[U-Boot] [RFC PATCH] rockchip: rk3288: skip lowlevel_init process
lowlevel_init() is never needed for rk3288, so drop it.
Signed-off-by: Ziyuan Xu xzy.xu@rock-chips.com
arch/arm/mach-rockchip/board.c | 4 ---- arch/arm/mach-rockchip/rk3288-board-spl.c | 4 ---- include/configs/rk3288_common.h | 1 + 3 files changed, 1 insertion(+), 8 deletions(-)
diff --git a/arch/arm/mach-rockchip/board.c b/arch/arm/mach-rockchip/board.c index bec756d..6c36bf9 100644 --- a/arch/arm/mach-rockchip/board.c +++ b/arch/arm/mach-rockchip/board.c @@ -81,10 +81,6 @@ void enable_caches(void) } #endif
-void lowlevel_init(void) -{ -} - #if defined(CONFIG_USB_GADGET) && defined(CONFIG_USB_GADGET_DWC2_OTG) #include <usb.h> #include <usb/dwc2_udc.h> diff --git a/arch/arm/mach-rockchip/rk3288-board-spl.c b/arch/arm/mach-rockchip/rk3288-board-spl.c index e0d92a6..ae509ff 100644 --- a/arch/arm/mach-rockchip/rk3288-board-spl.c +++ b/arch/arm/mach-rockchip/rk3288-board-spl.c @@ -280,7 +280,3 @@ err: /* No way to report error here */ hang(); } - -void lowlevel_init(void) -{ -} diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index d3d4c68..e909ef9 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -11,6 +11,7 @@
#include <asm/arch/hardware.h>
+#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY #define CONFIG_SYS_NO_FLASH #define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_ENV_SIZE 0x2000
Tested on firefly-rk3288: Tested-by: Simon Glass sjg@chromium.org
Applied to u-boot-rockchip/next, thanks!
Ziyuan Xu
