[PATCH] pci: pci_mvebu: Add support for reset-gpios
Release PERST# signal via GPIO when "reset-gpios" is defined in device tree.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/pci/pci_mvebu.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/drivers/pci/pci_mvebu.c b/drivers/pci/pci_mvebu.c index d80f87e0cfc6..269c027db204 100644 --- a/drivers/pci/pci_mvebu.c +++ b/drivers/pci/pci_mvebu.c @@ -22,6 +22,7 @@ #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> +#include <asm-generic/gpio.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/errno.h> @@ -60,6 +61,7 @@ struct mvebu_pcie { struct resource mem; void __iomem *iobase; struct resource io; + struct gpio_desc reset_gpio; u32 intregs; u32 port; u32 lane; @@ -416,6 +418,14 @@ static int mvebu_pcie_probe(struct udevice *dev) struct udevice *ctlr = pci_get_controller(dev); struct pci_controller *hose = dev_get_uclass_priv(ctlr); u32 reg; + int ret; + + /* Request for optional PERST# GPIO */ + ret = gpio_request_by_name(dev, "reset-gpios", 0, &pcie->reset_gpio, GPIOD_IS_OUT); + if (ret && ret != -ENOENT) { + printf("%s: unable to request reset-gpios: %d\n", pcie->name, ret); + return ret; + }
/* * Change Class Code of PCI Bridge device to PCI Bridge (0x600400) @@ -537,6 +547,10 @@ static int mvebu_pcie_probe(struct udevice *dev) pcie->cfgcache[(PCI_PREF_MEMORY_BASE - 0x10) / 4] = PCI_PREF_RANGE_TYPE_64 | (PCI_PREF_RANGE_TYPE_64 << 16);
+ /* Release PERST# via GPIO when it was defined */ + if (dm_gpio_is_valid(&pcie->reset_gpio)) + dm_gpio_set_value(&pcie->reset_gpio, 0); + mvebu_pcie_wait_for_link(pcie);
- struct gpio_desc reset_gpio; u32 intregs; u32 port; u32 lane;
int ret;
return ret;
- Change Class Code of PCI Bridge device to PCI Bridge (0x600400)
- /* Release PERST# via GPIO when it was defined */
- if (dm_gpio_is_valid(&pcie->reset_gpio))
So you're only releasing the GPIO (setting to inactive) here. Wouldn't it make sense to first use the GPIO (if available via DT) to actually reset the PCI device? How is this done in the Kernel driver(s)?
Thanks, Stefan
- int ret;
- /* Request for optional PERST# GPIO */
- ret = gpio_request_by_name(dev, "reset-gpios", 0, &pcie->reset_gpio, GPIOD_IS_OUT);
- if (ret && ret != -ENOENT) {
return ret;
Thanks, Stefan
This is something which I do not know what is the best. Kernel driver pci-mvebu.c has same logic - just release from reset at startup.
- int ret;
return ret;
Thanks, Stefan
I see. Could you please check some other PCI Kernel drivers, how they handle reset-gpios signalling?
Thanks, Stefan
- int ret;
return ret;
Thanks, Stefan
Thanks, Stefan
Every kernel driver is doing it differently. Touching PERST# in bootloader is for two different purposes (which is board specific):
1) Board is designed in a way that PCIe stays in reset after CPU starts and it is up to the SW to release PCIe reset, including reset of endpoint cards.
I think that this is recommended design due to how are PCIe requirements for timings and dependences on other stuff (like PCIe clock stabilization, power on, etc...).
This is also what I prefer for designing new boards.
2) Board is designed in a way that endpoint PCIe card is after CPU reset immediately released from the reset or maybe that PCIe card is not reset at all after CPU reset.
In this case lot of "broken" cards do not work until they are manually reset from software, which requires flipping PERST# pin manually (via GPIO).
Bootloader / U-Boot starts as the first SW and depends on specific state of CPU reset. So it can expects that nothing release PERST# from 1) before it.
In operating system it is harder as kernel cannot do this assumption.
And to make it even harder, there is important question: How long should be PERST# signal active to ensure that endpoint card is correctly reset?
Without knowing answer to this question, we do not know and cannot implement 2) properly.
I was not able to find answer for this question in PCIe specs, so I have asked it on mailing linux-pci mailing list: https://lore.kernel.org/linux-pci/20210310110535.zh4pnn4vpmvzwl5q@pali/ (and it is still without clear answer)
And if we go deeper to the PCIe initialization (as PERST# signal is part of it) I described some proposal for Linux kernel how it should be implemented correctly: https://lore.kernel.org/linux-pci/20211022183808.jdeo7vntnagqkg7g@pali/
So all this stuff needs to be rewritten, ideally into some common framework. Until that happens, every driver would continue doing it by its own -- and differently.
Yes, it is a mess, but I do not know what we can do with it.
Btw, in past I did also investigation of those resets and delays, and really every kernel driver is doing it differently: https://lore.kernel.org/linux-pci/20200424092546.25p3hdtkehohe3xw@pali/
Those card that you mention as broken are often just fine, from the standard point, they are just a pain ...
I think in general this last one is not a correct assumption, reset could just not be asserted at that point because of the hardware design.
I recently had issue because of that (Linux Kernel, not U-Boot), and this is the fix that was merged:
a6809941c1f1 ("PCI: imx6: Fix PERST# start-up sequence")
(and I also had myself similar issue while working on Intel platform firmware, e.g. UEFI).
Said that I agree that the topic is way more complicated than it should be :-/
Yes, that is why I marked the last part that applies only for hardware design from option 1) mentioned above.
Yes, it is :-( I proposed some options for kernel but it is lot of work for which probably nobody has time...
- int ret;
return ret;
- } /* * Change Class Code of PCI Bridge device to PCI Bridge (0x600400)
Thanks, Stefan
Thanks, Stefan
Pali, thanks for the detailed explanation.
With this in mind, I think it's best right now to accept your patch as-is, as this does minimal change (risk of breakage) in this GPIO area.
Thank, Stefan
int ret;
return ret;
While running some build tests, this error shows on some Kirkwood boards:
$ make pogo_v4_defconfig $ make -s -j20 ===================== WARNING ====================== This board does not use CONFIG_TIMER (Driver Model for Timer drivers). Please update the board to use CONFIG_TIMER before the v2023.01 release. Failure to update by the deadline may result in board removal. See doc/develop/driver-model/migration.rst for more info. ==================================================== ===================== WARNING ====================== This board does not use CONFIG_DM_SERIAL (Driver Model for Serial drivers). Please update the board to use CONFIG_DM_SERIAL before the v2023.04 release. Failure to update by the deadline may result in board removal. See doc/develop/driver-model/migration.rst for more info. ==================================================== /opt/kernel.org/gcc-11.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ld.bfd: drivers/pci/pci_mvebu.o: in function `mvebu_pcie_probe': /home/stefan/git/u-boot/u-boot-marvell/drivers/pci/pci_mvebu.c:424: undefined reference to `gpio_request_by_name' /opt/kernel.org/gcc-11.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ld.bfd: /home/stefan/git/u-boot/u-boot-marvell/drivers/pci/pci_mvebu.c:552: undefined reference to `dm_gpio_set_value' make: *** [Makefile:1818: u-boot] Error 1
Could you please take a look and make sure, that world build succeeds?
Thanks, Stefan
- int ret;
return ret;
- mvebu_pcie_wait_for_link(pcie); return 0;
Thanks, Stefan
There is probably missing DM_GPIO. Now I started CI test on github: https://github.com/u-boot/u-boot/pull/204 After that I will send v2.
- int ret;
return ret;
Thanks, Stefan
Perfect. Thanks.
Thanks, Stefan
- int ret;
return ret;
Thanks, Stefan
Perfect. Thanks.
Thanks, Stefan
CI tests passed, now sending v2.
Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Stefan Roese sr@denx.de --- Changes in v2: * select DM_GPIO * use asm/gpio.h --- drivers/pci/Kconfig | 1 + drivers/pci/pci_mvebu.c | 14 ++++++++++++++ 2 files changed, 15 insertions(+)
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 436acca898e4..22f4995453ed 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -301,6 +301,7 @@ config PCI_MVEBU depends on (ARCH_KIRKWOOD || ARCH_MVEBU) select MISC select DM_RESET + select DM_GPIO help Say Y here if you want to enable PCIe controller support on Kirkwood and Armada 370/XP/375/38x SoCs. diff --git a/drivers/pci/pci_mvebu.c b/drivers/pci/pci_mvebu.c index d80f87e0cfc6..5bd340a421b8 100644 --- a/drivers/pci/pci_mvebu.c +++ b/drivers/pci/pci_mvebu.c @@ -22,6 +22,7 @@ #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> +#include <asm/gpio.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/errno.h> @@ -60,6 +61,7 @@ struct mvebu_pcie { struct resource mem; void __iomem *iobase; struct resource io; + struct gpio_desc reset_gpio; u32 intregs; u32 port; u32 lane; @@ -416,6 +418,14 @@ static int mvebu_pcie_probe(struct udevice *dev) struct udevice *ctlr = pci_get_controller(dev); struct pci_controller *hose = dev_get_uclass_priv(ctlr); u32 reg; + int ret; + + /* Request for optional PERST# GPIO */ + ret = gpio_request_by_name(dev, "reset-gpios", 0, &pcie->reset_gpio, GPIOD_IS_OUT); + if (ret && ret != -ENOENT) { + printf("%s: unable to request reset-gpios: %d\n", pcie->name, ret); + return ret; + }
Changes in v2:
- select DM_GPIO
- use asm/gpio.h
Thanks, Stefan
- select DM_GPIO help Say Y here if you want to enable PCIe controller support on Kirkwood and Armada 370/XP/375/38x SoCs.
int ret;
return ret;
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
Changes in v2:
- select DM_GPIO
- use asm/gpio.h
int ret;
return ret;
Francesco Dolcini
Pali Rohár
Stefan Roese
