[U-Boot] [PATCH] test/py: make each unit test a pytest
A custom fixture named ut_subtest is implemented which is parametrized with the names of all unit tests that the U-Boot binary supports. This causes each U-Boot unit test to be exposes as a separate pytest. In turn, this allows more fine-grained pass/fail counts and test selection, e.g.:
test.py --bd sandbox -k ut_dm_usb
... will run about 8 tests at present.
Signed-off-by: Stephen Warren swarren@nvidia.com --- This depends on at least my recently sent "test/py: run C-based unit tests".
test/py/conftest.py | 105 ++++++++++++++++++++++++++++++++++++----------- test/py/tests/test_ut.py | 14 +++---- 2 files changed, 86 insertions(+), 33 deletions(-)
diff --git a/test/py/conftest.py b/test/py/conftest.py index 3e162cafcc4a..05491a2453c0 100644 --- a/test/py/conftest.py +++ b/test/py/conftest.py @@ -21,7 +21,9 @@ import pexpect import pytest from _pytest.runner import runtestprotocol import ConfigParser +import re import StringIO +import subprocess import sys
# Globals: The HTML log file, and the connection to the U-Boot console. @@ -189,8 +191,43 @@ def pytest_configure(config): import u_boot_console_exec_attach console = u_boot_console_exec_attach.ConsoleExecAttach(log, ubconfig)
-def pytest_generate_tests(metafunc): - """pytest hook: parameterize test functions based on custom rules. +re_ut_test_list = re.compile(r'_u_boot_list_2_(dm|env)_test_2_\1_test_(.*)\s*$') +def generate_ut_subtest(metafunc, fixture_name): + """Provide parametrization for a ut_subtest fixture. + + Determines the set of unit tests built into a U-Boot binary by parsing the + list of symbols present in the U-Boot binary. Provides this information to + test functions by parameterizing their ut_subtest fixture parameter. + + Args: + metafunc: The pytest test function. + fixture_name: The fixture name to test. + + Returns: + Nothing. + """ + + # This does rely on an objdump binary, but that's quite likely to be + # present. This approach trivially takes care of any source or Makefile- + # level conditional compilation which may occur, and matches the test + # execution order of a plain "ut dm" command. A source-scanning approach + # would not do neither. This approach also doesn't require access to the + # U-Boot source tree when running tests. + + cmd = 'objdump -t "%s" | sort' % (console.config.build_dir + '/u-boot') + out = subprocess.check_output(cmd, shell=True) + vals = [] + for l in out.splitlines(): + m = re_ut_test_list.search(l) + if not m: + continue + vals.append(m.group(1) + ' ' + m.group(2)) + + ids = ['ut_' + s.replace(' ', '_') for s in vals] + metafunc.parametrize(fixture_name, vals, ids=ids) + +def generate_config(metafunc, fixture_name): + """Provide parametrization for {env,brd}__ fixtures.
If a test function takes parameter(s) (fixture names) of the form brd__xxx or env__xxx, the brd and env configuration dictionaries are consulted to @@ -199,6 +236,7 @@ def pytest_generate_tests(metafunc):
Args: metafunc: The pytest test function. + fixture_name: The fixture name to test.
Returns: Nothing. @@ -208,30 +246,49 @@ def pytest_generate_tests(metafunc): 'brd': console.config.brd, 'env': console.config.env, } + parts = fixture_name.split('__') + if len(parts) < 2: + return + if parts[0] not in subconfigs: + return + subconfig = subconfigs[parts[0]] + vals = [] + val = subconfig.get(fixture_name, []) + # If that exact name is a key in the data source: + if val: + # ... use the dict value as a single parameter value. + vals = (val, ) + else: + # ... otherwise, see if there's a key that contains a list of + # values to use instead. + vals = subconfig.get(fixture_name+ 's', []) + def fixture_id(index, val): + try: + return val['fixture_id'] + except: + return fixture_name + str(index) + ids = [fixture_id(index, val) for (index, val) in enumerate(vals)] + metafunc.parametrize(fixture_name, vals, ids=ids) + +def pytest_generate_tests(metafunc): + """pytest hook: parameterize test functions based on custom rules. + + Check each test function parameter (fixture name) to see if it is one of + our custom names, and if so, provide the correct parametrization for that + parameter. + + Args: + metafunc: The pytest test function. + + Returns: + Nothing. + """ + for fn in metafunc.fixturenames: - parts = fn.split('__') - if len(parts) < 2: + if fn == 'ut_subtest': + generate_ut_subtest(metafunc, fn) continue - if parts[0] not in subconfigs: - continue - subconfig = subconfigs[parts[0]] - vals = [] - val = subconfig.get(fn, []) - # If that exact name is a key in the data source: - if val: - # ... use the dict value as a single parameter value. - vals = (val, ) - else: - # ... otherwise, see if there's a key that contains a list of - # values to use instead. - vals = subconfig.get(fn + 's', []) - def fixture_id(index, val): - try: - return val["fixture_id"] - except: - return fn + str(index) - ids = [fixture_id(index, val) for (index, val) in enumerate(vals)] - metafunc.parametrize(fn, vals, ids=ids) + generate_config(metafunc, fn)
@pytest.fixture(scope='function') def u_boot_console(request): diff --git a/test/py/tests/test_ut.py b/test/py/tests/test_ut.py index b033ca54d756..cd85b3ddc0ce 100644 --- a/test/py/tests/test_ut.py +++ b/test/py/tests/test_ut.py @@ -6,8 +6,8 @@ import os.path import pytest
@pytest.mark.buildconfigspec('ut_dm') -def test_ut_dm(u_boot_console): - """Execute the "ut dm" command.""" +def test_ut_dm_init(u_boot_console): + """Initialize data for ut dm tests."""
fn = u_boot_console.config.source_dir + '/testflash.bin' if not os.path.exists(fn): @@ -16,14 +16,10 @@ def test_ut_dm(u_boot_console): with open(fn, 'wb') as fh: fh.write(data)
- output = u_boot_console.run_command('ut dm') - assert output.endswith('Failures: 0') - -@pytest.mark.buildconfigspec('ut_env') -def test_ut_env(u_boot_console): - """Execute the "ut env" command.""" +def test_ut(u_boot_console, ut_subtest): + """Execute a "ut" subtest."""
- output = u_boot_console.run_command('ut env') + output = u_boot_console.run_command('ut ' + ut_subtest) assert output.endswith('Failures: 0')
@pytest.mark.buildconfigspec('ut_time')
Hi Stephen,
This seems a bit extreme. It might be better to move the remaining three commands under the 'ut' subcommand. Then all unit tests would be visible from the 'ut' help...
- """Provide parametrization for a ut_subtest fixture.
- Determines the set of unit tests built into a U-Boot binary by parsing the
- list of symbols present in the U-Boot binary. Provides this information to
- test functions by parameterizing their ut_subtest fixture parameter.
- Args:
- Returns:
Nothing.
- # This does rely on an objdump binary, but that's quite likely to be
- # present. This approach trivially takes care of any source or Makefile-
- # level conditional compilation which may occur, and matches the test
- # execution order of a plain "ut dm" command. A source-scanning approach
- # would not do neither. This approach also doesn't require access to the
- # U-Boot source tree when running tests.
- cmd = 'objdump -t "%s" | sort' % (console.config.build_dir + '/u-boot')
- out = subprocess.check_output(cmd, shell=True)
- vals = []
- for l in out.splitlines():
if not m:
continue
- ids = ['ut_' + s.replace(' ', '_') for s in vals]
- metafunc.parametrize(fixture_name, vals, ids=ids)
Returns: Nothing.
- parts = fixture_name.split('__')
return
return
- vals = []
- val = subconfig.get(fixture_name, [])
- if val:
vals = (val, )
- else:
try:
except:
- Check each test function parameter (fixture name) to see if it is one of
- our custom names, and if so, provide the correct parametrization for that
- parameter.
- Args:
- Returns:
Nothing.
- for fn in metafunc.fixturenames:
if len(parts) < 2:
continue
vals = []
if val:
vals = (val, )
else:
try:
except:
- """Execute a "ut" subtest."""
- output = u_boot_console.run_command('ut ' + ut_subtest) assert output.endswith('Failures: 0')
2.7.0
On 01/28/2016 08:52 PM, Simon Glass wrote:
Hi Stephen,
I'm not sure what you mean by "extreme"? Do you mean you don't want each unit test exposed as a separate pytest? I thought based on our previous conversation that was exactly what you wanted. If not, I'm not sure what the deficiency in the current code is; either all the dm subtests are executed at once by a single pytest with a single overall status, or they're each a separate pytest with individual status. Any grouping that's in between those seems like it would be entirely arbitrary?
Hi Stephen,
Hi Stephen,
I mean that there might be a simpler way to find out what unit tests are available in U-Boot rather than using objdump! Can the 'ut' command itself report this?
Also I'd prefer to move tests to be subcommands of 'ut' before wiring them up the the pytest stuff.
On 01/29/2016 11:23 AM, Simon Glass wrote:
Hi Stephen,
Hi Stephen,
Well, the Python code could parse the ELF binary itself... :-)
We can't parse the source code to determine the test list, since it'd be hard to determine which tests were actually compiled in (based on .config feature support), v.s. which were simply written but not compiled.
Perhaps we could add a new command-line option to U-Boot that /only/ prints out the list of support unit tests. That would mean executing the U-Boot binary on the host to determine the list though, which would limit the approach to sandbox; it couldn't ever work if we enabled unit tests on real HW. objdump should work in that scenario.
Or perhaps the build process could dump out a list of enabled unit tests, so test/py could simply read that file. At least that would push the objdump usage into the build process where it's basically guaranteed we have an objdump binary, plus we can use $(CROSS_COMPILE)objdump which would be better for cross-compiled binaries...
Hi Stephen,
Hi Stephen,
Hi Stephen,
Eek!
That was what I was thinking actually. The 'ut' command already prints a list when given no args, but you could add 'ut list'.
I'm not quite clear how useful the 'ut' tests are on real hardware. They are seldom enabled. Do you actually parse the U-Boot binary for the board?
Or do you think it would be acceptable to just have a hard-coded list of tests and try each one?
Or maybe your current approach is better than the alternatives...
On 01/29/2016 01:11 PM, Simon Glass wrote:
Hi Stephen,
Hi Stephen,
Hi Stephen,
Eek!
There's no other place in the test system that parses the U-Boot binary.
Overall, I still like the idea of simply parsing the binary best.
I see no reason why (at least some subset of) unit tests could not ever be enabled in non-sandbox builds. So, I'd like the test system not to assume that they won't be. This means we can't execute the binary to find out the list of enabled tests beforehand, since determining the list has to happen before we run any tests, and hence happen via code on the host machine, which can't run target binaries.
One improvement I can make is to run the objdump during the build process. As part of generating u-boot and u-boot.map, we can also call objdump to generate u-boot.syms. This isolates use of "compiler" tools like objdump to the Makefile; a more typical place to run them. The parsing of u-boot.syms can be left up to the test scripts.
Stephen Warren
