[PATCH 00/19] Add Cadence NAND Driver support
This patchset add Cadence NAND driver support for Intel Agilex5 devices.
The NAND driver is leveraged from the cadence-nand-controller.c from Linux. U-Boot will support read, write and erase NAND with Cadence driver. The driver further enhanced in U-Boot to support NAND booting from FSBL and support boot to kernel via UBIFS.
Dinesh Maniyam (19): dt: nand: add cadence nand dt-bindings arm: dts: agilex5: Enabled cdns-nand dts setting include: asm: Add support to read/write 64-bit drivers: mtd: nand: Add driver for Cadence Nand drivers: mtd: nand: cadence: Add support for read status command drivers: mtd: nand: cadence: Add support for readid command drivers: mtd: nand: cadence: Add support for NAND_CMD_PARAM drivers: mtd: nand: cadence: Support NAND_CMD_RESET drivers: mtd: nand: cadence: Support cmd SET_FEATURES & GET_FEATURES drivers: mtd: nand: cadence: Flush dma descriptor drivers: mtd: nand: cadence: Poll for desc complete status drivers: mtd: nand: cadence: Use bounce buffer drivers: nand: Enabled Kconfig and Makefile for cdns-nand configs: nand2_defconfig: Enable configs for nand boot drivers: mtd: nand: base: Add support for Hardware ECC for check bad block drivers: mtd: nand: spl: Add support for nand SPL load image drivers: mtd: nand: Enabled Kconfig and Makefile for Cadence-SPL drivers: mtd: nand: Kconfig: Remove SYS_NAND_BLOCK_SIZE dependency drivers: mtd: nand: Kconfig: Enabled self-init for cdns-nand SPL
arch/arm/dts/socfpga_agilex5.dtsi | 14 + .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 28 + arch/arm/include/asm/io.h | 25 + configs/socfpga_agilex5_nand2_defconfig | 169 ++ .../mtd/cadence,nand.yaml | 98 + drivers/mtd/nand/raw/Kconfig | 19 +- drivers/mtd/nand/raw/Makefile | 2 + drivers/mtd/nand/raw/cadence_nand.c | 2386 +++++++++++++++++ drivers/mtd/nand/raw/cadence_spl.c | 96 + drivers/mtd/nand/raw/nand_base.c | 71 +- include/cadence-nand.h | 528 ++++ include/linux/mtd/rawnand.h | 13 + 12 files changed, 3424 insertions(+), 25 deletions(-) create mode 100644 configs/socfpga_agilex5_nand2_defconfig create mode 100644 doc/device-tree-bindings/mtd/cadence,nand.yaml create mode 100644 drivers/mtd/nand/raw/cadence_nand.c create mode 100644 drivers/mtd/nand/raw/cadence_spl.c create mode 100644 include/cadence-nand.h
The Cadence NAND is a configurable mtd raw block which supports multiple options for chipsets, clocking and reset structure, and feature list.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- .../mtd/cadence,nand.yaml | 98 +++++++++++++++++++ 1 file changed, 98 insertions(+) create mode 100644 doc/device-tree-bindings/mtd/cadence,nand.yaml
diff --git a/doc/device-tree-bindings/mtd/cadence,nand.yaml b/doc/device-tree-bindings/mtd/cadence,nand.yaml new file mode 100644 index 0000000000..11ce023ec6 --- /dev/null +++ b/doc/device-tree-bindings/mtd/cadence,nand.yaml @@ -0,0 +1,98 @@ +# SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/mtd/cadence,nand.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Cadence NAND controller + +maintainers: + - Dinesh Maniyam dinesh.maniyam@intel.com + +properties: + compatible: + enum: + - cdns,nand + + reg-names: + description: | + There are two register regions: + reg: register interface + sdma: host data/command interface + items: + - const: reg + - const: sdma + + reg: + minItems: 2 + maxItems: 2 + + interrupts: + maxItems: 1 + + clocks: + description: | + There is one controller core clock + maxItems: 1 + + resets: + description: | + There are two resets: + controller core reset + combo-phy register reset + minItems: 1 + maxItems: 2 + + cdns,board-delay-ps: + description: | + Estimated Board delay. The value includes the total + round trip delay for the signals and is used for deciding on values + associated with data read capture. The example formula for SDR mode is + the following: + board delay = RE#PAD delay + PCB trace to device + PCB trace from device + + DQ PAD delay + enum: + - 4830 + +patternProperties: + "^nand@[a-f0-9]$": + type: object + properties: + compatible: + const: cdns,nand + + reg: + maxItems: 1 + + label: + maxItems: 1 + +required: + - compatible + - reg + - interrupts + - clocks + - cdns,board-delay-ps + +unevaluatedProperties: false + +examples: + - | + nand-controller@60000000 { + compatible = "cdns,nand"; + reg = <0x60000000 0x10000>, <0x80000000 0x1000>; + reg-names = "reg", "sdma"; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clk>; + cdns,board-delay-ps = <4830>; + interrupts = <2 0>; + nand@0 { + label = "nand-0"; + reg = <0>; + }; + nand@1 { + label = "nand-1"; + reg = <1>; + }; + };
This patch is to enable cdns-nand dts setting for the socfpga_agilex5 family device.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- arch/arm/dts/socfpga_agilex5.dtsi | 14 ++++++++++ .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 28 +++++++++++++++++++ 2 files changed, 42 insertions(+)
diff --git a/arch/arm/dts/socfpga_agilex5.dtsi b/arch/arm/dts/socfpga_agilex5.dtsi index 03b5504049..64665e499e 100644 --- a/arch/arm/dts/socfpga_agilex5.dtsi +++ b/arch/arm/dts/socfpga_agilex5.dtsi @@ -330,6 +330,20 @@ status = "disabled"; };
+ nand: nand@10b80000 { + compatible = "cdns,nand"; + reg = <0x10b80000 0x10000>, + <0x10840000 0x1000>; + reg-names = "reg", "sdma"; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 97 4>; + clocks = <&clkmgr AGILEX5_NAND_CLK>; + resets = <&rst NAND_RESET>, <&rst COMBOPHY_RESET>; + cdns,board-delay-ps = <4830>; + status = "disabled"; + }; + ocram: sram@00000000 { compatible = "mmio-sram"; reg = <0x00000000 0x200000>; diff --git a/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi index 9eb21d6542..f9cca84ee3 100644 --- a/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi +++ b/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi @@ -41,6 +41,10 @@ /delete-property/ cdns,read-delay; };
+&flash1 { + bootph-all; +}; + &i3c0 { bootph-all; }; @@ -102,6 +106,10 @@ status = "okay"; };
+&nand { + bootph-all; +}; + &timer0 { bootph-all; }; @@ -122,3 +130,23 @@ bootph-all; };
+&nand { + status = "okay"; + + flash1: flash@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "u-boot"; + reg = <0 0x200000>; + }; + partition@200000 { + label = "root"; + reg = <0x200000 0x3fe00000>; + }; + }; +}; + +
The patch is to extend support read and write 64-bits of buffer. This is required for Cadence NAND Driver to read/write ONFI parameter page. The parameter page is mapped to 64-bit. With only read/write 32 bits of buffer,there is an issue of overwriting last 4 bits of buffer which failed the NAND identification.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- arch/arm/include/asm/io.h | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/arch/arm/include/asm/io.h b/arch/arm/include/asm/io.h index 89b1015bc4..e3ea5f0eb2 100644 --- a/arch/arm/include/asm/io.h +++ b/arch/arm/include/asm/io.h @@ -391,6 +391,31 @@ void __memset_io(volatile void __iomem *dst, int c, size_t count) count--; } } + +static inline void readsq(const void __iomem *addr, void *buffer, + unsigned int count) +{ + if (count) { + u64 *buf = buffer; + + do { + u64 x = __raw_readq(addr); + *buf++ = x; + } while (--count); + } +} + +static inline void writesq(void __iomem *addr, const void *buffer, + unsigned int count) +{ + if (count) { + const u64 *buf = buffer; + + do { + __raw_writeq(*buf++, addr); + } while (--count); + } +} #endif /* CONFIG_ARM64 */
#ifdef CONFIG_ARM64
This patch is to enable driver for Cadence NAND for the family device agilex5. This driver is leveraged from linux.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/cadence_nand.c | 2210 +++++++++++++++++++++++++++ include/cadence-nand.h | 526 +++++++ 2 files changed, 2736 insertions(+) create mode 100644 drivers/mtd/nand/raw/cadence_nand.c create mode 100644 include/cadence-nand.h
diff --git a/drivers/mtd/nand/raw/cadence_nand.c b/drivers/mtd/nand/raw/cadence_nand.c new file mode 100644 index 0000000000..f9f28c392b --- /dev/null +++ b/drivers/mtd/nand/raw/cadence_nand.c @@ -0,0 +1,2210 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Cadence NAND flash controller driver + * + * Copyright (C) 2019 Cadence + * + * Author: Piotr Sroka piotrs@cadence.com + * + */ + +#include <cadence-nand.h> +#include <clk.h> +#include <dm.h> +#include <hang.h> +#include <malloc.h> +#include <memalign.h> +#include <nand.h> +#include <reset.h> +#include <wait_bit.h> +#include <dm/device_compat.h> +#include <dm/devres.h> +#include <linux/bitfield.h> +#include <linux/bug.h> +#include <linux/delay.h> +#include <linux/dma-direction.h> +#include <linux/dma-mapping.h> +#include <linux/io.h> +#include <linux/iopoll.h> +#include <linux/ioport.h> +#include <linux/printk.h> +#include <linux/sizes.h> + +static inline struct cadence_nand_info *mtd_to_cadence(struct mtd_info *mtd) +{ + return container_of(mtd_to_nand(mtd), struct cadence_nand_info, selected_chip); +} + +static inline struct +cdns_nand_chip *to_cdns_nand_chip(struct nand_chip *chip) +{ + return container_of(chip, struct cdns_nand_chip, chip); +} + +static bool +cadence_nand_dma_buf_ok(struct cadence_nand_info *cadence, const void *buf, + u32 buf_len) +{ + u8 data_dma_width = cadence->caps2.data_dma_width; + + return buf && + likely(IS_ALIGNED((uintptr_t)buf, data_dma_width)) && + likely(IS_ALIGNED(buf_len, DMA_DATA_SIZE_ALIGN)); +} + +static int cadence_nand_wait_for_value(struct cadence_nand_info *cadence, + u32 reg_offset, u32 timeout_us, + u32 mask, bool is_clear) +{ + u32 val; + int ret; + + ret = readl_poll_sleep_timeout(cadence->reg + reg_offset, + val, !(val & mask) == is_clear, + 10, timeout_us); + + if (ret < 0) { + dev_err(cadence->dev, + "Timeout while waiting for reg %x with mask %x is clear %d\n", + reg_offset, mask, is_clear); + } + + return ret; +} + +static int cadence_nand_set_ecc_enable(struct cadence_nand_info *cadence, + bool enable) +{ + u32 reg; + + if (cadence_nand_wait_for_value(cadence, CTRL_STATUS, + TIMEOUT_US, + CTRL_STATUS_CTRL_BUSY, true)) + return -ETIMEDOUT; + + reg = readl_relaxed(cadence->reg + ECC_CONFIG_0); + + if (enable) + reg |= ECC_CONFIG_0_ECC_EN; + else + reg &= ~ECC_CONFIG_0_ECC_EN; + + writel_relaxed(reg, cadence->reg + ECC_CONFIG_0); + + return 0; +} + +static void cadence_nand_set_ecc_strength(struct cadence_nand_info *cadence, + u8 corr_str_idx) +{ + u32 reg; + + if (cadence->curr_corr_str_idx == corr_str_idx) + return; + + reg = readl_relaxed(cadence->reg + ECC_CONFIG_0); + reg &= ~ECC_CONFIG_0_CORR_STR; + reg |= FIELD_PREP(ECC_CONFIG_0_CORR_STR, corr_str_idx); + writel_relaxed(reg, cadence->reg + ECC_CONFIG_0); + + cadence->curr_corr_str_idx = corr_str_idx; +} + +static int cadence_nand_get_ecc_strength_idx(struct cadence_nand_info *cadence, + u8 strength) +{ + int i, corr_str_idx = -1; + + for (i = 0; i < BCH_MAX_NUM_CORR_CAPS; i++) { + if (cadence->ecc_strengths[i] == strength) { + corr_str_idx = i; + break; + } + } + + return corr_str_idx; +} + +static int cadence_nand_set_skip_marker_val(struct cadence_nand_info *cadence, + u16 marker_value) +{ + u32 reg; + + if (cadence_nand_wait_for_value(cadence, CTRL_STATUS, + TIMEOUT_US, + CTRL_STATUS_CTRL_BUSY, true)) + return -ETIMEDOUT; + + reg = readl_relaxed(cadence->reg + SKIP_BYTES_CONF); + reg &= ~SKIP_BYTES_MARKER_VALUE; + reg |= FIELD_PREP(SKIP_BYTES_MARKER_VALUE, + marker_value); + + writel_relaxed(reg, cadence->reg + SKIP_BYTES_CONF); + + return 0; +} + +static int cadence_nand_set_skip_bytes_conf(struct cadence_nand_info *cadence, + u8 num_of_bytes, + u32 offset_value, + int enable) +{ + u32 reg, skip_bytes_offset; + + if (cadence_nand_wait_for_value(cadence, CTRL_STATUS, + TIMEOUT_US, + CTRL_STATUS_CTRL_BUSY, true)) + return -ETIMEDOUT; + + if (!enable) { + num_of_bytes = 0; + offset_value = 0; + } + + reg = readl_relaxed(cadence->reg + SKIP_BYTES_CONF); + reg &= ~SKIP_BYTES_NUM_OF_BYTES; + reg |= FIELD_PREP(SKIP_BYTES_NUM_OF_BYTES, + num_of_bytes); + skip_bytes_offset = FIELD_PREP(SKIP_BYTES_OFFSET_VALUE, + offset_value); + + writel_relaxed(reg, cadence->reg + SKIP_BYTES_CONF); + writel_relaxed(skip_bytes_offset, cadence->reg + SKIP_BYTES_OFFSET); + + return 0; +} + +/* Functions enables/disables hardware detection of erased data */ +static void cadence_nand_set_erase_detection(struct cadence_nand_info *cadence, + bool enable, + u8 bitflips_threshold) +{ + u32 reg; + + reg = readl_relaxed(cadence->reg + ECC_CONFIG_0); + + if (enable) + reg |= ECC_CONFIG_0_ERASE_DET_EN; + else + reg &= ~ECC_CONFIG_0_ERASE_DET_EN; + + writel_relaxed(reg, cadence->reg + ECC_CONFIG_0); + writel_relaxed(bitflips_threshold, cadence->reg + ECC_CONFIG_1); +} + +static int cadence_nand_set_access_width16(struct cadence_nand_info *cadence, + bool bit_bus16) +{ + u32 reg; + + if (cadence_nand_wait_for_value(cadence, CTRL_STATUS, + TIMEOUT_US, + CTRL_STATUS_CTRL_BUSY, true)) + return -ETIMEDOUT; + + reg = readl_relaxed(cadence->reg + COMMON_SET); + if (!bit_bus16) + reg &= ~COMMON_SET_DEVICE_16BIT; + else + reg |= COMMON_SET_DEVICE_16BIT; + writel_relaxed(reg, cadence->reg + COMMON_SET); + + return 0; +} + +static void +cadence_nand_clear_interrupt(struct cadence_nand_info *cadence, + struct cadence_nand_irq_status *irq_status) +{ + writel_relaxed(irq_status->status, cadence->reg + INTR_STATUS); + writel_relaxed(irq_status->trd_status, + cadence->reg + TRD_COMP_INT_STATUS); + writel_relaxed(irq_status->trd_error, + cadence->reg + TRD_ERR_INT_STATUS); +} + +static void +cadence_nand_read_int_status(struct cadence_nand_info *cadence, + struct cadence_nand_irq_status *irq_status) +{ + irq_status->status = readl_relaxed(cadence->reg + INTR_STATUS); + irq_status->trd_status = readl_relaxed(cadence->reg + + TRD_COMP_INT_STATUS); + irq_status->trd_error = readl_relaxed(cadence->reg + + TRD_ERR_INT_STATUS); +} + +static u32 irq_detected(struct cadence_nand_info *cadence, + struct cadence_nand_irq_status *irq_status) +{ + cadence_nand_read_int_status(cadence, irq_status); + + return irq_status->status || irq_status->trd_status || + irq_status->trd_error; +} + +static void cadence_nand_reset_irq(struct cadence_nand_info *cadence) +{ + memset(&cadence->irq_status, 0, sizeof(cadence->irq_status)); + memset(&cadence->irq_mask, 0, sizeof(cadence->irq_mask)); +} + +/* + * This is the interrupt service routine. It handles all interrupts + * sent to this device. + */ +static irqreturn_t cadence_nand_isr(struct cadence_nand_info *cadence) +{ + struct cadence_nand_irq_status irq_status; + irqreturn_t result = IRQ_NONE; + + if (irq_detected(cadence, &irq_status)) { + /* Handle interrupt. */ + /* First acknowledge it. */ + cadence_nand_clear_interrupt(cadence, &irq_status); + /* Status in the device context for someone to read. */ + cadence->irq_status.status |= irq_status.status; + cadence->irq_status.trd_status |= irq_status.trd_status; + cadence->irq_status.trd_error |= irq_status.trd_error; + /* Tell the OS that we've handled this. */ + result = IRQ_HANDLED; + } + return result; +} + +static void cadence_nand_set_irq_mask(struct cadence_nand_info *cadence, + struct cadence_nand_irq_status *irq_mask) +{ + writel_relaxed(INTR_ENABLE_INTR_EN | irq_mask->status, + cadence->reg + INTR_ENABLE); + + writel_relaxed(irq_mask->trd_error, + cadence->reg + TRD_ERR_INT_STATUS_EN); +} + +static void +cadence_nand_wait_for_irq(struct cadence_nand_info *cadence, + struct cadence_nand_irq_status *irq_mask, + struct cadence_nand_irq_status *irq_status) +{ + irqreturn_t result = IRQ_NONE; + u32 start = get_timer(0); + + while (get_timer(start) < TIMEOUT_US) { + result = cadence_nand_isr(cadence); + + if (result == IRQ_HANDLED) { + *irq_status = cadence->irq_status; + break; + } + udelay(1); + } + + if (!result) { + /* Timeout error. */ + dev_err(cadence->dev, "timeout occurred:\n"); + dev_err(cadence->dev, "\tstatus = 0x%x, mask = 0x%x\n", + irq_status->status, irq_mask->status); + dev_err(cadence->dev, + "\ttrd_status = 0x%x, trd_status mask = 0x%x\n", + irq_status->trd_status, irq_mask->trd_status); + dev_err(cadence->dev, + "\t trd_error = 0x%x, trd_error mask = 0x%x\n", + irq_status->trd_error, irq_mask->trd_error); + } +} + +/* Execute generic command on NAND controller. */ +static int cadence_nand_generic_cmd_send(struct cadence_nand_info *cadence, + u8 chip_nr, + u64 mini_ctrl_cmd) +{ + u32 mini_ctrl_cmd_l, mini_ctrl_cmd_h, reg; + + mini_ctrl_cmd |= FIELD_PREP(GCMD_LAY_CS, chip_nr); + mini_ctrl_cmd_l = mini_ctrl_cmd & 0xFFFFFFFF; + mini_ctrl_cmd_h = mini_ctrl_cmd >> 32; + + if (cadence_nand_wait_for_value(cadence, CTRL_STATUS, + TIMEOUT_US, + CTRL_STATUS_CTRL_BUSY, true)) + return -ETIMEDOUT; + + cadence_nand_reset_irq(cadence); + + writel_relaxed(mini_ctrl_cmd_l, cadence->reg + CMD_REG2); + writel_relaxed(mini_ctrl_cmd_h, cadence->reg + CMD_REG3); + + /* Select generic command. */ + reg = FIELD_PREP(CMD_REG0_CT, CMD_REG0_CT_GEN); + /* Thread number. */ + reg |= FIELD_PREP(CMD_REG0_TN, 0); + + /* Issue command. */ + writel_relaxed(reg, cadence->reg + CMD_REG0); + + return 0; +} + +/* Wait for data on slave DMA interface. */ +static int cadence_nand_wait_on_sdma(struct cadence_nand_info *cadence, u8 *out_sdma_trd, + u32 *out_sdma_size) +{ + struct cadence_nand_irq_status irq_mask, irq_status; + + irq_mask.trd_status = 0; + irq_mask.trd_error = 0; + irq_mask.status = INTR_STATUS_SDMA_TRIGG + | INTR_STATUS_SDMA_ERR + | INTR_STATUS_UNSUPP_CMD; + + cadence_nand_set_irq_mask(cadence, &irq_mask); + cadence_nand_wait_for_irq(cadence, &irq_mask, &irq_status); + if (irq_status.status == 0) { + dev_err(cadence->dev, "Timeout while waiting for SDMA\n"); + return -ETIMEDOUT; + } + + if (irq_status.status & INTR_STATUS_SDMA_TRIGG) { + *out_sdma_size = readl_relaxed(cadence->reg + SDMA_SIZE); + *out_sdma_trd = readl_relaxed(cadence->reg + SDMA_TRD_NUM); + *out_sdma_trd = + FIELD_GET(SDMA_TRD_NUM_SDMA_TRD, *out_sdma_trd); + } else { + dev_err(cadence->dev, "SDMA error - irq_status %x\n", + irq_status.status); + return -EIO; + } + + return 0; +} + +static void cadence_nand_get_caps(struct cadence_nand_info *cadence) +{ + u32 reg; + + reg = readl_relaxed(cadence->reg + CTRL_FEATURES); + + cadence->caps2.max_banks = 1 << FIELD_GET(CTRL_FEATURES_N_BANKS, reg); + + if (FIELD_GET(CTRL_FEATURES_DMA_DWITH64, reg)) + cadence->caps2.data_dma_width = 8; + else + cadence->caps2.data_dma_width = 4; + + if (reg & CTRL_FEATURES_CONTROL_DATA) + cadence->caps2.data_control_supp = true; + + if (reg & (CTRL_FEATURES_NVDDR_2_3 + | CTRL_FEATURES_NVDDR)) + cadence->caps2.is_phy_type_dll = true; +} + +/* Prepare CDMA descriptor. */ +static void +cadence_nand_cdma_desc_prepare(struct cadence_nand_info *cadence, + char nf_mem, u32 flash_ptr, dma_addr_t mem_ptr, + dma_addr_t ctrl_data_ptr, u16 ctype) +{ + struct cadence_nand_cdma_desc *cdma_desc = cadence->cdma_desc; + + memset(cdma_desc, 0, sizeof(struct cadence_nand_cdma_desc)); + + /* Set fields for one descriptor. */ + cdma_desc->flash_pointer = flash_ptr; + if (cadence->ctrl_rev >= 13) + cdma_desc->bank = nf_mem; + else + cdma_desc->flash_pointer |= (nf_mem << CDMA_CFPTR_MEM_SHIFT); + + cdma_desc->command_flags |= CDMA_CF_DMA_MASTER; + cdma_desc->command_flags |= CDMA_CF_INT; + + cdma_desc->memory_pointer = mem_ptr; + cdma_desc->status = 0; + cdma_desc->sync_flag_pointer = 0; + cdma_desc->sync_arguments = 0; + + cdma_desc->command_type = ctype; + cdma_desc->ctrl_data_ptr = ctrl_data_ptr; +} + +static u8 cadence_nand_check_desc_error(struct cadence_nand_info *cadence, + u32 desc_status) +{ + if (desc_status & CDMA_CS_ERP) + return STAT_ERASED; + + if (desc_status & CDMA_CS_UNCE) + return STAT_ECC_UNCORR; + + if (desc_status & CDMA_CS_ERR) { + dev_err(cadence->dev, ":CDMA desc error flag detected.\n"); + return STAT_FAIL; + } + + if (FIELD_GET(CDMA_CS_MAXERR, desc_status)) + return STAT_ECC_CORR; + + return STAT_FAIL; +} + +static int cadence_nand_cdma_finish(struct cadence_nand_info *cadence) +{ + struct cadence_nand_cdma_desc *desc_ptr = cadence->cdma_desc; + u8 status = STAT_BUSY; + + if (desc_ptr->status & CDMA_CS_FAIL) { + status = cadence_nand_check_desc_error(cadence, + desc_ptr->status); + dev_err(cadence->dev, ":CDMA error %x\n", desc_ptr->status); + } else if (desc_ptr->status & CDMA_CS_COMP) { + /* Descriptor finished with no errors. */ + if (desc_ptr->command_flags & CDMA_CF_CONT) { + dev_info(cadence->dev, "DMA unsupported flag is set"); + status = STAT_UNKNOWN; + } else { + /* Last descriptor. */ + status = STAT_OK; + } + } + + return status; +} + +static int cadence_nand_cdma_send(struct cadence_nand_info *cadence, + u8 thread) +{ + u32 reg; + int status; + + /* Wait for thread ready. */ + status = cadence_nand_wait_for_value(cadence, TRD_STATUS, + TIMEOUT_US, + BIT(thread), true); + if (status) + return status; + + cadence_nand_reset_irq(cadence); + + writel_relaxed((u32)cadence->dma_cdma_desc, + cadence->reg + CMD_REG2); + writel_relaxed(0, cadence->reg + CMD_REG3); + + /* Select CDMA mode. */ + reg = FIELD_PREP(CMD_REG0_CT, CMD_REG0_CT_CDMA); + /* Thread number. */ + reg |= FIELD_PREP(CMD_REG0_TN, thread); + /* Issue command. */ + writel_relaxed(reg, cadence->reg + CMD_REG0); + + return 0; +} + +/* Send SDMA command and wait for finish. */ +static u32 +cadence_nand_cdma_send_and_wait(struct cadence_nand_info *cadence, + u8 thread) +{ + struct cadence_nand_irq_status irq_mask, irq_status = {0}; + int status; + + irq_mask.trd_status = BIT(thread); + irq_mask.trd_error = BIT(thread); + irq_mask.status = INTR_STATUS_CDMA_TERR; + + cadence_nand_set_irq_mask(cadence, &irq_mask); + + status = cadence_nand_cdma_send(cadence, thread); + if (status) + return status; + + cadence_nand_wait_for_irq(cadence, &irq_mask, &irq_status); + + if (irq_status.status == 0 && irq_status.trd_status == 0 && + irq_status.trd_error == 0) { + dev_err(cadence->dev, "CDMA command timeout\n"); + return -ETIMEDOUT; + } + if (irq_status.status & irq_mask.status) { + dev_err(cadence->dev, "CDMA command failed\n"); + return -EIO; + } + + return 0; +} + +/* + * ECC size depends on configured ECC strength and on maximum supported + * ECC step size. + */ +static int cadence_nand_calc_ecc_bytes(int max_step_size, int strength) +{ + int nbytes = DIV_ROUND_UP(fls(8 * max_step_size) * strength, 8); + + return ALIGN(nbytes, 2); +} + +#define CADENCE_NAND_CALC_ECC_BYTES(max_step_size) \ + static int \ + cadence_nand_calc_ecc_bytes_##max_step_size(int step_size, \ + int strength)\ + {\ + return cadence_nand_calc_ecc_bytes(max_step_size, strength);\ + } + +CADENCE_NAND_CALC_ECC_BYTES(256) +CADENCE_NAND_CALC_ECC_BYTES(512) +CADENCE_NAND_CALC_ECC_BYTES(1024) +CADENCE_NAND_CALC_ECC_BYTES(2048) +CADENCE_NAND_CALC_ECC_BYTES(4096) + +/* Function reads BCH capabilities. */ +static int cadence_nand_read_bch_caps(struct cadence_nand_info *cadence) +{ + struct nand_ecc_caps *ecc_caps = &cadence->ecc_caps; + int max_step_size = 0, nstrengths, i; + u32 reg; + + reg = readl_relaxed(cadence->reg + BCH_CFG_3); + cadence->bch_metadata_size = FIELD_GET(BCH_CFG_3_METADATA_SIZE, reg); + if (cadence->bch_metadata_size < 4) { + dev_err(cadence->dev, + "Driver needs at least 4 bytes of BCH meta data\n"); + return -EIO; + } + + reg = readl_relaxed(cadence->reg + BCH_CFG_0); + cadence->ecc_strengths[0] = FIELD_GET(BCH_CFG_0_CORR_CAP_0, reg); + cadence->ecc_strengths[1] = FIELD_GET(BCH_CFG_0_CORR_CAP_1, reg); + cadence->ecc_strengths[2] = FIELD_GET(BCH_CFG_0_CORR_CAP_2, reg); + cadence->ecc_strengths[3] = FIELD_GET(BCH_CFG_0_CORR_CAP_3, reg); + + reg = readl_relaxed(cadence->reg + BCH_CFG_1); + cadence->ecc_strengths[4] = FIELD_GET(BCH_CFG_1_CORR_CAP_4, reg); + cadence->ecc_strengths[5] = FIELD_GET(BCH_CFG_1_CORR_CAP_5, reg); + cadence->ecc_strengths[6] = FIELD_GET(BCH_CFG_1_CORR_CAP_6, reg); + cadence->ecc_strengths[7] = FIELD_GET(BCH_CFG_1_CORR_CAP_7, reg); + + reg = readl_relaxed(cadence->reg + BCH_CFG_2); + cadence->ecc_stepinfos[0].stepsize = + FIELD_GET(BCH_CFG_2_SECT_0, reg); + + cadence->ecc_stepinfos[1].stepsize = + FIELD_GET(BCH_CFG_2_SECT_1, reg); + + nstrengths = 0; + for (i = 0; i < BCH_MAX_NUM_CORR_CAPS; i++) { + if (cadence->ecc_strengths[i] != 0) + nstrengths++; + } + + ecc_caps->nstepinfos = 0; + for (i = 0; i < BCH_MAX_NUM_SECTOR_SIZES; i++) { + /* ECC strengths are common for all step infos. */ + cadence->ecc_stepinfos[i].nstrengths = nstrengths; + cadence->ecc_stepinfos[i].strengths = + cadence->ecc_strengths; + + if (cadence->ecc_stepinfos[i].stepsize != 0) + ecc_caps->nstepinfos++; + + if (cadence->ecc_stepinfos[i].stepsize > max_step_size) + max_step_size = cadence->ecc_stepinfos[i].stepsize; + } + ecc_caps->stepinfos = &cadence->ecc_stepinfos[0]; + + switch (max_step_size) { + case 256: + ecc_caps->calc_ecc_bytes = &cadence_nand_calc_ecc_bytes_256; + break; + case 512: + ecc_caps->calc_ecc_bytes = &cadence_nand_calc_ecc_bytes_512; + break; + case 1024: + ecc_caps->calc_ecc_bytes = &cadence_nand_calc_ecc_bytes_1024; + break; + case 2048: + ecc_caps->calc_ecc_bytes = &cadence_nand_calc_ecc_bytes_2048; + break; + case 4096: + ecc_caps->calc_ecc_bytes = &cadence_nand_calc_ecc_bytes_4096; + break; + default: + dev_err(cadence->dev, + "Unsupported sector size(ecc step size) %d\n", + max_step_size); + return -EIO; + } + + return 0; +} + +/* Hardware initialization. */ +static int cadence_nand_hw_init(struct cadence_nand_info *cadence) +{ + int status; + u32 reg; + + status = cadence_nand_wait_for_value(cadence, CTRL_STATUS, + TIMEOUT_US, + CTRL_STATUS_INIT_COMP, false); + if (status) + return status; + + reg = readl_relaxed(cadence->reg + CTRL_VERSION); + cadence->ctrl_rev = FIELD_GET(CTRL_VERSION_REV, reg); + + dev_info(cadence->dev, + "%s: cadence nand controller version reg %x\n", + __func__, reg); + + /* Disable cache and multiplane. */ + writel_relaxed(0, cadence->reg + MULTIPLANE_CFG); + writel_relaxed(0, cadence->reg + CACHE_CFG); + + /* Clear all interrupts. */ + writel_relaxed(0xFFFFFFFF, cadence->reg + INTR_STATUS); + + cadence_nand_get_caps(cadence); + if (cadence_nand_read_bch_caps(cadence)) + return -EIO; + + /* + * Set IO width access to 8. + * It is because during SW device discovering width access + * is expected to be 8. + */ + status = cadence_nand_set_access_width16(cadence, false); + + return status; +} + +#define TT_MAIN_OOB_AREAS 2 +#define TT_RAW_PAGE 3 +#define TT_BBM 4 +#define TT_MAIN_OOB_AREA_EXT 5 + +/* Prepare size of data to transfer. */ +static void +cadence_nand_prepare_data_size(struct mtd_info *mtd, + int transfer_type) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct nand_chip *chip = mtd_to_nand(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(chip); + u32 sec_size = 0, offset = 0, sec_cnt = 1; + u32 last_sec_size = cdns_chip->sector_size; + u32 data_ctrl_size = 0; + u32 reg = 0; + + if (cadence->curr_trans_type == transfer_type) + return; + + switch (transfer_type) { + case TT_MAIN_OOB_AREA_EXT: + sec_cnt = cdns_chip->sector_count; + sec_size = cdns_chip->sector_size; + data_ctrl_size = cdns_chip->avail_oob_size; + break; + case TT_MAIN_OOB_AREAS: + sec_cnt = cdns_chip->sector_count; + last_sec_size = cdns_chip->sector_size + + cdns_chip->avail_oob_size; + sec_size = cdns_chip->sector_size; + break; + case TT_RAW_PAGE: + last_sec_size = mtd->writesize + mtd->oobsize; + break; + case TT_BBM: + offset = mtd->writesize + cdns_chip->bbm_offs; + last_sec_size = 8; + break; + } + + reg = 0; + reg |= FIELD_PREP(TRAN_CFG_0_OFFSET, offset); + reg |= FIELD_PREP(TRAN_CFG_0_SEC_CNT, sec_cnt); + writel_relaxed(reg, cadence->reg + TRAN_CFG_0); + + reg = 0; + reg |= FIELD_PREP(TRAN_CFG_1_LAST_SEC_SIZE, last_sec_size); + reg |= FIELD_PREP(TRAN_CFG_1_SECTOR_SIZE, sec_size); + writel_relaxed(reg, cadence->reg + TRAN_CFG_1); + + if (cadence->caps2.data_control_supp) { + reg = readl_relaxed(cadence->reg + CONTROL_DATA_CTRL); + reg &= ~CONTROL_DATA_CTRL_SIZE; + reg |= FIELD_PREP(CONTROL_DATA_CTRL_SIZE, data_ctrl_size); + writel_relaxed(reg, cadence->reg + CONTROL_DATA_CTRL); + } + + cadence->curr_trans_type = transfer_type; +} + +static int +cadence_nand_cdma_transfer(struct cadence_nand_info *cadence, u8 chip_nr, + int page, void *buf, void *ctrl_dat, u32 buf_size, + u32 ctrl_dat_size, enum dma_data_direction dir, + bool with_ecc) +{ + dma_addr_t dma_buf, dma_ctrl_dat = 0; + u8 thread_nr = chip_nr; + int status; + u16 ctype; + + if (dir == DMA_FROM_DEVICE) + ctype = CDMA_CT_RD; + else + ctype = CDMA_CT_WR; + + cadence_nand_set_ecc_enable(cadence, with_ecc); + + dma_buf = dma_map_single(buf, buf_size, dir); + if (dma_mapping_error(cadence->dev, dma_buf)) { + dev_err(cadence->dev, "Failed to map DMA buffer\n"); + return -EIO; + } + + if (ctrl_dat && ctrl_dat_size) { + dma_ctrl_dat = dma_map_single(ctrl_dat, + ctrl_dat_size, dir); + if (dma_mapping_error(cadence->dev, dma_ctrl_dat)) { + dma_unmap_single(dma_buf, + buf_size, dir); + dev_err(cadence->dev, "Failed to map DMA buffer\n"); + return -EIO; + } + } + + cadence_nand_cdma_desc_prepare(cadence, chip_nr, page, + dma_buf, dma_ctrl_dat, ctype); + + status = cadence_nand_cdma_send_and_wait(cadence, thread_nr); + + dma_unmap_single(dma_buf, + buf_size, dir); + + if (ctrl_dat && ctrl_dat_size) + dma_unmap_single(dma_ctrl_dat, + ctrl_dat_size, dir); + if (status) + return status; + + return cadence_nand_cdma_finish(cadence); +} + +static void cadence_nand_set_timings(struct cadence_nand_info *cadence, + struct cadence_nand_timings *t) +{ + writel_relaxed(t->async_toggle_timings, + cadence->reg + ASYNC_TOGGLE_TIMINGS); + writel_relaxed(t->timings0, cadence->reg + TIMINGS0); + writel_relaxed(t->timings1, cadence->reg + TIMINGS1); + writel_relaxed(t->timings2, cadence->reg + TIMINGS2); + + if (cadence->caps2.is_phy_type_dll) + writel_relaxed(t->dll_phy_ctrl, cadence->reg + DLL_PHY_CTRL); + + writel_relaxed(t->phy_ctrl, cadence->reg + PHY_CTRL); + + if (cadence->caps2.is_phy_type_dll) { + writel_relaxed(0, cadence->reg + PHY_TSEL); + writel_relaxed(2, cadence->reg + PHY_DQ_TIMING); + writel_relaxed(t->phy_dqs_timing, + cadence->reg + PHY_DQS_TIMING); + writel_relaxed(t->phy_gate_lpbk_ctrl, + cadence->reg + PHY_GATE_LPBK_CTRL); + writel_relaxed(PHY_DLL_MASTER_CTRL_BYPASS_MODE, + cadence->reg + PHY_DLL_MASTER_CTRL); + writel_relaxed(0, cadence->reg + PHY_DLL_SLAVE_CTRL); + } +} + +static int cadence_nand_select_target(struct cadence_nand_info *cadence, struct nand_chip *chip) +{ + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(chip); + + if (cadence_nand_wait_for_value(cadence, CTRL_STATUS, + TIMEOUT_US, + CTRL_STATUS_CTRL_BUSY, true)) + return -ETIMEDOUT; + + cadence_nand_set_timings(cadence, &cdns_chip->timings); + + cadence_nand_set_ecc_strength(cadence, + cdns_chip->corr_str_idx); + + cadence_nand_set_erase_detection(cadence, true, + chip->ecc.strength); + + cadence->curr_trans_type = -1; + + return 0; +} + +static int cadence_nand_erase(struct mtd_info *mtd, int page) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct nand_chip *chip = mtd_to_nand(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(chip); + int status; + u8 thread_nr = cdns_chip->cs[cadence->assigned_cs]; + + cadence_nand_cdma_desc_prepare(cadence, + cdns_chip->cs[cadence->assigned_cs], + page, 0, 0, + CDMA_CT_ERASE); + status = cadence_nand_cdma_send_and_wait(cadence, thread_nr); + if (status) { + dev_err(cadence->dev, "erase operation failed\n"); + return -EIO; + } + + status = cadence_nand_cdma_finish(cadence); + if (status) + return status; + + return 0; +} + +static int cadence_ecc_setup(struct mtd_info *mtd, struct nand_chip *chip, int oobavail) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + int ret; + + /* + * If .size and .strength are already set (usually by DT), + * check if they are supported by this controller. + */ + if (chip->ecc.size && chip->ecc.strength) + return nand_check_ecc_caps(chip, &cadence->ecc_caps, oobavail); + + /* + * We want .size and .strength closest to the chip's requirement + * unless NAND_ECC_MAXIMIZE is requested. + */ + if (!(chip->ecc.options & NAND_ECC_MAXIMIZE)) { + ret = nand_match_ecc_req(chip, &cadence->ecc_caps, oobavail); + if (!ret) + return 0; + } + + /* Max ECC strength is the last thing we can do */ + return nand_maximize_ecc(chip, &cadence->ecc_caps, oobavail); +} + +static int cadence_nand_read_bbm(struct mtd_info *mtd, struct nand_chip *chip, int page, u8 *buf) +{ + int status; + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(chip); + + cadence_nand_prepare_data_size(mtd, TT_BBM); + + cadence_nand_set_skip_bytes_conf(cadence, 0, 0, 0); + + /* + * Read only bad block marker from offset + * defined by a memory manufacturer. + */ + status = cadence_nand_cdma_transfer(cadence, + cdns_chip->cs[cadence->assigned_cs], + page, cadence->buf, NULL, + mtd->oobsize, + 0, DMA_FROM_DEVICE, false); + if (status) { + dev_err(cadence->dev, "read BBM failed\n"); + return -EIO; + } + + memcpy(buf + cdns_chip->bbm_offs, cadence->buf, cdns_chip->bbm_len); + + return 0; +} + +static int cadence_nand_write_page(struct mtd_info *mtd, struct nand_chip *chip, + const u8 *buf, int oob_required, int page) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(chip); + int status; + u16 marker_val = 0xFFFF; + + cadence_nand_set_skip_bytes_conf(cadence, cdns_chip->bbm_len, + mtd->writesize + + cdns_chip->bbm_offs, + 1); + + if (oob_required) { + marker_val = *(u16 *)(chip->oob_poi + + cdns_chip->bbm_offs); + } else { + /* Set oob data to 0xFF. */ + memset(cadence->buf + mtd->writesize, 0xFF, + cdns_chip->avail_oob_size); + } + + cadence_nand_set_skip_marker_val(cadence, marker_val); + + cadence_nand_prepare_data_size(mtd, TT_MAIN_OOB_AREA_EXT); + + if (cadence_nand_dma_buf_ok(cadence, buf, mtd->writesize) && + cadence->caps2.data_control_supp) { + u8 *oob; + + if (oob_required) + oob = chip->oob_poi; + else + oob = cadence->buf + mtd->writesize; + + status = cadence_nand_cdma_transfer(cadence, + cdns_chip->cs[cadence->assigned_cs], + page, (void *)buf, oob, + mtd->writesize, + cdns_chip->avail_oob_size, + DMA_TO_DEVICE, true); + if (status) { + dev_err(cadence->dev, "write page failed\n"); + return -EIO; + } + + return 0; + } + + if (oob_required) { + /* Transfer the data to the oob area. */ + memcpy(cadence->buf + mtd->writesize, chip->oob_poi, + cdns_chip->avail_oob_size); + } + + memcpy(cadence->buf, buf, mtd->writesize); + + cadence_nand_prepare_data_size(mtd, TT_MAIN_OOB_AREAS); + + return cadence_nand_cdma_transfer(cadence, + cdns_chip->cs[cadence->assigned_cs], + page, cadence->buf, NULL, + mtd->writesize + + cdns_chip->avail_oob_size, + 0, DMA_TO_DEVICE, true); +} + +static int cadence_nand_write_oob(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + + memset(cadence->buf, 0xFF, mtd->writesize); + + return cadence_nand_write_page(mtd, chip, cadence->buf, 1, page); +} + +static int cadence_nand_write_page_raw(struct mtd_info *mtd, struct nand_chip *chip, + const u8 *buf, int oob_required, int page) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(chip); + int writesize = mtd->writesize; + int oobsize = mtd->oobsize; + int ecc_steps = chip->ecc.steps; + int ecc_size = chip->ecc.size; + int ecc_bytes = chip->ecc.bytes; + void *tmp_buf = cadence->buf; + int oob_skip = cdns_chip->bbm_len; + size_t size = writesize + oobsize; + int i, pos, len; + + /* + * Fill the buffer with 0xff first except the full page transfer. + * This simplifies the logic. + */ + if (!buf || !oob_required) + memset(tmp_buf, 0xff, size); + + cadence_nand_set_skip_bytes_conf(cadence, 0, 0, 0); + + /* Arrange the buffer for syndrome payload/ecc layout. */ + if (buf) { + for (i = 0; i < ecc_steps; i++) { + pos = i * (ecc_size + ecc_bytes); + len = ecc_size; + + if (pos >= writesize) + pos += oob_skip; + else if (pos + len > writesize) + len = writesize - pos; + + memcpy(tmp_buf + pos, buf, len); + buf += len; + if (len < ecc_size) { + len = ecc_size - len; + memcpy(tmp_buf + writesize + oob_skip, buf, + len); + buf += len; + } + } + } + + if (oob_required) { + const u8 *oob = chip->oob_poi; + u32 oob_data_offset = (cdns_chip->sector_count - 1) * + (cdns_chip->sector_size + chip->ecc.bytes) + + cdns_chip->sector_size + oob_skip; + + /* BBM at the beginning of the OOB area. */ + memcpy(tmp_buf + writesize, oob, oob_skip); + + /* OOB free. */ + memcpy(tmp_buf + oob_data_offset, oob, + cdns_chip->avail_oob_size); + oob += cdns_chip->avail_oob_size; + + /* OOB ECC. */ + for (i = 0; i < ecc_steps; i++) { + pos = ecc_size + i * (ecc_size + ecc_bytes); + if (i == (ecc_steps - 1)) + pos += cdns_chip->avail_oob_size; + + len = ecc_bytes; + + if (pos >= writesize) + pos += oob_skip; + else if (pos + len > writesize) + len = writesize - pos; + + memcpy(tmp_buf + pos, oob, len); + oob += len; + if (len < ecc_bytes) { + len = ecc_bytes - len; + memcpy(tmp_buf + writesize + oob_skip, oob, + len); + oob += len; + } + } + } + + cadence_nand_prepare_data_size(mtd, TT_RAW_PAGE); + + return cadence_nand_cdma_transfer(cadence, + cdns_chip->cs[cadence->assigned_cs], + page, cadence->buf, NULL, + mtd->writesize + + mtd->oobsize, + 0, DMA_TO_DEVICE, false); +} + +static int cadence_nand_write_oob_raw(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + return cadence_nand_write_page_raw(mtd, chip, NULL, true, page); +} + +static int cadence_nand_read_page(struct mtd_info *mtd, struct nand_chip *chip, + u8 *buf, int oob_required, int page) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(chip); + int status = 0; + int ecc_err_count = 0; + + cadence_nand_set_skip_bytes_conf(cadence, cdns_chip->bbm_len, + mtd->writesize + + cdns_chip->bbm_offs, 1); + + /* + * If data buffer can be accessed by DMA and data_control feature + * is supported then transfer data and oob directly. + */ + if (cadence_nand_dma_buf_ok(cadence, buf, mtd->writesize) && + cadence->caps2.data_control_supp) { + u8 *oob; + + if (oob_required) + oob = chip->oob_poi; + else + oob = cadence->buf + mtd->writesize; + + cadence_nand_prepare_data_size(mtd, TT_MAIN_OOB_AREA_EXT); + status = cadence_nand_cdma_transfer(cadence, + cdns_chip->cs[cadence->assigned_cs], + page, buf, oob, + mtd->writesize, + cdns_chip->avail_oob_size, + DMA_FROM_DEVICE, true); + /* Otherwise use bounce buffer. */ + } else { + cadence_nand_prepare_data_size(mtd, TT_MAIN_OOB_AREAS); + status = cadence_nand_cdma_transfer(cadence, + cdns_chip->cs[cadence->assigned_cs], + page, cadence->buf, + NULL, mtd->writesize + + cdns_chip->avail_oob_size, + 0, DMA_FROM_DEVICE, true); + + memcpy(buf, cadence->buf, mtd->writesize); + if (oob_required) + memcpy(chip->oob_poi, + cadence->buf + mtd->writesize, + mtd->oobsize); + } + + switch (status) { + case STAT_ECC_UNCORR: + mtd->ecc_stats.failed++; + ecc_err_count++; + break; + case STAT_ECC_CORR: + ecc_err_count = FIELD_GET(CDMA_CS_MAXERR, + cadence->cdma_desc->status); + mtd->ecc_stats.corrected += ecc_err_count; + break; + case STAT_ERASED: + case STAT_OK: + break; + default: + dev_err(cadence->dev, "read page failed\n"); + return -EIO; + } + + if (oob_required) + if (cadence_nand_read_bbm(mtd, chip, page, chip->oob_poi)) + return -EIO; + + return ecc_err_count; +} + +static int cadence_nand_read_oob(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + + return cadence_nand_read_page(mtd, chip, cadence->buf, 1, page); +} + +static int cadence_nand_read_page_raw(struct mtd_info *mtd, struct nand_chip *chip, + u8 *buf, int oob_required, int page) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(chip); + int oob_skip = cdns_chip->bbm_len; + int writesize = mtd->writesize; + int ecc_steps = chip->ecc.steps; + int ecc_size = chip->ecc.size; + int ecc_bytes = chip->ecc.bytes; + void *tmp_buf = cadence->buf; + int i, pos, len; + int status = 0; + + cadence_nand_set_skip_bytes_conf(cadence, 0, 0, 0); + + cadence_nand_prepare_data_size(mtd, TT_RAW_PAGE); + status = cadence_nand_cdma_transfer(cadence, + cdns_chip->cs[cadence->assigned_cs], + page, cadence->buf, NULL, + mtd->writesize + + mtd->oobsize, + 0, DMA_FROM_DEVICE, false); + + switch (status) { + case STAT_ERASED: + case STAT_OK: + break; + default: + dev_err(cadence->dev, "read raw page failed\n"); + return -EIO; + } + + /* Arrange the buffer for syndrome payload/ecc layout. */ + if (buf) { + for (i = 0; i < ecc_steps; i++) { + pos = i * (ecc_size + ecc_bytes); + len = ecc_size; + + if (pos >= writesize) + pos += oob_skip; + else if (pos + len > writesize) + len = writesize - pos; + + memcpy(buf, tmp_buf + pos, len); + buf += len; + if (len < ecc_size) { + len = ecc_size - len; + memcpy(buf, tmp_buf + writesize + oob_skip, + len); + buf += len; + } + } + } + + if (oob_required) { + u8 *oob = chip->oob_poi; + u32 oob_data_offset = (cdns_chip->sector_count - 1) * + (cdns_chip->sector_size + chip->ecc.bytes) + + cdns_chip->sector_size + oob_skip; + + /* OOB free. */ + memcpy(oob, tmp_buf + oob_data_offset, + cdns_chip->avail_oob_size); + + /* BBM at the beginning of the OOB area. */ + memcpy(oob, tmp_buf + writesize, oob_skip); + + oob += cdns_chip->avail_oob_size; + + /* OOB ECC */ + for (i = 0; i < ecc_steps; i++) { + pos = ecc_size + i * (ecc_size + ecc_bytes); + len = ecc_bytes; + + if (i == (ecc_steps - 1)) + pos += cdns_chip->avail_oob_size; + + if (pos >= writesize) + pos += oob_skip; + else if (pos + len > writesize) + len = writesize - pos; + + memcpy(oob, tmp_buf + pos, len); + oob += len; + if (len < ecc_bytes) { + len = ecc_bytes - len; + memcpy(oob, tmp_buf + writesize + oob_skip, + len); + oob += len; + } + } + } + return 0; +} + +static int cadence_nand_read_oob_raw(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + return cadence_nand_read_page_raw(mtd, chip, NULL, true, page); +} + +static void cadence_nand_read_buf(struct mtd_info *mtd, u8 *buf, int len) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + u8 thread_nr = 0; + u32 sdma_size; + int status; + int len_in_words = len >> 2; + + /* Wait until slave DMA interface is ready to data transfer. */ + status = cadence_nand_wait_on_sdma(cadence, &thread_nr, &sdma_size); + if (status) { + pr_err("Wait on sdma failed:%x\n", status); + hang(); + } + + if (!cadence->caps1->has_dma) { + readsq(cadence->io.virt, buf, len_in_words); + + if (sdma_size > len) { + memcpy(cadence->buf, buf + (len_in_words << 2), + len - (len_in_words << 2)); + readsl(cadence->io.virt, cadence->buf, + sdma_size / 4 - len_in_words); + } + } +} + +static void cadence_nand_write_buf(struct mtd_info *mtd, const u8 *buf, int len) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + u8 thread_nr = 0; + u32 sdma_size; + int status; + int len_in_words = len >> 2; + + /* Wait until slave DMA interface is ready to data transfer. */ + status = cadence_nand_wait_on_sdma(cadence, &thread_nr, &sdma_size); + if (status) { + pr_err("Wait on sdma failed:%x\n", status); + hang(); + } + + if (!cadence->caps1->has_dma) { + writesq(cadence->io.virt, buf, len_in_words); + + if (sdma_size > len) { + memcpy(cadence->buf, buf + (len_in_words << 2), + len - (len_in_words << 2)); + writesl(cadence->io.virt, cadence->buf, + sdma_size / 4 - len_in_words); + } + } +} + +static int cadence_nand_cmd_opcode(struct cadence_nand_info *cadence, unsigned int op_id) +{ + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(&cadence->selected_chip); + u64 mini_ctrl_cmd = 0; + int ret; + + mini_ctrl_cmd |= GCMD_LAY_TWB; + mini_ctrl_cmd |= FIELD_PREP(GCMD_LAY_INSTR, GCMD_LAY_INSTR_CMD); + mini_ctrl_cmd |= FIELD_PREP(GCMD_LAY_INPUT_CMD, op_id); + + ret = cadence_nand_generic_cmd_send(cadence, + cdns_chip->cs[cadence->assigned_cs], + mini_ctrl_cmd); + + if (ret) + dev_err(cadence->dev, "send cmd %x failed\n", + op_id); + + return ret; +} + +static int cadence_nand_cmd_address(struct cadence_nand_info *cadence, + unsigned int naddrs, const u8 *addrs) +{ + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(&cadence->selected_chip); + u64 address = 0; + u64 mini_ctrl_cmd = 0; + int ret; + int i; + + mini_ctrl_cmd |= GCMD_LAY_TWB; + + mini_ctrl_cmd |= FIELD_PREP(GCMD_LAY_INSTR, + GCMD_LAY_INSTR_ADDR); + + for (i = 0; i < naddrs; i++) + address |= (u64)addrs[i] << (8 * i); + + mini_ctrl_cmd |= FIELD_PREP(GCMD_LAY_INPUT_ADDR, + address); + mini_ctrl_cmd |= FIELD_PREP(GCMD_LAY_INPUT_ADDR_SIZE, + naddrs - 1); + + ret = cadence_nand_generic_cmd_send(cadence, + cdns_chip->cs[cadence->assigned_cs], + mini_ctrl_cmd); + + if (ret) + pr_err("send address %llx failed\n", address); + + return ret; +} + +static int cadence_nand_cmd_data(struct cadence_nand_info *cadence, + unsigned int len, u8 mode) +{ + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(&cadence->selected_chip); + u64 mini_ctrl_cmd = 0; + int ret; + + mini_ctrl_cmd |= GCMD_LAY_TWB; + mini_ctrl_cmd |= FIELD_PREP(GCMD_LAY_INSTR, + GCMD_LAY_INSTR_DATA); + + if (mode) + mini_ctrl_cmd |= FIELD_PREP(GCMD_DIR, GCMD_DIR_WRITE); + + mini_ctrl_cmd |= FIELD_PREP(GCMD_SECT_CNT, 1); + mini_ctrl_cmd |= FIELD_PREP(GCMD_LAST_SIZE, len); + + ret = cadence_nand_generic_cmd_send(cadence, + cdns_chip->cs[cadence->assigned_cs], + mini_ctrl_cmd); + + if (ret) { + pr_err("send generic data cmd failed\n"); + return ret; + } + + return ret; +} + +static int cadence_nand_waitfunc(struct mtd_info *mtd, struct nand_chip *chip) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(&cadence->selected_chip); + int status; + + status = cadence_nand_wait_for_value(cadence, RBN_SETINGS, + TIMEOUT_US, + BIT(cdns_chip->cs[cadence->assigned_cs]), + false); + return status; +} + +static int cadence_nand_ooblayout_free(struct mtd_info *mtd, int section, + struct mtd_oob_region *oobregion) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(chip); + + if (section) + return -ERANGE; + + oobregion->offset = cdns_chip->bbm_len; + oobregion->length = cdns_chip->avail_oob_size + - cdns_chip->bbm_len; + + return 0; +} + +static int cadence_nand_ooblayout_ecc(struct mtd_info *mtd, int section, + struct mtd_oob_region *oobregion) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(chip); + + if (section) + return -ERANGE; + + oobregion->offset = cdns_chip->avail_oob_size; + oobregion->length = chip->ecc.total; + + return 0; +} + +static const struct mtd_ooblayout_ops cadence_nand_ooblayout_ops = { + .rfree = cadence_nand_ooblayout_free, + .ecc = cadence_nand_ooblayout_ecc, +}; + +static int calc_cycl(u32 timing, u32 clock) +{ + if (timing == 0 || clock == 0) + return 0; + + if ((timing % clock) > 0) + return timing / clock; + else + return timing / clock - 1; +} + +/* Calculate max data valid window. */ +static inline u32 calc_tdvw_max(u32 trp_cnt, u32 clk_period, u32 trhoh_min, + u32 board_delay_skew_min, u32 ext_mode) +{ + if (ext_mode == 0) + clk_period /= 2; + + return (trp_cnt + 1) * clk_period + trhoh_min + + board_delay_skew_min; +} + +/* Calculate data valid window. */ +static inline u32 calc_tdvw(u32 trp_cnt, u32 clk_period, u32 trhoh_min, + u32 trea_max, u32 ext_mode) +{ + if (ext_mode == 0) + clk_period /= 2; + + return (trp_cnt + 1) * clk_period + trhoh_min - trea_max; +} + +static inline int of_get_child_count(const ofnode node) +{ + return fdtdec_get_child_count(gd->fdt_blob, ofnode_to_offset(node)); +} + +static int cadence_setup_data_interface(struct mtd_info *mtd, int chipnr, + const struct nand_data_interface *conf) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(mtd_to_nand(mtd)); + const struct nand_sdr_timings *sdr; + struct cadence_nand_timings *t = &cdns_chip->timings; + u32 reg; + u32 board_delay = cadence->board_delay; + u32 clk_period = DIV_ROUND_DOWN_ULL(1000000000000ULL, + cadence->nf_clk_rate); + u32 tceh_cnt, tcs_cnt, tadl_cnt, tccs_cnt; + u32 tfeat_cnt, trhz_cnt, tvdly_cnt; + u32 trhw_cnt, twb_cnt, twh_cnt = 0, twhr_cnt; + u32 twp_cnt = 0, trp_cnt = 0, trh_cnt = 0; + u32 if_skew = cadence->caps1->if_skew; + u32 board_delay_skew_min = board_delay - if_skew; + u32 board_delay_skew_max = board_delay + if_skew; + u32 dqs_sampl_res, phony_dqs_mod; + u32 tdvw, tdvw_min, tdvw_max; + u32 ext_rd_mode, ext_wr_mode; + u32 dll_phy_dqs_timing = 0, phony_dqs_timing = 0, rd_del_sel = 0; + u32 sampling_point; + + sdr = nand_get_sdr_timings(conf); + if (IS_ERR(sdr)) + return PTR_ERR(sdr); + + memset(t, 0, sizeof(*t)); + /* Sampling point calculation. */ + if (cadence->caps2.is_phy_type_dll) + phony_dqs_mod = 2; + else + phony_dqs_mod = 1; + + dqs_sampl_res = clk_period / phony_dqs_mod; + + tdvw_min = sdr->tREA_max + board_delay_skew_max; + /* + * The idea of those calculation is to get the optimum value + * for tRP and tRH timings. If it is NOT possible to sample data + * with optimal tRP/tRH settings, the parameters will be extended. + * If clk_period is 50ns (the lowest value) this condition is met + * for SDR timing modes 1, 2, 3, 4 and 5. + * If clk_period is 20ns the condition is met only for SDR timing + * mode 5. + */ + if (sdr->tRC_min <= clk_period && + sdr->tRP_min <= (clk_period / 2) && + sdr->tREH_min <= (clk_period / 2)) { + /* Performance mode. */ + ext_rd_mode = 0; + tdvw = calc_tdvw(trp_cnt, clk_period, sdr->tRHOH_min, + sdr->tREA_max, ext_rd_mode); + tdvw_max = calc_tdvw_max(trp_cnt, clk_period, sdr->tRHOH_min, + board_delay_skew_min, + ext_rd_mode); + /* + * Check if data valid window and sampling point can be found + * and is not on the edge (ie. we have hold margin). + * If not extend the tRP timings. + */ + if (tdvw > 0) { + if (tdvw_max <= tdvw_min || + (tdvw_max % dqs_sampl_res) == 0) { + /* + * No valid sampling point so the RE pulse need + * to be widen widening by half clock cycle. + */ + ext_rd_mode = 1; + } + } else { + /* + * There is no valid window + * to be able to sample data the tRP need to be widen. + * Very safe calculations are performed here. + */ + trp_cnt = (sdr->tREA_max + board_delay_skew_max + + dqs_sampl_res) / clk_period; + ext_rd_mode = 1; + } + + } else { + /* Extended read mode. */ + u32 trh; + + ext_rd_mode = 1; + trp_cnt = calc_cycl(sdr->tRP_min, clk_period); + trh = sdr->tRC_min - ((trp_cnt + 1) * clk_period); + if (sdr->tREH_min >= trh) + trh_cnt = calc_cycl(sdr->tREH_min, clk_period); + else + trh_cnt = calc_cycl(trh, clk_period); + + tdvw = calc_tdvw(trp_cnt, clk_period, sdr->tRHOH_min, + sdr->tREA_max, ext_rd_mode); + /* + * Check if data valid window and sampling point can be found + * or if it is at the edge check if previous is valid + * - if not extend the tRP timings. + */ + if (tdvw > 0) { + tdvw_max = calc_tdvw_max(trp_cnt, clk_period, + sdr->tRHOH_min, + board_delay_skew_min, + ext_rd_mode); + + if ((((tdvw_max / dqs_sampl_res) + * dqs_sampl_res) <= tdvw_min) || + (((tdvw_max % dqs_sampl_res) == 0) && + (((tdvw_max / dqs_sampl_res - 1) + * dqs_sampl_res) <= tdvw_min))) { + /* + * Data valid window width is lower than + * sampling resolution and do not hit any + * sampling point to be sure the sampling point + * will be found the RE low pulse width will be + * extended by one clock cycle. + */ + trp_cnt = trp_cnt + 1; + } + } else { + /* + * There is no valid window to be able to sample data. + * The tRP need to be widen. + * Very safe calculations are performed here. + */ + trp_cnt = (sdr->tREA_max + board_delay_skew_max + + dqs_sampl_res) / clk_period; + } + } + + tdvw_max = calc_tdvw_max(trp_cnt, clk_period, + sdr->tRHOH_min, + board_delay_skew_min, ext_rd_mode); + + if (sdr->tWC_min <= clk_period && + (sdr->tWP_min + if_skew) <= (clk_period / 2) && + (sdr->tWH_min + if_skew) <= (clk_period / 2)) { + ext_wr_mode = 0; + } else { + u32 twh; + + ext_wr_mode = 1; + twp_cnt = calc_cycl(sdr->tWP_min + if_skew, clk_period); + if ((twp_cnt + 1) * clk_period < (sdr->tALS_min + if_skew)) + twp_cnt = calc_cycl(sdr->tALS_min + if_skew, + clk_period); + + twh = (sdr->tWC_min - (twp_cnt + 1) * clk_period); + if (sdr->tWH_min >= twh) + twh = sdr->tWH_min; + + twh_cnt = calc_cycl(twh + if_skew, clk_period); + } + + reg = FIELD_PREP(ASYNC_TOGGLE_TIMINGS_TRH, trh_cnt); + reg |= FIELD_PREP(ASYNC_TOGGLE_TIMINGS_TRP, trp_cnt); + reg |= FIELD_PREP(ASYNC_TOGGLE_TIMINGS_TWH, twh_cnt); + reg |= FIELD_PREP(ASYNC_TOGGLE_TIMINGS_TWP, twp_cnt); + t->async_toggle_timings = reg; + dev_dbg(cadence->dev, "ASYNC_TOGGLE_TIMINGS_SDR\t%x\n", reg); + + tadl_cnt = calc_cycl((sdr->tADL_min + if_skew), clk_period); + tccs_cnt = calc_cycl((sdr->tCCS_min + if_skew), clk_period); + twhr_cnt = calc_cycl((sdr->tWHR_min + if_skew), clk_period); + trhw_cnt = calc_cycl((sdr->tRHW_min + if_skew), clk_period); + reg = FIELD_PREP(TIMINGS0_TADL, tadl_cnt); + + /* + * If timing exceeds delay field in timing register + * then use maximum value. + */ + if (FIELD_FIT(TIMINGS0_TCCS, tccs_cnt)) + reg |= FIELD_PREP(TIMINGS0_TCCS, tccs_cnt); + else + reg |= TIMINGS0_TCCS; + + reg |= FIELD_PREP(TIMINGS0_TWHR, twhr_cnt); + reg |= FIELD_PREP(TIMINGS0_TRHW, trhw_cnt); + t->timings0 = reg; + dev_dbg(cadence->dev, "TIMINGS0_SDR\t%x\n", reg); + + /* The following is related to single signal so skew is not needed. */ + trhz_cnt = calc_cycl(sdr->tRHZ_max, clk_period); + trhz_cnt = trhz_cnt + 1; + twb_cnt = calc_cycl((sdr->tWB_max + board_delay), clk_period); + /* + * Because of the two stage syncflop the value must be increased by 3 + * first value is related with sync, second value is related + * with output if delay. + */ + twb_cnt = twb_cnt + 3 + 5; + /* + * The following is related to the we edge of the random data input + * sequence so skew is not needed. + */ + tvdly_cnt = calc_cycl(500000 + if_skew, clk_period); + reg = FIELD_PREP(TIMINGS1_TRHZ, trhz_cnt); + reg |= FIELD_PREP(TIMINGS1_TWB, twb_cnt); + reg |= FIELD_PREP(TIMINGS1_TVDLY, tvdly_cnt); + t->timings1 = reg; + dev_dbg(cadence->dev, "TIMINGS1_SDR\t%x\n", reg); + + tfeat_cnt = calc_cycl(sdr->tFEAT_max, clk_period); + if (tfeat_cnt < twb_cnt) + tfeat_cnt = twb_cnt; + + tceh_cnt = calc_cycl(sdr->tCEH_min, clk_period); + tcs_cnt = calc_cycl((sdr->tCS_min + if_skew), clk_period); + + reg = FIELD_PREP(TIMINGS2_TFEAT, tfeat_cnt); + reg |= FIELD_PREP(TIMINGS2_CS_HOLD_TIME, tceh_cnt); + reg |= FIELD_PREP(TIMINGS2_CS_SETUP_TIME, tcs_cnt); + t->timings2 = reg; + dev_dbg(cadence->dev, "TIMINGS2_SDR\t%x\n", reg); + + if (cadence->caps2.is_phy_type_dll) { + reg = DLL_PHY_CTRL_DLL_RST_N; + if (ext_wr_mode) + reg |= DLL_PHY_CTRL_EXTENDED_WR_MODE; + if (ext_rd_mode) + reg |= DLL_PHY_CTRL_EXTENDED_RD_MODE; + + reg |= FIELD_PREP(DLL_PHY_CTRL_RS_HIGH_WAIT_CNT, 7); + reg |= FIELD_PREP(DLL_PHY_CTRL_RS_IDLE_CNT, 7); + t->dll_phy_ctrl = reg; + dev_dbg(cadence->dev, "DLL_PHY_CTRL_SDR\t%x\n", reg); + } + + /* Sampling point calculation. */ + if ((tdvw_max % dqs_sampl_res) > 0) + sampling_point = tdvw_max / dqs_sampl_res; + else + sampling_point = (tdvw_max / dqs_sampl_res - 1); + + if (sampling_point * dqs_sampl_res > tdvw_min) { + dll_phy_dqs_timing = + FIELD_PREP(PHY_DQS_TIMING_DQS_SEL_OE_END, 4); + dll_phy_dqs_timing |= PHY_DQS_TIMING_USE_PHONY_DQS; + phony_dqs_timing = sampling_point / phony_dqs_mod; + + if ((sampling_point % 2) > 0) { + dll_phy_dqs_timing |= PHY_DQS_TIMING_PHONY_DQS_SEL; + if ((tdvw_max % dqs_sampl_res) == 0) + /* + * Calculation for sampling point at the edge + * of data and being odd number. + */ + phony_dqs_timing = (tdvw_max / dqs_sampl_res) + / phony_dqs_mod - 1; + + if (!cadence->caps2.is_phy_type_dll) + phony_dqs_timing--; + + } else { + phony_dqs_timing--; + } + rd_del_sel = phony_dqs_timing + 3; + } else { + dev_warn(cadence->dev, + "ERROR : cannot find valid sampling point\n"); + } + + reg = FIELD_PREP(PHY_CTRL_PHONY_DQS, phony_dqs_timing); + if (cadence->caps2.is_phy_type_dll) + reg |= PHY_CTRL_SDR_DQS; + t->phy_ctrl = reg; + dev_dbg(cadence->dev, "PHY_CTRL_REG_SDR\t%x\n", reg); + + if (cadence->caps2.is_phy_type_dll) { + dev_dbg(cadence->dev, "PHY_TSEL_REG_SDR\t%x\n", 0); + dev_dbg(cadence->dev, "PHY_DQ_TIMING_REG_SDR\t%x\n", 2); + dev_dbg(cadence->dev, "PHY_DQS_TIMING_REG_SDR\t%x\n", + dll_phy_dqs_timing); + t->phy_dqs_timing = dll_phy_dqs_timing; + + reg = FIELD_PREP(PHY_GATE_LPBK_CTRL_RDS, rd_del_sel); + dev_dbg(cadence->dev, "PHY_GATE_LPBK_CTRL_REG_SDR\t%x\n", + reg); + t->phy_gate_lpbk_ctrl = reg; + + dev_dbg(cadence->dev, "PHY_DLL_MASTER_CTRL_REG_SDR\t%lx\n", + PHY_DLL_MASTER_CTRL_BYPASS_MODE); + dev_dbg(cadence->dev, "PHY_DLL_SLAVE_CTRL_REG_SDR\t%x\n", 0); + } + return 0; +} + +static int cadence_nand_attach_chip(struct mtd_info *mtd, struct nand_chip *chip) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct cdns_nand_chip *cdns_chip = to_cdns_nand_chip(chip); + static struct nand_ecclayout nand_oob; + u32 ecc_size; + int ret; + + if (chip->options & NAND_BUSWIDTH_16) { + ret = cadence_nand_set_access_width16(cadence, true); + if (ret) + return ret; + } + + chip->bbt_options |= NAND_BBT_USE_FLASH; + chip->bbt_options |= NAND_BBT_NO_OOB; + chip->ecc.mode = NAND_ECC_HW_SYNDROME; + + chip->options |= NAND_NO_SUBPAGE_WRITE; + + cdns_chip->bbm_offs = chip->badblockpos; + cdns_chip->bbm_offs &= ~0x01; + /* this value should be even number */ + cdns_chip->bbm_len = 2; + + ret = cadence_ecc_setup(mtd, chip, mtd->oobsize - cdns_chip->bbm_len); + if (ret) { + dev_err(cadence->dev, "ECC configuration failed\n"); + return ret; + } + + dev_dbg(cadence->dev, + "chosen ECC settings: step=%d, strength=%d, bytes=%d\n", + chip->ecc.size, chip->ecc.strength, chip->ecc.bytes); + + /* Error correction configuration. */ + cdns_chip->sector_size = chip->ecc.size; + cdns_chip->sector_count = mtd->writesize / cdns_chip->sector_size; + ecc_size = cdns_chip->sector_count * chip->ecc.bytes; + + cdns_chip->avail_oob_size = mtd->oobsize - ecc_size; + + if (cdns_chip->avail_oob_size > cadence->bch_metadata_size) + cdns_chip->avail_oob_size = cadence->bch_metadata_size; + + if ((cdns_chip->avail_oob_size + cdns_chip->bbm_len + ecc_size) + > mtd->oobsize) + cdns_chip->avail_oob_size -= 4; + + ret = cadence_nand_get_ecc_strength_idx(cadence, chip->ecc.strength); + if (ret < 0) + return -EINVAL; + + cdns_chip->corr_str_idx = (u8)ret; + + if (cadence_nand_wait_for_value(cadence, CTRL_STATUS, + TIMEOUT_US, + CTRL_STATUS_CTRL_BUSY, true)) + return -ETIMEDOUT; + + cadence_nand_set_ecc_strength(cadence, + cdns_chip->corr_str_idx); + + cadence_nand_set_erase_detection(cadence, true, + chip->ecc.strength); + + dev_dbg(cadence->dev, + "chosen ECC settings: step=%d, strength=%d, bytes=%d\n", + chip->ecc.size, chip->ecc.strength, chip->ecc.bytes); + + /* Override the default read operations. */ + chip->ecc.options |= NAND_ECC_CUSTOM_PAGE_ACCESS; + chip->ecc.read_page = cadence_nand_read_page; + chip->ecc.read_page_raw = cadence_nand_read_page_raw; + chip->ecc.write_page = cadence_nand_write_page; + chip->ecc.write_page_raw = cadence_nand_write_page_raw; + chip->ecc.read_oob = cadence_nand_read_oob; + chip->ecc.write_oob = cadence_nand_write_oob; + chip->ecc.read_oob_raw = cadence_nand_read_oob_raw; + chip->ecc.write_oob_raw = cadence_nand_write_oob_raw; + chip->erase = cadence_nand_erase; + + if ((mtd->writesize + mtd->oobsize) > cadence->buf_size) + cadence->buf_size = mtd->writesize + mtd->oobsize; + + mtd_set_ooblayout(mtd, &cadence_nand_ooblayout_ops); + + nand_oob.eccbytes = cadence->selected_chip.ecc.bytes; + cadence->selected_chip.ecc.layout = &nand_oob; + + return 0; +} + +/* Dummy implementation: we don't support multiple chips */ +static void cadence_nand_select_chip(struct mtd_info *mtd, int chipnr) +{ + switch (chipnr) { + case -1: + case 0: + break; + + default: + WARN_ON(chipnr); + } +} + +static void cadence_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, + int offset_in_page, int page) +{ +} + +static int cadence_nand_dev_ready(struct mtd_info *mtd) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + + if (cadence_nand_wait_for_value(cadence, CTRL_STATUS, + TIMEOUT_US, + CTRL_STATUS_CTRL_BUSY, true)) + return -ETIMEDOUT; + + return 0; +} + +static u8 cadence_nand_read_byte(struct mtd_info *mtd) +{ + return 0; +} + +static void cadence_nand_write_byte(struct mtd_info *mtd, u8 byte) +{ + cadence_nand_write_buf(mtd, &byte, 1); +} + +static int cadence_nand_chip_init(struct cadence_nand_info *cadence, ofnode node) +{ + struct cdns_nand_chip *cdns_chip; + struct nand_chip *chip; + struct mtd_info *mtd; + int ret, i; + int nsels; + u32 cs; + + if (!ofnode_get_property(node, "reg", &nsels)) + return -ENODEV; + + nsels /= sizeof(u32); + if (nsels <= 0) { + dev_err(cadence->dev, "invalid reg property size %d\n", nsels); + return -EINVAL; + } + + cdns_chip = devm_kzalloc(cadence->dev, sizeof(*cdns_chip) + + (nsels * sizeof(u8)), GFP_KERNEL); + if (!cdns_chip) + return -ENODEV; + + cdns_chip->nsels = nsels; + for (i = 0; i < nsels; i++) { + /* Retrieve CS id. */ + ret = ofnode_read_u32_index(node, "reg", i, &cs); + if (ret) { + dev_err(cadence->dev, + "could not retrieve reg property: %d\n", + ret); + goto free_buf; + } + + if (cs >= cadence->caps2.max_banks) { + dev_err(cadence->dev, + "invalid reg value: %u (max CS = %d)\n", + cs, cadence->caps2.max_banks); + ret = -EINVAL; + goto free_buf; + } + + if (test_and_set_bit(cs, &cadence->assigned_cs)) { + dev_err(cadence->dev, + "CS %d already assigned\n", cs); + ret = -EINVAL; + goto free_buf; + } + + cdns_chip->cs[i] = cs; + } + + cadence->selected_chip = cdns_chip->chip; + chip = &cadence->selected_chip; + mtd = nand_to_mtd(chip); + nand_set_flash_node(chip, node); + chip->options |= NAND_BUSWIDTH_AUTO; + + chip->select_chip = cadence_nand_select_chip; + chip->cmdfunc = cadence_nand_cmdfunc; + chip->dev_ready = cadence_nand_dev_ready; + chip->read_byte = cadence_nand_read_byte; + chip->write_byte = cadence_nand_write_byte; + chip->waitfunc = cadence_nand_waitfunc; + chip->read_buf = cadence_nand_read_buf; + chip->write_buf = cadence_nand_write_buf; + chip->setup_data_interface = cadence_setup_data_interface; + + ret = nand_scan_ident(mtd, 1, NULL); + if (ret) { + dev_err(cadence->dev, "Chip identification failure\n"); + goto free_buf; + } + + ret = cadence_nand_attach_chip(mtd, chip); + if (ret) { + dev_err(cadence->dev, "Chip not able to attached\n"); + goto free_buf; + } + + ret = nand_scan_tail(mtd); + if (ret) { + dev_err(cadence->dev, "could not scan the nand chip\n"); + goto free_buf; + } + + ret = nand_register(0, mtd); + if (ret) { + dev_err(cadence->dev, "Failed to register MTD: %d\n", ret); + goto free_buf; + } + +free_buf: + devm_kfree(cadence->dev, cdns_chip); + return ret; +} + +static int cadence_nand_chips_init(struct cadence_nand_info *cadence) +{ + struct udevice *dev = cadence->dev; + ofnode node = dev_ofnode(dev); + ofnode nand_node; + int max_cs = cadence->caps2.max_banks; + int nchips, ret; + + nchips = of_get_child_count(node); + + if (nchips > max_cs) { + dev_err(cadence->dev, + "too many NAND chips: %d (max = %d CS)\n", + nchips, max_cs); + return -EINVAL; + } + + ofnode_for_each_subnode(nand_node, node) { + ret = cadence_nand_chip_init(cadence, nand_node); + if (ret) + return ret; + } + + return 0; +} + +static int cadence_nand_init(struct cadence_nand_info *cadence) +{ + int ret; + + cadence->cdma_desc = dma_alloc_coherent(sizeof(struct cadence_nand_cdma_desc), + (unsigned long *)&cadence->dma_cdma_desc); + if (!cadence->cdma_desc) + return -ENOMEM; + + cadence->buf_size = SZ_16K; + cadence->buf = kmalloc(cadence->buf_size, GFP_KERNEL); + if (!cadence->buf) { + ret = -ENOMEM; + goto free_buf_desc; + } + + //Hardware initialization + ret = cadence_nand_hw_init(cadence); + if (ret) + goto free_buf; + + cadence->curr_corr_str_idx = 0xFF; + + ret = cadence_nand_chips_init(cadence); + if (ret) { + dev_err(cadence->dev, "Failed to register MTD: %d\n", + ret); + goto free_buf; + } + + kfree(cadence->buf); + cadence->buf = kzalloc(cadence->buf_size, GFP_KERNEL); + if (!cadence->buf) { + ret = -ENOMEM; + goto free_buf_desc; + } + + return 0; + +free_buf: + kfree(cadence->buf); + +free_buf_desc: + dma_free_coherent(cadence->cdma_desc); + + return ret; +} + +static const struct cadence_nand_dt_devdata cadence_nand_default = { + .if_skew = 0, + .has_dma = 0, +}; + +static const struct udevice_id cadence_nand_dt_ids[] = { + { + .compatible = "cdns,nand", + .data = (unsigned long)&cadence_nand_default + }, {} +}; + +static int cadence_nand_dt_probe(struct udevice *dev) +{ + struct cadence_nand_info *cadence = dev_get_priv(dev); + const struct udevice_id *of_id; + const struct cadence_nand_dt_devdata *devdata; + struct resource res; + int ret; + u32 val; + + if (!dev) { + dev_warn(dev, "Device ptr null\n"); + return -EINVAL; + } + + of_id = &cadence_nand_dt_ids[0]; + devdata = (struct cadence_nand_dt_devdata *)of_id->data; + + cadence->caps1 = devdata; + cadence->dev = dev; + + ret = clk_get_by_index(dev, 0, &cadence->clk); + if (ret) + return ret; + + ret = clk_enable(&cadence->clk); + if (ret && ret != -ENOSYS && ret != -ENOMEM) { + clk_free(&cadence->clk); + dev_err(dev, "failed to enable clock\n"); + return ret; + } + cadence->nf_clk_rate = clk_get_rate(&cadence->clk); + + ret = reset_get_by_index(dev, 1, &cadence->softphy_reset); + if (ret) { + if (ret != -ENOMEM) + dev_warn(dev, "Can't get softphy_reset: %d\n", ret); + } else { + reset_deassert(&cadence->softphy_reset); + } + + ret = reset_get_by_index(dev, 0, &cadence->nand_reset); + if (ret) { + if (ret != -ENOMEM) + dev_warn(dev, "Can't get nand_reset: %d\n", ret); + } else { + reset_deassert(&cadence->nand_reset); + } + + ret = dev_read_resource_byname(dev, "reg", &res); + if (ret) + return ret; + cadence->reg = devm_ioremap(dev, res.start, resource_size(&res)); + + ret = dev_read_resource_byname(dev, "sdma", &res); + if (ret) + return ret; + cadence->io.dma = res.start; + cadence->io.virt = devm_ioremap(dev, res.start, resource_size(&res)); + + ret = ofnode_read_u32(dev_ofnode(dev->parent), + "cdns,board-delay-ps", &val); + if (ret) { + val = 4830; + dev_info(cadence->dev, + "missing cdns,board-delay-ps property, %d was set\n", + val); + } + cadence->board_delay = val; + + ret = cadence_nand_init(cadence); + if (ret) + return ret; + + return 0; +} + +U_BOOT_DRIVER(cadence_nand_dt) = { + .name = "cadence-nand-dt", + .id = UCLASS_MTD, + .of_match = cadence_nand_dt_ids, + .probe = cadence_nand_dt_probe, + .priv_auto = sizeof(struct cadence_nand_info), +}; + +void board_nand_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MTD, + DM_DRIVER_GET(cadence_nand_dt), + &dev); + if (ret && ret != -ENODEV) + pr_err("Failed to initialize Cadence NAND controller. (error %d)\n", + ret); +} diff --git a/include/cadence-nand.h b/include/cadence-nand.h new file mode 100644 index 0000000000..101f60ce0e --- /dev/null +++ b/include/cadence-nand.h @@ -0,0 +1,526 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Cadence NAND flash controller driver + * + * Copyright (C) 2019 Cadence + * + * Author: Piotr Sroka piotrs@cadence.com + * + */ + +#ifndef _CADENCE_NAND_H_ +#define _CADENCE_NAND_H_ +#include <clk.h> +#include <reset.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/rawnand.h> + +/* + * HPNFC can work in 3 modes: + * - PIO - can work in master or slave DMA + * - CDMA - needs Master DMA for accessing command descriptors. + * - Generic mode - can use only slave DMA. + * CDMA and PIO modes can be used to execute only base commands. + * CDMA and PIO modes can be used to execute only base commands. + * Generic mode can be used to execute any command + * on NAND flash memory. Driver uses CDMA mode for + * block erasing, page reading, page programing. + * Generic mode is used for executing rest of commands. + */ + +#define DMA_DATA_SIZE_ALIGN 8 + +/* Register definition. */ +/* + * Command register 0. + * Writing data to this register will initiate a new transaction + * of the NF controller. + */ +#define CMD_REG0 0x0000 +/* Command type field mask. */ +#define CMD_REG0_CT GENMASK(31, 30) +/* Command type CDMA. */ +#define CMD_REG0_CT_CDMA 0uL +/* Command type generic. */ +#define CMD_REG0_CT_GEN 3uL +/* Command thread number field mask. */ +#define CMD_REG0_TN GENMASK(27, 24) + +/* Command register 2. */ +#define CMD_REG2 0x0008 +/* Command register 3. */ +#define CMD_REG3 0x000C +/* Pointer register to select which thread status will be selected. */ +#define CMD_STATUS_PTR 0x0010 +/* Command status register for selected thread. */ +#define CMD_STATUS 0x0014 + +/* Interrupt status register. */ +#define INTR_STATUS 0x0110 +#define INTR_STATUS_SDMA_ERR BIT(22) +#define INTR_STATUS_SDMA_TRIGG BIT(21) +#define INTR_STATUS_UNSUPP_CMD BIT(19) +#define INTR_STATUS_DDMA_TERR BIT(18) +#define INTR_STATUS_CDMA_TERR BIT(17) +#define INTR_STATUS_CDMA_IDL BIT(16) + +/* Interrupt enable register. */ +#define INTR_ENABLE 0x0114 +#define INTR_ENABLE_INTR_EN BIT(31) + +/* Controller internal state. */ +#define CTRL_STATUS 0x0118 +#define CTRL_STATUS_INIT_COMP BIT(9) +#define CTRL_STATUS_CTRL_BUSY BIT(8) + +/* Command Engine threads state. */ +#define TRD_STATUS 0x0120 + +/* Command Engine interrupt thread error status. */ +#define TRD_ERR_INT_STATUS 0x0128 +/* Command Engine interrupt thread error enable. */ +#define TRD_ERR_INT_STATUS_EN 0x0130 +/* Command Engine interrupt thread complete status. */ +#define TRD_COMP_INT_STATUS 0x0138 + +/* + * Transfer config 0 register. + * Configures data transfer parameters. + */ +#define TRAN_CFG_0 0x0400 +/* Offset value from the beginning of the page. */ +#define TRAN_CFG_0_OFFSET GENMASK(31, 16) +/* Numbers of sectors to transfer within singlNF device's page. */ +#define TRAN_CFG_0_SEC_CNT GENMASK(7, 0) + +/* + * Transfer config 1 register. + * Configures data transfer parameters. + */ +#define TRAN_CFG_1 0x0404 +/* Size of last data sector. */ +#define TRAN_CFG_1_LAST_SEC_SIZE GENMASK(31, 16) +/* Size of not-last data sector. */ +#define TRAN_CFG_1_SECTOR_SIZE GENMASK(15, 0) + +/* ECC engine configuration register 0. */ +#define ECC_CONFIG_0 0x0428 +/* Correction strength. */ +#define ECC_CONFIG_0_CORR_STR GENMASK(10, 8) +/* Enable erased pages detection mechanism. */ +#define ECC_CONFIG_0_ERASE_DET_EN BIT(1) +/* Enable controller ECC check bits generation and correction. */ +#define ECC_CONFIG_0_ECC_EN BIT(0) + +/* ECC engine configuration register 1. */ +#define ECC_CONFIG_1 0x042C + +/* Multiplane settings register. */ +#define MULTIPLANE_CFG 0x0434 +/* Cache operation settings. */ +#define CACHE_CFG 0x0438 + +/* Transferred data block size for the slave DMA module. */ +#define SDMA_SIZE 0x0440 + +/* Thread number associated with transferred data block + * for the slave DMA module. + */ +#define SDMA_TRD_NUM 0x0444 +/* Thread number mask. */ +#define SDMA_TRD_NUM_SDMA_TRD GENMASK(2, 0) + +#define CONTROL_DATA_CTRL 0x0494 +/* Thread number mask. */ +#define CONTROL_DATA_CTRL_SIZE GENMASK(15, 0) + +#define CTRL_VERSION 0x800 +#define CTRL_VERSION_REV GENMASK(7, 0) + +/* Available hardware features of the controller. */ +#define CTRL_FEATURES 0x804 +/* Support for NV-DDR2/3 work mode. */ +#define CTRL_FEATURES_NVDDR_2_3 BIT(28) +/* Support for NV-DDR work mode. */ +#define CTRL_FEATURES_NVDDR BIT(27) +/* Support for asynchronous work mode. */ +#define CTRL_FEATURES_ASYNC BIT(26) +/* Support for asynchronous work mode. */ +#define CTRL_FEATURES_N_BANKS GENMASK(25, 24) +/* Slave and Master DMA data width. */ +#define CTRL_FEATURES_DMA_DWITH64 BIT(21) +/* Availability of Control Data feature.*/ +#define CTRL_FEATURES_CONTROL_DATA BIT(10) + +/* BCH Engine identification register 0 - correction strengths. */ +#define BCH_CFG_0 0x838 +#define BCH_CFG_0_CORR_CAP_0 GENMASK(7, 0) +#define BCH_CFG_0_CORR_CAP_1 GENMASK(15, 8) +#define BCH_CFG_0_CORR_CAP_2 GENMASK(23, 16) +#define BCH_CFG_0_CORR_CAP_3 GENMASK(31, 24) + +/* BCH Engine identification register 1 - correction strengths. */ +#define BCH_CFG_1 0x83C +#define BCH_CFG_1_CORR_CAP_4 GENMASK(7, 0) +#define BCH_CFG_1_CORR_CAP_5 GENMASK(15, 8) +#define BCH_CFG_1_CORR_CAP_6 GENMASK(23, 16) +#define BCH_CFG_1_CORR_CAP_7 GENMASK(31, 24) + +/* BCH Engine identification register 2 - sector sizes. */ +#define BCH_CFG_2 0x840 +#define BCH_CFG_2_SECT_0 GENMASK(15, 0) +#define BCH_CFG_2_SECT_1 GENMASK(31, 16) + +/* BCH Engine identification register 3. */ +#define BCH_CFG_3 0x844 +#define BCH_CFG_3_METADATA_SIZE GENMASK(23, 16) + +/* Ready/Busy# line status. */ +#define RBN_SETINGS 0x1004 + +/* Common settings. */ +#define COMMON_SET 0x1008 +/* 16 bit device connected to the NAND Flash interface. */ +#define COMMON_SET_DEVICE_16BIT BIT(8) + +/* Skip_bytes registers. */ +#define SKIP_BYTES_CONF 0x100C +#define SKIP_BYTES_MARKER_VALUE GENMASK(31, 16) +#define SKIP_BYTES_NUM_OF_BYTES GENMASK(7, 0) + +#define SKIP_BYTES_OFFSET 0x1010 +#define SKIP_BYTES_OFFSET_VALUE GENMASK(23, 0) + +/* Timings configuration. */ +#define ASYNC_TOGGLE_TIMINGS 0x101c +#define ASYNC_TOGGLE_TIMINGS_TRH GENMASK(28, 24) +#define ASYNC_TOGGLE_TIMINGS_TRP GENMASK(20, 16) +#define ASYNC_TOGGLE_TIMINGS_TWH GENMASK(12, 8) +#define ASYNC_TOGGLE_TIMINGS_TWP GENMASK(4, 0) + +#define TIMINGS0 0x1024 +#define TIMINGS0_TADL GENMASK(31, 24) +#define TIMINGS0_TCCS GENMASK(23, 16) +#define TIMINGS0_TWHR GENMASK(15, 8) +#define TIMINGS0_TRHW GENMASK(7, 0) + +#define TIMINGS1 0x1028 +#define TIMINGS1_TRHZ GENMASK(31, 24) +#define TIMINGS1_TWB GENMASK(23, 16) +#define TIMINGS1_TVDLY GENMASK(7, 0) + +#define TIMINGS2 0x102c +#define TIMINGS2_TFEAT GENMASK(25, 16) +#define TIMINGS2_CS_HOLD_TIME GENMASK(13, 8) +#define TIMINGS2_CS_SETUP_TIME GENMASK(5, 0) + +/* Configuration of the resynchronization of slave DLL of PHY. */ +#define DLL_PHY_CTRL 0x1034 +#define DLL_PHY_CTRL_DLL_RST_N BIT(24) +#define DLL_PHY_CTRL_EXTENDED_WR_MODE BIT(17) +#define DLL_PHY_CTRL_EXTENDED_RD_MODE BIT(16) +#define DLL_PHY_CTRL_RS_HIGH_WAIT_CNT GENMASK(11, 8) +#define DLL_PHY_CTRL_RS_IDLE_CNT GENMASK(7, 0) + +/* TODO: - Identify better way to handle PHY address */ +#define PHY_OFFSET 0x10000 + +/* Register controlling DQ related timing. */ +#define PHY_DQ_TIMING PHY_OFFSET + 0x2000 +/* Register controlling DSQ related timing. */ +#define PHY_DQS_TIMING PHY_OFFSET + 0x2004 +#define PHY_DQS_TIMING_DQS_SEL_OE_END GENMASK(3, 0) +#define PHY_DQS_TIMING_PHONY_DQS_SEL BIT(16) +#define PHY_DQS_TIMING_USE_PHONY_DQS BIT(20) + +/* Register controlling the gate and loopback control related timing. */ +#define PHY_GATE_LPBK_CTRL PHY_OFFSET + 0x2008 +#define PHY_GATE_LPBK_CTRL_RDS GENMASK(24, 19) + +/* Register holds the control for the master DLL logic. */ +#define PHY_DLL_MASTER_CTRL PHY_OFFSET + 0x200C +#define PHY_DLL_MASTER_CTRL_BYPASS_MODE BIT(23) + +/* Register holds the control for the slave DLL logic. */ +#define PHY_DLL_SLAVE_CTRL PHY_OFFSET + 0x2010 + +/* This register handles the global control settings for the PHY. */ +#define PHY_CTRL PHY_OFFSET + 0x2080 +#define PHY_CTRL_SDR_DQS BIT(14) +#define PHY_CTRL_PHONY_DQS GENMASK(9, 4) + +/* + * This register handles the global control settings + * for the termination selects for reads. + */ +#define PHY_TSEL PHY_OFFSET + 0x2084 + +/* Generic command layout. */ +#define GCMD_LAY_CS GENMASK_ULL(11, 8) +/* + * This bit informs the minicotroller if it has to wait for tWB + * after sending the last CMD/ADDR/DATA in the sequence. + */ +#define GCMD_LAY_TWB BIT_ULL(6) +/* Type of generic instruction. */ +#define GCMD_LAY_INSTR GENMASK_ULL(5, 0) + +/* Generic CMD sequence type. */ +#define GCMD_LAY_INSTR_CMD 0 +/* Generic ADDR sequence type. */ +#define GCMD_LAY_INSTR_ADDR 1 +/* Generic data transfer sequence type. */ +#define GCMD_LAY_INSTR_DATA 2 + +/* Input part of generic command type of input is command. */ +#define GCMD_LAY_INPUT_CMD GENMASK_ULL(23, 16) + +/* Generic command address sequence - address fields. */ +#define GCMD_LAY_INPUT_ADDR GENMASK_ULL(63, 16) +/* Generic command address sequence - address size. */ +#define GCMD_LAY_INPUT_ADDR_SIZE GENMASK_ULL(13, 11) + +/* Transfer direction field of generic command data sequence. */ +#define GCMD_DIR BIT_ULL(11) +/* Read transfer direction of generic command data sequence. */ +#define GCMD_DIR_READ 0 +/* Write transfer direction of generic command data sequence. */ +#define GCMD_DIR_WRITE 1 + +/* ECC enabled flag of generic command data sequence - ECC enabled. */ +#define GCMD_ECC_EN BIT_ULL(12) +/* Generic command data sequence - sector size. */ +#define GCMD_SECT_SIZE GENMASK_ULL(31, 16) +/* Generic command data sequence - sector count. */ +#define GCMD_SECT_CNT GENMASK_ULL(39, 32) +/* Generic command data sequence - last sector size. */ +#define GCMD_LAST_SIZE GENMASK_ULL(55, 40) + +/* CDMA descriptor fields. */ +/* Erase command type of CDMA descriptor. */ +#define CDMA_CT_ERASE 0x1000 +/* Program page command type of CDMA descriptor. */ +#define CDMA_CT_WR 0x2100 +/* Read page command type of CDMA descriptor. */ +#define CDMA_CT_RD 0x2200 + +/* Flash pointer memory shift. */ +#define CDMA_CFPTR_MEM_SHIFT 24 +/* Flash pointer memory mask. */ +#define CDMA_CFPTR_MEM GENMASK(26, 24) + +/* + * Command DMA descriptor flags. If set causes issue interrupt after + * the completion of descriptor processing. + */ +#define CDMA_CF_INT BIT(8) +/* + * Command DMA descriptor flags - the next descriptor + * address field is valid and descriptor processing should continue. + */ +#define CDMA_CF_CONT BIT(9) +/* DMA master flag of command DMA descriptor. */ +#define CDMA_CF_DMA_MASTER BIT(10) + +/* Operation complete status of command descriptor. */ +#define CDMA_CS_COMP BIT(15) +/* Operation complete status of command descriptor. */ +/* Command descriptor status - operation fail. */ +#define CDMA_CS_FAIL BIT(14) +/* Command descriptor status - page erased. */ +#define CDMA_CS_ERP BIT(11) +/* Command descriptor status - timeout occurred. */ +#define CDMA_CS_TOUT BIT(10) +/* + * Maximum amount of correction applied to one ECC sector. + * It is part of command descriptor status. + */ +#define CDMA_CS_MAXERR GENMASK(9, 2) +/* Command descriptor status - uncorrectable ECC error. */ +#define CDMA_CS_UNCE BIT(1) +/* Command descriptor status - descriptor error. */ +#define CDMA_CS_ERR BIT(0) + +/* Status of operation - OK. */ +#define STAT_OK 0 +/* Status of operation - FAIL. */ +#define STAT_FAIL 2 +/* Status of operation - uncorrectable ECC error. */ +#define STAT_ECC_UNCORR 3 +/* Status of operation - page erased. */ +#define STAT_ERASED 5 +/* Status of operation - correctable ECC error. */ +#define STAT_ECC_CORR 6 +/* Status of operation - unsuspected state. */ +#define STAT_UNKNOWN 7 +/* Status of operation - operation is not completed yet. */ +#define STAT_BUSY 0xFF + +#define BCH_MAX_NUM_CORR_CAPS 8 +#define BCH_MAX_NUM_SECTOR_SIZES 2 + +#define ONE_CYCLE 1 +#define TIMEOUT_US 1000000 + +struct cadence_nand_timings { + u32 async_toggle_timings; + u32 timings0; + u32 timings1; + u32 timings2; + u32 dll_phy_ctrl; + u32 phy_ctrl; + u32 phy_dqs_timing; + u32 phy_gate_lpbk_ctrl; +}; + +/* Command DMA descriptor. */ +struct cadence_nand_cdma_desc { + /* Next descriptor address. */ + u64 next_pointer; + + /* Flash address is a 32-bit address comprising of BANK and ROW ADDR. */ + u32 flash_pointer; + /*field appears in HPNFC version 13*/ + u16 bank; + u16 rsvd0; + + /* Operation the controller needs to perform. */ + u16 command_type; + u16 rsvd1; + /* Flags for operation of this command. */ + u16 command_flags; + u16 rsvd2; + + /* System/host memory address required for data DMA commands. */ + u64 memory_pointer; + + /* Status of operation. */ + u32 status; + u32 rsvd3; + + /* Address pointer to sync buffer location. */ + u64 sync_flag_pointer; + + /* Controls the buffer sync mechanism. */ + u32 sync_arguments; + u32 rsvd4; + + /* Control data pointer. */ + u64 ctrl_data_ptr; +}; + +/* Interrupt status. */ +struct cadence_nand_irq_status { + /* Thread operation complete status. */ + u32 trd_status; + /* Thread operation error. */ + u32 trd_error; + /* Controller status. */ + u32 status; +}; + +/* Cadence NAND flash controller capabilities get from driver data. */ +struct cadence_nand_dt_devdata { + /* Skew value of the output signals of the NAND Flash interface. */ + u32 if_skew; + /* It informs if slave DMA interface is connected to DMA engine. */ + unsigned int has_dma:1; +}; + +/* Cadence NAND flash controller capabilities read from registers. */ +struct cdns_nand_caps { + /* Maximum number of banks supported by hardware. */ + u8 max_banks; + /* Slave and Master DMA data width in bytes (4 or 8). */ + u8 data_dma_width; + /* Control Data feature supported. */ + bool data_control_supp; + /* Is PHY type DLL. */ + bool is_phy_type_dll; +}; + +struct cadence_nand_info { + struct udevice *dev; + struct reset_ctl softphy_reset; + struct reset_ctl nand_reset; + struct cadence_nand_cdma_desc *cdma_desc; + /* IP capability. */ + const struct cadence_nand_dt_devdata *caps1; + struct cdns_nand_caps caps2; + u8 ctrl_rev; + dma_addr_t dma_cdma_desc; + /* command interface buffers */ + u8 *buf; + u32 buf_size; + u8 *stat; + + u8 curr_corr_str_idx; + + /* Register interface. */ + void __iomem *reg; + + struct { + void __iomem *virt; + dma_addr_t dma; + } io; + + int irq; + /* Interrupts that have happened. */ + struct cadence_nand_irq_status irq_status; + /* Interrupts we are waiting for. */ + struct cadence_nand_irq_status irq_mask; + + int ecc_strengths[BCH_MAX_NUM_CORR_CAPS]; + struct nand_ecc_step_info ecc_stepinfos[BCH_MAX_NUM_SECTOR_SIZES]; + struct nand_ecc_caps ecc_caps; + + int curr_trans_type; + + struct clk clk; + u32 nf_clk_rate; + /* + * Estimated Board delay. The value includes the total + * round trip delay for the signals and is used for deciding on values + * associated with data read capture. + */ + u32 board_delay; + + struct nand_chip selected_chip; + + unsigned long assigned_cs; + struct list_head chips; + u8 bch_metadata_size; +}; + +struct cdns_nand_chip { + struct cadence_nand_timings timings; + struct nand_chip chip; + u8 nsels; + struct list_head node; + + /* + * part of oob area of NAND flash memory page. + * This part is available for user to read or write. + */ + u32 avail_oob_size; + + /* Sector size. There are few sectors per mtd->writesize */ + u32 sector_size; + u32 sector_count; + + /* Offset of BBM. */ + u8 bbm_offs; + /* Number of bytes reserved for BBM. */ + u8 bbm_len; + /* ECC strength index. */ + u8 corr_str_idx; + + u8 cs[]; +}; + +struct ecc_info { + int (*calc_ecc_bytes)(int step_size, int strength); + int max_step_size; +}; + +#endif /*_CADENCE_NAND_H_*/
This patch will add support for read status command in Cadence NAND driver. This status bit is important to check whether the flash is write-protected.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/cadence_nand.c | 46 ++++++++++++++++++++++++++++- include/cadence-nand.h | 2 ++ 2 files changed, 47 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/raw/cadence_nand.c b/drivers/mtd/nand/raw/cadence_nand.c index f9f28c392b..670f5ca184 100644 --- a/drivers/mtd/nand/raw/cadence_nand.c +++ b/drivers/mtd/nand/raw/cadence_nand.c @@ -343,6 +343,7 @@ static int cadence_nand_generic_cmd_send(struct cadence_nand_info *cadence,
/* Issue command. */ writel_relaxed(reg, cadence->reg + CMD_REG0); + cadence->buf_index = 0;
return 0; } @@ -1902,9 +1903,42 @@ static void cadence_nand_select_chip(struct mtd_info *mtd, int chipnr) } }
+static int cadence_nand_status(struct mtd_info *mtd, unsigned int command) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + int ret = 0; + + ret = cadence_nand_cmd_opcode(cadence, command); + if (ret) + return ret; + + ret = cadence_nand_cmd_data(cadence, 1, GCMD_DIR_READ); + if (ret) + return ret; + + return 0; +} + static void cadence_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, int offset_in_page, int page) { + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + int ret = 0; + + cadence->cmd = command; + switch (command) { + case NAND_CMD_STATUS: + ret = cadence_nand_status(mtd, command); + break; + /* + * ecc will override other command for read, write and erase + */ + default: + break; + } + + if (ret != 0) + printf("ERROR:%s:command:0x%x\n", __func__, cadence->cmd); }
static int cadence_nand_dev_ready(struct mtd_info *mtd) @@ -1921,7 +1955,17 @@ static int cadence_nand_dev_ready(struct mtd_info *mtd)
static u8 cadence_nand_read_byte(struct mtd_info *mtd) { - return 0; + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + u32 size = 1; + u8 val; + + if (cadence->buf_index == 0) + cadence_nand_read_buf(mtd, &cadence->buf[0], size); + + val = *(&cadence->buf[0] + cadence->buf_index); + cadence->buf_index++; + + return val; }
static void cadence_nand_write_byte(struct mtd_info *mtd, u8 byte) diff --git a/include/cadence-nand.h b/include/cadence-nand.h index 101f60ce0e..5b9d6e0382 100644 --- a/include/cadence-nand.h +++ b/include/cadence-nand.h @@ -453,6 +453,8 @@ struct cadence_nand_info { u8 *buf; u32 buf_size; u8 *stat; + u8 cmd; + u32 buf_index;
This patch will add support for readid command in Cadence NAND driver. The id is unique and used for flash identification.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/cadence_nand.c | 32 ++++++++++++++++++++++++++++- 1 file changed, 31 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/raw/cadence_nand.c b/drivers/mtd/nand/raw/cadence_nand.c index 670f5ca184..55fd3dfdb3 100644 --- a/drivers/mtd/nand/raw/cadence_nand.c +++ b/drivers/mtd/nand/raw/cadence_nand.c @@ -1919,6 +1919,27 @@ static int cadence_nand_status(struct mtd_info *mtd, unsigned int command) return 0; }
+static int cadence_nand_readid(struct mtd_info *mtd, int offset_in_page, unsigned int command) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + u8 addrs = (u8)offset_in_page; + int ret = 0; + + ret = cadence_nand_cmd_opcode(cadence, command); + if (ret) + return ret; + + ret = cadence_nand_cmd_address(cadence, ONE_CYCLE, &addrs); + if (ret) + return ret; + + ret = cadence_nand_cmd_data(cadence, 8, GCMD_DIR_READ); + if (ret) + return ret; + + return 0; +} + static void cadence_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, int offset_in_page, int page) { @@ -1930,6 +1951,11 @@ static void cadence_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, case NAND_CMD_STATUS: ret = cadence_nand_status(mtd, command); break; + + case NAND_CMD_READID: + ret = cadence_nand_readid(mtd, offset_in_page, command); + break; + /* * ecc will override other command for read, write and erase */ @@ -1959,8 +1985,12 @@ static u8 cadence_nand_read_byte(struct mtd_info *mtd) u32 size = 1; u8 val;
- if (cadence->buf_index == 0) + if (cadence->buf_index == 0) { + if (cadence->cmd == NAND_CMD_READID) + size = 8; + cadence_nand_read_buf(mtd, &cadence->buf[0], size); + }
val = *(&cadence->buf[0] + cadence->buf_index); cadence->buf_index++;
This patch is to add support for reading param page of NAND device. These paramaters are unique and used for identification purpose.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/cadence_nand.c | 30 +++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/drivers/mtd/nand/raw/cadence_nand.c b/drivers/mtd/nand/raw/cadence_nand.c index 55fd3dfdb3..1b5cda1955 100644 --- a/drivers/mtd/nand/raw/cadence_nand.c +++ b/drivers/mtd/nand/raw/cadence_nand.c @@ -1940,6 +1940,31 @@ static int cadence_nand_readid(struct mtd_info *mtd, int offset_in_page, unsigne return 0; }
+static int cadence_nand_param(struct mtd_info *mtd, u8 offset_in_page, unsigned int command) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct nand_chip *chip = mtd_to_nand(mtd); + int ret = 0; + + ret = cadence_nand_cmd_opcode(cadence, command); + if (ret) + return ret; + + ret = cadence_nand_cmd_address(cadence, ONE_CYCLE, &offset_in_page); + if (ret) + return ret; + + ret = cadence_nand_waitfunc(mtd, chip); + if (ret) + return ret; + + ret = cadence_nand_cmd_data(cadence, sizeof(struct nand_jedec_params), GCMD_DIR_READ); + if (ret) + return ret; + + return 0; +} + static void cadence_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, int offset_in_page, int page) { @@ -1956,6 +1981,9 @@ static void cadence_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, ret = cadence_nand_readid(mtd, offset_in_page, command); break;
+ case NAND_CMD_PARAM: + ret = cadence_nand_param(mtd, offset_in_page, command); + break; /* * ecc will override other command for read, write and erase */ @@ -1988,6 +2016,8 @@ static u8 cadence_nand_read_byte(struct mtd_info *mtd) if (cadence->buf_index == 0) { if (cadence->cmd == NAND_CMD_READID) size = 8; + else if (cadence->cmd == NAND_CMD_PARAM) + size = sizeof(struct nand_jedec_params);
cadence_nand_read_buf(mtd, &cadence->buf[0], size); }
The patch is to support nand reset command for Cadence Nand Driver.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/cadence_nand.c | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/drivers/mtd/nand/raw/cadence_nand.c b/drivers/mtd/nand/raw/cadence_nand.c index 1b5cda1955..1b1335af68 100644 --- a/drivers/mtd/nand/raw/cadence_nand.c +++ b/drivers/mtd/nand/raw/cadence_nand.c @@ -1965,10 +1965,28 @@ static int cadence_nand_param(struct mtd_info *mtd, u8 offset_in_page, unsigned return 0; }
+static int cadence_nand_reset(struct mtd_info *mtd, unsigned int command) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct nand_chip *chip = mtd_to_nand(mtd); + int ret = 0; + + ret = cadence_nand_cmd_opcode(cadence, command); + if (ret) + return ret; + + ret = cadence_nand_waitfunc(mtd, chip); + if (ret) + return ret; + + return 0; +} + static void cadence_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, int offset_in_page, int page) { struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + struct nand_chip *chip = mtd_to_nand(mtd); int ret = 0;
cadence->cmd = command; @@ -1984,6 +2002,10 @@ static void cadence_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, case NAND_CMD_PARAM: ret = cadence_nand_param(mtd, offset_in_page, command); break; + + case NAND_CMD_RESET: + ret = cadence_nand_reset(mtd, command); + break; /* * ecc will override other command for read, write and erase */ @@ -1991,6 +2013,12 @@ static void cadence_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, break; }
+ if (cadence->cmd == NAND_CMD_RESET) { + ret = cadence_nand_select_target(cadence, chip); + if (ret) + dev_err(cadence->dev, "Chip select failure after reset\n"); + } + if (ret != 0) printf("ERROR:%s:command:0x%x\n", __func__, cadence->cmd); }
This patch is to support NAND_CMD_SET_FEATURES & NAND_CMD_GET_FEATURES. These commands is one of the basic commands of NAND. Params get from these commands will be used to set timing mode of NAND data interface.
diff --git a/drivers/mtd/nand/raw/cadence_nand.c b/drivers/mtd/nand/raw/cadence_nand.c index 1b1335af68..108e1fa965 100644 --- a/drivers/mtd/nand/raw/cadence_nand.c +++ b/drivers/mtd/nand/raw/cadence_nand.c @@ -1982,6 +1982,29 @@ static int cadence_nand_reset(struct mtd_info *mtd, unsigned int command) return 0; }
+static int cadence_nand_features(struct mtd_info *mtd, u8 offset_in_page, u32 command) +{ + struct cadence_nand_info *cadence = mtd_to_cadence(mtd); + int ret = 0; + + ret = cadence_nand_cmd_opcode(cadence, command); + if (ret) + return ret; + + ret = cadence_nand_cmd_address(cadence, ONE_CYCLE, &offset_in_page); + if (ret) + return ret; + + if (command == NAND_CMD_GET_FEATURES) + ret = cadence_nand_cmd_data(cadence, ONFI_SUBFEATURE_PARAM_LEN, + GCMD_DIR_READ); + else + ret = cadence_nand_cmd_data(cadence, ONFI_SUBFEATURE_PARAM_LEN, + GCMD_DIR_WRITE); + + return ret; +} + static void cadence_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, int offset_in_page, int page) { @@ -2006,6 +2029,11 @@ static void cadence_nand_cmdfunc(struct mtd_info *mtd, unsigned int command, case NAND_CMD_RESET: ret = cadence_nand_reset(mtd, command); break; + + case NAND_CMD_SET_FEATURES: + case NAND_CMD_GET_FEATURES: + ret = cadence_nand_features(mtd, offset_in_page, command); + break; /* * ecc will override other command for read, write and erase */ @@ -2046,6 +2074,8 @@ static u8 cadence_nand_read_byte(struct mtd_info *mtd) size = 8; else if (cadence->cmd == NAND_CMD_PARAM) size = sizeof(struct nand_jedec_params); + else if (cadence->cmd == NAND_CMD_GET_FEATURES) + size = ONFI_SUBFEATURE_PARAM_LEN;
The patch is to ensure ddr memory is updated with the data from dcache, This would help to ensure cdma always reading the latest dma descriptor in ddr memory.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/cadence_nand.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/mtd/nand/raw/cadence_nand.c b/drivers/mtd/nand/raw/cadence_nand.c index 108e1fa965..429a5e8017 100644 --- a/drivers/mtd/nand/raw/cadence_nand.c +++ b/drivers/mtd/nand/raw/cadence_nand.c @@ -429,6 +429,10 @@ cadence_nand_cdma_desc_prepare(struct cadence_nand_info *cadence,
cdma_desc->command_type = ctype; cdma_desc->ctrl_data_ptr = ctrl_data_ptr; + + flush_cache((dma_addr_t)cadence->cdma_desc, + ROUND(sizeof(struct cadence_nand_cdma_desc), + ARCH_DMA_MINALIGN)); }
static u8 cadence_nand_check_desc_error(struct cadence_nand_info *cadence,
The patch is to poll for thread complete status to ensure the descriptor processing is complete. If complete then can ensure controller already update the descriptor status.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/cadence_nand.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/mtd/nand/raw/cadence_nand.c b/drivers/mtd/nand/raw/cadence_nand.c index 429a5e8017..33e8b79520 100644 --- a/drivers/mtd/nand/raw/cadence_nand.c +++ b/drivers/mtd/nand/raw/cadence_nand.c @@ -514,6 +514,7 @@ cadence_nand_cdma_send_and_wait(struct cadence_nand_info *cadence, { struct cadence_nand_irq_status irq_mask, irq_status = {0}; int status; + u32 val;
irq_mask.trd_status = BIT(thread); irq_mask.trd_error = BIT(thread); @@ -525,6 +526,14 @@ cadence_nand_cdma_send_and_wait(struct cadence_nand_info *cadence, if (status) return status;
+ /* Make sure the descriptor processing is complete */ + status = readl_poll_timeout(cadence->reg + TRD_COMP_INT_STATUS, val, + (val & BIT(thread)), TIMEOUT_US); + if (status) { + pr_err("cmd thread completion timeout!\n"); + return status; + } + cadence_nand_wait_for_irq(cadence, &irq_mask, &irq_status);
if (irq_status.status == 0 && irq_status.trd_status == 0 &&
The patch is to enable nand to use bounce buffer. In bounce buffer, read/write buf will use cadence->buf which has been allocated using malloc. This will align the memory and avoid memory to be allocated in different addresses.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/cadence_nand.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/raw/cadence_nand.c b/drivers/mtd/nand/raw/cadence_nand.c index 33e8b79520..9a26bdba8c 100644 --- a/drivers/mtd/nand/raw/cadence_nand.c +++ b/drivers/mtd/nand/raw/cadence_nand.c @@ -965,7 +965,7 @@ static int cadence_nand_write_page(struct mtd_info *mtd, struct nand_chip *chip, cadence_nand_prepare_data_size(mtd, TT_MAIN_OOB_AREA_EXT);
if (cadence_nand_dma_buf_ok(cadence, buf, mtd->writesize) && - cadence->caps2.data_control_supp) { + cadence->caps2.data_control_supp && !(chip->options & NAND_USE_BOUNCE_BUFFER) { u8 *oob;
if (oob_required) @@ -1132,7 +1132,7 @@ static int cadence_nand_read_page(struct mtd_info *mtd, struct nand_chip *chip, * is supported then transfer data and oob directly. */ if (cadence_nand_dma_buf_ok(cadence, buf, mtd->writesize) && - cadence->caps2.data_control_supp) { + cadence->caps2.data_control_supp && !(chip->options & NAND_USE_BOUNCE_BUFFER)) { u8 *oob;
if (oob_required) @@ -1824,6 +1824,7 @@ static int cadence_nand_attach_chip(struct mtd_info *mtd, struct nand_chip *chip return ret; }
+ chip->options |= NAND_USE_BOUNCE_BUFFER; chip->bbt_options |= NAND_BBT_USE_FLASH; chip->bbt_options |= NAND_BBT_NO_OOB; chip->ecc.mode = NAND_ECC_HW_SYNDROME;
This patch is to enable the Kconfig and Makefile for the Cadence NAND driver for the agilex5 family device.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/Kconfig | 9 +++++++++ drivers/mtd/nand/raw/Makefile | 1 + 2 files changed, 10 insertions(+)
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 9f3f1267cb..709c85c6e5 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -207,6 +207,15 @@ config SPL_NAND_LOAD def_bool y depends on NAND_DAVINCI && ARCH_DAVINCI && SPL_NAND_SUPPORT
+config NAND_CADENCE + bool "Support Cadence NAND controller as a DT device" + depends on OF_CONTROL && DM_MTD + select SYS_NAND_SELF_INIT + imply CMD_NAND + help + Enable the driver for NAND flash on platforms using a Cadence NAND + controller as a DT device. + config NAND_DENALI bool select SYS_NAND_SELF_INIT diff --git a/drivers/mtd/nand/raw/Makefile b/drivers/mtd/nand/raw/Makefile index 46fead6fa4..4ad1a2037f 100644 --- a/drivers/mtd/nand/raw/Makefile +++ b/drivers/mtd/nand/raw/Makefile @@ -51,6 +51,7 @@ obj-$(CONFIG_NAND_ATMEL) += atmel_nand.o obj-$(CONFIG_DM_NAND_ATMEL) += atmel/ obj-$(CONFIG_NAND_ARASAN) += arasan_nfc.o obj-$(CONFIG_NAND_BRCMNAND) += brcmnand/ +obj-$(CONFIG_NAND_CADENCE) += cadence_nand.o obj-$(CONFIG_NAND_DAVINCI) += davinci_nand.o obj-$(CONFIG_NAND_DENALI) += denali.o obj-$(CONFIG_NAND_DENALI_DT) += denali_dt.o
This patch is to enable configs for nand boot.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- configs/socfpga_agilex5_nand2_defconfig | 169 ++++++++++++++++++++++++ 1 file changed, 169 insertions(+) create mode 100644 configs/socfpga_agilex5_nand2_defconfig
diff --git a/configs/socfpga_agilex5_nand2_defconfig b/configs/socfpga_agilex5_nand2_defconfig new file mode 100644 index 0000000000..9e5a75194a --- /dev/null +++ b/configs/socfpga_agilex5_nand2_defconfig @@ -0,0 +1,169 @@ +CONFIG_ARM=y +CONFIG_SPL_LDSCRIPT="arch/arm/mach-socfpga/u-boot-spl-soc64.lds" +CONFIG_SYS_SPI_U_BOOT_OFFS=0x04000000 +CONFIG_ARCH_SOCFPGA=y +CONFIG_TEXT_BASE=0x80200000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x04100000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="socfpga_agilex5_socdk" +CONFIG_SPL_MMC=y +CONFIG_TARGET_SOCFPGA_AGILEX5_SOCDK=y +CONFIG_TARGET_SOCFPGA_AGILEX5_NAND2=y +CONFIG_QPDS_HPS_HANDOFF=y +CONFIG_IDENT_STRING="socfpga_agilex5" +CONFIG_SPL_FS_FAT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x82000000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="earlycon panic=-1 root=${nandroot} rw rootwait rootfstype=ubifs ubi.mtd=1" +CONFIG_LEGACY_IMAGE_FORMAT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_CRC32=y +CONFIG_SPL_CACHE=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_SYS_PROMPT="SOCFPGA_AGILEX5 # " +CONFIG_CMD_NVEDIT_SELECT=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=n +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_PHY=y +CONFIG_SPL_PHY=y +CONFIG_NOP_PHY=y +CONFIG_SPL_NOP_PHY=y +CONFIG_PHY_CADENCE_COMBOPHY=n +CONFIG_SPL_PHY_CADENCE_COMBOPHY=n +CONFIG_MMC=y +CONFIG_MMC_WRITE=y +# CONFIG_MMC_BROKEN_CD is not set +CONFIG_DM_MMC=y +CONFIG_SPL_DM_MMC=y +CONFIG_MMC_SDHCI_ADMA_HELPERS=y +# CONFIG_ARM_PL180_MMCI is not set +CONFIG_MMC_QUIRKS=y +CONFIG_SYS_MMC_MAX_BLK_COUNT=65535 +CONFIG_MMC_HW_PARTITIONING=y +# CONFIG_SUPPORT_EMMC_RPMB is not set +# CONFIG_SUPPORT_EMMC_BOOT is not set +# CONFIG_MMC_IO_VOLTAGE is not set +# CONFIG_MMC_HS400_ES_SUPPORT is not set +# CONFIG_MMC_HS400_SUPPORT is not set +# CONFIG_MMC_HS200_SUPPORT is not set +CONFIG_MMC_VERBOSE=n +CONFIG_MMC_TRACE=n +# CONFIG_MMC_DW is not set +# CONFIG_MMC_MXC is not set +# CONFIG_MMC_PCI is not set +# CONFIG_MMC_OMAP_HS is not set +CONFIG_MMC_SDHCI=y +# CONFIG_MMC_SDHCI_SDMA is not set +CONFIG_MMC_SDHCI_ADMA=y +CONFIG_SPL_MMC_SDHCI_ADMA=y +# CONFIG_MMC_SDHCI_BCMSTB is not set +CONFIG_MMC_SDHCI_CADENCE=y +CONFIG_CMD_FAT=y +CONFIG_DOS_PARTITION=y +CONFIG_SPL_DOS_PARTITION=y +CONFIG_SPL_SYS_DISABLE_DCACHE_OPS=y +CONFIG_CMD_MTD=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_CMD_NAND_TRIMFFS=y +CONFIG_CMD_NAND_LOCK_UNLOCK=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +CONFIG_SPL_SPI_FLASH_MTD=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_MTDIDS_DEFAULT="nand0=10b80000.nand.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=10b80000.nand.0:2m(u-boot),-(root)" +CONFIG_CMD_UBI=y +CONFIG_CMD_UBIFS=y +CONFIG_MTD_UBI=y +CONFIG_MTD_UBI_WL_THRESHOLD=4096 +CONFIG_MTD_UBI_BEB_LIMIT=20 +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_LIST="" +CONFIG_ENV_IS_IN_UBI=y +CONFIG_ENV_UBI_PART="root" +CONFIG_ENV_UBI_VOLUME="env" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_ALTERA_SDRAM=y +CONFIG_FPGA_INTEL_PR=y +CONFIG_DWAPB_GPIO=y +CONFIG_DM_I2C=n +CONFIG_SYS_I2C_DW=n +CONFIG_MISC=y +CONFIG_MISC_INIT_R=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x0 +CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND=0x100000 +CONFIG_SF_DEFAULT_MODE=0x2003 +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_UBI_SILENCE_MSG=y +CONFIG_PHY_MARVELL=y +CONFIG_DM_ETH=y +CONFIG_DWC_ETH_XGMAC=y +CONFIG_RGMII=y +CONFIG_DM_RESET=y +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_DESIGNWARE_SPI=y +CONFIG_USB=y +CONFIG_USB_DWC2=n +CONFIG_USB_DWC3=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_UBIFS_SILENCE_MSG=y +# CONFIG_SPL_USE_TINY_PRINTF is not set +CONFIG_PANIC_HANG=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_WDT=n +CONFIG_CMD_WDT=n +CONFIG_DESIGNWARE_WATCHDOG=n +CONFIG_SPL_WDT=n +CONFIG_WATCHDOG_AUTOSTART=n +CONFIG_TIMER=n +CONFIG_DESIGNWARE_APB_TIMER=n +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80300000 +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0xbff00000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x73000 +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xbfa00000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_BSS_MAX_SIZE=0x100000 +# CONFIG_EFI_LOADER is not set +CONFIG_I3C=n +CONFIG_DW_I3C_MASTER=n +CONFIG_CMD_I3C=n +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_CADENCE=y +CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_NAND_FRAMEWORK=y +CONFIG_SPL_NAND_CADENCE=y +CONFIG_SYS_MAXARGS=32 +CONFIG_SYS_NAND_ONFI_DETECTION=y
Hi
2.26.2
Please add Manteiner support for this board
Michael
On Sat, Oct 05, 2024 at 05:16:33PM +0200, Michael Nazzareno Trimarchi wrote:
Hi
2.26.2
Also you should strongly consider using the #include mechanism (see configs/am62x_lpsk_a53_defconfig and configs/am62x_evm_a53_defconfig for example and note the CONFIG_ARM and similar lines are required for buildman to work still and so CI) to make long term support for this variant of the board easier.
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: Saturday, 5 October 2024 11:21 pm To: Michael Nazzareno Trimarchi michael@amarulasolutions.com Cc: Maniyam, Dinesh dinesh.maniyam@intel.com; u-boot@lists.denx.de; Marek marex@denx.de; Simon simon.k.r.goldschmidt@gmail.com; Dario Binacchi dario.binacchi@amarulasolutions.com; Johan Jonker jbx6244@gmail.com; Michal Simek michal.simek@amd.com; Arseniy Krasnov avkrasnov@salutedevices.com; Alexander Dahl ada@thorsis.com; William Zhang william.zhang@broadcom.com; Igor Prusov ivprusov@salutedevices.com; Chee, Tien Fong tien.fong.chee@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com; Ng, Boon Khai boon.khai.ng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Teik Heng teik.heng.chong@intel.com; Zamri, Muhammad Hazim Izzat muhammad.hazim.izzat.zamri@intel.com; Meng, Tingting tingting.meng@intel.com; Lim, Jit Loon jit.loon.lim@intel.com; Tang, Sieu Mun sieu.mun.tang@intel.com Subject: Re: [PATCH 14/19] configs: nand2_defconfig: Enable configs for nand boot
Hi
diff --git a/configs/socfpga_agilex5_nand2_defconfig b/configs/socfpga_agilex5_nand2_defconfig new file mode 100644 index 0000000000..9e5a75194a --- /dev/null +++ b/configs/socfpga_agilex5_nand2_defconfig @@ -0,0 +1,169 @@ +CONFIG_ARM=y +CONFIG_SPL_LDSCRIPT="arch/arm/mach-socfpga/u-boot-spl-soc64.lds" +CONFIG_SYS_SPI_U_BOOT_OFFS=0x04000000 +CONFIG_ARCH_SOCFPGA=y +CONFIG_TEXT_BASE=0x80200000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x04100000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="socfpga_agilex5_socdk" +CONFIG_SPL_MMC=y +CONFIG_TARGET_SOCFPGA_AGILEX5_SOCDK=y +CONFIG_TARGET_SOCFPGA_AGILEX5_NAND2=y +CONFIG_QPDS_HPS_HANDOFF=y +CONFIG_IDENT_STRING="socfpga_agilex5" +CONFIG_SPL_FS_FAT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x82000000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="earlycon panic=-1 root=${nandroot} rw rootwait
+CONFIG_LEGACY_IMAGE_FORMAT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_CRC32=y +CONFIG_SPL_CACHE=y CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_SYS_PROMPT="SOCFPGA_AGILEX5 # " +CONFIG_CMD_NVEDIT_SELECT=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=n +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_PHY=y +CONFIG_SPL_PHY=y +CONFIG_NOP_PHY=y +CONFIG_SPL_NOP_PHY=y +CONFIG_PHY_CADENCE_COMBOPHY=n +CONFIG_SPL_PHY_CADENCE_COMBOPHY=n +CONFIG_MMC=y +CONFIG_MMC_WRITE=y +# CONFIG_MMC_BROKEN_CD is not set +CONFIG_DM_MMC=y +CONFIG_SPL_DM_MMC=y +CONFIG_MMC_SDHCI_ADMA_HELPERS=y +# CONFIG_ARM_PL180_MMCI is not set +CONFIG_MMC_QUIRKS=y +CONFIG_SYS_MMC_MAX_BLK_COUNT=65535 +CONFIG_MMC_HW_PARTITIONING=y +# CONFIG_SUPPORT_EMMC_RPMB is not set #
+not set # CONFIG_MMC_IO_VOLTAGE is not set # +CONFIG_MMC_HS400_ES_SUPPORT is not set #
+is not set # CONFIG_MMC_HS200_SUPPORT is not set +CONFIG_MMC_VERBOSE=n CONFIG_MMC_TRACE=n # CONFIG_MMC_DW
is not set
+# CONFIG_MMC_MXC is not set # CONFIG_MMC_PCI is not set # +CONFIG_MMC_OMAP_HS is not set CONFIG_MMC_SDHCI=y # +CONFIG_MMC_SDHCI_SDMA is not set CONFIG_MMC_SDHCI_ADMA=y +CONFIG_SPL_MMC_SDHCI_ADMA=y # CONFIG_MMC_SDHCI_BCMSTB is
not set
+CONFIG_MMC_SDHCI_CADENCE=y CONFIG_CMD_FAT=y
+CONFIG_CMD_MTD=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_NAND_LOCK_UNLOCK=y +CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y +CONFIG_SPL_SPI_FLASH_MTD=y CONFIG_SPI_FLASH_MTD=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_MTDIDS_DEFAULT="nand0=10b80000.nand.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=10b80000.nand.0:2m(u-boot),-
(root)"
+CONFIG_CMD_UBI=y +CONFIG_CMD_UBIFS=y +CONFIG_MTD_UBI=y +CONFIG_MTD_UBI_WL_THRESHOLD=4096 +CONFIG_MTD_UBI_BEB_LIMIT=20 +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_LIST="" +CONFIG_ENV_IS_IN_UBI=y +CONFIG_ENV_UBI_PART="root" +CONFIG_ENV_UBI_VOLUME="env" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_ALTERA_SDRAM=y +CONFIG_FPGA_INTEL_PR=y +CONFIG_DWAPB_GPIO=y +CONFIG_DM_I2C=n +CONFIG_SYS_I2C_DW=n +CONFIG_MISC=y +CONFIG_MISC_INIT_R=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x0 +CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND=0x100000 +CONFIG_SF_DEFAULT_MODE=0x2003 +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_UBI_SILENCE_MSG=y +CONFIG_PHY_MARVELL=y +CONFIG_DM_ETH=y +CONFIG_DWC_ETH_XGMAC=y +CONFIG_RGMII=y +CONFIG_DM_RESET=y +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_DESIGNWARE_SPI=y +CONFIG_USB=y +CONFIG_USB_DWC2=n +CONFIG_USB_DWC3=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_UBIFS_SILENCE_MSG=y +# CONFIG_SPL_USE_TINY_PRINTF is not set CONFIG_PANIC_HANG=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_WDT=n +CONFIG_CMD_WDT=n +CONFIG_DESIGNWARE_WATCHDOG=n +CONFIG_SPL_WDT=n +CONFIG_WATCHDOG_AUTOSTART=n +CONFIG_TIMER=n +CONFIG_DESIGNWARE_APB_TIMER=n +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80300000 +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0xbff00000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x73000 +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xbfa00000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_BSS_MAX_SIZE=0x100000 +# CONFIG_EFI_LOADER is not set +CONFIG_I3C=n +CONFIG_DW_I3C_MASTER=n +CONFIG_CMD_I3C=n +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_CADENCE=y +CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_NAND_FRAMEWORK=y +CONFIG_SPL_NAND_CADENCE=y +CONFIG_SYS_MAXARGS=32
2.26.2
-- Tom
Hi Tom & Michael,
Thanks for the reference. Please expect the next version of this patch, which I will include the maintainer and #include mechanism.
Regards Dinesh
Hi
On Mon, Oct 7, 2024 at 4:23 AM Maniyam, Dinesh dinesh.maniyam@intel.com wrote:
Hi
is not set
not set
(root)"
2.26.2
-- Tom
Hi Tom & Michael,
One important point, try to run the CI in github because this allow me to review quick and appply the patches that are ok with it
Michael
Regards Dinesh
-----Original Message----- From: Michael Nazzareno Trimarchi michael@amarulasolutions.com Sent: Tuesday, 8 October 2024 1:01 am To: Maniyam, Dinesh dinesh.maniyam@intel.com Cc: Tom Rini trini@konsulko.com; u-boot@lists.denx.de; Marek marex@denx.de; Simon simon.k.r.goldschmidt@gmail.com; Dario Binacchi dario.binacchi@amarulasolutions.com; Johan Jonker jbx6244@gmail.com; Michal Simek michal.simek@amd.com; Arseniy Krasnov avkrasnov@salutedevices.com; Alexander Dahl ada@thorsis.com; William Zhang william.zhang@broadcom.com; Igor Prusov ivprusov@salutedevices.com; Chee, Tien Fong tien.fong.chee@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com; Ng, Boon Khai boon.khai.ng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Zamri, Muhammad Hazim Izzat muhammad.hazim.izzat.zamri@intel.com; Meng, Tingting tingting.meng@intel.com; Lim, Jit Loon jit.loon.lim@intel.com; Tang, Sieu Mun sieu.mun.tang@intel.com Subject: Re: [PATCH 14/19] configs: nand2_defconfig: Enable configs for nand boot
Hi
wrote:
Hi
+CONFIG_LEGACY_IMAGE_FORMAT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_CRC32=y +CONFIG_SPL_CACHE=y CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_SYS_PROMPT="SOCFPGA_AGILEX5 # " +CONFIG_CMD_NVEDIT_SELECT=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=n +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_PHY=y +CONFIG_SPL_PHY=y +CONFIG_NOP_PHY=y +CONFIG_SPL_NOP_PHY=y +CONFIG_PHY_CADENCE_COMBOPHY=n +CONFIG_SPL_PHY_CADENCE_COMBOPHY=n +CONFIG_MMC=y +CONFIG_MMC_WRITE=y +# CONFIG_MMC_BROKEN_CD is not set CONFIG_DM_MMC=y +CONFIG_SPL_DM_MMC=y CONFIG_MMC_SDHCI_ADMA_HELPERS=y # +CONFIG_ARM_PL180_MMCI is not set CONFIG_MMC_QUIRKS=y +CONFIG_SYS_MMC_MAX_BLK_COUNT=65535 +CONFIG_MMC_HW_PARTITIONING=y +# CONFIG_SUPPORT_EMMC_RPMB is not set #
CONFIG_MMC_DW
is not set
is
not set
boot),-
(root)"
+CONFIG_CMD_UBI=y +CONFIG_CMD_UBIFS=y +CONFIG_MTD_UBI=y +CONFIG_MTD_UBI_WL_THRESHOLD=4096 +CONFIG_MTD_UBI_BEB_LIMIT=20 +# CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not +set CONFIG_OF_LIST="" +CONFIG_ENV_IS_IN_UBI=y +CONFIG_ENV_UBI_PART="root" +CONFIG_ENV_UBI_VOLUME="env" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_ALTERA_SDRAM=y +CONFIG_FPGA_INTEL_PR=y +CONFIG_DWAPB_GPIO=y +CONFIG_DM_I2C=n +CONFIG_SYS_I2C_DW=n +CONFIG_MISC=y +CONFIG_MISC_INIT_R=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x0 +CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND=0x100000 +CONFIG_SF_DEFAULT_MODE=0x2003 +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_UBI_SILENCE_MSG=y +CONFIG_PHY_MARVELL=y +CONFIG_DM_ETH=y +CONFIG_DWC_ETH_XGMAC=y +CONFIG_RGMII=y +CONFIG_DM_RESET=y +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_DESIGNWARE_SPI=y +CONFIG_USB=y +CONFIG_USB_DWC2=n +CONFIG_USB_DWC3=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_UBIFS_SILENCE_MSG=y +# CONFIG_SPL_USE_TINY_PRINTF is not set CONFIG_PANIC_HANG=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_WDT=n
CONFIG_CMD_WDT=n
+CONFIG_DESIGNWARE_WATCHDOG=n CONFIG_SPL_WDT=n +CONFIG_WATCHDOG_AUTOSTART=n CONFIG_TIMER=n +CONFIG_DESIGNWARE_APB_TIMER=n +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80300000 +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0xbff00000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x73000 +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0xbfa00000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x500000 +CONFIG_SPL_BSS_MAX_SIZE=0x100000 # CONFIG_EFI_LOADER is not
set
+CONFIG_I3C=n CONFIG_DW_I3C_MASTER=n CONFIG_CMD_I3C=n +CONFIG_MTD_RAW_NAND=y CONFIG_NAND_CADENCE=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_FRAMEWORK=y +CONFIG_SPL_NAND_CADENCE=y +CONFIG_SYS_MAXARGS=32
2.26.2
-- Tom
Hi Tom & Michael,
Michael
Regards Dinesh
-- Michael Nazzareno Trimarchi Co-Founder & Chief Executive Officer M. +39 347 913 2170 michael@amarulasolutions.com __________________________________
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com www.amarulasolutions.com
Sure, will run the CI in github.
Regards Dinesh
This patch is to leverage linux code to support hardware ECC interface in verify nand bad block.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/nand_base.c | 71 +++++++++++++++++++++----------- include/linux/mtd/rawnand.h | 13 ++++++ 2 files changed, 60 insertions(+), 24 deletions(-)
diff --git a/drivers/mtd/nand/raw/nand_base.c b/drivers/mtd/nand/raw/nand_base.c index 4401bdcdb9..9b1b2d1f85 100644 --- a/drivers/mtd/nand/raw/nand_base.c +++ b/drivers/mtd/nand/raw/nand_base.c @@ -9,6 +9,8 @@ * Copyright (C) 2000 Steven J. Hill (sjhill@realitydiluted.com) * 2002-2006 Thomas Gleixner (tglx@linutronix.de) * + * Copyright (C) 2024 Intel Corporation <www.intel.com> + * * Credits: * David Woodhouse for adding multichip support * @@ -306,6 +308,35 @@ void nand_read_buf16(struct mtd_info *mtd, uint8_t *buf, int len) ioread16_rep(chip->IO_ADDR_R, p, len >> 1); }
+/* + * nand_bbm_get_next_page - Get the next page for bad block markers + * @chip: The NAND chip + * @page: First page to start checking for bad block marker usage + * + * Returns an integer that corresponds to the page offset within a block, for + * a page that is used to store bad block markers. If no more pages are + * available, -EINVAL is returned. + */ +int nand_bbm_get_next_page(struct nand_chip *chip, int page) +{ + struct mtd_info *mtd = nand_to_mtd(chip); + int last_page = ((mtd->erasesize - mtd->writesize) >> + chip->page_shift) & chip->pagemask; + unsigned int bbm_flags = NAND_BBM_FIRSTPAGE | NAND_BBM_SECONDPAGE + | NAND_BBM_LASTPAGE; + + if (page == 0 && !(chip->options & bbm_flags)) + return 0; + if (page == 0 && chip->options & NAND_BBM_FIRSTPAGE) + return 0; + if (page <= 1 && chip->options & NAND_BBM_SECONDPAGE) + return 1; + if (page <= last_page && chip->options & NAND_BBM_LASTPAGE) + return last_page; + + return -EINVAL; +} + /** * nand_block_bad - [DEFAULT] Read bad block marker from the chip * @mtd: MTD device structure @@ -315,40 +346,32 @@ void nand_read_buf16(struct mtd_info *mtd, uint8_t *buf, int len) */ static int nand_block_bad(struct mtd_info *mtd, loff_t ofs) { - int page, res = 0, i = 0; struct nand_chip *chip = mtd_to_nand(mtd); - u16 bad; + int first_page, page_offset; + int res; + u8 bad;
- if (chip->bbt_options & NAND_BBT_SCANLASTPAGE) - ofs += mtd->erasesize - mtd->writesize; + first_page = (int)(ofs >> chip->page_shift) & chip->pagemask; + page_offset = nand_bbm_get_next_page(chip, 0);
- page = (int)(ofs >> chip->page_shift) & chip->pagemask; + while (page_offset >= 0) { + res = chip->ecc.read_oob(mtd, chip, first_page + page_offset); + if (res < 0) + return res;
- do { - if (chip->options & NAND_BUSWIDTH_16) { - chip->cmdfunc(mtd, NAND_CMD_READOOB, - chip->badblockpos & 0xFE, page); - bad = cpu_to_le16(chip->read_word(mtd)); - if (chip->badblockpos & 0x1) - bad >>= 8; - else - bad &= 0xFF; - } else { - chip->cmdfunc(mtd, NAND_CMD_READOOB, chip->badblockpos, - page); - bad = chip->read_byte(mtd); - } + bad = chip->oob_poi[chip->badblockpos];
if (likely(chip->badblockbits == 8)) res = bad != 0xFF; else res = hweight8(bad) < chip->badblockbits; - ofs += mtd->writesize; - page = (int)(ofs >> chip->page_shift) & chip->pagemask; - i++; - } while (!res && i < 2 && (chip->bbt_options & NAND_BBT_SCAN2NDPAGE)); + if (res) + return res;
- return res; + page_offset = nand_bbm_get_next_page(chip, page_offset + 1); + } + + return 0; }
/** diff --git a/include/linux/mtd/rawnand.h b/include/linux/mtd/rawnand.h index 537c62424a..49444e9353 100644 --- a/include/linux/mtd/rawnand.h +++ b/include/linux/mtd/rawnand.h @@ -4,6 +4,8 @@ * Steven J. Hill sjhill@realitydiluted.com * Thomas Gleixner tglx@linutronix.de * + * Copyright (C) 2024 Intel Corporation <www.intel.com> + * * Info: * Contains standard defines and IDs for NAND flash devices * @@ -131,6 +133,17 @@ void nand_wait_ready(struct mtd_info *mtd);
#define NAND_DATA_IFACE_CHECK_ONLY -1
+/* + * There are different places where the manufacturer stores the factory bad + * block markers. + * + * Position within the block: Each of these pages needs to be checked for a + * bad block marking pattern. + */ +#define NAND_BBM_FIRSTPAGE BIT(24) +#define NAND_BBM_SECONDPAGE BIT(25) +#define NAND_BBM_LASTPAGE BIT(26) + /* * Constants for ECC_MODES */
This patch is add support for spl nand to load binary image from NAND to RAM.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/cadence_spl.c | 96 ++++++++++++++++++++++++++++++ 1 file changed, 96 insertions(+) create mode 100644 drivers/mtd/nand/raw/cadence_spl.c
diff --git a/drivers/mtd/nand/raw/cadence_spl.c b/drivers/mtd/nand/raw/cadence_spl.c new file mode 100644 index 0000000000..841801420d --- /dev/null +++ b/drivers/mtd/nand/raw/cadence_spl.c @@ -0,0 +1,96 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#include <cadence-nand.h> +#include <dm.h> +#include <hang.h> +#include <malloc.h> +#include <memalign.h> +#include <nand.h> +#include <linux/bitfield.h> + +int nand_spl_load_image(u32 offset, u32 len, void *dst) +{ + size_t count = len, actual = 0, page_align_overhead = 0; + u32 page_align_offset = 0; + u8 *page_buffer; + int err = 0; + struct mtd_info *mtd; + + if (!len || !dst) + return -EINVAL; + + mtd = get_nand_dev_by_index(nand_curr_device); + if (!mtd) + hang(); + + if ((offset & (mtd->writesize - 1)) != 0) { + page_buffer = malloc_cache_aligned(mtd->writesize); + if (!page_buffer) { + debug("Error: allocating buffer\n"); + return -ENOMEM; + } + + page_align_overhead = offset % mtd->writesize; + page_align_offset = (offset / mtd->writesize) * mtd->writesize; + count = mtd->writesize; + + err = nand_read_skip_bad(mtd, page_align_offset, &count, + &actual, mtd->size, page_buffer); + + if (err) { + free(page_buffer); + return err; + } + + count -= page_align_overhead; + count = min((size_t)len, count); + memcpy(dst, page_buffer + page_align_overhead, count); + free(page_buffer); + + len -= count; + if (!len) + return err; + + offset += count; + dst += count; + count = len; + } + + return nand_read_skip_bad(mtd, offset, &count, &actual, mtd->size, dst); +} + +/* + * The offset at which the image to be loaded from NAND is located is + * retrieved from the itb header. The presence of bad blocks in the area + * of the NAND where the itb image is located could invalidate the offset + * which must therefore be adjusted taking into account the state of the + * sectors concerned + */ +u32 nand_spl_adjust_offset(u32 sector, u32 offs) +{ + u32 sector_align_offset, sector_align_end_offset; + struct mtd_info *mtd; + + mtd = get_nand_dev_by_index(nand_curr_device); + if (!mtd) + hang(); + + sector_align_offset = sector & (~(mtd->erasesize - 1)); + + sector_align_end_offset = (sector + offs) & (~(mtd->erasesize - 1)); + + while (sector_align_offset <= sector_align_end_offset) { + if (nand_block_isbad(mtd, sector_align_offset)) { + offs += mtd->erasesize; + sector_align_end_offset += mtd->erasesize; + } + sector_align_offset += mtd->erasesize; + } + + return offs; +} + +void nand_deselect(void) {}
Hi Dinesh
- Copyright (C) 2024 Intel Corporation <www.intel.com>
u8 *page_buffer;
int err = 0;
if (!len || !dst)
return -EINVAL;
if (!mtd)
hang();
if (!page_buffer) {
return -ENOMEM;
if (err) {
free(page_buffer);
return err;
free(page_buffer);
len -= count;
if (!len)
return err;
offset += count;
dst += count;
count = len;
We should rethink that way we have nand_spl_load_image and create a way to unify more SoC
- The offset at which the image to be loaded from NAND is located is
- retrieved from the itb header. The presence of bad blocks in the area
- of the NAND where the itb image is located could invalidate the offset
- which must therefore be adjusted taking into account the state of the
- sectors concerned
if (!mtd)
hang();
return offs;
Here the same
Michael
2.26.2
-----Original Message----- From: Michael Nazzareno Trimarchi michael@amarulasolutions.com Sent: Saturday, 5 October 2024 11:23 pm To: Maniyam, Dinesh dinesh.maniyam@intel.com Cc: u-boot@lists.denx.de; Marek marex@denx.de; Simon simon.k.r.goldschmidt@gmail.com; Tom Rini trini@konsulko.com; Dario Binacchi dario.binacchi@amarulasolutions.com; Johan Jonker jbx6244@gmail.com; Michal Simek michal.simek@amd.com; Arseniy Krasnov avkrasnov@salutedevices.com; Alexander Dahl ada@thorsis.com; William Zhang william.zhang@broadcom.com; Igor Prusov ivprusov@salutedevices.com; Chee, Tien Fong tien.fong.chee@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com; Ng, Boon Khai boon.khai.ng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Teik Heng teik.heng.chong@intel.com; Zamri, Muhammad Hazim Izzat muhammad.hazim.izzat.zamri@intel.com; Meng, Tingting tingting.meng@intel.com; Lim, Jit Loon jit.loon.lim@intel.com; Tang, Sieu Mun sieu.mun.tang@intel.com Subject: Re: [PATCH 16/19] drivers: mtd: nand: spl: Add support for nand SPL load image
Hi Dinesh
- Copyright (C) 2024 Intel Corporation <www.intel.com> */
+int nand_spl_load_image(u32 offset, u32 len, void *dst) {
u8 *page_buffer;
int err = 0;
if (!len || !dst)
return -EINVAL;
if (!mtd)
hang();
if (!page_buffer) {
return -ENOMEM;
&actual, mtd->size,
- page_buffer);
if (err) {
free(page_buffer);
return err;
free(page_buffer);
len -= count;
if (!len)
return err;
offset += count;
dst += count;
count = len;
+mtd->size, dst); }
+area
+offset
+the
- sectors concerned
+u32 nand_spl_adjust_offset(u32 sector, u32 offs) {
if (!mtd)
hang();
- 1));
return offs;
Here the same
Michael
2.26.2
I agree with your point. I will leverage the existing nand_spl_load_image to corporate with this new Cadence Nand driver.
Thanks Dinesh
This patch is to enable the Kconfig and Makefile for the Cadence-Nand SPL support in agilex5 family device.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/Kconfig | 7 +++++++ drivers/mtd/nand/raw/Makefile | 1 + 2 files changed, 8 insertions(+)
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 709c85c6e5..a9515c7b74 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -801,6 +801,13 @@ config SPL_NAND_AM33XX_BCH so those platforms should use CONFIG_SPL_NAND_SIMPLE for enabling SPL-NAND driver with software ECC correction support.
+config SPL_NAND_CADENCE + bool "Support Cadence NAND controller for SPL" + depends on SPL_NAND_SUPPORT + help + This is a small implementation of the Cadence NAND controller + for use on SPL. + config SPL_NAND_DENALI bool "Support Denali NAND controller for SPL" depends on SPL_NAND_SUPPORT diff --git a/drivers/mtd/nand/raw/Makefile b/drivers/mtd/nand/raw/Makefile index 4ad1a2037f..58fde3272f 100644 --- a/drivers/mtd/nand/raw/Makefile +++ b/drivers/mtd/nand/raw/Makefile @@ -10,6 +10,7 @@ NORMAL_DRIVERS=y endif
obj-$(CONFIG_SPL_NAND_AM33XX_BCH) += am335x_spl_bch.o +obj-$(CONFIG_SPL_NAND_CADENCE) += cadence_spl.o obj-$(CONFIG_SPL_NAND_DENALI) += denali_spl.o obj-$(CONFIG_SPL_NAND_SIMPLE) += nand_spl_simple.o obj-$(CONFIG_SPL_NAND_LOAD) += nand_spl_load.o
This patch is to remove SYS_NAND_BLOCK_SIZE dependency for cadence NAND. This config is not needed as the driver will send command read parameter page to identify the NAND block size during initialization.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index a9515c7b74..90f8f4b688 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -680,7 +680,7 @@ config SYS_NAND_BLOCK_SIZE depends on ARCH_SUNXI || SPL_NAND_SUPPORT || TPL_NAND_SUPPORT || \ MVEBU_SPL_BOOT_DEVICE_NAND depends on !NAND_MXS && !NAND_DENALI_DT && !NAND_LPC32XX_MLC && \ - !NAND_FSL_IFC && !NAND_MT7621 + !NAND_FSL_IFC && !NAND_MT7621 && !NAND_CADENCE help Number of data bytes in one eraseblock for the NAND chip on the board. This is the multiple of NAND_PAGE_SIZE and the number of
This patch is to enable SPL_SYS_NAND_SELF_INIT for Cadence NAND SPL.
Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- drivers/mtd/nand/raw/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 90f8f4b688..32444c2468 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -211,6 +211,7 @@ config NAND_CADENCE bool "Support Cadence NAND controller as a DT device" depends on OF_CONTROL && DM_MTD select SYS_NAND_SELF_INIT + select SPL_SYS_NAND_SELF_INIT imply CMD_NAND help Enable the driver for NAND flash on platforms using a Cadence NAND
Hello Dinesh,
Am Thu, Sep 19, 2024 at 11:54:53AM +0800 schrieb dinesh.maniyam@intel.com:
This patchset add Cadence NAND driver support for Intel Agilex5 devices.
The NAND driver is leveraged from the cadence-nand-controller.c from Linux. U-Boot will support read, write and erase NAND with Cadence driver. The driver further enhanced in U-Boot to support NAND booting from FSBL and support boot to kernel via UBIFS.
Could you please add to your U-Boot commit messages the exact Linux version you used for porting? This makes it easier in the future to re-import Linux bindings, dts, and driver updates to U-Boot.
Also avoid phrases like "This patch is to" in commit messages, this adds redundancy for no reason.
Greets Alex
Dinesh Maniyam (19): dt: nand: add cadence nand dt-bindings arm: dts: agilex5: Enabled cdns-nand dts setting include: asm: Add support to read/write 64-bit drivers: mtd: nand: Add driver for Cadence Nand drivers: mtd: nand: cadence: Add support for read status command drivers: mtd: nand: cadence: Add support for readid command drivers: mtd: nand: cadence: Add support for NAND_CMD_PARAM drivers: mtd: nand: cadence: Support NAND_CMD_RESET drivers: mtd: nand: cadence: Support cmd SET_FEATURES & GET_FEATURES drivers: mtd: nand: cadence: Flush dma descriptor drivers: mtd: nand: cadence: Poll for desc complete status drivers: mtd: nand: cadence: Use bounce buffer drivers: nand: Enabled Kconfig and Makefile for cdns-nand configs: nand2_defconfig: Enable configs for nand boot drivers: mtd: nand: base: Add support for Hardware ECC for check bad block drivers: mtd: nand: spl: Add support for nand SPL load image drivers: mtd: nand: Enabled Kconfig and Makefile for Cadence-SPL drivers: mtd: nand: Kconfig: Remove SYS_NAND_BLOCK_SIZE dependency drivers: mtd: nand: Kconfig: Enabled self-init for cdns-nand SPL
arch/arm/dts/socfpga_agilex5.dtsi | 14 + .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 28 + arch/arm/include/asm/io.h | 25 + configs/socfpga_agilex5_nand2_defconfig | 169 ++ .../mtd/cadence,nand.yaml | 98 + drivers/mtd/nand/raw/Kconfig | 19 +- drivers/mtd/nand/raw/Makefile | 2 + drivers/mtd/nand/raw/cadence_nand.c | 2386 +++++++++++++++++ drivers/mtd/nand/raw/cadence_spl.c | 96 + drivers/mtd/nand/raw/nand_base.c | 71 +- include/cadence-nand.h | 528 ++++ include/linux/mtd/rawnand.h | 13 + 12 files changed, 3424 insertions(+), 25 deletions(-) create mode 100644 configs/socfpga_agilex5_nand2_defconfig create mode 100644 doc/device-tree-bindings/mtd/cadence,nand.yaml create mode 100644 drivers/mtd/nand/raw/cadence_nand.c create mode 100644 drivers/mtd/nand/raw/cadence_spl.c create mode 100644 include/cadence-nand.h
-- 2.26.2
-----Original Message----- From: Alexander Dahl ada@thorsis.com Sent: Thursday, 19 September 2024 2:06 pm To: Maniyam, Dinesh dinesh.maniyam@intel.com Cc: u-boot@lists.denx.de; Marek marex@denx.de; Simon simon.k.r.goldschmidt@gmail.com; Tom Rini trini@konsulko.com; Dario Binacchi dario.binacchi@amarulasolutions.com; Michael Trimarchi michael@amarulasolutions.com; Johan Jonker jbx6244@gmail.com; Michal Simek michal.simek@amd.com; Arseniy Krasnov avkrasnov@salutedevices.com; Alexander Dahl ada@thorsis.com; William Zhang william.zhang@broadcom.com; Igor Prusov ivprusov@salutedevices.com; Chee, Tien Fong tien.fong.chee@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com; Ng, Boon Khai boon.khai.ng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Teik Heng teik.heng.chong@intel.com; Zamri, Muhammad Hazim Izzat muhammad.hazim.izzat.zamri@intel.com; Meng, Tingting tingting.meng@intel.com; Lim, Jit Loon jit.loon.lim@intel.com; Tang, Sieu Mun sieu.mun.tang@intel.com Subject: Re: [PATCH 00/19] Add Cadence NAND Driver support
Hello Dinesh,
Greets Alex
-- 2.26.2
Hi Alexander,
The patch I leverage is from the path /drivers/mtd/nand/raw/cadence-nand-controller.c from the stable version 6.11.2 Please expect the next version of this patch, in which I will remove the "this patch is to" commit phrases and minor refactoring of code to match the stable version 6.11.2.
Thanks Dinesh
participants (5)
Alexander Dahl
Maniyam, Dinesh
