[U-Boot] [PATCH 5/7] Factor out SC520 sub-features
Moved sub-features of the SC520 code which is currently selectively compiled using #ifdef out of sc520.c into individual files selectively compiled via the makefile
Signed-off-by: Graeme Russ <graeme.russ at gmail.com> --- cpu/i386/sc520/Makefile | 4 + cpu/i386/sc520/sc520.c | 277 ------------------------------------------ cpu/i386/sc520/sc520_pci.c | 171 ++++++++++++++++++++++++++ cpu/i386/sc520/sc520_ssi.c | 92 ++++++++++++++ cpu/i386/sc520/sc520_timer.c | 73 +++++++++++ 5 files changed, 340 insertions(+), 277 deletions(-) create mode 100644 cpu/i386/sc520/sc520_pci.c create mode 100644 cpu/i386/sc520/sc520_ssi.c create mode 100644 cpu/i386/sc520/sc520_timer.c
diff --git a/cpu/i386/sc520/Makefile b/cpu/i386/sc520/Makefile index ddfec23..87835b2 100644 --- a/cpu/i386/sc520/Makefile +++ b/cpu/i386/sc520/Makefile @@ -32,6 +32,10 @@ include $(TOPDIR)/config.mk LIB := $(obj)lib$(SOC).a
COBJS-$(CONFIG_SYS_SC520) += sc520.o +COBJS-$(CONFIG_SYS_SC520_SSI) += sc520_ssi.o +COBJS-$(CONFIG_SYS_SC520_TIMER) += sc520_timer.o +COBJS-$(CONFIG_PCI) += sc520_pci.o + SOBJS-$(CONFIG_SYS_SC520) += sc520_asm.o
SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) diff --git a/cpu/i386/sc520/sc520.c b/cpu/i386/sc520/sc520.c index 2ac3fd4..ae3b500 100644 --- a/cpu/i386/sc520/sc520.c +++ b/cpu/i386/sc520/sc520.c @@ -24,15 +24,8 @@ /* stuff specific for the sc520, * but idependent of implementation */
-#include <config.h> #include <common.h> -#include <config.h> -#include <pci.h> -#ifdef CONFIG_SYS_SC520_SSI -#include <asm/ic/ssi.h> -#endif #include <asm/io.h> -#include <asm/pci.h> #include <asm/ic/sc520.h>
DECLARE_GLOBAL_DATA_PTR; @@ -50,13 +43,6 @@ DECLARE_GLOBAL_DATA_PTR; * * void init_sc520(void) * unsigned long init_sc520_dram(void) - * void pci_sc520_init(struct pci_controller *hose) - * - * void reset_timer(void) - * ulong get_timer(ulong base) - * void set_timer(ulong t) - * void udelay(unsigned long usec) - * */
static u32 mmcr_base= 0xfffef000; @@ -241,269 +227,6 @@ unsigned long init_sc520_dram(void) return dram_present; }
- -#ifdef CONFIG_PCI - - -static struct { - u8 priority; - u16 level_reg; - u8 level_bit; -} sc520_irq[] = { - { SC520_IRQ0, SC520_MPICMODE, 0x01 }, - { SC520_IRQ1, SC520_MPICMODE, 0x02 }, - { SC520_IRQ2, SC520_SL1PICMODE, 0x02 }, - { SC520_IRQ3, SC520_MPICMODE, 0x08 }, - { SC520_IRQ4, SC520_MPICMODE, 0x10 }, - { SC520_IRQ5, SC520_MPICMODE, 0x20 }, - { SC520_IRQ6, SC520_MPICMODE, 0x40 }, - { SC520_IRQ7, SC520_MPICMODE, 0x80 }, - - { SC520_IRQ8, SC520_SL1PICMODE, 0x01 }, - { SC520_IRQ9, SC520_SL1PICMODE, 0x02 }, - { SC520_IRQ10, SC520_SL1PICMODE, 0x04 }, - { SC520_IRQ11, SC520_SL1PICMODE, 0x08 }, - { SC520_IRQ12, SC520_SL1PICMODE, 0x10 }, - { SC520_IRQ13, SC520_SL1PICMODE, 0x20 }, - { SC520_IRQ14, SC520_SL1PICMODE, 0x40 }, - { SC520_IRQ15, SC520_SL1PICMODE, 0x80 } -}; - - -/* The interrupt used for PCI INTA-INTD */ -int sc520_pci_ints[15] = { - -1, -1, -1, -1, -1, -1, -1, -1, - -1, -1, -1, -1, -1, -1, -1 -}; - -/* utility function to configure a pci interrupt */ -int pci_sc520_set_irq(int pci_pin, int irq) -{ - int i; - -# if 1 - printf("set_irq(): map INT%c to IRQ%d\n", pci_pin + 'A', irq); -#endif - if (irq < 0 || irq > 15) { - return -1; /* illegal irq */ - } - - if (pci_pin < 0 || pci_pin > 15) { - return -1; /* illegal pci int pin */ - } - - /* first disable any non-pci interrupt source that use - * this level */ - for (i=SC520_GPTMR0MAP;i<=SC520_GP10IMAP;i++) { - if (i>=SC520_PCIINTAMAP&&i<=SC520_PCIINTDMAP) { - continue; - } - if (read_mmcr_byte(i) == sc520_irq[irq].priority) { - write_mmcr_byte(i, SC520_IRQ_DISABLED); - } - } - - /* Set the trigger to level */ - write_mmcr_byte(sc520_irq[irq].level_reg, - read_mmcr_byte(sc520_irq[irq].level_reg) | sc520_irq[irq].level_bit); - - - if (pci_pin < 4) { - /* PCI INTA-INTD */ - /* route the interrupt */ - write_mmcr_byte(SC520_PCIINTAMAP + pci_pin, sc520_irq[irq].priority); - - - } else { - /* GPIRQ0-GPIRQ10 used for additional PCI INTS */ - write_mmcr_byte(SC520_GP0IMAP + pci_pin - 4, sc520_irq[irq].priority); - - /* also set the polarity in this case */ - write_mmcr_word(SC520_INTPINPOL, - read_mmcr_word(SC520_INTPINPOL) | (1 << (pci_pin-4))); - - } - - /* register the pin */ - sc520_pci_ints[pci_pin] = irq; - - - return 0; /* OK */ -} - -void pci_sc520_init(struct pci_controller *hose) -{ - hose->first_busno = 0; - hose->last_busno = 0xff; - - /* System memory space */ - pci_set_region(hose->regions + 0, - SC520_PCI_MEMORY_BUS, - SC520_PCI_MEMORY_PHYS, - SC520_PCI_MEMORY_SIZE, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - /* PCI memory space */ - pci_set_region(hose->regions + 1, - SC520_PCI_MEM_BUS, - SC520_PCI_MEM_PHYS, - SC520_PCI_MEM_SIZE, - PCI_REGION_MEM); - - /* ISA/PCI memory space */ - pci_set_region(hose->regions + 2, - SC520_ISA_MEM_BUS, - SC520_ISA_MEM_PHYS, - SC520_ISA_MEM_SIZE, - PCI_REGION_MEM); - - /* PCI I/O space */ - pci_set_region(hose->regions + 3, - SC520_PCI_IO_BUS, - SC520_PCI_IO_PHYS, - SC520_PCI_IO_SIZE, - PCI_REGION_IO); - - /* ISA/PCI I/O space */ - pci_set_region(hose->regions + 4, - SC520_ISA_IO_BUS, - SC520_ISA_IO_PHYS, - SC520_ISA_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = 5; - - pci_setup_type1(hose, - SC520_REG_ADDR, - SC520_REG_DATA); - - pci_register_hose(hose); - - hose->last_busno = pci_hose_scan(hose); - - /* enable target memory acceses on host brige */ - pci_write_config_word(0, PCI_COMMAND, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); - -} - - -#endif - -#ifdef CONFIG_SYS_SC520_TIMER - - -void reset_timer(void) -{ - write_mmcr_word(SC520_GPTMR0CNT, 0); - write_mmcr_word(SC520_GPTMR0CTL, 0x6001); - -} - -ulong get_timer(ulong base) -{ - /* fixme: 30 or 33 */ - return read_mmcr_word(SC520_GPTMR0CNT) / 33; -} - -void set_timer(ulong t) -{ - /* FixMe: use two cascade coupled timers */ - write_mmcr_word(SC520_GPTMR0CTL, 0x4001); - write_mmcr_word(SC520_GPTMR0CNT, t*33); - write_mmcr_word(SC520_GPTMR0CTL, 0x6001); -} - - -void udelay(unsigned long usec) -{ - int m=0; - long u; - - read_mmcr_word(SC520_SWTMRMILLI); - read_mmcr_word(SC520_SWTMRMICRO); - -#if 0 - /* do not enable this line, udelay is used in the serial driver -> recursion */ - printf("udelay: %ld m.u %d.%d tm.tu %d.%d\n", usec, m, u, tm, tu); -#endif - while (1) { - - m += read_mmcr_word(SC520_SWTMRMILLI); - u = read_mmcr_word(SC520_SWTMRMICRO) + (m * 1000); - - if (usec <= u) { - break; - } - } -} - -#endif - -int ssi_set_interface(int freq, int lsb_first, int inv_clock, int inv_phase) -{ - u8 temp=0; - - if (freq >= 8192) { - temp |= CTL_CLK_SEL_4; - } else if (freq >= 4096) { - temp |= CTL_CLK_SEL_8; - } else if (freq >= 2048) { - temp |= CTL_CLK_SEL_16; - } else if (freq >= 1024) { - temp |= CTL_CLK_SEL_32; - } else if (freq >= 512) { - temp |= CTL_CLK_SEL_64; - } else if (freq >= 256) { - temp |= CTL_CLK_SEL_128; - } else if (freq >= 128) { - temp |= CTL_CLK_SEL_256; - } else { - temp |= CTL_CLK_SEL_512; - } - - if (!lsb_first) { - temp |= MSBF_ENB; - } - - if (inv_clock) { - temp |= CLK_INV_ENB; - } - - if (inv_phase) { - temp |= PHS_INV_ENB; - } - - write_mmcr_byte(SC520_SSICTL, temp); - - return 0; -} - -u8 ssi_txrx_byte(u8 data) -{ - write_mmcr_byte(SC520_SSIXMIT, data); - while ((read_mmcr_byte(SC520_SSISTA)) & SSISTA_BSY); - write_mmcr_byte(SC520_SSICMD, SSICMD_CMD_SEL_XMITRCV); - while ((read_mmcr_byte(SC520_SSISTA)) & SSISTA_BSY); - return read_mmcr_byte(SC520_SSIRCV); -} - - -void ssi_tx_byte(u8 data) -{ - write_mmcr_byte(SC520_SSIXMIT, data); - while ((read_mmcr_byte(SC520_SSISTA)) & SSISTA_BSY); - write_mmcr_byte(SC520_SSICMD, SSICMD_CMD_SEL_XMIT); -} - -u8 ssi_rx_byte(void) -{ - while ((read_mmcr_byte(SC520_SSISTA)) & SSISTA_BSY); - write_mmcr_byte(SC520_SSICMD, SSICMD_CMD_SEL_RCV); - while ((read_mmcr_byte(SC520_SSISTA)) & SSISTA_BSY); - return read_mmcr_byte(SC520_SSIRCV); -} - #ifdef CONFIG_SYS_SC520_RESET void reset_cpu(ulong addr) { diff --git a/cpu/i386/sc520/sc520_pci.c b/cpu/i386/sc520/sc520_pci.c new file mode 100644 index 0000000..38b837e --- /dev/null +++ b/cpu/i386/sc520/sc520_pci.c @@ -0,0 +1,171 @@ +/* + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB daniel@omicron.se. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* stuff specific for the sc520, but independent of implementation */ + +#include <common.h> +#include <pci.h> +#include <asm/pci.h> +#include <asm/ic/sc520.h> + +static struct { + u8 priority; + u16 level_reg; + u8 level_bit; +} sc520_irq[] = { + { SC520_IRQ0, SC520_MPICMODE, 0x01 }, + { SC520_IRQ1, SC520_MPICMODE, 0x02 }, + { SC520_IRQ2, SC520_SL1PICMODE, 0x02 }, + { SC520_IRQ3, SC520_MPICMODE, 0x08 }, + { SC520_IRQ4, SC520_MPICMODE, 0x10 }, + { SC520_IRQ5, SC520_MPICMODE, 0x20 }, + { SC520_IRQ6, SC520_MPICMODE, 0x40 }, + { SC520_IRQ7, SC520_MPICMODE, 0x80 }, + + { SC520_IRQ8, SC520_SL1PICMODE, 0x01 }, + { SC520_IRQ9, SC520_SL1PICMODE, 0x02 }, + { SC520_IRQ10, SC520_SL1PICMODE, 0x04 }, + { SC520_IRQ11, SC520_SL1PICMODE, 0x08 }, + { SC520_IRQ12, SC520_SL1PICMODE, 0x10 }, + { SC520_IRQ13, SC520_SL1PICMODE, 0x20 }, + { SC520_IRQ14, SC520_SL1PICMODE, 0x40 }, + { SC520_IRQ15, SC520_SL1PICMODE, 0x80 } +}; + + +/* The interrupt used for PCI INTA-INTD */ +int sc520_pci_ints[15] = { + -1, -1, -1, -1, -1, -1, -1, -1, + -1, -1, -1, -1, -1, -1, -1 +}; + +/* utility function to configure a pci interrupt */ +int pci_sc520_set_irq(int pci_pin, int irq) +{ + int i; + +# if 1 + printf("set_irq(): map INT%c to IRQ%d\n", pci_pin + 'A', irq); +#endif + if (irq < 0 || irq > 15) { + return -1; /* illegal irq */ + } + + if (pci_pin < 0 || pci_pin > 15) { + return -1; /* illegal pci int pin */ + } + + /* first disable any non-pci interrupt source that use + * this level */ + for (i=SC520_GPTMR0MAP;i<=SC520_GP10IMAP;i++) { + if (i>=SC520_PCIINTAMAP&&i<=SC520_PCIINTDMAP) { + continue; + } + if (read_mmcr_byte(i) == sc520_irq[irq].priority) { + write_mmcr_byte(i, SC520_IRQ_DISABLED); + } + } + + /* Set the trigger to level */ + write_mmcr_byte(sc520_irq[irq].level_reg, + read_mmcr_byte(sc520_irq[irq].level_reg) | sc520_irq[irq].level_bit); + + + if (pci_pin < 4) { + /* PCI INTA-INTD */ + /* route the interrupt */ + write_mmcr_byte(SC520_PCIINTAMAP + pci_pin, sc520_irq[irq].priority); + + + } else { + /* GPIRQ0-GPIRQ10 used for additional PCI INTS */ + write_mmcr_byte(SC520_GP0IMAP + pci_pin - 4, sc520_irq[irq].priority); + + /* also set the polarity in this case */ + write_mmcr_word(SC520_INTPINPOL, + read_mmcr_word(SC520_INTPINPOL) | (1 << (pci_pin-4))); + + } + + /* register the pin */ + sc520_pci_ints[pci_pin] = irq; + + + return 0; /* OK */ +} + +void pci_sc520_init(struct pci_controller *hose) +{ + hose->first_busno = 0; + hose->last_busno = 0xff; + + /* System memory space */ + pci_set_region(hose->regions + 0, + SC520_PCI_MEMORY_BUS, + SC520_PCI_MEMORY_PHYS, + SC520_PCI_MEMORY_SIZE, + PCI_REGION_MEM | PCI_REGION_MEMORY); + + /* PCI memory space */ + pci_set_region(hose->regions + 1, + SC520_PCI_MEM_BUS, + SC520_PCI_MEM_PHYS, + SC520_PCI_MEM_SIZE, + PCI_REGION_MEM); + + /* ISA/PCI memory space */ + pci_set_region(hose->regions + 2, + SC520_ISA_MEM_BUS, + SC520_ISA_MEM_PHYS, + SC520_ISA_MEM_SIZE, + PCI_REGION_MEM); + + /* PCI I/O space */ + pci_set_region(hose->regions + 3, + SC520_PCI_IO_BUS, + SC520_PCI_IO_PHYS, + SC520_PCI_IO_SIZE, + PCI_REGION_IO); + + /* ISA/PCI I/O space */ + pci_set_region(hose->regions + 4, + SC520_ISA_IO_BUS, + SC520_ISA_IO_PHYS, + SC520_ISA_IO_SIZE, + PCI_REGION_IO); + + hose->region_count = 5; + + pci_setup_type1(hose, + SC520_REG_ADDR, + SC520_REG_DATA); + + pci_register_hose(hose); + + hose->last_busno = pci_hose_scan(hose); + + /* enable target memory acceses on host brige */ + pci_write_config_word(0, PCI_COMMAND, + PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); + +} diff --git a/cpu/i386/sc520/sc520_ssi.c b/cpu/i386/sc520/sc520_ssi.c new file mode 100644 index 0000000..dd667ca --- /dev/null +++ b/cpu/i386/sc520/sc520_ssi.c @@ -0,0 +1,92 @@ +/* + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB daniel@omicron.se. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* stuff specific for the sc520, but independent of implementation */ + +#include <common.h> +#include <asm/ic/ssi.h> +#include <asm/ic/sc520.h> + +int ssi_set_interface(int freq, int lsb_first, int inv_clock, int inv_phase) +{ + u8 temp=0; + + if (freq >= 8192) { + temp |= CTL_CLK_SEL_4; + } else if (freq >= 4096) { + temp |= CTL_CLK_SEL_8; + } else if (freq >= 2048) { + temp |= CTL_CLK_SEL_16; + } else if (freq >= 1024) { + temp |= CTL_CLK_SEL_32; + } else if (freq >= 512) { + temp |= CTL_CLK_SEL_64; + } else if (freq >= 256) { + temp |= CTL_CLK_SEL_128; + } else if (freq >= 128) { + temp |= CTL_CLK_SEL_256; + } else { + temp |= CTL_CLK_SEL_512; + } + + if (!lsb_first) { + temp |= MSBF_ENB; + } + + if (inv_clock) { + temp |= CLK_INV_ENB; + } + + if (inv_phase) { + temp |= PHS_INV_ENB; + } + + write_mmcr_byte(SC520_SSICTL, temp); + + return 0; +} + +u8 ssi_txrx_byte(u8 data) +{ + write_mmcr_byte(SC520_SSIXMIT, data); + while ((read_mmcr_byte(SC520_SSISTA)) & SSISTA_BSY); + write_mmcr_byte(SC520_SSICMD, SSICMD_CMD_SEL_XMITRCV); + while ((read_mmcr_byte(SC520_SSISTA)) & SSISTA_BSY); + return read_mmcr_byte(SC520_SSIRCV); +} + + +void ssi_tx_byte(u8 data) +{ + write_mmcr_byte(SC520_SSIXMIT, data); + while ((read_mmcr_byte(SC520_SSISTA)) & SSISTA_BSY); + write_mmcr_byte(SC520_SSICMD, SSICMD_CMD_SEL_XMIT); +} + +u8 ssi_rx_byte(void) +{ + while ((read_mmcr_byte(SC520_SSISTA)) & SSISTA_BSY); + write_mmcr_byte(SC520_SSICMD, SSICMD_CMD_SEL_RCV); + while ((read_mmcr_byte(SC520_SSISTA)) & SSISTA_BSY); + return read_mmcr_byte(SC520_SSIRCV); +} diff --git a/cpu/i386/sc520/sc520_timer.c b/cpu/i386/sc520/sc520_timer.c new file mode 100644 index 0000000..7578511 --- /dev/null +++ b/cpu/i386/sc520/sc520_timer.c @@ -0,0 +1,73 @@ +/* + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB daniel@omicron.se. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* stuff specific for the sc520, but independent of implementation */ + +#include <common.h> +#include <asm/interrupt.h> +#include <asm/ic/sc520.h> + +void reset_timer(void) +{ + write_mmcr_word(SC520_GPTMR0CNT, 0); + write_mmcr_word(SC520_GPTMR0CTL, 0x6001); + +} + +ulong get_timer(ulong base) +{ + /* fixme: 30 or 33 */ + return read_mmcr_word(SC520_GPTMR0CNT) / 33; +} + +void set_timer(ulong t) +{ + /* FixMe: use two cascade coupled timers */ + write_mmcr_word(SC520_GPTMR0CTL, 0x4001); + write_mmcr_word(SC520_GPTMR0CNT, t*33); + write_mmcr_word(SC520_GPTMR0CTL, 0x6001); +} + + +void udelay(unsigned long usec) +{ + int m=0; + long u; + + read_mmcr_word(SC520_SWTMRMILLI); + read_mmcr_word(SC520_SWTMRMICRO); + +#if 0 + /* do not enable this line, udelay is used in the serial driver -> recursion */ + printf("udelay: %ld m.u %d.%d tm.tu %d.%d\n", usec, m, u, tm, tu); +#endif + while (1) { + + m += read_mmcr_word(SC520_SWTMRMILLI); + u = read_mmcr_word(SC520_SWTMRMICRO) + (m * 1000); + + if (usec <= u) { + break; + } + } +}
Dear Graeme Russ,
cpu/i386/sc520/Makefile | 4 + cpu/i386/sc520/sc520.c | 277 --------------------------------------=
Applied to "next" branch. Thanks.
Graeme Russ
