[U-Boot] Please pull from u-boot-i2c
Hello Tom,
please pull from u-boot-i2c master
The following changes since commit 61608f395e7dcb2be6060407a72a1149b046430a:
Merge branch '2020-07-08-misc-features-and-fixes' (2020-07-08 20:20:24 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-i2c.git tags/for-v2020.10
for you to fetch changes up to 7239a610b796b0bb8f85c5c21798596c2768cb50:
pwm: Add PWM driver for SiFive SoC (2020-07-09 06:03:12 +0200)
---------------------------------------------------------------- i2c changes for v2020.10 - Add support for I2C controllers found on Octeon II/III and Octeon TX TX2 SoC platforms. - Add I2C controller support for Cortina Access CAxxxx SoCs - new rtc methods, rtc command, and tests - imx_lpi2c: Improve the codes to use private data - stm32f7_i2c.c: Add new compatible "st,stm32mp15-i2c" - stm32f7_i2c.c: Add Fast Mode Plus support - pwm: Add PWM driver for SiFive SoC
---------------------------------------------------------------- Alex Nemirovsky (1): board: presidio-asic: Add I2C support
Arthur Li (1): i2c: i2c-cortina: added CAxxxx I2C support
Patrick Delaunay (2): i2c: stm32f7: add stm32mp15 compatible i2c: stm32f7: SYSCFG Fast Mode Plus support for I2C STM32F7
Rasmus Villemoes (11): rtc: add dm_rtc_read helper and ->read method rtc: add dm_rtc_write() helper rtc: fall back to ->{read, write} if ->{read, write}8 are not provided rtc: pcf2127: provide ->read method rtc: pcf2127: provide ->write method rtc: add rtc command rtc: sandbox-rtc: fix set method rtc: i2c_rtc_emul: catch any write to the "reset" register test: dm: rtc: add test of dm_rtc_read, dm_rtc_write sandbox: add rtc command to defconfigs test: dm: rtc: add tests of rtc shell command
Suneel Garapati (1): i2c: octeon_i2c: Add I2C controller driver for Octeon
Yash Shah (2): pwm: Add DT documentation for SiFive PWM Controller pwm: Add PWM driver for SiFive SoC
Ye Li (1): i2c: imx_lpi2c: Improve the codes to use private data
MAINTAINERS | 4 + arch/sandbox/include/asm/rtc.h | 5 + cmd/Kconfig | 6 + cmd/Makefile | 1 + cmd/rtc.c | 167 +++++++++++++++++++++++ configs/cortina_presidio-asic-emmc_defconfig | 3 + configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + doc/device-tree-bindings/i2c/i2c-cortina.txt | 18 +++ doc/device-tree-bindings/i2c/octeon-i2c.txt | 24 ++++ doc/device-tree-bindings/pwm/pwm-sifive.txt | 31 +++++ drivers/i2c/Kconfig | 18 +++ drivers/i2c/Makefile | 2 + drivers/i2c/i2c-cortina.c | 347 ++++++++++++++++++++++++++++++++++++++++++++++++ drivers/i2c/i2c-cortina.h | 87 ++++++++++++ drivers/i2c/imx_lpi2c.c | 22 ++-- drivers/i2c/octeon_i2c.c | 847 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/i2c/stm32f7_i2c.c | 73 ++++++++++ drivers/pwm/Kconfig | 6 + drivers/pwm/Makefile | 1 + drivers/pwm/pwm-sifive.c | 172 ++++++++++++++++++++++++ drivers/rtc/i2c_rtc_emul.c | 3 +- drivers/rtc/pcf2127.c | 13 +- drivers/rtc/rtc-uclass.c | 59 ++++++++- drivers/rtc/sandbox_rtc.c | 65 ++++----- include/rtc.h | 47 +++++++ test/dm/rtc.c | 118 ++++++++++++++++- 28 files changed, 2081 insertions(+), 61 deletions(-) create mode 100644 cmd/rtc.c create mode 100644 doc/device-tree-bindings/i2c/i2c-cortina.txt create mode 100644 doc/device-tree-bindings/i2c/octeon-i2c.txt create mode 100644 doc/device-tree-bindings/pwm/pwm-sifive.txt create mode 100644 drivers/i2c/i2c-cortina.c create mode 100644 drivers/i2c/i2c-cortina.h create mode 100644 drivers/i2c/octeon_i2c.c create mode 100644 drivers/pwm/pwm-sifive.c
travis build:
https://travis-ci.org/github/hsdenx/u-boot-i2c/builds/706396477
bye, Heiko
On Thu, Jul 09, 2020 at 10:41:00AM +0200, Heiko Schocher wrote:
Hello Tom,
Heiko Schocher
