[U-Boot] Pull request: u-boot-mmc 02042014
Hi Tom,
The following changes since commit c494eaf409cb8db9a5a513e9bdfac20b7a83daca:
Prepare v2014.04-rc3 (2014-03-31 15:24:48 -0400)
git://git.denx.de/u-boot-mmc.git master
for you to fetch changes up to 1336e2d343f088b71ec71907855caccd1053d166:
mmc:eSDHC: Workaround for data timeout issue on Txxx SoC (2014-04-02 13:25:01 +0300)
---------------------------------------------------------------- Andrew Gabbasov (2): mmc: fsl_esdhc: fix calculation of timeout for data transactions mmc: fsl_esdhc: add controller reset in case of data related errors too
Haijun.Zhang (1): mmc:eSDHC: Workaround for data timeout issue on Txxx SoC
Nobuhiro Iwamatsu (2): mmc: sh_mmcif: Fix compile error mmc: sh_mmcif: Fix warning by unused variable
Tom Rini (1): mmc: Add 'mmc rst-function' sub-command
arch/powerpc/include/asm/config_mpc85xx.h | 5 +++++ board/ti/dra7xx/README | 1 + common/cmd_mmc.c | 37 +++++++++++++++++++++++++++++++++++++ drivers/mmc/fsl_esdhc.c | 78 +++++++++++++++++++++++++++++++++++++++++++++--------------------------------- drivers/mmc/mmc.c | 12 ++++++++++++ drivers/mmc/sh_mmcif.c | 5 ++--- include/mmc.h | 3 +++ 7 files changed, 105 insertions(+), 36 deletions(-)
Regards
-- Pantelis
On Wed, Apr 02, 2014 at 01:56:05PM +0300, Pantelis Antoniou wrote:
Hi Tom,
Pantelis Antoniou
