[U-Boot] [PATCH 0/2 v12] Btrfs filesystem port to U-boot
Adnan Ali (2): Enable btrfs support in mx53loco config Introduced btrfs file-system with btrload command
Makefile | 1 + common/Makefile | 1 + common/cmd_btr.c | 65 +++ fs/btrfs/Makefile | 51 ++ fs/btrfs/btrfs.c | 1347 ++++++++++++++++++++++++++++++++++++++++++++ fs/fs.c | 10 + include/btrfs.h | 416 ++++++++++++++ include/config_fallbacks.h | 4 + include/configs/mx53loco.h | 4 +- include/crc.h | 8 + include/fs.h | 1 + lib/Makefile | 1 + lib/crc32_c.c | 40 ++ 13 files changed, 1948 insertions(+), 1 deletion(-) create mode 100644 common/cmd_btr.c create mode 100644 fs/btrfs/Makefile create mode 100644 fs/btrfs/btrfs.c create mode 100644 include/btrfs.h create mode 100644 lib/crc32_c.c
Signed-off-by: Adnan Ali adnan.ali@codethink.co.uk --- include/configs/mx53loco.h | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index a4b610f..bf361a3 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -56,6 +56,8 @@ #define CONFIG_GENERIC_MMC #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 +#define CONFIG_CMD_BTR +#define CONFIG_CMD_FS_GENERIC #define CONFIG_DOS_PARTITION
/* Eth Configs */ @@ -128,7 +130,7 @@ "mmcroot=/dev/mmcblk0p3 rw rootwait\0" \ "mmcargs=setenv bootargs console=ttymxc0,${baudrate} root=${mmcroot}\0" \ "loadbootscript=" \ - "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ "bootscript=echo Running bootscript from mmc ...; " \ "source\0" \ "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \
Introduces btrfs file-system to read file from volume/sub-volumes with btrload command. This implementation has read-only support. This btrfs implementation is based on syslinux btrfs code, commit 269ebc845ebc8b46ef4b0be7fa0005c7fdb95b8d.
v12: Warnings removed. v11: Mirro super block check. v10: patch problem reworked. v5: merged with master. v4: btrls command added.
Signed-off-by: Adnan Ali adnan.ali@codethink.co.uk --- Makefile | 1 + common/Makefile | 1 + common/cmd_btr.c | 65 +++ fs/btrfs/Makefile | 51 ++ fs/btrfs/btrfs.c | 1347 ++++++++++++++++++++++++++++++++++++++++++++ fs/fs.c | 10 + include/btrfs.h | 416 ++++++++++++++ include/config_fallbacks.h | 4 + include/crc.h | 8 + include/fs.h | 1 + lib/Makefile | 1 + lib/crc32_c.c | 40 ++ 12 files changed, 1945 insertions(+) create mode 100644 common/cmd_btr.c create mode 100644 fs/btrfs/Makefile create mode 100644 fs/btrfs/btrfs.c create mode 100644 include/btrfs.h create mode 100644 lib/crc32_c.c
diff --git a/Makefile b/Makefile index 55bd55c..bd7981d 100644 --- a/Makefile +++ b/Makefile @@ -257,6 +257,7 @@ endif LIBS-$(CONFIG_OF_EMBED) += dts/libdts.o LIBS-y += arch/$(ARCH)/lib/lib$(ARCH).o LIBS-y += fs/libfs.o \ + fs/btrfs/libbtrfs.o \ fs/cbfs/libcbfs.o \ fs/cramfs/libcramfs.o \ fs/ext4/libext4fs.o \ diff --git a/common/Makefile b/common/Makefile index 719fc23..d1fae56 100644 --- a/common/Makefile +++ b/common/Makefile @@ -73,6 +73,7 @@ COBJS-$(CONFIG_CMD_BEDBUG) += bedbug.o cmd_bedbug.o COBJS-$(CONFIG_CMD_BMP) += cmd_bmp.o COBJS-$(CONFIG_CMD_BOOTLDR) += cmd_bootldr.o COBJS-$(CONFIG_CMD_BOOTSTAGE) += cmd_bootstage.o +COBJS-$(CONFIG_CMD_BTR) += cmd_btr.o COBJS-$(CONFIG_CMD_CACHE) += cmd_cache.o COBJS-$(CONFIG_CMD_CBFS) += cmd_cbfs.o COBJS-$(CONFIG_CMD_CONSOLE) += cmd_console.o diff --git a/common/cmd_btr.c b/common/cmd_btr.c new file mode 100644 index 0000000..e22154d --- /dev/null +++ b/common/cmd_btr.c @@ -0,0 +1,65 @@ +/* + * (C) Copyright 2013 Codethink Limited + * Btrfs port to Uboot by + * Adnan Ali adnan.ali@codethink.co.uk + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Boot support + */ +#include <fs.h> +#include <btrfs.h> + +char subvolname[BTRFS_MAX_SUBVOL_NAME]; + +int do_btr_fsload(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + if (argc > 5) + strcpy(subvolname, argv[5]); + else + subvolname[0] = '\0'; + + return do_load(cmdtp, flag, argc, argv, FS_TYPE_BTR, 16); +} + + +U_BOOT_CMD( +btrload, 7, 0, do_btr_fsload, + "load binary file from a btr filesystem", + "<interface> [<dev[:part]>] <addr> <filename> [subvol_name]\n" + " - Load binary file 'filename' from 'dev' on 'interface'\n" + " to address 'addr' from better filesystem.\n" + " the load stops on end of file.\n" + " subvol_name is used read that file from this subvolume.\n" + " All numeric parameters are assumed to be hex." +); + +static int do_btr_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return do_ls(cmdtp, flag, argc, argv, FS_TYPE_BTR); +} + +U_BOOT_CMD( + btrls, 4, 1, do_btr_ls, + "list files in a directory (default /)", + "<interface> [<dev[:part]>] [directory]\n" + " - list files from 'dev' on 'interface' in a 'directory'" +); + diff --git a/fs/btrfs/Makefile b/fs/btrfs/Makefile new file mode 100644 index 0000000..a9e2021 --- /dev/null +++ b/fs/btrfs/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2003 +# Pavel Bartusek, Sysgo Real-Time Solutions AG, pba@sysgo.de +# +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libbtrfs.o + +AOBJS = +COBJS-$(CONFIG_FS_BTR) := btrfs.o + +SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) + + +all: $(LIB) $(AOBJS) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/fs/btrfs/btrfs.c b/fs/btrfs/btrfs.c new file mode 100644 index 0000000..a7fcc16 --- /dev/null +++ b/fs/btrfs/btrfs.c @@ -0,0 +1,1347 @@ +/* + * (C) Copyright 2013 Codethink Limited + * Btrfs port to Uboot by + * Adnan Ali adnan.ali@codethink.co.uk + + * btrfs.c -- readonly btrfs support for syslinux + * Some data structures are derivated from btrfs-tools-0.19 ctree.h + * Copyright 2009 Intel Corporation; author: alek.du@intel.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation, Inc., 53 Temple Place Ste 330, + * Boston MA 02111-1307, USA; either version 2 of the License, or + * (at your option) any later version; incorporated herein by reference. + * + */ + +#include <malloc.h> +#include <common.h> +#include <btrfs.h> +#include <command.h> +#include <config.h> +#include <crc.h> +#include <fs.h> +#include <linux/compiler.h> +#include <linux/ctype.h> +#include <linux/stat.h> +#include <asm/byteorder.h> + +unsigned long btr_part_offset; +static char crc_table_built; +/* Actual file structures (we don't have malloc yet...) */ +struct file files[BTRFS_MAX_OPEN]; +static u32 btrfs_crc32_table[256]; +static block_dev_desc_t *btrfs_block_dev_desc; +static disk_partition_t *part_info; +struct inode parent_inode; + +static void btrfs_init_crc32c(void) +{ + /* Bit-reflected CRC32C polynomial */ + crc32c_init(btrfs_crc32_table, 0x82F63B78); +} + +static inline u32 crc32c_le(u32 crc, const char *data, size_t length) +{ + return crc32c_cal(crc, data, length, btrfs_crc32_table); +} + +void btrfs_type(char num) +{ + switch (num) { + case BTRFS_FILE: + puts("<FILE> "); break; + case BTRFS_DIR: + puts("<DIR> "); break; + case BTRFS_SYMLNK: + puts("<SYM> "); break; + default: + puts("<UNKNOWN>"); break; + } +} + +static inline __le32 next_psector(__le32 psector, uint32_t skip) +{ + if (EXTENT_SPECIAL(psector)) + return psector; + else + return psector + skip; +} + +static inline __le32 next_pstart(const struct extent *e) +{ + return next_psector(e->pstart, e->len); +} + +static inline struct inode *get_inode(struct inode *inode) +{ + inode->refcnt++; + + return inode; +} + +/* compare function used for bin_search */ +typedef int (*cmp_func)(void *ptr1, void *ptr2); + +static int bin_search(void *ptr, int item_size, void *cmp_item, cmp_func func, + int min, int max, int *slot) +{ + int low = min; + int high = max; + int mid; + int ret; + unsigned long offset; + void *item; + + while (low < high) { + mid = (low + high) / 2; + offset = mid * item_size; + + item = ptr + offset; + ret = func(item, cmp_item); + + if (ret < 0) + low = mid + 1; + else if (ret > 0) + high = mid; + else { + *slot = mid; + return 0; + } + } + *slot = low; + + return 1; +} + +/* XXX: these should go into the filesystem instance structure */ +static struct btrfs_chunk_map chunk_map; +static struct btrfs_super_block sb; +static u64 fs_tree; +/* compare btrfs chunk map in list*/ +static int btrfs_comp_chunk_map(struct btrfs_chunk_map_item *m1, + struct btrfs_chunk_map_item *m2) +{ + if (__le64_to_cpu(m1->logical) > __le64_to_cpu(m2->logical)) + return 1; + + if (__le64_to_cpu(m1->logical) < __le64_to_cpu(m2->logical)) + return -1; + + return 0; +} + +/* insert a new chunk mapping item */ +static void insert_map(struct btrfs_chunk_map_item *item) +{ + int ret; + int slot; + int i; + + if (chunk_map.map == NULL) { /* first item */ + chunk_map.map_length = BTRFS_MAX_CHUNK_ENTRIES; + chunk_map.map = (struct btrfs_chunk_map_item *) + malloc(chunk_map.map_length * sizeof(*chunk_map.map)); + chunk_map.map[0] = *item; + chunk_map.cur_length = 1; + + return; + } + ret = bin_search(chunk_map.map, sizeof(*item), item, + (cmp_func)btrfs_comp_chunk_map, 0, + chunk_map.cur_length, &slot); + if (ret == 0)/* already in map */ + return; + + if (chunk_map.cur_length == BTRFS_MAX_CHUNK_ENTRIES) { + /* should be impossible */ + puts("too many chunk items\n"); + return; + } + for (i = chunk_map.cur_length; i > slot; i--) + chunk_map.map[i] = chunk_map.map[i-1]; + chunk_map.map[slot] = *item; + chunk_map.cur_length++; +} + +/* + * from sys_chunk_array or chunk_tree, we can convert a logical address to + * a physical address we can not support multi device case yet + */ +static u64 logical_physical(u64 logical) +{ + struct btrfs_chunk_map_item item; + int slot, ret; + + item.logical = logical; + ret = bin_search(chunk_map.map, sizeof(*chunk_map.map), &item, + (cmp_func)btrfs_comp_chunk_map, 0, + chunk_map.cur_length, &slot); + if (ret == 0) + slot++; + else if (slot == 0) + return -1; + + if (logical >= + chunk_map.map[slot-1].logical + chunk_map.map[slot-1].length) + return -1; + + return chunk_map.map[slot-1].physical + logical - + chunk_map.map[slot-1].logical; +} + +int btrfs_devread(int sector, int byte_offset, int byte_len, char *buf) +{ + ALLOC_CACHE_ALIGN_BUFFER(char, sec_buf, BTRFS_SS); + unsigned block_len; + + /* Get the read to the beginning of a partition */ + sector += byte_offset >> BTRFS_SECTOR_BITS; + byte_offset &= BTRFS_SS - 1; + + if (btrfs_block_dev_desc == NULL) { + puts("** Invalid Block Device Descriptor (NULL)\n"); + return 0; + } + if (byte_offset != 0) { + /* read first part which isn't aligned with start of sector */ + if (btrfs_block_dev_desc-> + block_read(btrfs_block_dev_desc->dev, + part_info->start + sector, 1, + (unsigned long *) sec_buf) != 1) { + puts(" ** btrfs_devread() read error **\n"); + return 0; + } + memcpy(buf, sec_buf + byte_offset, + min(BTRFS_SS - byte_offset, byte_len)); + buf += min(BTRFS_SS - byte_offset, byte_len); + byte_len -= min(BTRFS_SS - byte_offset, byte_len); + sector++; + } + /* read sector aligned part */ + + block_len = byte_len & ~(BTRFS_SS - 1); + + if (block_len == 0) { + ALLOC_CACHE_ALIGN_BUFFER(u8, p, BTRFS_SS); + + block_len = BTRFS_SS; + btrfs_block_dev_desc->block_read(btrfs_block_dev_desc->dev, + part_info->start + sector, + 1, (unsigned long *)p); + memcpy(buf, p, byte_len); + return 1; + } + ALLOC_CACHE_ALIGN_BUFFER(u8, t, block_len); + if (btrfs_block_dev_desc->block_read(btrfs_block_dev_desc->dev, + part_info->start + sector, + block_len / BTRFS_SS, + (unsigned long *) t) != + block_len / BTRFS_SS) { + debug(" ** %s read error - block\n", __func__); + return 0; + } + + memcpy(buf, t, block_len); + block_len = byte_len & ~(BTRFS_SS - 1); + buf += block_len; + byte_len -= block_len; + sector += block_len / BTRFS_SS; + if (byte_len != 0) { + /* read rest of data which are not in whole sector */ + if (btrfs_block_dev_desc-> + block_read(btrfs_block_dev_desc->dev, + part_info->start + sector, 1, + (unsigned long *) sec_buf) != 1) { + debug("* %s read error - last part\n", __func__); + return 0; + } + memcpy(buf, sec_buf, byte_len); + } + + return 1; +} +/* btrfs has several super block mirrors, need to calculate their location */ +static inline u64 btrfs_sb_offset(int mirror) +{ + u64 start = 16 * 1024; + + if (mirror) + return start << (BTRFS_SUPER_MIRROR_SHIFT * mirror); + + return BTRFS_SUPER_INFO_OFFSET; +} + +/* find the most recent super block */ +static int btrfs_read_super_block(struct btrfs_info *fs) +{ + int i; + u8 fsid[BTRFS_FSID_SIZE]; + u64 offset; + u64 transid = 0; + struct btrfs_super_block buf; + + sb.total_bytes = ~0; /* Unknown as of yet */ + + /* + * Only first header is checked for filesystem verification + * mirror of this header can be used if required + */ + /* find most recent super block */ + for (i = 0; i < BTRFS_SUPER_MIRROR_MAX; i++) { + + offset = btrfs_sb_offset(i); + if (offset >= sb.total_bytes) + break; + + if (btrfs_devread((offset/BTRFS_SS), 0, + sizeof(struct btrfs_super_block), + (char *)&buf) != 1) + return -1; + + if (buf.bytenr != offset || + strncmp((char *)(&buf.magic), + BTRFS_MAGIC, sizeof(buf.magic))) + return -1; + + if (i == 0) + memcpy(fsid, buf.fsid, sizeof(fsid)); + else if (memcmp(fsid, buf.fsid, sizeof(fsid))) { + puts("fsid doesn't match\n"); + return -1; + } + + if (buf.generation > transid) { + memcpy(&sb, &buf, sizeof(sb)); + transid = buf.generation; + } + } + + return 0; +} + +static inline unsigned long btrfs_chunk_item_size(int num_stripes) +{ + return sizeof(struct btrfs_chunk) + + sizeof(struct btrfs_stripe) * (num_stripes - 1); +} + +static void clear_path(struct btrfs_path *path) +{ + memset(path, 0, sizeof(*path)); +} + +static int btrfs_comp_keys(struct btrfs_disk_key *k1, struct btrfs_disk_key *k2) +{ + if (k1->objectid > k2->objectid) + return 1; + if (k1->objectid < k2->objectid) + return -1; + if (k1->type > k2->type) + return 1; + if (k1->type < k2->type) + return -1; + if (k1->offset > k2->offset) + return 1; + if (k1->offset < k2->offset) + return -1; + + return 0; +} + +/* compare keys but ignore offset, is useful to enumerate all same kind keys */ +static int btrfs_comp_keys_type(struct btrfs_disk_key *k1, + struct btrfs_disk_key *k2) +{ + if (k1->objectid > k2->objectid) + return 1; + if (k1->objectid < k2->objectid) + return -1; + if (k1->type > k2->type) + return 1; + if (k1->type < k2->type) + return -1; + + return 0; +} + +/* seach tree directly on disk ... */ +static int search_tree(struct btrfs_info *fs, u64 loffset, + struct btrfs_disk_key *key, struct btrfs_path *path) +{ + u8 buf[BTRFS_MAX_LEAF_SIZE]; + struct btrfs_header *header = (struct btrfs_header *)buf; + struct btrfs_node *node = (struct btrfs_node *)buf; + struct btrfs_leaf *leaf = (struct btrfs_leaf *)buf; + int slot, ret; + u64 offset; + + offset = logical_physical(loffset); + btrfs_devread(offset/BTRFS_SS, (offset%BTRFS_SS), + sizeof(*header), (char *)header); + if (header->level) { /*node*/ + btrfs_devread(((offset+sizeof(*header))/BTRFS_SS), + ((offset+sizeof(*header))%BTRFS_SS), + __le32_to_cpu(sb.nodesize) - sizeof(*header), + (char *)&node->ptrs[0]); + path->itemsnr[header->level] = header->nritems; + path->offsets[header->level] = loffset; + ret = bin_search(&node->ptrs[0], sizeof(struct btrfs_key_ptr), + key, (cmp_func)btrfs_comp_keys, + path->slots[header->level], header->nritems, &slot); + if (ret && slot > path->slots[header->level]) + slot--; + path->slots[header->level] = slot; + ret = search_tree(fs, node->ptrs[slot].blockptr, key, path); + } else { /*leaf*/ + btrfs_devread(((offset+sizeof(*header))/BTRFS_SS), + ((offset+sizeof(*header))%BTRFS_SS), + (sb.leafsize) - sizeof(*header), + (char *)&leaf->items); + path->itemsnr[header->level] = header->nritems; + path->offsets[0] = loffset; + ret = bin_search(&leaf->items[0], sizeof(struct btrfs_item), + key, (cmp_func)btrfs_comp_keys, path->slots[0], + header->nritems, &slot); + if (ret && slot > path->slots[header->level]) + slot--; + path->slots[0] = slot; + path->item = leaf->items[slot]; + btrfs_devread( + ((offset + sizeof(*header) + leaf->items[slot].offset) + /BTRFS_SS), + ((offset + sizeof(*header) + leaf->items[slot].offset) + %BTRFS_SS), + leaf->items[slot].size, (char *)&path->data); + } + + return ret; +} + +/* return 0 if leaf found */ +static int next_leaf(struct btrfs_info *fs, struct btrfs_disk_key *key, + struct btrfs_path *path) +{ + int slot; + int level = 1; + + while (level < BTRFS_MAX_LEVEL) { + if (!path->itemsnr[level]) /* no more nodes */ + return 1; + + slot = path->slots[level] + 1; + if (slot >= path->itemsnr[level]) { + level++; + continue; + } + path->slots[level] = slot; + path->slots[level-1] = 0; /* reset low level slots info */ + search_tree(fs, path->offsets[level], key, path); + break; + } + if (level == BTRFS_MAX_LEVEL) + return 1; + + return 0; +} + +/* return 0 if slot found */ +static int next_slot(struct btrfs_info *fs, struct btrfs_disk_key *key, + struct btrfs_path *path) +{ + int slot; + + if (!path->itemsnr[0]) + return 1; + + slot = path->slots[0] + 1; + if (slot >= path->itemsnr[0]) + return 1; + + path->slots[0] = slot; + search_tree(fs, path->offsets[0], key, path); + + return 0; +} + +/* + * read chunk_array in super block + */ +static void btrfs_read_sys_chunk_array(void) +{ + struct btrfs_chunk_map_item item; + struct btrfs_disk_key *key; + struct btrfs_chunk *chunk; + int cur; + + /* read chunk array in superblock */ + cur = 0; + + while (cur < __le32_to_cpu(sb.sys_chunk_array_size)) { + key = (struct btrfs_disk_key *)(sb.sys_chunk_array + cur); + cur += sizeof(*key); + chunk = (struct btrfs_chunk *)(sb.sys_chunk_array + cur); + cur += btrfs_chunk_item_size(chunk->num_stripes); + /* insert to mapping table, ignore multi stripes */ + item.logical = key->offset; + item.length = chunk->length; + item.devid = chunk->stripe.devid; + item.physical = chunk->stripe.offset;/*ignore other stripes */ + insert_map(&item); + } +} + +/* read chunk items from chunk_tree and insert them to chunk map */ +static void btrfs_read_chunk_tree(struct btrfs_info *fs) +{ + struct btrfs_disk_key search_key; + struct btrfs_chunk *chunk; + struct btrfs_chunk_map_item item; + struct btrfs_path path; + + if (!(__le64_to_cpu(sb.flags) & BTRFS_SUPER_FLAG_METADUMP)) { + if (__le64_to_cpu(sb.num_devices) > 1) { + debug("warning: only support one btrfs device %lld\n", + __le64_to_cpu(sb.num_devices)); + return; + } + /* read chunk from chunk_tree */ + search_key.objectid = BTRFS_FIRST_CHUNK_TREE_OBJECTID; + search_key.type = BTRFS_CHUNK_ITEM_KEY; + search_key.offset = 0; + clear_path(&path); + search_tree(fs, (sb.chunk_root), &search_key, &path); + do { + do { + if (btrfs_comp_keys_type(&search_key, + &path.item.key)) + break; + chunk = (struct btrfs_chunk *)(path.data); + /* insert to mapping table, ignore stripes */ + item.logical = path.item.key.offset; + item.length = chunk->length; + item.devid = chunk->stripe.devid; + item.physical = chunk->stripe.offset; + insert_map(&item); + } while (!next_slot(fs, &search_key, &path)); + if (btrfs_comp_keys_type(&search_key, &path.item.key)) + break; + } while (!next_leaf(fs, &search_key, &path)); + } +} + +static inline u64 btrfs_name_hash(const char *name, int len) +{ + return btrfs_crc32c((u32)~1, name, len); +} + +static struct inode *btrfs_iget_by_inr(struct btrfs_info *fs, u64 inr) +{ + struct inode *inode; + struct btrfs_inode_item *inode_item; + struct btrfs_disk_key search_key; + struct btrfs_path path; + struct btrfs_pvt_inode *pvt; + int ret; + + /* + *FIXME: some BTRFS inode member are u64, while our logical inode + *is u32, we may need change them to u64 later + */ + search_key.objectid = inr; + search_key.type = BTRFS_INODE_ITEM_KEY; + search_key.offset = 0; + clear_path(&path); + ret = search_tree(fs, fs_tree, &search_key, &path); + if (ret) { + debug("%s search_tree failed\n", __func__); + return NULL; + } + + inode_item = (struct btrfs_inode_item *)path.data; + inode = alloc_inode(fs, inr, sizeof(struct btrfs_pvt_inode)); + if (!(inode)) { + debug("%s alloc_inode failed\n", __func__); + return NULL; + } + inode->ino = inr; + inode->size = inode_item->size; + inode->mode = BTRFS_IFTODT(inode_item->mode); + if (inode->mode == BTRFS_DT_REG || inode->mode == BTRFS_DT_LNK) { + struct btrfs_file_extent_item *extent_item; + u64 offset; + + /* get file_extent_item */ + search_key.type = BTRFS_EXTENT_DATA_KEY; + search_key.offset = 0; + clear_path(&path); + ret = search_tree(fs, fs_tree, &search_key, &path); + if (ret) + return NULL; /* impossible */ + extent_item = (struct btrfs_file_extent_item *)path.data; + if (extent_item->type == BTRFS_FILE_EXTENT_INLINE) + offset = path.offsets[0] + sizeof(struct btrfs_header) + + path.item.offset + + offsetof(struct btrfs_file_extent_item, + disk_bytenr); + else + offset = extent_item->disk_bytenr; + pvt = (struct btrfs_pvt_inode *)inode->pvt; + pvt->offset = offset; + } + + return inode; +} + +static struct inode *btrfs_iget_root(struct btrfs_info *fs) +{ + /* BTRFS_FIRST_CHUNK_TREE_OBJECTID(256) actually + * is first OBJECTID for FS_TREE + */ + return btrfs_iget_by_inr(fs, BTRFS_FIRST_CHUNK_TREE_OBJECTID); +} + +static struct inode *btrfs_iget(const char *name, struct inode *parent) +{ + struct btrfs_info *fs = parent->fs; + struct btrfs_disk_key search_key; + struct btrfs_path path; + struct btrfs_dir_item dir_item; + int ret; + + search_key.objectid = parent->ino; + search_key.type = BTRFS_DIR_ITEM_KEY; + search_key.offset = btrfs_name_hash(name, strlen(name)); + clear_path(&path); + ret = search_tree(fs, fs_tree, &search_key, &path); + if (ret) + return NULL; + + dir_item = *(struct btrfs_dir_item *)path.data; + + return btrfs_iget_by_inr(fs, dir_item.location.objectid); +} + +static int btrfs_readlink(struct inode *inode, char *buf) +{ + struct btrfs_pvt_inode *pvt = (struct btrfs_pvt_inode *)inode->pvt; + btrfs_devread((logical_physical(pvt->offset)/BTRFS_SS), + (logical_physical(pvt->offset)%BTRFS_SS), + inode->size, (char *)buf); + buf[inode->size] = '\0'; + return inode->size; +} + +static int btrfs_readdir(struct file *file, struct btrfs_dirent *btrfs_dirent) +{ + struct btrfs_info *fs = file->fs; + struct inode *inode = file->inode; + struct btrfs_disk_key search_key; + struct btrfs_path path; + struct btrfs_dir_item *dir_item; + int ret; + + /* + * we use file->offset to store last search key.offset, will will search + * key that lower that offset, 0 means first search and we will search + * -1UL, which is the biggest possible key + */ + search_key.objectid = inode->ino; + search_key.type = BTRFS_DIR_ITEM_KEY; + search_key.offset = file->offset - 1; + clear_path(&path); + ret = search_tree(fs, fs_tree, &search_key, &path); + + if (ret) { + if (btrfs_comp_keys_type(&search_key, &path.item.key)) + return -1; + } + + dir_item = (struct btrfs_dir_item *)path.data; + file->offset = path.item.key.offset; + btrfs_dirent->d_ino = dir_item->location.objectid; + btrfs_dirent->d_off = file->offset; + btrfs_dirent->d_reclen = offsetof(struct btrfs_dirent, d_name) + + dir_item->name_len + 1; + btrfs_dirent->d_type = BTRFS_IFTODT(dir_item->type); + memcpy(btrfs_dirent->d_name, dir_item + 1, dir_item->name_len); + btrfs_dirent->d_name[dir_item->name_len] = '\0'; + btrfs_type(dir_item->type); + printf(" %s\n", btrfs_dirent->d_name); + + return 0; +} + +static int btrfs_next_extent(struct inode *inode, uint32_t lstart) +{ + struct btrfs_disk_key search_key; + struct btrfs_file_extent_item *extent_item; + struct btrfs_path path; + int ret; + u64 offset; + struct btrfs_info *fs = inode->fs; + struct btrfs_pvt_inode *pvt; + u32 sec_shift = BTRFS_SECTOR_BITS; + u32 sec_size = BTRFS_SS; + + search_key.objectid = inode->ino; + search_key.type = BTRFS_EXTENT_DATA_KEY; + search_key.offset = lstart << sec_shift; + clear_path(&path); + ret = search_tree(fs, fs_tree, &search_key, &path); + if (ret) { /* impossible */ + puts("btrfs: search extent data error\n"); + return -1; + } + extent_item = (struct btrfs_file_extent_item *)path.data; + + if (extent_item->encryption) { + puts("btrfs: found encrypted data, cannot continue\n"); + return -1; + } + if (extent_item->compression) { + puts("btrfs: found compressed data, cannot continue\n"); + return -1; + } + + if (extent_item->type == BTRFS_FILE_EXTENT_INLINE) {/* inline file */ + /* we fake a extent here, and PVT of inode will tell us */ + offset = path.offsets[0] + sizeof(struct btrfs_header) + + path.item.offset + + offsetof(struct btrfs_file_extent_item, disk_bytenr); + inode->next_extent.len = + (inode->size + sec_size - 1) >> sec_shift; + } else { + offset = extent_item->disk_bytenr + extent_item->offset; + inode->next_extent.len = + (extent_item->num_bytes + sec_size - 1) >> sec_shift; + } + inode->next_extent.pstart = + logical_physical(offset) >> sec_shift; + pvt = (struct btrfs_pvt_inode *)inode->pvt; + pvt->offset = offset; + return 0; +} + +static uint32_t btrfs_getfssec(struct file *file, char *buf, int sectors, + char *have_more) +{ + u32 ret; + struct btrfs_pvt_inode *pvt = + (struct btrfs_pvt_inode *)file->inode->pvt; + u32 off = pvt->offset % BTRFS_SS; + char handle_inline = 0; + + if (off && !file->offset) {/* inline file first read patch */ + file->inode->size += off; + handle_inline = 1; + } + ret = generic_getfssec(file, buf, sectors, have_more); + if (!ret) + return ret; + + off = pvt->offset % BTRFS_SS; + if (handle_inline) {/* inline file patch */ + ret -= off; + memcpy(buf, buf + off, ret); + } + + return ret; +} + +static void btrfs_get_fs_tree(struct btrfs_info *fs) +{ + struct btrfs_disk_key search_key; + struct btrfs_path path; + struct btrfs_root_item *tree; + char subvol_ok = 0; + + /* check if subvol is filled by installer */ + if (*subvolname) { + search_key.objectid = BTRFS_FS_TREE_OBJECTID; + search_key.type = BTRFS_ROOT_REF_KEY; + search_key.offset = 0; + clear_path(&path); + if (search_tree(fs, __le64_to_cpu(sb.root), &search_key, &path)) + next_slot(fs, &search_key, &path); + do { + do { + struct btrfs_root_ref *ref; + int pathlen; + + if (btrfs_comp_keys_type(&search_key, + &path.item.key)) + break; + ref = (struct btrfs_root_ref *)path.data; + pathlen = + path.item.size - sizeof(struct btrfs_root_ref); + + debug("sub_vol found %s\n", (char *)(ref+1)); + if (!strncmp((char *)(ref + 1), + subvolname, pathlen)) { + subvol_ok = 1; + break; + } + } while (!next_slot(fs, &search_key, &path)); + if (subvol_ok) + break; + if (btrfs_comp_keys_type(&search_key, &path.item.key)) + break; + } while (!next_leaf(fs, &search_key, &path)); + if (!subvol_ok) + puts("no subvol found\n"); + } + /* find fs_tree from tree_root */ + if (subvol_ok) + search_key.objectid = path.item.key.offset; + else /* "default" volume */ + search_key.objectid = BTRFS_FS_TREE_OBJECTID; + search_key.type = BTRFS_ROOT_ITEM_KEY; + search_key.offset = -1; + clear_path(&path); + search_tree(fs, (sb.root), &search_key, &path); + tree = (struct btrfs_root_item *)path.data; + fs_tree = tree->bytenr; +} + +/* init. the fs meta data, return the block size shift bits. */ +int btrfs_fs_init(struct btrfs_info *fs) +{ + if (!crc_table_built) { /*Build crc table once*/ + btrfs_init_crc32c(); + crc_table_built = 1; + } + + btrfs_read_super_block(fs); + if (strncmp((char *)(&sb.magic), BTRFS_MAGIC, sizeof(sb.magic))) + return -1; + + btrfs_read_sys_chunk_array(); + btrfs_read_chunk_tree(fs); + btrfs_get_fs_tree(fs); + fs->root = btrfs_iget_root(fs); + parent_inode = *(fs->root); + + return 1; +} +static inline uint16_t file_to_handle(struct file *file) +{ + return file ? (file - files) + 1 : 0; +} + +static inline struct file *handle_to_file(uint16_t handle) +{ + return handle ? &files[handle - 1] : NULL; +} + +/* + * Free a refcounted inode + */ +void put_inode(struct inode *inode) +{ + while (inode && --inode->refcnt == 0) { + struct inode *dead = inode; + inode = inode->parent; + if (dead->name) + free((char *)dead->name); + free(dead); + } +} + +/* + * Get a new inode structure + */ +struct inode *alloc_inode(struct btrfs_info *fs, uint32_t ino, size_t data) +{ + struct inode *inode = malloc(sizeof(struct inode) + data); + + if (inode) { + inode->fs = fs; + inode->ino = ino; + inode->refcnt = 1; + } + + return inode; +} + +/* + * Get an empty file structure + */ +static struct file *alloc_file(void) +{ + int i; + struct file *file = files; + + for (i = 0; i < BTRFS_MAX_OPEN; i++) { + if (!file->fs) + return file; + + file++; + } + + return NULL; +} + +/* + * Close and free a file structure + */ +static inline void free_file(struct file *file) +{ + memset(file, 0, sizeof *file); +} + +void close_file(struct file *file) +{ + if (file->inode) { + file->offset = 0; + put_inode(file->inode); + } +} + +void btrfs_close_file(struct file *file) +{ + if (file->fs) + close_file(file); + free_file(file); +} + +void btrfs_mangle_name(char *dst, const char *src) +{ + char *p = dst, ch, len; + int i = BTRFS_FILENAME_MAX-1; + + len = strlen(src); + ch = *src; + while (!isspace(ch)) { + if (*src == '/') { + if (src[1] == '/') { + src++; + i--; + continue; + } + } + if (!len) + break; + i--; + len--; + *dst++ = *src++; + ch = *src; + } + while (1) { + if (dst == p) + break; + if (dst[-1] != '/') + break; + if ((dst[-1] == '/') && ((dst - 1) == p)) + break; + + dst--; + i++; + } + + i++; + for (; i > 0; i--) + *dst++ = '\0'; + +} + +int searchdir(const char *name) +{ + struct inode *inode = NULL; + struct inode *parent = &parent_inode; + struct file *file; + char *pathbuf = NULL; + char *part, *p, echar; + int symlink_count = BTRFS_MAX_SYMLINK_CNT; + + file = alloc_file(); + if (!(file)) + goto err_no_close; + + p = pathbuf = strdup(name); + if (!pathbuf) + goto err; + + do { +got_link: + if (*p == '/') { + put_inode(parent); + parent = &parent_inode; + } + + do { + inode = get_inode(parent); + + while (*p == '/') + p++; + + if (!*p) + break; + + part = p; + while ((echar = *p) && echar != '/') + p++; + *p++ = '\0'; + if (part[0] == '.' && part[1] == '.' && + part[2] == '\0') { + if (inode->parent) { + put_inode(parent); + parent = get_inode(inode->parent); + put_inode(inode); + inode = NULL; + if (!echar) { + /* Terminal double dots */ + inode = parent; + parent = inode->parent ? + get_inode(inode->parent) : NULL; + } + } + } else if (part[0] != '.' || part[1] != '\0') { + inode = btrfs_iget(part, parent); + if (!inode) + goto err; + if (inode->mode == BTRFS_DT_LNK) { + char *linkbuf, *q; + int name_len = echar ? strlen(p) : 0; + int total_len = inode->size + + name_len + 2; + int link_len; + + if (--symlink_count == 0 || + total_len > BTRFS_MAX_SYMLINK_BUF) + goto err; + + linkbuf = malloc(total_len); + if (!linkbuf) + goto err; + + link_len = + btrfs_readlink(inode, linkbuf); + if (link_len <= 0) { + free(linkbuf); + goto err; + } + + q = linkbuf + link_len; + + if (echar) { + if (link_len > 0 && + q[-1] != '/') + *q++ = '/'; + memcpy(q, p, name_len+1); + } else { + *q = '\0'; + } + + free(pathbuf); + p = pathbuf = linkbuf; + put_inode(inode); + inode = NULL; + goto got_link; + } + + inode->name = (u8 *)strdup(part); + + inode->parent = parent; + parent = NULL; + + if (!echar) + break; + + if (inode->mode != BTRFS_DT_DIR) + goto err; + + parent = inode; + inode = NULL; + } + } while (echar); + } while (0); + + free(pathbuf); + pathbuf = NULL; + put_inode(parent); + parent = NULL; + + if (!inode) + goto err; + + file->inode = inode; + file->offset = 0; + + return file_to_handle(file); + +err: + put_inode(inode); + put_inode(parent); + if (pathbuf != NULL) + free(pathbuf); + btrfs_close_file(file); +err_no_close: + return -1; +} + +int btrfs_open_file(const char *name, struct com32_filedata *filedata) +{ + int rv; + struct file *file; + char mangled_name[BTRFS_FILENAME_MAX]; + + btrfs_mangle_name(mangled_name, name); + rv = searchdir(mangled_name); + if (rv < 0) + return rv; + + file = handle_to_file(rv); + filedata->size = file->inode->size; + filedata->handle = rv; + + return rv; +} + +static void get_next_extent(struct inode *inode) +{ + /* The logical start address that we care about... */ + uint32_t lstart = inode->this_extent.lstart + inode->this_extent.len; + + if (btrfs_next_extent(inode, lstart)) + inode->next_extent.len = 0; /* ERROR */ + inode->next_extent.lstart = lstart; +} + +int getfssec(struct com32_filedata *filedata, char * buf) +{ + int sectors; + char have_more; + uint32_t bytes_read; + struct file *file; + if (filedata->size >= 512) { + sectors = filedata->size/BTRFS_SS; + sectors += (filedata->size%BTRFS_SS) ? 1 : 0; + } else + sectors = 2; + + file = handle_to_file(filedata->handle); + + bytes_read = btrfs_getfssec(file, buf, sectors, &have_more); + + return bytes_read; +} + +uint32_t generic_getfssec(struct file *file, char *buf, + int sectors, char *have_more) +{ + struct inode *inode = file->inode; + uint32_t bytes_read = 0; + uint32_t bytes_left = inode->size - file->offset; + uint32_t sectors_left = (bytes_left + BTRFS_SS - 1) >> 9; + uint32_t lsector; + + if (sectors > sectors_left) + sectors = sectors_left; + + if (!sectors) + return 0; + + lsector = file->offset >> 9; + + if (lsector < inode->this_extent.lstart || + lsector >= inode->this_extent.lstart + inode->this_extent.len) { + /* inode->this_extent unusable, maybe next_extent is... */ + inode->this_extent = inode->next_extent; + } + + if (lsector < inode->this_extent.lstart || + lsector >= inode->this_extent.lstart + inode->this_extent.len) { + /* Still nothing useful... */ + inode->this_extent.lstart = lsector; + inode->this_extent.len = 0; + } else { + /* We have some usable information */ + uint32_t delta = lsector - inode->this_extent.lstart; + inode->this_extent.lstart = lsector; + inode->this_extent.len -= delta; + inode->this_extent.pstart + = next_psector(inode->this_extent.pstart, delta); + } + + while (sectors) { + uint32_t chunk; + size_t len; + + while (sectors > inode->this_extent.len) { + if (!inode->next_extent.len || + inode->next_extent.lstart != + inode->this_extent.lstart + + inode->this_extent.len) + get_next_extent(inode); + if (!inode->this_extent.len) { + /* Doesn't matter if it's contiguous... */ + inode->this_extent = inode->next_extent; + if (!inode->next_extent.len) { + sectors = 0; /* Failed to get anything*/ + break; + } + } else if (inode->next_extent.len && + inode->next_extent.pstart == + next_pstart(&inode->this_extent)) { + /* Coalesce extents and loop */ + inode->this_extent.len += + inode->next_extent.len; + } else { + /* Discontiguous extents */ + break; + } + } + + chunk = min(sectors, inode->this_extent.len); + len = chunk << 9; + + if (inode->this_extent.pstart == BTRFS_EXTENT_ZERO) { + memset(buf, 0, len); + } else { + btrfs_block_dev_desc->block_read( + btrfs_block_dev_desc->dev, part_info->start + + (inode->this_extent.pstart), chunk, buf); + inode->this_extent.pstart += chunk; + } + + buf += len; + sectors -= chunk; + bytes_read += len; + inode->this_extent.lstart += chunk; + inode->this_extent.len -= chunk; + } + + bytes_read = min(bytes_read, bytes_left); + file->offset += bytes_read; + + if (have_more) + *have_more = bytes_read < bytes_left; + + return bytes_read; +} + +/* + * Open a directory + */ +struct _DIR_ *opendir(const char *path) +{ + int rv; + struct file *file; + rv = searchdir(path); + if (rv < 0) + return NULL; + + file = handle_to_file(rv); + + if (file->inode->mode != BTRFS_DT_DIR) { + btrfs_close_file(file); + return NULL; + } + + return (struct _DIR_ *)file; +} + +/* + * Read one directory entry at one time + */ +struct btrfs_dirent *readdir(struct _DIR_ *dir) +{ + static struct btrfs_dirent buf; + struct file *dd_dir = (struct file *)dir; + int rv = -1; + + if (dd_dir) + rv = btrfs_readdir(dd_dir, &buf); + + return rv < 0 ? NULL : &buf; +} + +/* + * Btrfs file-system Interface + * + */ + +struct btrfs_info fs; + +/* + * mount btrfs file-system + */ +int btrfs_probe(block_dev_desc_t *rbdd, disk_partition_t *info) +{ + btrfs_block_dev_desc = rbdd; + part_info = info; + btr_part_offset = info->start; + if (btrfs_fs_init(&fs) < 0) { + puts("btrfs probe failed\n"); + return -1; + } + + return 0; +} + +/* + * Read file data + */ +int btrfs_read_file(const char *filename, void *buf, int offset, int len) +{ + int file_len = 0; + int len_read; + struct com32_filedata filedata; + int handle; + if (offset != 0) { + puts("** Cannot support non-zero offset **\n"); + return -1; + } + + handle = btrfs_open_file(filename, &filedata); + if (handle < 0) { + debug("** File not found %s Invalid handle**\n", filename); + return -1; + } + + /*file handle is valid get the size of the file*/ + len = filedata.size; + if (len == 0) + len = file_len; + + len_read = getfssec(&filedata, (char *)buf); + if (len_read != len) { + debug("** Unable to read file %s **\n", filename); + return -1; + } + + return len_read; +} + +/* + * Show directory entries + */ +int btrfs_ls(const char *dirn) +{ + struct btrfs_dirent *de; + char *dirname = (char *)dirn; + struct _DIR_ *dir; + + if (*dirname == '/' && *(dirname+1) == 0) + *dirname = '.'; + + dir = opendir(dirname); + if (dir == NULL) + return -1; + + /* readdir prints contents on media*/ + de = readdir(dir); + while (de != NULL) + de = readdir(dir); + + return 0; +} + +/* + * umount btrfs file-system + */ +void btrfs_close(void) +{ +} diff --git a/fs/fs.c b/fs/fs.c index 6f5063c..b8c3603 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -17,6 +17,7 @@ #include <config.h> #include <common.h> #include <part.h> +#include <btrfs.h> #include <ext4fs.h> #include <fat.h> #include <fs.h> @@ -88,6 +89,15 @@ static struct fstype_info fstypes[] = { .read = fs_read_sandbox, }, #endif +#ifdef CONFIG_FS_BTR + { + .fstype = FS_TYPE_BTR, + .probe = btrfs_probe, + .close = btrfs_close, + .ls = btrfs_ls, + .read = btrfs_read_file, + }, +#endif { .fstype = FS_TYPE_ANY, .probe = fs_probe_unsupported, diff --git a/include/btrfs.h b/include/btrfs.h new file mode 100644 index 0000000..c59d35f --- /dev/null +++ b/include/btrfs.h @@ -0,0 +1,416 @@ +#ifndef _BTRFS_H_ +#define _BTRFS_H_ + +#include <asm/byteorder.h> +/* type that store on disk, but it is same as cpu type for i386 arch */ + +#define BTRFS_CURRENTDIR_MAX 15 +#define BTRFS_MAX_OPEN 5 +#define BTRFS_FILENAME_MAX 20 +#define BTRFS_MAX_SYMLINK_CNT 20 +#define BTRFS_MAX_SYMLINK_BUF 4096 +#define BTRFS_SECTOR_SHIFT(fs) ((fs)->sector_shift) +#define BTRFS_IFTODT(mode) (((mode) & 0170000) >> 12) +#define BTRFS_SECTOR_SIZE 0x200 +#define BTRFS_SECTOR_BITS 9 +#define BTRFS_EXTENT_ZERO ((uint32_t)-1) /* All-zero extent */ +#define BTRFS_EXTENT_VOID ((uint32_t)-2) /* Invalid information */ +#define BTRFS_DT_LNK 10 +#define BTRFS_DT_REG 8 +#define BTRFS_DT_DIR 4 +#define EXTENT_SPECIAL(x) ((x) >= BTRFS_EXTENT_VOID) +#define BTRFS_MAX_SUBVOL_NAME 50 + +#define BTRFS_FILE 1 +#define BTRFS_DIR 2 +#define BTRFS_SYMLNK 7 +#define BTRFS_SS BTRFS_SECTOR_SIZE + +extern char subvolname[BTRFS_MAX_SUBVOL_NAME]; +struct _DIR_; + +struct com32_filedata { + size_t size; /* File size */ + int blocklg2; /* log2(block size) */ + uint16_t handle; /* File handle */ +}; + +struct btrfs_info { + const struct fs_ops *fs_ops; + struct device *fs_dev; + void *btrfs_info; /* The fs-specific information */ + int sector_shift, sector_size; + int block_shift, block_size; + struct inode *root, *cwd; /* Root and current directories */ + char cwd_name[BTRFS_CURRENTDIR_MAX]; /* Current directory by name */ +}; +/* + * Extent structure: contains the mapping of some chunk of a file + * that is contiguous on disk. + */ +struct extent { + uint64_t pstart; + uint32_t lstart; /* Logical start sector */ + uint32_t len; /* Number of contiguous sectors */ +} __packed; + + +struct inode { + struct btrfs_info *fs; /* The filesystem inode is associated with */ + struct inode *parent; /* Parent directory, if any */ + const u8 *name; /* Name, valid for generic path search only */ + uint32_t refcnt; + uint32_t mode; /* FILE , DIR or SYMLINK */ + uint32_t size; + uint32_t blocks; /* How many blocks the file take */ + uint32_t ino; /* Inode number */ + uint32_t atime; /* Access time */ + uint32_t mtime; /* Modify time */ + uint32_t ctime; /* Create time */ + uint32_t dtime; /* Delete time */ + uint32_t flags; + uint32_t file_acl; + struct extent this_extent, next_extent; + u8 pvt[0]; /* Private filesystem data */ +} __packed; +struct file { + struct btrfs_info *fs; + uint64_t offset; /* for next read */ + struct inode *inode; /* The file-specific information */ +} __packed; + +#define NAME_MAX 20 +struct btrfs_dirent { + uint32_t d_ino; + uint32_t d_off; + uint16_t d_reclen; + uint16_t d_type; + char d_name[NAME_MAX + 1]; +}; + +#define btrfs_crc32c crc32c_le + +#define BTRFS_SUPER_INFO_OFFSET (64 * 1024) +#define BTRFS_SUPER_INFO_SIZE 4096 +#define BTRFS_MAX_LEAF_SIZE 4096 +#define BTRFS_BLOCK_SHIFT 12 + +#define BTRFS_SUPER_MIRROR_MAX 3 +#define BTRFS_SUPER_MIRROR_SHIFT 12 +#define BTRFS_CSUM_SIZE 32 +#define BTRFS_FSID_SIZE 16 +#define BTRFS_LABEL_SIZE 256 +#define BTRFS_SYSTEM_CHUNK_ARRAY_SIZE 2048 +#define BTRFS_UUID_SIZE 16 + +#define BTRFS_MAGIC "_BHRfS_M" + +#define BTRFS_SUPER_FLAG_METADUMP (1ULL << 33) + +#define BTRFS_DEV_ITEM_KEY 216 +#define BTRFS_CHUNK_ITEM_KEY 228 +#define BTRFS_ROOT_REF_KEY 156 +#define BTRFS_ROOT_ITEM_KEY 132 +#define BTRFS_EXTENT_DATA_KEY 108 +#define BTRFS_DIR_ITEM_KEY 84 +#define BTRFS_INODE_ITEM_KEY 1 + +#define BTRFS_EXTENT_TREE_OBJECTID 2ULL +#define BTRFS_FS_TREE_OBJECTID 5ULL + +#define BTRFS_FIRST_CHUNK_TREE_OBJECTID 256ULL + +#define BTRFS_FILE_EXTENT_INLINE 0 +#define BTRFS_FILE_EXTENT_REG 1 +#define BTRFS_FILE_EXTENT_PREALLOC 2 + +#define BTRFS_MAX_LEVEL 8 +#define BTRFS_MAX_CHUNK_ENTRIES 256 + +#define BTRFS_FT_REG_FILE 1 +#define BTRFS_FT_DIR 2 +#define BTRFS_FT_SYMLINK 7 + +#define ROOT_DIR_WORD 0x002f + +struct btrfs_dev_item { + uint64_t devid; + uint64_t total_bytes; + uint64_t bytes_used; + uint32_t io_align; + uint32_t io_width; + uint32_t sector_size; + uint64_t type; + uint64_t generation; + uint64_t start_offset; + uint32_t dev_group; + u8 seek_speed; + u8 bandwidth; + u8 uuid[BTRFS_UUID_SIZE]; + u8 fsid[BTRFS_UUID_SIZE]; +} __packed; + +struct btrfs_super_block { + u8 csum[BTRFS_CSUM_SIZE]; + /* the first 4 fields must match struct btrfs_header */ + u8 fsid[BTRFS_FSID_SIZE]; /* FS specific uuid */ + uint64_t bytenr; /* this block number */ + uint64_t flags; + + /* allowed to be different from the btrfs_header from here own down */ + uint64_t magic; + uint64_t generation; + uint64_t root; + uint64_t chunk_root; + uint64_t log_root; + + /* this will help find the new super based on the log root */ + uint64_t log_root_transid; + uint64_t total_bytes; + uint64_t bytes_used; + uint64_t root_dir_objectid; + uint64_t num_devices; + uint32_t sectorsize; + uint32_t nodesize; + uint32_t leafsize; + uint32_t stripesize; + uint32_t sys_chunk_array_size; + uint64_t chunk_root_generation; + uint64_t compat_flags; + uint64_t compat_ro_flags; + uint64_t incompat_flags; + __le16 csum_type; + u8 root_level; + u8 chunk_root_level; + u8 log_root_level; + struct btrfs_dev_item dev_item; + + char label[BTRFS_LABEL_SIZE]; + + uint64_t cache_generation; + + /* future expansion */ + uint64_t reserved[31]; + u8 sys_chunk_array[BTRFS_SYSTEM_CHUNK_ARRAY_SIZE]; +} __packed; +struct btrfs_disk_key { + uint64_t objectid; + u8 type; + uint64_t offset; +} __packed; + +struct btrfs_stripe { + uint64_t devid; + uint64_t offset; + u8 dev_uuid[BTRFS_UUID_SIZE]; +} __packed; + +struct btrfs_chunk { + uint64_t length; + uint64_t owner; + uint64_t stripe_len; + uint64_t type; + uint32_t io_align; + uint32_t io_width; + uint32_t sector_size; + __le16 num_stripes; + __le16 sub_stripes; + struct btrfs_stripe stripe; +} __packed __attribute__((__may_alias__)); + +struct btrfs_header { + /* these first four must match the super block */ + u8 csum[BTRFS_CSUM_SIZE]; + u8 fsid[BTRFS_FSID_SIZE]; /* FS specific uuid */ + uint64_t bytenr; /* which block this node is supposed to live in */ + uint64_t flags; + + /* allowed to be different from the super from here on down */ + u8 chunk_tree_uuid[BTRFS_UUID_SIZE]; + uint64_t generation; + uint64_t owner; + uint32_t nritems; + u8 level; +} __packed; + +struct btrfs_item { + struct btrfs_disk_key key; + uint32_t offset; + uint32_t size; +} __packed; + +struct btrfs_leaf { + struct btrfs_header header; + struct btrfs_item items[]; +} __packed; + +struct btrfs_key_ptr { + struct btrfs_disk_key key; + uint64_t blockptr; + uint64_t generation; +} __packed; + +struct btrfs_node { + struct btrfs_header header; + struct btrfs_key_ptr ptrs[]; +} __packed; + +/* remember how we get to a node/leaf */ +struct btrfs_path { + uint64_t offsets[BTRFS_MAX_LEVEL]; + uint32_t itemsnr[BTRFS_MAX_LEVEL]; + uint32_t slots[BTRFS_MAX_LEVEL]; + /* remember last slot's item and data */ + struct btrfs_item item; + u8 data[BTRFS_MAX_LEAF_SIZE]; +} __packed; + +/* store logical offset to physical offset mapping */ +struct btrfs_chunk_map_item { + uint64_t logical; + uint64_t length; + uint64_t devid; + uint64_t physical; +} __packed; + +struct btrfs_chunk_map { + struct btrfs_chunk_map_item *map; + uint32_t map_length; + uint32_t cur_length; +} __packed; + +struct btrfs_timespec { + uint64_t sec; + uint32_t nsec; +} __packed; + +struct btrfs_inode_item { + /* nfs style generation number */ + uint64_t generation; + /* transid that last touched this inode */ + uint64_t transid; + uint64_t size; + uint64_t nbytes; + uint64_t block_group; + uint32_t nlink; + uint32_t uid; + uint32_t gid; + uint32_t mode; + uint64_t rdev; + uint64_t flags; + + /* modification sequence number for NFS */ + uint64_t sequence; + + /* + * a little future expansion, for more than this we can + * just grow the inode item and version it + */ + uint64_t reserved[4]; + struct btrfs_timespec atime; + struct btrfs_timespec ctime; + struct btrfs_timespec mtime; + struct btrfs_timespec otime; +} __packed __attribute__((__may_alias__)); + +struct btrfs_root_item { + struct btrfs_inode_item inode; + uint64_t generation; + uint64_t root_dirid; + uint64_t bytenr; + uint64_t byte_limit; + uint64_t bytes_used; + uint64_t last_snapshot; + uint64_t flags; + uint32_t refs; + struct btrfs_disk_key drop_progress; + u8 drop_level; + u8 level; +} __packed __attribute__((__may_alias__)); + +struct btrfs_dir_item { + struct btrfs_disk_key location; + uint64_t transid; + __le16 data_len; + __le16 name_len; + u8 type; +} __packed __attribute__((__may_alias__)); + +struct btrfs_file_extent_item { + uint64_t generation; + uint64_t ram_bytes; + u8 compression; + u8 encryption; + __le16 other_encoding; /* spare for later use */ + u8 type; + uint64_t disk_bytenr; + uint64_t disk_num_bytes; + uint64_t offset; + uint64_t num_bytes; +} __packed __attribute__((__may_alias__)); + +struct btrfs_root_ref { + uint64_t dirid; + uint64_t sequence; + __le16 name_len; +} __packed; + +/* + * btrfs private inode information + */ +struct btrfs_pvt_inode { + uint64_t offset; +} __packed; + + +int btrfs_probe(block_dev_desc_t *rbdd , disk_partition_t *info); + +/* + *search through disk and mount file-system + */ +int btrfs_fs_init(struct btrfs_info *fs); + +/* + *save inode in list + */ +void put_inode(struct inode *inode); + +/* + *memory allocation for new inode + */ +struct inode *alloc_inode(struct btrfs_info *fs, uint32_t ino, size_t data); + +/* + * open btrfs file + */ +int btrfs_open_file(const char *name, struct com32_filedata *filedata); +/* + * reading data from file + */ +int getfssec(struct com32_filedata *filedata, char *buf); +uint32_t generic_getfssec(struct file *file, char *buf, + int sectors, char *have_more); + +/* + * mount btrfs file-system + */ +int btrfs_probe(block_dev_desc_t *rbdd , disk_partition_t *info); + +/* + * listing file/directory on btrfs partition/disk + */ +int btrfs_ls(const char *); + +/* + * read file data + */ +int btrfs_read_file(const char *filename, void *buf, int offset, int len); + +/* + * umount btrfs file-system + */ +void btrfs_close(void); + +#define PVT(i) ((struct btrfs_pvt_inode *)((i)->pvt)) + +#endif diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index bfb9680..28a0a66 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -26,4 +26,8 @@ #define CONFIG_EXT4_WRITE #endif
+#if defined(CONFIG_CMD_BTR) && !defined(CONFIG_FS_BTR) +#define CONFIG_FS_BTR +#endif + #endif /* __CONFIG_FALLBACKS_H */ diff --git a/include/crc.h b/include/crc.h index 10560c9..5e5b1f0 100644 --- a/include/crc.h +++ b/include/crc.h @@ -97,4 +97,12 @@ cyg_ether_crc32_accumulate(uint32_t crc, unsigned char *s, int len);
extern uint16_t cyg_crc16(unsigned char *s, int len);
+/* CRC init for btrfs file-system*/ + +void crc32c_init(u32 *crc32c_table, u32 pol); + +/* CRC calculate for btrfs file-system*/ + +u32 crc32c_cal(u32 crc, const char *data, size_t length, u32 *crc32c_table); + #endif /* _SERVICES_CRC_CRC_H_ */ diff --git a/include/fs.h b/include/fs.h index b6d69e5..a8b97ea 100644 --- a/include/fs.h +++ b/include/fs.h @@ -22,6 +22,7 @@ #define FS_TYPE_FAT 1 #define FS_TYPE_EXT 2 #define FS_TYPE_SANDBOX 3 +#define FS_TYPE_BTR 4
/* * Tell the fs layer which block device an partition to use for future diff --git a/lib/Makefile b/lib/Makefile index 86ca1a6..9518b72 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -67,6 +67,7 @@ COBJS-$(CONFIG_SPL_NET_SUPPORT) += hashtable.o COBJS-$(CONFIG_SPL_NET_SUPPORT) += net_utils.o endif COBJS-y += crc32.o +COBJS-y += crc32_c.o COBJS-y += ctype.o COBJS-y += div64.o COBJS-y += linux_string.o diff --git a/lib/crc32_c.c b/lib/crc32_c.c new file mode 100644 index 0000000..b97c98a --- /dev/null +++ b/lib/crc32_c.c @@ -0,0 +1,40 @@ +/* + * Copied from Linux kernel crypto/crc32c.c + * Copyright (c) 2004 Cisco Systems, Inc. + * Copyright (c) 2008 Herbert Xu herbert@gondor.apana.org.au + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + * + */ +#include <linux/stat.h> +#include <command.h> +#include <asm/byteorder.h> +#include <linux/compiler.h> +#include <common.h> +#include <config.h> + +u32 crc32c_cal(u32 crc, const char *data, size_t length, u32 *crc32c_table) +{ + while (length--) + crc = crc32c_table[(u8)(crc ^ *data++)] ^ (crc >> 8); + + return crc; +} + +void crc32c_init(u32 *crc32c_table, u32 pol) +{ + int i, j; + u32 v; + const u32 poly = pol; /* Bit-reflected CRC32C polynomial */ + + for (i = 0; i < 256; i++) { + v = i; + for (j = 0; j < 8; j++) + v = (v >> 1) ^ ((v & 1) ? poly : 0); + + crc32c_table[i] = v; + } +}
Dear Adnan Ali,
In message 1367660512-10489-3-git-send-email-adnan9901@yahoo.com you wrote:
... include/crc.h | 8 + include/fs.h | 1 + lib/Makefile | 1 + lib/crc32_c.c | 40 ++ ...
These changes should be factored out into a separate commit. In any case, the code should be compiled in only when needed, i. e. when btrfs support is selected. Otherwise you just bloat the code size and build time for all systems without need.
Hm... do we really need yet another crc32 implementation?
I still see an checkpatch error and warnings; also incorrect multi-line comments - did these slip through, or is it intentional not to fix these? Why?
- "load binary file from a btr filesystem",
- "<interface> [<dev[:part]>] <addr> <filename> [subvol_name]\n"
- " - Load binary file 'filename' from 'dev' on 'interface'\n"
Please remove the "binary" here. I guess we can also load text files and any other file tpes as well.
Also please decide how to call the B-Tree file system in descriptions like this. IIRC, Linux tends to write "btrfs" in cases like this one.
Which makes: "load file from btrfs file system", etc.
- " to address 'addr' from better filesystem.\n"
"better filesystem"? "BTRFS" means B-tree file system. Pronounciation may sound like this, but we don't write it that way.
i. e. something like:
"Load file 'filename' from btrfs file system on 'dev' on 'interface' to address 'addr'"
- " the load stops on end of file.\n"
Would it be easy to add support for loading only a certain (smaller) lenght?
- " subvol_name is used read that file from this subvolume.\n"
It seems this sentence is not complete.
- " All numeric parameters are assumed to be hex."
Drop this. This is standard in U-Boot.
- Copied from Linux kernel crypto/crc32c.c
Which exact version of the Linux kernel has this been copied from? The current version of crypto/crc32c.c does not contain any such code at all.
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 05/05/2013 03:28 AM, Wolfgang Denk wrote:
Dear Adnan Ali,
We should be able to make lib/crc32_c.o depend on btrfs being set, yes. But non-command stuff should be getting garbage collected out in most cases at last (Need to poke Albert about the patch for ARM).
We talked about this before I believe and the answer is yes :(
- -- Tom
Dear Tom Rini,
Yes, it may be garbage collected, but only after compilation - which means we add to the build time for about 1000 boards which do not use this.
Yes, I remember this discussion. But look at the code. It raises a number of questions:
- Why do we have to calculate the crc32c_table[] at runtime? Our regular CRC code uses a pre-calculated table; we should do the same here.
- Compare the code for crc32c_cal() in the patch with the definition of DO_CRC(x) in "lib/crc32.c" - to me, it appears to be the same for little endian code (it is redundant?), but different for big endian systems - which raises the question if this code has ever been tested on a BE machine?
- The code claims to be derived from "Linux kernel crypto/crc32c.c"; but I cannot find such code in that file.
- The implementation of crc32c_cal() suffers from a few other problems (like not triggering the watchdog, which will cause problems on systems that use one).
I think we should re-check this. My feeling is that we may eventually end up with a different CRC table, but without need for new code.
Hi
On 05/05/13 16:15, Wolfgang Denk wrote:
Dear Tom Rini,
This is part of the port. But pre-calculated table can be manually created.
My code uses lib/crc32.c and i have only tested it on mx53loco manchine.
I think yes but part of part from syslinux. I have also added SHA1 of commit so don't know.
I think that is true as its not using main line crc32 code.
Thanks Adnan Ali
Dear Adnan Ali,
created.
Not manually. It should be done at compile time, suing basically the same code.
I tend to believe thatit will not work on a big endian system, then.
Please provide an exact reference where this code is coming from.
We probably should do that, then.
Thanks.
On 2013-05-09 22:43, Wolfgang Denk wrote:
Dear Adnan Ali,
same
here.
manually created.
definition
same for
endian
Sorry I meant to say my code uses lib/crc32_c.c. The lib/crc32.c is main line so you think main line code is not for big endian. What can i say.
crypto/crc32c.c";
Just clone syslinux and code is in ~/syslinux/core/fs/btrfs/crc32c.h
problems
To use that code probably i need to create static crc32 table.
Thanks.
Dear Adnan Ali,
definition
same for
endian
What exactly do you mean by "my code uses lib/crc32_c.c? I was referring to the crc32c_cal() funciton in your patch. It is this function where I think it will fail on BE systems.
crypto/crc32c.c";
The pelase fix the comment, and provide exact reference (commit ID etc. as described at bullet # 4 at [1]) for that code.
[1] http://www.denx.de/wiki/view/U-Boot/Patches#Attributing_Code_Copyrights_Sign
Indeed. This should also reduce boot time.
Adnan Ali
Adnan Ali
