[PATCH 0/4] Repeal and replace TZDRAM_ related config options
When enabling OPTEE support in the config menu, one is asked for the TZDRAM region and OPTEE load address. It would seem that these are very important values, not just some half-assed bollocks.
There are currently three sources of information regarding OPTEE and its associated DRAM region: 1) Devicetree "/reserved-memory" nodes 2) uImage and FIT load-address and entry-point 3) The CONFIG_s currently under scrutiny
(1) and (2) are sufficient to identify and reject OP-TEE images which fall outside TZDRAM. Such a check might make sense in the context of not bricking a device. But if an incompatible image was already installed, the device is likely soft-bricked anyway and needs manual intervention. This series doesn't implement such a check.
It is possible for (1) and (3) to be in conflict. Because the values in (3) default to 0x0, it is very likely to happen. Such a situation causes the "bootm" command to reject otherwise valid OP-TEE images. Thus a perfectly tuned u-boot which doesn't also set (3) will be non-functional with respect to OP-TEE images.
This becomes confusing, and has caused yours truly a disproportionate amount of grief. Fortunately, SPL can also load OP-TEE images, and does not even look at the values in (3). It only uses (1) and (2) to determine the appropriate values for firing up OP-TEE. It is more reliable and easy to use than "bootm".
We are able to remove these configs without breaking anything. This also resolves the problems with "bootm" mentioned earlier.
I hypothesize that one could re-add the removed checks from optee_verify_image() by deriving TZDRAM information from (1) instead of (3). I chose not to implement it because I don't see the value.
Alexandru Gagniuc (4): lib: optee: Avoid CONFIG_TZDRAM_* in optee_verify_bootm_image() lib: optee: Remove CONFIG_OPTEE_TZDRAM_BASE lib: optee: Remove CONFIG_OPTEE_LOAD_ADDR arm: imx: mx7: Move CONFIG_OPTEE_TZDRAM_SIZE from lib/optee
arch/arm/mach-imx/mx7/Kconfig | 8 ++++++++ configs/warp7_bl33_defconfig | 1 - configs/warp7_defconfig | 2 -- include/configs/warp7.h | 5 ----- include/tee/optee.h | 14 -------------- lib/optee/Kconfig | 23 ----------------------- lib/optee/optee.c | 21 ++++++--------------- 7 files changed, 14 insertions(+), 60 deletions(-)
The configs TZDRAM_BASE and TZDRAM_SIZE are expected to describe the memory allocated to the OPTEE region. according to according to commit c5a6e8bd00cc ("optee: Add optee_verify_bootm_image()"). The TZDRAM is with some limitations, described by "/reserved-memory" nodes in the devicetree.
Consequently TZDRAM_BASE and TZDRAM_SIZE can point to imaginary regions which have nothing to do with actual DRAM. They are not used to configure the hardware or set up the Trust Zone Controller (TZC) for OP-TEE -- the devicetree values are used instead.
When a valid OP-TEE image does not fall within the region described by these configs, u-boot will refuse to load it. In fact, it mostly serves to cause "bootm" to reject perfectly good OP-TEE images.
Ironically, someone has to correctly configure the devicetree for TZDRAM, then go back and enter the same information in Kconfig for "bootm". To remedy this, do not use TZDRAM_BASE and TZDRAM_SIZE in the verification of OPTEE images.
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- include/tee/optee.h | 14 -------------- lib/optee/optee.c | 21 ++++++--------------- 2 files changed, 6 insertions(+), 29 deletions(-)
diff --git a/include/tee/optee.h b/include/tee/optee.h index ebdfe5e98d..764a55b264 100644 --- a/include/tee/optee.h +++ b/include/tee/optee.h @@ -43,20 +43,6 @@ optee_image_get_load_addr(const struct image_header *hdr) return optee_image_get_entry_point(hdr) - sizeof(struct optee_header); }
-#if defined(CONFIG_OPTEE) -int optee_verify_image(struct optee_header *hdr, unsigned long tzdram_start, - unsigned long tzdram_len, unsigned long image_len); -#else -static inline int optee_verify_image(struct optee_header *hdr, - unsigned long tzdram_start, - unsigned long tzdram_len, - unsigned long image_len) -{ - return -EPERM; -} - -#endif - #if defined(CONFIG_OPTEE) int optee_verify_bootm_image(unsigned long image_addr, unsigned long image_load_addr, diff --git a/lib/optee/optee.c b/lib/optee/optee.c index 672690dc53..67e46d71d6 100644 --- a/lib/optee/optee.c +++ b/lib/optee/optee.c @@ -16,14 +16,12 @@
#define optee_hdr_err_msg \ "OPTEE verification error:" \ - "\n\thdr=%p image=0x%08lx magic=0x%08x tzdram 0x%08lx-0x%08lx " \ + "\n\thdr=%p image=0x%08lx magic=0x%08x" \ "\n\theader lo=0x%08x hi=0x%08x size=0x%08lx arch=0x%08x" \ "\n\tuimage params 0x%08lx-0x%08lx\n"
-int optee_verify_image(struct optee_header *hdr, unsigned long tzdram_start, - unsigned long tzdram_len, unsigned long image_len) +static int optee_verify_image(struct optee_header *hdr, unsigned long image_len) { - unsigned long tzdram_end = tzdram_start + tzdram_len; uint32_t tee_file_size;
tee_file_size = hdr->init_size + hdr->paged_size + @@ -31,11 +29,7 @@ int optee_verify_image(struct optee_header *hdr, unsigned long tzdram_start,
if (hdr->magic != OPTEE_MAGIC || hdr->version != OPTEE_VERSION || - hdr->init_load_addr_hi > tzdram_end || - hdr->init_load_addr_lo < tzdram_start || - tee_file_size > tzdram_len || - tee_file_size != image_len || - (hdr->init_load_addr_lo + tee_file_size) > tzdram_end) { + tee_file_size != image_len) { return -EINVAL; }
@@ -47,12 +41,9 @@ int optee_verify_bootm_image(unsigned long image_addr, unsigned long image_len) { struct optee_header *hdr = (struct optee_header *)image_addr; - unsigned long tzdram_start = CONFIG_OPTEE_TZDRAM_BASE; - unsigned long tzdram_len = CONFIG_OPTEE_TZDRAM_SIZE; - int ret;
- ret = optee_verify_image(hdr, tzdram_start, tzdram_len, image_len); + ret = optee_verify_image(hdr, image_len); if (ret) goto error;
@@ -63,8 +54,8 @@ int optee_verify_bootm_image(unsigned long image_addr,
return ret; error: - printf(optee_hdr_err_msg, hdr, image_addr, hdr->magic, tzdram_start, - tzdram_start + tzdram_len, hdr->init_load_addr_lo, + printf(optee_hdr_err_msg, hdr, image_addr, hdr->magic, + hdr->init_load_addr_lo, hdr->init_load_addr_hi, image_len, hdr->arch, image_load_addr, image_load_addr + image_len);
It is no longer used in u-boot. Information about the TZDRAM location is usually available in the devicetree as "/reserved-memory/" nodes. Because this isn't used, remove it.
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- configs/warp7_bl33_defconfig | 1 - configs/warp7_defconfig | 1 - lib/optee/Kconfig | 8 -------- 3 files changed, 10 deletions(-)
diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index ec078178ab..f9c0add926 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -67,4 +67,3 @@ CONFIG_USB_ETH_CDC=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_OPTEE_TZDRAM_SIZE=0x02000000 -CONFIG_OPTEE_TZDRAM_BASE=0x9e000000 diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 19c0c183f7..1514019064 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -73,5 +73,4 @@ CONFIG_USB_ETH_CDC=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_OPTEE_LOAD_ADDR=0x84000000 CONFIG_OPTEE_TZDRAM_SIZE=0x3000000 -CONFIG_OPTEE_TZDRAM_BASE=0x9d000000 CONFIG_BOOTM_OPTEE=y diff --git a/lib/optee/Kconfig b/lib/optee/Kconfig index c398f9b953..831e9f4ac6 100644 --- a/lib/optee/Kconfig +++ b/lib/optee/Kconfig @@ -22,14 +22,6 @@ config OPTEE_TZDRAM_SIZE The size of pre-allocated Trust Zone DRAM to allocate for the OPTEE runtime.
-config OPTEE_TZDRAM_BASE - hex "Base address of Trust-Zone RAM for the OPTEE image" - default 0x00000000 - depends on OPTEE - help - The base address of pre-allocated Trust Zone DRAM for - the OPTEE runtime. - config BOOTM_OPTEE bool "Support OPTEE bootm command" select BOOTM_LINUX
This value is not used by u-boot, and it should not. The load address of an OPTEE image is defined by said image. Either a uImage or a FIT will have a defined load address and entry point. Those values are the correct ones, not CONFIG_OPTEE_LOAD_ADDR.
Commit f25006b96e9f ("optee: Add CONFIG_OPTEE_LOAD_ADDR") justifies this config by requiring its presence in u-boot's .config for other images as part of a larger build, claiming it is "the best way".
This argument is not persuasive. U-boot's configuration is driven by platform requirements, not the other way around. It seems more likely that the argument is conflating tooling issues with Kconfig. Yocto and buildroot have excellent mechanisms for defining values across the board (pun intended). u-boot's Kconfig is the wrong place to do it.
Furthermore, it is not "best" for u-boot because it hardcodes a value which is then not used. In fact the load address that u-boot uses is the one derived from the OPTEE image.
Confused yet? I sure was. To prevent future confusion, remove CONFIG_OPTEE_LOAD_ADDR.
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- configs/warp7_defconfig | 1 - include/configs/warp7.h | 5 ----- lib/optee/Kconfig | 7 ------- 3 files changed, 13 deletions(-)
diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 1514019064..b872548464 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -71,6 +71,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" -CONFIG_OPTEE_LOAD_ADDR=0x84000000 CONFIG_OPTEE_TZDRAM_SIZE=0x3000000 CONFIG_BOOTM_OPTEE=y diff --git a/include/configs/warp7.h b/include/configs/warp7.h index a5d52e3977..0df7e3b146 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -34,10 +34,6 @@ #define BOOT_SCR_STRING "source ${bootscriptaddr}\0" #endif
-#ifndef CONFIG_OPTEE_LOAD_ADDR -#define CONFIG_OPTEE_LOAD_ADDR 0 -#endif - #define CONFIG_EXTRA_ENV_SETTINGS \ CONFIG_DFU_ENV_SETTINGS \ "script=boot.scr\0" \ @@ -52,7 +48,6 @@ "fdt_file=imx7s-warp.dtb\0" \ "fdt_addr=" __stringify(CONFIG_SYS_FDT_ADDR)"\0" \ "fdtovaddr=0x83100000\0" \ - "optee_addr=" __stringify(CONFIG_OPTEE_LOAD_ADDR)"\0" \ "boot_fdt=try\0" \ "ip_dyn=yes\0" \ "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ diff --git a/lib/optee/Kconfig b/lib/optee/Kconfig index 831e9f4ac6..26677b7548 100644 --- a/lib/optee/Kconfig +++ b/lib/optee/Kconfig @@ -7,13 +7,6 @@ config OPTEE OPTEE specific checks before booting an OPTEE image created with mkimage.
-config OPTEE_LOAD_ADDR - hex "OPTEE load address" - default 0x00000000 - depends on OPTEE - help - The load address of the bootable OPTEE binary. - config OPTEE_TZDRAM_SIZE hex "Amount of Trust-Zone RAM for the OPTEE image" default 0x0000000
This config is only used by three boards with this SOC. Most other platforms derive this information from devicetree, and are unlikely to ever need this config.
Moreover, it is confusing when Kconfig asks for this value under "Support OPTEE images", but does not do anything with the value. Move it to imx7 for those boards who still make use of it.
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- arch/arm/mach-imx/mx7/Kconfig | 8 ++++++++ lib/optee/Kconfig | 8 -------- 2 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-imx/mx7/Kconfig b/arch/arm/mach-imx/mx7/Kconfig index adedc01164..26cb10f6a8 100644 --- a/arch/arm/mach-imx/mx7/Kconfig +++ b/arch/arm/mach-imx/mx7/Kconfig @@ -23,6 +23,14 @@ config SPL_TEXT_BASE depends on SPL default 0x00912000
+config OPTEE_TZDRAM_SIZE + hex "Amount of Trust-Zone RAM for the OPTEE image" + default 0x0000000 + depends on OPTEE + help + The size of pre-allocated Trust Zone DRAM to allocate for the OPTEE + runtime. + choice prompt "MX7 board select" optional diff --git a/lib/optee/Kconfig b/lib/optee/Kconfig index 26677b7548..9d11b5f37d 100644 --- a/lib/optee/Kconfig +++ b/lib/optee/Kconfig @@ -7,14 +7,6 @@ config OPTEE OPTEE specific checks before booting an OPTEE image created with mkimage.
-config OPTEE_TZDRAM_SIZE - hex "Amount of Trust-Zone RAM for the OPTEE image" - default 0x0000000 - depends on OPTEE - help - The size of pre-allocated Trust Zone DRAM to allocate for the OPTEE - runtime. - config BOOTM_OPTEE bool "Support OPTEE bootm command" select BOOTM_LINUX
Alexandru Gagniuc
