Re: [U-Boot] [PATCH 1/5] i.MX6Q: icorem6: Add modeboot env via board_late_init
Hi Stefano,
On Mon, Apr 17, 2017 at 9:18 PM, Jagan Teki jagannadh.teki@gmail.com wrote:
On Wed, Apr 12, 2017 at 9:27 PM, Stefano Babic sbabic@denx.de wrote:
On 07/04/2017 19:50, Jagan Teki wrote:
Hi Stefano,
On Mon, Mar 27, 2017 at 11:32 PM, Jagan Teki jagan@openedev.com wrote:
Add runtime, modeboot env which is setting mmcboot, or nandboot based on the bootdevice so-that conditional macros b/w MMC and NAND for CONFIG_BOOTCOMMAND should be avoided in config files.
Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Cc: Stefano Babic sbabic@denx.de Signed-off-by: Jagan Teki jagan@amarulasolutions.com
Can you take this series?
I could take, but I am just asking if you do not find another way to avoid code duplication. You have very similar boards, and code is simply duplicated. Let's see Pathch 1/5 and Patch 3/5:
+int board_late_init(void) +{
switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >>
IMX6_BMODE_SHIFT) {
case IMX6_BMODE_SD:
case IMX6_BMODE_ESD:
setenv("modeboot", "mmcboot");
break;
case IMX6_BMODE_NAND:
setenv("modeboot", "nandboot");
break;
default:
setenv("modeboot", "");
break;
And patch 3/5:
IMX6_BMODE_SHIFT) {
case IMX6_BMODE_SD:
break;
break;
default:
break;
Why do you not use the same factorization as for Freescale's boards ? A board/engicam/common could contain shared code, and you reuse it among boards. The same for the default environment: it is duplicated again.
Yes, I understand completely. will factorized the code in coming MW.
Any help?
thanks!
Jagan Teki
