[U-Boot-Users] insmod is not active in kernel?
13 May
2005
13 May
'05
10:39 a.m.
when I print : $insmod hello.o in the kernel the system tells me the insmode command is not implemented
how can I make the command active?(I don't wanna use busybox described in the pdf by now)
13 May
13 May
11:15 a.m.
Insmod is not an U-Boot command. You are completely off topic here.
You seem to be assuming that the whole world knows which PDF file you might read (or ignore). This assumption is wrong.
Software Engineering: Embedded and Realtime Systems, Embedded Linux
Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
He is truly wise who gains wisdom from another's mishap.
7299
1 comments
2 participants
zhonglei
