[U-Boot] [PATCH] sf: fix sf probe
This patch fixes the "sf probe" command. The very first SPI flash probe passes, for instance when u-boot tries to read its environment settings from a (Q)SPI memory but next "sf probe" commands fail because the flash memory node is unbound from the SPI controller children nodes.
Signed-off-by: Cyrille Pitchen cyrille.pitchen@atmel.com Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
cmd/sf.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/cmd/sf.c b/cmd/sf.c index 286906c..65b117f 100644 --- a/cmd/sf.c +++ b/cmd/sf.c @@ -125,7 +125,6 @@ static int do_spi_flash_probe(int argc, char * const argv[]) ret = spi_find_bus_and_cs(bus, cs, &bus_dev, &new); if (!ret) { device_remove(new); - device_unbind(new); } flash = NULL; ret = spi_flash_probe_bus_cs(bus, cs, speed, mode, &new);
(Added Tom to Cc)
Without this patch, "sf probe" fails miserably. So its definitely a "must have" for this release.
Tested-by: Stefan Roese sr@denx.de
Thanks, Stefan
Hi Tom,
On 25.08.2016 13:13, Stefan Roese wrote:
(Added Tom to Cc)
Tom, could you please include this patch in this release? Without it DM based "sf probe" just fails. At least in my tests.
Thanks, Stefan
mfG Schmelzer Hannes
} flash = NULL; ret = spi_flash_probe_bus_cs(bus, cs, speed, mode, &new);device_unbind(new);
Tested-by: Hannes Schmelzer oe5hpm@oevsv.at
The original code was to handle 'sf probe' where it actually creates a new ad-hoc device (not from the device tree). But I'm happy to drop this.
- Simon
Signed-off-by: Cyrille Pitchen cyrille.pitchen@atmel.com Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Tested-by: Stefan Roese sr@denx.de Tested-by: Hannes Schmelzer oe5hpm@oevsv.at Reviewed-by: Simon Glass sjg@chromium.org
participants (5)
Hannes Schmelzer
Stefan Roese
Wenyou Yang
