[PATCH] xilinx: Add jedec compatible string for QSPI (Zynq/ZynqMP)
From: Raju Kumar Pothuraju raju.kumar-pothuraju@xilinx.com
Add missing "jedec, spi-nor" compatible string for QSPI flash node. Spi-nor framework uses this compatibility string to probe & initialize flash. With missing compatibility string we are observing below error:
Zynq> sf probe 0 0 0 jedec_spi_nor spi_flash@0:0: unrecognized JEDEC id bytes: 00, 00, 00 Failed to initialize SPI flash at 0:0 (error -2)
Signed-off-by: Raju Kumar Pothuraju raju.kumar-pothuraju@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynq-cc108.dts | 2 +- arch/arm/dts/zynq-cse-qspi.dtsi | 2 +- arch/arm/dts/zynq-topic-miami.dts | 2 +- arch/arm/dts/zynqmp-topic-miamimp-xilinx-xdp-v1r1.dts | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/zynq-cc108.dts b/arch/arm/dts/zynq-cc108.dts index 64d73ecbc592..036106e2212c 100644 --- a/arch/arm/dts/zynq-cc108.dts +++ b/arch/arm/dts/zynq-cc108.dts @@ -58,7 +58,7 @@ is-dual = <0>; num-cs = <1>; flash@0 { /* 16 MB */ - compatible = "n25q128a11"; + compatible = "n25q128a11", "jedec,spi-nor"; reg = <0x0>; spi-max-frequency = <50000000>; spi-tx-bus-width = <1>; diff --git a/arch/arm/dts/zynq-cse-qspi.dtsi b/arch/arm/dts/zynq-cse-qspi.dtsi index eb0e29e6cb6e..38410eeca886 100644 --- a/arch/arm/dts/zynq-cse-qspi.dtsi +++ b/arch/arm/dts/zynq-cse-qspi.dtsi @@ -60,7 +60,7 @@ #size-cells = <0>; num-cs = <1>; flash0: flash@0 { - compatible = "n25q128a11"; + compatible = "n25q128a11", "jedec,spi-nor"; reg = <0x0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; diff --git a/arch/arm/dts/zynq-topic-miami.dts b/arch/arm/dts/zynq-topic-miami.dts index ab6bde95fed9..c4ec56138e1e 100644 --- a/arch/arm/dts/zynq-topic-miami.dts +++ b/arch/arm/dts/zynq-topic-miami.dts @@ -36,7 +36,7 @@ is-dual = <0>; num-cs = <1>; flash@0 { - compatible = "st,m25p80", "n25q256a"; + compatible = "st,m25p80", "n25q256a", "jedec,spi-nor"; m25p,fast-read; reg = <0x0>; spi-tx-bus-width = <1>; diff --git a/arch/arm/dts/zynqmp-topic-miamimp-xilinx-xdp-v1r1.dts b/arch/arm/dts/zynqmp-topic-miamimp-xilinx-xdp-v1r1.dts index 6ec96e0e8c96..300e2ebe96e8 100644 --- a/arch/arm/dts/zynqmp-topic-miamimp-xilinx-xdp-v1r1.dts +++ b/arch/arm/dts/zynqmp-topic-miamimp-xilinx-xdp-v1r1.dts @@ -58,7 +58,7 @@ status = "okay"; is-dual = <1>; flash@0 { - compatible = "st,m25p80", "n25q256a"; + compatible = "st,m25p80", "n25q256a", "jedec,spi-nor"; m25p,fast-read; reg = <0x0>; spi-tx-bus-width = <1>;
pá 6. 8. 2021 v 13:28 odesílatel Michal Simek michal.simek@xilinx.com napsal:
-- 2.32.0
Applied. M
Michal Simek
Michal Simek
