[U-Boot] [PATCH 1/2] tools: imx8mimage: add SOC_TYPE
Add SOC_TYPE for i.MX8MN usage. i.MX8MN ivt_offset needs to be 0, and for flexspi, the rom_image_offset needs to be 4KB.
Signed-off-by: Peng Fan peng.fan@nxp.com --- include/imximage.h | 1 + tools/imx8mimage.c | 20 ++++++++++++++++++-- 2 files changed, 19 insertions(+), 2 deletions(-)
diff --git a/include/imximage.h b/include/imximage.h index 544babb53a..e8cc993f2b 100644 --- a/include/imximage.h +++ b/include/imximage.h @@ -79,6 +79,7 @@ enum imximage_cmd { CMD_LOADER, CMD_SECOND_LOADER, CMD_DDR_FW, + CMD_SOC_TYPE, };
enum imximage_fld_types { diff --git a/tools/imx8mimage.c b/tools/imx8mimage.c index 6c02337698..463bbb71a6 100644 --- a/tools/imx8mimage.c +++ b/tools/imx8mimage.c @@ -21,6 +21,10 @@ static uint32_t sld_header_off; static uint32_t ivt_offset; static uint32_t using_fit;
+#define ROM_V1 1 /* V1 ROM for i.MX8MQ/MM */ +#define ROM_V2 2 /* V2 ROM for iMX8MN */ +static uint32_t version = ROM_V1; + #define CSF_SIZE 0x2000 #define HDMI_IVT_ID 0 #define IMAGE_IVT_ID 1 @@ -71,6 +75,7 @@ static table_entry_t imx8mimage_cmds[] = { {CMD_LOADER, "LOADER", "loader image", }, {CMD_SECOND_LOADER, "SECOND_LOADER", "2nd loader image", }, {CMD_DDR_FW, "DDR_FW", "ddr firmware", }, + {CMD_SOC_TYPE, "SOC_TYPE", "soc type", }, {-1, "", "", }, };
@@ -90,6 +95,15 @@ static void parse_cfg_cmd(int32_t cmd, char *token, char *name, int lineno) token); if (!strncmp(token, "sd", 2)) rom_image_offset = 0x8000; + if (version == ROM_V2) { + ivt_offset = 0; + if (!strncmp(token, "fspi", 4)) + rom_image_offset = 0x1000; + } + break; + case CMD_SOC_TYPE: + if (!strncmp(token, "IMX8MN", 6)) + version = ROM_V2; break; case CMD_LOADER: ap_img = token; @@ -491,8 +505,10 @@ void build_image(int ofd) * Record the second bootloader relative offset in * image's IVT reserved1 */ - imx_header[IMAGE_IVT_ID].fhdr.reserved1 = - sld_header_off - header_image_off; + if (version == ROM_V1) { + imx_header[IMAGE_IVT_ID].fhdr.reserved1 = + sld_header_off - header_image_off; + } sld_fd = open(sld_img, O_RDONLY | O_BINARY); if (sld_fd < 0) { fprintf(stderr, "%s: Can't open: %s\n",
Add SECOND_LOADER_IVT to support generate FIT image with IVT embedded. In android case, we need dual boot loader, with one SPL image support Dual U-Boot proper. In our case, we need dual u-boot.itb with ivt embedded for secure boot.
When SECOND_LOADER_IVT included in cfg file, not add SECOND_LOADER. The example is: SECOND_LOADER_IVT u-boot.itb 0x40200000 0x0
Signed-off-by: Peng Fan peng.fan@nxp.com --- include/imximage.h | 1 + tools/imx8mimage.c | 42 +++++++++++++++++++++++++++++++++++++++--- 2 files changed, 40 insertions(+), 3 deletions(-)
diff --git a/include/imximage.h b/include/imximage.h index e8cc993f2b..a9c72f622e 100644 --- a/include/imximage.h +++ b/include/imximage.h @@ -80,6 +80,7 @@ enum imximage_cmd { CMD_SECOND_LOADER, CMD_DDR_FW, CMD_SOC_TYPE, + CMD_SECOND_LOADER_IVT, };
enum imximage_fld_types { diff --git a/tools/imx8mimage.c b/tools/imx8mimage.c index 463bbb71a6..7a7037c972 100644 --- a/tools/imx8mimage.c +++ b/tools/imx8mimage.c @@ -12,7 +12,7 @@ #include "compiler.h"
static uint32_t ap_start_addr, sld_start_addr, sld_src_off; -static char *ap_img, *sld_img, *signed_hdmi; +static char *ap_img, *sld_img, *signed_hdmi, sld_img_ivt[128]; static imx_header_v3_t imx_header[2]; /* At most there are 3 IVT headers */ static uint32_t rom_image_offset; static uint32_t sector_size = 0x200; @@ -20,6 +20,8 @@ static uint32_t image_off; static uint32_t sld_header_off; static uint32_t ivt_offset; static uint32_t using_fit; +static bool gen_fit_ivt; +static int sld_img_ivt_ofd;
#define ROM_V1 1 /* V1 ROM for i.MX8MQ/MM */ #define ROM_V2 2 /* V2 ROM for iMX8MN */ @@ -74,6 +76,7 @@ static table_entry_t imx8mimage_cmds[] = { {CMD_SIGNED_HDMI, "SIGNED_HDMI", "signed hdmi image", }, {CMD_LOADER, "LOADER", "loader image", }, {CMD_SECOND_LOADER, "SECOND_LOADER", "2nd loader image", }, + {CMD_SECOND_LOADER_IVT, "SECOND_LOADER_IVT", "2nd loader image", }, {CMD_DDR_FW, "DDR_FW", "ddr firmware", }, {CMD_SOC_TYPE, "SOC_TYPE", "soc type", }, {-1, "", "", }, @@ -111,6 +114,13 @@ static void parse_cfg_cmd(int32_t cmd, char *token, char *name, int lineno) case CMD_SECOND_LOADER: sld_img = token; break; + case CMD_SECOND_LOADER_IVT: + sld_img = token; + gen_fit_ivt = true; + strcpy(sld_img_ivt, sld_img); + strcat(sld_img_ivt, "-ivt"); + fprintf(stdout, "sld_img_ivt %s\n", sld_img_ivt); + break; case CMD_SIGNED_HDMI: signed_hdmi = token; break; @@ -147,6 +157,7 @@ static void parse_cfg_fld(int32_t *cmd, char *token, ap_start_addr = get_cfg_value(token, name, lineno); break; case CMD_SECOND_LOADER: + case CMD_SECOND_LOADER_IVT: sld_start_addr = get_cfg_value(token, name, lineno); break; } @@ -154,6 +165,7 @@ static void parse_cfg_fld(int32_t *cmd, char *token, case CFG_REG_VALUE: switch (*cmd) { case CMD_SECOND_LOADER: + case CMD_SECOND_LOADER_IVT: sld_src_off = get_cfg_value(token, name, lineno); break; } @@ -495,7 +507,7 @@ void build_image(int ofd) file_off += CSF_SIZE;
/* Second boot loader image */ - if (sld_img) { + if (sld_img && !gen_fit_ivt) { if (!using_fit) { fprintf(stderr, "Not support no fit\n"); exit(EXIT_FAILURE); @@ -562,7 +574,7 @@ void build_image(int ofd) csf_off -= ivt_offset; fill_zero(ofd, CSF_SIZE, csf_off);
- if (sld_img) { + if (sld_img && !gen_fit_ivt) { sld_header_off -= ivt_offset; ret = lseek(ofd, sld_header_off, SEEK_SET); if (ret < 0) { @@ -582,6 +594,30 @@ void build_image(int ofd) } }
+ if (gen_fit_ivt) { + sld_img_ivt_ofd = open(sld_img_ivt, + O_RDWR | O_CREAT | O_TRUNC | O_BINARY, + 0666); + if (sld_img_ivt_ofd < 0) { + fprintf(stderr, "Open %s failed\n", sld_img_ivt); + return; + } + copy_file(sld_img_ivt_ofd, sld_img, 0, sld_src_off, 0); + sld_csf_off = generate_ivt_for_fit(sld_img_ivt_ofd, + sld_src_off, + sld_start_addr, + &sld_load_addr) + 0x20; + /* Close output file */ + close(sld_img_ivt_ofd); + + fprintf(stdout, "\nFIT IVT IMAGE:\n"); + fprintf(stdout, " fit_csf_off \t\t0x%x\n", + sld_csf_off); + fprintf(stdout, " fit hab block: \t0x%x 0x%x 0x%x\n", + sld_load_addr, sld_src_off, + sld_csf_off - sld_src_off); + } + if (!signed_hdmi) dump_header_v2(imx_header, 0); dump_header_v2(imx_header, 1);
Peng Fan
