[U-Boot] [PATCH v3 1/2] eth: asix88179: Prepare supporting the driver model
Change the prototype of a few functions to allow resuing the code for the driver model.
Signed-off-by: Alban Bedel alban.bedel@avionic-design.de --- Changelog: v3: * Don't break the build without driver model --- drivers/usb/eth/asix88179.c | 75 ++++++++++++++++++++++++++++----------------- 1 file changed, 47 insertions(+), 28 deletions(-)
diff --git a/drivers/usb/eth/asix88179.c b/drivers/usb/eth/asix88179.c index 81eae04e3402..f3179bcf1e2e 100644 --- a/drivers/usb/eth/asix88179.c +++ b/drivers/usb/eth/asix88179.c @@ -259,36 +259,32 @@ static int asix_read_cmd(struct ueth_data *dev, u8 cmd, u16 value, u16 index, return len == size ? 0 : ECOMM; }
-static int asix_read_mac(struct eth_device *eth) +static int asix_read_mac(struct ueth_data *dev, uint8_t *enetaddr) { - struct ueth_data *dev = (struct ueth_data *)eth->priv; - u8 buf[ETH_ALEN]; + int ret;
- asix_read_cmd(dev, AX_ACCESS_MAC, AX_NODE_ID, 6, 6, buf); - debug("asix_read_mac() returning %02x:%02x:%02x:%02x:%02x:%02x\n", - buf[0], buf[1], buf[2], buf[3], buf[4], buf[5]); + ret = asix_read_cmd(dev, AX_ACCESS_MAC, AX_NODE_ID, 6, 6, enetaddr); + if (ret < 0) + debug("Failed to read MAC address: %02x\n", ret);
- memcpy(eth->enetaddr, buf, ETH_ALEN); - - return 0; + return ret; }
-static int asix_write_mac(struct eth_device *eth) +static int asix_write_mac(struct ueth_data *dev, uint8_t *enetaddr) { - struct ueth_data *dev = (struct ueth_data *)eth->priv; int ret;
ret = asix_write_cmd(dev, AX_ACCESS_MAC, AX_NODE_ID, ETH_ALEN, - ETH_ALEN, eth->enetaddr); + ETH_ALEN, enetaddr); if (ret < 0) debug("Failed to set MAC address: %02x\n", ret);
return ret; }
-static int asix_basic_reset(struct ueth_data *dev) +static int asix_basic_reset(struct ueth_data *dev, + struct asix_private *dev_priv) { - struct asix_private *dev_priv = (struct asix_private *)dev->dev_priv; u8 buf[5]; u16 *tmp16; u8 *tmp; @@ -387,13 +383,9 @@ static int asix_wait_link(struct ueth_data *dev) } }
-/* - * Asix callbacks - */ -static int asix_init(struct eth_device *eth, bd_t *bd) +static int asix_init_common(struct ueth_data *dev, + struct asix_private *dev_priv) { - struct ueth_data *dev = (struct ueth_data *)eth->priv; - struct asix_private *dev_priv = (struct asix_private *)dev->dev_priv; u8 buf[2], tmp[5], link_sts; u16 *tmp16, mode;
@@ -411,7 +403,7 @@ static int asix_init(struct eth_device *eth, bd_t *bd) if (asix_wait_link(dev) != 0) { /*reset device and try again*/ printf("Reset Ethernet Device\n"); - asix_basic_reset(dev); + asix_basic_reset(dev, dev_priv); if (asix_wait_link(dev) != 0) goto out_err; } @@ -463,11 +455,10 @@ out_err: return -1; }
-static int asix_send(struct eth_device *eth, void *packet, int length) +static int asix_send_common(struct ueth_data *dev, + struct asix_private *dev_priv, + void *packet, int length) { - struct ueth_data *dev = (struct ueth_data *)eth->priv; - struct asix_private *dev_priv = (struct asix_private *)dev->dev_priv; - int err; u32 packet_len, tx_hdr2; int actual_len, framesize; @@ -504,6 +495,32 @@ static int asix_send(struct eth_device *eth, void *packet, int length) return err; }
+/* + * Asix callbacks + */ +static int asix_init(struct eth_device *eth, bd_t *bd) +{ + struct ueth_data *dev = (struct ueth_data *)eth->priv; + struct asix_private *dev_priv = (struct asix_private *)dev->dev_priv; + + return asix_init_common(dev, dev_priv); +} + +static int asix_write_hwaddr(struct eth_device *eth) +{ + struct ueth_data *dev = (struct ueth_data *)eth->priv; + + return asix_write_mac(dev, eth->enetaddr); +} + +static int asix_send(struct eth_device *eth, void *packet, int length) +{ + struct ueth_data *dev = (struct ueth_data *)eth->priv; + struct asix_private *dev_priv = (struct asix_private *)dev->dev_priv; + + return asix_send_common(dev, dev_priv, packet, length); +} + static int asix_recv(struct eth_device *eth) { struct ueth_data *dev = (struct ueth_data *)eth->priv; @@ -693,6 +710,8 @@ int ax88179_eth_probe(struct usb_device *dev, unsigned int ifnum, int ax88179_eth_get_info(struct usb_device *dev, struct ueth_data *ss, struct eth_device *eth) { + struct asix_private *dev_priv = (struct asix_private *)ss->dev_priv; + if (!eth) { debug("%s: missing parameter.\n", __func__); return 0; @@ -702,14 +721,14 @@ int ax88179_eth_get_info(struct usb_device *dev, struct ueth_data *ss, eth->send = asix_send; eth->recv = asix_recv; eth->halt = asix_halt; - eth->write_hwaddr = asix_write_mac; + eth->write_hwaddr = asix_write_hwaddr; eth->priv = ss;
- if (asix_basic_reset(ss)) + if (asix_basic_reset(ss, dev_priv)) return 0;
/* Get the MAC address */ - if (asix_read_mac(eth)) + if (asix_read_mac(ss, eth->enetaddr)) return 0; debug("MAC %pM\n", eth->enetaddr);
Adjust this driver to support driver model for Ethernet.
Signed-off-by: Alban Bedel alban.bedel@avionic-design.de --- drivers/usb/eth/asix88179.c | 184 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 184 insertions(+)
diff --git a/drivers/usb/eth/asix88179.c b/drivers/usb/eth/asix88179.c index f3179bcf1e2e..7548269f958a 100644 --- a/drivers/usb/eth/asix88179.c +++ b/drivers/usb/eth/asix88179.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <dm.h> #include <usb.h> #include <net.h> #include <linux/mii.h> @@ -197,10 +198,18 @@ static const struct { {7, 0xcc, 0x4c, 0x04, 8}, };
+#ifndef CONFIG_DM_ETH static int curr_eth_dev; /* index for name of next device detected */ +#endif
/* driver private */ struct asix_private { +#ifdef CONFIG_DM_ETH + struct ueth_data ueth; + unsigned pkt_cnt; + uint8_t *pkt_data; + uint32_t *pkt_hdr; +#endif int flags; int rx_urb_size; int maxpacketsize; @@ -495,6 +504,7 @@ static int asix_send_common(struct ueth_data *dev, return err; }
+#ifndef CONFIG_DM_ETH /* * Asix callbacks */ @@ -734,3 +744,177 @@ int ax88179_eth_get_info(struct usb_device *dev, struct ueth_data *ss,
return 1; } + +#else /* !CONFIG_DM_ETH */ + +static int ax88179_eth_start(struct udevice *dev) +{ + struct asix_private *priv = dev_get_priv(dev); + + return asix_init_common(&priv->ueth, priv); +} + +void ax88179_eth_stop(struct udevice *dev) +{ + struct asix_private *priv = dev_get_priv(dev); + struct ueth_data *ueth = &priv->ueth; + + debug("** %s()\n", __func__); + + usb_ether_advance_rxbuf(ueth, -1); + priv->pkt_cnt = 0; + priv->pkt_data = NULL; + priv->pkt_hdr = NULL; +} + +int ax88179_eth_send(struct udevice *dev, void *packet, int length) +{ + struct asix_private *priv = dev_get_priv(dev); + + return asix_send_common(&priv->ueth, priv, packet, length); +} + +int ax88179_eth_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct asix_private *priv = dev_get_priv(dev); + struct ueth_data *ueth = &priv->ueth; + int ret, len; + u16 pkt_len; + + /* No packet left, get a new one */ + if (priv->pkt_cnt == 0) { + uint8_t *ptr; + u16 pkt_cnt; + u16 hdr_off; + u32 rx_hdr; + + len = usb_ether_get_rx_bytes(ueth, &ptr); + debug("%s: first try, len=%d\n", __func__, len); + if (!len) { + if (!(flags & ETH_RECV_CHECK_DEVICE)) + return -EAGAIN; + + ret = usb_ether_receive(ueth, priv->rx_urb_size); + if (ret < 0) + return ret; + + len = usb_ether_get_rx_bytes(ueth, &ptr); + debug("%s: second try, len=%d\n", __func__, len); + } + + if (len < 4) { + usb_ether_advance_rxbuf(ueth, -1); + return -EMSGSIZE; + } + + rx_hdr = *(u32 *)(ptr + len - 4); + le32_to_cpus(&rx_hdr); + + pkt_cnt = (u16)rx_hdr; + if (pkt_cnt == 0) { + usb_ether_advance_rxbuf(ueth, -1); + return 0; + } + + hdr_off = (u16)(rx_hdr >> 16); + if (hdr_off > len - 4) { + usb_ether_advance_rxbuf(ueth, -1); + return -EIO; + } + + priv->pkt_cnt = pkt_cnt; + priv->pkt_data = ptr; + priv->pkt_hdr = (u32 *)(ptr + hdr_off); + debug("%s: %d packets received, pkt header at %d\n", + __func__, (int)priv->pkt_cnt, (int)hdr_off); + } + + le32_to_cpus(priv->pkt_hdr); + pkt_len = (*priv->pkt_hdr >> 16) & 0x1fff; + + *packetp = priv->pkt_data + 2; + + priv->pkt_data += (pkt_len + 7) & 0xFFF8; + priv->pkt_cnt--; + priv->pkt_hdr++; + + debug("%s: return packet of %d bytes (%d packets left)\n", + __func__, (int)pkt_len, priv->pkt_cnt); + return pkt_len; +} + +static int ax88179_free_pkt(struct udevice *dev, uchar *packet, int packet_len) +{ + struct asix_private *priv = dev_get_priv(dev); + struct ueth_data *ueth = &priv->ueth; + + if (priv->pkt_cnt == 0) + usb_ether_advance_rxbuf(ueth, -1); + + return 0; +} + +int ax88179_write_hwaddr(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct asix_private *priv = dev_get_priv(dev); + struct ueth_data *ueth = &priv->ueth; + + return asix_write_mac(ueth, pdata->enetaddr); +} + +static int ax88179_eth_probe(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct asix_private *priv = dev_get_priv(dev); + struct usb_device *usb_dev; + int ret; + + priv->flags = dev->driver_data; + ret = usb_ether_register(dev, &priv->ueth, AX_RX_URB_SIZE); + if (ret) + return ret; + + usb_dev = priv->ueth.pusb_dev; + priv->maxpacketsize = usb_dev->epmaxpacketout[AX_ENDPOINT_OUT]; + + /* Get the MAC address */ + ret = asix_read_mac(&priv->ueth, pdata->enetaddr); + if (ret) + return ret; + debug("MAC %pM\n", pdata->enetaddr); + + return 0; +} + +static const struct eth_ops ax88179_eth_ops = { + .start = ax88179_eth_start, + .send = ax88179_eth_send, + .recv = ax88179_eth_recv, + .free_pkt = ax88179_free_pkt, + .stop = ax88179_eth_stop, + .write_hwaddr = ax88179_write_hwaddr, +}; + +U_BOOT_DRIVER(ax88179_eth) = { + .name = "ax88179_eth", + .id = UCLASS_ETH, + .probe = ax88179_eth_probe, + .ops = &ax88179_eth_ops, + .priv_auto_alloc_size = sizeof(struct asix_private), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; + +static const struct usb_device_id ax88179_eth_id_table[] = { + { USB_DEVICE(0x0b95, 0x1790), .driver_info = FLAG_TYPE_AX88179 }, + { USB_DEVICE(0x0b95, 0x178a), .driver_info = FLAG_TYPE_AX88178a }, + { USB_DEVICE(0x2001, 0x4a00), .driver_info = FLAG_TYPE_DLINK_DUB1312 }, + { USB_DEVICE(0x0df6, 0x0072), .driver_info = FLAG_TYPE_SITECOM }, + { USB_DEVICE(0x04e8, 0xa100), .driver_info = FLAG_TYPE_SAMSUNG }, + { USB_DEVICE(0x17ef, 0x304b), .driver_info = FLAG_TYPE_LENOVO }, + { USB_DEVICE(0x04b4, 0x3610), .driver_info = FLAG_TYPE_GX3 }, + { } /* Terminating entry */ +}; + +U_BOOT_USB_DEVICE(ax88179_eth, ax88179_eth_id_table); +#endif /* !CONFIG_DM_ETH */
Applied, thanks.
Applied, thanks.
Alban Bedel
