[U-Boot] Root-Filesystem ober NFS doesn't work... --> Kernel panic ---> corrupt textfile
I'm sorry, somehow the log.txt in my last e-mail got corrupted....
Here it is:
Uncompressing Linux............................................................................................... done, booting the kernel. Linux version 2.6.14-M5 (Alan@ace-yang) (gcc version 3.3.2) #837 Tue Aug 14 14:14:03 CST 2007 CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T) Machine: Artila M501 SOM Memory policy: ECC disabled, Data cache writeback Clocks: CPU 179 MHz, master 59 MHz, main 18.432 MHz CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets Built 1 zonelists Kernel command line: root=/dev/nfs rw nfsroot=192.168.2.40:/opt/arm ip=192.168.2.196:192.168.2.40:192.168.2.254:255.255.255.0:michael-laptop::off console=ttyS0,115200 AT91: 128 gpio irqs in 4 banks PID hash table entries: 256 (order: 8, 4096 bytes) Console: colour dummy device 80x30 Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 32MB = 32MB total Memory: 26824KB available (2389K code, 523K data, 104K init) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok checking if image is initramfs...it isn't (no cpio magic); looks like an initrd Freeing initrd memory: 2509K NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub NetWinder Floating Point Emulator V0.97 (extended precision) JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc. Initializing Cryptographic API Matrix500 RTC driver. Matrix500 GPIO Driver Loaded. AT91 SPI driver loaded AT91 Watchdog Timer enabled (5 seconds) ttyS0 at MMIO 0xfefff200 (irq = 1) is a AT91_SERIAL ttyS1 at MMIO 0xfefc0000 (irq = 6) is a AT91_SERIAL ttyS2 at MMIO 0xfefc4000 (irq = 7) is a AT91_SERIAL ttyS3 at MMIO 0xfefc8000 (irq = 8) is a AT91_SERIAL ttyS4 at MMIO 0xfefcc000 (irq = 9) is a AT91_SERIAL io scheduler noop registered io scheduler anticipatory registered RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize PPP generic driver version 2.4.2 PPP BSD Compression module registered NET: Registered protocol family 24 eth0: Link now 100-FullDuplex eth0: AT91 ethernet at 0xfefbc000 int=24 100-FullDuplex (00:13:48:00:77:b5) eth0: Davicom 9161AE PHY (Copper) physmap flash device: 1000000 at 10000000 phys_mapped_flash: Found 1 x16 devices at 0x0 in 16-bit bank Intel/Sharp Extended Query Table at 0x010A Using buffer write method cfi_cmdset_0001: Erase suspend on write enabled RedBoot partition parsing not available block2mtd: version $Revision: 1.28 $ at91rm9200-ohci at91rm9200-ohci: AT91RM9200 OHCI at91rm9200-ohci at91rm9200-ohci: new USB bus registered, assigned bus number 1 at91rm9200-ohci at91rm9200-ohci: irq 23, io mem 0x00300000 usb usb1: Product: AT91RM9200 OHCI usb usb1: Manufacturer: Linux 2.6.14-M5 ohci_hcd usb usb1: SerialNumber: at91rm9200 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected usbcore: registered new driver cdc_acm drivers/usb/class/cdc-acm.c: v0.23:USB Abstract Control Model driver for USB modems and ISDN adapters usbcore: registered new driver usblp drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. rtusb init ====> usbcore: registered new driver rt73 usbcore: registered new driver usbserial drivers/usb/serial/usb-serial.c: USB Serial support registered for Generic usbcore: registered new driver usbserial_generic drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0 drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device usbcore: registered new driver ftdi_sio drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver drivers/usb/serial/usb-serial.c: USB Serial support registered for PL-2303 usbcore: registered new driver pl2303 drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver v0.12 mice: PS/2 mouse device common for all mice i2c /dev entries driver Found AT91 i2c RTC found. AT91RM9200 MCI initialized NET: Registered protocol family 2 IP route cache hash table entries: 512 (order: -1, 2048 bytes) TCP established hash table entries: 2048 (order: 1, 8192 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered ip_conntrack version 2.3 (256 buckets, 2048 max) - 240 bytes per conntrack ctnetlink v0.90: registering with nfnetlink. ip_tables: (C) 2000-2002 Netfilter core team ipt_recent v0.3.1: Stephen Frost sfrost@snowman.net. http://snowman.net/projects/ipt_recent/ arp_tables: (C) 2002 David S. Miller TCP bic registered Netfilter messages via NETLINK v0.30. NET: Registered protocol family 1 NET: Registered protocol family 17 eth0: Link now 100-FullDuplex IP-Config: Complete: device=eth0, addr=192.168.2.196, mask=255.255.255.0, gw=192.168.2.254, host=michael-laptop, domain=, nis-domain=(none), bootserver=192.168.2.40, rootserver=192.168.2.40, rootpath= RAMDISK: Compressed image found at block 0 VFS: Mounted root (ext2 filesystem). VFS: Cannot open root device "nfs" or unknown-block(0,255) Please append a correct "root=" boot option Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,255)
Michael Schmid
