[U-Boot] [PATCH] powerpc/esdhc: force the bus width to 4bit
For the current u-boot codes, only 4bit/1bit SD/SDHC bus width is support. So for MMC card, we also support 4bit bus width, otherwiase, we will get the 12bit bus width, which is not correct: => mmcinfo Device: FSL_SDHC Manufacturer ID: 1e OEM: ffff Name: MMC Tran Speed: 52000000 Rd Block Len: 512 MMC version 4.0 High Capacity: No Capacity: 1.9 GiB Bus Width: 12-bit
Signed-off-by: Jerry Huang Chang-Ming.Huang@freescalecom CC: Andy Fleming afleming@gmail.com CC: Marek Vasut marex@denx.de --- drivers/mmc/fsl_esdhc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 3f8d30d..7b83dd2 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -577,7 +577,7 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) return -1; }
- mmc->host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT; + mmc->host_caps = MMC_MODE_4BIT;
if (caps & ESDHC_HOSTCAPBLT_HSS) mmc->host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS;
Dear Chang-Ming.Huang@freescale.com,
Andy ... can you please explain? I don't quite understand the problem, I thought we had no problem supporting 8bit mmc (esp. if the controller handles that for us mostly).
Best regards, Marek Vasut
Best Regards Jerry Huang
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Tuesday, October 23, 2012 3:24 PM To: Huang Changming-R66093 Cc: u-boot@lists.denx.de; Andy Fleming Subject: Re: [PATCH] powerpc/esdhc: force the bus width to 4bit
support.
Yes, the controller support 8bit MMC.
FSL ESDHC driver set the host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT; But, the current codes for MMC card has been changed to:
} else { width = ((mmc->host_caps & MMC_MODE_MASK_WIDTH_BITS) >> MMC_MODE_WIDTH_BITS_SHIFT); for (; width >= 0; width--) { ....
So for FSL ESDHC, the width = 3, after implement mmc_switch successfully, will set the bus to 4 * width. Therefore, I will get the 12bit (4 x 3) bus width.
Below is the old codes (width = 2): } else { for (width = EXT_CSD_BUS_WIDTH_8; width >= 0; width--) {
Dear Huang Changming-R66093,
support.
Uh, so it's a bug in the MMC subsystem? Best regards, Marek Vasut
support.
I don't know. Maybe Andy can give some comment.
support.
This problem is MMC subsystem's bug. I think good that will modify the code in mmc.c. If caps is set to MMC_MODE_4BIT | MMC_MODE_8BIT, we can see the 12bit support with using "mmcinfo" command
Best Regards, Jaehoon Chung
Uh, so it's a bug in the MMC subsystem? Best regards, Marek Vasut _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Jaehoon,
support.
Hmm... looks like it is code done by me :-) So little explanation shall be given.
This code is necessary for some targets (like Samsung's Goni) which can only support 4 bit MMC mode.
The mmc_set_bus_width(mmc, 4 * width) in conjunction to above code causes the problem.
I agree, that this code shall be refactored. Lei, what do you think?
Hi, Lukasz,
support.
then how about using the width[idx] like kernel?
Hi Jaehoon,
Hi, Lukasz,
> For the current u-boot codes, only 4bit/1bit SD/SDHC bus width > is
support.
> So for MMC card, we also support 4bit bus width, otherwiase, we > will
> get the 12bit bus width, which is not correct: Andy ... can you please explain? I don't quite understand the problem, I thought we had no problem supporting 8bit mmc (esp. if the controller handles that for us mostly).
I don't mind :-) if it works at kernel.
Hi Lukasz,
This code has the problem. If width is set to 0x3, then BUS_WIDTH field of ext_csd register is set to 0x3. Value 0x3 is nothing.(It's reserved) If we want to set 4-bit, then that value is set to 0x2. This problem need to fix. I will send the patch for this problem.
On 10/31/2012 05:20 PM, Lukasz Majewski wrote:
Hi Jaehoon,
Hi, Lukasz,
>> For the current u-boot codes, only 4bit/1bit SD/SDHC bus width >> is > > support. > >> So for MMC card, we also support 4bit bus width, otherwiase, we >> will > >> get the 12bit bus width, which is not correct: > Andy ... can you please explain? I don't quite understand the > problem, I thought we had no problem supporting 8bit mmc (esp. > if the controller handles that for us mostly).
I am... very confused by this whole thread. And the code associated with it. The host_caps field has a bitmask which declares the widths supported by a given controller.
What would possess you to index them by addition, and convert their values by multiplication?? It's a bitfield! I'm embarrassed that I allowed this code in, and will review future submissions from you with a very skeptical eye.
Ah, and further review indicates it is Lei Wen who introduced the idea of iterating through a bitfield by subtraction, though I can see how iterating through the EXT_CSD *field* definition (which looks a lot like a bitfield, but may not be) *might* be considered reasonable.
Meanwhile, Huang Changming, why would you see this broken code, and then decide the best workaround was to cripple our controller by eliminating support for 8-bit?
I'm going to fix this right now. Probably in the quite sensible way that Jaehoon Chung suggested.
Andy
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Andy Fleming Sent: Thursday, November 01, 2012 12:09 PM To: Lukasz Majewski Cc: Jaehoon Chung; Marek Vasut; Lei Wen; u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] powerpc/esdhc: force the bus width to 4bit
I see 12bit width when using mmcinfo, then found out the mmc.c has been changed, and I assume this change is right, So I have to force our controller to just support 4bit width, otherwise, the 12bit bus width is not correct.
Andy has sent the patch related with this problem. Check the patch "[RFC] mmc: Properly determine maximum supported bus width"
Thanks, Jaehoon, I saw it.
-----Original Message----- From: Jaehoon Chung [mailto:jh80.chung@samsung.com] Sent: Friday, November 02, 2012 10:03 AM To: Huang Changming-R66093 Cc: Andy Fleming; Lukasz Majewski; Jaehoon Chung; Marek Vasut; u- boot@lists.denx.de; Wen; Lei@theia.denx.de Subject: Re: [U-Boot] [PATCH] powerpc/esdhc: force the bus width to 4bit
I wonder if you're just making fun of all of us or what you're actually trying to acomplish here with the constant top-posting ... I'm really stunned :-(
Hi Andy,
I admit, that this code was a hack, I will even say more (after the "big picture" presented by You) - I've delivered very low quality code.
Shame on me - my fault. Period.
Andy
participants (6)
Andy Fleming
Jaehoon Chung
Lukasz Majewski
