[U-Boot] Pull request: u-boot-arm/master
Hello Tom,
The following changes since commit bd23b22badadcdc414a900828253961fc5ec6c39:
Merge branch 'agust@denx.de-next' of git://git.denx.de/u-boot-staging (2012-10-15 13:37:22 -0700)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to 39826f09978a0a7070999acc15babf88f03e4051:
arm: fdt: Relocate fdt along with other data (2012-10-19 21:38:27 +0200)
---------------------------------------------------------------- 402jagan@gmail.com (1): versatile: board configs: Use buffered writes on flash
Albert ARIBAUD (1): Remove lh7a40x cpu and serial driver
Marek Vasut (2): dm: wdt: arm: Move tnetv107x into drivers/watchdog/ dm: Move s3c24xx USB driver to a proper place
Simon Glass (1): arm: fdt: Relocate fdt along with other data
Tom Rini (1): actux[123]: Update linker script for ELDK 4.2
Łukasz Dałek (1): h2200: Add support for iPAQ h2200 palmtop
MAINTAINERS | 4 + arch/arm/cpu/arm1176/tnetv107x/Makefile | 2 +- arch/arm/cpu/arm920t/s3c24x0/Makefile | 3 - arch/arm/cpu/arm920t/s3c24x0/usb.c | 71 --- arch/arm/cpu/lh7a40x/config.mk | 33 -- arch/arm/cpu/lh7a40x/cpu.c | 65 --- arch/arm/cpu/lh7a40x/speed.c | 83 ---- arch/arm/cpu/lh7a40x/start.S | 506 -------------------- arch/arm/cpu/lh7a40x/timer.c | 182 ------- arch/arm/lib/board.c | 22 + board/actux1/u-boot.lds | 2 +- board/actux2/u-boot.lds | 2 +- board/actux3/u-boot.lds | 2 +- {arch/arm/cpu/lh7a40x => board/h2200}/Makefile | 26 +- board/h2200/h2200-header.S | 27 ++ board/h2200/h2200.c | 53 ++ boards.cfg | 1 + doc/driver-model/UDM-serial.txt | 32 +- drivers/serial/Makefile | 1 - drivers/serial/serial_lh7a40x.c | 204 -------- drivers/usb/gadget/gadget_chips.h | 34 +- drivers/usb/host/Makefile | 1 + .../usb_ohci.c => drivers/usb/host/ohci-s3c24xx.c | 46 +- .../usb_ohci.h => drivers/usb/host/ohci-s3c24xx.h | 0 drivers/watchdog/Makefile | 1 + .../wdt.c => drivers/watchdog/tnetv107x_wdt.c | 0 include/configs/VCMA9.h | 1 + include/configs/ca9x4_ct_vxp.h | 2 + include/configs/h2200.h | 157 ++++++ include/configs/smdk2410.h | 1 + include/configs/tnetv107x_evm.h | 1 + include/configs/versatile.h | 1 + include/lh7a400.h | 75 --- include/lh7a404.h | 83 ---- include/lh7a40x.h | 279 ----------- include/lpd7a400_cpld.h | 195 -------- 36 files changed, 362 insertions(+), 1836 deletions(-) delete mode 100644 arch/arm/cpu/arm920t/s3c24x0/usb.c delete mode 100644 arch/arm/cpu/lh7a40x/config.mk delete mode 100644 arch/arm/cpu/lh7a40x/cpu.c delete mode 100644 arch/arm/cpu/lh7a40x/speed.c delete mode 100644 arch/arm/cpu/lh7a40x/start.S delete mode 100644 arch/arm/cpu/lh7a40x/timer.c rename {arch/arm/cpu/lh7a40x => board/h2200}/Makefile (71%) create mode 100644 board/h2200/h2200-header.S create mode 100644 board/h2200/h2200.c delete mode 100644 drivers/serial/serial_lh7a40x.c rename arch/arm/cpu/arm920t/s3c24x0/usb_ohci.c => drivers/usb/host/ohci-s3c24xx.c (97%) rename arch/arm/cpu/arm920t/s3c24x0/usb_ohci.h => drivers/usb/host/ohci-s3c24xx.h (100%) rename arch/arm/cpu/arm1176/tnetv107x/wdt.c => drivers/watchdog/tnetv107x_wdt.c (100%) create mode 100644 include/configs/h2200.h delete mode 100644 include/lh7a400.h delete mode 100644 include/lh7a404.h delete mode 100644 include/lh7a40x.h delete mode 100644 include/lpd7a400_cpld.h
Amicalement,
On Sat, Oct 20, 2012 at 01:55:42AM +0200, Albert ARIBAUD wrote:
Hello Tom,
??ukasz Da??ek (1): h2200: Add support for iPAQ h2200 palmtop
- .../usb_ohci.c => drivers/usb/host/ohci-s3c24xx.c | 46
Applied to u-boot/master with a trivial conflict fixed up, thanks!
Albert ARIBAUD
