[PATCH 1/4] am335x: Update list of defconfigs
Both the am335x_boneblack and am335x_evm_usbspl configs have been gone for a while, remove their entries from MAINTAINERS.
Signed-off-by: Tom Rini trini@konsulko.com --- board/ti/am335x/MAINTAINERS | 2 -- 1 file changed, 2 deletions(-)
diff --git a/board/ti/am335x/MAINTAINERS b/board/ti/am335x/MAINTAINERS index 565f7055cdd3..e100adfd68ec 100644 --- a/board/ti/am335x/MAINTAINERS +++ b/board/ti/am335x/MAINTAINERS @@ -3,7 +3,5 @@ M: Tom Rini trini@konsulko.com S: Maintained F: board/ti/am335x/ F: include/configs/am335x_evm.h -F: configs/am335x_boneblack_defconfig F: configs/am335x_boneblack_vboot_defconfig F: configs/am335x_evm_defconfig -F: configs/am335x_evm_usbspl_defconfig
Disable USB support for now. There is non-trivial work required to fully move the OMAP3 platforms to DM. While this work is in-progress, disable USB support for now as we've gone well past the migration deadline.
Cc: Adam Ford aford173@gmail.com Signed-off-by: Tom Rini trini@konsulko.com --- configs/omap3_beagle_defconfig | 20 ++------------------ 1 file changed, 2 insertions(+), 18 deletions(-)
diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index ed7cb8f2ff63..236a4f4f5f5a 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_DISTRO_DEFAULTS=y +CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="usb start" @@ -31,7 +32,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_UUID=y @@ -50,8 +50,6 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=1 @@ -73,24 +71,10 @@ CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y +CONFIG_DM_ETH=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_OMAP3=y -CONFIG_USB_MUSB_GADGET=y -CONFIG_USB_MUSB_OMAP2PLUS=y -CONFIG_TWL4030_USB=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="TI" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_ETHER=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_MCS7830=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_VIDEO_OMAP3=y CONFIG_FAT_WRITE=y CONFIG_BCH=y
I don't have a beagle, but I have DM_USB working on two different OMAP3 boards. I am curious to know what's left or what's not working.
adam
diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index ed7cb8f2ff63..236a4f4f5f5a 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_DISTRO_DEFAULTS=y +CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="usb start" @@ -31,7 +32,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_UUID=y @@ -50,8 +50,6 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=1 @@ -73,24 +71,10 @@ CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y +CONFIG_DM_ETH=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_OMAP3=y -CONFIG_USB_MUSB_GADGET=y -CONFIG_USB_MUSB_OMAP2PLUS=y -CONFIG_TWL4030_USB=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="TI" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_ETHER=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_MCS7830=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_VIDEO_OMAP3=y CONFIG_FAT_WRITE=y CONFIG_BCH=y -- 2.17.1
Oh? I thought when we talked last there was still more to do to fully migrate things over. Where should I check again to see what I need to do on beagle to convert it over? Thanks!
With [1], the DM support for the EHCI controller was added. There is still some work to be done to make it better, because there are still some #defines that need to assign the reset GPIO's. Ideally we'd get rid of the GPIO defines and use the device tree to address the reset. It isn't perfect, but it's better than having no USB at all. The am3517_evm and omap3_logic_somlv have them working. Make sure the board files have the legacy USB stuff removed [2]
[1] - https://gitlab.denx.de/u-boot/u-boot/-/commit/94ed66194f150c308d1713965a28ab... [2] - https://gitlab.denx.de/u-boot/u-boot/-/commit/76f6d52e61a1968702af69d6cea463...
Let me know if there is anything I can do to help.
adam
-- Tom
Hunh, thanks. I thought I had tried this much before but had things blow up. With [2] it's a quick conversion and passing basic sanity checks. Thanks!
As Adam noted, I should just convert this instead. It does in fact convert easily at this point, so I'm rejecting this patch and will post a conversion instead soon.
This platform is already using DM in general and the MMC controller is the early generation of what is compatible with "ti,omap4-hsmmc" so enable DM_MMC (which in turn gets BLK enabled).
Signed-off-by: Tom Rini trini@konsulko.com --- configs/ti816x_evm_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 17aa6a02067c..033d35df4d02 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -47,6 +47,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_OMAP24XX=y +CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y
The TI814x (DM814x) platform is rather old and in need of a lot of migration work. As much of that work is well past the deadline, remove this platform.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-omap2/Kconfig | 1 - board/ti/ti814x/Kconfig | 15 --- board/ti/ti814x/MAINTAINERS | 6 -- board/ti/ti814x/Makefile | 11 -- board/ti/ti814x/evm.c | 190 ----------------------------------- board/ti/ti814x/evm.h | 8 -- board/ti/ti814x/mux.c | 86 ---------------- configs/ti814x_evm_defconfig | 45 --------- 8 files changed, 362 deletions(-) delete mode 100644 board/ti/ti814x/Kconfig delete mode 100644 board/ti/ti814x/MAINTAINERS delete mode 100644 board/ti/ti814x/Makefile delete mode 100644 board/ti/ti814x/evm.c delete mode 100644 board/ti/ti814x/evm.h delete mode 100644 board/ti/ti814x/mux.c delete mode 100644 configs/ti814x_evm_defconfig
diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 4c87cbc00f74..48bc80a6390a 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -181,7 +181,6 @@ source "board/BuR/brppt1/Kconfig" source "board/siemens/draco/Kconfig" source "board/siemens/pxm2/Kconfig" source "board/siemens/rut/Kconfig" -source "board/ti/ti814x/Kconfig" source "board/ti/ti816x/Kconfig" source "board/ti/am43xx/Kconfig" source "board/ti/am335x/Kconfig" diff --git a/board/ti/ti814x/Kconfig b/board/ti/ti814x/Kconfig deleted file mode 100644 index 2960099a8e5b..000000000000 --- a/board/ti/ti814x/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_TI814X_EVM - -config SYS_BOARD - default "ti814x" - -config SYS_VENDOR - default "ti" - -config SYS_SOC - default "am33xx" - -config SYS_CONFIG_NAME - default "ti814x_evm" - -endif diff --git a/board/ti/ti814x/MAINTAINERS b/board/ti/ti814x/MAINTAINERS deleted file mode 100644 index b2ee39e8a339..000000000000 --- a/board/ti/ti814x/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -TI814X BOARD -M: Tom Rini trini@konsulko.com -S: Maintained -F: board/ti/ti814x/ -F: include/configs/ti814x_evm.h -F: configs/ti814x_evm_defconfig diff --git a/board/ti/ti814x/Makefile b/board/ti/ti814x/Makefile deleted file mode 100644 index c5ff8d072851..000000000000 --- a/board/ti/ti814x/Makefile +++ /dev/null @@ -1,11 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Makefile -# -# Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ - -ifdef CONFIG_SPL_BUILD -obj-y := mux.o -endif - -obj-y += evm.o diff --git a/board/ti/ti814x/evm.c b/board/ti/ti814x/evm.c deleted file mode 100644 index 8ed80d2f4627..000000000000 --- a/board/ti/ti814x/evm.c +++ /dev/null @@ -1,190 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * evm.c - * - * Board functions for TI814x EVM - * - * Copyright (C) 2011, Texas Instruments, Incorporated - http://www.ti.com/ - */ - -#include <common.h> -#include <cpsw.h> -#include <env.h> -#include <errno.h> -#include <init.h> -#include <net.h> -#include <spl.h> -#include <asm/arch/cpu.h> -#include <asm/arch/hardware.h> -#include <asm/arch/omap.h> -#include <asm/arch/ddr_defs.h> -#include <asm/arch/clock.h> -#include <asm/arch/gpio.h> -#include <asm/arch/mmc_host_def.h> -#include <asm/arch/sys_proto.h> -#include <asm/io.h> -#include <asm/emif.h> -#include <asm/gpio.h> -#include "evm.h" - -DECLARE_GLOBAL_DATA_PTR; - -static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; - -/* UART Defines */ -#ifdef CONFIG_SPL_BUILD -static const struct cmd_control evm_ddr2_cctrl_data = { - .cmd0csratio = 0x80, - .cmd0iclkout = 0x00, - - .cmd1csratio = 0x80, - .cmd1iclkout = 0x00, - - .cmd2csratio = 0x80, - .cmd2iclkout = 0x00, -}; - -static const struct emif_regs evm_ddr2_emif0_regs = { - .sdram_config = 0x40801ab2, - .ref_ctrl = 0x10000c30, - .sdram_tim1 = 0x0aaaf552, - .sdram_tim2 = 0x043631d2, - .sdram_tim3 = 0x00000327, - .emif_ddr_phy_ctlr_1 = 0x00000007 -}; - -static const struct emif_regs evm_ddr2_emif1_regs = { - .sdram_config = 0x40801ab2, - .ref_ctrl = 0x10000c30, - .sdram_tim1 = 0x0aaaf552, - .sdram_tim2 = 0x043631d2, - .sdram_tim3 = 0x00000327, - .emif_ddr_phy_ctlr_1 = 0x00000007 -}; - -const struct dmm_lisa_map_regs evm_lisa_map_regs = { - .dmm_lisa_map_0 = 0x00000000, - .dmm_lisa_map_1 = 0x00000000, - .dmm_lisa_map_2 = 0x806c0300, - .dmm_lisa_map_3 = 0x806c0300, -}; - -static const struct ddr_data evm_ddr2_data = { - .datardsratio0 = ((0x35<<10) | (0x35<<0)), - .datawdsratio0 = ((0x20<<10) | (0x20<<0)), - .datawiratio0 = ((0<<10) | (0<<0)), - .datagiratio0 = ((0<<10) | (0<<0)), - .datafwsratio0 = ((0x90<<10) | (0x90<<0)), - .datawrsratio0 = ((0x50<<10) | (0x50<<0)), -}; - -void set_uart_mux_conf(void) -{ - /* Set UART pins */ - enable_uart0_pin_mux(); -} - -void set_mux_conf_regs(void) -{ - /* Set MMC pins */ - enable_mmc1_pin_mux(); - - /* Set Ethernet pins */ - enable_enet_pin_mux(); -} - -void sdram_init(void) -{ - config_dmm(&evm_lisa_map_regs); - - config_ddr(0, NULL, &evm_ddr2_data, &evm_ddr2_cctrl_data, - &evm_ddr2_emif0_regs, 0); - config_ddr(0, NULL, &evm_ddr2_data, &evm_ddr2_cctrl_data, - &evm_ddr2_emif1_regs, 1); -} -#endif - -/* - * Basic board specific setup. Pinmux has been handled already. - */ -int board_init(void) -{ - gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; - return 0; -} - -#if defined(CONFIG_MMC) -int board_mmc_init(bd_t *bis) -{ - omap_mmc_init(1, 0, 0, -1, -1); - - return 0; -} -#endif - -#ifdef CONFIG_DRIVER_TI_CPSW -static void cpsw_control(int enabled) -{ - /* VTP can be added here */ - - return; -} - -static struct cpsw_slave_data cpsw_slaves[] = { - { - .slave_reg_ofs = 0x50, - .sliver_reg_ofs = 0x700, - .phy_addr = 1, - }, - { - .slave_reg_ofs = 0x90, - .sliver_reg_ofs = 0x740, - .phy_addr = 0, - }, -}; - -static struct cpsw_platform_data cpsw_data = { - .mdio_base = CPSW_MDIO_BASE, - .cpsw_base = CPSW_BASE, - .mdio_div = 0xff, - .channels = 8, - .cpdma_reg_ofs = 0x100, - .slaves = 1, - .slave_data = cpsw_slaves, - .ale_reg_ofs = 0x600, - .ale_entries = 1024, - .host_port_reg_ofs = 0x28, - .hw_stats_reg_ofs = 0x400, - .bd_ram_ofs = 0x2000, - .mac_control = (1 << 5), - .control = cpsw_control, - .host_port_num = 0, - .version = CPSW_CTRL_VERSION_1, -}; -#endif - -int board_eth_init(bd_t *bis) -{ - uint8_t mac_addr[6]; - uint32_t mac_hi, mac_lo; - - if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { - printf("<ethaddr> not set. Reading from E-fuse\n"); - /* try reading mac address from efuse */ - mac_lo = readl(&cdev->macid0l); - mac_hi = readl(&cdev->macid0h); - mac_addr[0] = mac_hi & 0xFF; - mac_addr[1] = (mac_hi & 0xFF00) >> 8; - mac_addr[2] = (mac_hi & 0xFF0000) >> 16; - mac_addr[3] = (mac_hi & 0xFF000000) >> 24; - mac_addr[4] = mac_lo & 0xFF; - mac_addr[5] = (mac_lo & 0xFF00) >> 8; - - if (is_valid_ethaddr(mac_addr)) - eth_env_set_enetaddr("ethaddr", mac_addr); - else - printf("Unable to read MAC address. Set <ethaddr>\n"); - } - - return cpsw_register(&cpsw_data); -} diff --git a/board/ti/ti814x/evm.h b/board/ti/ti814x/evm.h deleted file mode 100644 index 6aebec62d4a4..000000000000 --- a/board/ti/ti814x/evm.h +++ /dev/null @@ -1,8 +0,0 @@ -#ifndef _EVM_H -#define _EVM_H - -void enable_uart0_pin_mux(void); -void enable_mmc1_pin_mux(void); -void enable_enet_pin_mux(void); - -#endif /* _EVM_H */ diff --git a/board/ti/ti814x/mux.c b/board/ti/ti814x/mux.c deleted file mode 100644 index fd9f36451158..000000000000 --- a/board/ti/ti814x/mux.c +++ /dev/null @@ -1,86 +0,0 @@ -/* - * mux.c - * - * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation version 2. - * - * This program is distributed "as is" WITHOUT ANY WARRANTY of any - * kind, whether express or implied; without even the implied warranty - * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <common.h> -#include <asm/arch/sys_proto.h> -#include <asm/arch/hardware.h> -#include <asm/arch/mux.h> -#include <asm/io.h> -#include <i2c.h> -#include "evm.h" - -static struct module_pin_mux uart0_pin_mux[] = { - {OFFSET(pincntl70), PULLUP_EN | MODE(0x01)}, /* UART0_RXD */ - {OFFSET(pincntl71), PULLUP_EN | MODE(0x01)}, /* UART0_TXD */ - {-1}, -}; - -static struct module_pin_mux mmc1_pin_mux[] = { - {OFFSET(pincntl1), PULLUP_EN | MODE(0x01)}, /* SD1_CLK */ - {OFFSET(pincntl2), PULLUP_EN | MODE(0x01)}, /* SD1_CMD */ - {OFFSET(pincntl3), PULLUP_EN | MODE(0x01)}, /* SD1_DAT[0] */ - {OFFSET(pincntl4), PULLUP_EN | MODE(0x01)}, /* SD1_DAT[1] */ - {OFFSET(pincntl5), PULLUP_EN | MODE(0x01)}, /* SD1_DAT[2] */ - {OFFSET(pincntl6), PULLUP_EN | MODE(0x01)}, /* SD1_DAT[3] */ - {OFFSET(pincntl74), PULLUP_EN | MODE(0x40)}, /* SD1_POW */ - {OFFSET(pincntl75), MODE(0x40)}, /* SD1_SDWP */ - {OFFSET(pincntl80), PULLUP_EN | MODE(0x02)}, /* SD1_SDCD */ - {-1}, -}; - -static struct module_pin_mux enet_pin_mux[] = { - {OFFSET(pincntl232), MODE(0x01)}, /* EMAC_RMREFCLK */ - {OFFSET(pincntl233), PULLUP_EN | MODE(0x01)}, /* MDCLK */ - {OFFSET(pincntl234), PULLUP_EN | MODE(0x01)}, /* MDIO */ - {OFFSET(pincntl235), MODE(0x01)}, /* EMAC[0]_MTCLK */ - {OFFSET(pincntl236), MODE(0x01)}, /* EMAC[0]_MCOL */ - {OFFSET(pincntl237), MODE(0x01)}, /* EMAC[0]_MCRS */ - {OFFSET(pincntl238), MODE(0x01)}, /* EMAC[0]_MRXER */ - {OFFSET(pincntl239), MODE(0x01)}, /* EMAC[0]_MRCLK */ - {OFFSET(pincntl240), MODE(0x01)}, /* EMAC[0]_MRXD[0] */ - {OFFSET(pincntl241), MODE(0x01)}, /* EMAC[0]_MRXD[1] */ - {OFFSET(pincntl242), MODE(0x01)}, /* EMAC[0]_MRXD[2] */ - {OFFSET(pincntl243), MODE(0x01)}, /* EMAC[0]_MRXD[3] */ - {OFFSET(pincntl244), MODE(0x01)}, /* EMAC[0]_MRXD[4] */ - {OFFSET(pincntl245), MODE(0x01)}, /* EMAC[0]_MRXD[5] */ - {OFFSET(pincntl246), MODE(0x01)}, /* EMAC[0]_MRXD[6] */ - {OFFSET(pincntl247), MODE(0x01)}, /* EMAC[0]_MRXD[7] */ - {OFFSET(pincntl248), MODE(0x01)}, /* EMAC[0]_MRXDV */ - {OFFSET(pincntl249), MODE(0x01)}, /* EMAC[0]_GMTCLK */ - {OFFSET(pincntl250), MODE(0x01)}, /* EMAC[0]_MTXD[0] */ - {OFFSET(pincntl251), MODE(0x01)}, /* EMAC[0]_MTXD[1] */ - {OFFSET(pincntl252), MODE(0x01)}, /* EMAC[0]_MTXD[2] */ - {OFFSET(pincntl253), MODE(0x01)}, /* EMAC[0]_MTXD[3] */ - {OFFSET(pincntl254), MODE(0x01)}, /* EMAC[0]_MTXD[4] */ - {OFFSET(pincntl255), MODE(0x01)}, /* EMAC[0]_MTXD[5] */ - {OFFSET(pincntl256), MODE(0x01)}, /* EMAC[0]_MTXD[6] */ - {OFFSET(pincntl257), MODE(0x01)}, /* EMAC[0]_MTXD[7] */ - {OFFSET(pincntl258), MODE(0x01)}, /* EMAC[0]_MTXEN */ -}; - -void enable_uart0_pin_mux(void) -{ - configure_module_pin_mux(uart0_pin_mux); -} - -void enable_mmc1_pin_mux(void) -{ - configure_module_pin_mux(mmc1_pin_mux); -} - -void enable_enet_pin_mux(void) -{ - configure_module_pin_mux(enet_pin_mux); -} diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig deleted file mode 100644 index 71c9119c7d06..000000000000 --- a/configs/ti814x_evm_defconfig +++ /dev/null @@ -1,45 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_SPL_GPIO_SUPPORT=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_TI814X=y -CONFIG_TARGET_TI814X_EVM=y -CONFIG_SPL_MMC_SUPPORT=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_SPL=y -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_TEXT_BASE=0x40300000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_BOOTDELAY=1 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_MISC_INIT_R is not set -CONFIG_VERSION_VARIABLE=y -# CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -# CONFIG_CMDLINE_EDITING is not set -# CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="U-Boot# " -CONFIG_CMD_ASKENV=y -CONFIG_CMD_MMC=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_MMC_OMAP_HS=y -CONFIG_PHY_ET1011C=y -CONFIG_MII=y -CONFIG_DRIVER_TI_CPSW=y -CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y
Adam Ford
