[U-Boot] [PATCH v8 8/9] mips: ath79: add AP121 reference board
This patch add board-level code and base DT for AP121.
Signed-off-by: Wills Wang wills.wang@live.com ---
Changes in v8: - Move board/ath79/ap121 into board/qca/ap121 - Move SYS_VENDOR into board-level for ap121
Changes in v7: - Use KSEG1 address for debug port in ap121
Changes in v6: - Convert SZ_XXX into hex in ap121.h - Remove useless CONFIG_SYS_INIT_SP_OFFSET in ap121.h - Add board_early_init_f for DDR and pin initialization - Select UART and SPI in ap121_defconfig
Changes in v5: - Move CONFIG_SYS_TEXT_BASE into ap121.h, and remove config.mk - Remove useless README file - Remove useless checkboard function
Changes in v4: None Changes in v3: - Add support for device tree
Changes in v2: - Add a reference board implemention
arch/mips/dts/Makefile | 1 + arch/mips/dts/ap121.dts | 43 ++++++++++++++++++++++ arch/mips/dts/ar933x.dtsi | 82 +++++++++++++++++++++++++++++++++++++++++ arch/mips/mach-ath79/Kconfig | 11 ++++++ board/qca/ap121/Kconfig | 12 ++++++ board/qca/ap121/MAINTAINERS | 6 +++ board/qca/ap121/Makefile | 5 +++ board/qca/ap121/ap121.c | 50 +++++++++++++++++++++++++ configs/ap121_defconfig | 46 +++++++++++++++++++++++ include/configs/ap121.h | 87 ++++++++++++++++++++++++++++++++++++++++++++ 10 files changed, 343 insertions(+) create mode 100644 arch/mips/dts/ap121.dts create mode 100644 arch/mips/dts/ar933x.dtsi create mode 100644 board/qca/ap121/Kconfig create mode 100644 board/qca/ap121/MAINTAINERS create mode 100644 board/qca/ap121/Makefile create mode 100644 board/qca/ap121/ap121.c create mode 100644 configs/ap121_defconfig create mode 100644 include/configs/ap121.h
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index b513918..30e5c68 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -2,6 +2,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
+dtb-$(CONFIG_TARGET_AP121) += ap121.dtb dtb-$(CONFIG_TARGET_PIC32MZDASK) += pic32mzda_sk.dtb
targets += $(dtb-y) diff --git a/arch/mips/dts/ap121.dts b/arch/mips/dts/ap121.dts new file mode 100644 index 0000000..e31f601 --- /dev/null +++ b/arch/mips/dts/ap121.dts @@ -0,0 +1,43 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include "ar933x.dtsi" + +/ { + model = "AP121 Reference Board"; + compatible = "qca,ap121", "qca,ar933x"; + + aliases { + spi0 = &spi0; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&xtal { + clock-frequency = <25000000>; +}; + +&uart0 { + status = "okay"; +}; + +&spi0 { + spi-max-frequency = <25000000>; + status = "okay"; + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + memory-map = <0x9f000000 0x00800000>; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; diff --git a/arch/mips/dts/ar933x.dtsi b/arch/mips/dts/ar933x.dtsi new file mode 100644 index 0000000..11f60a2 --- /dev/null +++ b/arch/mips/dts/ar933x.dtsi @@ -0,0 +1,82 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dt-bindings/interrupt-controller/irq.h> +#include "skeleton.dtsi" + +/ { + compatible = "qca,ar933x"; + + #address-cells = <1>; + #size-cells = <1>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + device_type = "cpu"; + compatible = "mips,mips24Kc"; + reg = <0>; + }; + }; + + clocks { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + xtal: xtal { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-output-names = "xtal"; + }; + }; + + pinctrl { + u-boot,dm-pre-reloc; + compatible = "qca,ar933x-pinctrl"; + ranges; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x18040000 0x100>; + }; + + ahb { + compatible = "simple-bus"; + ranges; + + #address-cells = <1>; + #size-cells = <1>; + + apb { + compatible = "simple-bus"; + ranges; + + #address-cells = <1>; + #size-cells = <1>; + + uart0: uart@18020000 { + compatible = "qca,ar9330-uart"; + reg = <0x18020000 0x20>; + interrupts = <128 IRQ_TYPE_LEVEL_HIGH>; + + status = "disabled"; + }; + }; + + spi0: spi@1f000000 { + compatible = "qca,ar7100-spi"; + reg = <0x1f000000 0x10>; + interrupts = <129 IRQ_TYPE_LEVEL_HIGH>; + + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + }; + }; +}; diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach-ath79/Kconfig index e35f1b5..c3012f8 100644 --- a/arch/mips/mach-ath79/Kconfig +++ b/arch/mips/mach-ath79/Kconfig @@ -22,4 +22,15 @@ config SOC_QCA953X help This supports QCA/Atheros qca953x family SOCs.
+choice + prompt "Board select" + +config TARGET_AP121 + bool "AP121 Reference Board" + select SOC_AR933X + +endchoice + +source "board/qca/ap121/Kconfig" + endmenu diff --git a/board/qca/ap121/Kconfig b/board/qca/ap121/Kconfig new file mode 100644 index 0000000..f7e768a --- /dev/null +++ b/board/qca/ap121/Kconfig @@ -0,0 +1,12 @@ +if TARGET_AP121 + +config SYS_VENDOR + default "qca" + +config SYS_BOARD + default "ap121" + +config SYS_CONFIG_NAME + default "ap121" + +endif diff --git a/board/qca/ap121/MAINTAINERS b/board/qca/ap121/MAINTAINERS new file mode 100644 index 0000000..8b02988 --- /dev/null +++ b/board/qca/ap121/MAINTAINERS @@ -0,0 +1,6 @@ +AP121 BOARD +M: Wills Wang wills.wang@live.com +S: Maintained +F: board/qca/ap121/ +F: include/configs/ap121.h +F: configs/ap121_defconfig diff --git a/board/qca/ap121/Makefile b/board/qca/ap121/Makefile new file mode 100644 index 0000000..ced5432 --- /dev/null +++ b/board/qca/ap121/Makefile @@ -0,0 +1,5 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y = ap121.o diff --git a/board/qca/ap121/ap121.c b/board/qca/ap121/ap121.c new file mode 100644 index 0000000..d6c60fe --- /dev/null +++ b/board/qca/ap121/ap121.c @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/ddr.h> +#include <debug_uart.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) +{ + void __iomem *regs; + u32 val; + + regs = map_physmem(AR71XX_GPIO_BASE, AR71XX_GPIO_SIZE, + MAP_NOCACHE); + + /* + * GPIO9 as input, GPIO10 as output + */ + val = readl(regs + AR71XX_GPIO_REG_OE); + val &= ~AR933X_GPIO(9); + val |= AR933X_GPIO(10); + writel(val, regs + AR71XX_GPIO_REG_OE); + + /* + * Enable UART, GPIO9 as UART_SI, GPIO10 as UART_SO + */ + val = readl(regs + AR71XX_GPIO_REG_FUNC); + val |= AR933X_GPIO_FUNC_UART_EN | AR933X_GPIO_FUNC_RES_TRUE; + writel(val, regs + AR71XX_GPIO_REG_FUNC); +} +#endif + +int board_early_init_f(void) +{ +#ifdef CONFIG_DEBUG_UART + debug_uart_init(); +#endif + ddr_init(); + return 0; +} diff --git a/configs/ap121_defconfig b/configs/ap121_defconfig new file mode 100644 index 0000000..6ba1e29 --- /dev/null +++ b/configs/ap121_defconfig @@ -0,0 +1,46 @@ +CONFIG_MIPS=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DM_SERIAL=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_ARCH_ATH79=y +CONFIG_TARGET_AP121=y +CONFIG_DEFAULT_DEVICE_TREE="ap121" +CONFIG_SYS_PROMPT="ap121 # " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_DATAFLASH=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PINCTRL=y +CONFIG_PINCONF=y +CONFIG_AR933X_PINCTRL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_AR933X=y +CONFIG_DEBUG_UART_BASE=0xb8020000 +CONFIG_DEBUG_UART_CLOCK=25000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_AR933X_UART=y +CONFIG_ATH79_SPI=y diff --git a/include/configs/ap121.h b/include/configs/ap121.h new file mode 100644 index 0000000..b06969b --- /dev/null +++ b/include/configs/ap121.h @@ -0,0 +1,87 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_SYS_TEXT_BASE 0x9f000000 + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_EARLY_INIT_F + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_MHZ 200 +#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) + +/* Cache Configuration */ +#define CONFIG_SYS_DCACHE_SIZE 0x8000 +#define CONFIG_SYS_ICACHE_SIZE 0x10000 +#define CONFIG_SYS_CACHELINE_SIZE 32 + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_MALLOC_LEN 0x40000 +#define CONFIG_SYS_BOOTPARAMS_LEN 0x20000 + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_LOAD_ADDR 0x81000000 + +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_SYS_INIT_RAM_ADDR 0xbd000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE - 1) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE \ + {9600, 19200, 38400, 57600, 115200} + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock2 " \ + "rootfstype=squashfs" +#define CONFIG_BOOTCOMMAND "sf probe;" \ + "mtdparts default;" \ + "bootm 0x9f300000" +#define CONFIG_LZMA +#define CONFIG_OF_LIBFDT + +#define MTDIDS_DEFAULT "nor0=spi-flash.0" +#define MTDPARTS_DEFAULT "mtdparts=spi-flash.0:" \ + "256k(u-boot),64k(u-boot-env)," \ + "2752k(rootfs),896k(uImage)," \ + "64k(NVRAM),64k(ART)" + +#define CONFIG_ENV_SPI_MAX_HZ 25000000 +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_OFFSET 0x40000 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#define CONFIG_ENV_SIZE 0x10000 + +/* + * Command + */ +#define CONFIG_CMD_MTDPARTS + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE + +/* + * Diagnostics + */ +#define CONFIG_SYS_MEMTEST_START 0x80100000 +#define CONFIG_SYS_MEMTEST_END 0x83f00000 +#define CONFIG_CMD_MEMTEST + +#endif /* __CONFIG_H */
Wills Wang
