[U-Boot] [RFC PATCH] driver: pci: Fix regions for local memory
When adding local memory to PCI region, gd->ram_size is correct only if the memory is in one continuous block. In case memory is split into several banks, each bank should be added separately.
Signed-off-by: York Sun york.sun@nxp.com CC: Simon Glass sjg@chromium.org --- It was spotted when I was rewriting the code to reserve secure memory and forgot to reduce gd->ram_size. PCIe resumes working after fixing gd->ram_size. For my case, the memory is split into two banks. So base + gd->ram_size is not in memory. I don't know how it worked before. This change seems reasonable without digging into PCI code.
drivers/pci/pci-uclass.c | 18 +++++++++++++++++- 1 file changed, 17 insertions(+), 1 deletion(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 3b00e6a..eb80198 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -814,7 +814,22 @@ static int decode_regions(struct pci_controller *hose, const void *blob, pci_set_region(hose->regions + pos, pci_addr, addr, size, type); }
- /* Add a region for our local memory */ + /* Add region(s) for our local memory */ +#ifdef CONFIG_NR_DRAM_BANKS + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + base = gd->bd->bi_dram[i].start; + size = gd->bd->bi_dram[i].size; + if (gd->pci_ram_top && + gd->pci_ram_top >= base && + gd->pci_ram_top < base + size) + size = gd->pci_ram_top - base; + if (size) { + pci_set_region(hose->regions + hose->region_count++, + base, base, size, + PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); + } + } +#else size = gd->ram_size; #ifdef CONFIG_SYS_SDRAM_BASE base = CONFIG_SYS_SDRAM_BASE; @@ -823,6 +838,7 @@ static int decode_regions(struct pci_controller *hose, const void *blob, size = gd->pci_ram_top - base; pci_set_region(hose->regions + hose->region_count++, base, base, size, PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); +#endif
return 0; }
Hi York,
Unfortunately this breaks chromebook_link (x86).
Do you have any ideas or should I dig into it?
On 03/16/2017 08:14 PM, Simon Glass wrote:
Hi York,
Sorry I have no idea. If you can look into it, that will be great.
York
Hi York,
Hi York,
The problem is that x86 sets up PCI before relocation, thus before gd->bd is available.
I think several changes are needed:
1. Something like:
bool use_dram_banks = false;
#ifdef CONFIG_NR_DRAM_BANKS use_dram_banks = gd->bd != NULL; #endif if (use_dram_banks) { your new code } else { old code }
2. DRAM banks can have a size of 0, so check for that and skip if needed.
3. Check you don't overflow the size of the pci controller regions[] array.
Sorry I didn't notice this when reviewing it. It looked fine to me!
On 03/17/2017 04:43 AM, Simon Glass wrote:
Hi York,
Hi York,
That explains it.
- Something like:
Thanks for the explanation.
York
York Sun
york sun
