[U-Boot] [PATCH 1/2] powerpc/85xx: Add C29x SoC support
The Freescale C29x family is a high performance crypto co-processor. It combines a single e500v2 core with necessary SEC engine. There're three SoC types(C291, C292, C293) with the following features:
- 512K L2 Cache/SRAM and 512 KB platform SRAM - DDR3/DDR3L 32bit DDR controller - One PCI express (x1, x2, x4) Gen 2.0 Controller - Trust Architecture 2.0 - SEC6.0 engine
Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Po Liu Po.Liu@freescale.com --- Base on tree git://git.denx.de/u-boot.git, modified integrate C291/C292/C293 to C29X. arch/powerpc/cpu/mpc85xx/Makefile | 2 + arch/powerpc/cpu/mpc85xx/c29x_serdes.c | 65 +++++++++++++++++++++++++++++++ arch/powerpc/cpu/mpc8xxx/cpu.c | 3 ++ arch/powerpc/include/asm/config_mpc85xx.h | 12 ++++++ arch/powerpc/include/asm/fsl_law.h | 1 + arch/powerpc/include/asm/immap_85xx.h | 23 +++++++++++ arch/powerpc/include/asm/processor.h | 3 ++ 7 files changed, 109 insertions(+) create mode 100644 arch/powerpc/cpu/mpc85xx/c29x_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 2318064..5135083 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -62,6 +62,7 @@ COBJS-$(CONFIG_MPC8568) += ddr-gen2.o COBJS-$(CONFIG_MPC8544) += ddr-gen2.o
# supports ddr1/2/3 +COBJS-$(CONFIG_C29X) += ddr-gen3.o COBJS-$(CONFIG_MPC8572) += ddr-gen3.o COBJS-$(CONFIG_MPC8536) += ddr-gen3.o COBJS-$(CONFIG_MPC8569) += ddr-gen3.o @@ -115,6 +116,7 @@ COBJS-$(CONFIG_SYS_FSL_QORIQ_CHASSIS1) += fsl_corenet_serdes.o COBJS-$(CONFIG_SYS_FSL_QORIQ_CHASSIS2) += fsl_corenet2_serdes.o
# SoC specific SERDES support +COBJS-$(CONFIG_C29X) += c29x_serdes.o COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o COBJS-$(CONFIG_MPC8544) += mpc8544_serdes.o COBJS-$(CONFIG_MPC8548) += mpc8548_serdes.o diff --git a/arch/powerpc/cpu/mpc85xx/c29x_serdes.c b/arch/powerpc/cpu/mpc85xx/c29x_serdes.c new file mode 100644 index 0000000..4b3214d --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/c29x_serdes.c @@ -0,0 +1,65 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_serdes.h> + +#define SRDS1_MAX_LANES 4 + +static u32 serdes1_prtcl_map; + +struct serdes_config { + u32 protocol; + u8 lanes[SRDS1_MAX_LANES]; +}; + +static const struct serdes_config serdes1_cfg_tbl[] = { + /* SerDes 1 */ + {1, {PCIE1, PCIE1, PCIE1, PCIE1} }, + {2, {PCIE1, PCIE1, PCIE1, PCIE1} }, + {3, {PCIE1, PCIE1, NONE, NONE} }, + {4, {PCIE1, PCIE1, NONE, NONE} }, + {5, {PCIE1, NONE, NONE, NONE} }, + {6, {PCIE1, NONE, NONE, NONE} }, + {} +}; + +int is_serdes_configured(enum srds_prtcl device) +{ + return (1 << device) & serdes1_prtcl_map; +} + +void fsl_serdes_init(void) +{ + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + u32 pordevsr = in_be32(&gur->pordevsr); + u32 srds_cfg = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> + MPC85xx_PORDEVSR_IO_SEL_SHIFT; + const struct serdes_config *ptr; + int lane; + + debug("PORDEVSR[IO_SEL_SRDS] = %x\n", srds_cfg); + + if (srds_cfg > ARRAY_SIZE(serdes1_cfg_tbl)) { + printf("Invalid PORDEVSR[IO_SEL_SRDS] = %d\n", srds_cfg); + return; + } + + ptr = &serdes1_cfg_tbl[srds_cfg]; + if (!ptr->protocol) + return; + + for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = ptr->lanes[lane]; + serdes1_prtcl_map |= (1 << lane_prtcl); + } +} diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index bc26855..2eed872 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -95,6 +95,9 @@ static struct cpu_type cpu_type_list[] = { CPU_TYPE_ENTRY(BSC9131, 9131, 1), CPU_TYPE_ENTRY(BSC9132, 9132, 2), CPU_TYPE_ENTRY(BSC9232, 9232, 2), + CPU_TYPE_ENTRY(C291, C291, 1), + CPU_TYPE_ENTRY(C292, C292, 1), + CPU_TYPE_ENTRY(C293, C293, 1), #elif defined(CONFIG_MPC86xx) CPU_TYPE_ENTRY(8610, 8610, 1), CPU_TYPE_ENTRY(8641, 8641, 2), diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 1009a31..dd23a4a 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -621,6 +621,18 @@ #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000
+#elif defined(CONFIG_C29X) +#define CONFIG_MAX_CPUS 1 +#define CONFIG_FSL_SDHC_V2_3 +#define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_SYS_PPC_E500_DEBUG_TLB 3 +#define CONFIG_TSECV2_1 +#define CONFIG_SYS_FSL_SEC_COMPAT 6 +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111 +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 + #else #error Processor type not defined for this platform #endif diff --git a/arch/powerpc/include/asm/fsl_law.h b/arch/powerpc/include/asm/fsl_law.h index 90b264d..ae95573 100644 --- a/arch/powerpc/include/asm/fsl_law.h +++ b/arch/powerpc/include/asm/fsl_law.h @@ -87,6 +87,7 @@ enum law_trgt_if { #endif LAW_TRGT_IF_LBC = 0x04, LAW_TRGT_IF_CCSR = 0x08, + LAW_TRGT_IF_PLATFORM_SRAM = 0x0a, LAW_TRGT_IF_DDR_INTRLV = 0x0b, LAW_TRGT_IF_RIO = 0x0c, LAW_TRGT_IF_RIO_2 = 0x0d, diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 4052037..5bf7d9b 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2145,6 +2145,11 @@ typedef struct ccsr_gur { #ifdef CONFIG_MPC8536 #define MPC85xx_PORPLLSR_DDR_RATIO 0x3e000000 #define MPC85xx_PORPLLSR_DDR_RATIO_SHIFT 25 +#elif defined(CONFIG_C29X) +#define MPC85xx_PORPLLSR_DDR_RATIO 0x00003f00 +#define MPC85xx_PORPLLSR_DDR_RATIO_SHIFT (9 - ((gur->pordevsr2 \ + & MPC85xx_PORDEVSR2_DDR_SPD_0) \ + >> MPC85xx_PORDEVSR2_DDR_SPD_0_SHIFT)) #else #if defined(CONFIG_BSC9131) || defined(CONFIG_BSC9132) #define MPC85xx_PORPLLSR_DDR_RATIO 0x00003f00 @@ -2192,6 +2197,9 @@ typedef struct ccsr_gur { #elif defined(CONFIG_BSC9132) #define MPC85xx_PORDEVSR_IO_SEL 0x00FE0000 #define MPC85xx_PORDEVSR_IO_SEL_SHIFT 17 +#elif defined(CONFIG_C29X) +#define MPC85xx_PORDEVSR_IO_SEL 0x00e00000 +#define MPC85xx_PORDEVSR_IO_SEL_SHIFT 21 #else #define MPC85xx_PORDEVSR_IO_SEL 0x00780000 #define MPC85xx_PORDEVSR_IO_SEL_SHIFT 19 @@ -2207,6 +2215,10 @@ typedef struct ccsr_gur { #define MPC85xx_PORDEVSR_RIO_DEV_ID 0x00000007 u32 pordbgmsr; /* POR debug mode status */ u32 pordevsr2; /* POR I/O device status 2 */ +#if defined(CONFIG_C29X) +#define MPC85xx_PORDEVSR2_DDR_SPD_0 0x00000008 +#define MPC85xx_PORDEVSR2_DDR_SPD_0_SHIFT 3 +#endif /* The 8544 RM says this is bit 26, but it's really bit 24 */ #define MPC85xx_PORDEVSR2_SEC_CFG 0x00000080 u8 res1[8]; @@ -2353,6 +2365,11 @@ typedef struct ccsr_gur { #define MPC85xx_PMUXCR0_SIM_SEL_MASK 0x0003b000 #define MPC85xx_PMUXCR0_SIM_SEL 0x00014000 #endif +#if defined(CONFIG_C29X) +#define MPC85xx_PMUXCR_SPI_MASK 0x00000300 +#define MPC85xx_PMUXCR_SPI 0x00000000 +#define MPC85xx_PMUXCR_SPI_GPIO 0x00000100 +#endif u32 pmuxcr2; /* Alt. function signal multiplex control 2 */ #if defined(CONFIG_P1010) || defined(CONFIG_P1014) #define MPC85xx_PMUXCR2_UART_GPIO 0x40000000 @@ -3022,12 +3039,18 @@ struct ccsr_pman { #define CONFIG_SYS_MPC85xx_USB2_OFFSET 0x23000 #ifdef CONFIG_TSECV2 #define CONFIG_SYS_TSEC1_OFFSET 0xB0000 +#elif defined(CONFIG_TSECV2_1) +#define CONFIG_SYS_TSEC1_OFFSET 0x10000 #else #define CONFIG_SYS_TSEC1_OFFSET 0x24000 #endif #define CONFIG_SYS_MDIO1_OFFSET 0x24000 #define CONFIG_SYS_MPC85xx_ESDHC_OFFSET 0x2e000 +#if defined(CONFIG_C29X) +#define CONFIG_SYS_FSL_SEC_OFFSET 0x80000 +#else #define CONFIG_SYS_FSL_SEC_OFFSET 0x30000 +#endif #define CONFIG_SYS_MPC85xx_SERDES2_OFFSET 0xE3100 #define CONFIG_SYS_MPC85xx_SERDES1_OFFSET 0xE3000 #define CONFIG_SYS_SNVS_OFFSET 0xE6000 diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 56b22d8..64a6f9c 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1119,6 +1119,9 @@ #define SVR_T4240 0x824000 #define SVR_T4120 0x824001 #define SVR_T4160 0x824100 +#define SVR_C291 0x850000 +#define SVR_C292 0x850020 +#define SVR_C293 0x850030 #define SVR_B4860 0X868000 #define SVR_G4860 0x868001 #define SVR_G4060 0x868003
C29XPCIE board is a series of Freescale PCIe add-in cards to perform as public key crypto accelerator or secure key management module. It includes C293PCIE board, C293PCIE board and C291PCIE board.
- 512KB platform SRAM in addition to 512K L2 Cache/SRAM - 512MB soldered DDR3 32bit memory - CPLD System Logic - 64MB x16 NOR flash and 4GB x8 NAND flash - 16MB SPI flash
Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Singed-off-by: Po Liu Po.Liu@freescale.com --- Base on tree git://git.denx.de/u-boot.git, modified integrate C291/C292/C293 to C29X. board/freescale/c29xpcie/Makefile | 34 +++ board/freescale/c29xpcie/c29xpcie.c | 150 ++++++++++ board/freescale/c29xpcie/cpld.c | 155 ++++++++++ board/freescale/c29xpcie/cpld.h | 53 ++++ board/freescale/c29xpcie/ddr.c | 89 ++++++ board/freescale/c29xpcie/law.c | 22 ++ board/freescale/c29xpcie/tlb.c | 89 ++++++ boards.cfg | 2 + include/configs/C29XPCIE.h | 551 ++++++++++++++++++++++++++++++++++++ 9 files changed, 1145 insertions(+) create mode 100644 board/freescale/c29xpcie/Makefile create mode 100644 board/freescale/c29xpcie/c29xpcie.c create mode 100644 board/freescale/c29xpcie/cpld.c create mode 100644 board/freescale/c29xpcie/cpld.h create mode 100644 board/freescale/c29xpcie/ddr.c create mode 100644 board/freescale/c29xpcie/law.c create mode 100644 board/freescale/c29xpcie/tlb.c create mode 100644 include/configs/C29XPCIE.h
diff --git a/board/freescale/c29xpcie/Makefile b/board/freescale/c29xpcie/Makefile new file mode 100644 index 0000000..15bef9a --- /dev/null +++ b/board/freescale/c29xpcie/Makefile @@ -0,0 +1,34 @@ +# +# Copyright 2013 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or modify it +# under the terms of the GNU General Public License as published by the Free +# Software Foundation; either version 2 of the License, or (at your option) +# any later version. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += cpld.o +COBJS-y += ddr.o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/c29xpcie/c29xpcie.c b/board/freescale/c29xpcie/c29xpcie.c new file mode 100644 index 0000000..21f3892 --- /dev/null +++ b/board/freescale/c29xpcie/c29xpcie.c @@ -0,0 +1,150 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/io.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <fsl_mdio.h> +#include <tsec.h> +#include <mmc.h> +#include <netdev.h> +#include <pci.h> +#include <asm/fsl_ifc.h> +#include <asm/fsl_pci.h> + +#include "cpld.h" + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + struct cpu_type *cpu = gd->arch.cpu; + + printf("Board: %sPCIe, ", cpu->name); + printf("CPLD Ver: 0x%02x\n", CPLD_READ(cpldver)); + + return 0; +} + +int board_early_init_f(void) +{ + struct fsl_ifc *ifc = (void *)CONFIG_SYS_IFC_ADDR; + + /* Clock configuration to access CPLD using IFC(GPCM) */ + setbits_be32(&ifc->ifc_gcr, 1 << IFC_GCR_TBCTL_TRN_TIME_SHIFT); + + return 0; +} + +int board_early_init_r(void) +{ + const unsigned long flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_64M, 1); + + return 0; +} + +#ifdef CONFIG_PCI +void pci_init_board(void) +{ + fsl_pcie_init_board(0); +} +#endif /* ifdef CONFIG_PCI */ + +#ifdef CONFIG_TSEC_ENET +int board_eth_init(bd_t *bis) +{ + struct fsl_pq_mdio_info mdio_info; + struct tsec_info_struct tsec_info[2]; + int num = 0; + +#ifdef CONFIG_TSEC1 + SET_STD_TSEC_INFO(tsec_info[num], 1); + num++; +#endif +#ifdef CONFIG_TSEC2 + SET_STD_TSEC_INFO(tsec_info[num], 2); + num++; +#endif + if (!num) { + printf("No TSECs initialized\n"); + return 0; + } + + /* Register 1G MDIO bus */ + mdio_info.regs = (struct tsec_mii_mng *)CONFIG_SYS_MDIO_BASE_ADDR; + mdio_info.name = DEFAULT_MII_NAME; + + fsl_pq_mdio_init(bis, &mdio_info); + + tsec_eth_init(bis, tsec_info, num); + + return pci_eth_init(bis); +} +#endif + +#if defined(CONFIG_OF_BOARD_SETUP) +void fdt_del_sec(void *blob, int offset) +{ + int nodeoff = 0; + + while ((nodeoff = fdt_node_offset_by_compat_reg(blob, "fsl,sec-v6.0", + CONFIG_SYS_CCSRBAR_PHYS + CONFIG_SYS_FSL_SEC_OFFSET + + offset * 0x20000)) >= 0) { + fdt_del_node(blob, nodeoff); + offset++; + } +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + struct cpu_type *cpu; + + cpu = gd->arch.cpu; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + +#if defined(CONFIG_PCI) + FT_FSL_PCI_SETUP; +#endif + + fdt_fixup_memory(blob, (u64)base, (u64)size); + if (cpu->soc_ver == SVR_C291) + fdt_del_sec(blob, 1); + else if (cpu->soc_ver == SVR_C292) + fdt_del_sec(blob, 2); +} +#endif diff --git a/board/freescale/c29xpcie/cpld.c b/board/freescale/c29xpcie/cpld.c new file mode 100644 index 0000000..54a8820 --- /dev/null +++ b/board/freescale/c29xpcie/cpld.c @@ -0,0 +1,155 @@ +/** + * Copyright 2013 Freescale Semiconductor + * Author: Mingkai Hu Mingkai.hu@freescale.com + * Po Liu Po.Liu@freescale.com + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + * + * This file provides support for the board-specific CPLD used on some Freescale + * reference boards. + * + * The following macros need to be defined: + * + * CONFIG_SYS_CPLD_BASE - The virtual address of the base of the + * CPLD register map + * + */ + +#include <common.h> +#include <command.h> +#include <asm/io.h> + +#include "cpld.h" + +static u8 __cpld_read(unsigned int reg) +{ + void *p = (void *)CONFIG_SYS_CPLD_BASE; + + return in_8(p + reg); +} + +u8 cpld_read(unsigned int reg) __attribute__((weak, alias("__cpld_read"))); + +static void __cpld_write(unsigned int reg, u8 value) +{ + void *p = (void *)CONFIG_SYS_CPLD_BASE; + + out_8(p + reg, value); +} + +void cpld_write(unsigned int reg, u8 value) + __attribute__((weak, alias("__cpld_write"))); + +/** + * Set the boot bank to the alternate bank + */ +void __cpld_set_altbank(u8 banksel) +{ + u8 reg11 = CPLD_READ(flhcsr); + + switch (banksel) { + case 1: + CPLD_WRITE(flhcsr, (reg11 & CPLD_BANKSEL_MASK) + | CPLD_BANKSEL_EN | CPLD_SELECT_BANK1); + break; + case 2: + CPLD_WRITE(flhcsr, (reg11 & CPLD_BANKSEL_MASK) + | CPLD_BANKSEL_EN | CPLD_SELECT_BANK2); + break; + case 3: + CPLD_WRITE(flhcsr, (reg11 & CPLD_BANKSEL_MASK) + | CPLD_BANKSEL_EN | CPLD_SELECT_BANK3); + break; + case 4: + CPLD_WRITE(flhcsr, (reg11 & CPLD_BANKSEL_MASK) + | CPLD_BANKSEL_EN | CPLD_SELECT_BANK4); + break; + default: + printf("Invalid value! [1-4]\n"); + return; + } + + udelay(100); + do_reset(NULL, 0, 0, NULL); +} + +void cpld_set_altbank(u8 banksel) + __attribute__((weak, alias("__cpld_set_altbank"))); + +/** + * Set the boot bank to the default bank + */ +void __cpld_set_defbank(void) +{ + __cpld_set_altbank(4); +} + +void cpld_set_defbank(void) + __attribute__((weak, alias("__cpld_set_defbank"))); + +#ifdef DEBUG +static void cpld_dump_regs(void) +{ + printf("chipid1 = 0x%02x\n", CPLD_READ(chipid1)); + printf("chipid2 = 0x%02x\n", CPLD_READ(chipid2)); + printf("hwver = 0x%02x\n", CPLD_READ(hwver)); + printf("cpldver = 0x%02x\n", CPLD_READ(cpldver)); + printf("rstcon = 0x%02x\n", CPLD_READ(rstcon)); + printf("flhcsr = 0x%02x\n", CPLD_READ(flhcsr)); + printf("wdcsr = 0x%02x\n", CPLD_READ(wdcsr)); + printf("wdkick = 0x%02x\n", CPLD_READ(wdkick)); + printf("fancsr = 0x%02x\n", CPLD_READ(fancsr)); + printf("ledcsr = 0x%02x\n", CPLD_READ(ledcsr)); + printf("misc = 0x%02x\n", CPLD_READ(misccsr)); + printf("bootor = 0x%02x\n", CPLD_READ(bootor)); + printf("bootcfg1 = 0x%02x\n", CPLD_READ(bootcfg1)); + printf("bootcfg2 = 0x%02x\n", CPLD_READ(bootcfg2)); + printf("bootcfg3 = 0x%02x\n", CPLD_READ(bootcfg3)); + printf("bootcfg4 = 0x%02x\n", CPLD_READ(bootcfg4)); + putc('\n'); +} +#endif + +int cpld_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int rc = 0; + unsigned char value; + + if (argc <= 1) + return cmd_usage(cmdtp); + + if (strcmp(argv[1], "reset") == 0) { + if (!strcmp(argv[2], "altbank") && argv[3]) { + value = (u8)simple_strtoul(argv[3], NULL, 16); + cpld_set_altbank(value); + } else if (!argv[2]) + cpld_set_defbank(); + else + cmd_usage(cmdtp); +#ifdef DEBUG + } else if (strcmp(argv[1], "dump") == 0) { + cpld_dump_regs(); +#endif + } else + rc = cmd_usage(cmdtp); + + return rc; +} + +U_BOOT_CMD( + cpld_cmd, CONFIG_SYS_MAXARGS, 1, cpld_cmd, + "Reset the board using the CPLD sequencer", + "reset - hard reset to default bank 4\n" + "cpld_cmd reset altbank [bank]- reset to alternate bank\n" + " - [bank] bank value select 1-4\n" + " - bank 1 on the flash 0x0000000~0x0ffffff\n" + " - bank 2 on the flash 0x1000000~0x1ffffff\n" + " - bank 3 on the flash 0x2000000~0x2ffffff\n" + " - bank 4 on the flash 0x3000000~0x3ffffff\n" +#ifdef DEBUG + "cpld_cmd dump - display the CPLD registers\n" +#endif + ); diff --git a/board/freescale/c29xpcie/cpld.h b/board/freescale/c29xpcie/cpld.h new file mode 100644 index 0000000..15d33cd --- /dev/null +++ b/board/freescale/c29xpcie/cpld.h @@ -0,0 +1,53 @@ +/** + * Copyright 2013 Freescale Semiconductor + * Author: Mingkai Hu Mingkai.Hu@freescale.com + * Po Liu Po.Liu@freescale.com + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + * + * This file provides support for the ngPIXIS, a board-specific FPGA used on + * some Freescale reference boards. + */ + +/* + * CPLD register set. Feel free to add board-specific #ifdefs where necessary. + */ +struct cpld_data { + u8 chipid1; /* 0x0 - CPLD Chip ID1 Register */ + u8 chipid2; /* 0x1 - CPLD Chip ID2 Register */ + u8 hwver; /* 0x2 - Hardware Version Register */ + u8 cpldver; /* 0x3 - Software Version Register */ + u8 res[12]; + u8 rstcon; /* 0x10 - Reset control register */ + u8 flhcsr; /* 0x11 - Flash control and status Register */ + u8 wdcsr; /* 0x12 - Watchdog control and status Register */ + u8 wdkick; /* 0x13 - Watchdog kick Register */ + u8 fancsr; /* 0x14 - Fan control and status Register */ + u8 ledcsr; /* 0x15 - LED control and status Register */ + u8 misccsr; /* 0x16 - Misc control and status Register */ + u8 bootor; /* 0x17 - Boot configure override Register */ + u8 bootcfg1; /* 0x18 - Boot configure 1 Register */ + u8 bootcfg2; /* 0x19 - Boot configure 2 Register */ + u8 bootcfg3; /* 0x1a - Boot configure 3 Register */ + u8 bootcfg4; /* 0x1b - Boot configure 4 Register */ +}; + +/* Pointer to the CPLD register set */ +#define cpld ((struct cpld_data *)CONFIG_SYS_CPLD_BASE) + +u8 cpld_read(unsigned int reg); +void cpld_write(unsigned int reg, u8 value); + +#define CPLD_BANKSEL_EN 0x02 +#define CPLD_BANKSEL_MASK 0x3f +#define CPLD_SELECT_BANK1 0xc0 +#define CPLD_SELECT_BANK2 0x80 +#define CPLD_SELECT_BANK3 0x40 +#define CPLD_SELECT_BANK4 0x00 + +#define CPLD_READ(reg) cpld_read(offsetof(struct cpld_data, reg)) +#define CPLD_WRITE(reg, value) cpld_write(offsetof(struct cpld_data, reg), \ + value) diff --git a/board/freescale/c29xpcie/ddr.c b/board/freescale/c29xpcie/ddr.c new file mode 100644 index 0000000..62476ca --- /dev/null +++ b/board/freescale/c29xpcie/ddr.c @@ -0,0 +1,89 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_ddr_dimm_params.h> + +/* + * Micron MT41J128M16HA-15E + * */ +dimm_params_t ddr_raw_timing = { + .n_ranks = 1, + .rank_density = 536870912u, + .capacity = 536870912u, + .primary_sdram_width = 32, + .ec_sdram_width = 8, + .registered_dimm = 0, + .mirrored_dimm = 0, + .n_row_addr = 14, + .n_col_addr = 10, + .n_banks_per_sdram_device = 8, + .edc_config = 2, + .burst_lengths_bitmask = 0x0c, + + .tCKmin_X_ps = 1650, + .caslat_X = 0x7e << 4, /* 5,6,7,8,9,10 */ + .tAA_ps = 14050, + .tWR_ps = 15000, + .tRCD_ps = 13500, + .tRRD_ps = 75000, + .tRP_ps = 13500, + .tRAS_ps = 40000, + .tRC_ps = 49500, + .tRFC_ps = 160000, + .tWTR_ps = 75000, + .tRTP_ps = 75000, + .refresh_rate_ps = 7800000, + .tFAW_ps = 30000, +}; + +int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, + unsigned int controller_number, + unsigned int dimm_number) +{ + const char dimm_model[] = "Fixed DDR on board"; + + if ((controller_number == 0) && (dimm_number == 0)) { + memcpy(pdimm, &ddr_raw_timing, sizeof(dimm_params_t)); + memset(pdimm->mpart, 0, sizeof(pdimm->mpart)); + memcpy(pdimm->mpart, dimm_model, sizeof(dimm_model) - 1); + } + + return 0; +} + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + int i; + popts->clk_adjust = 2; + popts->cpo_override = 0x1f; + popts->write_data_delay = 4; + popts->half_strength_driver_enable = 1; + popts->bstopre = 0x3cf; + popts->quad_rank_present = 1; + popts->rtt_override = 1; + popts->rtt_override_value = 1; + popts->dynamic_power = 1; + /* Write leveling override */ + popts->wrlvl_en = 1; + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + popts->wrlvl_start = 0x4; + popts->trwt_override = 1; + popts->trwt = 0; + + for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { + popts->cs_local_opts[i].odt_rd_cfg = FSL_DDR_ODT_NEVER; + popts->cs_local_opts[i].odt_wr_cfg = FSL_DDR_ODT_CS; + } +} diff --git a/board/freescale/c29xpcie/law.c b/board/freescale/c29xpcie/law.c new file mode 100644 index 0000000..064fa71 --- /dev/null +++ b/board/freescale/c29xpcie/law.c @@ -0,0 +1,22 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_64M, LAW_TRGT_IF_IFC), + SET_LAW(CONFIG_SYS_CPLD_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_IFC), + SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_IFC), + SET_LAW(CONFIG_SYS_PLATFORM_SRAM_BASE_PHYS, LAW_SIZE_512K, + LAW_TRGT_IF_PLATFORM_SRAM), +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/c29xpcie/tlb.c b/board/freescale/c29xpcie/tlb.c new file mode 100644 index 0000000..b793c2c --- /dev/null +++ b/board/freescale/c29xpcie/tlb.c @@ -0,0 +1,89 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024 , + CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024 , + CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024 , + CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* TLB 1 */ + /* *I*** - Covers boot page */ + SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_4K, 1), + + /* *I*G* - CCSRBAR */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + + SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, + 0, 2, BOOKE_PAGESZ_64M, 1), + +#ifdef CONFIG_PCI + /* *I*G* - PCI */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_PHYS, + MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI I/O */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_IO_VIRT, CONFIG_SYS_PCIE1_IO_PHYS, + MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 4, BOOKE_PAGESZ_256K, 1), +#endif + + /* *I*G - Board CPLD */ + SET_TLB_ENTRY(1, CONFIG_SYS_CPLD_BASE, CONFIG_SYS_CPLD_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 5, BOOKE_PAGESZ_4K, 1), + + SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 6, BOOKE_PAGESZ_1M, 1), + + /* *I*G - platform SRAM */ + SET_TLB_ENTRY(1, CONFIG_SYS_PLATFORM_SRAM_BASE, + CONFIG_SYS_PLATFORM_SRAM_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 7, BOOKE_PAGESZ_256K, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_PLATFORM_SRAM_BASE + 0x40000, + CONFIG_SYS_PLATFORM_SRAM_BASE_PHYS + 0x40000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 8, BOOKE_PAGESZ_256K, 1), + +#ifdef CONFIG_SYS_RAMBOOT + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, + CONFIG_SYS_DDR_SDRAM_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 9, BOOKE_PAGESZ_256M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000, + CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 10, BOOKE_PAGESZ_256M, 1), +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 1e598cb..e50c4c3 100644 --- a/boards.cfg +++ b/boards.cfg @@ -771,6 +771,8 @@ MPC8569MDS_NAND powerpc mpc85xx mpc8569mds freesca MPC8572DS powerpc mpc85xx mpc8572ds freescale - MPC8572DS MPC8572DS_36BIT powerpc mpc85xx mpc8572ds freescale - MPC8572DS:36BIT MPC8572DS_NAND powerpc mpc85xx mpc8572ds freescale - MPC8572DS:NAND +C29XPCIE powerpc mpc85xx c29xpcie freescale - C29XPCIE:C29XPCIE,36BIT +C29XPCIE_SPIFLASH powerpc mpc85xx c29xpcie freescale - C29XPCIE:C29XPCIE,36BIT,SPIFLASH P1010RDB_36BIT_NAND powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,NAND P1010RDB_36BIT_NAND_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,NAND_SECBOOT,SECURE_BOOT P1010RDB_36BIT_NOR powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h new file mode 100644 index 0000000..221d0b6 --- /dev/null +++ b/include/configs/C29XPCIE.h @@ -0,0 +1,551 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * C29XPCIE board configuration file + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifdef CONFIG_36BIT +#define CONFIG_PHYS_64BIT +#endif + +#ifdef CONFIG_C29XPCIE +#define CONFIG_C29X +#endif + +#ifdef CONFIG_SPIFLASH +#define CONFIG_RAMBOOT_SPIFLASH +#define CONFIG_SYS_TEXT_BASE 0x11000000 +#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc +#endif + +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xeff80000 +#endif + +#ifndef CONFIG_RESET_VECTOR_ADDRESS +#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc +#endif + +#ifndef CONFIG_SYS_MONITOR_BASE +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE /* BOOKE */ +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_MPC85xx +#define CONFIG_FSL_IFC /* Enable IFC Support */ +#define CONFIG_SYS_HAS_SERDES /* common SERDES init code */ + +#define CONFIG_PCI /* Enable PCI/PCIE */ +#ifdef CONFIG_PCI +#define CONFIG_PCIE1 /* PCIE controler 1 (slot 1) */ +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_PCI_INDIRECT_BRIDGE +#define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ +#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ + +#define CONFIG_CMD_NET +#define CONFIG_CMD_PCI + +#define CONFIG_E1000 + +/* Add Sil3132 support */ +#define CONFIG_CMD_SATA +#define CONFIG_SATA_SIL +#define CONFIG_SYS_SATA_MAX_DEVICE 1 +#define CONFIG_LIBATA +#define CONFIG_LBA48 + +/* + * PCI Windows + * Memory space is mapped 1-1, but I/O space must start from 0. + */ +/* controller 1, Slot 1, tgtid 1, Base address a000 */ +#define CONFIG_SYS_PCIE1_NAME "Slot 1" +#define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull +#else +#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0x80000000 +#endif +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE1_IO_VIRT 0xffc00000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE1_IO_PHYS 0xfffc00000ull +#else +#define CONFIG_SYS_PCIE1_IO_PHYS 0xffc00000 +#endif + +#define CONFIG_PCI_PNP /* do pci plug-and-play */ + +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_DOS_PARTITION +#endif + +#define CONFIG_FSL_LAW /* Use common FSL init code */ +#define CONFIG_TSEC_ENET +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_DDR_CLK_FREQ 100000000 +#define CONFIG_SYS_CLK_FREQ 66666666 + +#define CONFIG_HWCONFIG + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE /* toggle L2 cache */ +#define CONFIG_BTB /* toggle branch predition */ + +#define CONFIG_ADDR_STREAMING /* toggle addr streaming */ + +#define CONFIG_ENABLE_36BIT_PHYS + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_ADDR_MAP 1 +#define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ +#endif + +#define CONFIG_SYS_MEMTEST_START 0x00200000 +#define CONFIG_SYS_MEMTEST_END 0x00400000 +#define CONFIG_PANIC_HANG + +/* DDR Setup */ +#define CONFIG_FSL_DDR3 +#define CONFIG_DDR_SPD +#define CONFIG_SYS_SPD_BUS_NUM 0 +#define SPD_EEPROM_ADDRESS 0x50 +#define CONFIG_SYS_DDR_RAW_TIMING + +#define CONFIG_DDR_ECC + +#ifdef CONFIG_DDR_ECC +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#endif + +#define CONFIG_SYS_SDRAM_SIZE 512 +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL 1 + +#define CONFIG_SYS_CCSRBAR 0xffe00000 +#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR + +/* Platform SRAM setting */ +#define CONFIG_SYS_PLATFORM_SRAM_BASE 0xffb00000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PLATFORM_SRAM_BASE_PHYS \ + (0xf00000000ull | CONFIG_SYS_PLATFORM_SRAM_BASE) +#else +#define CONFIG_SYS_PLATFORM_SRAM_BASE_PHYS CONFIG_SYS_PLATFORM_SRAM_BASE +#endif +#define CONFIG_SYS_PLATFORM_SRAM_SIZE (512 << 10) + +/* + * IFC Definitions + */ +/* NOR Flash on IFC */ +#define CONFIG_SYS_FLASH_BASE 0xec000000 +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* 64M */ + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) +#else +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#endif + +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE_PHYS } +#define CONFIG_SYS_MAX_FLASH_BANKS 1 + +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* in ms */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* in ms */ + +/* 16Bit NOR Flash - S29GL512S10TFI01 */ +#define CONFIG_SYS_NOR_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(64*1024*1024) +#define CONFIG_SYS_NOR_CSOR CSOR_NOR_ADM_SHIFT(4) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ + FTIM0_NOR_TEADC(0x5) | \ + FTIM0_NOR_TEAHC(0x5)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x1e) | \ + FTIM1_NOR_TRAD_NOR(0x0f) | \ + FTIM1_NOR_TSEQRAD_NOR(0x0f)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ + FTIM2_NOR_TCH(0x4) | \ + FTIM2_NOR_TWP(0x1c)) +#define CONFIG_SYS_NOR_FTIM3 0x0 + +/* CFI for NOR Flash */ +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE + +/* NAND Flash on IFC */ +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_BASE 0xff800000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_NAND_BASE_PHYS 0xfff800000ull +#else +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE +#endif + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +/* 8Bit NAND Flash - K9F1G08U0B */ +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_NAND \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_2 /* RAL = 2 Bytes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2k */ \ + | CSOR_NAND_SPRZ_64 /* Spare size = 64 */ \ + | CSOR_NAND_PB(64)) /* 64 Pages Per Block */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x01) | \ + FTIM0_NAND_TWP(0x0c) | \ + FTIM0_NAND_TWCHT(0x08) | \ + FTIM0_NAND_TWH(0x06)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x28) | \ + FTIM1_NAND_TWBE(0x1d) | \ + FTIM1_NAND_TRR(0x08) | \ + FTIM1_NAND_TRP(0x0c)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0c) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x18)) +#define CONFIG_SYS_NAND_FTIM3 (FTIM3_NAND_TWW(0x04)) + +#define CONFIG_SYS_NAND_DDR_LAW 11 + +/* Set up IFC registers for boot location NOR/NAND */ +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NAND_FTIM3 + +/* CPLD on IFC, selected by CS2 */ +#define CONFIG_SYS_CPLD_BASE 0xffdf0000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_CPLD_BASE_PHYS (0xf00000000ull \ + | CONFIG_SYS_CPLD_BASE) +#else +#define CONFIG_SYS_CPLD_BASE_PHYS CONFIG_SYS_CPLD_BASE +#endif + +#define CONFIG_SYS_CSPR2 (CSPR_PHYS_ADDR(CONFIG_SYS_CPLD_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) +#define CONFIG_SYS_AMASK2 IFC_AMASK(64*1024) +#define CONFIG_SYS_CSOR2 0x0 +/* CPLD Timing parameters for IFC CS2 */ +#define CONFIG_SYS_CS2_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define CONFIG_SYS_CS2_FTIM1 (FTIM1_GPCM_TACO(0x0e) | \ + FTIM1_GPCM_TRAD(0x1f)) +#define CONFIG_SYS_CS2_FTIM2 (FTIM2_GPCM_TCS(0x0e) | \ + FTIM2_GPCM_TCH(0x0) | \ + FTIM2_GPCM_TWP(0x1f)) +#define CONFIG_SYS_CS2_FTIM3 0x0 + +#if defined(CONFIG_RAMBOOT_SPIFLASH) +#define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC +#else +#undef CONFIG_SYS_RAMBOOT +#endif + +#define CONFIG_BOARD_EARLY_INIT_R + +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 +#define CONFIG_SYS_INIT_RAM_END 0x00004000 + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END \ + - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) + +/* Serial Port */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_SERIAL_MULTI /* Enable both serial ports */ +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +/* + * Pass open firmware flat tree + */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +#define CONFIG_FSL_I2C +#define CONFIG_HARD_I2C +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_CMD_TREE +#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +/* I2C EEPROM */ +/* enable read and write access to EEPROM */ +#define CONFIG_CMD_EEPROM +#define CONFIG_SYS_I2C_MULTI_EEPROMS +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + +#define CONFIG_CMD_I2C + +/* eSPI - Enhanced SPI */ +#define CONFIG_FSL_ESPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SPANSION +#define CONFIG_SPI_FLASH_EON +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 + +#ifdef CONFIG_TSEC_ENET +#ifndef CONFIG_NET_MULTI +#define CONFIG_NET_MULTI +#endif + +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ +#define CONFIG_TSEC1 1 +#define CONFIG_TSEC1_NAME "eTSEC1" +#define CONFIG_TSEC2 1 +#define CONFIG_TSEC2_NAME "eTSEC2" + +/* Default mode is RGMII mode */ +#define TSEC1_PHY_ADDR 0 +#define TSEC2_PHY_ADDR 2 + +#define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +#define CONFIG_ETHPRIME "eTSEC1" + +#define CONFIG_PHY_GIGE +#endif /* CONFIG_TSEC_ENET */ + +/* + * Environment + */ +#if defined(CONFIG_SYS_RAMBOOT) +#if defined(CONFIG_RAMBOOT_SPIFLASH) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_SECT_SIZE 0x10000 +#define CONFIG_ENV_SIZE 0x2000 +#endif +#else +#define CONFIG_ENV_IS_IN_FLASH +#if CONFIG_SYS_MONITOR_BASE > 0xfff80000 +#define CONFIG_ENV_ADDR 0xfff80000 +#else +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#endif +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 +#endif + +#define CONFIG_LOADS_ECHO +#define CONFIG_SYS_LOADS_BAUD_CHANGE + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ERRATA +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_REGINFO + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ + +#ifdef CONFIG_CMD_KGDB +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) + /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* dec freq: 1ms ticks */ + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 64 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial Memory map for Linux */ +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ + +#ifdef CONFIG_TSEC_ENET +#define CONFIG_HAS_ETH0 +#define CONFIG_HAS_ETH1 +#endif + +#define CONFIG_ROOTPATH "/opt/nfsroot" +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_UBOOTPATH u-boot.bin/* U-Boot image on TFTP server */ + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=" __stringify(CONFIG_DEF_HWCONFIG) "\0" \ + "netdev=eth0\0" \ + "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ + "loadaddr=1000000\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=rootfs.ext2.gz.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=c293pcie.dtb\0" \ + "bdev=sda1\0" \ + "hwconfig=usb1:dr_mode=host,phy_type=utmi\0" \ + "othbootargs=ramdisk_size=600000\0" \ + "usbfatboot=setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs; " \ + "usb start;" \ + "fatload usb 0:2 $loadaddr $bootfile;" \ + "fatload usb 0:2 $fdtaddr $fdtfile;" \ + "fatload usb 0:2 $ramdiskaddr $ramdiskfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr\0" \ + "usbext2boot=setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs; " \ + "usb start;" \ + "ext2load usb 0:4 $loadaddr $bootfile;" \ + "ext2load usb 0:4 $fdtaddr $fdtfile;" \ + "ext2load usb 0:4 $ramdiskaddr $ramdiskfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr\0" \ + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs; " \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_RAMBOOTCOMMAND + +#endif /* __CONFIG_H */
On 06/26/2013 02:23:30 AM, Po Liu wrote:
- set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS,
Don't set MAS3_SX on I/O mappings.
- /* *I*G - Board CPLD */
- SET_TLB_ENTRY(1, CONFIG_SYS_CPLD_BASE,
- SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE,
- /* *I*G - platform SRAM */
- SET_TLB_ENTRY(1, CONFIG_SYS_PLATFORM_SRAM_BASE,
- SET_TLB_ENTRY(1, CONFIG_SYS_PLATFORM_SRAM_BASE + 0x40000,
Why is this I+G?
Why are you adding non-36bit support that will not even get build testing?
- Internal Definitions
- Boot Flags
These are not used anywhere. Please go through this file and only retain things which actually continue to make sense.
- For booting Linux, the board info and command line data
- have to be in the first 64 MB of memory, since this is
- the maximum mapped by the Linux kernel during initialization.
Likewise, this KGDB stuff is bad copy-and-paste.
- Environment Configuration
- "hwconfig=" __stringify(CONFIG_DEF_HWCONFIG) "\0" \
- "netdev=eth0\0" \
- "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \
- "loadaddr=1000000\0" \
- "consoledev=ttyS0\0" \
- "ramdiskaddr=2000000\0" \
- "ramdiskfile=rootfs.ext2.gz.uboot\0" \
- "fdtaddr=c00000\0" \
- "fdtfile=c293pcie.dtb\0" \
Why c293? Doesn't this support c291 and c292 as well?
Better to not have any default, or an obviously non-working placeholder like fdtfile=name/of/device-tree.dtb
-Scott
Po Liu
Scott Wood
