[U-Boot] [PATCH 2/2] usb: r8a66597: Fix initilization size of r8a66597 info, structure
Initialization of r8a66597 info structure is not enough. Because initilization was used size of pointer. This fixes that use size of r8a6659 info structure.
Signed-off-by: Yasuhisa Umano yasuhisa.umano.zc@renesas.com --- drivers/usb/host/r8a66597-hcd.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/host/r8a66597-hcd.c b/drivers/usb/host/r8a66597-hcd.c index c58d2a9..8e82212 100644 --- a/drivers/usb/host/r8a66597-hcd.c +++ b/drivers/usb/host/r8a66597-hcd.c @@ -807,7 +807,7 @@ int usb_lowlevel_init(int index, enum usb_init_type init, void **controller)
R8A66597_DPRINT("%s\n", __func__);
- memset(r8a66597, 0, sizeof(r8a66597)); + memset(r8a66597, 0, sizeof(struct r8a66597)); r8a66597->reg = CONFIG_R8A66597_BASE_ADDR;
disable_controller(r8a66597);
- memset(r8a66597, 0, sizeof(struct r8a66597));
Let's use sizeof(*r8a66597) instead . This is more scalable as you won't need to adjust this code when you change the data type of the *r8a66597 pointer,
I will adjust that and apply with sizeof(*r8a66597); , does that work for you?
Best regards, Marek Vasut
Hi, Thanks for your comment.
Indeed. I will check your point and resend updated patch.
Best regards, Yasuhisa
I pushed the fixed version and it's in u-boot-usb/master . Base subsequent patches on that please .
Yasuhisa Umano
yasuhisa umano
