifiers/interrupts. + */ +#define AT91_ID_FIQ 0 /* Advanced Interrupt Controller (FIQ) */ +#define AT91_ID_SYS 1 /* System Peripherals */ +#define AT91SAM9263_ID_PIOA 2 /* Parallel IO Controller A */ +#define AT91SAM9263_ID_PIOB 3 /* Parallel IO Controller B */ +#define AT91SAM9263_ID_PIOCDE 4 /* Parallel IO Controller C */ +#define AT91SAM9263_ID_US0 7 /* USART 0 */ +#define AT91SAM9263_ID_US1 8 /* USART 1 */ +#define AT91SAM9263_ID_US2 9 /* USART 2 */ +#define AT91SAM9263_ID_MCI0 10 /* Multimedia Card Interface */ +#define AT91SAM9263_ID_MCI1 11 /* Multimedia Card Interface */ +#define AT91SAM9263_ID_CAN 12 /* CAN Controller */ +#define AT91SAM9263_ID_TWI 13 /* Two-Wire Interface */ +#define AT91SAM9263_ID_SPI0 14 /* Serial Peripheral Interface 0 */ +#define AT91SAM9263_ID_SPI1 15 /* Serial Peripheral Interface 1 */ +#define AT91SAM9263_ID_SSC0 16 /* Serial Synchronous Controller 0 */ +#define AT91SAM9263_ID_SSC1 17 /* Serial Synchronous Controller 1 */ +#define AT91SAM9263_ID_AC97 18 /* AC 97 Controller */ +#define AT91SAM9263_ID_TC012 19 /* Timer Counter 0, 1 and 2 */ +#define AT91SAM9263_ID_PWMC 20 /* PWM Controller */ +#define AT91SAM9263_ID_EMAC 21 /* Ethernet */ +#define AT91SAM9263_ID_2DGE 23 /* 2D Graphics Engine */ +#define AT91SAM9263_ID_UDP 24 /* USB Device Port */ +#define AT91SAM9263_ID_ISI 25 /* Image Sensor Interface */ +#define AT91SAM9263_ID_LCDC 26 /* LCD Controller */ +#define AT91SAM9263_ID_DMA 27 /* DMA Controller */ +#define AT91SAM9263_ID_UHP 29 /* USB Host Controller */ +#define AT91SAM9263_ID_IRQ0 30 /* External IRQ 0 */ +#define AT91SAM9263_ID_IRQ1 31 /* External IRQ 1 */ + +/* + * User Peripheral physical base addresses. + */ +#define AT91SAM9263_BASE_UDP 0xfff78000 +#define AT91SAM9263_BASE_TC012 0xfff7C000 +#define AT91SAM9263_BASE_MCI0 0xfff80000 +#define AT91SAM9263_BASE_MCI1 0xfff84000 +#define AT91SAM9263_BASE_TWI 0xfff88000 +#define AT91SAM9263_BASE_US0 0xfff8c000 +#define AT91SAM9263_BASE_US1 0xfff90000 +#define AT91SAM9263_BASE_US2 0xfff94000 +#define AT91SAM9263_BASE_SSC0 0xfff98000 +#define AT91SAM9263_BASE_SSC1 0xfff9c000 +#define AT91SAM9263_BASE_AC97 0xfffa0000 +#define AT91SAM9263_BASE_SPI0 0xfffa4000 +#define AT91SAM9263_BASE_SPI1 0xfffa8000 +#define AT91SAM9263_BASE_CAN0 0xfffac000 +#define AT91SAM9263_BASE_PWMC 0xfffb8000 +#define AT91SAM9263_BASE_EMAC 0xfffbc000 +#define AT91SAM9263_BASE_ISI 0xfffc4000 +#define AT91SAM9263_BASE_2DGE 0xfffc8000 +#define AT91_BASE_SYS 0xffffc000 + +/* + * System Peripherals (offset from AT91_BASE_SYS) + */ +#define AT91_ECC (0xffffe000 - AT91_BASE_SYS) +#define AT91_SDRAMC (0xffffe200 - AT91_BASE_SYS) +#define AT91_SMC (0xffffe400 - AT91_BASE_SYS) +#define AT91_ECC1 (0xffffe600 - AT91_BASE_SYS) +#define AT91_SDRAMC1 (0xffffe800 - AT91_BASE_SYS) +#define AT91_SMC1 (0xffffea00 - AT91_BASE_SYS) +#define AT91_MATRIX (0xffffec00 - AT91_BASE_SYS) +#define AT91_CCFG (0xffffed10 - AT91_BASE_SYS) +#define AT91_DBGU (0xffffee00 - AT91_BASE_SYS) +#define AT91_AIC (0xfffff000 - AT91_BASE_SYS) +#define AT91_PIOA (0xfffff200 - AT91_BASE_SYS) +#define AT91_PIOB (0xfffff400 - AT91_BASE_SYS) +#define AT91_PIOC (0xfffff600 - AT91_BASE_SYS) +#define AT91_PIOD (0xfffff800 - AT91_BASE_SYS) +#define AT91_PIOE (0xfffffa00 - AT91_BASE_SYS) +#define AT91_PMC (0xfffffc00 - AT91_BASE_SYS) +#define AT91_RSTC (0xfffffd00 - AT91_BASE_SYS) +#define AT91_SHDWC (0xfffffd10 - AT91_BASE_SYS) +#define AT91_RTT (0xfffffd20 - AT91_BASE_SYS) +#define AT91_PIT (0xfffffd30 - AT91_BASE_SYS) +#define AT91_WDT (0xfffffd40 - AT91_BASE_SYS) +#define AT91_RTT1 (0xfffffd50 - AT91_BASE_SYS) +#define AT91_GPBR (0xfffffd60 - AT91_BASE_SYS) + +#define AT91_USART0 AT91SAM9263_BASE_US0 +#define AT91_USART1 AT91SAM9263_BASE_US1 +#define AT91_USART2 AT91SAM9263_BASE_US2 + +/* + * Internal Memory. + */ +#define AT91SAM9263_ROM_BASE 0x00400000 /* Internal ROM base address */ +#define AT91SAM9263_ROM_SIZE SZ_128K /* Internal ROM size (128Kb) */ + +#define AT91SAM9263_SRAM0_BASE 0x00500000 /* Internal SRAM 0 base address */ +#define AT91SAM9263_SRAM0_SIZE SZ_16K /* Internal SRAM 0 size (16Kb) */ +#define AT91SAM9263_SRAM1_BASE 0x00300000 /* Internal SRAM 1 base address */ +#define AT91SAM9263_SRAM1_SIZE SZ_80K /* Internal SRAM 1 size (80Kb) */ + +#define AT91SAM9263_UHP_BASE 0x00A00000 /* USB Host controller */ + +#define AT91SAM9XE_FLASH_BASE 0x00200000 /* Internal FLASH base address */ +#define AT91SAM9XE_SRAM_BASE 0x00300000 /* Internal SRAM base address */ + +#endif diff --git a/include/asm-arm/arch-at91sam9/at91sam9263_matrix.h b/include/asm-arm/arch-at91sam9/at91sam9263_matrix.h new file mode 100644 index 0000000..c90f01a --- /dev/null +++ b/include/asm-arm/arch-at91sam9/at91sam9263_matrix.h @@ -0,0 +1,88 @@ +/* + * include/asm-arm/arch-at91/at91sam9260_matrix.h + * + * Memory Controllers (MATRIX, EBI) - System peripherals registers. + * Based on AT91SAM9260 datasheet revision B. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91SAM9260_MATRIX_H +#define AT91SAM9260_MATRIX_H + +#define AT91_MATRIX_MCFG0 (AT91_MATRIX + 0x00) /* Master Configuration Register 0 */ +#define AT91_MATRIX_MCFG1 (AT91_MATRIX + 0x04) /* Master Configuration Register 1 */ +#define AT91_MATRIX_MCFG2 (AT91_MATRIX + 0x08) /* Master Configuration Register 2 */ +#define AT91_MATRIX_MCFG3 (AT91_MATRIX + 0x0C) /* Master Configuration Register 3 */ +#define AT91_MATRIX_MCFG4 (AT91_MATRIX + 0x10) /* Master Configuration Register 4 */ +#define AT91_MATRIX_MCFG5 (AT91_MATRIX + 0x14) /* Master Configuration Register 5 */ +#define AT91_MATRIX_ULBT (7 << 0) /* Undefined Length Burst Type */ +#define AT91_MATRIX_ULBT_INFINITE (0 << 0) +#define AT91_MATRIX_ULBT_SINGLE (1 << 0) +#define AT91_MATRIX_ULBT_FOUR (2 << 0) +#define AT91_MATRIX_ULBT_EIGHT (3 << 0) +#define AT91_MATRIX_ULBT_SIXTEEN (4 << 0) + +#define AT91_MATRIX_SCFG0 (AT91_MATRIX + 0x40) /* Slave Configuration Register 0 */ +#define AT91_MATRIX_SCFG1 (AT91_MATRIX + 0x44) /* Slave Configuration Register 1 */ +#define AT91_MATRIX_SCFG2 (AT91_MATRIX + 0x48) /* Slave Configuration Register 2 */ +#define AT91_MATRIX_SCFG3 (AT91_MATRIX + 0x4C) /* Slave Configuration Register 3 */ +#define AT91_MATRIX_SCFG4 (AT91_MATRIX + 0x50) /* Slave Configuration Register 4 */ +#define AT91_MATRIX_SLOT_CYCLE (0xff << 0) /* Maximum Number of Allowed Cycles for a Burst */ +#define AT91_MATRIX_DEFMSTR_TYPE (3 << 16) /* Default Master Type */ +#define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_LAST (1 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) +#define AT91_MATRIX_FIXED_DEFMSTR (7 << 18) /* Fixed Index of Default Master */ +#define AT91_MATRIX_ARBT (3 << 24) /* Arbitration Type */ +#define AT91_MATRIX_ARBT_ROUND_ROBIN (0 << 24) +#define AT91_MATRIX_ARBT_FIXED_PRIORITY (1 << 24) + +#define AT91_MATRIX_PRAS0 (AT91_MATRIX + 0x80) /* Priority Register A for Slave 0 */ +#define AT91_MATRIX_PRAS1 (AT91_MATRIX + 0x88) /* Priority Register A for Slave 1 */ +#define AT91_MATRIX_PRAS2 (AT91_MATRIX + 0x90) /* Priority Register A for Slave 2 */ +#define AT91_MATRIX_PRAS3 (AT91_MATRIX + 0x98) /* Priority Register A for Slave 3 */ +#define AT91_MATRIX_PRAS4 (AT91_MATRIX + 0xA0) /* Priority Register A for Slave 4 */ +#define AT91_MATRIX_M0PR (3 << 0) /* Master 0 Priority */ +#define AT91_MATRIX_M1PR (3 << 4) /* Master 1 Priority */ +#define AT91_MATRIX_M2PR (3 << 8) /* Master 2 Priority */ +#define AT91_MATRIX_M3PR (3 << 12) /* Master 3 Priority */ +#define AT91_MATRIX_M4PR (3 << 16) /* Master 4 Priority */ +#define AT91_MATRIX_M5PR (3 << 20) /* Master 5 Priority */ + +#define AT91_MATRIX_MRCR (AT91_MATRIX + 0x100) /* Master Remap Control Register */ +#define AT91_MATRIX_RCB0 (1 << 0) /* Remap Command for AHB Master 0 (ARM926EJ-S Instruction Master) */ +#define AT91_MATRIX_RCB1 (1 << 1) /* Remap Command for AHB Master 1 (ARM926EJ-S Data Master) */ + +#define AT91_MATRIX_CSA (AT91_MATRIX + 0x120) /* EBI0 Chip Select Assignment Register */ +#define AT91_MATRIX_CS1A (1 << 1) /* Chip Select 1 Assignment */ +#define AT91_MATRIX_CS1A_SMC (0 << 1) +#define AT91_MATRIX_CS1A_SDRAMC (1 << 1) +#define AT91_MATRIX_CS3A (1 << 3) /* Chip Select 3 Assignment */ +#define AT91_MATRIX_CS3A_SMC (0 << 3) +#define AT91_MATRIX_CS3A_SMC_SMARTMEDIA (1 << 3) +#define AT91_MATRIX_CS4A (1 << 4) /* Chip Select 4 Assignment */ +#define AT91_MATRIX_CS4A_SMC (0 << 4) +#define AT91_MATRIX_CS4A_SMC_CF1 (1 << 4) +#define AT91_MATRIX_CS5A (1 << 5) /* Chip Select 5 Assignment */ +#define AT91_MATRIX_CS5A_SMC (0 << 5) +#define AT91_MATRIX_CS5A_SMC_CF2 (1 << 5) +#define AT91_MATRIX_DBPUC (1 << 8) /* Data Bus Pull-up Configuration */ +#define AT91_MATRIX_VDDIOMSEL (1 << 16) /* Memory voltage selection */ +#define AT91_MATRIX_VDDIOMSEL_1_8V (0 << 16) +#define AT91_MATRIX_VDDIOMSEL_3_3V (1 << 16) +#define AT91_MATRIX_EBI1_CSA (AT91_MATRIX + 0x124) /* EBI1 Chip Select Assignment Register */ +#define AT91_MATRIX_EBI1_CS1A (1 << 1) /* Chip Select 1 Assignment */ +#define AT91_MATRIX_EBI1_CS1A_SMC (0 << 1) +#define AT91_MATRIX_EBI1_CS1A_SDRAMC (1 << 1) +#define AT91_MATRIX_EBI1_CS2A (1 << 3) /* Chip Select 3 Assignment */ +#define AT91_MATRIX_EBI1_CS2A_SMC (0 << 3) +#define AT91_MATRIX_EBI1_CS2A_SMC_SMARTMEDIA (1 << 3) +#define AT91_MATRIX_EBI1_DBPUC (1 << 8) /* Data Bus Pull-up Configuration */ +#define AT91_MATRIX_EBI1_VDDIOMSEL (1 << 16) /* Memory voltage selection */ +#define AT91_MATRIX_EBI1_VDDIOMSEL_1_8V (0 << 16) +#define AT91_MATRIX_EBI1_VDDIOMSEL_3_3V (1 << 16) +#endif diff --git a/include/asm-arm/arch-at91sam9/at91sam9263_mc.h b/include/asm-arm/arch-at91sam9/at91sam9263_mc.h new file mode 100644 index 0000000..041138f --- /dev/null +++ b/include/asm-arm/arch-at91sam9/at91sam9263_mc.h @@ -0,0 +1,140 @@ +/* + * include/asm-arm/arch-at91/at91sam926x_mc.h + * + * Memory Controllers (SMC, SDRAMC) - System peripherals registers. + * Based on AT91SAM9261 datasheet revision D. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91SAM926x_MC_H +#define AT91SAM926x_MC_H + +/* SDRAM Controller (SDRAMC) registers */ +#define AT91_SDRAMC_MR (AT91_SDRAMC + 0x00) /* SDRAM Controller Mode Register */ +#define AT91_SDRAMC_MODE (0xf << 0) /* Command Mode */ +#define AT91_SDRAMC_MODE_NORMAL 0 +#define AT91_SDRAMC_MODE_NOP 1 +#define AT91_SDRAMC_MODE_PRECHARGE 2 +#define AT91_SDRAMC_MODE_LMR 3 +#define AT91_SDRAMC_MODE_REFRESH 4 +#define AT91_SDRAMC_MODE_EXT_LMR 5 +#define AT91_SDRAMC_MODE_DEEP 6 + +#define AT91_SDRAMC_TR (AT91_SDRAMC + 0x04) /* SDRAM Controller Refresh Timer Register */ +#define AT91_SDRAMC_COUNT (0xfff << 0) /* Refresh Timer Counter */ + +#define AT91_SDRAMC_CR (AT91_SDRAMC + 0x08) /* SDRAM Controller Configuration Register */ +#define AT91_SDRAMC_NC (3 << 0) /* Number of Column Bits */ +#define AT91_SDRAMC_NC_8 (0 << 0) +#define AT91_SDRAMC_NC_9 (1 << 0) +#define AT91_SDRAMC_NC_10 (2 << 0) +#define AT91_SDRAMC_NC_11 (3 << 0) +#define AT91_SDRAMC_NR (3 << 2) /* Number of Row Bits */ +#define AT91_SDRAMC_NR_11 (0 << 2) +#define AT91_SDRAMC_NR_12 (1 << 2) +#define AT91_SDRAMC_NR_13 (2 << 2) +#define AT91_SDRAMC_NB (1 << 4) /* Number of Banks */ +#define AT91_SDRAMC_NB_2 (0 << 4) +#define AT91_SDRAMC_NB_4 (1 << 4) +#define AT91_SDRAMC_CAS (3 << 5) /* CAS Latency */ +#define AT91_SDRAMC_CAS_1 (1 << 5) +#define AT91_SDRAMC_CAS_2 (2 << 5) +#define AT91_SDRAMC_CAS_3 (3 << 5) +#define AT91_SDRAMC_DBW (1 << 7) /* Data Bus Width */ +#define AT91_SDRAMC_DBW_32 (0 << 7) +#define AT91_SDRAMC_DBW_16 (1 << 7) +#define AT91_SDRAMC_TWR (0xf << 8) /* Write Recovery Delay */ +#define AT91_SDRAMC_TRC (0xf << 12) /* Row Cycle Delay */ +#define AT91_SDRAMC_TRP (0xf << 16) /* Row Precharge Delay */ +#define AT91_SDRAMC_TRCD (0xf << 20) /* Row to Column Delay */ +#define AT91_SDRAMC_TRAS (0xf << 24) /* Active to Precharge Delay */ +#define AT91_SDRAMC_TXSR (0xf << 28) /* Exit Self Refresh to Active Delay */ + +#define AT91_SDRAMC_LPR (AT91_SDRAMC + 0x10) /* SDRAM Controller Low Power Register */ +#define AT91_SDRAMC_LPCB (3 << 0) /* Low-power Configurations */ +#define AT91_SDRAMC_LPCB_DISABLE 0 +#define AT91_SDRAMC_LPCB_SELF_REFRESH 1 +#define AT91_SDRAMC_LPCB_POWER_DOWN 2 +#define AT91_SDRAMC_LPCB_DEEP_POWER_DOWN 3 +#define AT91_SDRAMC_PASR (7 << 4) /* Partial Array Self Refresh */ +#define AT91_SDRAMC_TCSR (3 << 8) /* Temperature Compensated Self Refresh */ +#define AT91_SDRAMC_DS (3 << 10) /* Drive Strenght */ +#define AT91_SDRAMC_TIMEOUT (3 << 12) /* Time to define when Low Power Mode is enabled */ +#define AT91_SDRAMC_TIMEOUT_0_CLK_CYCLES (0 << 12) +#define AT91_SDRAMC_TIMEOUT_64_CLK_CYCLES (1 << 12) +#define AT91_SDRAMC_TIMEOUT_128_CLK_CYCLES (2 << 12) + +#define AT91_SDRAMC_IER (AT91_SDRAMC + 0x14) /* SDRAM Controller Interrupt Enable Register */ +#define AT91_SDRAMC_IDR (AT91_SDRAMC + 0x18) /* SDRAM Controller Interrupt Disable Register */ +#define AT91_SDRAMC_IMR (AT91_SDRAMC + 0x1C) /* SDRAM Controller Interrupt Mask Register */ +#define AT91_SDRAMC_ISR (AT91_SDRAMC + 0x20) /* SDRAM Controller Interrupt Status Register */ +#define AT91_SDRAMC_RES (1 << 0) /* Refresh Error Status */ + +#define AT91_SDRAMC_MDR (AT91_SDRAMC + 0x24) /* SDRAM Memory Device Register */ +#define AT91_SDRAMC_MD (3 << 0) /* Memory Device Type */ +#define AT91_SDRAMC_MD_SDRAM 0 +#define AT91_SDRAMC_MD_LOW_POWER_SDRAM 1 + +/* Static Memory Controller (SMC) registers */ +#define AT91_SMC_SETUP(n) (AT91_SMC + 0x00 + ((n)*0x10)) /* Setup Register for CS n */ +#define AT91_SMC_NWESETUP (0x3f << 0) /* NWE Setup Length */ +#define AT91_SMC_NWESETUP_(x) ((x) << 0) +#define AT91_SMC_NCS_WRSETUP (0x3f << 8) /* NCS Setup Length in Write Access */ +#define AT91_SMC_NCS_WRSETUP_(x) ((x) << 8) +#define AT91_SMC_NRDSETUP (0x3f << 16) /* NRD Setup Length */ +#define AT91_SMC_NRDSETUP_(x) ((x) << 16) +#define AT91_SMC_NCS_RDSETUP (0x3f << 24) /* NCS Setup Length in Read Access */ +#define AT91_SMC_NCS_RDSETUP_(x) ((x) << 24) + +#define AT91_SMC_PULSE(n) (AT91_SMC + 0x04 + ((n)*0x10)) /* Pulse Register for CS n */ +#define AT91_SMC_NWEPULSE (0x7f << 0) /* NWE Pulse Length */ +#define AT91_SMC_NWEPULSE_(x) ((x) << 0) +#define AT91_SMC_NCS_WRPULSE (0x7f << 8) /* NCS Pulse Length in Write Access */ +#define AT91_SMC_NCS_WRPULSE_(x)((x) << 8) +#define AT91_SMC_NRDPULSE (0x7f << 16) /* NRD Pulse Length */ +#define AT91_SMC_NRDPULSE_(x) ((x) << 16) +#define AT91_SMC_NCS_RDPULSE (0x7f << 24) /* NCS Pulse Length in Read Access */ +#define AT91_SMC_NCS_RDPULSE_(x)((x) << 24) + +#define AT91_SMC_CYCLE(n) (AT91_SMC + 0x08 + ((n)*0x10)) /* Cycle Register for CS n */ +#define AT91_SMC_NWECYCLE (0x1ff << 0 ) /* Total Write Cycle Length */ +#define AT91_SMC_NWECYCLE_(x) ((x) << 0) +#define AT91_SMC_NRDCYCLE (0x1ff << 16) /* Total Read Cycle Length */ +#define AT91_SMC_NRDCYCLE_(x) ((x) << 16) + +#define AT91_SMC_MODE(n) (AT91_SMC + 0x0c + ((n)*0x10)) /* Mode Register for CS n */ +#define AT91_SMC_READMODE (1 << 0) /* Read Mode */ +#define AT91_SMC_WRITEMODE (1 << 1) /* Write Mode */ +#define AT91_SMC_EXNWMODE (3 << 4) /* NWAIT Mode */ +#define AT91_SMC_EXNWMODE_DISABLE (0 << 4) +#define AT91_SMC_EXNWMODE_FROZEN (2 << 4) +#define AT91_SMC_EXNWMODE_READY (3 << 4) +#define AT91_SMC_BAT (1 << 8) /* Byte Access Type */ +#define AT91_SMC_BAT_SELECT (0 << 8) +#define AT91_SMC_BAT_WRITE (1 << 8) +#define AT91_SMC_DBW (3 << 12) /* Data Bus Width */ +#define AT91_SMC_DBW_8 (0 << 12) +#define AT91_SMC_DBW_16 (1 << 12) +#define AT91_SMC_DBW_32 (2 << 12) +#define AT91_SMC_TDF (0xf << 16) /* Data Float Time. */ +#define AT91_SMC_TDF_(x) ((x) << 16) +#define AT91_SMC_TDFMODE (1 << 20) /* TDF Optimization - Enabled */ +#define AT91_SMC_PMEN (1 << 24) /* Page Mode Enabled */ +#define AT91_SMC_PS (3 << 28) /* Page Size */ +#define AT91_SMC_PS_4 (0 << 28) +#define AT91_SMC_PS_8 (1 << 28) +#define AT91_SMC_PS_16 (2 << 28) +#define AT91_SMC_PS_32 (3 << 28) + +#if defined(AT91_SMC1) /* The AT91SAM9263 has 2 Static Memory contollers */ +#define AT91_SMC1_SETUP(n) (AT91_SMC1 + 0x00 + ((n)*0x10)) /* Setup Register for CS n */ +#define AT91_SMC1_PULSE(n) (AT91_SMC1 + 0x04 + ((n)*0x10)) /* Pulse Register for CS n */ +#define AT91_SMC1_CYCLE(n) (AT91_SMC1 + 0x08 + ((n)*0x10)) /* Cycle Register for CS n */ +#define AT91_SMC1_MODE(n) (AT91_SMC1 + 0x0c + ((n)*0x10)) /* Mode Register for CS n */ +#endif + +#endif diff --git a/include/asm-arm/arch-at91sam9/hardware.h b/include/asm-arm/arch-at91sam9/hardware.h index 80b334f..4f9f2a8 100644 --- a/include/asm-arm/arch-at91sam9/hardware.h +++ b/include/asm-arm/arch-at91sam9/hardware.h @@ -28,6 +28,10 @@ #include <asm/arch/at91sam9261.h> #elif defined(CONFIG_AT91SAM9263) #include <asm/arch/at91sam9263.h> +#define AT91_BASE_EMAC AT91SAM9263_BASE_EMAC +#define AT91_BASE_SPI AT91SAM9263_BASE_SPI0 +#define AT91_ID_UHP AT91SAM9263_ID_UHP +#define AT91_PMC_UHP AT91SAM926x_PMC_UHP #elif defined(CONFIG_AT91SAM9RL) #include <asm/arch/at91sam9rl.h> #elif defined(CONFIG_AT91CAP9) diff --git a/include/asm-i386/arch b/include/asm-i386/arch new file mode 100644 index 0000000..3fab653 --- /dev/null +++ b/include/asm-i386/arch @@ -0,0 +1 @@ +arch-i386 \ No newline at end of file diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h new file mode 100644 index 0000000..3ae9846 --- /dev/null +++ b/include/configs/at91sam9263ek.h @@ -0,0 +1,205 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop <stelian.pop <at> leadtechdesign.com> + * Lead Tech Design <www.leadtechdesign.com> + * + * Configuation settings for the AT91SAM9260EK board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* ARM asynchronous clock */ +#define CRYSTAL_16_36766MHZ 1 + +#ifdef CRYSTAL_16_36766MHZ + +#define AT91_MAIN_CLOCK 199919000 /* from 16.367 MHz crystal (16367000 / 14 * 171) */ +#define AT91_MASTER_CLOCK (199919000/2) /* peripheral clock (AT91C_MAIN_CLOCK / 2) */ + +#endif + +#ifdef CRYSTAL_18_432MHZ + +#define AT91_MAIN_CLOCK 198656000 /* from 16.367 MHz crystal (16367000 / 5 * 61) */ +#define AT91_MASTER_CLOCK (198656000/2) /* peripheral clock (AT91C_MAIN_CLOCK / 2) */ + +#endif/* ARM asynchronous clock */ + +#define CFG_HZ 1000000 /* 1us resolution */ + +#define AT91_SLOW_CLOCK 32768 /* slow clock */ + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9263 1 /* It's an Atmel AT91SAM9263 SoC*/ +#define CONFIG_AT91SAM9263EK 1 /* on an AT91SAM9263EK Board */ +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock0 rw rootfstype=jffs2" + +/* #define CONFIG_ENV_OVERWRITE 1 */ + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */ + +/* DataFlash */ +#define CONFIG_HAS_DATAFLASH 1 +#define CFG_SPI_WRITE_TOUT (5*CFG_HZ) +#define CFG_MAX_DATAFLASH_BANKS 2 +#define CFG_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define CFG_DATAFLASH_LOGIC_ADDR_CS1 0xD0000000 /* CS1 */ +#define AT91_SPI_CLK 33000000 +#define DATAFLASH_TCSS (0x1a << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* NAND flash */ +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 +#define CFG_NAND_BASE 0x40000000 + +/* NOR flash - no real flash on this board */ +#define CFG_NO_FLASH 1 + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R 1 + +/* USB */ +#define CONFIG_USB_OHCI_NEW 1 +#define LITTLEENDIAN 1 +#define CONFIG_DOS_PARTITION 1 +#define CFG_USB_OHCI_CPU_INIT 1 +#define CFG_USB_OHCI_REGS_BASE 0x00a00000 /* AT91SAM9260_UHP_BASE */ +#define CFG_USB_OHCI_SLOT_NAME "at91sam9263" +#define CFG_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 + +#define CFG_LOAD_ADDR 0x22000000 /* load address */ + +#define CFG_MEMTEST_START PHYS_SDRAM +#define CFG_MEMTEST_END 0x23e00000 + +#undef CFG_USE_DATAFLASH_CS0 +#undef CFG_USE_DATAFLASH_CS1 +#define CFG_USE_NANDFLASH 1 + +#ifdef CFG_USE_DATAFLASH_CS0 + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CFG_ENV_IS_IN_DATAFLASH 1 +#define CFG_MONITOR_BASE (CFG_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) +#define CFG_ENV_OFFSET 0x4200 +#define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CFG_ENV_OFFSET) +#define CFG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b 0xC003DE00 0x22000000 0x200040; bootm" + +#elif CFG_USE_DATAFLASH_CS1 + +/* bootstrap + u-boot + env + linux in dataflash on CS1 */ +#define CFG_ENV_IS_IN_DATAFLASH 1 +#define CFG_MONITOR_BASE (CFG_DATAFLASH_LOGIC_ADDR_CS1 + 0x8400) +#define CFG_ENV_OFFSET 0x4200 +#define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS1 + CFG_ENV_OFFSET) +#define CFG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b 0xD003DE00 0x22000000 0x200040; bootm" + +#else /* CFG_USE_NANDFLASH */ + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CFG_ENV_IS_IN_NAND 1 +#define CFG_ENV_OFFSET 0x60000 +#define CFG_ENV_OFFSET_REDUND 0x80000 +#define CFG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm" + +#endif + +#define CONFIG_BAUDRATE 115200 +#define CFG_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CFG_PROMPT "U-Boot> " +#define CFG_CBSIZE 256 +#define CFG_MAXARGS 16 +#define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) +#define CFG_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CFG_MALLOC_LEN ROUND(3 * CFG_ENV_SIZE + 128*1024, 0x1000) +#define CFG_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif diff --git a/net/eth.c b/net/eth.c index c4f24c6..e532f8c 100644 --- a/net/eth.c +++ b/net/eth.c @@ -288,7 +288,7 @@ int eth_initialize(bd_t *bis) #if defined(CONFIG_FSLDMAFEC) mcdmafec_initialize(bis); #endif -#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) +#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9263) at91sam9_eth_initialize(bis); #endif
In message 12095450983375-git-send-email-j.holzman@genesysdesign.com.au you wrote:
Commit message missing.
Signed-off-by line missing.
Please add your own Copyright message!
- (C) Copyright 2007-2008
- Stelian Pop <stelian.pop <at> leadtechdesign.com>
- Lead Tech Design <www.leadtechdesign.com>
- project.
Ditto.
- project.
Ditto.
- at91_set_gpio_value(POWER_LED, 1);
- at91_set_gpio_value(POWER_LED, 0);
- at91_set_gpio_value(USER1_LED, 0);
This whole board/atmel/*/led.c stuff is a terrible mess and needs a major cleanup one day.
Anybody volunteering?
- (C) Copyright 2006 ATMEL Rousset, Lacressonniere Nicolas
Copyright entry...
Ditto.
- (C) Copyright 2002
- Gary Jennejohn, DENX Software Engineering, <gj <at> denx.de>
- project.
Ditto.
- include/asm-arm/arch-at91/at91sam9263.h
- (C) 2006 Andrew Victor
Hm. The Linux kernel has a file that's looking suspiciously similar, but it reads:
(C) 2007 Atmel Corporation.
Which one is correct?
- include/asm-arm/arch-at91/at91sam9260_matrix.h
- Memory Controllers (MATRIX, EBI) - System peripherals registers.
- Based on AT91SAM9260 datasheet revision B.
Here the Linux file has
Copyright (C) 2006 Atmel Corporation.
- include/asm-arm/arch-at91/at91sam926x_mc.h
- Memory Controllers (SMC, SDRAMC) - System peripherals registers.
- Based on AT91SAM9261 datasheet revision D.
Copyright ?
Ditto ?
Jared Holzman
